  4. Backitup
    5.1k
Backitup
48 Beiträge 5 Kommentatoren 5.8k Aufrufe 5 Beobachtet
  • C Offline
    chka
    #41
    habe es mal auf den 2 host verschoben das gleiche
    Gestartet...
    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"192.168.178.99","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Total","dir":"/Sicherungen/homematic/backups/iobroker/","dirMinimal":"/Sicherungen/homematic/backups/iobroker/","dirTotal":"/Sicherungen/homematic/backups/iobroker/","user":"admin","pass":"****"}
    [ERROR] [mount] - [undefined /bin/sh: 1: Syntax error: EOF in backquote substitution
    [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=admin,password="xyz,rw,file_mode=0777,dir_mode=0777 //192.168.178.99/Sicherungen/homematic/backups/iobroker/ /opt/iobroker/backups
    INTEL NUC BOXNUC6I3SYH i3-6100U - Proxmox
    Speicher: Transcend MTS800 M.2 SSD 128GB SATA III, MLC
    RAM: 40Gig Crucial 8GB DDR4 CT2K8G4SFS824A + 32GB DDR4CT32G4SFD8266
    • C Offline
      chka
      #42
      node und nodejs auf der 8.15.1 (musste node manuell löschen)
      nmp rebuild ausgeführt
      leider immer noch das gleiche
      Gestartet...
      [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"192.168.178.99","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:XX:XX","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Total","dir":"/Sicherungen/homematic/backups/iobroker/","dirMinimal":"/Sicherungen/homematic/backups/iobroker/","dirTotal":"/Sicherungen/homematic/backups/iobroker/","user":"admin","pass":"****"}
      [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=admin,password="XXX,rw,file_mode=0777,dir_mode=0777 //192.168.178.99/Sicherungen/homematic/backups/iobroker/ /opt/iobroker/backups
      • C chka
        Gestartet...
        simatecS Offline
        simatecS Offline
        simatec
        #43
        @chka
        Erkläre mal bitte, was du genau gemacht hast?
        Hast du iobroker neu augesetzt oder dein komplettes System neu aufgesetzt?
        Hast du cifs-utils installiert?
        Hast du den Installer Fix (siehe Signatur) installiert?
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        • C Offline
          chka
          #44
          also bestehendes Debian mit bestehender iobroker Installation(lates) js-controller war der letzt aktuellste glaube 1.5.2
          ich hatte immer wieder Probleme mit abstürzen also wollte ich auf die stable zurück.
          Ein downgread ging aber nicht also habe ich es wie hier beschrieben gemacht:
          @Stabilostick sagte in Probleme nach js-controller 1.5.6->1.4.2 Downgrade:
          Eine Option ist das Neuinstallieren von ioBroker. Das geht am einfachsten so:
          1. Altes Verzeichnis umbenennen.
          2. Neu installieren nach Anleitung http://www.iobroker.net/docu/?page_id=8323&lang=de
          3. iobroker stoppen, falls läuft
          4. iobroker-data Verzeichnis aus altem Ordner kopieren in die neue Installation, vorhandene Dateien überschreiben
          5. „sudo chown -R iobroker.iobroker iobroker-data“ im iobroker-Ordner
          6. iobroker neu starten
          7. warten bis alle Adapter wieder automatisch installiert wurden.
          Aber wahrscheinlich stelle ich mich nur unwissend an und man müsste zur Reparatur nur „sudo npm i“ ausführen? Bin mit dem neuen Setup noch nicht sattelfest.
          das ging wunderbar, wieso auch immer hat er bei mir node nicht auf die 8.15.1 installiert. Das habe ich jetzt fixen können in dem ich node manuell komplett gelöscht habe, dadurch wurde es neu installiert
          Mehr oder weniger ist es eine neuinstalstion in die nur der bestehende iobroker-data Ordner reinkopiert wurde.
          cif ist installier
          apt-get install cifs-utils
          cifs-utils ist schon die neueste Version.
          • C chka
            cif ist installier
            simatecS Offline
            simatecS Offline
            simatec
            #45
            @chka
            Hmm das hört sich aber etwas verbogen an.
            Ich würde dir raten, dein System mal sauber komplett neu aufzusetzen.
            • C Offline
              chka
              #46
              ok danke
              • C Offline
                chka
                schrieb am zuletzt editiert von chka
                #47
                konnte es nicht lassen und bin deutlich weiter
                habe cifs und den adapter runtergeschmissen neugestartet und wieder installiert und neugestartet
                mounten geht wieder
                Gestartet...
                [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.178.99","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/Sicherungen/homematic/backups/iobroker","dirMinimal":"/Sicherungen/homematic/backups/iobroker","dirTotal":"/Sicherungen/homematic/backups/iobroker","user":"admin","pass":"****"}
                [DEBUG] [mount] - done
                [DEBUG] [minimal] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.178.99","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/Sicherungen/homematic/backups/iobroker","dirMinimal":"/Sicherungen/homematic/backups/iobroker","dirTotal":"/Sicherungen/homematic/backups/iobroker","user":"admin","pass":"****","context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.178.99","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/Sicherungen/homematic/backups/iobroker","dirMinimal":"/Sicherungen/homematic/backups/iobroker","dirTotal":"/Sicherungen/homematic/backups/iobroker","user":"admin","pass":"wasser2505"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                [ERROR [minimal] - host.IoBrocker Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/minimal_2019_03_03-19_11_35_backupiobroker.tar.gz']
                [DEBUG] [minimal] - done
                [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.178.99","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/Sicherungen/homematic/backups/iobroker","dirMinimal":"/Sicherungen/homematic/backups/iobroker","dirTotal":"/Sicherungen/homematic/backups/iobroker","user":"admin","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
                [DEBUG] [cifs] - done
                [DEBUG] [clean] start with {"deleteBackupAfter":0}
                [DEBUG] [clean] - done
                [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.178.99","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/Sicherungen/homematic/backups/iobroker","dirMinimal":"/Sicherungen/homematic/backups/iobroker","dirTotal":"/Sicherungen/homematic/backups/iobroker","user":"admin","pass":"****","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_03_03-19_11_35_backupiobroker.tar.gz"],"errors":{},"done":["mount","minimal"],"types":["minimal"]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.178.99","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/Sicherungen/homematic/backups/iobroker","dirMinimal":"/Sicherungen/homematic/backups/iobroker","dirTotal":"/Sicherungen/homematic/backups/iobroker","user":"admin","pass":"wasser2505"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"03. Maerz 2019 um 19:11 Uhr"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                [DEBUG] [history] - backitup.0.history.html
                [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.178.99","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/Sicherungen/homematic/backups/iobroker","dirMinimal":"/Sicherungen/homematic/backups/iobroker","dirTotal":"/Sicherungen/homematic/backups/iobroker","user":"admin","pass":"****","backupDir":"/opt/iobroker/backups"}
                [DEBUG] [umount] - mount activ... umount in 60 Seconds!!
                [DEBUG] [umount] - done
                [EXIT] 9
                warum kann er nicht auf die selbst erstellte Datei zugreifen? diese wurde angelegt und liegt auch auf der nas ist aber 0KB groß
                • simatecS Offline
                  simatecS Offline
                  simatec
                  #48
                  Dein iobroker hat keine Rechte für den Ordner.
