  4. Fehlermeldung im Log
    6.0k
47 Beiträge 10 Kommentatoren 6.5k Aufrufe 5 Beobachtet
    Danke!
    Dann müsste der Befehl passen - jetzt bin ich ratlos.
    Vielleicht weiss @Apollon77 weiter
    Rainer
    • KusselinK Kusselin
      könnt ihr mir bitte sagen was das für ein Fehler ist? hängt das mit Node.js zusammen…was muss ich da machen?
      Gruss
      host.raspberrypi	2019-01-26 17:44:16.288	error	instance system.adapter.zigbee.0 terminated with code 1 ()
      host.raspberrypi	2019-01-26 17:44:16.288	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:700:10)
      host.raspberrypi	2019-01-26 17:44:16.288	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:689:30)
      host.raspberrypi	2019-01-26 17:44:16.288	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
      host.raspberrypi	2019-01-26 17:44:16.288	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:81:44)
      host.raspberrypi	2019-01-26 17:44:16.288	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:22:18)
      host.raspberrypi	2019-01-26 17:44:16.288	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:637:17)
      host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:530:3)
      host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:538:12)
      host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:599:32)
      host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:718:18)
      host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
      host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: NODE_MODULE_VERSION 64\. Please try re-compiling or re-installing
      host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: NODE_MODULE_VERSION 57\. This version of Node.js requires
      host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: was compiled against a different Node.js version using
      host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
      host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: ^
      host.raspberrypi	2019-01-26 17:44:16.286	error	Caught by controller[0]: throw e
      host.raspberrypi	2019-01-26 17:44:16.286	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:88</anonymous>
      megaron
      @Kusselin
      Hallo, ich habe einen Pi4 neu installiert. Alle Programmteile sind aktuell. Leider bekomme die selben Fehlermeldungen wie du im Minutentakt. Wie hast du dein Problem gelöst bekommen?
      Viele Grüße megaron
      Viele Grüße megaron
        maxpd
        schrieb am zuletzt editiert von maxpd
        Same here nach update von Nodejs 10 auf 12.
        host.iobroker	2020-05-07 20:53:15.856	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.iobroker	2020-05-07 20:53:15.855	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.iobroker	2020-05-07 20:53:15.855	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
        host.iobroker	2020-05-07 20:53:15.855	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
        host.iobroker	2020-05-07 20:53:15.855	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
        host.iobroker	2020-05-07 20:53:15.854	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
        host.iobroker	2020-05-07 20:53:15.854	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
        host.iobroker	2020-05-07 20:53:15.854	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
        host.iobroker	2020-05-07 20:53:15.854	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
        host.iobroker	2020-05-07 20:53:15.854	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
        host.iobroker	2020-05-07 20:53:15.854	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
        host.iobroker	2020-05-07 20:53:15.853	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
        host.iobroker	2020-05-07 20:53:15.853	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
        host.iobroker	2020-05-07 20:53:15.853	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
        host.iobroker	2020-05-07 20:53:15.853	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
        host.iobroker	2020-05-07 20:53:15.853	error	Caught by controller[0]: was compiled against a different Node.js version using
        host.iobroker	2020-05-07 20:53:15.852	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
        host.iobroker	2020-05-07 20:53:15.852	error	Caught by controller[0]: ^
        host.iobroker	2020-05-07 20:53:15.852	error	Caught by controller[0]: throw e;
        host.iobroker	2020-05-07 20:53:15.851	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
        host.iobroker	2020-05-07 20:53:15.459	info	instance system.adapter.zigbee.0 started with pid 3641
        maxpd
        Raspi 4 8gb | iobroker + pivccu3 | 46 Adapter | 68 Scripte, 120 Devices
        • M maxpd
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          @maxpd sagte in Fehlermeldung im Log:
          cd /opt/iobroker
          iobroker stop
          npm rebuild
          iobroker start
          • GlasfaserG Glasfaser
            cd /opt/iobroker
            iobroker stop
            npm rebuild
            iobroker start
            maxpd
            @Glasfaser LEider klappt das nicht
            pi@iobroker:/opt/iobroker $ iobroker stop
            pi@iobroker:/opt/iobroker $ npm rebuild
            > iobroker@2.0.3 install /opt/iobroker/node_modules/iobroker
            > node lib/checkVersions.js
            NPM version: 6.14.4
            > iobroker@2.0.3 postinstall /opt/iobroker/node_modules/iobroker
            > node lib/install.js
            lib/install.js is not being run as part of an installation - skipping...
            > protobufjs@6.8.9 postinstall /opt/iobroker/node_modules/protobufjs
            > node scripts/postinstall
            > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings
            > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
            prebuild-install WARN install No prebuilt binaries found (target=12.16.3 runtime=node arch=arm libc= platform=linux)
            gyp ERR! clean error
            gyp ERR! stack Error: EACCES: permission denied, rmdir 'build'
            gyp ERR! System Linux 4.19.97-v7l+
            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
            gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings
            gyp ERR! node -v v12.16.3
            gyp ERR! node-gyp -v v5.1.0
            gyp ERR! not ok
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! @serialport/bindings@2.0.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the @serialport/bindings@2.0.8 install script.
            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            npm ERR!     /home/pi/.npm/_logs/2020-05-07T20_24_32_194Z-debug.log
            maxpd
            • M maxpd
              NPM version: 6.14.4
              > node lib/install.js
              gyp ERR! not ok
              npm ERR! errno 1
              npm ERR!
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              Link Text
              Wie hast du denn von 10 auf 12 hochgezogen ... mit welchen Befehlen !??
              und lass mal den Fixer drüberlaufen
              Thomas BraunT M 2 Antworten Letzte Antwort
                Link Text
                @maxpd
                Da hast du vermutlich tiefer im System was verfummelt. Das hatten wir gestern schon mal. Ich such den Thread nochmal raus.
                Da musste in den jason files irgendwas gelöscht werden. War aber nicht ganz risikofrei, wenn ich mich recht entsinne.
                  Link Text
                  maxpd
                  @Glasfaser
                  curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
                  sudo apt update
                  sudo apt dist-upgrade
                  maxpd
                  • M maxpd
                    @Glasfaser
                    sudo apt update
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Glasfaser
                    @maxpd
                    Warum schreibst du nicht im anderen Thread weiter ... das ist murks .
                    @Thomas-Braun hilft dir doch schon hier Link Text
                      @maxpd
                      @AlCalzone schrieb:
                      iobroker@2.0.3 ist das Kern-Paket, dass beim Installieren benötigt wird. Deine Installation denkt wohl, dass das fehlt und bricht daraufhin alle npm-Installationen ab. Eigentlich sollte es auch gar nicht installiert sein, sondern enthält nur die Dateien, die zur Installation benötigt werden. Aus deiner Post-Historie vermute ich, dass du es ausversehen installiert hast, weil du Befehle nicht richtig abgetippt hast.
                      Bitte genau lesen, nicht wie oben immer mal wieder Teile übersehen! Und bitte meine Antwort abwarten, nicht draus irgendwelchen Handlungsbedarf ableiten.
                      Ist im Ordner /opt/iobroker eine Datei package-lock.json?
                      Ist im Ordner /opt/iobroker/node_modules ein Ordner iobroker ohne führendes @?
                      Zeige bitte den Inhalt der Datei /opt/iobroker/package.json.
                        @maxpd
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Glasfaser
                        @Thomas-Braun
                        habe es schon verlinkt !
                          @maxpd
                          maxpd
                          @Glasfaser sorry, weil das Topic hier zugeschnittener war auf das Problem. Meins hatte ja nicht mehr so viel mit dem Eingangsthema zu tun.
                          maxpd
                          • M maxpd
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            @maxpd
                            Komisch !!??
                            im anderen Thread
                            @maxpd
                            auch der rebuild lässt Zigbee nicht starten. Fehler bleibt der gleiche.
                            Aber Egal....
                            • G Offline
                              gifftstaub
                              schrieb am zuletzt editiert von gifftstaub
                              Hallo Zusammen,
                              Ich hänge mich mal hier mit rein.
                              Ich habe auch diese Meldungen im log.
                              iot.0	2020-05-16 10:46:49.889	warn	the module (for instance, using `npm rebuild` or `npm install`).
                              iot.0	2020-05-16 10:46:49.889	warn	NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                              iot.0	2020-05-16 10:46:49.889	warn	NODE_MODULE_VERSION 64. This version of Node.js requires
                              iot.0	2020-05-16 10:46:49.889	warn	was compiled against a different Node.js version using
                              iot.0	2020-05-16 10:46:49.889	warn	(6249) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                              ich habe die Node so ein Update verpasst.
                              Die existierenden node & node.js Versionen deinstallieren
                              sudo apt-get --purge remove node
                              sudo apt-get --purge remove nodejs
                              sudo apt-get autoremove
                              sudo reboot
                              Node.js neu installieren für Linux und Raspberry 2/3
                              sudo apt install -y nodejs
                              sudo reboot
                              wegen dem Fehler oben im Log habe ich unter /opt/iobroker npm rebuild ausgeführt das lief auch ohne meckern durch.
                              nachdem aber noch weiterhin das Problem besteht habe ich nun noch ein npm install ausgeführt dabei kommt die Fehlermeldung.
                              > iobroker.inst@2.0.3 install /opt/iobroker
                              NPM version: 6.14.4
                              > iobroker.inst@2.0.3 postinstall /opt/iobroker
                              > node lib/install.js
                              │ Manual installation of ioBroker is no longer supported  │
                              │ on Linux, OSX and FreeBSD!                              │
                              │ Please refer to the documentation on how to install it! │
                              │ https://github.com/ioBroker/ioBroker/wiki/Installation  │
                              npm ERR! errno 100
                              npm ERR! iobroker.inst@2.0.3 postinstall: `node lib/install.js`
                              npm ERR! Exit status 100
                              npm ERR!
                              npm ERR! Failed at the iobroker.inst@2.0.3 postinstall script.
                              npm ERR!     /home/iobroker/.npm/_logs/2020-05-16T09_24_21_156Z-debug.log
                              wie gehe ich den nun weiter vor?
                              LG
                              • G gifftstaub
                                Hallo Zusammen,
                                sudo reboot
                                sudo reboot
                                NPM version: 6.14.4
                                > node lib/install.js
                                npm ERR! errno 100
                                npm ERR!
                                LG
                                @gifftstaub Kannst du das bitte als Text (in </> Code-Tags) hier posten und nicht als screenshot? Danke.
                                G 1 Antwort Letzte Antwort
                                  gifftstaub
                                  @Thomas-Braun
                                  Sorry ist Erledigt
                                  • G gifftstaub
                                    @Thomas-Braun
                                    Sorry ist Erledigt
                                    @gifftstaub Und dann bitte die komplette Konsole inkl. login prompt.
                                    • G gifftstaub
                                      @Thomas-Braun
                                      Sorry ist Erledigt
                                      @gifftstaub
                                      nodejs -v && node -v && npm -v
                                      which nodejs
                                      which node
                                      which npm
                                        @gifftstaub
                                        which nodejs
                                        which node
                                        which npm
                                        gifftstaub
                                        @Thomas-Braun
                                        which nodejs
                                        /usr/bin/nodejs
                                        which node
                                        /usr/bin/node
                                        which npm
                                        /usr/bin/npm
                                        v12.16.3
                                        v12.16.3
                                        6.14.4
                                        • G gifftstaub
                                          @Thomas-Braun
                                          which nodejs
                                          /usr/bin/nodejs
                                          which node
                                          /usr/bin/node
                                          which npm
                                          /usr/bin/npm
                                          v12.16.3
                                          v12.16.3
                                          6.14.4
                                          @gifftstaub Und die drei anderen Punkte?
