  4. [Vorstellung] Meine zweite Visualisierung
    apollon77A
vistemplate
1.3k Beiträge 148 Kommentatoren 745.7k Aufrufe 157 Beobachtet
  • G
    G
    gfrene
    @Kuddel könntest du die Scripte zur Verfügung stellen wie du die Zonenreinigung umgesetzt hast :-)
    Danke dir und 1a VIS
    • G gfrene
      K
      K
      Kuddel
      @gfrene
      Skript für die Zonenreinung:
      <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="A3mcx,(O{KZ0SAwINJkl" x="-362.00000000000057" y="10037.5">
        <mutation items="1"></mutation>
        <value name="OID0">
          <shadow type="field_oid" id="=^9T:bBq#a4Q,Nh;+#c=">
            <field name="oid">javascript.0.NoNo.Zonen_Reinigung</field>
          </shadow>
        </value>
        <statement name="STATEMENT">
          <block type="variables_set" id="?Vkt^R1:a?ZRu{JyI(Vh">
            <field name="VAR">Buero</field>
            <value name="VALUE">
              <block type="text" id="a=(?PpOyB5iGBLjQ6Aap">
                <field name="TEXT">app_zoned_clean;[[18471,19907,22571,23007,1]]</field>
              </block>
            </value>
            <next>
              <block type="variables_set" id="sYCBkY(T4jb-]X+2Eak,">
                <field name="VAR">Flur</field>
                  <block type="text" id="%-KCb~RlSSjV6q_]/?j*">
                    <field name="TEXT">app_zoned_clean;[[22637,19580,29787,25130,2]]</field>
                  </block>
                </value>
                <next>
                  <block type="variables_set" id=";M*u(QADG3GbZdCgq8GG">
                    <field name="VAR">GaesteWC</field>
                      <block type="text" id="lS%?^.}[p`XS/bXa8f#g">
                        <field name="TEXT">app_zoned_clean;[[28009,25008,29709,26458,2]]</field>
                      </block>
                    </value>
                    <next>
                      <block type="variables_set" id="H#[grBDiKs9O6?Cx9J4#">
                        <field name="VAR">Kueche</field>
                          <block type="text" id="qSyl{KE}K,}iq}DCvI!1">
                            <field name="TEXT">app_zoned_clean;[[26727,25000,29777,29250,2]]</field>
                          </block>
                        </value>
                        <next>
                          <block type="variables_set" id="q[mk=w]QG/B:uT%rh)%7">
                            <field name="VAR">Wohnzimmer</field>
                              <block type="text" id="Qd0=lq+^}-*HGJNu^hHE">
                                <field name="TEXT">app_zoned_clean;[[18626,25160,25976,29110,2],[18569,23306,22519,25106,2]]</field>
                              </block>
                            </value>
                            <next>
                              <block type="controls_if" id="lH-2B:yzLcZ]@Mk~(nc]">
                                <value name="IF0">
                                  <block type="logic_compare" id="Bp2=TLQfL3|kHV=a:vvq">
                                    <field name="OP">EQ</field>
                                    <value name="A">
                                      <block type="get_value" id="Hmzyi5vAP`/`|r8fEf=T">
                                        <field name="OID">javascript.0.NoNo.Zonen_Reinigung</field>
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="math_number" id="=ef#+88ApoWQv2F(soI)">
                                        <field name="NUM">1</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <statement name="DO0">
                                  <block type="control" id="rvU:D+8+T0=}aFHB4Y_,">
                                    <mutation delay_input="false"></mutation>
                                    <field name="OID">mihome-vacuum.0.control.X_send_command</field>
                                      <block type="variables_get" id="OrN{Ji``zx:c+,GIQ%V~">
                                      </block>
                                    </value>
                                  </block>
                                </statement>
                                <next>
                                  <block type="controls_if" id="p@4RtG#w?*ZfeQh-DhW=">
                                    <value name="IF0">
                                      <block type="logic_compare" id="]ML3dK+K%Ss*PP1C6}.I">
                                        <value name="A">
                                          <block type="get_value" id="A[L@C_egi[F/oVMQW^_/">
                                          </block>
                                        </value>
                                        <value name="B">
                                          <block type="math_number" id=":t3k=z={gtWBjX9%+oDY">
                                            <field name="NUM">2</field>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                      <block type="control" id="Fj!_{m.PvLy[ZCTt69Ai">
                                          <block type="variables_get" id="cs^jf5ppROjO7t=DIc:W">
                                          </block>
                                        </value>
                                      </block>
                                    </statement>
                                    <next>
                                      <block type="controls_if" id="522b~?+NAKvD,dErnt,l">
                                        <value name="IF0">
                                          <block type="logic_compare" id="b3T-%fupbfET7[^%D{gz">
                                            <value name="A">
                                              <block type="get_value" id="DciAT#,TJm)AFKPl,ZKU">
                                              </block>
                                            </value>
                                            <value name="B">
                                              <block type="math_number" id="Mtrun}#MK=5#js?MQLDP">
                                                <field name="NUM">3</field>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                          <block type="control" id="hP#DYCrpD6@t+ZCj4K}t">
                                              <block type="variables_get" id="d6tpE4/.-l@yw(k6Op:h">
                                              </block>
                                            </value>
                                          </block>
                                        </statement>
                                        <next>
                                          <block type="controls_if" id="wSNWFV(=oe3*Wq;f*@BI">
                                            <value name="IF0">
                                              <block type="logic_compare" id="Amc2r/~*m=c94}A/ex2x">
                                                <value name="A">
                                                  <block type="get_value" id="^2CFEG{SfmYy#-cI{L{a">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  <block type="math_number" id="@{Af3%,R_U}B/_]Qnf!j">
                                                    <field name="NUM">4</field>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                              <block type="control" id="2OX9HjBTIzS|;/.x7Evs">
                                                  <block type="variables_get" id="!aKr!M;)d[~lIFQEW:Rv">
                                                  </block>
                                                </value>
                                              </block>
                                            </statement>
                                            <next>
                                              <block type="controls_if" id="sFsn,FsK/.lHM#d!zPu{">
                                                <value name="IF0">
                                                  <block type="logic_compare" id="sV!{?%?M[3~@{WX[desv">
                                                    <value name="A">
                                                      <block type="get_value" id="jUehj--)Ra/*Fa_!-kBh">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <block type="math_number" id="KC(quv,.gF*^p+@UY[f/">
                                                        <field name="NUM">5</field>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                  <block type="control" id="YO.z!X!:4Bz}]iBb(jhf">
                                                      <block type="variables_get" id="hhG2Xi:Ge;lTOZ`k]ta-">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </statement>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
      </block>
      Ausgelöst wird das ganze durch den entsprechenden Wert im Datenpunkt javascript.0.NoNo.Zonen_Reiningung
      0 = Aus
      1 = Raum 1
      2 = Raum 2
      ect.
      G 2 Antworten Letzte Antwort
      • K Kuddel
        @Mallet
        Mittlerwiele habe ich für alles mögliche Skripte am laufen (an der Zahl 56).
        Die aufzulisten ist nicht mal eben schnell gemacht.
        Wenn du spezielle Fragen zu Skripten hast, die evtl. für meine VIS wichtig sein könnte, schieß los.
        M
        M
        Mallet
        @Kuddel Hi Knuddel,
        das es nicht blos ein oder 2 sind dachte ich mir schon... :) habe akutell keine direkte frage... aber wenn schreib ich... Danke :) Wirklich toll die VIS
        • K Kuddel
          @haschel
          Ja das ist ein bisschen komplexer.
          Uptime ioBroker = Uptime im RPI Adapter. Wird dann von Sekunden entsprechend umgewandelt
          Uptime CCU = Wird per Skript auf der CCU ausgelesen und auf der CCU in eine Variable geschieben
          Uptime ESX-NUC = Auf meiner WIn10 VM läuft ein Powershell Skript, was doe Uptime per PowerCLI ausgelesen und an den ioBroker übergeibt
          Uptime Win10 = Wird ebenfalls per Skitpt auf der VM ausgelesen und übergeben (per API)
          Uptime Unifi = Wird per Shell Skript auf der ioBroker VM per SSH ausgelesen und formatiert
          Uptime Sophos = Wird per Shell Skript auf der ioBroker VM per SSH ausgelesen und formatiert
          Uptime QNAP-B = Auswetung der SNMP Adapter
          Wenn du ein bestimmtes Skript brauchst, gib Bescheid, dann poste ich das eben
          haschelH
          haschelH
          haschel
          @Kuddel hört sich sehr gut an. bin gerade am fummeln, wie ich mir die Uptime per Script speicher. Das auslesen ist soweit kein Problem. Würde mich freuen wenn du mir die für das Windws-System und für Unifi geben könntest.
          Also, Interesse hätte ich an:
          Win 10 Uptime
          Unifi Uptime
          Festplattenspeicher NAS
          WOL (Win Server)
          Vielen Dank an dich - wirklich super Arbeit - das Verständnis wird meinerseits immer besser. :)
          • K Kuddel
            @gfrene
              <value name="OID0">
                </shadow>
              </value>
                    </block>
                  </value>
                  <next>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                          <next>
                                </block>
                              </value>
                              <next>
                                    </block>
                                  </value>
                                  <next>
                                      <value name="IF0">
                                          <value name="A">
                                            </block>
                                          </value>
                                          <value name="B">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                            </block>
                                          </value>
                                        </block>
                                      </statement>
                                      <next>
                                          <value name="IF0">
                                              <value name="A">
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                          <next>
                                              <value name="IF0">
                                                  <value name="A">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                              <next>
                                                  <value name="IF0">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                  <next>
                                                      <value name="IF0">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </statement>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </statement>
            </block>
            0 = Aus
            1 = Raum 1
            2 = Raum 2
            ect.
            G
            G
            gfrene
            @Kuddel Dickes danke :-) wegen dem javascript.0.NoNo.Zonen_Reiningung steht in diesen Datenpukt was ? ist das noch ein JAVA-Srcipt ? Gruß und danke für deine Hilfe.
            • K
              K
              Kuddel
              @haschel
              Uptime WIndows 10 (Powershell):
              windows_10_uptime_umwandeln.txt windows_10_uptime_abfrage.txt
              Uptime Unifi-Controller (Shell):
              Voraussetzung: auf dem ioBroker einen SSH Key erstellen und auf den Unifi-Controller kopieren, sonst funktioniert die Abfrage nicht ohne PW
              unifi_uptime_umwandelntxt.txt unifi_uptime_abfrage.txt
              Festplattensepicher WinNAS (Powershell):
              WinNAS_Festplattenauslastung.txt
              WOL WinNAS (JavaScript):
              WinNAS_WOL.txt
              P 1 Antwort Letzte Antwort
              • G gfrene
                K
                K
                Kuddel
                @gfrene
                In dem Datenpunkt steht eine Zahl.
                Über meine VIS wird über das entsprechende Raum Widget eine Zahl riengeschrieben.
                Beispiel: Ich drücke in der VIS auf "Büro". Dann setzt das Widget eine 2 in das Datenobjekt.
                Über diese 2 werden dann per Blockly die entsprechenden Koordinaten ausgewählt und der Saugvorgang gestartet
                • K Kuddel
                  @wendy2702:
                  Ein Frage.
                  Sind die Bilder von unterschiedlichen Tagen?
                  Einmal Vollmond und einmal Neumond wie es aussieht. `
                  damit man das besser erkennen kann habe ich auf der Startseite einen Vollmond genommen. diese Bild ändert sich nicht
                  EDIT: habs mal eben geändert:
                  M
                  M
                  maxpd
                  schrieb am zuletzt editiert von maxpd
                  @Kuddel said in [Vorstellung] Meine zweite Visualisierung:
                  Mhhh, lässt sich im neuen Forum nicht mehr im Thread selber filtern?
                  Bei dem Astro Modul sind JavaScripte hinterlegt. Wie finde ich diese denn? Bei mir steht nur NaN oder null wo Zahlen stehen sollten.
                  maxpd
                  • M maxpd
                    K
                    K
                    Kuddel
                    @maxpd
                    Da ich keine Ahnung von Java habe, habe ich alles mit Blockly umgesetzt:
                    Tages und Nachtzeit
                    Tages_und_Nachtlaenge.txt
                    Fortschritt
                    Fortschritt.txt
                    • M
                      M
                      maxpd
                      #66
                      @Kuddel
                      Ich auch nicht :)
                      ich sehe nur unter Allgemein im Widget: javascript.0.zeiten.tageslaenge_fortschritt
                      maxpd
                      • K
                        K
                        Kuddel
                        schrieb am zuletzt editiert von Kuddel
                        #67
                        @maxpd
                        Wenn du alle Datenojekte die ich so verwende haben möchtest, erstelle ein JavaScript und kopiere folgendes rein:
                        createState('javascript.0.zeiten.sonnenuntergang', false, {type: 'string',name: 'sonnenuntergang'});
                        createState('javascript.0.zeiten.sonnenaufgang', false, {type: 'string',name: 'sonnenaufgang'});
                        createState('javascript.0.zeiten.sonnenaufgang_stunde', false, {type: 'string',name: 'sonnenaufgang_stunde'});
                        createState('javascript.0.zeiten.sonnenaufgang_minute', false, {type: 'string',name: 'sonnenaufgang_minute'});
                        createState('javascript.0.zeiten.nachtlaenge', false, {type: 'string',name: 'nachtlaenge'});
                        createState('javascript.0.zeiten.nachtlaenge_in_minuten', false, {type: 'string',name: 'nachtlaenge_in_minuten'});
                        createState('javascript.0.zeiten.nachtlaenge_keinlicht', false, {type: 'string',name: 'nachtlaenge_keinlicht'});
                        createState('javascript.0.zeiten.nachtlaenge_fortschritt', false, {type: 'string',name: 'nachtlaenge_fortschritt'});
                        createState('javascript.0.zeiten.tageslaenge', false, {type: 'string',name: 'tageslaenge'});
                        createState('javascript.0.zeiten.tageslaenge_differenz', false, {type: 'string',name: 'tageslaenge_differenz'});
                        createState('javascript.0.zeiten.tageslaenge_fortschritt', false, {type: 'string',name: 'tageslaenge_fortschritt'});
                        createState('javascript.0.zeiten.tageslaenge_in_minuten', false, {type: 'string',name: 'tageslaenge_in_minuten'});
                        createState('javascript.0.zeiten.tageslaenge_tageslicht', false, {type: 'string',name: 'tageslaenge_tageslicht'});
                        createState('javascript.0.zeiten.tageslaenge_tageslicht_in_minuten', false, {type: 'string',name: 'tageslaenge_tageslicht_in_minuten'});
                        createState('javascript.0.zeiten.tageslaenge_timer_restart', false, {type: 'boolean',name:'tageslaenge_timer_restart'});
                        G 1 Antwort Letzte Antwort
                        • M
                          M
                          maxpd
                          #68
                          @maxpd
                          Die Astro Anzeige fand ich ganz interessant, da ich die Angaben auch manchmal google.
                          Aber am meisten versuche ich erst mal Zusammenhänge und Funktionsweisen in iobroker und VIS zu verstehen.
                          Ha, jetzt haben sich NaN und null auf false geändert :D Aber der Import von Fortschrifft funktioniert auch nicht. Da kommt eine Fehlermeldung:
                          TypeError: Cannot read property 'appendChild' of null
                          maxpd
                          • M maxpd
                            @maxpd
                            K
                            K
                            Kuddel
                            #69
                            @maxpd
                            Ja stimmt, ich kann es nach einem neuen Export aucht nicht importieren. Beim Fortschritt für die Nacht liegt irgendwo der Fehler.
                            Hier ist der Fortschritt für Tagsüber:
                            <block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="(zB*eILS0}lC]4feO;NQ" x="-287" y="-12">
                              <field name="SCHEDULE">* * * * *</field>
                                <block type="comment" id="F@)g%-I%DLPUO?NKxC~p">
                                  <field name="COMMENT">Tageslicht</field>
                                  <next>
                                    <block type="controls_if" id="cggsDF/*JY)o.]T!zs:|">
                                      <value name="IF0">
                                        <block type="logic_compare" id="neWt`yuwThe[})R*v;ua">
                                          <value name="A">
                                            <block type="time_get" id="3o?IF#+zk%NF)7tdrZF)">
                                              <mutation format="false" language="false"></mutation>
                                              <field name="OPTION">hh:mm</field>
                                            </block>
                                          </value>
                                          <value name="B">
                                            <block type="get_value" id="pn0]=@}Q6ypxVSk)x_ky">
                                              <field name="OID">javascript.0.zeiten.sonnenaufgang</field>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                        <block type="control" id="FhF0Pwtrp.dFfW%SAmMK">
                                          <field name="OID">javascript.0.zeiten.tageslaenge_fortschritt</field>
                                            <block type="text" id="]EO6n@[7[C{)s_~D3VgB">
                                              <field name="TEXT">100</field>
                                            </block>
                                          </value>
                                          <next>
                                            <block type="control" id="zF!boiV!!!f{]?n0baQ=">
                                              <field name="OID">javascript.0.zeiten.tageslaenge_tageslicht_in_minuten</field>
                                                <block type="convert_tostring" id=".]Q`EYCiV@we[rPrLSY1">
                                                    <block type="math_arithmetic" id="!2*6Vi%`h}LN!_|`1@8(" inline="false">
                                                      <value name="A">
                                                        <shadow type="math_number" id="B3|V_Ljn[~%Q+HHiV?_~">
                                                        </shadow>
                                                        <block type="convert_from_date" id="7*E(LC8fHz2pU;ssHht,">
                                                          <field name="OPTION">mid</field>
                                                            <block type="time_astro" id="yS6(Fn=S5sB4/ATrUahy">
                                                              <field name="TYPE">sunset</field>
                                                              <field name="OFFSET">0</field>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <shadow type="math_number" id="(c6`X/y~y*sa=f+,g)#y">
                                                        </shadow>
                                                        <block type="time_get" id="j:5w/cmmi!1JI;lj77Pn">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                      <next>
                                        <block type="controls_if" id="(^^D^mu@vrKf*MzEai,n">
                                          <value name="IF0">
                                            <block type="logic_compare" id="OBaCAYbHt;;UM#v(xeQN">
                                              <field name="OP">GT</field>
                                              <value name="A">
                                                <block type="get_value" id="aqm]}h[z_`dAS]2;:t;n">
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="math_number" id="k(G3Y:Tu)=yEFQ5yp2eS">
                                                  <field name="NUM">0</field>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                            <block type="control" id="Rd6@e{hWV62YiKLLY/%X">
                                              <comment pinned="false" h="80" w="160">Rechnung:
                            (aktueller Zeitpunkt in Minuten *100)/ Tagseslänge in Minuten
                                              </comment>
                                                <block type="convert_tostring" id="h!Y]I%GI10@a.jL{6tok">
                                                    <block type="math_round" id="ygBOxsic4R5t?UbA@}-~">
                                                      <field name="OP">ROUND</field>
                                                      <value name="NUM">
                                                        <shadow type="math_number" id="]:,s32?5@NfsE]u6dQ,H">
                                                          <field name="NUM">3.1</field>
                                                        </shadow>
                                                        <block type="math_arithmetic" id=".5pSNur])MV]f@qp4{i:" inline="false">
                                                          <field name="OP">DIVIDE</field>
                                                          <value name="A">
                                                            <shadow type="math_number" id="G`UN:3+p%7/kxBEol_%a">
                                                            </shadow>
                                                            <block type="math_arithmetic" id="uP/zc2;9gJbD1lYM.oaE" inline="false">
                                                              <field name="OP">MULTIPLY</field>
                                                              <value name="A">
        <shadow type="math_number" id="i,38}R*oiUl1Om7!vYyI">
        </shadow>
        <block type="math_arithmetic" id="?~2A?%.eh#xtWJCztS@{" inline="false">
        <value name="A">
        </shadow>
        <block type="convert_from_date" id="b)so8-M#4Y2YR:rb8:d8">
        <block type="time_astro" id="_13-93yo_*T4j%L]p!fj">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        <block type="time_get" id="s9}ko*Y3GcHi[IQk4G6!">
        </block>
        </value>
        </block>
                                                              </value>
                                                              <value name="B">
        <shadow type="math_number" id="9ci?a^NEeRpDmWT/.fJq">
        <field name="NUM">100</field>
        </shadow>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <shadow type="math_number" id="WJCqhHA]_5|(VSXL)c|q">
                                                            </shadow>
                                                            <block type="get_value" id="ZCwsVW~Ji2=d3_=6BFpz">
                                                              <field name="OID">javascript.0.zeiten.tageslaenge_in_minuten</field>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <next>
                                                <block type="control" id="]zc;(b~L*|]iI!G,)m~G">
                                                    <block type="convert_tostring" id="XbTV|L},^Tdv^f,~_g2#">
                                                        <block type="math_arithmetic" id="pu^#PKi=UWTlp26L*~`x" inline="false">
                                                          <value name="A">
                                                            </shadow>
                                                            <block type="convert_from_date" id="X]N4(s*fnW7_jxGUUifu">
        <block type="time_astro" id="iTZiG%s}DR)?Sy6`;5rj">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </shadow>
                                                            <block type="time_get" id=")sbT91k10eU/}HPQ~ylz">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                    <block type="comment" id="Y1N3R)La8(53qWH.V?a9">
                                                      <next>
                                                        <block type="variables_set" id="ET}/!,v^cU1/5jyE}eGQ">
                                                          <field name="VAR">tageslicht_stunden</field>
                                                            <block type="math_round" id="t?v^j0B).zQX+H~}=N(L">
                                                              <field name="OP">ROUNDDOWN</field>
                                                              <value name="NUM">
        <shadow type="math_number" id="E5^T=-p[{Skz]^7aPJ+F">
        </shadow>
        <block type="math_arithmetic" id="QwUu#.n:s-Nt)d@Q@o%[" inline="false">
        <value name="A">
        <shadow type="math_number" id="1A!||Q4Q9fXwNB5L_|J*">
        </shadow>
        <block type="get_value" id="yQr4N;rn6xI;oAW_T2Nl">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="`sFASt]W(*oo7d%O%hwn">
        <field name="NUM">60</field>
        </shadow>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <next>
                                                            <block type="variables_set" id=")}DYs.qo/qSk_T|Y5Htz">
                                                              <field name="VAR">tageslicht_minuten</field>
        <block type="math_arithmetic" id="=lynCq7?+TJh%a5B?Ntt" inline="false">
        <value name="A">
        <shadow type="math_number" id="WD~!+d%3~wqM=kmHzDlk">
        </shadow>
        <block type="get_value" id="J=0k:+OoU6)^14p}FGfQ">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id=")).0/8sID@I9|,f|pKo?">
        </shadow>
        <block type="math_arithmetic" id="(_3*6w96%s1oQHYJ16ko" inline="false">
        <value name="A">
        <shadow type="math_number" id="fc]gQz4gNGA*T6;VLb5l">
        </shadow>
        <block type="variables_get" id="y/1C[b{KCV}@cR!6WO-7">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="TL6V{F/fJM57]O?xKm_i">
        </shadow>
        </value>
        </block>
        </value>
        </block>
                                                              </value>
                                                              <next>
        <block type="controls_if" id=".ZRuC~F66A;*aLrdlC+v">
        <value name="IF0">
        <block type="logic_compare" id="HTm~#EmdyULx?`/NKXZp">
        <field name="OP">LT</field>
        <value name="A">
        <block type="variables_get" id="4fiBgAwIQ;48sw[.9QH?">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="KWPSYMzD`d4?F_7y=]lo">
        <field name="NUM">10</field>
        </block>
        </value>
        </block>
        </value>
        <block type="variables_set" id="528hrX[=)+b)a0kl@Kle">
        <block type="text_join" id="9]x8h0aiY)OmCU:_ohg(">
        <value name="ADD0">
        <block type="text" id="qef:q5saO(ccR;^IVVD:">
        <field name="TEXT">0</field>
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="vuQYs.,C2y*esJOU8:~v">
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="controls_if" id="73j.SvxF#,oZbvhipBNI">
        <value name="IF0">
        <block type="logic_compare" id="w*q*5{z3E|#q*c~,B;h0">
        <value name="A">
        <block type="variables_get" id="BM)8Wr*ds{sP!z-)Y+*K">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="[mr@FAqLcBz%[rHF58Qv">
        </block>
        </value>
        </block>
        </value>
        <block type="variables_set" id="uPPa@wz([53N3kGW[(RJ">
        <block type="text_join" id="-^:=WQ_=Ie8:buhh*).u">
        <value name="ADD0">
        <block type="text" id="pz8#`YTfV:=P_8]](/#i">
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="Mq~(xp1l-t:Jj1B*l#Dc">
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="control" id="gYZcm^-jUxihTef2X^gk">
        <field name="OID">javascript.0.zeiten.tageslaenge_tageslicht</field>
        <block type="convert_tostring" id="q[zG5-(W%PeQIJ,nTg|c">
        <block type="text_join" id="{Ln%z*ZgfT1HwU@xZF-m">
        <value name="ADD0">
        <block type="variables_get" id="3D+c0Y!fe1n5AJ^#K`wY">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="7M}EySWGm^xwZHhEY=#M">
        <field name="TEXT">:</field>
        </block>
        </value>
        <value name="ADD2">
        <block type="variables_get" id="vC7GN1uRdzm)YkW.c_]Y">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                          <next>
                                            <block type="controls_if" id="|)SKV{5+KIllIIw!(T:v">
                                              <value name="IF0">
                                                <block type="logic_operation" id="YKkKg7bAvjKaj7mV+F3S" inline="false">
                                                  <field name="OP">AND</field>
                                                  <value name="A">
                                                    <block type="logic_compare" id=")y}[Y5d^Zj|lcW.]g-~y">
                                                      <value name="A">
                                                        <block type="get_value" id="An.K@#d]()Gk^lL9g].G">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <block type="text" id="pDv3@EH6gt^e:IixA}XP">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <block type="logic_compare" id="(CUNsRMks#.%3?oIjQ%l">
                                                      <field name="OP">NEQ</field>
                                                      <value name="A">
                                                        <block type="get_value" id="%2wrh+-Rt%Qh]bYf^dD|">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <block type="text" id="{wbkp39a3O]Q6zjD15i`">
                                                          <field name="TEXT">00:00</field>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                <block type="control" id="cU?u,@73HT#~~0Ub=(uZ">
                                                    <block type="convert_tostring" id="O-5R5~#q|eT@0T8c}_?0">
                                                        <block type="text" id="2r6?Z7W|^({ea)3h03OY">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </statement>
                            </block>
                            • M
                              M
                              maxpd
                              #70
                              Danke dir @Kuddel
                              vielleicht kannst du dein Blockly für die Fenster oder Lampenübersicht zumindest als Screen mal zeigen? Denn eine solche Übersicht wollte ich mir auch bauen, habe aber das Gefühl, dass ich mein Blockly zu kompliziert konzipiere.
                              maxpd
                              • M maxpd
                                Danke dir @Kuddel
                                K
                                K
                                Kuddel
                                #71
                                @maxpd
                                Fenster_EG
                                • M
                                  M
                                  maxpd
                                  #72
                                  OK ja, mache ich auch so. Hatte gehofft, dass man alle Fenster in einer Liste oder Case abfragen kann
                                  maxpd
                                  • haschelH
                                    haschelH
                                    haschel
                                    schrieb am zuletzt editiert von haschel
                                    #73
                                    @Kuddel
                                    Danke erstmal für Scripte. Klappt alles soweit. Nur weiß ich gerade nicht, ob und wenn wo, ich auf dem Schlauch stehe. Bei dem Speicherplatzscript wird mir im Datenpunkt bei der Systemplatte der belegte Speicher angezeigt, und bei den anderen der verfügbare - soweit alles gut. Leider zeigt er mit den Wert in TB an - sprich 15GB frei zeigt er mit im Objekt als 0.015 an. Normalerweise habe ich mit Code nicht das Problem - kenne mich aber zu wenig mit der Power-Shell Syntax aus um sie dahingehend zu verändern. Oder hast du dafür noch ein Script im ioBroker um die Daten umzuwandeln? - Eher nicht, oder?
                                    Danke dir! :)
                                    • haschelH haschel
                                      @Kuddel
                                      Danke dir! :)
                                      K
                                      K
                                      Kuddel
                                      #74
                                      @haschel
                                      der Wert wird direkt im Powershellskript umgerechnet
                                      haschelH G 2 Antworten Letzte Antwort
                                      • K Kuddel
                                        @haschel
                                        haschelH
                                        haschelH
                                        haschel
                                        #75
                                        @Kuddel ja, so meine ich das auch verstanden zu haben. Da scheint ja eine Bedingung für das Anzeigen/Berechnen von GB oder TB zu sein - richtig? Will mich da jetzt ein wenig reinfuchsen, deswegen die Fragen - hoffe es stört dich nicht... :)
                                        • D
                                          D
                                          derrapf
                                          #76
                                          Hi
                                          Da sind ein paar spannende Widgets dabei.
                                          Wie hast Du denn den Wecker realisiert und welche Widgets dazu verwendet`? Ist das ein einzelnes Widget oder eine Kombination aus Mehreren?
                                          Gruss Ralf
                                          83.9k
