  4. Update Mi Home Vacuum auf 1.1.0 schlägt fehl/Fehlermeldungen
8 Beiträge 5 Kommentatoren 926 Aufrufe
  • K Offline
    Kueppert
    Hallo in die Gemeinde,
    habe eben vom 0.6.0 auf 1.1.0 ein Update gefahren und folgende Fehlermeldung erhalten:
    ! Fertig mit Fehler: /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:431 target[attr] = additional[attr]; ^ TypeError: Cannot create property 'en' on string 'This adapter allows control Xiaomi vacuum cleaner' at extendCommon (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:431:34) at extendCommon (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:434:21) at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:487:64) at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9) at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12) at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15) at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8) at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15) at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:134:20)
    und hier was im grauen Kasten im Admin steht, nicht darüber:
    ! $ ./iobroker upgrade mihome-vacuum
    ! Update mihome-vacuum from @0.6.0 to @1.1.0
    ! NPM version: 5.7.1
    ! npm install iobroker.mihome-vacuum@1.1.0 –production --save --prefix "/opt/iobroker" (System call)
    ! npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.mihome-vacuum"
    ! npm
    ! notice created a lockfile as package-lock.json. You should commit this file.
    ! got /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin
    ! upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
    ! ERROR: /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:431 target[attr] = additional[attr];
    ! TypeError: Cannot create property 'en' on string 'This adapter allows control Xiaomi vacuum cleaner'
    ! at extendCommon (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:431:34)
    ! at extendCommon (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:434:21)
    ! at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:487:64)
    ! at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
    ! at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    ! at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15)
    ! at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    ! at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
    ! at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15)
    ! at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:134:20)
    ! ERROR: process exited with code 1</anonymous></anonymous></anonymous>
    Ist das jetzt schlimm oder in Ordnung/gewollt so?? :)
    JS-Controller: v.1.4.0
    Danke und Grüße, Thorsten
    • BluefoxB Offline
      BluefoxB Offline
      Node.JS 4 oder 6?
      • K Offline
        Kueppert
        Node.js 6.13.1
        • Espace0401E Offline
          Espace0401E Offline
          Espace0401
          Bei mir das gleiche!!!! Habe es aber erstmal nur auf meinem Reserve System ausprobiert. Nach dem aktualisieren wird dann aber die Version 1.1.0 angezeigt.
          Iobroker in LXC-Container auf Proxmox 8 - Sicherung auf PBS - Homematic CCU2 - Netatmo Wetterstation und Thermostat
          • dslraserD Offline
            dslraserD Offline
            dslraser
            normales Update schlägt bei mir auch fehl.
            Über URL (GitHub) lief das Update sauber durch.
            das stand im Log
            ! iobroker 2018-04-11 21:00:04.193 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:134:20)
            ! iobroker 2018-04-11 21:00:04.193 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15)
            ! iobroker 2018-04-11 21:00:04.193 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
            ! iobroker 2018-04-11 21:00:04.193 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
            ! iobroker 2018-04-11 21:00:04.193 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-bind/index.js:21:15)
            ! iobroker 2018-04-11 21:00:04.193 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
            ! iobroker 2018-04-11 21:00:04.193 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
            ! iobroker 2018-04-11 21:00:04.193 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:487:64)
            ! iobroker 2018-04-11 21:00:04.193 error at extendCommon (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:434:21)
            ! iobroker 2018-04-11 21:00:04.193 error at extendCommon (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:431:34)
            ! iobroker 2018-04-11 21:00:04.193 error TypeError: Cannot create property 'en' on string 'This adapter allows control Xiaomi vacuum cleaner'
            ! iobroker 2018-04-11 21:00:04.193 error ^
            ! iobroker 2018-04-11 21:00:04.193 error /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:431 target[attr] = additional[attr];
            • apollon77A Offline
              Legt bitte mal ein GitHub Issue beim Adapter dafür an, Danke
              • K Offline
                Kueppert
                @apollon77:
                Legt bitte mal ein GitHub Issue beim Adapter dafür an, Danke ` Erledigt
                  Espace0401E Offline
                  Espace0401
                  Mit js-controller Version 1.4.2 gab es beim Update keine Fehlermeldung mehr.
                  Gruss Joachim
