  4. Modbus adapter
    5.7k
Modbus adapter
modbus adaptermodbus
981 Beiträge 141 Kommentatoren 482.3k Aufrufe 64 Beobachtet
  • S Schtallone
    Guten Abend zusammen,
    ich habe mal 1-2 Fragen zum Modbus Adapter, welche hoffentlich in diesem Thread richtig aufgehoben sind.
    Folgende Log habe ich einmal repräsentativ hier angefügt.
    2023-09-21 17:50:13.223  - error: modbus.0 (1212) Can not set value: Attempt to access memory outside buffer bounds
    2023-09-21 17:50:55.007  - info: modbus.0 (1212) Disconnected from slave 192.168.1.47
    2023-09-21 17:51:55.009  - info: modbus.0 (1212) Connected to slave 192.168.1.47
    2023-09-21 17:52:28.070  - info: modbus.0 (1212) Disconnected from slave 192.168.1.47
    2023-09-21 17:53:28.072  - info: modbus.0 (1212) Connected to slave 192.168.1.47
    2023-09-21 17:55:00.063  - info: host.iobroker instance system.adapter.dwd.0 started with pid 15872
    2023-09-21 17:55:01.546  - info: dwd.0 (15872) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
    2023-09-21 17:55:02.457  - info: dwd.0 (15872) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-21 17:55:02.977  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-21 17:55:18.079  - info: modbus.0 (1212) Disconnected from slave 192.168.1.47
    2023-09-21 17:56:18.081  - info: modbus.0 (1212) Connected to slave 192.168.1.47
    2023-09-21 17:56:58.083  - info: modbus.0 (1212) Disconnected from slave 192.168.1.47
    2023-09-21 17:57:58.086  - info: modbus.0 (1212) Connected to slave 192.168.1.47
    2023-09-21 17:58:58.084  - info: modbus.0 (1212) Disconnected from slave 192.168.1.47
    2023-09-21 17:59:58.086  - info: modbus.0 (1212) Connected to slave 192.168.1.47
    2023-09-21 18:00:00.058  - info: host.iobroker instance system.adapter.dwd.0 started with pid 16115
    2023-09-21 18:00:03.212  - info: dwd.0 (16115) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
    2023-09-21 18:00:05.863  - info: dwd.0 (16115) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-21 18:00:06.387  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-21 18:00:18.082  - info: modbus.0 (1212) Disconnected from slave 192.168.1.47
    2023-09-21 18:01:18.084  - info: modbus.0 (1212) Connected to slave 192.168.1.47
    2023-09-21 18:02:13.108  - error: modbus.0 (1212) Can not set value: Attempt to access memory outside buffer bounds
    2023-09-21 18:02:35.021  - info: modbus.0 (1212) Disconnected from slave 192.168.1.47
    2023-09-21 18:02:54.448  - info: shelly.0 (5156) [MQTT] Device with client id "shellyplus1pm-a8032ab96370" connected!
    2023-09-21 18:03:35.022  - info: modbus.0 (1212) Connected to slave 192.168.1.47
    2023-09-21 18:03:58.089  - info: modbus.0 (1212) Disconnected from slave 192.168.1.47
    2023-09-21 18:04:58.091  - info: modbus.0 (1212) Connected to slave 192.168.1.47
    2023-09-21 18:05:00.064  - info: host.iobroker instance system.adapter.dwd.0 started with pid 16372
    2023-09-21 18:05:01.542  - info: dwd.0 (16372) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
    2023-09-21 18:05:02.768  - info: dwd.0 (16372) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-21 18:05:03.292  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-21 18:05:33.516  - error: modbus.0 (1212) Can not set value: Attempt to access memory outside buffer bounds
    2023-09-21 18:07:34.528  - info: modbus.0 (1212) Disconnected from slave 192.168.1.47
    2023-09-21 18:08:34.532  - info: modbus.0 (1212) Connected to slave 192.168.1.47
    2023-09-21 18:09:05.028  - info: modbus.0 (1212) Disconnected from slave 192.168.1.47
    2023-09-21 18:10:00.059  - info: host.iobroker instance system.adapter.dwd.0 started with pid 16631
    2023-09-21 18:10:01.955  - info: dwd.0 (16631) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
    2023-09-21 18:10:03.758  - info: dwd.0 (16631) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-21 18:10:04.309  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-21 18:10:05.030  - info: modbus.0 (1212) Connected to slave 192.168.1.47
    2023-09-21 18:10:48.091  - info: modbus.0 (1212) Disconnected from slave 192.168.1.47
    2023-09-21 18:11:48.093  - info: modbus.0 (1212) Connected to slave 192.168.1.47
    2023-09-21 18:12:05.040  - info: modbus.0 (1212) Disconnected from slave 192.168.1.47
    2023-09-21 18:12:23.562  - info: admin.0 (246) ==> Connected system.user.admin from ::ffff:192.168.1.119
    2023-09-21 18:13:05.042  - info: modbus.0 (1212) Connected to slave 192.168.1.47
    2023-09-21 18:13:38.096  - info: modbus.0 (1212) Disconnected from slave 192.168.1.47
    2023-09-21 18:57:56.667  - debug: modbus.0 (18045) [DevID_120] Poll start ---------------------
    2023-09-21 18:57:56.667  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 52 - 2 registers
    2023-09-21 18:57:56.767  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 52 DONE
    2023-09-21 18:57:56.767  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 72 - 2 registers
    2023-09-21 18:57:56.870  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 72 DONE
    2023-09-21 18:57:57.921  - debug: modbus.0 (18045) [DevID_1] Poll start ---------------------
    2023-09-21 18:57:57.922  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 12 - 2 registers
    2023-09-21 18:57:58.023  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 12 DONE
    2023-09-21 18:57:58.024  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 342 - 2 registers
    2023-09-21 18:57:58.126  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 342 DONE
    2023-09-21 18:57:58.177  - debug: modbus.0 (18045) [DevID_110] Poll start ---------------------
    2023-09-21 18:57:58.177  - debug: modbus.0 (18045) [DevID_110/inputRegs] Poll address 52 - 2 registers
    2023-09-21 18:57:58.277  - debug: modbus.0 (18045) [DevID_110/inputRegs] Poll address 52 DONE
    2023-09-21 18:57:58.278  - debug: modbus.0 (18045) [DevID_110/inputRegs] Poll address 72 - 2 registers
    2023-09-21 18:57:58.380  - debug: modbus.0 (18045) [DevID_110/inputRegs] Poll address 72 DONE
    2023-09-21 18:57:58.431  - debug: modbus.0 (18045) [DevID_116] Poll start ---------------------
    2023-09-21 18:57:58.431  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 52 - 2 registers
    2023-09-21 18:57:58.533  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 52 DONE
    2023-09-21 18:57:58.534  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 72 - 4 registers
    2023-09-21 18:57:58.636  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 72 DONE
    2023-09-21 18:57:58.637  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 342 - 2 registers
    2023-09-21 18:57:58.738  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 342 DONE
    2023-09-21 18:57:58.739  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 396 - 2 registers
    2023-09-21 18:57:58.840  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 396 DONE
    2023-09-21 18:57:58.841  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 1280 - 4 registers
    2023-09-21 18:57:58.944  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 1280 DONE
    2023-09-21 18:57:58.994  - debug: modbus.0 (18045) [DevID_120] Poll start ---------------------
    2023-09-21 18:57:58.994  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 52 - 2 registers
    2023-09-21 18:57:59.096  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 52 DONE
    2023-09-21 18:57:59.097  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 72 - 2 registers
    2023-09-21 18:57:59.198  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 72 DONE
    2023-09-21 18:58:00.248  - debug: modbus.0 (18045) [DevID_1] Poll start ---------------------
    2023-09-21 18:58:00.248  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 12 - 2 registers
    2023-09-21 18:58:00.351  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 12 DONE
    2023-09-21 18:58:00.351  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 342 - 2 registers
    2023-09-21 18:58:00.454  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 342 DONE
    2023-09-21 18:58:00.504  - debug: modbus.0 (18045) [DevID_110] Poll start ---------------------
    2023-09-21 18:58:00.505  - debug: modbus.0 (18045) [DevID_110/inputRegs] Poll address 52 - 2 registers
    2023-09-21 18:58:00.607  - debug: modbus.0 (18045) [DevID_110/inputRegs] Poll address 52 DONE
    2023-09-21 18:58:00.607  - debug: modbus.0 (18045) [DevID_110/inputRegs] Poll address 72 - 2 registers
    2023-09-21 18:58:00.708  - debug: modbus.0 (18045) [DevID_110/inputRegs] Poll address 72 DONE
    2023-09-21 18:58:00.758  - debug: modbus.0 (18045) [DevID_116] Poll start ---------------------
    2023-09-21 18:58:00.758  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 52 - 2 registers
    2023-09-21 18:58:00.861  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 52 DONE
    2023-09-21 18:58:00.862  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 72 - 4 registers
    2023-09-21 18:58:00.964  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 72 DONE
    2023-09-21 18:58:00.964  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 342 - 2 registers
    2023-09-21 18:58:01.067  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 342 DONE
    2023-09-21 18:58:01.067  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 396 - 2 registers
    2023-09-21 18:58:01.168  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 396 DONE
    2023-09-21 18:58:01.168  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 1280 - 4 registers
    2023-09-21 18:58:01.271  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 1280 DONE
    2023-09-21 18:58:01.322  - debug: modbus.0 (18045) [DevID_120] Poll start ---------------------
    2023-09-21 18:58:01.323  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 52 - 2 registers
    2023-09-21 18:58:01.424  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 52 DONE
    2023-09-21 18:58:01.425  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 72 - 2 registers
    2023-09-21 18:58:01.527  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 72 DONE
    2023-09-21 18:58:02.578  - debug: modbus.0 (18045) [DevID_1] Poll start ---------------------
    2023-09-21 18:58:02.579  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 12 - 2 registers
    2023-09-21 18:58:13.694  - debug: modbus.0 (18045) Socket closed with error
    2023-09-21 18:58:13.694  - debug: modbus.0 (18045) Clearing timeout of the current request.
    2023-09-21 18:58:13.694  - debug: modbus.0 (18045) Cleaning up request fifo.
    2023-09-21 18:58:14.695  - debug: modbus.0 (18045) Closing client on purpose.
    2023-09-21 18:58:14.696  - info: modbus.0 (18045) Disconnected from slave 192.168.1.47
    2023-09-21 18:59:14.699  - info: modbus.0 (18045) Connected to slave 192.168.1.47
    2023-09-21 18:59:14.700  - debug: modbus.0 (18045) [DevID_1] Poll start ---------------------
    2023-09-21 18:59:14.700  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 12 - 2 registers
    2023-09-21 18:59:14.802  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 12 DONE
    2023-09-21 18:59:14.803  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 342 - 2 registers
    2023-09-21 18:59:14.889  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 342 DONE
    2023-09-21 18:59:14.940  - debug: modbus.0 (18045) [DevID_110] Poll start ---------------------
    2023-09-21 18:59:14.940  - debug: modbus.0 (18045) [DevID_110/inputRegs] Poll address 52 - 2 registers
    2023-09-21 18:59:15.019  - debug: modbus.0 (18045) [DevID_110/inputRegs] Poll address 52 DONE
    2023-09-21 18:59:15.020  - debug: modbus.0 (18045) [DevID_110/inputRegs] Poll address 72 - 2 registers
    2023-09-21 18:59:15.099  - debug: modbus.0 (18045) [DevID_110/inputRegs] Poll address 72 DONE
    2023-09-21 18:59:15.150  - debug: modbus.0 (18045) [DevID_116] Poll start ---------------------
    2023-09-21 18:59:15.150  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 52 - 2 registers
    2023-09-21 18:59:15.229  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 52 DONE
    2023-09-21 18:59:15.230  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 72 - 4 registers
    2023-09-21 18:59:15.316  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 72 DONE
    2023-09-21 18:59:15.316  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 342 - 2 registers
    2023-09-21 18:59:15.400  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 342 DONE
    2023-09-21 18:59:15.400  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 396 - 2 registers
    2023-09-21 18:59:15.483  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 396 DONE
    2023-09-21 18:59:15.483  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 1280 - 4 registers
    2023-09-21 18:59:15.566  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 1280 DONE
    2023-09-21 18:59:15.616  - debug: modbus.0 (18045) [DevID_120] Poll start ---------------------
    2023-09-21 18:59:15.616  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 52 - 2 registers
    2023-09-21 18:59:15.700  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 52 DONE
    2023-09-21 18:59:15.700  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 72 - 2 registers
    2023-09-21 18:59:15.780  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 72 DONE
    2023-09-21 18:59:16.832  - debug: modbus.0 (18045) [DevID_1] Poll start ---------------------
    2023-09-21 18:59:16.833  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 12 - 2 registers
    2023-09-21 18:59:16.920  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 12 DONE
    2023-09-21 18:59:16.920  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 342 - 2 registers
    2023-09-21 18:59:17.010  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 342 DONE
    2023-09-21 18:59:17.061  - debug: modbus.0 (18045) [DevID_110] Poll start ---------------------
    2023-09-21 18:59:17.062  - debug: modbus.0 (18045) [DevID_110/inputRegs] Poll address 52 - 2 registers
    2023-09-21 18:59:17.143  - debug: modbus.0 (18045) [DevID_110/inputRegs] Poll address 52 DONE
    2023-09-21 18:59:17.143  - debug: modbus.0 (18045) [DevID_110/inputRegs] Poll address 72 - 2 registers
    2023-09-21 18:59:17.223  - debug: modbus.0 (18045) [DevID_110/inputRegs] Poll address 72 DONE
    2023-09-21 18:59:17.274  - debug: modbus.0 (18045) [DevID_116] Poll start ---------------------
    2023-09-21 18:59:17.274  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 52 - 2 registers
    2023-09-21 18:59:17.353  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 52 DONE
    2023-09-21 18:59:17.354  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 72 - 4 registers
    2023-09-21 18:59:17.436  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 72 DONE
    2023-09-21 18:59:17.437  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 342 - 2 registers
    2023-09-21 18:59:17.520  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 342 DONE
    2023-09-21 18:59:17.521  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 396 - 2 registers
    2023-09-21 18:59:17.603  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 396 DONE
    2023-09-21 18:59:17.604  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 1280 - 4 registers
    2023-09-21 18:59:17.686  - debug: modbus.0 (18045) [DevID_116/inputRegs] Poll address 1280 DONE
    2023-09-21 18:59:17.737  - debug: modbus.0 (18045) [DevID_120] Poll start ---------------------
    2023-09-21 18:59:17.737  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 52 - 2 registers
    2023-09-21 18:59:17.820  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 52 DONE
    2023-09-21 18:59:17.821  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 72 - 2 registers
    2023-09-21 18:59:17.900  - debug: modbus.0 (18045) [DevID_120/inputRegs] Poll address 72 DONE
    2023-09-21 18:59:18.952  - debug: modbus.0 (18045) [DevID_1] Poll start ---------------------
    2023-09-21 18:59:18.953  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 12 - 2 registers
    2023-09-21 18:59:19.041  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 12 DONE
    2023-09-21 18:59:19.041  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 342 - 2 registers
    2023-09-21 18:59:19.131  - debug: modbus.0 (18045) [DevID_1/inputRegs] Poll address 342 DONE
    Skript v.2023-06-20
    *** BASE SYSTEM ***
    cat: /sys/devices/virtual/dmi/id/sys_vendor: No such file or directory
    Hardware Vendor :
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v8.1.0
    Virtualization  : Docker
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     19:07:15 up 5 days,  5:58,  0 users,  load average: 1.73, 1.57, 1.45
    CPU threads: 2
    *** Time and Time Zones ***
    Thu Sep 21 17:07:15 UTC 2023
    Thu Sep 21 19:07:15 CEST 2023
    CEST +0200
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            7.8G        3.9G        669M        253M        3.3G        3.1G
    Swap:            23G        1.1G         22G
    Total:           31G        5.0G         23G
             7792 M total memory
             3872 M used memory
             3179 M active memory
             2564 M inactive memory
              669 M free memory
             1380 M buffer memory
             1870 M swap cache
            23447 M total swap
             1080 M used swap
            22366 M free swap
    *** FILESYSTEM ***
    Filesystem            Type     Size  Used Avail Use% Mounted on
    overlay               overlay  2.6T  1.6T 1016G  62% /
    tmpfs                 tmpfs     64M     0   64M   0% /dev
    tmpfs                 tmpfs    3.9G     0  3.9G   0% /sys/fs/cgroup
    shm                   tmpfs     64M     0   64M   0% /dev/shm
    /dev/mapper/cachedev1 ext4     2.6T  1.6T 1016G  62% /opt/iobroker
    tmpfs                 tmpfs    3.9G     0  3.9G   0% /proc/asound
    tmpfs                 tmpfs    3.9G     0  3.9G   0% /proc/acpi
    tmpfs                 tmpfs    3.9G     0  3.9G   0% /proc/scsi
    tmpfs                 tmpfs    3.9G     0  3.9G   0% /sys/firmware
    dmesg: read kernel buffer failed: Operation not permitted
    Show mounted filesystems (real ones only):
    TARGET           SOURCE        FSTYPE OPTIONS
    /opt/iobroker    /dev/mapper/cachedev1[/Docker/iobroker]        ext4   rw,relatime,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
    /etc/resolv.conf /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/fc3f3c4c81fc4d371ff10ae519deeb41066e2e757561c9f538dca358839bd4af/resolv.conf] ext4   rw,relatime,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
    /etc/hostname    /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/fc3f3c4c81fc4d371ff10ae519deeb41066e2e757561c9f538dca358839bd4af/hostname]    ext4   rw,relatime,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
    /etc/hosts       /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/fc3f3c4c81fc4d371ff10ae519deeb41066e2e757561c9f538dca358839bd4af/hosts]       ext4   rw,relatime,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
    /var:
    33M     /var/
    31M     /var/lib
    18M     /var/lib/apt/lists
    18M     /var/lib/apt
    13M     /var/lib/dpkg
    /opt/iobroker/backups:
    1005M   /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    616M    /opt/iobroker/iobroker-data/
    415M    /opt/iobroker/iobroker-data/files
    132M    /opt/iobroker/iobroker-data/files/javascript.admin
    129M    /opt/iobroker/iobroker-data/files/devices.admin/static
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.f95354b8.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 127.0.0.1
    States:                     jsonl on 127.0.0.1
    Core adapters versions
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   1
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
      system.adapter.device-watcher.0         : device-watcher        : iobroker                                 - disabled
      system.adapter.devices.0                : devices               : iobroker                                 - disabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      system.adapter.energiefluss.0           : energiefluss          : iobroker                                 - disabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 - disabled
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
      system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
      system.adapter.meross.0                 : meross                : iobroker                                 - disabled
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
      system.adapter.pvforecast.0             : pvforecast            : iobroker                                 - disabled
      system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      system.adapter.snmp.0                   : snmp                  : iobroker                                 - disabled
      system.adapter.sonos.0                  : sonos                 : iobroker                                 - disabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
      system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alias-manager": 1.2.4    , installed 1.2.6
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "device-watcher": 2.9.3   , installed 2.9.3
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.4
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.8
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "meross"       : 1.15.1   , installed 1.15.1
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "pushover"     : 3.0.3    , installed 3.0.4
    Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
    Adapter    "schoolfree"   : 1.1.1    , installed 1.1.2
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
    Adapter    "snmp"         : 2.4.11   , installed 2.4.11
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "vw-connect"   : 0.0.67   , installed 0.1.2
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Objects and States
    Objects:        10622
    States:         8871
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       82559291   -
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       56866846   -
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       25973221   -
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       25973205   -
    tcp        0      0 127.0.0.11:39891        0.0.0.0:*               LISTEN      0          25586275   -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       25995518   -
    udp        0      0 127.0.0.11:41697        0.0.0.0:*                           0          25586274   -
    2023-09-15 00:37:02.337  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-a8032ab94e10 / shellyplus1pm#a8032ab94e10#1) (false)
    2023-09-15 00:37:03.121  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a876248"
    2023-09-15 00:37:04.440  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-5443b23e5f74" connected!
    2023-09-15 00:37:05.005  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a8b94fc"
    2023-09-15 00:37:05.005  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-7c87ce65d970"
    2023-09-15 00:37:05.006  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a8bf730"
    2023-09-15 00:37:05.006  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a8032ab94e10"
    2023-09-15 00:37:05.295  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-b8d61a863524 / shellyplus2pm#b8d61a863524#1) (false)
    2023-09-15 00:37:05.587  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-3c610579bd34 / shellyplus1pm#3c610579bd34#1) (false)
    2023-09-15 00:37:06.868  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a863524"
    2023-09-15 00:37:07.457  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-3c610579bd34"
    2023-09-15 00:37:07.722  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-4022d8da969c / shellyplus2pm#4022d8da969c#1) (false)
    2023-09-15 00:37:07.785  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-7c87ce65d794 / shellyplus1pm#7c87ce65d794#1) (false)
    2023-09-15 00:37:11.460  - info: modbus.0 (411) Connected to slave 192.168.1.47
    2023-09-15 00:37:12.224  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-5443b23ecce4" connected!
    2023-09-15 00:37:14.432  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-5443b23e5f74 / shellyplus2pm#5443b23e5f74#1) (false)
    2023-09-15 00:37:22.217  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-5443b23ecce4 / shellyplus2pm#5443b23ecce4#1) (false)
    2023-09-15 00:37:25.564  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-5443b23fd3dc" connected!
    2023-09-15 00:37:27.320  - info: modbus.0 (411) Disconnected from slave 192.168.1.47
    2023-09-15 00:37:29.078  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus1pm-a8032abc230c" connected!
    2023-09-15 00:37:30.096  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-5443b23e1a90" connected!
    2023-09-15 00:37:35.564  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-5443b23fd3dc / shellyplus2pm#5443b23fd3dc#1) (false)
    2023-09-15 00:37:36.407  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-4022d8dbe474" connected!
    2023-09-15 00:37:38.493  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus1-441793a820f4" connected!
    2023-09-15 00:37:38.853  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-a8032abc230c / shellyplus1pm#a8032abc230c#1) (false)
                         v.2023-06-20
    model name      : Intel(R) Celeron(R) J4005 CPU @ 2.00GHz
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v8.1.0
    Installation:           Docker
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Etc/UTC
    User-ID:                0
    X-Server:               false
    Pending OS-Updates:     1
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            7.8G        3.9G        808M        252M        3.1G        3.1G
    Swap:            23G        1.1G         22G
    Total:           31G        5.0G         23G
    Active iob-Instances:   11
    ioBroker Core:          js-controller           5.0.12
                            admin                   6.10.1
    Objects type: jsonl
    States  type: jsonl
    Objects:                10622
    States:                 8871
    Size of iob-Database:
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    3.0M    /opt/iobroker/iobroker-data/states.jsonl
    Der Modbus Adapter in der Version 5.0.11 verbindet und trennt die VErbindung zu einem Protoss PE-11 Modbus-Ethernet Adapter mitz der statischen IP 192.168.1.47, an dem in SUmme 3 SDM72 Zähler hängen.
    Weitere Register der Zähler lese ich direkt per NodeRed aus und schreibe Sie nach Aufbereitung in eine Influx2.0 DB.
    Den Umweg über den ioB wähle ich bei den oben genannten Registern, da ich diese Verbräuche per SourceAnalytics Adapter verarbeitet und dann auch per NodeRed in die InfluxDB schreibe.
    Meine Fragen lautet:
    Ist dieses Connect / Disconnect VErhalten normal?
    Ich bekomme auch periodisch Fehlermeldungen (siehe Log). Wie kann ich dies in den Griff bekommen bzw. optimieren?
    Folgende Register lese ich aus:
    Folgende Apdater-Einstellungen habe ich aktuell am laufen:
    Wenn Ihr noch weitere Informationen benötigt, teile ich diese gerne mit.
    Danke für Eure Hilfe und Gruß
    #921
    @schtallone sagte in Modbus adapter:
    wenn du
    auf das selbe Interface zugreifst könnte ich mir das als Ursache vorstellen.
      wenn du
      Schtallone
      #922
      Ich habe mal die Abfragen über NodeRed deaktiviert. Die Frquenz der Disconnects ist geringer geworden, aber nicht weg:
      2023-09-21 19:29:58.381  - info: modbus.0 (21734) starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.17.1, js-controller: 5.0.12
      2023-09-21 19:29:59.582  - info: modbus.0 (21734) Connected to slave 192.168.1.47
      2023-09-21 19:30:00.058  - info: host.iobroker instance system.adapter.dwd.0 started with pid 21749
      2023-09-21 19:30:02.490  - info: dwd.0 (21749) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-21 19:30:05.734  - info: dwd.0 (21749) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-21 19:30:06.258  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-21 19:30:23.880  - info: modbus.0 (21734) Disconnected from slave 192.168.1.47
      2023-09-21 19:31:23.882  - info: modbus.0 (21734) Connected to slave 192.168.1.47
      2023-09-21 19:31:44.468  - info: modbus.0 (21734) Disconnected from slave 192.168.1.47
      2023-09-21 19:32:09.510  - info: admin.0 (246) ==> Connected system.user.admin from ::ffff:192.168.1.119
      2023-09-21 19:32:44.471  - info: modbus.0 (21734) Connected to slave 192.168.1.47
      2023-09-21 19:33:04.531  - info: modbus.0 (21734) Disconnected from slave 192.168.1.47
      • S Schtallone
        Skript v.2023-06-20
        *** BASE SYSTEM ***
        Hardware Vendor :
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v8.1.0
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 2
        CEST +0200
        Etc/UTC
        root
        /root
        root
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:            23G        1.1G         22G
        Total:           31G        5.0G         23G
                 7792 M total memory
                 3872 M used memory
                  669 M free memory
                 1870 M swap cache
                23447 M total swap
                 1080 M used swap
                22366 M free swap
        *** FILESYSTEM ***
        /var:
        33M     /var/
        31M     /var/lib
        18M     /var/lib/apt
        13M     /var/lib/dpkg
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.10.1
        javascript:     7.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        10622
        States:         8871
        Pending Updates: 1
                             v.2023-06-20
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v8.1.0
        Kernel:                 x86_64
        Userland:               amd64
        Timezone:               Etc/UTC
        User-ID:                0
        X-Server:               false
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        MEMORY:
        Swap:            23G        1.1G         22G
        Total:           31G        5.0G         23G
                                admin                   6.10.1
        Objects type: jsonl
        States  type: jsonl
        Objects:                10622
        States:                 8871
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        #923
        Schalte mal testweise die Shelly Instanz aus , danach startest du den Container neu .
        Was ist dann , wenn der Shelly Adapter aus ist , mit den Meldungen !?
        PS :
        Seit 2 Wochen habe ich den Shelly Adapter installiert ( ink 3 Geräte ) , danach habe ich ein merkwürdiges phänomen beim Modbus Adapter festgestellt wie bei dir , nur sind bei mir 5 Instanzen betroffen , die gleich Meldung wie bei dir und beim anlernen einer Shelly bekomme ich ein App Timeout sogar .
        Den Hintergrund bin ich selber noch am suchen .
        • GlasfaserG Glasfaser
          PS :
          Schtallone
          #924
          @glasfaser
          werde ich gleich mal testen und berichten.
          Diese Fehlermeldung kommt aus sporadisch....
          2023-09-21 19:36:55.244  - info: modbus.0 (21734) Connected to slave 192.168.1.47
          2023-09-21 19:37:02.585  - error: modbus.0 (21734) Can not set value: Attempt to access memory outside buffer bounds
          2023-09-21 19:37:24.243  - info: modbus.0 (21734) Disconnected from slave 192.168.1.47
          • S Schtallone
            @glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            #925
            @schtallone
            Eventuell muß du den "Datenabfrageinterval" höher setzen von 1000 auf z.B 5000 ,
            probiere es zusätzlich noch aus !
              @schtallone
              Schtallone
              #926
              @glasfaser
              Habe den Shelly Adapter aus. Keine Veränderung.
              Ebenfalls Abfrageintervall von 1000 auf 5000 erhöht. Immernoch Connects / dissconnects.
              2023-09-21 19:48:23.048  - info: modbus.0 (233) Got terminate signal TERMINATE_YOURSELF
              2023-09-21 19:48:23.050  - info: modbus.0 (233) terminating
              2023-09-21 19:48:23.051  - info: modbus.0 (233) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-09-21 19:48:23.384  - info: admin.0 (179) <== Disconnect system.user.admin from ::ffff:192.168.1.119 modbus
              2023-09-21 19:48:23.552  - info: modbus.0 (233) terminating
              2023-09-21 19:48:23.606  - info: host.iobroker instance system.adapter.modbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-09-21 19:48:26.186  - info: host.iobroker instance system.adapter.modbus.0 started with pid 837
              2023-09-21 19:48:27.576  - info: modbus.0 (837) starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.17.1, js-controller: 5.0.12
              2023-09-21 19:48:27.931  - info: modbus.0 (837) Connected to slave 192.168.1.47
              2023-09-21 19:49:24.868  - info: modbus.0 (837) Disconnected from slave 192.168.1.47
              2023-09-21 19:50:00.046  - info: host.iobroker instance system.adapter.dwd.0 started with pid 924
              2023-09-21 19:50:01.683  - info: dwd.0 (924) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
              2023-09-21 19:50:03.711  - info: dwd.0 (924) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-09-21 19:50:04.272  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-09-21 19:50:24.870  - info: modbus.0 (837) Connected to slave 192.168.1.47
              2023-09-21 19:52:24.880  - info: modbus.0 (837) Disconnected from slave 192.168.1.47
              2023-09-21 19:53:24.881  - info: modbus.0 (837) Connected to slave 192.168.1.47
              2023-09-21 19:54:13.873  - info: modbus.0 (837) Disconnected from slave 192.168.1.47
              2023-09-21 19:55:00.048  - info: host.iobroker instance system.adapter.dwd.0 started with pid 1170
              2023-09-21 19:55:01.615  - info: dwd.0 (1170) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
              2023-09-21 19:55:02.794  - info: dwd.0 (1170) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-09-21 19:55:03.319  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-09-21 19:55:13.876  - info: modbus.0 (837) Connected to slave 192.168.1.47
              2023-09-21 19:55:44.888  - info: modbus.0 (837) Disconnected from slave 192.168.1.47
              2023-09-21 19:56:44.892  - info: modbus.0 (837) Connected to slave 192.168.1.47
              • S Schtallone
                Skript v.2023-06-20
                *** BASE SYSTEM ***
                Hardware Vendor :
                Kernel          : x86_64
                Userland        : amd64
                Docker          : v8.1.0
                Kernel          : x86_64
                Userland        : amd64
                CPU threads: 2
                CEST +0200
                Etc/UTC
                root
                /root
                root
                X-Server:       false
                Desktop:
                Terminal:
                *** MEMORY ***
                Swap:            23G        1.1G         22G
                Total:           31G        5.0G         23G
                         7792 M total memory
                         3872 M used memory
                          669 M free memory
                         1870 M swap cache
                        23447 M total swap
                         1080 M used swap
                        22366 M free swap
                *** FILESYSTEM ***
                /var:
                33M     /var/
                31M     /var/lib
                18M     /var/lib/apt
                13M     /var/lib/dpkg
                /usr/bin/npm            9.6.7
                /usr/bin/npx            9.6.7
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.10.1
                javascript:     7.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects:        10622
                States:         8871
                Pending Updates: 1
                                     v.2023-06-20
                Kernel          : x86_64
                Userland        : amd64
                Docker          : v8.1.0
                Kernel:                 x86_64
                Userland:               amd64
                Timezone:               Etc/UTC
                User-ID:                0
                X-Server:               false
                                        /usr/bin/npm            9.6.7
                                        /usr/bin/npx            9.6.7
                MEMORY:
                Swap:            23G        1.1G         22G
                Total:           31G        5.0G         23G
                                        admin                   6.10.1
                Objects type: jsonl
                States  type: jsonl
                Objects:                10622
                States:                 8871
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                #927
                Brauche noch Infos:
                Hast du die Instanz erst neu angelegt und eingerichtet
                oder lief es mal und jetzt kommen diese Fehler !?
                • S Schtallone
                  @glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  #928
                  @schtallone
                  Ich denke mal neu eingerichtet , denn ich sehe da ein Fehler
                  Du hast doch nur ein Protoss PE-11 Modbus-Ethernet Adapter und nur ein SDM72 Zähler !?
                  dann gehört da nur die 1 als ID rein , die auch der Protoss PE-11 Modbus-Ethernet Adapter hat
                  und nicht 110 bis ....
                    Brauche noch Infos:
                    Schtallone
                    #929
                    @glasfaser
                    Ich habe die Instanz schon länger laufen, mehrere Wochen. Lief aber nie ohne Fehler.
                    Ich habe einiges an Abfragen auf NodeRed verschoben, dabei ist es im Adapter besser geworden. Aber wer weiß was im "Backoffice" von NodeRed jetzt los ist...
                    Debug das ist aber ok.
                    • S Schtallone
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      #930
                      siehe oben
                      EDIT :
                      so meine ich das :
                        @schtallone
                        Schtallone
                        #931
                        @glasfaser
                        ich habe in SUmme 4 Modbus-Zähler dran. IDs 1, 110, 116 und 120
                        • S Schtallone
                          @glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Glasfaser
                          #932
                          @schtallone
                          Abschlusswiderstand vorhanden , Bautrate alle gleich usw.
                          Dann Klemme nach und nach einen Zähler ab ( natürlich auch dazu das Register kürzen ) , ist diese Meldung dann auch nur bei einem Zähler der angeschlossen ist vorhanden !?
                          S HomoranH 2 Antworten Letzte Antwort
                            @schtallone
                            Schtallone
                            #933
                            @glasfaser said in Modbus adapter:
                            @schtallone
                            nein, kannst Du das erläutern?
                            ja
                            • S Schtallone
                              @schtallone
                              ja
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Glasfaser
                              #934
                              Z.B :
                              https://servicecenter.linemetrics.com/de/servicearticle/linemetrics-box/schnittstellen/modbus/aufbau-und-funktion-von-modbusgeraten/
                                @schtallone
                                #935
                                @glasfaser sagte in Modbus adapter:
                                halte ich für unnötig.
                                wenn Verdrahtung eher hier
                                aber ich tippe eher auf den Konverter
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  #936
                                  @homoran sagte in Modbus adapter:
                                  War nur ein Vorschlag , da ich seine Installation nicht kenne bei mehr als 3 Modbus Teilnehmer
                                  deshalb soll er nach und nach abklemmen , da er schreibt
                                  hat noch nie ohne Fehler funktioniert
                                    #937
                                    kein Problem
                                    Allerdings alles RTU bis zum Serverschrank etwa 7m ohne Widerstände
                                      kein Problem
                                      Schtallone
                                      #938
                                      ich komme gerade nicht dazu, melde mich aber am Wochenende dazu. Danke erstmal und Gruß
                                        Schtallone
                                        #939
                                        Tach zusammen,
                                        gerade mal geschaut und ich habe keine Daisy-Chain aufgebaut, sondern eine Art Stub-Connection.
                                        Ich werde dies mal die Tage ändern und dann hier berichten.
                                        • S Schtallone
                                          Tach zusammen,
                                          #940
                                          das macht Ärger!
                                          bin gespannt
                                          S 2 Antworten Letzte Antwort
