  4. Raspberrypi install iobroker - node.js 8.12
    6.4k
27 Beiträge 6 Kommentatoren 6.3k Aufrufe
    Arnulf
    @AlCalzone:
    You have to execute "npm rebuild" in /opt/iobroker.
    This is what I've done.
    And I receive same error messages as shown in my former post
    [Update]
    nice
    now, after one reboot iobroker is dead
    pi@ioBroker-Pi:/opt/iobroker $ sudo iobroker start
    module.js:550
        throw err;
    Error: Cannot find module '/usr/local/www/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (module.js:548:15)
        at Function.Module._load (module.js:475:25)
        at Function.Module.runMain (module.js:694:10)
        at startup (bootstrap_node.js:204:16)
        at bootstrap_node.js:625:3
    now (after iobroker is definately not running I tryed again npm rebuild
    log.txt
    so my try was to do chmod 777 /var/lib/dpkg because of the first messages
    E: Sperrdatei /var/lib/dpkg/lock konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
    E: Sperren des Administrationsverzeichnisses (/var/lib/dpkg/) nicht möglich, sind Sie root?
    but no change. Same errors
    next try:
     sudo apt-get install build-essential
    result:
     build-essential ist schon die neueste Version (12.3).
     Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
     gyp javascript-common libc-ares2 libhttp-parser2.8 libjs-inherits libjs-jquery
     libjs-node-uuid libjs-underscore libssl-dev libssl-doc libuv1 libuv1-dev node-abbrev
     node-ansi node-ansi-color-table node-archy node-async node-balanced-match
     node-block-stream node-brace-expansion node-builtin-modules node-combined-stream
     node-concat-map node-cookie-jar node-delayed-stream node-forever-agent node-form-data
     node-fs.realpath node-fstream node-fstream-ignore node-github-url-from-git node-glob
     node-graceful-fs node-gyp node-hosted-git-info node-inflight node-inherits node-ini
     node-is-builtin-module node-isexe node-json-stringify-safe node-lockfile node-lru-cache
     node-mime node-minimatch node-mkdirp node-mute-stream node-node-uuid node-nopt
     node-normalize-package-data node-npmlog node-once node-osenv node-path-is-absolute
     node-pseudomap node-qs node-read node-read-package-json node-request node-retry
     node-rimraf node-semver node-sha node-slide node-spdx-correct
     node-spdx-expression-parse node-spdx-license-ids node-tar node-tunnel-agent
     node-underscore node-validate-npm-package-license node-which node-wrappy node-yallist
     nodejs-doc python-pkg-resources
     Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
     0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
    then again:
    npm rebuild
    sudo npm rebuild
    both with same errors.
    Maybe I am wrong but i think with sudo I am same as root.
    Or not?
    Do I have to login as root?
    [update]
    as root the first errors are gore (lock) but rest is the same.
    Then I tryed
    root@ioBroker-Pi:/opt/iobroker#  apt-get update
    Holen:1 http://archive.raspberrypi.org/debian stretch InRelease [25,3 kB]
    Holen:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15,0 kB]
    OK:3 https://deb.nodesource.com/node_8.x stretch InRelease
    Holen:4 http://archive.raspberrypi.org/debian stretch/main armhf Packages [199 kB]
    Holen:5 http://archive.raspberrypi.org/debian stretch/ui armhf Packages [39,2 kB]
    Es wurden 279 kB in 1 s geholt (198 kB/s).
    root@ioBroker-Pi:/opt/iobroker#  apt-get upgrade -y
    Paketaktualisierung (Upgrade) wird berechnet... Fertig
      gyp javascript-common libc-ares2 libhttp-parser2.8 libjs-inherits libjs-jquery libjs-node-uuid libjs-underscore
      libssl-dev libssl-doc libuv1 libuv1-dev node-abbrev node-ansi node-ansi-color-table node-archy node-async
      node-balanced-match node-block-stream node-brace-expansion node-builtin-modules node-combined-stream node-concat-map
      node-cookie-jar node-delayed-stream node-forever-agent node-form-data node-fs.realpath node-fstream
      node-fstream-ignore node-github-url-from-git node-glob node-graceful-fs node-gyp node-hosted-git-info node-inflight
      node-inherits node-ini node-is-builtin-module node-isexe node-json-stringify-safe node-lockfile node-lru-cache
      node-mime node-minimatch node-mkdirp node-mute-stream node-node-uuid node-nopt node-normalize-package-data node-npmlog
      node-once node-osenv node-path-is-absolute node-pseudomap node-qs node-read node-read-package-json node-request
      node-retry node-rimraf node-semver node-sha node-slide node-spdx-correct node-spdx-expression-parse
      node-spdx-license-ids node-tar node-tunnel-agent node-underscore node-validate-npm-package-license node-which
      node-wrappy node-yallist nodejs-doc python-pkg-resources
    Verwenden Sie »apt autoremove«, um sie zu entfernen.
    But iobroker is still dead
    • apollon77A Offline
      But you have seen that the path in the error Waage when starting iobroker is wrong?! /var/www/… inhale no idea where this path comes from.
      The rebuild log seems ok because authenticate-Pam is an optional package.
      Changing rights in system stuff like Dpkg is no good idea!!
      Gesendet vom Handy ...
      • AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        I think you guys can talk in german :D
          Arnulf
          it is because the thread started in english.
          :lol:
            Arnulf
            @apollon77:
            Changing rights in system stuff like Dpkg is no good idea!! `
            sure. it was only for testing
            maybe it is a good idea to reinstall (only) iobroker.
            But are these instructions correct?
            cd /opt/iobroker
            sudo chmod 777 * -R
            sudo npm install iobroker.js-controller --production
              AlCalzoneA Offline
              AlCalzone
              @Arnulf:
              But are these instructions correct? `
              They are pretty outdated. See viewtopic.php?f=8&t=19111 and viewtopic.php?f=8&t=19209
              Since your installation is pretty fucked, I think one of the cleanest ways to get an almost fresh installation is deleting the old node_modules
              cd /opt/iobroker
              sudo rm -rf node_modules
              and performing a clean install (while keeping iobroker-data)
              curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/installer.sh | bash -
              ioBroker should then detect which adapters are missing and install them again.
                Arnulf
                hmmm
                pi@ioBroker-Pi:/opt/iobroker $ cd /opt/iobroker
                pi@ioBroker-Pi:/opt/iobroker $ sudo rm -rf node_modules
                pi@ioBroker-Pi:/opt/iobroker $ curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/installer.sh | bash -
                    Welcome to the ioBroker installer!
                    You might need to enter your password a couple of times.
                    Creating ioBroker directory (1/4)
                    Downloading installation files (2/4)
                npm ERR! code ENOSELF
                npm ERR! Refusing to install package with name "iobroker" under a package
                npm ERR! also called "iobroker". Did you name your project the same
                npm ERR! as the dependency you're installing?
                npm ERR!
                npm ERR! For more information, see:
                npm ERR!     <https: docs.npmjs.com/cli/install#limitations-of-npms-install-algorithm="">npm ERR! A complete log of this run can be found in:
                npm ERR!     /home/pi/.npm/_logs/2018-12-06T15_47_56_194Z-debug.log
                    Installing ioBroker (3/4)
                npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                npm WARN deprecated nodemailer@1.11.0: All versions below 4.0.1 of Nodemailer are deprecated. See https://nodemailer.com/status/
                npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are deprecated
                npm WARN deprecated mailcomposer@2.1.0: This project is unmaintained
                npm WARN deprecated mimelib@0.3.1: This project is unmaintained
                npm WARN deprecated buildmail@2.0.0: This project is unmaintained
                npm ERR! code 128
                npm ERR! Command failed: /usr/bin/git submodule update -q --init --recursive
                npm ERR! fatal: Could not change back to '/root/.npm/_cacache/tmp/git-clone-5787434c': Keine Berechtigung
                npm ERR!
                npm ERR!     /root/.npm/_logs/2018-12-06T15_48_43_483Z-debug.log
                    Finalizing installation (4/4)
                    ioBroker was installed successfully
                    Open http://localhost:8081 in a browser and start configuring!
                ==========================================================================</https:>
                and after reboot:
                pi@ioBroker-Pi:~ $ iobroker start
                module.js:550
                    throw err;
                I don't know why there is a call to the webserver
