  4. Adapter: iobroker.backitup (stable Release)
    6.1k
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.5m Aufrufe 50 Beobachtet
  • SegwayS Offline
    SegwayS Offline
    Segway
    #1401
    Woran sehe ich das ob alles gesichert wurde ?
    Meine sql DB ist recht gross da kann das file doch nicht so klein sein
    Gruß Dirk
    • simatecS Offline
      simatecS Offline
      simatec
      #1402
      Öffne die Datei mit einem geeigneten Tool
      Winzip, winrar, 7zip …
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • SegwayS Offline
        SegwayS Offline
        Segway
        #1403
        so hier erstmal das Log; sind auf jedenfall error drin:
        2019-01-05 08:43:15.732  - [34mdebug[39m: backitup.0 [minimal/mount] done
        2019-01-05 08:43:21.901  - [34mdebug[39m: backitup.0 [minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-08_43_15_backupiobroker.tar.gz
        2019-01-05 08:43:21.970  - [34mdebug[39m: backitup.0 [minimal/minimal] done
        2019-01-05 08:43:21.996  - [34mdebug[39m: backitup.0 [minimal/mysql] [IGNORED] Error: spawn mysqldump ENOENT
        2019-01-05 08:43:22.013  - [34mdebug[39m: backitup.0 [minimal/mysql] done
        2019-01-05 08:43:22.036  - [34mdebug[39m: backitup.0 [minimal/cifs] done
        2019-01-05 08:43:22.051  - [34mdebug[39m: backitup.0 [minimal/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
        2019-01-05 08:43:22.051  - [34mdebug[39m: backitup.0 [minimal/clean] done
        2019-01-05 08:43:22.057  - [34mdebug[39m: backitup.0 [minimal/mysql] done
        2019-01-05 08:43:22.064  - [34mdebug[39m: backitup.0 [minimal/telegram] [minimal] used Telegram-Instance: telegram.0
        2019-01-05 08:43:22.067  - [34mdebug[39m: backitup.0 sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
        2019-01-05 08:43:22.067  - [34mdebug[39m: backitup.0 [minimal/telegram] done
        2019-01-05 08:43:22.072  - [34mdebug[39m: backitup.0 [minimal/mysql] MySql File deleted!
        2019-01-05 08:43:22.079  - [34mdebug[39m: backitup.0 [minimal/umount] wait 60 seconds for umount!
        2019-01-05 08:43:22.085  - [34mdebug[39m: backitup.0 [minimal/history] done
        2019-01-05 08:43:22.086  - [34mdebug[39m: backitup.0 [minimal] exec: done
        2019-01-05 08:43:22.094  - [34mdebug[39m: backitup.0 redis pmessage  io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546674202093,"q":0,"from":"system.adapter.backitup.0","lc":1546674202093}
        2019-01-05 08:43:22.134  - [34mdebug[39m: backitup.0 [minimal/redis] done
        2019-01-05 08:43:22.135  - [34mdebug[39m: backitup.0 [minimal] exec: done
        2019-01-05 08:43:22.140  - [34mdebug[39m: backitup.0 redis pmessage  io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546674202138,"q":0,"from":"system.adapter.backitup.0","lc":1546674202093}
        2019-01-05 08:44:22.147  - [34mdebug[39m: backitup.0 [minimal/umount] done
        2019-01-05 08:44:22.148  - [34mdebug[39m: backitup.0 [minimal] exec: done
        2019-01-05 08:44:22.153  - [34mdebug[39m: backitup.0 redis pmessage  io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546674262151,"q":0,"from":"system.adapter.backitup.0","lc":1546674202093}
        Gruß Dirk
        • SegwayS Offline
          SegwayS Offline
          Segway
          #1404
          @nieIP:
          die Installation von
          apt-get install mysql-client
          war die Lösung `
          Das hier hat die Lösung gebracht ! Zumindest ist der Fehler weg und alles läuft sauber durch –> oder nicht ? mysql.tar.gz ist immer noch sehr klein
          backitup.0	2019-01-05 09:45:34.911	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal
          {"val":false,"ack":true,"ts":1546677934908,"q":0,"from":"system.adapter.backitup.0","lc":1546677874890}
          backitup.0	2019-01-05 09:45:34.910	debug	[minimal] exec: done
          backitup.0	2019-01-05 09:45:34.909	debug	[minimal/umount] done
          host.ioBdebian	2019-01-05 09:45:10.805	info	instance system.adapter.daswetter.0 terminated with code 0 (OK)
          daswetter.0	2019-01-05 09:45:01.308	info	starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.15.0
          host.ioBdebian	2019-01-05 09:45:00.024	info	instance system.adapter.daswetter.0 started with pid 1810
          backitup.0	2019-01-05 09:44:39.905	debug	system.adapter.admin.0: logging true
          backitup.0	2019-01-05 09:44:39.904	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1546677879900,"q":0,"from":"system.adapter.admin.0","lc":1546677879900}
          backitup.0	2019-01-05 09:44:34.963	debug	[minimal/mysql] MySql File deleted!
          backitup.0	2019-01-05 09:44:34.891	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546677874890,"q":0,"from":"system.adapter.backitup.0","lc":1546677874890}
          backitup.0	2019-01-05 09:44:34.888	debug	[minimal] exec: done
          backitup.0	2019-01-05 09:44:34.885	debug	[minimal/redis] done
          backitup.0	2019-01-05 09:44:34.846	debug	[minimal/umount] wait 60 seconds for umount!
          backitup.0	2019-01-05 09:44:34.844	debug	[minimal/history] done
          backitup.0	2019-01-05 09:44:34.831	debug	[minimal/telegram] done
          backitup.0	2019-01-05 09:44:34.830	debug	sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
          backitup.0	2019-01-05 09:44:34.828	debug	[minimal/telegram] [minimal] used Telegram-Instance: telegram.0
          backitup.0	2019-01-05 09:44:34.823	debug	[minimal/clean] done
          backitup.0	2019-01-05 09:44:34.819	debug	[minimal/cifs] done
          backitup.0	2019-01-05 09:44:34.814	debug	[minimal/mysql] done
          backitup.0	2019-01-05 09:44:34.774	debug	[minimal/mysql] done
          backitup.0	2019-01-05 09:44:34.674	debug	[minimal/minimal] done
          backitup.0	2019-01-05 09:44:34.561	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-09_44_29_backupiobroker.tar.gz
          backitup.0	2019-01-05 09:44:29.848	debug	[minimal/mount] done
          backitup.0	2019-01-05 09:44:25.496	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":true,"ack":false,"ts":1546677865495,"q":0,"from":"system.adapter.admin.0","lc":1546677865495}
          backitup.0	2019-01-05 09:44:22.157	debug	sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"638246091":"Schecki_Homematic"}
          backitup.0	2019-01-05 09:44:22.154	debug	redis pmessage messagebox.system.adapter.backitup.0 messagebox.system.adapter.backitup.0 {"command":"getTelegramUser","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1
          backitup.0	2019-01-05 09:43:48.300	debug	system.adapter.admin.0: logging false
          backitup.0	2019-01-05 09:43:48.298	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1546677828296,"q":0,"from":"system.adapter.admin.0","lc":1546677828296}
          Gruß Dirk
          • simatecS Offline
            simatecS Offline
            simatec
            #1405
            Wie gesagt … öffne das backup und schaue nach.
            Alles andere ist Glaskugel schauen ...
            • SegwayS Offline
              SegwayS Offline
              Segway
              #1406
              Musste dafür an den Win-Rechner. Also das mysql file ist leer. Das wurde also nicht erstellt - kein Wunder bei 1Kb Größe.
              Im Log ist aber auch keine Meldung gewesen.
              Debug File sieht sauber aus aber SQL dump wird nicht gemacht :-(
              backitup.0	2019-01-05 12:56:51.107	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546689411103,"q":0,"from":"system.adapter.backitup.0","lc":1546689351091}
              backitup.0	2019-01-05 12:56:51.104	debug	[minimal] exec: done
              backitup.0	2019-01-05 12:56:51.104	debug	[minimal/umount] done
              backitup.0	2019-01-05 12:55:51.093	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546689351091,"q":0,"from":"system.adapter.backitup.0","lc":1546689351091}
              backitup.0	2019-01-05 12:55:51.088	debug	[minimal] exec: done
              backitup.0	2019-01-05 12:55:51.086	debug	[minimal/redis] done
              backitup.0	2019-01-05 12:55:51.041	debug	[minimal/umount] wait 60 seconds for umount!
              backitup.0	2019-01-05 12:55:51.038	debug	[minimal/history] done
              backitup.0	2019-01-05 12:55:51.031	debug	[minimal/mysql] MySql File deleted!
              backitup.0	2019-01-05 12:55:51.020	debug	[minimal/telegram] done
              backitup.0	2019-01-05 12:55:51.019	debug	sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
              backitup.0	2019-01-05 12:55:51.017	debug	[minimal/telegram] [minimal] used Telegram-Instance: telegram.0
              backitup.0	2019-01-05 12:55:51.009	debug	[minimal/clean] done
              backitup.0	2019-01-05 12:55:51.004	debug	[minimal/cifs] done
              backitup.0	2019-01-05 12:55:50.995	debug	[minimal/mysql] done
              backitup.0	2019-01-05 12:55:50.899	debug	[minimal/mysql] done
              backitup.0	2019-01-05 12:55:50.840	debug	[minimal/minimal] done
              backitup.0	2019-01-05 12:55:50.774	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-12_55_45_backupiobroker.tar.gz
              backitup.0	2019-01-05 12:55:45.829	debug	[minimal/mount] done
              backitup.0	2019-01-05 12:55:41.309	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":true,"ack":false,"ts":1546689341308,"q":0,"from":"system.adapter.admin.0","lc":1546689341308}
              backitup.0	2019-01-05 12:55:38.285	debug	sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"638246091":"Schecki_Homematic"}
              backitup.0	2019-01-05 12:55:38.280	debug	redis pmessage messagebox.system.adapter.backitup.0 messagebox.system.adapter.backitup.0 {"command":"getTelegramUser","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4
              Gruß Dirk
              • simatecS Offline
                simatecS Offline
                simatec
                #1407
                Schaue mal genau rein.
                Da liegt ein File drin mit dem Dateinamen „.“ (Punkt)
                Die kannst du im Editor öffnen
                • SegwayS Offline
                  SegwayS Offline
                  Segway
                  #1408
                  Puh, jetzt hab ichs entpacken können und meine AUGENESA hen gar nicht das "_" File :-)
                  Hier das Ergebnis was auch immer mir das sagen soll:
                  -- MySQL dump 10.16  Distrib 10.1.37-MariaDB, for debian-linux-gnu (x86_64)
                  -- Host: 192.168.40.11    Database: iobroker
                  -- Server version	5.1.73
                  /*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */;
                  /*!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS */;
                  /*!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION */;
                  /*!40101 SET NAMES utf8mb4 */;
                  /*!40103 SET @OLD_TIME_ZONE=@@TIME_ZONE */;
                  /*!40103 SET TIME_ZONE='+00:00' */;
                  /*!40014 SET @OLD_UNIQUE_CHECKS=@@UNIQUE_CHECKS, UNIQUE_CHECKS=0 */;
                  /*!40014 SET @OLD_FOREIGN_KEY_CHECKS=@@FOREIGN_KEY_CHECKS, FOREIGN_KEY_CHECKS=0 */;
                  /*!40101 SET @OLD_SQL_MODE=@@SQL_MODE, SQL_MODE='NO_AUTO_VALUE_ON_ZERO' */;
                  /*!40111 SET @OLD_SQL_NOTES=@@SQL_NOTES, SQL_NOTES=0 */;
                  Zur Info: Ich habe mal per sqldump auf dem NAS direkt ein backup angestossen. Datei ist 155MB gross und nicht 1kB
                  Gruß Dirk
                  • simatecS Offline
                    simatecS Offline
                    simatec
                    #1409
                    Wie hast das manuell gemacht?
                    Nur die iobroker Datenbank oder alles
                    Prüfe deine Daten in der backitup config auch noch einmal
                    Vor allem den Port
                    • SegwayS Offline
                      SegwayS Offline
                      Segway
                      #1410
                      Jo habe das manuell angestossen über die Seite STANDARD und Haken angekreuzt das SQL mitgemacht werden soll.
                      Auf der Seite von SQL habe ich schon sämtliche Einstellungen ausprobiert inkl unterschiedlich Ports (0, 3306, 3307 und leer). Immer das gleiche Ergebnise :-( Daten sind vom sql.0 Adapter übernommen
                      Gruß Dirk
                      • simatecS Offline
                        simatecS Offline
                        simatec
                        #1411
                        zeige mal bitte deine Einstellung für mysql
                        • simatecS Offline
                          simatecS Offline
                          simatec
                          #1412
                          Ab sofort ist die Version 1.0.2 im github und latest verfügbar.
                          1.0.2 (05.01.2019)
                          (simatec) Fix start/stop for new iobroker-Installer
                          • SegwayS Offline
                            SegwayS Offline
                            Segway
                            #1413
                            Hier meine Einstellung
                            backitup.0	2019-01-05 18:56:41.675	debug	[minimal] exec: done
                            backitup.0	2019-01-05 18:56:41.673	debug	[minimal/umount] done
                            backitup.0	2019-01-05 18:56:23.162	debug	system.adapter.admin.0: logging false
                            backitup.0	2019-01-05 18:56:23.162	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1546710983160,"q":0,"from":"system.adapter.admin.0","lc":1546710983160}
                            backitup.0	2019-01-05 18:56:16.972	debug	sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"638246091":"xxxxxxxxx"}
                            backitup.0	2019-01-05 18:56:16.970	debug	redis pmessage messagebox.system.adapter.backitup.0 messagebox.system.adapter.backitup.0 {"command":"getTelegramUser","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1
                            backitup.0	2019-01-05 18:55:46.977	debug	system.adapter.admin.0: logging true
                            backitup.0	2019-01-05 18:55:46.977	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1546710946975,"q":0,"from":"system.adapter.admin.0","lc":1546710946975}
                            backitup.0	2019-01-05 18:55:41.669	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546710941667,"q":0,"from":"system.adapter.backitup.0","lc":1546710941667}
                            backitup.0	2019-01-05 18:55:41.663	debug	[minimal] exec: done
                            backitup.0	2019-01-05 18:55:41.661	debug	[minimal/redis] done
                            backitup.0	2019-01-05 18:55:41.645	debug	[minimal/mysql] MySql File deleted!
                            backitup.0	2019-01-05 18:55:41.616	debug	[minimal/umount] wait 60 seconds for umount!
                            backitup.0	2019-01-05 18:55:41.614	debug	[minimal/history] done
                            backitup.0	2019-01-05 18:55:41.603	debug	[minimal/telegram] done
                            backitup.0	2019-01-05 18:55:41.603	debug	sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
                            backitup.0	2019-01-05 18:55:41.601	debug	[minimal/telegram] [minimal] used Telegram-Instance: telegram.0
                            backitup.0	2019-01-05 18:55:41.597	debug	[minimal/clean] done
                            backitup.0	2019-01-05 18:55:41.593	debug	[minimal/cifs] done
                            backitup.0	2019-01-05 18:55:41.588	debug	[minimal/mysql] done
                            backitup.0	2019-01-05 18:55:41.563	debug	[minimal/mysql] done
                            backitup.0	2019-01-05 18:55:41.504	debug	[minimal/minimal] done
                            backitup.0	2019-01-05 18:55:41.460	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-18_55_36_backupiobroker.tar.gz
                            backitup.0	2019-01-05 18:55:36.556	debug	[minimal/mount] done
                            backitup.0	2019-01-05 18:55:33.202	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":true,"ack":false,"ts":1546710933201,"q":0,"from":"system.adapter.admin.0","lc":1546710933201}
                            backitup.0	2019-01-05 18:55:29.368	debug	sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"638246091":"Schecki_Homematic"}
                            backitup.0	2019-01-05 18:55:29.367	debug	redis pmessage messagebox.system.adapter.backitup.0 messagebox.system.adapter.backitup.0 {"command":"getTelegramUser","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1
                            backitup.0	2019-01-05 18:55:23.853	debug	system.adapter.admin.0: logging false
                            backitup.0	2019-01-05 18:55:23.853	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1546710923850,"q":0,"from":"system.adapter.admin.0","lc":1546710923850}
                            Gruß Dirk
                            • simatecS Offline
                              simatecS Offline
                              simatec
                              #1414
                              Hast du mal probiert den Hostname statt der IP Adresse zu nehmen?
                              Wo liegt deine mysqldump?
                              Gib mal zum testen den Pfad mit ein
                              • SegwayS Offline
                                SegwayS Offline
                                Segway
                                #1415
                                Weder der Name noch der Pfad bringt was
                                Warte mal ich glaub ich habs !
                                Gruß Dirk
                                • SegwayS Offline
                                  SegwayS Offline
                                  Segway
                                  #1416
                                  So, man muss den PFAD eintragen und ich hatte noch zusaetzlich das Programm eingetragen.
                                  Jedenfalls verstehe ich den Text so, wie er da steht - da gehört aber anscheinend nur der Pfad hin.
                                  Nun rödelt er am backup rum !
                                  Frage:
                                  Warum kam keine Meldung im Log ? Kann du das noch einbauen oder nicht erforderlich ?
                                  Gruß Dirk
                                  • SegwayS Offline
                                    SegwayS Offline
                                    Segway
                                    #1417
                                    zu früh gefreut ?
                                    seit (fast) einer Stunde dieses Bild
                                    Gruß Dirk
                                    • SegwayS Offline
                                      SegwayS Offline
                                      Segway
                                      #1418
                                      Jo, nach diesen Meldungen ist der Adapter neu gestartet :-( kannst du damit was anfangen ?
                                      backitup.0	2019-01-05 20:06:31.445	debug	[minimal] 10 00 01 */5 * *
                                      backitup.0	2019-01-05 20:06:31.444	info	[minimal] backup was activated at 01:00 every 5 day(s)
                                      backitup.0	2019-01-05 20:06:31.402	error	Error: spawn sudo umount ENOENT at Process.ChildProcess._handle.onexit (internal/child_process.js:190:19) at onErrorNT (internal/child_process.js:362:16) at _combinedTickCallback (internal
                                      backitup.0	2019-01-05 20:06:31.402	error	uncaught exception: spawn sudo umount ENOENT
                                      backitup.0	2019-01-05 20:06:31.402	info	starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
                                      backitup.0	2019-01-05 20:05:59.854	error	Error: spawn EACCES at ChildProcess.spawn (internal/child_process.js:313:11) at exports.spawn (child_process.js:508:9) at WriteStream.stream.once.fd (/opt/iobroker/node_modules/iobroker.ba
                                      backitup.0	2019-01-05 20:05:59.853	error	uncaught exception: spawn EACCES
                                      backitup.0	2019-01-05 20:05:59.825	debug	[minimal/minimal] done
                                      backitup.0	2019-01-05 20:05:59.761	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-20_05_54_backupiobroker.tar.gz
                                      backitup.0	2019-01-05 20:05:54.762	debug	[minimal/mount] done
                                      Gruß Dirk
                                      • simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #1419
                                        Was liegt jetzt auf dem NAS?
                                        Hat er etwas erstellt?
                                        • SegwayS Offline
                                          SegwayS Offline
                                          Segway
                                          #1420
                                          Bitte schön :-)
                                          Gruß Dirk
