  4. Homematic IP Heizkörperthermostate
    6.0k
65 Beiträge 17 Kommentatoren 18.0k Aufrufe 19 Beobachtet
  • RöstkartoffelR Röstkartoffel
    @Alero
    Ich habe das Widget jetzt nochmal exportiert, teste das mal bitte:
    [{"tpl":"tplValueFloatBar","data":{"oid":"hm-rpc.3.00039709xxxxxx.1.LEVEL","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","min":"0","max":"1.005","orientation":"horizontal","color":"{v:hm-rpc.3.00039709xxxxxx.1.LEVEL;v < 0.5 ? \"#FDEE00\" :: v < 0.7 ? \"#FFA500\" :: \"#FF0000\"}","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"name":"Ventilstellung","g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"reverse":false},"style":{"left":"330px","top":"272px","width":"200px","height":"10px","z-index":"3"},"widgetSet":"basic"}]
    Alero
    schrieb am zuletzt editiert von Alero
    #41
    @Röstkartoffel
    Hi, habe es importiert. Danke noch mal dafür.
    Nicht das ich hier was falsch verstehe. Der Balken ist doch dafür da um die Position des Ventils anzuzeigen, oder?
    Heisst, wenn ich auf 30 Grad gehe, sollte der Balken gelb oder sogar rot werden.
    Richtig?
    Alero
    RöstkartoffelR 1 Antwort Letzte Antwort
    • A Alero
      @Röstkartoffel
      Richtig?
      Alero
      RöstkartoffelR Offline
      Röstkartoffel
      #42
      @Alero
      Ja. Aber ... die Übertragung der Daten vom Thermostat zu ioBroker kann aber einige Minuten dauern.
      Du kannst auch über die VIS den Boost auslösen, dann sollte gleich was zu sehen sein. Oder du kannst den Datenpunkt "hm-rpc.3.00039709xxxxxx.1.LEVEL" von Hand ändern und bestätigen und in der VIS siehst du dann den farbigen Balken.
      NUC7i3BNH mit Proxmox und ioBroker (VM Debian Buster), Raspi3 (Slave Smartmeter für eHZ easymeter), Hardware CCU2, SMA SB5000TL-21
      A 1 Antwort Letzte Antwort
        @Alero
        Alero
        #43
        @Röstkartoffel
        Hi ,
        Bei Boost sehe ich jetzt auch einen Balken. Ich dachte der Blaken bleibt stehen. Nach dem Boost ist er wieder weg.
        Alero
          Moing
          #44
          Bin gerade auch bei der Einrichtung von HM-IP Thermostaten.
          Widget importiert, die Funktionen sind soweit wie gewühnscht vorhanden.
          Nur bin ich gerade überfragt, in welchen Ordner ich die Icons packen muss?
          Bisher ist durch die Fehlende Anzeige der Adapter nur funktional, aber nicht schön
          • M Moing
            Röstkartoffel
            schrieb am zuletzt editiert von Röstkartoffel
            #45
            @Moing sagte in Homematic IP Heizkörperthermostate:
            /vis.0/main/rot/
            /vis.0/main/weiß/
            main ist der Name meines VIS-Projektes, den musst du auch anpassen.
            Hier findest du den Pfad (Die Ordner weiß und rot musst du selber anlegen):
            Bilder (Icons) bitte mit dem Dateimanager hochladen.
            Wenn du dir die Icons ansehen willst, den Dateimanager aufrufen, den Pfad auswählen und das kleine Dreieck oben rechts anklicken. Damit änderst du den Hintergrund im Dateimanager, da du sonst weiße Symbole auf weißen Hintergrund nicht sehen kannst. 😎
            Das Ganze soll dann so ausehen:
            Ich habe den Fensterstatus geändert, offen ist rot und geschlossen ist jetzt grün.
            Bitte das alte Widget löschen und dieses importieren:
            [{"tpl":"tplMfdWindowBool","data":{"oid":"hm-rpc.4.000A18A996FA89.1.WINDOW_STATE","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","asButton":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"name":"Kinderzimmer klein Window state","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"closed_icon":"","closed_iconColor":"#09f000","opened_iconColor":"#c20000","invert_state":false},"style":{"left":"711px","top":"442px","width":"35px","height":"35px","z-index":"2","background-color":"#323433","border-width":"1px","border-style":"solid","border-color":"gray","border-radius":"5px"},"widgetSet":"jqui-mfd"}]
            • MicM Mic
              Vielen Dank für die Anregungen hier. Ich habe es in meine Visualisierung auch mal so umgesetzt.
              Beispiel:
              Mit Boost (Farben muss ich noch etwas spielen):
              Fenster offen:
              Die unterschiedlichen Widgets hatte ich nicht ganz verstanden. Ich verwende für "Automatik / Manuell" das Widget "jqui - Radiobuttons ValueList" mit entsprechender CSS-Formatierung, daneben für Boost ein Widget ""hqwidgets - On/Off"" (geschaltet auf Datenpunkt hm-rpc.0.xxxxxxxxxx.1.BOOST_MODE). Funktioniert super.
              Die Schaltleiste "Aus / Standard / Urlaub" schaltet die Heizprofile 1-3.
              TJJochenT Offline
              TJJochenT Offline
              TJJochen
              #46
              @Mic sagte in Homematic IP Heizkörperthermostate:
              Beispiel:
              Fenster offen:
              Hey Mic, deine Heizungssteuerung gefällt mir echt gut. Würde diese so in der Art gerne bei mir einsetzen.
              Würdest du das Widget evtl. komplett zur Verfügung stellen?
              Schöne Grüße
              Jochen
              • MicM Offline
                MicM Offline
                Mic
                #47
                Gerne. Hier der rohe Widget-Export. hz_m.txt
                Hier noch CSS zur Anpassung:
                 * Radiobuttons
                /* Zentrieren */
                .micRadiobtnHz table tbody {
                  margin-left: auto;
                  margin-right: auto;
                .micRadiobtnHz *[id*="_radio"] * {
                  padding-top:2px !important;
                  padding-bottom:2px !important;
                  padding-left:4px !important;
                  padding-right:4px !important;
                  font-size:1.1em;
                  font-weight:bold;
                  font-family:"RobotoCondensed-Light";
                .micRadiobtnHz *[id*="_radio"] label {
                  background:none !important;
                  border:none !important;
                  color:rgba(255,255,255,0.87) !important;
                  border-radius:0px;
                  border-bottom:2px solid rgba(0,0,0,0) !important;
                .micRadiobtnHz *[id*="_radio"] label.ui-state-active {
                  border-bottom-color:#D9C300 !important;
                .micRadiobtnHzSmaller *[id*="_radio"] * {
                    font-size:14px !important;
                TJJochenT 1 Antwort Letzte Antwort
                • MicM Mic
                   * Radiobuttons
                  /* Zentrieren */
                    margin-left: auto;
                    margin-right: auto;
                    font-size:1.1em;
                    font-weight:bold;
                    border-radius:0px;
                  TJJochenT Offline
                  TJJochenT Offline
                  TJJochen
                  #48
                  @Mic Vielen Dank :-)
                  • J Offline
                    jwerlsdf
                    schrieb am zuletzt editiert von jwerlsdf
                    #49
                    ich habe das widget oben verbaut. Ich habe aber noch ein paar Fragen/ Probleme:
                    Problem 1: Das icon Flow-Chart ist weiß. Das sollte doch wie bei den anderen einen schwarzen Hintergrund haben (z.B. bei der Batterie).
                    Problem 2: Die Ventilöffnung verschiebt sich irgendwann aus dem Bild weg (s. Bild 1)
                    Verständnisfrage 1: Bei der Batterie müssen doch folgende Werte eingeben werden:
                    Min: 0
                    Max: 1.5
                    Mit den voreingestellten werden (0 & 25.5?) ist das Batteriebild immer auf "leer" Max bedeutet doch 1.5Volt?
                    Verständnisfrage 2: Wann wird der Valve-State (also Batteriewechsel, etc. angezeigt? Bei mir erscheint die Anzeige nicht?!
                    Verständnisfrage 3: Kann ich "live" die Bootsekunden runterzählen lassen? ich muss immer auf aktualisieren klicken, damit er mir den Wert anzeigt.
                    Ich würde mich sehr über Hilfe freuen!
                    RöstkartoffelR E 2 Antworten Letzte Antwort
                    • J jwerlsdf
                      Min: 0
                      Max: 1.5
                      Röstkartoffel
                      #50
                      @jwerlsdf sagte in Homematic IP Heizkörperthermostate:
                      Min: 0
                      Max: 1.5
                      Da der Thermostat mit 2 Stk. Batterien läuft, ist als max-Wert 3 einzutragen.
                      Die Sichtbarkeit ist wahrscheinlich eingestellt. Habe ich zumindest so. Damit erscheint das Feld nicht im Normal-Modus.
                      Das habe ich auch nicht hinbekommen und verzichte daher auf die Anzeige.
                      opossumO 1 Antwort Letzte Antwort
                      • J jwerlsdf
                        Min: 0
                        Max: 1.5
                        eXectiX
                        schrieb am zuletzt editiert von eXectiX
                        #51
                        @jwerlsdf
                        Ja es hat einen schwarzen Hintergrund bei mir!
                        Dieses Problem habe ich auch noch und wäre auch an einer Lösung interessiert!
                          Min: 0
                          Max: 1.5
                          opossumO Offline
                          opossumO Offline
                          opossum
                          schrieb am zuletzt editiert von opossum
                          #52
                          @Röstkartoffel sagte in Homematic IP Heizkörperthermostate:
                          Die Anzeige wird bei mir heruntergezählt. Ich beschreibe mal, was ich da gemacht habe:
                          So sieht das bei mir aus, wenn Boost eingeschaltet ist:
                          Die Anzeige für das Herunterzählen der Boostzeit habe ich wie folgt gebaut:
                          Es sind zwei Widgets übereinander:
                          1. Slider = Basic Bar mit folgenden Einstellungen( eine Ebene tiefer als das zweite Widget):
                          2. Anzeige der Minuten = Basic Number mit folgenden Einstellungen:
                          Die Anzahl der Minuten legt man in der CCU im Gerätemanager fest:
                          Vielleicht hilft es ja, ist allerdings Homematic, kein IP.
                          https://www.schlepper-petersdorf.de
                          • opossumO opossum
                            Röstkartoffel
                            #53
                            @opossum
                            Das mit den VIS war nicht das Problem, sondern der Ablauf scheint bei HMIP anders zu funktionieren.
                            Anscheinend wird nur ca. alle 2 Minuten (bei meinem System) die Rest-Boosttime übermittelt. Zumindest ändert sich der DP nur ca. alle 2 Minuten und das ist für diesen Zweck nicht ausreichend, weil das kein richtiges Runterzählen ist.
                            • opossumO Offline
                              opossumO Offline
                              opossum
                              #54
                              Hallo, @Röstkartoffel,
                              war meine Befürchtung, vielleicht kann man sich hier mit einem Countdown behelfen und den anstarten, wenn ich das Boost auslöse und dessen Angabe in die Anzeige übernehmen? Ich glaube, bei mir wird das auch nur 2minütlich geändert. Ist allerdings auch nur nice to have und nicht sooo wichtig.
                                /vis.0/main/rot/
                                /vis.0/main/weiß/
                                dos1973
                                #55
                                Sorry, das ist absolut offtopic,
                                aber wie hast du denn den Hintergrund im upload Fenster grau eingefärbt?
                                Ich habe auch ein Haufen weißer Icons und suche mir immer einen Wolf...
                                • D dos1973
                                  Röstkartoffel
                                  #56
                                  @dos1973
                                  Bitteschön:
                                    dos1973
                                    #57
                                    @Röstkartoffel
                                    unglaublich, den Button habe ich bisher noch nie wahrgenommen.
                                    Vielen Dank für den Tipp!!!! Der ist Gold wert.
                                    • J Offline
                                      jwerlsdf
                                      #58
                                      würde mir bitte jemand nur den flow-chart zur Verfügung stellen?
                                      L 1 Antwort Letzte Antwort
                                      • J jwerlsdf
                                        luft-post
                                        #59
                                        Moin,
                                        ich weiß altes Thema hier, aber vielleicht schaut ja doch noch jemand rein :-)
                                        Funktional funktioniert bei mir alles super. Nur die Darstellung der Auto/Manu/Boost leiste ist farblich nicht so wie bei euch.
                                        Ich denke mal ich muss noch die CSS von oben einfügen, aber wie?
                                        Unter der Spalte CSS habe ich schon die CSS von Material Design drin, kann ich die andere einfach mit anhängen?
                                        MAtthias
                                        J 1 Antwort Letzte Antwort
                                        • L luft-post
                                          Moin,
                                          MAtthias
                                          jan_xx
                                          #60
                                          @luft-post
                                          Hallo zusammen, ist hier noch leben in dem Beitrag?
                                          Hätte da mal eine Frage zu dem Basic number widget?
                                          Grüße
                                          LongbowL 1 Antwort Letzte Antwort
