  4. Xiaomi Philips Bulb einbinden
64 Beiträge 20 Kommentatoren 13.8k Aufrufe 6 Beobachtet
    Smitkas
    for zhirui downlight
    All your need:
    php-miio-master and node-red-contrib-string (google please)
    sudo apt-get install php
    then copy library on PI
    php /home/dom/php-miio-master/miio-cli.php –discover all
    on/off
    php /home/pi/php-miio-master/miio-cli.php --ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"set_power","params":["on"]}'
    php /home/pi/php-miio-master/miio-cli.php –ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"set_power","params":["off"]}'
    toggle
    php /home/pi/php-miio-master/miio-cli.php –ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"toggle",,"params":[]}'
    brightness (from 1 to 100)
    php /home/pi/php-miio-master/miio-cli.php --ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"set_bright","params":[1]}'
    color (1-yellow, 100 – white)
    php /home/pi/php-miio-master/miio-cli.php –ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"set_cct","params":[100]}'
    scenes (from 1 to 4)
    php /home/pi/php-miio-master/miio-cli.php –ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"apply_fixed_scene","params":[1]}'
    status
    php /home/pi/php-miio-master/miio-cli.php –ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"get_prop","params":["power","bright", ,"cct","snm","dv"]}'
    Code
    ! "id": "8d7ab50b.086a48",
    ! "type": "tab",
    ! "label": "Flow 3",
    ! "disabled": false,
    ! "info": ""
    ! "id": "1199f0d9.331b1f",
    ! "type": "ioBroker in",
    ! "z": "8d7ab50b.086a48",
    ! "name": "First button pressed",
    ! "topic": "mihome.0.devices.86sw2_158d000233827e.channel_0",
    ! "payloadType": "value",
    ! "onlyack": "",
    ! "func": "all",
    ! "gap": "",
    ! "x": 170,
    ! "y": 180,
    ! "wires": [
    ! "82596561.899ce8"
    ! "id": "dc776a4c.fbd218",
    ! "type": "inject",
    ! "name": "Button",
    ! "topic": "",
    ! "payload": "true",
    ! "payloadType": "str",
    ! "repeat": "",
    ! "crontab": "",
    ! "once": false,
    ! "onceDelay": 0.1,
    ! "x": 150,
    ! "y": 400,
    ! "wires": [
    ! "345c5f57.38ca6"
    ! "id": "345c5f57.38ca6",
    ! "type": "switch",
    ! "name": "only true",
    ! "property": "payload",
    ! "propertyType": "msg",
    ! "rules": [
    ! "t": "eq",
    ! "v": "true",
    ! "vt": "str"
    ! "checkall": "true",
    ! "repair": false,
    ! "outputs": 1,
    ! "x": 280,
    ! "y": 320,
    ! "wires": [
    ! "b643cffa.5e1ac",
    ! "b1c46b43.e444d8"
    ! "id": "78dad649.35d498",
    ! "type": "switch",
    ! "name": "Is Light On?",
    ! "property": "STAT1",
    ! "propertyType": "flow",
    ! "rules": [
    ! "t": "eq",
    ! "v": "false",
    ! "vt": "str"
    ! "t": "eq",
    ! "v": "true",
    ! "vt": "str"
    ! "repair": false,
    ! "outputs": 2,
    ! "x": 530,
    ! "y": 320,
    ! "wires": [
    ! "66ee6bc9.126594"
    ! "10645dc0.7ac9e2"
    ! "id": "66ee6bc9.126594",
    ! "type": "change",
    ! "name": "PowerOn Lamp",
    ! "rules": [
    ! "t": "set",
    ! "p": "payload",
    ! "pt": "msg",
    ! "to": "true",
    ! "tot": "bool"
    ! "action": "",
    ! "property": "",
    ! "from": "",
    ! "to": "",
    ! "reg": false,
    ! "x": 800,
    ! "y": 280,
    ! "wires": [
    ! "64e1cf4e.ec14a"
    ! "id": "10645dc0.7ac9e2",
    ! "type": "change",
    ! "name": "PowerOff Lamp",
    ! "rules": [
    ! "t": "set",
    ! "p": "payload",
    ! "pt": "msg",
    ! "to": "true",
    ! "tot": "bool"
    ! "action": "",
    ! "property": "",
    ! "from": "",
    ! "to": "",
    ! "reg": false,
    ! "x": 800,
    ! "y": 340,
    ! "wires": [
    ! "f262cc14.faa8e"
    ! "id": "9a8e714.224659",
    ! "type": "exec",
    ! "command": "php /home/pi/php-miio-master/miio-cli.php –ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"set_power","params":["off"]}'",
    ! "addpay": true,
    ! "append": "",
    ! "useSpawn": "false",
    ! "timer": "",
    ! "oldrc": false,
    ! "name": "",
    ! "x": 780,
    ! "y": 1080,
    ! "wires": [
    ! "id": "bec64fe2.71292",
    ! "type": "exec",
    ! "command": "php /home/pi/php-miio-master/miio-cli.php –ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"set_power","params":["on"]}'",
    ! "addpay": true,
    ! "append": "",
    ! "timer": "",
    ! "oldrc": false,
    ! "name": "power on",
    ! "x": 1060,
    ! "y": 260,
    ! "wires": [
    ! "id": "7c0af08b.0c659",
    ! "type": "switch",
    ! "name": "STAT1",
    ! "rules": [
    ! "t": "cont",
    ! "v": "true",
    ! "vt": "str"
    ! "t": "cont",
    ! "v": "false",
    ! "vt": "str"
    ! "checkall": "false",
    ! "repair": false,
    ! "outputs": 2,
    ! "x": 830,
    ! "y": 160,
    ! "wires": [
    ! "8a2dac90.3ca8c"
    ! "ed111c41.dcf5"
    ! "id": "8a2dac90.3ca8c",
    ! "type": "change",
    ! "name": "Light On",
    ! "rules": [
    ! "t": "set",
    ! "p": "STAT1",
    ! "pt": "flow",
    ! "to": "true",
    ! "tot": "str"
    ! "action": "",
    ! "property": "",
    ! "from": "",
    ! "to": "",
    ! "reg": false,
    ! "x": 1040,
    ! "y": 140,
    ! "wires": [
    ! "id": "ed111c41.dcf5",
    ! "type": "change",
    ! "name": "Light Off",
    ! "rules": [
    ! "t": "set",
    ! "p": "STAT1",
    ! "pt": "flow",
    ! "to": "false",
    ! "tot": "str"
    ! "action": "",
    ! "property": "",
    ! "from": "",
    ! "to": "",
    ! "reg": false,
    ! "x": 1040,
    ! "y": 200,
    ! "wires": [
    ! "id": "b643cffa.5e1ac",
    ! "type": "exec",
    ! "command": "php /home/pi/php-miio-master/miio-cli.php –ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"get_prop","params":["power"]}'",
    ! "addpay": false,
    ! "append": "",
    ! "timer": "",
    ! "oldrc": false,
    ! "name": "Lamp status?",
    ! "x": 480,
    ! "y": 160,
    ! "wires": [
    ! "c1d9f7ec.d097c8"
    ! "id": "81a1c26a.2224b",
    ! "type": "inject",
    ! "name": "Button",
    ! "topic": "",
    ! "repeat": "",
    ! "crontab": "",
    ! "once": false,
    ! "onceDelay": 0.1,
    ! "x": 150,
    ! "y": 120,
    ! "wires": [
    ! "b643cffa.5e1ac"
    ! "id": "c1d9f7ec.d097c8",
    ! "type": "string",
    ! "name": "",
    ! "methods": [
    ! "name": "toString",
    ! "params": []
    ! "name": "between",
    ! "params": [
    ! "type": "str",
    ! "value": "result":[""
    ! "type": "str",
    ! "value": ""],"id""
    ! "params": []
    ! "name": "toBoolean",
    ! "params": []
    ! "prop": "payload",
    ! "propout": "payload",
    ! "object": "msg",
    ! "objectout": "msg",
    ! "x": 690,
    ! "y": 160,
    ! "wires": [
    ! "7c0af08b.0c659"
    ! "id": "34ba9712.3e5b88",
    ! "type": "exec",
    ! "addpay": true,
    ! "append": "",
    ! "timer": "",
    ! "oldrc": false,
    ! "name": "power off",
    ! "x": 1060,
    ! "y": 340,
    ! "wires": [
    ! "id": "f262cc14.faa8e",
    ! "type": "delay",
    ! "name": "",
    ! "pauseType": "delay",
    ! "timeout": "1400",
    ! "timeoutUnits": "milliseconds",
    ! "rate": "1",
    ! "nbRateUnits": "1",
    ! "rateUnits": "second",
    ! "randomFirst": "1",
    ! "randomLast": "5",
    ! "randomUnits": "seconds",
    ! "drop": false,
    ! "x": 820,
    ! "y": 400,
    ! "wires": [
    ! "34ba9712.3e5b88"
    ! "id": "64e1cf4e.ec14a",
    ! "type": "delay",
    ! "name": "",
    ! "rate": "1",
    ! "drop": false,
    ! "x": 800,
    ! "y": 220,
    ! "wires": [
    ! "bec64fe2.71292"
    ! "id": "b1c46b43.e444d8",
    ! "type": "delay",
    ! "name": "",
    ! "rate": "1",
    ! "drop": false,
    ! "x": 540,
    ! "y": 240,
    ! "wires": [
    ! "78dad649.35d498"
    ! "id": "82596561.899ce8",
    ! "type": "trigger",
    ! "op1": "true",
    ! "op2": "",
    ! "op1type": "str",
    ! "op2type": "nul",
    ! "duration": "5300",
    ! "extend": false,
    ! "units": "ms",
    ! "reset": "",
    ! "bytopic": "all",
    ! "name": "",
    ! "x": 240,
    ! "y": 260,
    ! "wires": [
    ! "345c5f57.38ca6"
    • crunchipC Offline
      crunchipC Offline
      miio wusste ich, aber node red habe ich gar nicht, kenn ich mich auch nicht mit aus
        SvensonLF
        @crunchip:
        ich bekomm die lampen gar nicht erst in Iobroker angezeigt, wie habt ihr das gemacht? `
        Hi!
        ja zuerst habe ich im ioBroker folgende repo installiert https://github.com/kirovilya/ioBroker.miio
        Im Anschluss kannst du im Adapter über das + Symbol die Lampe mit der IP und dem Token eintragen.
        Es wird mir leider nur der Status der Lampe angezeigt bzw. Connected aber mehr auch nicht…
          Seb007
          Hi!
          Bei mir genau gleich. Leider auch nur der Status. Habe bisher keine Lösung hinbekommen.
            SvensonLF
            Geht mir leider nicht anders… Wird wohl auf einen zweiten Pi rauslaufen mit Home Assistant
            • CookiemonsterC Offline
              Cookiemonster
              Hat denn jemand inzwischen rausgefunden, ob man die Lampe einbinden kann?
              Ich bin kurz davor vier von den Decken-Einbau-Lampe zu kaufen…
              https://www.gearbest.com/ceiling-lights/pp_1830509.html
              Wenn die in der MiHome App gesteuert werden kann, kann ich nicht davon ausgehen, dass der MiHome Adapter das auch findet/unterstützt?
              Hat das jemand ausprobieren können?
              Andere Frage: Falls es nicht klappt, kann die Lampe einfach via Power (normaler Lichtschalter) ein und ausgeschaltet werden? Dann wäre der Kauf im Zweifel nicht ganz für den Bobbes... ;-)
              VG!
              Jan
                Ich bräuchte leider immer noch Hilfe.
                das miio paket hab ich installiert und Token der Philips ZhiRui https://de.gearbest.com/ceiling-lights/ … tWEALw_wcB ausgelesen.
                Jedoch weiss ich noch immer nicht mit welchem Adapter ich nun die Lampen zum laufen bringen soll bzw ansprechen kann.
                Im Xiaomi MiHome Adapter werden sie ja nicht gelistet, mit dem Xiaomi Desk Lamp Adapter funktioniert es nicht und mit dem Yeelight Adapter bekomm ich es auch nicht zum laufen.
                Gruss
                Cookiemonster
                @crunchip said in Xiaomi Philips Bulb einbinden:
                Gruss
                Hey!
                Inzwischen wird die Lampe in der MiHome App gelistet - sollte die Lampe dann nicht auch durch den MiHome Adapter in ioBroker auftauchen? (Steuerung dann also via Adapter über das Xiaomi Gateway)
                Ich hab die Lampe leider nicht, sonst könnte ich es ausprobieren.
                • AtomicIXA Offline
                  AtomicIXA Offline
                  AtomicIX
                  schrieb am zuletzt editiert von AtomicIX
                  Dieser Beitrag wurde gelöscht!
                  • H Offline
                    Hohenbostler
                    Hallo zusammen.
                    Gibt es hier mittlerweile was neues ob es machbar ist die Lampen mit dem iobroker zu verbinden ??
                    Danke für die Hilfe.
                      SvensonLF
                      schrieb am zuletzt editiert von SvensonLF
                      Es läuft endlich ohne Probleme oder großen Aufwand!
                      Einfach den Adapter installieren und die Lampen einpflegen Xiaomi miIO protocol device
                      • S SvensonLF
                        crunchipC Offline
                        crunchipC Offline
                        @SvensonLF den Adapter gibts doch schon länger, hatte aber bisher nicht funktioniert, oder sprechen wir von verschiedenen Lampen?
                        • H Offline
                          Hohenbostler
                          Ich glaube ihr zwei redet von unterschiedlichen Adaptern.
                          Der link von weiter oben ist für die Stehtischlampe
                          Wir suchen aber alle einen Adapter für die Einbauspots ;)
                          • crunchipC Offline
                            crunchipC Offline
                            Ich rede von Philips ZhiRui Deckenstrahler
                            aber gibt ja den Xiaomi miIO protocol device Adapter
                            muss die Tage meine Lampen mal wieder anschliessen und sehn ob die damit laufen.
                              SvensonLF
                              ich rede auch von den Spots habe 9 Stück in meiner Dachuntersicht verbaut und die laufen Top!
                              Ach Scheisse sorry ich habe den falschen Link reingesetzt... Es ging natürlich um diesen Adapter "Xiaomi miIO protocol device"
                              Bildschirmfoto 2019-04-14 um 15.08.25.png Bildschirmfoto 2019-04-14 um 15.09.45.png
                              H 2 Antworten Letzte Antwort
                              • S SvensonLF
                                Hohenbostler
                                @SvensonLF sagte in Xiaomi Philips Bulb einbinden:
                                Und wie genau bist du vor gegangen ? Wo hast du das Zeichen her ?
                                  SvensonLF
                                  Auf die Idee bin ich durch das Einbinden des Saugroboters gekommen und habe einfach Spasshalber die Token als Schlüssel verwendet ;)
                                  Ich habe mir diese App Xiaomi Home 5.5.6 von einem Russischen Programmierer geladen und per BlueStacks installiert, da ich zu dem Zeitpunkt noch kein Android nutzer war.
                                  Dort kannst du dann über die abgeänderte Xiaomi App die Token auslesen und als Schlüssel eintragen.
                                  Den Token findest du über antippen der Lampe und dort auf die ... klicken.
                                  Allgemeine Einstellungen und Netzwerkinformationen
                                  • H Offline
                                    Hohenbostler
                                    Kannst du mir die apk evtl hier. Zur Verfügung stellen ??
                                    Ich habe mir die Version 5.5.6 von apkmirror geladen . Von deinem Link darf ich sie aus meinem Land nicht laden.
                                    Mit meiner Version sehe ich den token leider nicht.
                                    • H Hohenbostler
                                      crunchipC Offline
                                      crunchipC Offline
                                      @Hohenbostler npm install -g miio
                                      deinen rechner mit der Lampe verbinden
                                      miio discover
                                      und schon haste den Token
                                      • H Offline
                                        Hohenbostler
                                        schrieb am zuletzt editiert von Hohenbostler
                                        Ja ich habe die App jetzt gefunden. Bzw sie wurde mir zugeschickt.
                                        MiHome_5.3.19_vevs.apk:
                                        https://boehling.myds.me:5001/sharing/brsrgvq1Y
                                        Hier der Downloadlink
                                        Das PW lautet iobroker
                                        edit 2 Jahre später. Anscheinend geht es auch mit den alten versionen der Mihome apk nicht mehr. Entsprechend habe ich über umwegen den token extractor gefunden und es damit gelöst : Hier ist der dl Link: http://gofile.me/4g7JB/Mys5o4MLz
                                          SvensonLF
                                          Sorry ich war bis eben unterwegs, sonst hätte ich dir die APK besorgt.
                                          Nicht vergessen... solltest du die Lampe aus deiner APP entfernen und neu hinzufügen, ändert sich auch der Token. Dieser wird immer bei der Einrichtung neu vergeben. Also wenn du sie in deiner APP verbunden hast, lass sie dort ;)
