  4. [Vorstellung] Meine zweite Visualisierung
    apollon77A
vistemplate
1.3k Beiträge 148 Kommentatoren 744.1k Aufrufe 157 Beobachtet
  • G gfrene
    @Kuddel könntest du die Scripte zur Verfügung stellen wie du die Zonenreinigung umgesetzt hast :-)
    Danke dir und 1a VIS
    K
    K
    Kuddel
    @gfrene
    Skript für die Zonenreinung:
    <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="A3mcx,(O{KZ0SAwINJkl" x="-362.00000000000057" y="10037.5">
      <mutation items="1"></mutation>
      <value name="OID0">
        <shadow type="field_oid" id="=^9T:bBq#a4Q,Nh;+#c=">
          <field name="oid">javascript.0.NoNo.Zonen_Reinigung</field>
        </shadow>
      </value>
      <statement name="STATEMENT">
        <block type="variables_set" id="?Vkt^R1:a?ZRu{JyI(Vh">
          <field name="VAR">Buero</field>
          <value name="VALUE">
            <block type="text" id="a=(?PpOyB5iGBLjQ6Aap">
              <field name="TEXT">app_zoned_clean;[[18471,19907,22571,23007,1]]</field>
            </block>
          </value>
          <next>
            <block type="variables_set" id="sYCBkY(T4jb-]X+2Eak,">
              <field name="VAR">Flur</field>
                <block type="text" id="%-KCb~RlSSjV6q_]/?j*">
                  <field name="TEXT">app_zoned_clean;[[22637,19580,29787,25130,2]]</field>
                </block>
              </value>
              <next>
                <block type="variables_set" id=";M*u(QADG3GbZdCgq8GG">
                  <field name="VAR">GaesteWC</field>
                    <block type="text" id="lS%?^.}[p`XS/bXa8f#g">
                      <field name="TEXT">app_zoned_clean;[[28009,25008,29709,26458,2]]</field>
                    </block>
                  </value>
                  <next>
                    <block type="variables_set" id="H#[grBDiKs9O6?Cx9J4#">
                      <field name="VAR">Kueche</field>
                        <block type="text" id="qSyl{KE}K,}iq}DCvI!1">
                          <field name="TEXT">app_zoned_clean;[[26727,25000,29777,29250,2]]</field>
                        </block>
                      </value>
                      <next>
                        <block type="variables_set" id="q[mk=w]QG/B:uT%rh)%7">
                          <field name="VAR">Wohnzimmer</field>
                            <block type="text" id="Qd0=lq+^}-*HGJNu^hHE">
                              <field name="TEXT">app_zoned_clean;[[18626,25160,25976,29110,2],[18569,23306,22519,25106,2]]</field>
                            </block>
                          </value>
                          <next>
                            <block type="controls_if" id="lH-2B:yzLcZ]@Mk~(nc]">
                              <value name="IF0">
                                <block type="logic_compare" id="Bp2=TLQfL3|kHV=a:vvq">
                                  <field name="OP">EQ</field>
                                  <value name="A">
                                    <block type="get_value" id="Hmzyi5vAP`/`|r8fEf=T">
                                      <field name="OID">javascript.0.NoNo.Zonen_Reinigung</field>
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="math_number" id="=ef#+88ApoWQv2F(soI)">
                                      <field name="NUM">1</field>
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <statement name="DO0">
                                <block type="control" id="rvU:D+8+T0=}aFHB4Y_,">
                                  <mutation delay_input="false"></mutation>
                                  <field name="OID">mihome-vacuum.0.control.X_send_command</field>
                                    <block type="variables_get" id="OrN{Ji``zx:c+,GIQ%V~">
                                    </block>
                                  </value>
                                </block>
                              </statement>
                              <next>
                                <block type="controls_if" id="p@4RtG#w?*ZfeQh-DhW=">
                                  <value name="IF0">
                                    <block type="logic_compare" id="]ML3dK+K%Ss*PP1C6}.I">
                                      <value name="A">
                                        <block type="get_value" id="A[L@C_egi[F/oVMQW^_/">
                                        </block>
                                      </value>
                                      <value name="B">
                                        <block type="math_number" id=":t3k=z={gtWBjX9%+oDY">
                                          <field name="NUM">2</field>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                    <block type="control" id="Fj!_{m.PvLy[ZCTt69Ai">
                                        <block type="variables_get" id="cs^jf5ppROjO7t=DIc:W">
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                  <next>
                                    <block type="controls_if" id="522b~?+NAKvD,dErnt,l">
                                      <value name="IF0">
                                        <block type="logic_compare" id="b3T-%fupbfET7[^%D{gz">
                                          <value name="A">
                                            <block type="get_value" id="DciAT#,TJm)AFKPl,ZKU">
                                            </block>
                                          </value>
                                          <value name="B">
                                            <block type="math_number" id="Mtrun}#MK=5#js?MQLDP">
                                              <field name="NUM">3</field>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                        <block type="control" id="hP#DYCrpD6@t+ZCj4K}t">
                                            <block type="variables_get" id="d6tpE4/.-l@yw(k6Op:h">
                                            </block>
                                          </value>
                                        </block>
                                      </statement>
                                      <next>
                                        <block type="controls_if" id="wSNWFV(=oe3*Wq;f*@BI">
                                          <value name="IF0">
                                            <block type="logic_compare" id="Amc2r/~*m=c94}A/ex2x">
                                              <value name="A">
                                                <block type="get_value" id="^2CFEG{SfmYy#-cI{L{a">
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="math_number" id="@{Af3%,R_U}B/_]Qnf!j">
                                                  <field name="NUM">4</field>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                            <block type="control" id="2OX9HjBTIzS|;/.x7Evs">
                                                <block type="variables_get" id="!aKr!M;)d[~lIFQEW:Rv">
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                          <next>
                                            <block type="controls_if" id="sFsn,FsK/.lHM#d!zPu{">
                                              <value name="IF0">
                                                <block type="logic_compare" id="sV!{?%?M[3~@{WX[desv">
                                                  <value name="A">
                                                    <block type="get_value" id="jUehj--)Ra/*Fa_!-kBh">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <block type="math_number" id="KC(quv,.gF*^p+@UY[f/">
                                                      <field name="NUM">5</field>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                <block type="control" id="YO.z!X!:4Bz}]iBb(jhf">
                                                    <block type="variables_get" id="hhG2Xi:Ge;lTOZ`k]ta-">
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </next>
        </block>
      </statement>
    </block>
    Ausgelöst wird das ganze durch den entsprechenden Wert im Datenpunkt javascript.0.NoNo.Zonen_Reiningung
    0 = Aus
    1 = Raum 1
    2 = Raum 2
    ect.
    G 2 Antworten Letzte Antwort
    • K Kuddel
      @Mallet
      Mittlerwiele habe ich für alles mögliche Skripte am laufen (an der Zahl 56).
      Die aufzulisten ist nicht mal eben schnell gemacht.
      Wenn du spezielle Fragen zu Skripten hast, die evtl. für meine VIS wichtig sein könnte, schieß los.
      M
      M
      Mallet
      @Kuddel Hi Knuddel,
      das es nicht blos ein oder 2 sind dachte ich mir schon... :) habe akutell keine direkte frage... aber wenn schreib ich... Danke :) Wirklich toll die VIS
      • K Kuddel
        @haschel
        Ja das ist ein bisschen komplexer.
        Uptime ioBroker = Uptime im RPI Adapter. Wird dann von Sekunden entsprechend umgewandelt
        Uptime CCU = Wird per Skript auf der CCU ausgelesen und auf der CCU in eine Variable geschieben
        Uptime ESX-NUC = Auf meiner WIn10 VM läuft ein Powershell Skript, was doe Uptime per PowerCLI ausgelesen und an den ioBroker übergeibt
        Uptime Win10 = Wird ebenfalls per Skitpt auf der VM ausgelesen und übergeben (per API)
        Uptime Unifi = Wird per Shell Skript auf der ioBroker VM per SSH ausgelesen und formatiert
        Uptime Sophos = Wird per Shell Skript auf der ioBroker VM per SSH ausgelesen und formatiert
        Uptime QNAP-B = Auswetung der SNMP Adapter
        Wenn du ein bestimmtes Skript brauchst, gib Bescheid, dann poste ich das eben
        haschelH
        haschelH
        haschel
        @Kuddel hört sich sehr gut an. bin gerade am fummeln, wie ich mir die Uptime per Script speicher. Das auslesen ist soweit kein Problem. Würde mich freuen wenn du mir die für das Windws-System und für Unifi geben könntest.
        Also, Interesse hätte ich an:
        Win 10 Uptime
        Unifi Uptime
        Festplattenspeicher NAS
        WOL (Win Server)
        Vielen Dank an dich - wirklich super Arbeit - das Verständnis wird meinerseits immer besser. :)
        • K Kuddel
          @gfrene
            <value name="OID0">
              </shadow>
            </value>
                  </block>
                </value>
                <next>
                      </block>
                    </value>
                    <next>
                          </block>
                        </value>
                        <next>
                              </block>
                            </value>
                            <next>
                                  </block>
                                </value>
                                <next>
                                    <value name="IF0">
                                        <value name="A">
                                          </block>
                                        </value>
                                        <value name="B">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                          </block>
                                        </value>
                                      </block>
                                    </statement>
                                    <next>
                                        <value name="IF0">
                                            <value name="A">
                                              </block>
                                            </value>
                                            <value name="B">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                              </block>
                                            </value>
                                          </block>
                                        </statement>
                                        <next>
                                            <value name="IF0">
                                                <value name="A">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </statement>
                                            <next>
                                                <value name="IF0">
                                                    <value name="A">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </statement>
                                                <next>
                                                    <value name="IF0">
                                                        <value name="A">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </statement>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
          </block>
          0 = Aus
          1 = Raum 1
          2 = Raum 2
          ect.
          G
          G
          gfrene
          @Kuddel Dickes danke :-) wegen dem javascript.0.NoNo.Zonen_Reiningung steht in diesen Datenpukt was ? ist das noch ein JAVA-Srcipt ? Gruß und danke für deine Hilfe.
          • K
            K
            Kuddel
            @haschel
            Uptime WIndows 10 (Powershell):
            windows_10_uptime_umwandeln.txt windows_10_uptime_abfrage.txt
            Uptime Unifi-Controller (Shell):
            Voraussetzung: auf dem ioBroker einen SSH Key erstellen und auf den Unifi-Controller kopieren, sonst funktioniert die Abfrage nicht ohne PW
            unifi_uptime_umwandelntxt.txt unifi_uptime_abfrage.txt
            Festplattensepicher WinNAS (Powershell):
            WinNAS_Festplattenauslastung.txt
            WOL WinNAS (JavaScript):
            WinNAS_WOL.txt
            P 1 Antwort Letzte Antwort
            • G gfrene
              K
              K
              Kuddel
              @gfrene
              In dem Datenpunkt steht eine Zahl.
              Über meine VIS wird über das entsprechende Raum Widget eine Zahl riengeschrieben.
              Beispiel: Ich drücke in der VIS auf "Büro". Dann setzt das Widget eine 2 in das Datenobjekt.
              Über diese 2 werden dann per Blockly die entsprechenden Koordinaten ausgewählt und der Saugvorgang gestartet
              • K Kuddel
                @wendy2702:
                Ein Frage.
                Sind die Bilder von unterschiedlichen Tagen?
                Einmal Vollmond und einmal Neumond wie es aussieht. `
                damit man das besser erkennen kann habe ich auf der Startseite einen Vollmond genommen. diese Bild ändert sich nicht
                EDIT: habs mal eben geändert:
                M
                M
                maxpd
                schrieb am zuletzt editiert von maxpd
                @Kuddel said in [Vorstellung] Meine zweite Visualisierung:
                Mhhh, lässt sich im neuen Forum nicht mehr im Thread selber filtern?
                Bei dem Astro Modul sind JavaScripte hinterlegt. Wie finde ich diese denn? Bei mir steht nur NaN oder null wo Zahlen stehen sollten.
                maxpd
                • M maxpd
                  K
                  K
                  Kuddel
                  @maxpd
                  Da ich keine Ahnung von Java habe, habe ich alles mit Blockly umgesetzt:
                  Tages und Nachtzeit
                  Tages_und_Nachtlaenge.txt
                  Fortschritt
                  Fortschritt.txt
                  • M
                    M
                    maxpd
                    #66
                    @Kuddel
                    Ich auch nicht :)
                    ich sehe nur unter Allgemein im Widget: javascript.0.zeiten.tageslaenge_fortschritt
                    maxpd
                    • K
                      K
                      Kuddel
                      schrieb am zuletzt editiert von Kuddel
                      #67
                      @maxpd
                      Wenn du alle Datenojekte die ich so verwende haben möchtest, erstelle ein JavaScript und kopiere folgendes rein:
                      createState('javascript.0.zeiten.sonnenuntergang', false, {type: 'string',name: 'sonnenuntergang'});
                      createState('javascript.0.zeiten.sonnenaufgang', false, {type: 'string',name: 'sonnenaufgang'});
                      createState('javascript.0.zeiten.sonnenaufgang_stunde', false, {type: 'string',name: 'sonnenaufgang_stunde'});
                      createState('javascript.0.zeiten.sonnenaufgang_minute', false, {type: 'string',name: 'sonnenaufgang_minute'});
                      createState('javascript.0.zeiten.nachtlaenge', false, {type: 'string',name: 'nachtlaenge'});
                      createState('javascript.0.zeiten.nachtlaenge_in_minuten', false, {type: 'string',name: 'nachtlaenge_in_minuten'});
                      createState('javascript.0.zeiten.nachtlaenge_keinlicht', false, {type: 'string',name: 'nachtlaenge_keinlicht'});
                      createState('javascript.0.zeiten.nachtlaenge_fortschritt', false, {type: 'string',name: 'nachtlaenge_fortschritt'});
                      createState('javascript.0.zeiten.tageslaenge', false, {type: 'string',name: 'tageslaenge'});
                      createState('javascript.0.zeiten.tageslaenge_differenz', false, {type: 'string',name: 'tageslaenge_differenz'});
                      createState('javascript.0.zeiten.tageslaenge_fortschritt', false, {type: 'string',name: 'tageslaenge_fortschritt'});
                      createState('javascript.0.zeiten.tageslaenge_in_minuten', false, {type: 'string',name: 'tageslaenge_in_minuten'});
                      createState('javascript.0.zeiten.tageslaenge_tageslicht', false, {type: 'string',name: 'tageslaenge_tageslicht'});
                      createState('javascript.0.zeiten.tageslaenge_tageslicht_in_minuten', false, {type: 'string',name: 'tageslaenge_tageslicht_in_minuten'});
                      createState('javascript.0.zeiten.tageslaenge_timer_restart', false, {type: 'boolean',name:'tageslaenge_timer_restart'});
                      G 1 Antwort Letzte Antwort
                      • M
                        M
                        maxpd
                        #68
                        @maxpd
                        Die Astro Anzeige fand ich ganz interessant, da ich die Angaben auch manchmal google.
                        Aber am meisten versuche ich erst mal Zusammenhänge und Funktionsweisen in iobroker und VIS zu verstehen.
                        Ha, jetzt haben sich NaN und null auf false geändert :D Aber der Import von Fortschrifft funktioniert auch nicht. Da kommt eine Fehlermeldung:
                        TypeError: Cannot read property 'appendChild' of null
                        maxpd
                        • M maxpd
                          @maxpd
                          K
                          K
                          Kuddel
                          #69
                          @maxpd
                          Ja stimmt, ich kann es nach einem neuen Export aucht nicht importieren. Beim Fortschritt für die Nacht liegt irgendwo der Fehler.
                          Hier ist der Fortschritt für Tagsüber:
                          <block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="(zB*eILS0}lC]4feO;NQ" x="-287" y="-12">
                            <field name="SCHEDULE">* * * * *</field>
                              <block type="comment" id="F@)g%-I%DLPUO?NKxC~p">
                                <field name="COMMENT">Tageslicht</field>
                                <next>
                                  <block type="controls_if" id="cggsDF/*JY)o.]T!zs:|">
                                    <value name="IF0">
                                      <block type="logic_compare" id="neWt`yuwThe[})R*v;ua">
                                        <value name="A">
                                          <block type="time_get" id="3o?IF#+zk%NF)7tdrZF)">
                                            <mutation format="false" language="false"></mutation>
                                            <field name="OPTION">hh:mm</field>
                                          </block>
                                        </value>
                                        <value name="B">
                                          <block type="get_value" id="pn0]=@}Q6ypxVSk)x_ky">
                                            <field name="OID">javascript.0.zeiten.sonnenaufgang</field>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                      <block type="control" id="FhF0Pwtrp.dFfW%SAmMK">
                                        <field name="OID">javascript.0.zeiten.tageslaenge_fortschritt</field>
                                          <block type="text" id="]EO6n@[7[C{)s_~D3VgB">
                                            <field name="TEXT">100</field>
                                          </block>
                                        </value>
                                        <next>
                                          <block type="control" id="zF!boiV!!!f{]?n0baQ=">
                                            <field name="OID">javascript.0.zeiten.tageslaenge_tageslicht_in_minuten</field>
                                              <block type="convert_tostring" id=".]Q`EYCiV@we[rPrLSY1">
                                                  <block type="math_arithmetic" id="!2*6Vi%`h}LN!_|`1@8(" inline="false">
                                                    <value name="A">
                                                      <shadow type="math_number" id="B3|V_Ljn[~%Q+HHiV?_~">
                                                      </shadow>
                                                      <block type="convert_from_date" id="7*E(LC8fHz2pU;ssHht,">
                                                        <field name="OPTION">mid</field>
                                                          <block type="time_astro" id="yS6(Fn=S5sB4/ATrUahy">
                                                            <field name="TYPE">sunset</field>
                                                            <field name="OFFSET">0</field>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <shadow type="math_number" id="(c6`X/y~y*sa=f+,g)#y">
                                                      </shadow>
                                                      <block type="time_get" id="j:5w/cmmi!1JI;lj77Pn">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                    <next>
                                      <block type="controls_if" id="(^^D^mu@vrKf*MzEai,n">
                                        <value name="IF0">
                                          <block type="logic_compare" id="OBaCAYbHt;;UM#v(xeQN">
                                            <field name="OP">GT</field>
                                            <value name="A">
                                              <block type="get_value" id="aqm]}h[z_`dAS]2;:t;n">
                                              </block>
                                            </value>
                                            <value name="B">
                                              <block type="math_number" id="k(G3Y:Tu)=yEFQ5yp2eS">
                                                <field name="NUM">0</field>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                          <block type="control" id="Rd6@e{hWV62YiKLLY/%X">
                                            <comment pinned="false" h="80" w="160">Rechnung:
                          (aktueller Zeitpunkt in Minuten *100)/ Tagseslänge in Minuten
                                            </comment>
                                              <block type="convert_tostring" id="h!Y]I%GI10@a.jL{6tok">
                                                  <block type="math_round" id="ygBOxsic4R5t?UbA@}-~">
                                                    <field name="OP">ROUND</field>
                                                    <value name="NUM">
                                                      <shadow type="math_number" id="]:,s32?5@NfsE]u6dQ,H">
                                                        <field name="NUM">3.1</field>
                                                      </shadow>
                                                      <block type="math_arithmetic" id=".5pSNur])MV]f@qp4{i:" inline="false">
                                                        <field name="OP">DIVIDE</field>
                                                        <value name="A">
                                                          <shadow type="math_number" id="G`UN:3+p%7/kxBEol_%a">
                                                          </shadow>
                                                          <block type="math_arithmetic" id="uP/zc2;9gJbD1lYM.oaE" inline="false">
                                                            <field name="OP">MULTIPLY</field>
                                                            <value name="A">
                                                              <shadow type="math_number" id="i,38}R*oiUl1Om7!vYyI">
                                                              </shadow>
                                                              <block type="math_arithmetic" id="?~2A?%.eh#xtWJCztS@{" inline="false">
        <value name="A">
        </shadow>
        <block type="convert_from_date" id="b)so8-M#4Y2YR:rb8:d8">
        <block type="time_astro" id="_13-93yo_*T4j%L]p!fj">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        <block type="time_get" id="s9}ko*Y3GcHi[IQk4G6!">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <shadow type="math_number" id="9ci?a^NEeRpDmWT/.fJq">
        <field name="NUM">100</field>
                                                              </shadow>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <shadow type="math_number" id="WJCqhHA]_5|(VSXL)c|q">
                                                          </shadow>
                                                          <block type="get_value" id="ZCwsVW~Ji2=d3_=6BFpz">
                                                            <field name="OID">javascript.0.zeiten.tageslaenge_in_minuten</field>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <next>
                                              <block type="control" id="]zc;(b~L*|]iI!G,)m~G">
                                                  <block type="convert_tostring" id="XbTV|L},^Tdv^f,~_g2#">
                                                      <block type="math_arithmetic" id="pu^#PKi=UWTlp26L*~`x" inline="false">
                                                        <value name="A">
                                                          </shadow>
                                                          <block type="convert_from_date" id="X]N4(s*fnW7_jxGUUifu">
                                                              <block type="time_astro" id="iTZiG%s}DR)?Sy6`;5rj">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          </shadow>
                                                          <block type="time_get" id=")sbT91k10eU/}HPQ~ylz">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="comment" id="Y1N3R)La8(53qWH.V?a9">
                                                    <next>
                                                      <block type="variables_set" id="ET}/!,v^cU1/5jyE}eGQ">
                                                        <field name="VAR">tageslicht_stunden</field>
                                                          <block type="math_round" id="t?v^j0B).zQX+H~}=N(L">
                                                            <field name="OP">ROUNDDOWN</field>
                                                            <value name="NUM">
                                                              <shadow type="math_number" id="E5^T=-p[{Skz]^7aPJ+F">
                                                              </shadow>
                                                              <block type="math_arithmetic" id="QwUu#.n:s-Nt)d@Q@o%[" inline="false">
        <value name="A">
        <shadow type="math_number" id="1A!||Q4Q9fXwNB5L_|J*">
        </shadow>
        <block type="get_value" id="yQr4N;rn6xI;oAW_T2Nl">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="`sFASt]W(*oo7d%O%hwn">
        <field name="NUM">60</field>
        </shadow>
        </value>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="variables_set" id=")}DYs.qo/qSk_T|Y5Htz">
                                                            <field name="VAR">tageslicht_minuten</field>
                                                              <block type="math_arithmetic" id="=lynCq7?+TJh%a5B?Ntt" inline="false">
        <value name="A">
        <shadow type="math_number" id="WD~!+d%3~wqM=kmHzDlk">
        </shadow>
        <block type="get_value" id="J=0k:+OoU6)^14p}FGfQ">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id=")).0/8sID@I9|,f|pKo?">
        </shadow>
        <block type="math_arithmetic" id="(_3*6w96%s1oQHYJ16ko" inline="false">
        <value name="A">
        <shadow type="math_number" id="fc]gQz4gNGA*T6;VLb5l">
        </shadow>
        <block type="variables_get" id="y/1C[b{KCV}@cR!6WO-7">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="TL6V{F/fJM57]O?xKm_i">
        </shadow>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <next>
                                                              <block type="controls_if" id=".ZRuC~F66A;*aLrdlC+v">
        <value name="IF0">
        <block type="logic_compare" id="HTm~#EmdyULx?`/NKXZp">
        <field name="OP">LT</field>
        <value name="A">
        <block type="variables_get" id="4fiBgAwIQ;48sw[.9QH?">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="KWPSYMzD`d4?F_7y=]lo">
        <field name="NUM">10</field>
        </block>
        </value>
        </block>
        </value>
        <block type="variables_set" id="528hrX[=)+b)a0kl@Kle">
        <block type="text_join" id="9]x8h0aiY)OmCU:_ohg(">
        <value name="ADD0">
        <block type="text" id="qef:q5saO(ccR;^IVVD:">
        <field name="TEXT">0</field>
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="vuQYs.,C2y*esJOU8:~v">
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="controls_if" id="73j.SvxF#,oZbvhipBNI">
        <value name="IF0">
        <block type="logic_compare" id="w*q*5{z3E|#q*c~,B;h0">
        <value name="A">
        <block type="variables_get" id="BM)8Wr*ds{sP!z-)Y+*K">
        </block>
        </value>
        <value name="B">
        <block type="math_number" id="[mr@FAqLcBz%[rHF58Qv">
        </block>
        </value>
        </block>
        </value>
        <block type="variables_set" id="uPPa@wz([53N3kGW[(RJ">
        <block type="text_join" id="-^:=WQ_=Ie8:buhh*).u">
        <value name="ADD0">
        <block type="text" id="pz8#`YTfV:=P_8]](/#i">
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="Mq~(xp1l-t:Jj1B*l#Dc">
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
        <next>
        <block type="control" id="gYZcm^-jUxihTef2X^gk">
        <field name="OID">javascript.0.zeiten.tageslaenge_tageslicht</field>
        <block type="convert_tostring" id="q[zG5-(W%PeQIJ,nTg|c">
        <block type="text_join" id="{Ln%z*ZgfT1HwU@xZF-m">
        <value name="ADD0">
        <block type="variables_get" id="3D+c0Y!fe1n5AJ^#K`wY">
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="7M}EySWGm^xwZHhEY=#M">
        <field name="TEXT">:</field>
        </block>
        </value>
        <value name="ADD2">
        <block type="variables_get" id="vC7GN1uRdzm)YkW.c_]Y">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </statement>
                                        <next>
                                          <block type="controls_if" id="|)SKV{5+KIllIIw!(T:v">
                                            <value name="IF0">
                                              <block type="logic_operation" id="YKkKg7bAvjKaj7mV+F3S" inline="false">
                                                <field name="OP">AND</field>
                                                <value name="A">
                                                  <block type="logic_compare" id=")y}[Y5d^Zj|lcW.]g-~y">
                                                    <value name="A">
                                                      <block type="get_value" id="An.K@#d]()Gk^lL9g].G">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <block type="text" id="pDv3@EH6gt^e:IixA}XP">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  <block type="logic_compare" id="(CUNsRMks#.%3?oIjQ%l">
                                                    <field name="OP">NEQ</field>
                                                    <value name="A">
                                                      <block type="get_value" id="%2wrh+-Rt%Qh]bYf^dD|">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <block type="text" id="{wbkp39a3O]Q6zjD15i`">
                                                        <field name="TEXT">00:00</field>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                              <block type="control" id="cU?u,@73HT#~~0Ub=(uZ">
                                                  <block type="convert_tostring" id="O-5R5~#q|eT@0T8c}_?0">
                                                      <block type="text" id="2r6?Z7W|^({ea)3h03OY">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </statement>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </statement>
                          </block>
                          • M
                            M
                            maxpd
                            #70
                            Danke dir @Kuddel
                            vielleicht kannst du dein Blockly für die Fenster oder Lampenübersicht zumindest als Screen mal zeigen? Denn eine solche Übersicht wollte ich mir auch bauen, habe aber das Gefühl, dass ich mein Blockly zu kompliziert konzipiere.
                            maxpd
                            • M maxpd
                              Danke dir @Kuddel
                              K
                              K
                              Kuddel
                              #71
                              @maxpd
                              Fenster_EG
                              • M
                                M
                                maxpd
                                #72
                                OK ja, mache ich auch so. Hatte gehofft, dass man alle Fenster in einer Liste oder Case abfragen kann
                                maxpd
                                • haschelH
                                  haschelH
                                  haschel
                                  schrieb am zuletzt editiert von haschel
                                  #73
                                  @Kuddel
                                  Danke erstmal für Scripte. Klappt alles soweit. Nur weiß ich gerade nicht, ob und wenn wo, ich auf dem Schlauch stehe. Bei dem Speicherplatzscript wird mir im Datenpunkt bei der Systemplatte der belegte Speicher angezeigt, und bei den anderen der verfügbare - soweit alles gut. Leider zeigt er mit den Wert in TB an - sprich 15GB frei zeigt er mit im Objekt als 0.015 an. Normalerweise habe ich mit Code nicht das Problem - kenne mich aber zu wenig mit der Power-Shell Syntax aus um sie dahingehend zu verändern. Oder hast du dafür noch ein Script im ioBroker um die Daten umzuwandeln? - Eher nicht, oder?
                                  Danke dir! :)
                                  • haschelH haschel
                                    @Kuddel
                                    Danke dir! :)
                                    K
                                    K
                                    Kuddel
                                    #74
                                    @haschel
                                    der Wert wird direkt im Powershellskript umgerechnet
                                    haschelH G 2 Antworten Letzte Antwort
                                    • K Kuddel
                                      @haschel
                                      haschelH
                                      haschelH
                                      haschel
                                      #75
                                      @Kuddel ja, so meine ich das auch verstanden zu haben. Da scheint ja eine Bedingung für das Anzeigen/Berechnen von GB oder TB zu sein - richtig? Will mich da jetzt ein wenig reinfuchsen, deswegen die Fragen - hoffe es stört dich nicht... :)
                                      • D
                                        D
                                        derrapf
                                        #76
                                        Hi
                                        Da sind ein paar spannende Widgets dabei.
                                        Wie hast Du denn den Wecker realisiert und welche Widgets dazu verwendet`? Ist das ein einzelnes Widget oder eine Kombination aus Mehreren?
                                        Gruss Ralf
                                        • D derrapf
                                          Hi
                                          Gruss Ralf
                                          K
                                          K
                                          Kuddel
                                          #77
                                          @derrapf
                                          Die Weckzeit besteht aus 3 Widgets.
                                          1. Anzeige der Uhrzeit (Stunde:Minute)
                                          2. Steuerung der Stunde
                                          3. Stuerung der Minunte
                                          Auf Grund der Weckzeit wird dann entsprechend ein Skript zur ausgewählten Zeit gestartet, was Lampen, Echos etc. anschaltet
                                          83.9k
