  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер ioBroker Admin
89 Beiträge 18 Kommentatoren 37.0k Aufrufe 1 Beobachtet
  • L Offline
    Lstt
    Не могу обновить до версии 0.5.9
    Javascript/Coffescript Script Engine до версии 0.5.5.
    ioBroker Visualisation до версии 6.1.3
    ЧТо сделать?
    ! admin-0 2015-08-27 20:50:02 info received all objects admin-0 2015-08-27 20:50:02 info received all states admin-0 2015-08-27 20:50:02 info Use link "http://localhost:8081" to configure. admin-0 2015-08-27 20:50:02 info http server listening on port 8081 admin-0 2015-08-27 20:50:02 info requesting all objects admin-0 2015-08-27 20:50:02 info requesting all states admin-0 2015-08-27 20:50:02 info starting. Version 0.5.8 in C:/Program Files/ioBroker/node_modules/iobroker.admin mqtt-1 2015-08-27 20:50:01 info Server publishes "mqtt.1.Temperature05": 25.87 host-SERVER 2015-08-27 20:50:01 info instance system.adapter.admin.0 started with pid 3576 mqtt-1 2015-08-27 20:50:00 info Server publishes "mqtt.1.Temperature04": 26.06 iobroker 2015-08-27 20:49:59 info exit 0 iobroker 2015-08-27 20:49:59 info Adapter "admin" updated iobroker 2015-08-27 20:49:59 info upload [0] admin.admin C:/Program Files/ioBroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png iobroker 2015-08-27 20:49:59 info upload [1] admin.admin C:/Program Files/ioBroker/node_modules/iobroker.admin/admin/index.html index.html text/html host-SERVER 2015-08-27 20:49:59 info Restart adapter system.adapter.admin.0 because enabled host-SERVER 2015-08-27 20:49:59 warn instance system.adapter.admin.0 terminated due to SIGTERM host-SERVER 2015-08-27 20:49:59 info stopInstance system.adapter.admin.0 killing pid 3624 host-SERVER 2015-08-27 20:49:59 info stopInstance system.adapter.admin.0 host-SERVER 2015-08-27 20:49:59 info object change system.adapter.admin.0 iobroker 2015-08-27 20:49:59 info got C:/Program Files/ioBroker/node_modules/iobroker.admin/admin mqtt-1 2015-08-27 20:49:58 info Server publishes "mqtt.1.Temperature03": 25.69 iobroker 2015-08-27 20:49:58 info npm install --production --prefix "C:/Program Files/ioBroker/node_modules/iobroker.admin" (System call) mqtt-1 2015-08-27 20:49:57 info Server publishes "mqtt.1.Temperature02": 25.69 iobroker 2015-08-27 20:49:56 info WARN optional dep failed, continuing bufferutil@1.1.0 iobroker 2015-08-27 20:49:56 info WARN optional dep failed, continuing utf-8-validate@1.1.0npm iobroker 2015-08-27 20:49:56 info npm iobroker 2015-08-27 20:49:56 info ERR! not ok iobroker 2015-08-27 20:49:56 info gyp iobroker 2015-08-27 20:49:56 info ERR! node -v v0.12.7gyp ERR! node-gyp -v v2.0.1 iobroker 2015-08-27 20:49:56 info gyp iobroker 2015-08-27 20:49:56 info gyp ERR! command "node" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\Program Files\ioBroker\node_modules\node_modules\iobroker.adm iobroker 2015-08-27 20:49:56 info iobroker 2015-08-27 20:49:56 info at FSReqWrap.oncomplete (evalmachine.:95:15)gyp ERR! System Windows_NT 6.3.9600 iobroker 2015-08-27 20:49:56 info gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:69:11gyp ERR! stack iobroker 2015-08-27 20:49:56 info gyp ERR! stack at failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:114:14) iobroker 2015-08-27 20:49:56 info gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable. iobroker 2015-08-27 20:49:56 info iobroker 2015-08-27 20:49:56 info ERR! configure error iobroker 2015-08-27 20:49:56 info iobroker 2015-08-27 20:49:56 info gyp iobroker 2015-08-27 20:49:56 info ERR! not ok iobroker 2015-08-27 20:49:56 info gyp iobroker 2015-08-27 20:49:56 info node-gyp -v v2.0.1 iobroker 2015-08-27 20:49:56 info ERR! iobroker 2015-08-27 20:49:56 info gyp iobroker 2015-08-27 20:49:56 info node -v v0.12.7 iobroker 2015-08-27 20:49:56 info ERR! iobroker 2015-08-27 20:49:56 info iobroker 2015-08-27 20:49:56 info C:\Program Files\ioBroker\node_modules\node_modules\iobroker.admin\node_modules\socket.io\node_modules\socket.io-client\node_modules\engine.io-client\node_modules\ws\node_modules\utf-8-validategyp iobroker 2015-08-27 20:49:56 info ERR! cwd iobroker 2015-08-27 20:49:56 info gyp iobroker 2015-08-27 20:49:56 info ERR! command "node" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild" iobroker 2015-08-27 20:49:56 info iobroker 2015-08-27 20:49:56 info gyp iobroker 2015-08-27 20:49:56 info Windows_NT 6.3.9600 iobroker 2015-08-27 20:49:56 info gyp ERR! System iobroker 2015-08-27 20:49:56 info at FSReqWrap.oncomplete (evalmachine.:95:15) iobroker 2015-08-27 20:49:56 info gyp ERR! stack iobroker 2015-08-27 20:49:56 info at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:69:11 iobroker 2015-08-27 20:49:56 info stack iobroker 2015-08-27 20:49:56 info ERR! iobroker 2015-08-27 20:49:56 info gyp iobroker 2015-08-27 20:49:56 info at failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:114:14) iobroker 2015-08-27 20:49:56 info stack iobroker 2015-08-27 20:49:56 info iobroker 2015-08-27 20:49:56 info ERR! iobroker 2015-08-27 20:49:56 info iobroker 2015-08-27 20:49:56 info gyp iobroker 2015-08-27 20:49:56 info Error: Can't find Python executable "python", you can set the PYTHON env variable. iobroker 2015-08-27 20:49:56 info stack iobroker 2015-08-27 20:49:56 info iobroker 2015-08-27 20:49:56 info ERR! iobroker 2015-08-27 20:49:56 info gyp iobroker 2015-08-27 20:49:56 info configure error iobroker 2015-08-27 20:49:56 info ERR! iobroker 2015-08-27 20:49:56 info iobroker 2015-08-27 20:49:56 info gyp mqtt-1 2015-08-27 20:49:56 info Server publishes "mqtt.1.Temperature01": 25.69 iobroker 2015-08-27 20:49:53 info npm WARN optional dep failed, continuing bufferutil@1.1.0 iobroker 2015-08-27 20:49:53 info WARN optional dep failed, continuing utf-8-validate@1.1.0 iobroker 2015-08-27 20:49:53 info iobroker 2015-08-27 20:49:53 info npm iobroker 2015-08-27 20:49:53 info iobroker 2015-08-27 20:49:53 info node-gyp -v v2.0.1gyp ERR! not ok iobroker 2015-08-27 20:49:53 info node -v v0.12.7gyp ERR! iobroker 2015-08-27 20:49:53 info ERR! cwd C:\Program Files\ioBroker\node_modules\node_modules\iobroker.admin\node_modules\socket.io\node_modules\engine.io\node_modules\ws\node_modules\bufferutilgyp ERR! iobroker 2015-08-27 20:49:53 info iobroker 2015-08-27 20:49:53 info gyp iobroker 2015-08-27 20:49:53 info ERR! command "node" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild" iobroker 2015-08-27 20:49:53 info gyp iobroker 2015-08-27 20:49:53 info Windows_NT 6.3.9600 iobroker 2015-08-27 20:49:53 info System iobroker 2015-08-27 20:49:53 info ERR! iobroker 2015-08-27 20:49:53 info iobroker 2015-08-27 20:49:53 info gyp iobroker 2015-08-27 20:49:53 info at FSReqWrap.oncomplete (evalmachine.:95:15) iobroker 2015-08-27 20:49:53 info stack iobroker 2015-08-27 20:49:53 info ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:69:11gyp ERR! iobroker 2015-08-27 20:49:53 info iobroker 2015-08-27 20:49:53 info at failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:114:14)gyp iobroker 2015-08-27 20:49:53 info stack iobroker 2015-08-27 20:49:53 info iobroker 2015-08-27 20:49:53 info ERR! iobroker 2015-08-27 20:49:53 info gyp iobroker 2015-08-27 20:49:53 info Error: Can't find Python executable "python", you can set the PYTHON env variable. iobroker 2015-08-27 20:49:53 info stack iobroker 2015-08-27 20:49:53 info iobroker 2015-08-27 20:49:53 info ERR! iobroker 2015-08-27 20:49:53 info gyp iobroker 2015-08-27 20:49:53 info configure error iobroker 2015-08-27 20:49:53 info ERR! iobroker 2015-08-27 20:49:53 info iobroker 2015-08-27 20:49:53 info gyp iobroker 2015-08-27 20:49:53 info iobroker 2015-08-27 20:49:53 info node-gyp -v v2.0.1gyp ERR! not ok iobroker 2015-08-27 20:49:53 info gyp ERR! iobroker 2015-08-27 20:49:53 info gyp ERR! node -v v0.12.7 iobroker 2015-08-27 20:49:53 info ERR! command "node" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\Program Files\ioBroker\node_modules\node_modules\iobroker.admin\ iobroker 2015-08-27 20:49:53 info gyp ERR! System Windows_NT 6.3.9600gyp iobroker 2015-08-27 20:49:53 info gyp ERR! stack at FSReqWrap.oncomplete (evalmachine.:95:15) iobroker 2015-08-27 20:49:53 info iobroker 2015-08-27 20:49:53 info stack at failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:114:14)gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp iobroker 2015-08-27 20:49:53 info ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR! iobroker 2015-08-27 20:49:53 info gyp iobroker 2015-08-27 20:49:53 info ERR! configure error iobroker 2015-08-27 20:49:53 info iobroker 2015-08-27 20:49:53 info gyp iobroker 2015-08-27 20:49:47 info npm install iobroker.admin --production --prefix "C:/Program Files/ioBroker/node_modules" (System call) !
    • I Offline
      I Offline
      instalator
      @Lstt:
      ЧТо сделать? `
      Сервер обновил?, вкладка серверы. И похоже node.js 0.12 версии стоит. Поставь 0.10.25
      Высокий уровень Децибел вреден для здоровья!
      http://blog.instalator.ru/
      • L Offline
        Lstt
        @instalator:
        @Lstt:
        ЧТо сделать? Сервер обновил?, вкладка серверы. И похоже node.js 0.12 версии стоит. Поставь 0.10.25
        Спасибо огромное! Всё заработало именно после смены node.js на указанную версию..!
        • I Offline
          I Offline
          instalator
          Обновил Admin до 0.5.12 на вкладке Скриты вечнаяя загрузка и окно выглядит так:
          • aurodionovA Offline
            aurodionovA Offline
            aurodionov
            @instalator:
            Обновил Admin до 0.5.12 на вкладке Скриты вечнаяя загрузка и окно выглядит так: `
            Подтверждаю, аналогичная ситуация.
            Пишу с пульта….
            • BluefoxB Offline
              BluefoxB Offline
              Обновил. Надо обновить admin и javascript
                aurodionovA Offline
                aurodionov
                "Апнул" до последних версий , всё появилось, спасибо.
                Пишу с пульта….
                • I Offline
                  I Offline
                  instalator
                  Сегодня в админке наблюдаю такое:
                  host-Server-PC 2015-11-02 23:35:43 warn warning: Following packages cannot be read: wolf
                  • BluefoxB Offline
                    BluefoxB Offline
                    Да. Разработчик, что то напутал. Немцы тоже ругались. Думаю сегодня починит.
                    • BluefoxB Offline
                      BluefoxB Offline
                      Кстати уже починил.
                      • I Offline
                        I Offline
                        instalator
                        В админке всегда такое когда работает торрент, на компе с которого захожу на страницу.
                        Скорость инета до Франкфурта с активным торрентом
                        Добавлено:
                        Вот что в логе:
                        ! Server-PC 2015-11-04 18:25:15 warn host.Server-PC warning: Looks like there is no internet.
                        ! Server-PC 2015-11-04 18:25:04 info host.Server-PC Update repository "default" under "conf/sources-dist.json"
                        ! Server-PC 2015-11-04 18:09:14 warn host.Server-PC warning: Looks like there is no internet.
                        ! Server-PC 2015-11-04 18:09:04 info host.Server-PC Update repository "default" under "conf/sources-dist.json"
                        ! Server-PC 2015-11-04 18:08:55 warn host.Server-PC warning: Looks like there is no internet.
                        ! Server-PC 2015-11-04 18:08:54 warn host.Server-PC warning: Looks like there is no internet.
                        ! Server-PC 2015-11-04 18:08:44 info host.Server-PC Update repository "default" under "conf/sources-dist.json"
                        ! Server-PC 2015-11-04 18:02:13 info host.Server-PC Update repository "default" under "conf/sources-dist.json"
                        • V Offline
                          V Offline
                          vtec
                          У меня такая же фигня, кода на работе хреновый интернет или отсутствует.
                          Как ты это лечишь?
                          • I Offline
                            I Offline
                            instalator
                            @vtec:
                            Как ты это лечишь? `
                            выключаю торрент)
                            • I Offline
                              I Offline
                              instalator
                              Проблемы с Категориями
                              После добавления категории не доступна кнопка добавления переменных в список.
                              Кнопка появляется если нажать редактирование, потом сохранить, имя категории при этом меняется (было enum.спальня стало спальня).
                              После обновления странички имена у категории снова меняются (добавляется в начале enum.) и кнопки добавления снова исчезают
                              • BluefoxB Offline
                                BluefoxB Offline
                                @instalator:
                                filename="hgfgfg.png" index="1">~~ `
                                Да. это баг с переименованием, но F5 решит проблему.
                                Другая проблема в том, что категории должны быть двух-уровневые. То есть нельзя создавать enums.кухня.
                                Надо создать сначала enums.комнаты, потом enums.комнаты.кухня и туда уже добавлять устройства.
                                • I Offline
                                  I Offline
                                  instalator
                                  @instalator:
                                  filename="yuy.png" index="1">~~
                                  filename="jyt.png" index="0">~~
                                  Добавлено:
                                  Вот что в логе:
                                  ! Server-PC 2015-11-04 18:02:13 info host.Server-PC Update repository "default" under "conf/sources-dist.json" `
                                  Нашлось время занятся этим вопросом.
                                  Вообщем сделал на маршутизаторе проброс портов для utorrentа, полет нормальный.
                                    aurodionovA Offline
                                    aurodionov
                                    @instalator:
                                    @instalator:
                                    Добавлено:
                                    Вот что в логе:
                                    Вообщем сделал на маршутизаторе проброс портов для utorrentа, полет нормальный. `
                                    Тоесть проблема была в роутере, нехватало ресурсов(мощности ) для нормальной работы сети.
                                    У меня подобное наблюдается, после замены микротика на д-линк, не вывозит, постоянно виснет, при этом рассыпается часть сети
                                    Пишу с пульта….
                                    • I Offline
                                      I Offline
                                      instalator
                                      @aurodionov:
                                      @instalator:
                                      @instalator:
                                      Добавлено:
                                      Вот что в логе:
                                      У меня подобное наблюдается, после замены микротика на д-линк, не вывозит, постоянно виснет, при этом рассыпается часть сети `
                                      У меня маршрутизатор не виснет (asus 66), я думаю из-за брандмауэра на маршрутизаторе.
                                      • I Offline
                                        I Offline
                                        instalator
                                        Нужно что то делать с аутентификацией, браузер не запоминает пароль и не сохраняется сессия, приходится каждый раз вводить пароль, особенно неудобно это в виз. Может время куки увеличить если она пишется вообще.
                                        • L Offline
                                          Lstt
                                          Задам, возможно, нубский вопрос…Как визуально, не через Javascript, во вкладке "Объекты" создать вручную не сами объекты, а группу, в которой уже произвольно можно создать объект...Не понял, есть ли такая возможность? Или там объекты группируются только через категории enum?
