  4. Daikin Cloud Adapter nodejs18 [gelöst]
116 Beiträge 7 Kommentatoren 12.3k Aufrufe 6 Beobachtet
  • J JoergH
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     21:58:16 up  9:41,  1 user,  load average: 1.19, 0.92, 1.02
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=51.6'C
    volt=0.9160V
    *** Time and Time Zones ***
                   Local time: Wed 2023-05-24 21:58:17 CEST
               Universal time: Wed 2023-05-24 19:58:17 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        2.4G        4.1G        1.0M        1.3G        5.3G
    Swap:            99M          0B         99M
    Total:          7.9G        2.4G        4.2G
             7811 M total memory
             2446 M used memory
             2593 M active memory
              912 M inactive memory
             4064 M free memory
              131 M buffer memory
             1169 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      118G   11G  103G  10% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
    /dev/sda1      vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
    [Wed May 24 12:16:48 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:F1:62:5F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  usb-storage.quirk=152d:0579:u console=ttyS0,115200 console=tty1 root=PARTUUID=622a00f4-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed May 24 12:16:51 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed May 24 12:16:51 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Wed May 24 12:16:53 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
    6.9G    /var/
    5.3G    /var/log
    4.0G    /var/log/journal/ebf43f1ac9ac40f88ddf4138fee55e47
    929M    /var/lib
    Archived and active journals take up 3.9G in the file system.
    /opt/iobroker/backups:
    93M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    401M    /opt/iobroker/iobroker-data/
    270M    /opt/iobroker/iobroker-data/files
    87M     /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/telegram.admin
    34M     /opt/iobroker/iobroker-data/objects.jsonl
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    9.2M    /opt/iobroker/iobroker-data/states.jsonl
    8.5M    /opt/iobroker/iobroker-data/files/vis.0/Homematic_Steuerung/img/Eigene_Bilder/20180322_153925_HDR.jpg
    7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   3
    Adapter State
      system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
    + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
    + system.adapter.exchangerates.0          : exchangerates         : raspberrypi                              -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
    + system.adapter.firetv.0                 : firetv                : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.go-e.0                   : go-e                  : raspberrypi                              -  enabled
    + system.adapter.ham.0                    : ham                   : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
    + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi                              -  enabled
    + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
      system.adapter.odl.0                    : odl                   : raspberrypi                              -  enabled
      system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
      system.adapter.powerfox2.0              : powerfox2             : raspberrypi                              -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
    + system.adapter.renault.0                : renault               : raspberrypi                              -  enabled
    + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
      system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
    + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.vaillant.0               : vaillant              : raspberrypi                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Adapter    "birthdays"    : 2.2.0    , installed 2.2.0
    Adapter    "daikin-cloud" : 0.2.3    , installed 0.2.3
    Adapter    "denon"        : 1.15.0   , installed 1.15.0
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "exchangerates": 0.0.14   , installed 0.0.14
    Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
    Adapter    "firetv"       : 1.0.0    , installed 1.0.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "go-e"         : 1.0.27   , installed 1.0.27
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "odl"          : 2.0.5    , installed 2.0.5
    Adapter    "openweathermap": 0.3.3   , installed 0.3.3
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
    Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
    Adapter    "renault"      : 0.0.15   , installed 0.0.17
    Adapter    "sayit"        : 1.12.3   , installed 1.12.3
    Adapter    "schoolfree"   : 1.1.1    , installed 1.1.1
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vaillant"     : 0.1.2    , installed 0.1.2
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Objects and States
    Objects:        19935
    States:         15758
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://packages.grafana.com/oss/deb stable InRelease
    Hit:7 https://repos.influxdata.com/debian bullseye InRelease
    Hit:8 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:9 https://apt.pivccu.de/piVCCU stable InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       894933     36776/io.mqtt.0
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      111        15653      831/influxd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12799      937/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       897434     36528/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       895635     36528/iobroker.js-c
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          12188      926/dnsmasq
    tcp        0      0 192.168.178.55:2010     0.0.0.0:*               LISTEN      1001       897012     36846/io.hm-rpc.1
    tcp        0      0 192.168.178.55:2001     0.0.0.0:*               LISTEN      1001       896833     36659/io.hm-rpc.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12801      937/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       900999     37344/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       894640     36549/io.admin.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      111        15662      831/influxd
    tcp6       0      0 :::3000                 :::*                    LISTEN      112        15870      1325/grafana
    udp        0      0 0.0.0.0:51826           0.0.0.0:*                           0          12198      -
    udp        0      0 0.0.0.0:43971           0.0.0.0:*                           108        11970      430/avahi-daemon: r
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          12187      926/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          12184      926/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12633      593/dhclient
    udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       896912     36743/io.mihome-vac
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       897715     36618/io.ham.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11968      430/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       898088     36828/io.shelly.0
    udp6       0      0 :::51826                :::*                                0          12199      -
    udp6       0      0 :::33920                :::*                                108        11971      430/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        11969      430/avahi-daemon: r
    2023-05-24 21:59:24.503  - debug: hm-rpc.1 (36846) hm-rpc.1.001B9BE9A05111.6.LEVEL_STATUS ==> UNIT: "undefined" (min: undefined, max: undefined) From "0" => "0"
    2023-05-24 21:59:24.503  - debug: hm-rpc.1 (36846) xml multicall <event>: raspberrypi:hm-rpc.1:3315ff8b2de0e5e6cb69b5a334400967,001B9BE9A05111:6,LEVEL,0.08
    2023-05-24 21:59:24.503  - debug: hm-rpc.1 (36846) xmlrpc <- event ["raspberrypi:hm-rpc.1:3315ff8b2de0e5e6cb69b5a334400967","001B9BE9A05111:6","LEVEL",0.08]
    2023-05-24 21:59:24.503  - debug: hm-rpc.1 (36846) hm-rpc.1.001B9BE9A05111.6.LEVEL ==> UNIT: "100%" (min: 0, max: 1) From "0.08" => "8"
    2023-05-24 21:59:26.904  - debug: hm-rega.0 (36640) --> polling.fn
    2023-05-24 21:59:26.908  - debug: hm-rega.0 (36640) --> !# polling.fn 1.3 !# !# Dieses Script gibt die Werte aller Systemvariablen als J
    2023-05-24 21:59:26.917  - debug: hm-rega.0 (36640) <-- {"15191":[0,"2023-05-24 12:18:13"],
    "1033":[false,"1970-01-01 01:00:00"],
    "950":[true,"2023-05-24 12:18:14"],
    "7789":["Fensterstatus%20war%20ge%F6ffnet%20","2023-05-24 12:18:13"],
    "1395":[15.000000,"2023-05-24 12:18:13"],
    "16407":[false,"1970-01-01 01:00:00"],
    "10027":[false,"1970-01-01 01:00:00"],
    "40":[0,"2023-05-24 12:18:14"],
    "41":[4,"2023-05-24 21:59:24"]}
    2023-05-24 21:59:30.002  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Zeit seit Anstecken an go-e charger: 563.1808833333333
    2023-05-24 21:59:30.003  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA: 0 A
    2023-05-24 21:59:30.004  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA FINAL: 0 A
    2023-05-24 21:59:30.004  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Ladestrom GO-E: 0 A
    2023-05-24 21:59:30.004  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Ladestrom go-e bei TESLA Prio: 0
    2023-05-24 21:59:30.005  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Überschuss brutto / netto: -5 / -5
    2023-05-24 21:59:30.005  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Gemittelt GO-E: 0 - Restzeit go-e: 00:00
    2023-05-24 21:59:30.006  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: Gemittelt TESLA: 0
    2023-05-24 21:59:30.006  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: 0 - 3033.81 - 0
    2023-05-24 21:59:30.006  - info: javascript.0 (36586) script.js.Energiemanagement.PV_Laden_neu: 0:00
    @joergh
    Sollte eigentlich funktionieren.
    Hier bei mir geht's jedenfalls.
      @joergh
      JoergH
      @thomas-braun @apollon77
      Leider funktioniert es bei mir nach wie vor nicht. Ich kann keine Instanz hinzufügen, weil immer das Fenster aufgeht, dass es mit nodejs 18.x nicht funktioniert.
      • J JoergH
        @joergh Und du hast es gemacht wie auf den screens?
        Admin - Expertenmodus - Adapter - Custom Install/GitHub icon - von GitHub Tab - Adapter wählen - installieren
        • apollon77A apollon77
          JoergH
          @apollon77
          Ja, siehe Screenshot oben.
          Thomas BraunT apollon77A 2 Antworten Letzte Antwort
          • J JoergH
            @apollon77
            @joergh
            iobroker upload all
            • J JoergH
              @apollon77
              @joergh Bei installation über die Katze gibt es an sich keinerlei checks und auch keinerlei warnungen
                JoergH
                @apollon77
                Der Adapter wird ja auch installiert, aber wenn ich dann mit + eine Instanz erstellen will, dann kommt das Popup Fenster mit der Ansage, dass es mit nodejs 18.6 nicht geht und ich kann keine Instanz hinzufügen, sondern nur schließen auswählen.
                • J JoergH
                  @apollon77
                  @joergh Hast Du Single oder MultiHost system? Falls Multihost - hast DU auch den korrekten Host gewählt für die installation?
                    JoergH
                    @apollon77 Ich habe ein Single Host System....
                    • J JoergH
                      @joergh Dann ehrlich ... verstehe ich es nicht, wenn du alles gemacht hast wie oben gesagt sollte das nicht passieren
                      J 2 Antworten Letzte Antwort
                        JoergH
                        @apollon77
                        Nachdem ich gestern mal Schluß gemacht habe, habe ich heute den Rechner angeschaltet, mich eingeloggt und dann auf der Adapterseite einfach noch einmal probiert eine Instanz zu installieren und siehe da es ging!
                        Anscheinend muss es wohl wieder ein Cache Thema oder sowas gewesen sein. Gestern bin ich immer auf der Adapterseite geblieben und habe den Adapter mehrfach deinstalliert, per Github wieder installiert und dann direkt versucht eine Instanz er erstellen und immer kam das Popup Fenster.
                        Fazit: Immer besser mal den Browser schließen und neu öffnen :-/
                        Viele Dank für die Hinweise an alle!
                          JoergH
                          @apollon77
                          Leider habe ich mich etwas zu früh gefreut, denn die Instanz ist zwar nun wieder da und er verbindet sich auch, aber er zieht keine Daten
                          Dafür aber einige Warnungen im Log:
                          daikin-cloud.0
                          	2023-05-25 14:09:54.815	warn	State "daikin-cloud.0.67205806-98ce-4317-99a2-16d050608e74.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                          daikin-cloud.0
                          	2023-05-25 14:09:54.814	warn	State "daikin-cloud.0.67205806-98ce-4317-99a2-16d050608e74.climateControl.sensoryData.outdoorTemperature" has no existing object, this might lead to an error in future versions
                          daikin-cloud.0
                          	2023-05-25 14:09:54.397	warn	State "daikin-cloud.0.14ca0b88-9561-482f-b830-1c0e42e72fff.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                          daikin-cloud.0
                          	2023-05-25 14:08:54.590	warn	State "daikin-cloud.0.67205806-98ce-4317-99a2-16d050608e74.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                          daikin-cloud.0
                          	2023-05-25 14:08:54.167	warn	State "daikin-cloud.0.14ca0b88-9561-482f-b830-1c0e42e72fff.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                          daikin-cloud.0
                          	2023-05-25 14:07:54.399	warn	State "daikin-cloud.0.67205806-98ce-4317-99a2-16d050608e74.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                          daikin-cloud.0
                          	2023-05-25 14:07:53.950	warn	State "daikin-cloud.0.14ca0b88-9561-482f-b830-1c0e42e72fff.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                          daikin-cloud.0
                          	2023-05-25 14:06:54.008	warn	State "daikin-cloud.0.67205806-98ce-4317-99a2-16d050608e74.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                          daikin-cloud.0
                          	2023-05-25 14:06:54.007	warn	State "daikin-cloud.0.67205806-98ce-4317-99a2-16d050608e74.climateControl.sensoryData.outdoorTemperature" has no existing object, this might lead to an error in future versions
                          daikin-cloud.0
                          	2023-05-25 14:06:54.006	warn	State "daikin-cloud.0.67205806-98ce-4317-99a2-16d050608e74.gateway.wifiConnectionStrength" has no existing object, this might lead to an error in future versions
                          daikin-cloud.0
                          	2023-05-25 14:06:53.752	warn	State "daikin-cloud.0.14ca0b88-9561-482f-b830-1c0e42e72fff.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                          daikin-cloud.0
                          	2023-05-25 14:06:53.751	warn	State "daikin-cloud.0.14ca0b88-9561-482f-b830-1c0e42e72fff.climateControl.sensoryData.outdoorTemperature" has no existing object, this might lead to an error in future versions
                          daikin-cloud.0
                          	2023-05-25 14:06:53.750	warn	State "daikin-cloud.0.14ca0b88-9561-482f-b830-1c0e42e72fff.gateway.wifiConnectionStrength" has no existing object, this might lead to an error in future versions
                          daikin-cloud.0
                          	2023-05-25 14:05:53.714	warn	State "daikin-cloud.0.67205806-98ce-4317-99a2-16d050608e74.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                          daikin-cloud.0
                          	2023-05-25 14:05:53.548	warn	State "daikin-cloud.0.14ca0b88-9561-482f-b830-1c0e42e72fff.lastUpdateReceived" has no existing object, this might lead to an error in future versions
                          • J JoergH
                            @apollon77
                            daikin-cloud.0
                            daikin-cloud.0
                            daikin-cloud.0
                            daikin-cloud.0
                            daikin-cloud.0
                            daikin-cloud.0
                            daikin-cloud.0
                            daikin-cloud.0
                            daikin-cloud.0
                            daikin-cloud.0
                            daikin-cloud.0
                            daikin-cloud.0
                            daikin-cloud.0
                            daikin-cloud.0
                            daikin-cloud.0
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @joergh sagte in Daikin Cloud Adapter nodejs18 [gelöst]:
                            dann zeige bitte ein DEBUG Log Ausgabe .. so kann man nichts dazu sagen
                            • GlasfaserG Glasfaser
                              JoergH
                              @glasfaser Hat sich inzwischen erledigt. Nachdem ich ein paar Stunden nicht dran war sind sie da.
                              • Elektroniker86E Offline
                                Elektroniker86
                                schrieb am zuletzt editiert von Elektroniker86
                                Mist bei mir lässt sich der Adapter nicht von Github installieren/updaten:
                                $ iobroker url Apollon77/ioBroker.daikin-cloud --host iobroker --debug
                                install Apollon77/ioBroker.daikin-cloud
                                NPM version: 9.5.1
                                Installing Apollon77/ioBroker.daikin-cloud... (System call)
                                npm ERR! code EBADENGINE
                                upload [0] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/words.js words.js application/javascript
                                Process exited with code 0
                                Ich weiß jetzt nicht mehr weiter. Bin für jede Hilfe dankbar!
                                • Elektroniker86E Elektroniker86
                                  NPM version: 9.5.1
                                  @elektroniker86 sagte in Daikin Cloud Adapter nodejs18 [gelöst]:
                                  was für eine Hardware/OS?
                                  Elektroniker86E 1 Antwort Letzte Antwort
                                    Elektroniker86
                                    Der ioBroker läuft in einem Ubuntu 22.04.2 LTS auf einem Proxmox System als VM
                                      Elektroniker86
                                      Ich habe vor ein paar Tagen das System laut dieser Anleitung:
                                      https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
                                      von Nodejs 16 auf 18 aktualisiert. Keine Auffälligkeiten alles rund gelaufen.
                                        @elektroniker86
                                        Mach es aus einem Terminal heraus:
                                        iobroker update
                                          @elektroniker86
                                          iobroker update
                                          Elektroniker86
                                          iobroker@iobroker:~$ iobroker url Apollon77/ioBroker.daikin-cloud --host iobroker --debug
                                          NPM version: 9.5.1
                                          npm ERR! engine Unsupported engine
                                          npm ERR! engine Not compatible with your version of node/npm: openid-client@5.1.9
                                          npm ERR! notsup Not compatible with your version of node/npm: openid-client@5.1.9
                                          npm ERR! notsup Required: {"node":"^12.19.0 || ^14.15.0 || ^16.13.0"}
                                          npm ERR! notsup Actual:   {"npm":"9.5.1","node":"v18.16.0"}
                                          npm ERR!     /home/iobroker/.npm/_logs/2023-06-07T07_14_11_886Z-debug-0.log
                                          upload [6] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/admin.d.ts admin.d.ts video/mp2t
                                          upload [5] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin-cloud.jpg daikin-cloud.jpg image/jpeg
                                          upload [4] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin_logo.jpg daikin_logo.jpg image/jpeg
                                          upload [3] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/index_m.html index_m.html text/html
                                          upload [2] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/style.css style.css text/css
                                          upload [1] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/warning.png warning.png image/png
