  4. Javascript Adapter lässt sich nicht mehr installieren.
    6.0k
62 Beiträge 5 Kommentatoren 7.1k Aufrufe
  • ? Offline
    Dein Befehl wurde eingegeben und nochmals installiert.
    Diesmal vom Git-Hub
    $ ./iobroker url "https://github.com/ioBroker/ioBroker.javascript/tarball/master" javascript --debug
    install https://github.com/ioBroker/ioBroker.javascript/tarball/master
    npm install https://github.com/ioBroker/ioBroker.javascript/tarball/master --production --save --prefix "/opt/iobroker" (System call)
    npm
     WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    > iobroker.javascript@4.0.2 postinstall /opt/iobroker/node_modules/iobroker.javascript
    > node ./install/installTypings.js
    installing NodeJS typings...
    npm
     ERR! path /root/.npm/_logsnpm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall scandir
    npm ERR! Error: EACCES: permission denied, scandir '/root/.npm/_logs'npm ERR!  { Error: EACCES: permission denied, scandir '/root/.npm/_logs'
    npm ERR!   stack: 'Error: EACCES: permission denied, scandir \'/root/.npm/_logs\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'scandir',
    npm ERR!   path: '/root/.npm/_logs' }
    npm ERR! npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    glob error { Error: EACCES: permission denied, scandir '/root/.npm/_logs'  stack: 'Error: EACCES: permission denied, scandir \'/root/.npm/_logs\'',
      errno: -13,
      code: 'EACCES',
      syscall: 'scandir',
    npm ERR! path /root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2benpm ERR! code EACCES
    npm ERR! errno -13
    npm ERR!
     syscall opennpm ERR! Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be'
    npm ERR!  { Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be'
    npm ERR!   cause:
    npm ERR!      syscall: 'open',
    npm ERR!      path: '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be' },
    npm ERR!   isOperational: true,
    npm ERR!   stack: 'Error: EACCES: permission denied, open \'/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be\'',
    npm ERR!   syscall: 'open',npm ERR!   path: '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be' }
    npm ERR!
    npm ERR!
    npm
     ERR! code ELIFECYCLEnpm ERR! errno 243
    npm ERR! iobroker.javascript@4.0.2 postinstall: `node ./install/installTypings.js`npm ERR! Exit status 243
    npm ERR!
    npm ERR! Failed at the iobroker.javascript@4.0.2 postinstall script.
    npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2018-12-05T16_15_30_736Z-debug.log
    ERROR: host.bpi-iobroker Cannot install https://github.com/ioBroker/ioBroker.javascript/tarball/master: 243
    Irgendwie drehen wir uns im Kreis
    Dieser Befehl wurde zum installieren von iobroker benutzt:
    curl -sL https://raw.githubusercontent.com/ioBro … staller.sh | bash -
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      @Menne:
      Irgendwie drehen wir uns im Kreis Und da haben wir es wieder :roll: > Diesmal vom Git-Hub `
      Warum machst du bei der Fehlersuche parallel Dinge, nach denen du nicht gefragt wurdest?
      Etwas Geduld bitte, ich habe hier kein System an dem ich es schnell selbst ausprobieren kann.
      Bitte folgendes probieren:
      sudo chown -R pi:pi /home/pi/.npm
      JavaScript über Admin installieren. Ergebnis hier posten.
      Geht das nicht, dann
      sudo chown -R iobroker:iobroker /home/iobroker/.npm
      wieder JavaScript über Admin installieren. Ergebnis hier posten.
      Geht das auch nicht, dann bitte nochmal melden.
      • ? Offline
        Jawohl Sir
        …konnte ich mir nicht verkneifen. :D
        • ? Offline
          Mit chown -R pi:pi /home/pi/.npm
          $ ./iobroker add javascript 0 --host bpi-iobroker
          NPM version: 6.4.1
          npm install iobroker.javascript --production --save --prefix "/opt/iobroker" (System call)
          npm
          npm
          npm ERR! errno -13
          npm ERR!
            errno: -13,
            code: 'EACCES',
            syscall: 'scandir',
          npm
          npm ERR! errno -13
          npm ERR! syscall open
          npm ERR! Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be'npm ERR!  { Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be'
          npm
          ERR!   cause: npm ERR!    { Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be'
          npm ERR!
          npm
           ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current user
          npm ERR!
          npm
          npm ERR! errno 243
          npm ERR!
          npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2018-12-05T16_38_06_223Z-debug.log
          ERROR: host.bpi-iobroker Cannot install iobroker.javascript: 243
          Mit chown -R iobroker:iobroker /home/iobroker/.npm
          NPM version: 6.4.1
          npm
          npm
          npm ERR! errno -13
          npm
          npm ERR!
            errno: -13,
            code: 'EACCES',
            syscall: 'scandir',
          npm ERR! errno -13
          npm
          ERR! syscall open
          npm ERR!   cause:
          npm ERR!
          npm ERR!
           It is likely you do not have the permissions to access this file as the current usernpm ERR!
          npm
          ERR! errno 243
          npm
          npm
          ERR! npm ERR! Failed at the iobroker.javascript@4.0.2 postinstall script.
          npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2018-12-05T16_41_13_634Z-debug.log
            AlCalzoneA Offline
            AlCalzone
            Ok dann muss ich selbst nochmal auf die Suche gehen. Melde mich später.
            • ? Offline
              OK,
              übrigens bin ich als root angemeldet. Daher oben kein Sudo davor.
              • StuebiS Offline
                StuebiS Offline
                Stuebi
                @Menne:
                OK,
                übrigens bin ich als root angemeldet. Daher oben kein Sudo davor. `
                Bei mir hatte folgendes im meinem Docker Container geholfen :
                cd /opt/iobroker
                npm install iobroker.javascript@4.0.1
                iobroker update javascript
                ioBroker auf Synology DS216+II im Docker Container
                • ? Offline
                  Das habe ich gestern schon probiert, habe es ebend nochmals versucht….
                  root@bpi-iobroker:/# npm install iobroker.javascript@4.0.1
                  npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                  > iobroker.javascript@4.0.1 postinstall /node_modules/iobroker.javascript
                  npm ERR! path /root/.npm/_logs
                  npm ERR! errno -13
                  npm ERR!
                  npm ERR!
                    errno: -13,
                    code: 'EACCES',
                    syscall: 'scandir',
                  npm ERR! errno -13
                  npm ERR!   cause:
                  npm ERR!
                  npm ERR!
                  npm WARN enoent ENOENT: no such file or directory, open '/package.json'
                  npm WARN !invalid#1 No description
                  npm WARN !invalid#1 No repository field.
                  npm WARN !invalid#1 No README data
                  npm WARN !invalid#1 No license field.
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 243
                  npm ERR! iobroker.javascript@4.0.1 postinstall: `node ./install/installTypings.js`
                  npm ERR!
                  npm ERR! Failed at the iobroker.javascript@4.0.1 postinstall script.
                  npm ERR!     /root/.npm/_logs/2018-12-05T17_13_26_786Z-debug.log
                  Tja
                  • ? Offline
                    Diese Adapter sind derzeit schon installiert.
                    Nur Java steigt aus.
                    Web und Scenes Adapter gingen auch ebend zu installieren. Bleibt für mich nur der Java übrig.
                    Mehr brauche ich derzeit nicht. Nur für Licht, Geräte, Tasten und Aktionen Steuerung via Alexa.
                    …und dazu brauche ich noch die Scripte.
                      AlCalzoneA Offline
                      AlCalzone
                      Ich weiß woran es liegt, die Frage ist jedoch, wie es zu beheben ist.
                      Auf die Gefahr hin, dass ich nerve… ich benötige möglichst detaillierte Informationen von dir.
                      Du installierst auf einem RasPi (bzw. Derivat davon), richtig?
                      Das OS ist Raspbian?
                      Wenn du die Installationsroutine ausführst (curl ...), als welcher User startest du sie?
                      Führe bitte folgendes aus:
                      ps aux | grep js-controller
                      Welcher User steht in der Zeile mit iobroker.js-controller (ganz vorne)?
                      Als welcher User warst du angemeldet, als du versucht hast, manuell javascript zu installieren (npm install …)?
                      • ? Offline
                        Ich installiere auf einen Banana pi M2
                        OS Minimal-Raspbian
                        Installiert als root
                        root@bpi-iobroker:/opt/iobroker# ps aux | grep js-controller
                        iobroker  7264 73.0  2.4  80780 24868 ?        Rsl  19:14   0:01 iobroker.js-controller
                        root      7271  0.0  0.0   4364   848 pts/0    S+   19:14   0:00 grep js-controller
                        root     10456  1.3  5.7 152544 59244 ?        Ssl  16:37   2:07 iobroker.js-controller
                        Ich hatte root bisher nicht abgemeldet.
                        Ist ja nur eigenartig, das sich die anderen Adapter installieren ließen
                        • StuebiS Offline
                          StuebiS Offline
                          Stuebi
                          Ich bin kein NPM Experte, aber folgendes kannst ja nochmals versuchen.
                          cd /opt/iobroker
                          npm install iobroker.javascript --unsafe-perm
                          iobroker upload javascript
                          <size size="85">Edit: Fehlerhafte Befehle korrigiert, Problematische Befehle entfernt. (AlCalzone)</size>
                            AlCalzoneA Offline
                            AlCalzone
                            Dein JS-Controller läuft 2x, hat vermutlich mit der systemd und den start/stop-Experimenten zu tun.
                            Kannst du die Kiste mal sauber neu starten? Erst dann kann man sicher sein, unter welchem User ioBroker tatsächlich läuft.
                            Prüfe danach bitte nochmal die Ausgabe von dem Befehl.
                            Wenn es iobroker ist, dann probier bitte nochmal die Installation über das Webinterface.
                            Sofern es wirklich root ist, weiß ich, welche Änderung am JS-Adapter nötig ist.
                            Das Postinstall-Skript will nämlich auch "npm install" ausführen, läuft auch unter dem User root, aber mit verringerten Rechten. Deswegen haben die ganzen Permission-Geschichten nicht gegriffen.
                            Du kannst dann als Workaround den Adapter folgendermaßen manuell installieren:
                            cd /opt/iobroker
                            npm i iobroker.javascript --unsafe-perm
                              AlCalzoneA Offline
                              AlCalzone
                              @tstueben - Bitte informier dich erst mal über die Befehle, die du hier postest:
                              • npm config set … setzt unsafe-perm für alle Installationen in ioBroker auf true. Das untergräbt alle Sicherheitsanstrengungen, die wir in letzter Zeit unternommen haben. Bitte nicht!
                              • "npm install iobroker.javascript@4.0.1 unsafe-perm=true" ist kein richtiger Befehl. Siehe mein anderer Kommentar. Außerdem ist inzwischen 4.0.2 verfügbar
                              • "iobroker update javascript" ist Unfug.
                              • ? Offline
                                root@bpi-iobroker:/opt/iobroker# npm install iobroker.javascript@4.0.1  unsafe-p                  erm=true
                                npm ERR! code EINVALIDTAGNAME
                                npm ERR! Invalid tag name "unsafe-perm=true": Tags may not have any characters t                  hat encodeURIComponent encodes.
                                npm ERR!     /root/.npm/_logs/2018-12-05T18_22_16_681Z-debug.log
                                root@bpi-iobroker:/opt/iobroker# root@bpi-iobroker:/opt/iobroker#
                                bash: root@bpi-iobroker:/opt/iobroker#: Datei oder Verzeichnis nicht gefunden
                                root@bpi-iobroker:/opt/iobroker# npm install iobroker.javascript@4.0.1  unsafe-perm=true
                                npm ERR! Invalid tag name "unsafe-perm=true": Tags may not have any characters that encodeURIComponent encodes.
                                npm ERR!     /root/.npm/_logs/2018-12-05T18_25_18_797Z-debug.log
                                root@bpi-iobroker:/opt/iobroker# npm config set unsafe-perm true
                                > iobroker.javascript@4.0.1 postinstall /opt/iobroker/node_modules/iobroker.javascript
                                npm notice created a lockfile as package-lock.json. You should commit this file.
                                + @types/node@8.10.38
                                added 9 packages from 53 contributors and audited 10 packages in 6.901s
                                found 0 vulnerabilities
                                + iobroker.javascript@4.0.1
                                added 15 packages from 52 contributors and audited 2942 packages in 84.428s
                                found 40 vulnerabilities (28 low, 12 high)
                                  run `npm audit fix` to fix them, or `npm audit` for details
                                root@bpi-iobroker:/opt/iobroker# iobroker update javascript
                                Used repository: javascript
                                update done
                                Das zweite funzte, aber beim hochladen in der vorletzten Zeile ein Fehler.
                                Javascrpt wird als installiert angezeigt,ist aber nicht in Instanzen vertreten.
                                Upload
                                $ ./iobroker upload javascript
                                got /opt/iobroker/node_modules/iobroker.javascript/admin
                                upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/redshift/redshift.js vs/basic-languages/redshift/redshift.js application/javascript
                                upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/objective-c/objective-c.js vs/basic-languages/objective-c/objective-c.js application/javascript
                                upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/go/go.js vs/basic-languages/go/go.js application/javascript
                                upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vendor/socket.io.js vendor/socket.io.js application/javascript
                                upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/css/main.cd153a24.chunk.css static/css/main.cd153a24.chunk.css text/css
                                upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/it.js google-blockly/own/msg/it.js application/javascript
                                upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_timeout.js google-blockly/own/blocks_timeout.js application/javascript
                                upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pl.js google-blockly/msg/js/pl.js application/javascript
                                upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote0.png google-blockly/media/quote0.png image/png
                                upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur application/octet-stream
                                upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur application/octet-stream
                                upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur application/octet-stream
                                upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/x-wav
                                upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
                                upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
                                upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/x-wav
                                upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
                                upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
                                upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/x-wav
                                upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
                                upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
                                upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
                                upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
                                upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
                                upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
                                upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE application/octet-stream
                                upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/x-icon
                                upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
                                upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                ERROR: system.adapter.javascript does not exist
                                process exited with code 0
                                • ? Offline
                                  Jetzt nochmals über Admin drüber installiert….läuft.
                                  Schwere Geburt
                                  • StuebiS Offline
                                    StuebiS Offline
                                    Stuebi
                                    @AlCalzone:
                                    • "iobroker update javascript" ist Unfug. `
                                    Wie gesagt ich hatte das gleiche Problem. Mit npm install iobroker.javascript@4.0.1 –unsafe-perm konnte ich den Adapter installieren. Anschließend wurden mir die alten Screens vom 3.6 angezeigt. Browserchache löschen etc. hat nicht geholfen. Erst mit iobroker update javascript hatte ich das neue Design! Vielleicht Zufall, aber so lief es bei mir! Wie oben schon angemerkt ich bin kein NPM Experte.
                                    • ? Offline
                                      Danke euch allen.
                                      Jetzt kommt es aufs Backup an.
                                      Das ist ein Total Backup….weiss da jemand zufällig wie lange es dauert?
                                      Noch ist iobroker gestoppt...
                                      ca. 70 MB
                                      ...wieder gestartet
                                        AlCalzoneA Offline
                                        AlCalzone
                                        @tstueben:
                                        Erst mit iobroker update javascript hatte ich das neue Design! `
                                        Du meinst iobroker <u>upload</u> javascript.
                                        • StuebiS Offline
                                          StuebiS Offline
                                          Stuebi
                                          @AlCalzone:
                                          @tstueben:
                                          Du meinst iobroker <u>upload</u> javascript. `
                                          heute habe ich es mit den Befehlen :-) update statt upload und unsafe-perm=true statt nur unsafe-perm . Ich glaube ich lege den Rechner für heute zur Seite.
