  4. Probleme nach js-controller 1.5.6->1.4.2 Downgrade
    6.3k
22 Beiträge 4 Kommentatoren 6.0k Aufrufe 5 Beobachtet
  • StabilostickS Stabilostick
    @Rocket85
    Zurück auf 1.4.2:
    cd /opt/iobroker
    iobroker stop
    npm i iobroker.js-controller@1.4.2 --production
    iobroker start
    Rocket85
    @Stabilostick
    Habe ich versucht, bekomme dann die selbe Fehlermeldung
    • StabilostickS Offline
      Stabilostick
      Wann kommt die? Bei jedem iobroker-Kommando?
      R 1 Antwort Letzte Antwort
        Rocket85
        schrieb am zuletzt editiert von Stabilostick
        @Stabilostick
        gerade nochmal versucht. Jetzt hat es anscheinend geklappt
        pi@raspberrypi:/opt/iobroker $ npm i iobroker.js-controller@1.4.2 --production
        > iobroker.js-controller@1.4.2 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstall_check.js
        NPM version: 6.5.0
        npm version >= 5: disabling package-lock
        > iobroker.js-controller@1.4.2 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        + iobroker.js-controller@1.4.2
        added 15 packages from 16 contributors, removed 5 packages, updated 1 package and audited 4473 packages in 56.871s
        found 54 vulnerabilities (38 low, 1 moderate, 15 high)
          run `npm audit fix` to fix them, or `npm audit` for details
        Stabilostick, 14.02.19 01:07
        Code als Code-Block formatiert
        • R Offline
          Rocket85
          npm ERR! code ELOCKVERIFY
          npm ERR! Errors were found in your package-lock.json, run npm install to fix them.
          npm ERR! Invalid: lock file's iobroker.admin@3.5.10 does not satisfy iobroker.admin@^3.6.0
          npm ERR! Missing: iobroker.alexa2@^1.1.3
          npm ERR! Missing: iobroker.cloud@^2.6.2
          npm ERR! Missing: iobroker.fritzbox@^0.2.1
          npm ERR! Missing: iobroker.ham@^1.0.0
          npm ERR! Missing: iobroker.javascript@^4.0.12
          npm ERR! Missing: iobroker.material@^0.10.6
          npm ERR! Missing: iobroker.mihome@^1.2.5
          npm ERR! Missing: iobroker.pushover@^1.0.4
          npm ERR! Missing: iobroker.rpi2@^1.0.0
          npm ERR! Missing: iobroker.samsung@^0.2.9
          npm ERR! Missing: iobroker.scenes@^1.1.0
          npm ERR! Missing: iobroker.shelly@^2.1.0
          npm ERR! Missing: iobroker.telegram@^1.3.6
          npm ERR! Missing: iobroker.terminal@^0.1.2
          npm ERR! Missing: iobroker.text2command@^1.2.5
          npm ERR! Missing: iobroker.tradfri@^2.1.0
          npm ERR! Missing: iobroker.vis@^1.1.10
          npm ERR! Missing: iobroker.vis-colorpicker@^1.1.1
          npm ERR! Missing: iobroker.vis-hqwidgets@https://github.com/ioBroker/ioBroker.vis-hqwidgets/tarball/master
          npm ERR! Missing: iobroker.vis-players@^0.1.5
          npm ERR! Missing: iobroker.vis-timeandweather@^1.1.7
          npm ERR! Missing: iobroker.vis-weather@^2.2.1
          npm ERR! Missing: iobroker.web@^2.4.1
            Stabilostick
            Führe bitte im Ordner /opt/iobroker den Befehl
            npm i
            aus.
              npm i
              aus.
              Rocket85
              @Stabilostick
              > iobroker.inst@1.3.1 install /opt/iobroker
              > node lib/checkVersions.js
              NPM version: 6.5.0
              > iobroker.inst@1.3.1 postinstall /opt/iobroker
              > node lib/install.js
              Cannot create file /usr/bin/iobroker!. Non critical
              You can manually copy file into /usr/bin/. Just write:
                  sudo cp /opt/iobroker/iobroker /usr/bin/
                  sudo chmod 755 /usr/bin/iobroker
              Non-critical error: EACCES: permission denied, open '/lib/systemd/system/iobroker.service'
              audited 4463 packages in 49.685s
              found 53 vulnerabilities (38 low, 1 moderate, 14 high)
              Stabilostick, 14.02.19 01:16
              Code bitte in Code-Tags schreiben.
                Stabilostick
                Wenn Du magst, kannst Du genau die Befehle ausführen, die da im Log stehen (die mit sudo) und dann versuchen, den ioBroker wieder zu starten.
                  Rocket85
                  @Stabilostick
                  Hab es versucht, danach wieder npm i
                  NPM version: 6.5.0
                  > node lib/install.js
                  audited 4463 packages in 49.6s
                  • R Rocket85
                    @Stabilostick
                    NPM version: 6.5.0
                    > node lib/install.js
                    Rocket85
                    @Rocket85
                    Keine Reaktion
                    pi@raspberrypi:/opt/iobroker $ sudo cp /opt/iobroker/iobroker /usr/bin/
                    pi@raspberrypi:/opt/iobroker $ sudo chmod 755 /usr/bin/iobroker
                      Stabilostick
                      Eine Option ist das Neuinstallieren von ioBroker. Das geht am einfachsten so:
                      1. Altes Verzeichnis umbenennen.
                      2. Neu installieren nach Anleitung http://www.iobroker.net/docu/?page_id=8323&lang=de
                      3. iobroker stoppen, falls läuft
                      4. iobroker-data Verzeichnis aus altem Ordner kopieren in die neue Installation, vorhandene Dateien überschreiben
                      5. „sudo chown -R iobroker.iobroker iobroker-data“ im iobroker-Ordner
                      6. iobroker neu starten
                      7. warten bis alle Adapter wieder automatisch installiert wurden.
                      Aber wahrscheinlich stelle ich mich nur unwissend an und man müsste zur Reparatur nur „sudo npm i“ ausführen? Bin mit dem neuen Setup noch nicht sattelfest.
                      • R Rocket85
                        @Rocket85 diese Meldungen einfach ignorieren. Oder Package-lock löschen.
                        • apollon77A apollon77
                          Rocket85
                          @apollon77
                          Okay, ich ignoriere erst einmal. DANKE!
                          • R Offline
                            Rocket85
                            Seit dem versuchten Update hab ich leider nur Probleme. Kann mir jemand das hier erklären?
                            telegram.0	2019-02-16 08:51:41.946	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:51:39.675	info	Restart adapter system.adapter.pushover.0 because enabled
                            host.raspberrypi	2019-02-16 08:51:39.672	error	instance system.adapter.pushover.0 terminated with code 7 (Adapter already running)
                            telegram.0	2019-02-16 08:51:38.612	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            telegram.0	2019-02-16 08:51:38.611	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            telegram.0	2019-02-16 08:51:38.610	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:51:38.503	info	instance system.adapter.pushover.0 started with pid 19516
                            telegram.0	2019-02-16 08:51:35.137	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            telegram.0	2019-02-16 08:51:31.800	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            telegram.0	2019-02-16 08:51:31.799	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:51:30.012	info	Restart adapter system.adapter.shelly.0 because enabled
                            host.raspberrypi	2019-02-16 08:51:30.011	error	instance system.adapter.shelly.0 terminated with code 7 (Adapter already running)
                            host.raspberrypi	2019-02-16 08:51:28.864	info	Restart adapter system.adapter.discovery.0 because enabled
                            host.raspberrypi	2019-02-16 08:51:28.861	error	instance system.adapter.discovery.0 terminated with code 7 (Adapter already running)
                            host.raspberrypi	2019-02-16 08:51:28.668	info	instance system.adapter.shelly.0 started with pid 19498
                            telegram.0	2019-02-16 08:51:28.329	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:51:27.873	info	Restart adapter system.adapter.javascript.0 because enabled
                            host.raspberrypi	2019-02-16 08:51:27.872	error	instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
                            host.raspberrypi	2019-02-16 08:51:27.686	info	instance system.adapter.discovery.0 started with pid 19488
                            mihome.0	2019-02-16 08:51:26.307	info	Change connection status: true
                            telegram.0	2019-02-16 08:51:24.996	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            telegram.0	2019-02-16 08:51:24.995	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:51:24.071	info	instance system.adapter.javascript.0 started with pid 19478
                            telegram.0	2019-02-16 08:51:21.533	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            mihome.0	2019-02-16 08:51:19.579	error	Error: bind EADDRINUSE 0.0.0.0:9898
                            mihome.0	2019-02-16 08:51:19.578	error	Error: bind EADDRINUSE 0.0.0.0:9898
                            mihome.0	2019-02-16 08:51:19.578	info	Change connection status: false
                            mihome.0	2019-02-16 08:51:19.577	info	Change connection status: false
                            mihome.0	2019-02-16 08:51:19.109	info	Change connection status: true
                            mihome.0	2019-02-16 08:51:18.917	error	Error: bind EADDRINUSE 0.0.0.0:9898
                            mihome.0	2019-02-16 08:51:18.916	error	Error: bind EADDRINUSE 0.0.0.0:9898
                            mihome.0	2019-02-16 08:51:18.915	error	Error: bind EADDRINUSE 0.0.0.0:9898
                            mihome.0	2019-02-16 08:51:18.897	error	Error: bind EADDRINUSE 0.0.0.0:9898
                            mihome.0	2019-02-16 08:51:18.896	error	Error: bind EADDRINUSE 0.0.0.0:9898
                            mihome.0	2019-02-16 08:51:18.896	info	Change connection status: false
                            mihome.0	2019-02-16 08:51:18.895	info	Change connection status: false
                            telegram.0	2019-02-16 08:51:18.198	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            telegram.0	2019-02-16 08:51:18.197	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            telegram.0	2019-02-16 08:51:18.196	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            telegram.0	2019-02-16 08:51:14.718	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:51:13.396	info	Restart adapter system.adapter.mihome.0 because enabled
                            host.raspberrypi	2019-02-16 08:51:13.396	error	instance system.adapter.mihome.0 terminated with code 7 (Adapter already running)
                            host.raspberrypi	2019-02-16 08:51:12.133	info	instance system.adapter.mihome.0 started with pid 19464
                            telegram.0	2019-02-16 08:51:11.385	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            telegram.0	2019-02-16 08:51:11.384	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:51:08.467	info	Restart adapter system.adapter.pushover.0 because enabled
                            host.raspberrypi	2019-02-16 08:51:08.466	error	instance system.adapter.pushover.0 terminated with code 7 (Adapter already running)
                            telegram.0	2019-02-16 08:51:07.916	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:51:07.270	info	instance system.adapter.pushover.0 started with pid 19454
                            telegram.0	2019-02-16 08:51:01.100	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:50:58.647	info	Restart adapter system.adapter.shelly.0 because enabled
                            host.raspberrypi	2019-02-16 08:50:58.646	error	instance system.adapter.shelly.0 terminated with code 7 (Adapter already running)
                            telegram.0	2019-02-16 08:50:57.766	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:50:57.669	info	Restart adapter system.adapter.discovery.0 because enabled
                            host.raspberrypi	2019-02-16 08:50:57.668	error	instance system.adapter.discovery.0 terminated with code 7 (Adapter already running)
                            host.raspberrypi	2019-02-16 08:50:57.237	info	instance system.adapter.shelly.0 started with pid 19436
                            host.raspberrypi	2019-02-16 08:50:56.366	info	instance system.adapter.discovery.0 started with pid 19430
                            mihome.0	2019-02-16 08:50:55.701	info	Change connection status: true
                            telegram.0	2019-02-16 08:50:54.300	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:50:54.042	info	Restart adapter system.adapter.javascript.0 because enabled
                            host.raspberrypi	2019-02-16 08:50:54.041	error	instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
                            telegram.0	2019-02-16 08:50:50.963	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:50:50.193	info	instance system.adapter.javascript.0 started with pid 19416
                            mihome.0	2019-02-16 08:50:49.573	error	Error: bind EADDRINUSE 0.0.0.0:9898
                            mihome.0	2019-02-16 08:50:49.572	info	Change connection status: false
                            mihome.0	2019-02-16 08:50:49.191	info	Change connection status: true
                            mihome.0	2019-02-16 08:50:48.913	error	Error: bind EADDRINUSE 0.0.0.0:9898
                            mihome.0	2019-02-16 08:50:48.891	error	Error: bind EADDRINUSE 0.0.0.0:9898
                            mihome.0	2019-02-16 08:50:48.889	info	Change connection status: false
                            telegram.0	2019-02-16 08:50:47.474	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            telegram.0	2019-02-16 08:50:44.136	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:50:42.107	info	Restart adapter system.adapter.mihome.0 because enabled
                            host.raspberrypi	2019-02-16 08:50:42.106	error	instance system.adapter.mihome.0 terminated with code 7 (Adapter already running)
                            host.raspberrypi	2019-02-16 08:50:40.847	info	instance system.adapter.mihome.0 started with pid 19402
                            telegram.0	2019-02-16 08:50:40.663	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            telegram.0	2019-02-16 08:50:37.326	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:50:37.253	info	Restart adapter system.adapter.pushover.0 because enabled
                            host.raspberrypi	2019-02-16 08:50:37.252	error	instance system.adapter.pushover.0 terminated with code 7 (Adapter already running)
                            host.raspberrypi	2019-02-16 08:50:36.056	info	instance system.adapter.pushover.0 started with pid 19392
                            telegram.0	2019-02-16 08:50:33.868	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            telegram.0	2019-02-16 08:50:30.534	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            cloud.0	2019-02-16 08:50:29.855	info	Connection changed: connect
                            cloud.0	2019-02-16 08:50:29.719	info	Trying to connect as system.user.admin
                            mihome.0	2019-02-16 08:50:28.357	info	Change connection status: true
                            host.raspberrypi	2019-02-16 08:50:27.222	info	Restart adapter system.adapter.shelly.0 because enabled
                            host.raspberrypi	2019-02-16 08:50:27.221	error	instance system.adapter.shelly.0 terminated with code 7 (Adapter already running)
                            telegram.0	2019-02-16 08:50:27.067	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:50:26.344	info	Restart adapter system.adapter.discovery.0 because enabled
                            host.raspberrypi	2019-02-16 08:50:26.344	error	instance system.adapter.discovery.0 terminated with code 7 (Adapter already running)
                            host.raspberrypi	2019-02-16 08:50:25.829	info	instance system.adapter.shelly.0 started with pid 19374
                            host.raspberrypi	2019-02-16 08:50:25.138	info	instance system.adapter.discovery.0 started with pid 19364
                            telegram.0	2019-02-16 08:50:23.725	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            telegram.0	2019-02-16 08:50:20.257	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:50:20.171	info	Restart adapter system.adapter.javascript.0 because enabled
                            host.raspberrypi	2019-02-16 08:50:20.170	error	instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
                            mihome.0	2019-02-16 08:50:19.572	error	Error: bind EADDRINUSE 0.0.0.0:9898
                            mihome.0	2019-02-16 08:50:19.570	info	Change connection status: false
                            mihome.0	2019-02-16 08:50:19.269	info	Change connection status: true
                            mihome.0	2019-02-16 08:50:18.911	error	Error: bind EADDRINUSE 0.0.0.0:9898
                            mihome.0	2019-02-16 08:50:18.888	error	Error: bind EADDRINUSE 0.0.0.0:9898
                            mihome.0	2019-02-16 08:50:18.886	info	Change connection status: false
                            telegram.0	2019-02-16 08:50:16.913	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:50:16.261	info	instance system.adapter.javascript.0 started with pid 19354
                            telegram.0	2019-02-16 08:50:13.423	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:50:10.834	info	Restart adapter system.adapter.mihome.0 because enabled
                            host.raspberrypi	2019-02-16 08:50:10.834	error	instance system.adapter.mihome.0 terminated with code 7 (Adapter already running)
                            telegram.0	2019-02-16 08:50:10.088	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:50:09.554	info	instance system.adapter.mihome.0 started with pid 19339
                            telegram.0	2019-02-16 08:50:06.602	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:50:06.036	info	Restart adapter system.adapter.pushover.0 because enabled
                            host.raspberrypi	2019-02-16 08:50:06.035	error	instance system.adapter.pushover.0 terminated with code 7 (Adapter already running)
                            host.raspberrypi	2019-02-16 08:50:04.852	info	instance system.adapter.pushover.0 started with pid 19325
                            telegram.0	2019-02-16 08:50:03.266	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            telegram.0	2019-02-16 08:49:59.795	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            telegram.0	2019-02-16 08:49:56.451	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
                            host.raspberrypi	2019-02-16 08:49:55.815	info	Restart adapter system.adapter.shelly.0 because enabled
                            host.raspberrypi	2019-02-16 08:49:55.814	error	instance system.adapter.shelly.0 terminated with code 7 (Adapter already running)
                            host.raspberrypi	2019-02-16 08:49:55.110	info	Restart adapter system.adapter.discovery.0 because enabled
                            host.raspberrypi	2019-02-16 08:49:55.109	error	instance system.adapter.discovery.0 terminated with code 7 (Adapter already running)
                            host.raspberrypi	2019-02-16 08:49:54.342	info	instance system.adapter.shelly.0 started with pid 19306
                            host.raspberrypi	2019-02-16 08:49:53.878	info	instance system.adapter.discovery.0 started with pid 19300
                            mihome.0	2019-02-16 08:49:53.776	info	Change connection status: true
                            telegram.0	2019-02-16 08:49:53.327	info	getMe: {"id":776274381,"is_bot":true,"first_name":"ZuhauseBot","username":"UnserAsgardbot"}
                            telegram.0	2019-02-16 08:49:52.786	info	starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.telegram, node: v8.15.0
                            text2command.0	2019-02-16 08:49:51.787	info	starting. Version 1.2.5 in /opt/iobroker/node_modules/iobroker.text2command, node: v8.15.0
                            host.raspberrypi	2019-02-16 08:49:50.341	info	instance system.adapter.text2command.0 started with pid 19286
                            host.raspberrypi	2019-02-16 08:49:49.993	info	instance system.adapter.telegram.0 started with pid 19280
                            mihome.0	2019-02-16 08:49:49.569	error	Error: bind EADDRINUSE 0.0.0.0:9898
                            mihome.0	2019-02-16 08:49:49.567	info	Change connection status: false
                            mihome.0	2019-02-16 08:49:49.313	info	Change connection status: true
                            host.raspberrypi	2019-02-16 08:49:48.972	info	Restart adapter system.adapter.telegram.0 because enabled
                            host.raspberrypi	2019-02-16 08:49:48.972	error	instance system.adapter.telegram.0 terminated with code 7 (Adapter already running)
                            Caught	2019-02-16 08:49:48.972	error	by controller[0]: See https://github.com/yagop/node-telegram-bot-api/issues/319. at module.js:653:30
                            Caught	2019-02-16 08:49:48.971	error	by controller[0]: In the future, you will have to enable it yourself.
                            Caught	2019-02-16 08:49:48.971	error	by controller[0]: Sat, 16 Feb 2019 07:49:48 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
                            mihome.0	2019-02-16 08:49:48.909	error	Error: bind EADDRINUSE 0.0.0.0:9898
                            mihome.0	2019-02-16 08:49:48.886	error	Error: bind EADDRINUSE 0.0.0.0:9898
                            mihome.0	2019-02-16 08:49:48.884	info	Change connection status: false
                            host.raspberrypi	2019-02-16 08:49:46.339	info	instance system.adapter.telegram.0 started with pid 19270
                            host.raspberrypi	2019-02-16 08:49:46.241	info	Restart adapter system.adapter.javascript.0 because enabled
                            host.raspberrypi	2019-02-16 08:49:46.240	error	instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
                            host.raspberrypi	2019-02-16 08:49:42.357	info	instance system.adapter.javascript.0 started with pid 19256
                            host.raspberrypi	2019-02-16 08:49:39.535	info	Restart adapter system.adapter.mihome.0 because enabled
                            host.raspberrypi	2019-02-16 08:49:39.534	error	instance system.adapter.mihome.0 terminated with code 7 (Adapter already running)
                            host.raspberrypi	2019-02-16 08:49:38.364	info	instance system.adapter.mihome.0 started with pid 19246
                            host.raspberrypi	2019-02-16 08:49:34.831	info	Restart adapter system.adapter.pushover.0 because enabled
                            host.raspberrypi	2019-02-16 08:49:34.831	error	instance system.adapter.pushover.0 terminated with code 7 (Adapter already running)
                            host.raspberrypi	2019-02-16 08:49:33.618	info	instance system.adapter.pushover.0 started with pid 19232
                            web.0	2019-02-16 08:49:32.161	info	http server listening on port 8082
                            web.0	2019-02-16 08:49:32.156	info	socket.io server listening on port 8082
                            web.0	2019-02-16 08:49:31.633	info	starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v8.15.0
                            • R Offline
                              Rocket85
                              Alle Instanzen springen zwischen grün und rot hin und her! Iobroker Neustart habe ich schon mehrfach durchgeführt!
                              • apollon77A Offline
                                iobroker neustart hilft nicht wenn ein Prozess zombie noch läuft. Entweder iobroker stoppen und dann noch laufende prozesse killen oder rebooten
                                  Rocket85
                                  @apollon77
                                  Danke wieder was gelernt -Prozess Zombie-. Wie kille ich denn laufende Prozesse?
                                    ioBroker Prozesse sehen haben als Namen immer "io.<Adaptername>.<Instanz>", mit
                                    ps auxww |grep io.
                                    siehst Du die die ggf noch laufen. Killen mit
                                    sudo kill -9 <ProzessID>
                                    • R Offline
                                      Rocket85
                                      Hier wieder etwas neues, ich weiß nicht womit das zusammen hängt und wollte jetzt nicht extra ein neues Thema öffnen.
                                      Aber egal was ich anklicke, ob Objekte instanzen usw. immer ist automatisch etwas in die Filterleiste kopiert.
                                      • R Rocket85
                                        sigi234S Online
                                        sigi234S Online
                                        @Rocket85
                                        Link Text
                                        • sigi234S sigi234
                                          @Rocket85
                                          Link Text
                                          Rocket85
                                          @sigi234
                                          DANKE!
