  4. Probleme nach js-controller 1.5.6->1.4.2 Downgrade
    6.3k
22 Beiträge 4 Kommentatoren 6.0k Aufrufe 5 Beobachtet
  • R Rocket85
    npm ERR! code ELOCKVERIFY
    npm ERR! Errors were found in your package-lock.json, run npm install to fix them.
    npm ERR! Invalid: lock file's iobroker.admin@3.5.10 does not satisfy iobroker.admin@^3.6.0
    npm ERR! Missing: iobroker.alexa2@^1.1.3
    npm ERR! Missing: iobroker.cloud@^2.6.2
    npm ERR! Missing: iobroker.fritzbox@^0.2.1
    npm ERR! Missing: iobroker.ham@^1.0.0
    npm ERR! Missing: iobroker.javascript@^4.0.12
    npm ERR! Missing: iobroker.material@^0.10.6
    npm ERR! Missing: iobroker.mihome@^1.2.5
    npm ERR! Missing: iobroker.pushover@^1.0.4
    npm ERR! Missing: iobroker.rpi2@^1.0.0
    npm ERR! Missing: iobroker.samsung@^0.2.9
    npm ERR! Missing: iobroker.scenes@^1.1.0
    npm ERR! Missing: iobroker.shelly@^2.1.0
    npm ERR! Missing: iobroker.telegram@^1.3.6
    npm ERR! Missing: iobroker.terminal@^0.1.2
    npm ERR! Missing: iobroker.text2command@^1.2.5
    npm ERR! Missing: iobroker.tradfri@^2.1.0
    npm ERR! Missing: iobroker.vis@^1.1.10
    npm ERR! Missing: iobroker.vis-colorpicker@^1.1.1
    npm ERR! Missing: iobroker.vis-hqwidgets@https://github.com/ioBroker/ioBroker.vis-hqwidgets/tarball/master
    npm ERR! Missing: iobroker.vis-players@^0.1.5
    npm ERR! Missing: iobroker.vis-timeandweather@^1.1.7
    npm ERR! Missing: iobroker.vis-weather@^2.2.1
    npm ERR! Missing: iobroker.web@^2.4.1
    @Rocket85 diese Meldungen einfach ignorieren. Oder Package-lock löschen.
    R 1 Antwort Letzte Antwort
    • apollon77A apollon77
      Rocket85
      @apollon77
      Okay, ich ignoriere erst einmal. DANKE!
      • R Offline
        Rocket85
        Seit dem versuchten Update hab ich leider nur Probleme. Kann mir jemand das hier erklären?
        telegram.0	2019-02-16 08:51:41.946	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:51:39.675	info	Restart adapter system.adapter.pushover.0 because enabled
        host.raspberrypi	2019-02-16 08:51:39.672	error	instance system.adapter.pushover.0 terminated with code 7 (Adapter already running)
        telegram.0	2019-02-16 08:51:38.612	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        telegram.0	2019-02-16 08:51:38.611	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        telegram.0	2019-02-16 08:51:38.610	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:51:38.503	info	instance system.adapter.pushover.0 started with pid 19516
        telegram.0	2019-02-16 08:51:35.137	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        telegram.0	2019-02-16 08:51:31.800	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        telegram.0	2019-02-16 08:51:31.799	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:51:30.012	info	Restart adapter system.adapter.shelly.0 because enabled
        host.raspberrypi	2019-02-16 08:51:30.011	error	instance system.adapter.shelly.0 terminated with code 7 (Adapter already running)
        host.raspberrypi	2019-02-16 08:51:28.864	info	Restart adapter system.adapter.discovery.0 because enabled
        host.raspberrypi	2019-02-16 08:51:28.861	error	instance system.adapter.discovery.0 terminated with code 7 (Adapter already running)
        host.raspberrypi	2019-02-16 08:51:28.668	info	instance system.adapter.shelly.0 started with pid 19498
        telegram.0	2019-02-16 08:51:28.329	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:51:27.873	info	Restart adapter system.adapter.javascript.0 because enabled
        host.raspberrypi	2019-02-16 08:51:27.872	error	instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
        host.raspberrypi	2019-02-16 08:51:27.686	info	instance system.adapter.discovery.0 started with pid 19488
        mihome.0	2019-02-16 08:51:26.307	info	Change connection status: true
        telegram.0	2019-02-16 08:51:24.996	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        telegram.0	2019-02-16 08:51:24.995	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:51:24.071	info	instance system.adapter.javascript.0 started with pid 19478
        telegram.0	2019-02-16 08:51:21.533	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        mihome.0	2019-02-16 08:51:19.579	error	Error: bind EADDRINUSE 0.0.0.0:9898
        mihome.0	2019-02-16 08:51:19.578	error	Error: bind EADDRINUSE 0.0.0.0:9898
        mihome.0	2019-02-16 08:51:19.578	info	Change connection status: false
        mihome.0	2019-02-16 08:51:19.577	info	Change connection status: false
        mihome.0	2019-02-16 08:51:19.109	info	Change connection status: true
        mihome.0	2019-02-16 08:51:18.917	error	Error: bind EADDRINUSE 0.0.0.0:9898
        mihome.0	2019-02-16 08:51:18.916	error	Error: bind EADDRINUSE 0.0.0.0:9898
        mihome.0	2019-02-16 08:51:18.915	error	Error: bind EADDRINUSE 0.0.0.0:9898
        mihome.0	2019-02-16 08:51:18.897	error	Error: bind EADDRINUSE 0.0.0.0:9898
        mihome.0	2019-02-16 08:51:18.896	error	Error: bind EADDRINUSE 0.0.0.0:9898
        mihome.0	2019-02-16 08:51:18.896	info	Change connection status: false
        mihome.0	2019-02-16 08:51:18.895	info	Change connection status: false
        telegram.0	2019-02-16 08:51:18.198	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        telegram.0	2019-02-16 08:51:18.197	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        telegram.0	2019-02-16 08:51:18.196	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        telegram.0	2019-02-16 08:51:14.718	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:51:13.396	info	Restart adapter system.adapter.mihome.0 because enabled
        host.raspberrypi	2019-02-16 08:51:13.396	error	instance system.adapter.mihome.0 terminated with code 7 (Adapter already running)
        host.raspberrypi	2019-02-16 08:51:12.133	info	instance system.adapter.mihome.0 started with pid 19464
        telegram.0	2019-02-16 08:51:11.385	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        telegram.0	2019-02-16 08:51:11.384	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:51:08.467	info	Restart adapter system.adapter.pushover.0 because enabled
        host.raspberrypi	2019-02-16 08:51:08.466	error	instance system.adapter.pushover.0 terminated with code 7 (Adapter already running)
        telegram.0	2019-02-16 08:51:07.916	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:51:07.270	info	instance system.adapter.pushover.0 started with pid 19454
        telegram.0	2019-02-16 08:51:01.100	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:50:58.647	info	Restart adapter system.adapter.shelly.0 because enabled
        host.raspberrypi	2019-02-16 08:50:58.646	error	instance system.adapter.shelly.0 terminated with code 7 (Adapter already running)
        telegram.0	2019-02-16 08:50:57.766	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:50:57.669	info	Restart adapter system.adapter.discovery.0 because enabled
        host.raspberrypi	2019-02-16 08:50:57.668	error	instance system.adapter.discovery.0 terminated with code 7 (Adapter already running)
        host.raspberrypi	2019-02-16 08:50:57.237	info	instance system.adapter.shelly.0 started with pid 19436
        host.raspberrypi	2019-02-16 08:50:56.366	info	instance system.adapter.discovery.0 started with pid 19430
        mihome.0	2019-02-16 08:50:55.701	info	Change connection status: true
        telegram.0	2019-02-16 08:50:54.300	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:50:54.042	info	Restart adapter system.adapter.javascript.0 because enabled
        host.raspberrypi	2019-02-16 08:50:54.041	error	instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
        telegram.0	2019-02-16 08:50:50.963	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:50:50.193	info	instance system.adapter.javascript.0 started with pid 19416
        mihome.0	2019-02-16 08:50:49.573	error	Error: bind EADDRINUSE 0.0.0.0:9898
        mihome.0	2019-02-16 08:50:49.572	info	Change connection status: false
        mihome.0	2019-02-16 08:50:49.191	info	Change connection status: true
        mihome.0	2019-02-16 08:50:48.913	error	Error: bind EADDRINUSE 0.0.0.0:9898
        mihome.0	2019-02-16 08:50:48.891	error	Error: bind EADDRINUSE 0.0.0.0:9898
        mihome.0	2019-02-16 08:50:48.889	info	Change connection status: false
        telegram.0	2019-02-16 08:50:47.474	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        telegram.0	2019-02-16 08:50:44.136	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:50:42.107	info	Restart adapter system.adapter.mihome.0 because enabled
        host.raspberrypi	2019-02-16 08:50:42.106	error	instance system.adapter.mihome.0 terminated with code 7 (Adapter already running)
        host.raspberrypi	2019-02-16 08:50:40.847	info	instance system.adapter.mihome.0 started with pid 19402
        telegram.0	2019-02-16 08:50:40.663	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        telegram.0	2019-02-16 08:50:37.326	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:50:37.253	info	Restart adapter system.adapter.pushover.0 because enabled
        host.raspberrypi	2019-02-16 08:50:37.252	error	instance system.adapter.pushover.0 terminated with code 7 (Adapter already running)
        host.raspberrypi	2019-02-16 08:50:36.056	info	instance system.adapter.pushover.0 started with pid 19392
        telegram.0	2019-02-16 08:50:33.868	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        telegram.0	2019-02-16 08:50:30.534	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        cloud.0	2019-02-16 08:50:29.855	info	Connection changed: connect
        cloud.0	2019-02-16 08:50:29.719	info	Trying to connect as system.user.admin
        mihome.0	2019-02-16 08:50:28.357	info	Change connection status: true
        host.raspberrypi	2019-02-16 08:50:27.222	info	Restart adapter system.adapter.shelly.0 because enabled
        host.raspberrypi	2019-02-16 08:50:27.221	error	instance system.adapter.shelly.0 terminated with code 7 (Adapter already running)
        telegram.0	2019-02-16 08:50:27.067	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:50:26.344	info	Restart adapter system.adapter.discovery.0 because enabled
        host.raspberrypi	2019-02-16 08:50:26.344	error	instance system.adapter.discovery.0 terminated with code 7 (Adapter already running)
        host.raspberrypi	2019-02-16 08:50:25.829	info	instance system.adapter.shelly.0 started with pid 19374
        host.raspberrypi	2019-02-16 08:50:25.138	info	instance system.adapter.discovery.0 started with pid 19364
        telegram.0	2019-02-16 08:50:23.725	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        telegram.0	2019-02-16 08:50:20.257	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:50:20.171	info	Restart adapter system.adapter.javascript.0 because enabled
        host.raspberrypi	2019-02-16 08:50:20.170	error	instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
        mihome.0	2019-02-16 08:50:19.572	error	Error: bind EADDRINUSE 0.0.0.0:9898
        mihome.0	2019-02-16 08:50:19.570	info	Change connection status: false
        mihome.0	2019-02-16 08:50:19.269	info	Change connection status: true
        mihome.0	2019-02-16 08:50:18.911	error	Error: bind EADDRINUSE 0.0.0.0:9898
        mihome.0	2019-02-16 08:50:18.888	error	Error: bind EADDRINUSE 0.0.0.0:9898
        mihome.0	2019-02-16 08:50:18.886	info	Change connection status: false
        telegram.0	2019-02-16 08:50:16.913	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:50:16.261	info	instance system.adapter.javascript.0 started with pid 19354
        telegram.0	2019-02-16 08:50:13.423	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:50:10.834	info	Restart adapter system.adapter.mihome.0 because enabled
        host.raspberrypi	2019-02-16 08:50:10.834	error	instance system.adapter.mihome.0 terminated with code 7 (Adapter already running)
        telegram.0	2019-02-16 08:50:10.088	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:50:09.554	info	instance system.adapter.mihome.0 started with pid 19339
        telegram.0	2019-02-16 08:50:06.602	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:50:06.036	info	Restart adapter system.adapter.pushover.0 because enabled
        host.raspberrypi	2019-02-16 08:50:06.035	error	instance system.adapter.pushover.0 terminated with code 7 (Adapter already running)
        host.raspberrypi	2019-02-16 08:50:04.852	info	instance system.adapter.pushover.0 started with pid 19325
        telegram.0	2019-02-16 08:50:03.266	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        telegram.0	2019-02-16 08:49:59.795	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        telegram.0	2019-02-16 08:49:56.451	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
        host.raspberrypi	2019-02-16 08:49:55.815	info	Restart adapter system.adapter.shelly.0 because enabled
        host.raspberrypi	2019-02-16 08:49:55.814	error	instance system.adapter.shelly.0 terminated with code 7 (Adapter already running)
        host.raspberrypi	2019-02-16 08:49:55.110	info	Restart adapter system.adapter.discovery.0 because enabled
        host.raspberrypi	2019-02-16 08:49:55.109	error	instance system.adapter.discovery.0 terminated with code 7 (Adapter already running)
        host.raspberrypi	2019-02-16 08:49:54.342	info	instance system.adapter.shelly.0 started with pid 19306
        host.raspberrypi	2019-02-16 08:49:53.878	info	instance system.adapter.discovery.0 started with pid 19300
        mihome.0	2019-02-16 08:49:53.776	info	Change connection status: true
        telegram.0	2019-02-16 08:49:53.327	info	getMe: {"id":776274381,"is_bot":true,"first_name":"ZuhauseBot","username":"UnserAsgardbot"}
        telegram.0	2019-02-16 08:49:52.786	info	starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.telegram, node: v8.15.0
        text2command.0	2019-02-16 08:49:51.787	info	starting. Version 1.2.5 in /opt/iobroker/node_modules/iobroker.text2command, node: v8.15.0
        host.raspberrypi	2019-02-16 08:49:50.341	info	instance system.adapter.text2command.0 started with pid 19286
        host.raspberrypi	2019-02-16 08:49:49.993	info	instance system.adapter.telegram.0 started with pid 19280
        mihome.0	2019-02-16 08:49:49.569	error	Error: bind EADDRINUSE 0.0.0.0:9898
        mihome.0	2019-02-16 08:49:49.567	info	Change connection status: false
        mihome.0	2019-02-16 08:49:49.313	info	Change connection status: true
        host.raspberrypi	2019-02-16 08:49:48.972	info	Restart adapter system.adapter.telegram.0 because enabled
        host.raspberrypi	2019-02-16 08:49:48.972	error	instance system.adapter.telegram.0 terminated with code 7 (Adapter already running)
        Caught	2019-02-16 08:49:48.972	error	by controller[0]: See https://github.com/yagop/node-telegram-bot-api/issues/319. at module.js:653:30
        Caught	2019-02-16 08:49:48.971	error	by controller[0]: In the future, you will have to enable it yourself.
        Caught	2019-02-16 08:49:48.971	error	by controller[0]: Sat, 16 Feb 2019 07:49:48 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
        mihome.0	2019-02-16 08:49:48.909	error	Error: bind EADDRINUSE 0.0.0.0:9898
        mihome.0	2019-02-16 08:49:48.886	error	Error: bind EADDRINUSE 0.0.0.0:9898
        mihome.0	2019-02-16 08:49:48.884	info	Change connection status: false
        host.raspberrypi	2019-02-16 08:49:46.339	info	instance system.adapter.telegram.0 started with pid 19270
        host.raspberrypi	2019-02-16 08:49:46.241	info	Restart adapter system.adapter.javascript.0 because enabled
        host.raspberrypi	2019-02-16 08:49:46.240	error	instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
        host.raspberrypi	2019-02-16 08:49:42.357	info	instance system.adapter.javascript.0 started with pid 19256
        host.raspberrypi	2019-02-16 08:49:39.535	info	Restart adapter system.adapter.mihome.0 because enabled
        host.raspberrypi	2019-02-16 08:49:39.534	error	instance system.adapter.mihome.0 terminated with code 7 (Adapter already running)
        host.raspberrypi	2019-02-16 08:49:38.364	info	instance system.adapter.mihome.0 started with pid 19246
        host.raspberrypi	2019-02-16 08:49:34.831	info	Restart adapter system.adapter.pushover.0 because enabled
        host.raspberrypi	2019-02-16 08:49:34.831	error	instance system.adapter.pushover.0 terminated with code 7 (Adapter already running)
        host.raspberrypi	2019-02-16 08:49:33.618	info	instance system.adapter.pushover.0 started with pid 19232
        web.0	2019-02-16 08:49:32.161	info	http server listening on port 8082
        web.0	2019-02-16 08:49:32.156	info	socket.io server listening on port 8082
        web.0	2019-02-16 08:49:31.633	info	starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v8.15.0
        • R Offline
          Rocket85
          Alle Instanzen springen zwischen grün und rot hin und her! Iobroker Neustart habe ich schon mehrfach durchgeführt!
          • apollon77A Offline
            iobroker neustart hilft nicht wenn ein Prozess zombie noch läuft. Entweder iobroker stoppen und dann noch laufende prozesse killen oder rebooten
              Rocket85
              @apollon77
              Danke wieder was gelernt -Prozess Zombie-. Wie kille ich denn laufende Prozesse?
                ioBroker Prozesse sehen haben als Namen immer "io.<Adaptername>.<Instanz>", mit
                ps auxww |grep io.
                siehst Du die die ggf noch laufen. Killen mit
                sudo kill -9 <ProzessID>
                • R Offline
                  Rocket85
                  Hier wieder etwas neues, ich weiß nicht womit das zusammen hängt und wollte jetzt nicht extra ein neues Thema öffnen.
                  Aber egal was ich anklicke, ob Objekte instanzen usw. immer ist automatisch etwas in die Filterleiste kopiert.
                  • R Rocket85
                    sigi234S Online
                    sigi234S Online
                    @Rocket85
                    Link Text
                    • sigi234S sigi234
                      @Rocket85
                      Link Text
                      Rocket85
                      @sigi234
                      DANKE!
