  4. Fehlermeldung im Log
47 Beiträge 10 Kommentatoren 6.6k Aufrufe 5 Beobachtet
  • KusselinK Offline
    KusselinK Offline
    Kusselin
    könnt ihr mir bitte sagen was das für ein Fehler ist? hängt das mit Node.js zusammen…was muss ich da machen?
    Gruss
    host.raspberrypi	2019-01-26 17:44:16.288	error	instance system.adapter.zigbee.0 terminated with code 1 ()
    host.raspberrypi	2019-01-26 17:44:16.288	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:700:10)
    host.raspberrypi	2019-01-26 17:44:16.288	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:689:30)
    host.raspberrypi	2019-01-26 17:44:16.288	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
    host.raspberrypi	2019-01-26 17:44:16.288	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:81:44)
    host.raspberrypi	2019-01-26 17:44:16.288	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:22:18)
    host.raspberrypi	2019-01-26 17:44:16.288	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:637:17)
    host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:530:3)
    host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:538:12)
    host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:599:32)
    host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:718:18)
    host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: NODE_MODULE_VERSION 64\. Please try re-compiling or re-installing
    host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: NODE_MODULE_VERSION 57\. This version of Node.js requires
    host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
    host.raspberrypi	2019-01-26 17:44:16.287	error	Caught by controller[0]: ^
    host.raspberrypi	2019-01-26 17:44:16.286	error	Caught by controller[0]: throw e
    host.raspberrypi	2019-01-26 17:44:16.286	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:88</anonymous>
    • KusselinK Offline
      KusselinK Offline
      Kusselin
      akso das kommt bei den node ausgaben:
      pi@raspberrypi:~ $ node -v
      v10.15.0
      pi@raspberrypi:~ $ nodejs -v
      v10.15.0
      pi@raspberrypi:~ $ npm -v
      6.4.1
      passt das nicht?
      • apollon77A Offline
        Darf ich annehmen das du nodejs von einer Version kleiner 10 auf 10 aktualisiert hast? Dann ist die Fehlermeldung zu erwarten und die lösung steht auch da drin.
        Führe mal "npm rebuild" im iobroker Verzeichnis aus
        • SegwayS Offline
          SegwayS Offline
          Segway
          ist node10 nicht noch zumindest für einige Adapter mit Fehlern behaftet ?
          Die "sichere" Version wäre die 8er oder ?
          Gruß Dirk
          • KusselinK Offline
            KusselinK Offline
            Kusselin
            @apollon77:
            Führe mal "npm rebuild" im iobroker Verzeichnis aus `
            hi appolon,
            ich habe jetzt nochmal nach der Anleitung das gemacht:
                Die alten node & node.js Versionen deinstallieren
                    sudo apt-get --purge remove node
                    sudo apt-get --purge remove nodejs
                    sudo apt-get autoremove
                    sudo reboot
            Node.js neu installieren für Linux und Raspberry 2/3
                curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
                sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
                sudo reboot
            damit kam ich wieder auf 8.xxx und jetzt gehts wieder…aber in fhem brauch ich 10.xx ???? das ist halt blöd...ich fahre parallel noch fhem auf meinem Raspi und hab auch den fhem adapter installiert...jetzt wollte ich halt in fhem noch die xaiomi bridge installieren....dazu brauche ich aber node und nodejs größer 10.xx...
            ich habe den Zigbee adpater installiert und habe da bei Einstellungen das hier eingegeben:
            /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E32C4C-if00
            das gleiche habe ich auch bei fhem unter der yaml datei einegeben müssen..aber ich brauche da eine höhere node und nodejs version…hast du noch ein Tipp wie ich die Bridge in Fhem auch zum laufen bekomme weil so mit der Version v8.15.0 funzt das net in fhem
            • KusselinK Offline
              KusselinK Offline
              Kusselin
              @Segway:
              Die "sichere" Version wäre die 8er oder ? `
              das weiss ich nicht????
              welchen Code müsste ich in die Konsole eingeben um auf die 8er zu kommen.???
              aber in fhem in der Anleitung steht haltr 10.xx
              schaut:
              2\. Installing
              # Setup Node.js repository
              sudo curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
              # Install Node.js
              sudo apt-get install -y nodejs git make g++ gcc
              # Verify that the correct nodejs and npm (automatically installed with nodejs)
              # version has been installed
              node --version  # Should output v10.X
              npm --version  # Should output 6.X
              # Clone zigbee2mqtt repository
              sudo git clone https://github.com/Koenkk/zigbee2mqtt.git /opt/zigbee2mqtt
              sudo chown -R pi:pi /opt/zigbee2mqtt
              # Install dependencies
              cd /opt/zigbee2mqtt
              npm install
                Es kann Probleme geben. Versuch es doch mit der 10er. Bekannt ist das das Löschen von Backup Files …
                • KusselinK Offline
                  KusselinK Offline
                  Kusselin
                  Hää..du schreibst versuch es dich mit der 10er..du meinst hier 8er oder?
                  Hast dich verschrieben…oder?
                  Wie installiert man die 8er also code für Console..
                  • G Offline
                    Georgius
                    Nein er meinte schon 10. Das Löschproblem ist ein bekanntes mit node 10.
                    • KusselinK Offline
                      KusselinK Offline
                      Kusselin
                      Sorry ..verstehe ich nicht was ihr sagt…
                      Wenn ich die 10er installiere geht in iobroker der Yakah und der xiaomi Adapter nicht mehr...
                      Weiß halt nicht was ich jetzt machen soll?
                      Gesendet von iPad mit Tapatalk Pro
                        Warum tut das nicht mehr? Wegen der Fehlermeldung oben? Auch trotz einem "npm rebuild"?
                        • KusselinK Offline
                          KusselinK Offline
                          Kusselin
                          Hi Apollon,
                          Jetzt nochmal in Ruhe..
                          Ich habe jetzt wieder wie in der iobroker Anleitung für raspberry 2+3 das Node und nodejs installiert..hier bin ich dann wieder auf 8.xx
                          Was soll ich deiner Meinung jetzt machen??
                          Auf Console einfach MPM rebuild machen???
                          Sei doch so nett und sag mir in schritten was ich jetzt machen soll auf console..??
                          • HomoranH Offline
                            HomoranH Offline
                            cd /opt/iobroker
                            sudo -H npm rebuild
                            • SegwayS Offline
                              SegwayS Offline
                              Segway
                              ergibt leider bei mir den folgenden Fehler und somit Abbruch:
                              1191 verbose pkgid iobroker@1.3.1
                              1192 verbose cwd /opt/iobroker
                              1193 verbose Linux 4.9.0-7-amd64
                              1194 verbose argv "/usr/bin/node" "/usr/bin/npm" "rebuild"
                              1195 verbose node v8.15.0
                              1196 verbose npm  v6.4.1
                              1197 error code ELIFECYCLE
                              1198 error errno 1
                              1199 error iobroker@1.3.1 postinstall: `node lib/install.js`
                              1199 error Exit status 1
                              1200 error Failed at the iobroker@1.3.1 postinstall script.
                              1200 error This is probably not a problem with npm. There is likely additional logging output above.
                              1201 verbose exit [ 1, true ]
                              Gruß Dirk
                              • KusselinK Offline
                                KusselinK Offline
                                Kusselin
                                @Homoran:
                                cd /opt/iobroker
                                sudo -H npm rebuild
                                Was bedeutet wenn ich das eingebe??
                                Und was mach ich danach??
                                Erzähl doch bislang was dazu das andere auch was verstehen
                                Danke Dir
                                • HomoranH Offline
                                  HomoranH Offline
                                  @Kusselin:
                                  Was bedeutet wenn ich das eingebe?? `
                                  Ich weiß nicht wo genau es da bei dir hakt?
                                  Wenn du wissen willst, was diese Befehle bewirken?
                                  1.) wechsel in das Installationsverzeichnis von ioBroker
                                  2.) Die Pakete werden immer für die Hardware, das Betriebssystem und das jeweilige nodejs-Framework kompiliert.
                                  Dies muss jetzt angepasst werden, da du (zumindest) die Version von nodejs geändert hast.
                                  Rainer
                                  • KusselinK Offline
                                    KusselinK Offline
                                    Kusselin
                                    das kommt wenn ich das von die eingabe:
                                    pi@raspberrypi:~ $ cd /opt/iobroker
                                    pi@raspberrypi:/opt/iobroker $ sudo -H npm rebuild
                                    > iobroker@2.0.2 install /opt/iobroker/node_modules/iobroker
                                    > node lib/checkVersions.js
                                    NPM version: 6.4.1
                                    > iobroker@2.0.2 postinstall /opt/iobroker/node_modules/iobroker
                                    > node lib/install.js
                                    lib/install.js is not being run as part of an installation - skipping...
                                    > serialport@6.2.2 install /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
                                    > prebuild-install || node-gyp rebuild
                                    prebuild-install WARN install EACCES: permission denied, access '/root/.npm'
                                    gyp ERR! clean error
                                    gyp ERR! stack Error: EACCES: permission denied, rmdir 'build'
                                    gyp ERR! System Linux 4.14.79-v7+
                                    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
                                    gyp ERR! node -v v8.15.0
                                    gyp ERR! node-gyp -v v3.8.0
                                    gyp ERR! not ok
                                    npm ERR! code ELIFECYCLE
                                    npm ERR! errno 1
                                    npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
                                    npm ERR! Exit status 1
                                    npm ERR!
                                    npm ERR! Failed at the serialport@6.2.2 install script.
                                    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                    npm ERR!     /root/.npm/_logs/2019-01-27T12_54_47_265Z-debug.log
                                    • HomoranH Offline
                                      HomoranH Offline
                                      Ähm???
                                      wie hast du ioBroker (und nodejs) installiert?
                                      Rainer
                                        Vllt eine alte Installation?
                                        Mach mal ohne das -H
                                        Gesendet vom Handy …
                                        • KusselinK Offline
                                          KusselinK Offline
                                          Kusselin
                                          @Homoran:
                                          Ähm???
                                          Rainer `
                                          so wie hier angegeben:
                                          Installation Node.js
                                              System-Update: sudo apt-get update && sudo apt-get upgrade
                                              Je nach verwendetem OS kann das Update auch mittels: sudo apt update && sudo apt upgrade ausgeführt werden
                                              Auf bereits vorhandene Versionen von nodejs und npm testen.
                                                  node -v
                                                  nodejs -v
                                                  npm -v
                                              nur wenn ALLE diese Befehle kein Ergebnis bringen (also keine Versionsnummer mehr anzeigen) mit Schritt 4\. dieses Abschnittes weitermachen, sonst
                                                      sudo reboot
                                                  sudo reboot
                                              Nach der Installation müssen das Kommandos “node -v” und “nodejs -v” die gleiche Versionsnummer zurückgeben.
                                                  Falls “node -v” eine Fehlermeldung wie “nicht gefunden” erzeugt, dann bitte ein sudo ln -s /usr/local/bin/nodejs /usr/bin/node an der Konsole ausführen.
                                                  Sind die Versionen unterschiedlich, bitte nochmals den Abschnitt “Installation Node.js” abarbeiten
                                              Als letzte Überprüfung bitte noch die Version von npm mittels npm -v überprüfen.
                                              Ergibt dies eine Version < 6, bitte noch mit sudo npm install -g npm@6 ein npm-Update durchführen
                                          Installation ioBroker
                                              ioBroker installieren. Die Installation kann mit dem User pi aber auch mit dem User root erfolgen
                                                  An der Konsole dann
                                                  curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/installer.sh | bash -
                                                  ausführen
                                                  Die Installation erfolgt in 4 Schritten:
                                                      Creating ioBroker directory (1/4)
                                                      Downloading installation files (2/4)
                                                      Installing ioBroker (3/4)
                                                      Finalizing installation (4/4)
                                                  Zum Abschluss kommt dann noch die Meldung
                                                  ioBroker was installed successfully
                                                  Open http://localhost:8081 in a browser and start configuring!
                                                  ioBroker nun über IP im Webbrowser aufrufen: http://IP-Adresse:8081
