  4. Javascript Adapter lässt sich nicht mehr installieren.
    6.0k
62 Beiträge 5 Kommentatoren 7.1k Aufrufe
  • ? Offline
    #41
    Mit chown -R pi:pi /home/pi/.npm
    $ ./iobroker add javascript 0 --host bpi-iobroker
    NPM version: 6.4.1
    npm install iobroker.javascript --production --save --prefix "/opt/iobroker" (System call)
    npm
     WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    npm
     ERR! path /root/.npm/_logsnpm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall scandir
    npm ERR! Error: EACCES: permission denied, scandir '/root/.npm/_logs'npm ERR!  { Error: EACCES: permission denied, scandir '/root/.npm/_logs'
    npm ERR!   stack: 'Error: EACCES: permission denied, scandir \'/root/.npm/_logs\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'scandir',
    npm ERR!   path: '/root/.npm/_logs' }
    npm ERR! npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    glob error { Error: EACCES: permission denied, scandir '/root/.npm/_logs'  stack: 'Error: EACCES: permission denied, scandir \'/root/.npm/_logs\'',
      errno: -13,
      code: 'EACCES',
      syscall: 'scandir',
    npm
     ERR! path /root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2benpm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall open
    npm ERR! Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be'npm ERR!  { Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be'
    npm
    ERR!   cause: npm ERR!    { Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be'
    npm ERR!      syscall: 'open',
    npm ERR!      path: '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be' },
    npm ERR!   isOperational: true,
    npm ERR!   stack: 'Error: EACCES: permission denied, open \'/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be\'',
    npm ERR!
    npm
     ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm
     ERR! code ELIFECYCLE
    npm ERR! errno 243
    npm ERR! iobroker.javascript@4.0.2 postinstall: `node ./install/installTypings.js`npm ERR! Exit status 243
    npm ERR!
    npm ERR! Failed at the iobroker.javascript@4.0.2 postinstall script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2018-12-05T16_38_06_223Z-debug.log
    ERROR: host.bpi-iobroker Cannot install iobroker.javascript: 243
    Mit chown -R iobroker:iobroker /home/iobroker/.npm
    NPM version: 6.4.1
    npm
    npm
    npm ERR! errno -13
    npm
    npm ERR!
      errno: -13,
      code: 'EACCES',
      syscall: 'scandir',
    npm ERR! path /root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2benpm ERR! code EACCES
    npm ERR! errno -13
    npm
    ERR! syscall open
    npm ERR!   cause:
    npm ERR!
    npm ERR!
     It is likely you do not have the permissions to access this file as the current usernpm ERR!
    npm
    ERR! code ELIFECYCLEnpm
    ERR! errno 243
    npm
    npm
    ERR! npm ERR! Failed at the iobroker.javascript@4.0.2 postinstall script.
    npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2018-12-05T16_41_13_634Z-debug.log
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      #42
      Ok dann muss ich selbst nochmal auf die Suche gehen. Melde mich später.
      • ? Offline
        #43
        OK,
        übrigens bin ich als root angemeldet. Daher oben kein Sudo davor.
        • StuebiS Offline
          StuebiS Offline
          Stuebi
          #44
          @Menne:
          OK,
          übrigens bin ich als root angemeldet. Daher oben kein Sudo davor. `
          Bei mir hatte folgendes im meinem Docker Container geholfen :
          cd /opt/iobroker
          npm install iobroker.javascript@4.0.1
          iobroker update javascript
          ioBroker auf Synology DS216+II im Docker Container
          • ? Offline
            #45
            Das habe ich gestern schon probiert, habe es ebend nochmals versucht….
            root@bpi-iobroker:/# npm install iobroker.javascript@4.0.1
            npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
            > iobroker.javascript@4.0.1 postinstall /node_modules/iobroker.javascript
            installing NodeJS typings...
            npm ERR! path /root/.npm/_logs
            npm ERR! errno -13
            npm ERR!
            npm ERR!
              errno: -13,
              code: 'EACCES',
              syscall: 'scandir',
            npm ERR! errno -13
            npm ERR!   cause:
            npm ERR!
            npm ERR!
            npm WARN enoent ENOENT: no such file or directory, open '/package.json'
            npm WARN !invalid#1 No description
            npm WARN !invalid#1 No repository field.
            npm WARN !invalid#1 No README data
            npm WARN !invalid#1 No license field.
            npm ERR! code ELIFECYCLE
            npm ERR! errno 243
            npm ERR! iobroker.javascript@4.0.1 postinstall: `node ./install/installTypings.js`
            npm ERR!
            npm ERR! Failed at the iobroker.javascript@4.0.1 postinstall script.
            npm ERR!     /root/.npm/_logs/2018-12-05T17_13_26_786Z-debug.log
            Tja
            • ? Offline
              #46
              Diese Adapter sind derzeit schon installiert.
              Nur Java steigt aus.
              Web und Scenes Adapter gingen auch ebend zu installieren. Bleibt für mich nur der Java übrig.
              Mehr brauche ich derzeit nicht. Nur für Licht, Geräte, Tasten und Aktionen Steuerung via Alexa.
              …und dazu brauche ich noch die Scripte.
                AlCalzoneA Offline
                AlCalzone
                #47
                Ich weiß woran es liegt, die Frage ist jedoch, wie es zu beheben ist.
                Auf die Gefahr hin, dass ich nerve… ich benötige möglichst detaillierte Informationen von dir.
                Du installierst auf einem RasPi (bzw. Derivat davon), richtig?
                Das OS ist Raspbian?
                Wenn du die Installationsroutine ausführst (curl ...), als welcher User startest du sie?
                Führe bitte folgendes aus:
                ps aux | grep js-controller
                Welcher User steht in der Zeile mit iobroker.js-controller (ganz vorne)?
                Als welcher User warst du angemeldet, als du versucht hast, manuell javascript zu installieren (npm install …)?
                • ? Offline
                  #48
                  Ich installiere auf einen Banana pi M2
                  OS Minimal-Raspbian
                  Installiert als root
                  root@bpi-iobroker:/opt/iobroker# ps aux | grep js-controller
                  iobroker  7264 73.0  2.4  80780 24868 ?        Rsl  19:14   0:01 iobroker.js-controller
                  root      7271  0.0  0.0   4364   848 pts/0    S+   19:14   0:00 grep js-controller
                  root     10456  1.3  5.7 152544 59244 ?        Ssl  16:37   2:07 iobroker.js-controller
                  Ich hatte root bisher nicht abgemeldet.
                  Ist ja nur eigenartig, das sich die anderen Adapter installieren ließen
                  • StuebiS Offline
                    StuebiS Offline
                    Stuebi
                    #49
                    Ich bin kein NPM Experte, aber folgendes kannst ja nochmals versuchen.
                    cd /opt/iobroker
                    npm install iobroker.javascript --unsafe-perm
                    iobroker upload javascript
                    <size size="85">Edit: Fehlerhafte Befehle korrigiert, Problematische Befehle entfernt. (AlCalzone)</size>
                      AlCalzoneA Offline
                      AlCalzone
                      #50
                      Dein JS-Controller läuft 2x, hat vermutlich mit der systemd und den start/stop-Experimenten zu tun.
                      Kannst du die Kiste mal sauber neu starten? Erst dann kann man sicher sein, unter welchem User ioBroker tatsächlich läuft.
                      Prüfe danach bitte nochmal die Ausgabe von dem Befehl.
                      Wenn es iobroker ist, dann probier bitte nochmal die Installation über das Webinterface.
                      Sofern es wirklich root ist, weiß ich, welche Änderung am JS-Adapter nötig ist.
                      Das Postinstall-Skript will nämlich auch "npm install" ausführen, läuft auch unter dem User root, aber mit verringerten Rechten. Deswegen haben die ganzen Permission-Geschichten nicht gegriffen.
                      Du kannst dann als Workaround den Adapter folgendermaßen manuell installieren:
                      cd /opt/iobroker
                      npm i iobroker.javascript --unsafe-perm
                        AlCalzoneA Offline
                        AlCalzone
                        #51
                        @tstueben - Bitte informier dich erst mal über die Befehle, die du hier postest:
                        • npm config set … setzt unsafe-perm für alle Installationen in ioBroker auf true. Das untergräbt alle Sicherheitsanstrengungen, die wir in letzter Zeit unternommen haben. Bitte nicht!
                        • "npm install iobroker.javascript@4.0.1 unsafe-perm=true" ist kein richtiger Befehl. Siehe mein anderer Kommentar. Außerdem ist inzwischen 4.0.2 verfügbar
                        • "iobroker update javascript" ist Unfug.
                        • ? Offline
                          #52
                          root@bpi-iobroker:/opt/iobroker# npm install iobroker.javascript@4.0.1  unsafe-p                  erm=true
                          npm ERR! code EINVALIDTAGNAME
                          npm ERR! Invalid tag name "unsafe-perm=true": Tags may not have any characters t                  hat encodeURIComponent encodes.
                          npm ERR!     /root/.npm/_logs/2018-12-05T18_22_16_681Z-debug.log
                          root@bpi-iobroker:/opt/iobroker# root@bpi-iobroker:/opt/iobroker#
                          bash: root@bpi-iobroker:/opt/iobroker#: Datei oder Verzeichnis nicht gefunden
                          root@bpi-iobroker:/opt/iobroker# npm install iobroker.javascript@4.0.1  unsafe-perm=true
                          npm ERR! Invalid tag name "unsafe-perm=true": Tags may not have any characters that encodeURIComponent encodes.
                          npm ERR!     /root/.npm/_logs/2018-12-05T18_25_18_797Z-debug.log
                          root@bpi-iobroker:/opt/iobroker# npm config set unsafe-perm true
                          > iobroker.javascript@4.0.1 postinstall /opt/iobroker/node_modules/iobroker.javascript
                          npm notice created a lockfile as package-lock.json. You should commit this file.
                          + @types/node@8.10.38
                          added 9 packages from 53 contributors and audited 10 packages in 6.901s
                          found 0 vulnerabilities
                          + iobroker.javascript@4.0.1
                          added 15 packages from 52 contributors and audited 2942 packages in 84.428s
                          found 40 vulnerabilities (28 low, 12 high)
                            run `npm audit fix` to fix them, or `npm audit` for details
                          root@bpi-iobroker:/opt/iobroker# iobroker update javascript
                          Used repository: javascript
                          update done
                          Das zweite funzte, aber beim hochladen in der vorletzten Zeile ein Fehler.
                          Javascrpt wird als installiert angezeigt,ist aber nicht in Instanzen vertreten.
                          Upload
                          $ ./iobroker upload javascript
                          got /opt/iobroker/node_modules/iobroker.javascript/admin
                          upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/redshift/redshift.js vs/basic-languages/redshift/redshift.js application/javascript
                          upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/objective-c/objective-c.js vs/basic-languages/objective-c/objective-c.js application/javascript
                          upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/go/go.js vs/basic-languages/go/go.js application/javascript
                          upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vendor/socket.io.js vendor/socket.io.js application/javascript
                          upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/css/main.cd153a24.chunk.css static/css/main.cd153a24.chunk.css text/css
                          upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/it.js google-blockly/own/msg/it.js application/javascript
                          upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_timeout.js google-blockly/own/blocks_timeout.js application/javascript
                          upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pl.js google-blockly/msg/js/pl.js application/javascript
                          upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote0.png google-blockly/media/quote0.png image/png
                          upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur application/octet-stream
                          upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur application/octet-stream
                          upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur application/octet-stream
                          upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/x-wav
                          upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
                          upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
                          upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/x-wav
                          upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
                          upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
                          upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/x-wav
                          upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
                          upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
                          upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
                          upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
                          upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
                          upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
                          upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE application/octet-stream
                          upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/x-icon
                          upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
                          upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                          ERROR: system.adapter.javascript does not exist
                          process exited with code 0
                          • ? Offline
                            #53
                            Jetzt nochmals über Admin drüber installiert….läuft.
                            Schwere Geburt
                            • StuebiS Offline
                              StuebiS Offline
                              Stuebi
                              #54
                              @AlCalzone:
                              • "iobroker update javascript" ist Unfug. `
                              Wie gesagt ich hatte das gleiche Problem. Mit npm install iobroker.javascript@4.0.1 –unsafe-perm konnte ich den Adapter installieren. Anschließend wurden mir die alten Screens vom 3.6 angezeigt. Browserchache löschen etc. hat nicht geholfen. Erst mit iobroker update javascript hatte ich das neue Design! Vielleicht Zufall, aber so lief es bei mir! Wie oben schon angemerkt ich bin kein NPM Experte.
                              • ? Offline
                                #55
                                Danke euch allen.
                                Jetzt kommt es aufs Backup an.
                                Das ist ein Total Backup….weiss da jemand zufällig wie lange es dauert?
                                Noch ist iobroker gestoppt...
                                ca. 70 MB
                                ...wieder gestartet
                                  AlCalzoneA Offline
                                  AlCalzone
                                  #56
                                  @tstueben:
                                  Erst mit iobroker update javascript hatte ich das neue Design! `
                                  Du meinst iobroker <u>upload</u> javascript.
                                  • StuebiS Offline
                                    StuebiS Offline
                                    Stuebi
                                    #57
                                    @AlCalzone:
                                    @tstueben:
                                    Du meinst iobroker <u>upload</u> javascript. `
                                    heute habe ich es mit den Befehlen :-) update statt upload und unsafe-perm=true statt nur unsafe-perm . Ich glaube ich lege den Rechner für heute zur Seite.
                                    • ? Offline
                                      #58
                                      Kurze Rückmeldung:
                                      Restore hat auch geklappt…
                                      Funkionstest bestanden
                                      Alles bestens.
                                      Ich werde dann noch ein Image für den Banana Pi M2 Berry vorbereiten auf der Basis
                                      von einem Minimal-Raspbian und den im Image üblichen Adaptern.
                                      Wenn ich noch ein Raspbian finde das nur 4GB braucht, wird das Image für einen 4GB Karte sein. Sonst wird es 8GB.
                                      Leute habt einen schönen Dank bei der Hilfe.
                                      Falls wir uns nicht mehr Schreiben wünsche ich euch allen ein Frohes Weihnachtfest und einen guten Rutsch ins neue Jahr.
                                        AlCalzoneA Offline
                                        AlCalzone
                                        #59
                                        @tstueben:
                                        heute habe ich es mit den Befehlen :-) update statt upload und unsafe-perm=true statt nur unsafe-perm . Ich glaube ich lege den Rechner für heute zur Seite. `
                                        Und immer noch zwei Bindestriche vergessen ;) Gute Nacht :D
                                        • ? Offline
                                          #60
                                          Irgendwas scheint trotzdem noch falsch zu laufen.
                                          Habe gestern Abend sowie jetzt einen vollständiges System Reboot gemacht.
                                          Natürlich vorher iobroker heruntergefahren.
                                          Wenn er wieder nach oben fährt, fängt die Web Oberfläche im Takt an von Hell auf Dunkel zu schalten.
                                          Im Dunkel Modus kommt der Spinner. Also für mich fährt er rauf/runter.
                                          Gefangen hat sich das, indem ich in der Konsole 2x iobroker hintereinander starten musste.
                                          Das war gestern Abend und jetzt. Ich kann das auch immer wieder nachvollziehen.
                                          Hier mal ein Auszug aus dem Info Log.
                                          admin.0	2018-12-06 11:23:52.671	info	received all objects
                                          iobroker	2018-12-06 11:23:51.862	info	exit 0
                                          iobroker	2018-12-06 11:23:51.818	info	Starting node restart.js
                                          discovery.0	2018-12-06 11:23:51.595	info	starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.discovery, node: v8.14.0
                                          admin.0	2018-12-06 11:23:50.886	info	received all states
                                          iobroker	2018-12-06 11:23:50.524	info	_restart
                                          Error:	2018-12-06 11:23:50.509	error	at Timer.listOnTimeout (timers.js:290:5)
                                          Error:	2018-12-06 11:23:50.509	error	at tryOnTimeout (timers.js:323:5)
                                          Error:	2018-12-06 11:23:50.509	error	at ontimeout (timers.js:498:11)
                                          Error:	2018-12-06 11:23:50.509	error	at Timeout.saveConfig [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1897:16)
                                          Error:	2018-12-06 11:23:50.509	error	at Object.fs.writeFileSync (fs.js:1299:33)
                                          Error:	2018-12-06 11:23:50.509	error	at Object.fs.openSync (fs.js:646:18)
                                          Error:	2018-12-06 11:23:50.509	error	EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json.bak'
                                          uncaught	2018-12-06 11:23:50.502	error	exception: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json.bak'
                                          admin.0	2018-12-06 11:23:49.696	info	Request actual repository...
                                          admin.0	2018-12-06 11:23:49.692	info	requesting all objects
                                          admin.0	2018-12-06 11:23:49.688	info	requesting all states
                                          admin.0	2018-12-06 11:23:49.642	info	starting. Version 3.5.10 in /opt/iobroker/node_modules/iobroker.admin, node: v8.14.0
                                          admin.0	2018-12-06 11:23:49.614	error	setObject id missing!!
                                          host.bpi-iobroker	2018-12-06 11:23:49.450	info	instance system.adapter.discovery.0 started with pid 3460
                                          host.bpi-iobroker	2018-12-06 11:23:45.520	info	instance system.adapter.admin.0 started with pid 3432
                                          host.bpi-iobroker	2018-12-06 11:23:45.428	info	starting 11 instances
                                          host.bpi-iobroker	2018-12-06 11:23:45.397	info	11 instances found
                                          host.bpi-iobroker	2018-12-06 11:23:45.355	info	InMemoryDB connected
                                          host.bpi-iobroker	2018-12-06 11:23:45.306	info	inMem-objects listening on port 9001
                                          host.bpi-iobroker	2018-12-06 11:23:44.907	info	inMem-states listening on port 9000
