  4. Raspberrypi install iobroker - node.js 8.12
    6.4k
27 Beiträge 6 Kommentatoren 6.3k Aufrufe
  • J Offline
    j_poool
    Hi to all
    Try to install iobroker on Raspberrypi 3
    Install not possible, cause node.js version
    How can i update node.js to the 8.12 version?
    Thanks for you support :geek:
    ioBroker needs at least Node.JS 8.12\. You have installed 8.11.1
    Please update your Node.JS version!
    npm WARN This failure might be due to the use of legacy binary "node"
    npm WARN For further explanations, please read
    /usr/share/doc/nodejs/README.Debian
    npm ERR! iobroker@1.3.1 install: `node lib/checkVersions.js`
    npm ERR! Exit status 2
    npm ERR!
    npm ERR! Failed at the iobroker@1.3.1 install script.
    npm ERR! This is most likely a problem with the iobroker package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR!     node lib/checkVersions.js
    npm ERR! You can get their info via:
    npm ERR!     npm owner ls iobroker
    npm ERR! There is likely additional logging output above.
    npm ERR! System Linux 4.14.79-v7+
    npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install" "iobroker"
    npm ERR! cwd /home/pi
    npm ERR! node -v v8.11.1
    npm ERR! npm -v 1.4.21
    npm ERR! code ELIFECYCLE
    npm ERR!
    npm ERR! Additional logging details can be found in:
    npm ERR!     /home/pi/npm-debug.log
    npm ERR! not ok code 0
    • apollon77A Offline
      If it is a Linux System you should simply update the packages
      E.g. (or depending on your distribution)
      apt-get update
      apt-get upgrade
      And check afterwards
      node -v
      nodejs -v
      npm -v
      Gesendet vom Handy …
      • J Offline
        j_poool
        Hi! Thank you
        Raspberry was updated but the nodejs version remains the v8.11.1
          How you installed nodejs? Directly using your distribution or using the nodesource curl command? If district then this may be the reason because the often only have older versions. .
          What npm Version you have?
          • J Offline
            j_poool
            I used this instructions
            http://www.iobroker.net/docu/?page_id=5090&lang=en
            Installation of Node.js
            	1\. Kernel Update: sudo apt-get update && sudo apt-get upgrade
            	2\. Deinstall old node.je Version (not required by Jessie Light)
            		1.apt-get --purge remove node
            		2.apt-get --purge remove nodejs
            		3.apt-get autoremove
            		4.reboot
            	3\. login as root via Putty
            	4\. Install Node.js anew for Raspbery 2/3
            		1.curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
            		2.sudo apt-get install -y build-essential python-rpi.gpio python nodejs
            		3.reboot
            	5\. login as root via Putty sudo su (now is Root Mode active)
            	6\. After installation of node.js the command “node -v” should show the node.js version. if not, create alias to bin file::
            sudo ln -s /usr/local/bin/nodejs /usr/bin/node
            npm is up to date?
            pi@panel:~ $ npm -v
            1.4.21
            (node:2450) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpd        ir() instead.
            pi@panel:~ $ node -v
            v8.11.1
            pi@panel:~ $ nodejs -v
            v8.11.1
            Thank you
              please remove node and nodejs again
              sudo apt-get purge node
              sudo apt-get purge nodejs
              and check the versions again
              node -v
              nodejs -v
              npm -v
              the actual npm version is very strange
              looks like ther was a nodejs already installed by the OS
              Greets
              Rainer
              • J Offline
                j_poool
                Ok, node and nodejs is deinstalled
                How or where can i find the nodejs v8.12 for Raspberrypi?
                • paul53P Offline
                  @j_poool:
                  How or where can i find the nodejs v8.12 for Raspberrypi? `
                  curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
                  sudo apt-get install -y nodejs
                  node -v
                  npm -v
                  • J Offline
                    j_poool
                    :idea:
                    Thank you! wrks finally :D
                      The problem is that your linux district updated their node version to 8.x and because you had installed node 6 it was updated and this broke it.
                        Arnulf
                        today i had to reinstall node.js because my latest update crashed.
                        Now I habe node.js 8.14 and ble-adaptes as well as the zigbee-adapter don't run.
                        I sems that the node.js is to new for these adapters.
                        Is this possible?
                          No when changing nodejs versions you may need to rebuild some native modules.
                          Running „npm rebuild“ in your iobroker directory should fix this.
                            Arnulf
                            thank you. I will try it :)
                              Arnulf
                              :shock:
                              waves of errors
                              sudo npm rebuild
                              log.txt
                              • AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                > Error: EACCES: permission denied, scandir '/root/.npm/_logs'
                                Run
                                sudo chown -R $(whoami) ~/.npm
                                and try again.
                                And try npm rebuild without sudo before resorting to sudo npm rebuild. sudo is known to cause problems.
                                  Arnulf
                                  ah thx.
                                  the zigbee adapter still had problems. So I decided to deinstall this adapter and reinstall it
                                  Now it wprks
                                  thank you
                                  Before I make any othe changes I will do a full backup tomorrow… :lol:
                                    Arnulf
                                    @AlCalzone:
                                    Run
                                    and try again.
                                    And try npm rebuild without sudo before resorting to sudo npm rebuild. sudo is known to cause problems. `
                                    hm…
                                    just to clarity first...
                                    means that the ohnership of all files and subdirectories are transferred to user "pi"?
                                    and I have to set this commad at /opt/iobroker ?
                                    and what is with iobroker? do I have to stop it first?
                                      AlCalzoneA Offline
                                      AlCalzone
                                      @Arnulf:
                                      just to clarity first…
                                      means that the ohnership of all files and subdirectories are transferred to user "pi"? `
                                      Newer npm versions have the tendency to change the ownership of the .npm folder in the current user's homedir (~). So when you execute npm install with sudo and later without, it won't be able to access ~/.npm (e.g. /home/pi/.npm) because it now belongs to root.
                                      The above command changes the ownership back to whomever it belonged in the first place.
                                      And no, you don't need to do anything with iobroker or change folder to execute that command.
                                        Arnulf
                                        I tryed n
                                        ==> no output, cursor prompt returns within miliseconds
                                        then
                                        npm rebuild
                                        from the root directory shows this
                                        ! pi@ioBroker-Pi:~ $ npm rebuild
                                        ! ajv@6.5.5 /home/pi/node_modules/ajv
                                        ! fast-deep-equal@2.0.1 /home/pi/node_modules/fast-deep-equal
                                        ! fast-json-stable-stringify@2.0.0 /home/pi/node_modules/fast-json-stable-stringify
                                        ! json-schema-traverse@0.4.1 /home/pi/node_modules/json-schema-traverse
                                        ! uri-js@4.2.2 /home/pi/node_modules/uri-js
                                        ! punycode@2.1.1 /home/pi/node_modules/punycode
                                        ! asap@2.0.6 /home/pi/node_modules/asap
                                        ! asn1@0.2.4 /home/pi/node_modules/asn1
                                        ! safer-buffer@2.1.2 /home/pi/node_modules/safer-buffer
                                        ! assert-plus@1.0.0 /home/pi/node_modules/assert-plus
                                        ! asynckit@0.4.0 /home/pi/node_modules/asynckit
                                        ! aws-sign2@0.7.0 /home/pi/node_modules/aws-sign2
                                        ! aws4@1.8.0 /home/pi/node_modules/aws4
                                        ! bcrypt-pbkdf@1.0.2 /home/pi/node_modules/bcrypt-pbkdf
                                        ! tweetnacl@0.14.5 /home/pi/node_modules/tweetnacl
                                        ! caseless@0.12.0 /home/pi/node_modules/caseless
                                        ! combined-stream@1.0.7 /home/pi/node_modules/combined-stream
                                        ! delayed-stream@1.0.0 /home/pi/node_modules/delayed-stream
                                        ! core-util-is@1.0.2 /home/pi/node_modules/core-util-is
                                        ! dashdash@1.14.1 /home/pi/node_modules/dashdash
                                        ! debug@2.6.9 /home/pi/node_modules/debug
                                        ! ms@2.0.0 /home/pi/node_modules/ms
                                        ! ecc-jsbn@0.1.2 /home/pi/node_modules/ecc-jsbn
                                        ! jsbn@0.1.1 /home/pi/node_modules/jsbn
                                        ! extend@3.0.2 /home/pi/node_modules/extend
                                        ! extsprintf@1.3.0 /home/pi/node_modules/extsprintf
                                        ! forever-agent@0.6.1 /home/pi/node_modules/forever-agent
                                        ! form-data@2.3.3 /home/pi/node_modules/form-data
                                        ! mime-types@2.1.21 /home/pi/node_modules/mime-types
                                        ! mime-db@1.37.0 /home/pi/node_modules/mime-db
                                        ! getpass@0.1.7 /home/pi/node_modules/getpass
                                        ! har-schema@2.0.0 /home/pi/node_modules/har-schema
                                        ! har-validator@5.1.3 /home/pi/node_modules/har-validator
                                        ! http-signature@1.2.0 /home/pi/node_modules/http-signature
                                        ! jsprim@1.4.1 /home/pi/node_modules/jsprim
                                        ! json-schema@0.2.3 /home/pi/node_modules/json-schema
                                        ! verror@1.10.0 /home/pi/node_modules/verror
                                        ! sshpk@1.15.2 /home/pi/node_modules/sshpk
                                        ! ip@1.1.5 /home/pi/node_modules/ip
                                        ! is-absolute@0.2.6 /home/pi/node_modules/is-absolute
                                        ! is-relative@0.2.1 /home/pi/node_modules/is-relative
                                        ! is-unc-path@0.1.2 /home/pi/node_modules/is-unc-path
                                        ! unc-path-regex@0.1.2 /home/pi/node_modules/unc-path-regex
                                        ! is-windows@0.2.0 /home/pi/node_modules/is-windows
                                        ! is-typedarray@1.0.0 /home/pi/node_modules/is-typedarray
                                        ! isstream@0.1.2 /home/pi/node_modules/isstream
                                        ! json-stringify-safe@5.0.1 /home/pi/node_modules/json-stringify-safe
                                        ! lodash@4.17.11 /home/pi/node_modules/lodash
                                        ! minimist@0.0.8 /home/pi/node_modules/minimist
                                        ! mkdirp@0.5.1 /home/pi/node_modules/mkdirp
                                        ! node-persist@2.1.0 /home/pi/node_modules/node-persist
                                        ! q@1.1.2 /home/pi/node_modules/q
                                        ! node-red-contrib-alexa-local@0.3.12 /home/pi/node_modules/node-red-contrib-alexa-local
                                        ! peer-ssdp@0.0.5 /home/pi/node_modules/peer-ssdp
                                        ! stoppable@1.0.5 /home/pi/node_modules/stoppable
                                        ! node-red-contrib-bool-gate@1.0.2 /home/pi/node_modules/node-red-contrib-bool-gate
                                        ! node-red-contrib-wemo-emulator@0.6.0 /home/pi/node_modules/node-red-contrib-wemo-emulator
                                        ! wemore@0.6.0 /home/pi/node_modules/wemore
                                        ! node-ssdp@2.9.1 /home/pi/node_modules/node-ssdp
                                        ! q@2.0.3 /home/pi/node_modules/wemore/node_modules/q
                                        ! pop-iterate@1.0.1 /home/pi/node_modules/pop-iterate
                                        ! weak-map@1.0.5 /home/pi/node_modules/weak-map
                                        ! request@2.88.0 /home/pi/node_modules/request
                                        ! oauth-sign@0.9.0 /home/pi/node_modules/oauth-sign
                                        ! performance-now@2.1.0 /home/pi/node_modules/performance-now
                                        ! qs@6.5.2 /home/pi/node_modules/qs
                                        ! safe-buffer@5.1.2 /home/pi/node_modules/safe-buffer
                                        ! tough-cookie@2.4.3 /home/pi/node_modules/tough-cookie
                                        ! psl@1.1.29 /home/pi/node_modules/psl
                                        ! punycode@1.4.1 /home/pi/node_modules/tough-cookie/node_modules/punycode
                                        ! tunnel-agent@0.6.0 /home/pi/node_modules/tunnel-agent
                                        ! uuid@3.3.2 /home/pi/node_modules/uuid
                                        ! xml2js@0.4.19 /home/pi/node_modules/xml2js
                                        ! sax@1.2.4 /home/pi/node_modules/sax
                                        ! xmlbuilder@9.0.7 /home/pi/node_modules/xmlbuilder
                                        but with starting point /opt/iobroker all the same sh… again
                                          AlCalzoneA Offline
                                          AlCalzone
                                          You have to execute "npm rebuild" in /opt/iobroker.
