  3. Einsteigerfragen
  4. Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter
    2.7k
    4.8k
    4.0k
190 Beiträge 20 Kommentatoren 35.4k Aufrufe 16 Beobachtet
  • V V8Turbo
    @klassisch Kann ich versuchen bzw hatte ich schonmal gemacht aber es geht ja per USB zumindest eins... Hab das Grad nochmal getestet. Wenn ich ein 2. Register dazu mach geht es auch noch aber sobald ein 3. kommt geht es nicht mehr...
    odbus.0
    	2023-01-23 17:28:51.308	debug	Cleaning up request fifo.
    modbus.0
    	2023-01-23 17:28:51.307	debug	Clearing timeout of the current request.
    modbus.0
    	2023-01-23 17:28:51.302	info	Disconnected from slave
    modbus.0
    	2023-01-23 17:28:50.303	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
    modbus.0
    	2023-01-23 17:28:50.301	error	Request timed out.
    modbus.0
    	2023-01-23 17:28:50.301	warn	Error: undefined
    modbus.0
    	2023-01-23 17:28:45.379	error	Wrong CRC for frame: 2,3,44,0,0,0,122,0,0,3,99,0,0,1,157,0,0,4,192,192,0,0,1,51,0,0,2,158,0,0,0,0,0,0,0,174,0,0,0,14,0,0,2,120,0,0,0,24,135
    modbus.0
    	2023-01-23 17:28:45.292	debug	[DevID_2/holdingRegs] Poll address 1157 - 1 registers
    modbus.0
    	2023-01-23 17:28:45.292	debug	Initialization of scale factors done!
    modbus.0
    	2023-01-23 17:28:45.290	debug	[DevID_2] Poll start ---------------------
    modbus.0
    	2023-01-23 17:28:45.289	info	Connected to slave
    modbus.0
    	2023-01-23 17:28:45.280	debug	connect to serial /dev/ttyUSB0 with 9600
    modbus.0
    	2023-01-23 17:28:44.932	debug	Add holdingRegisters.2.41689_Bat_Discharge_Today: {"_id":"holdingRegisters.2.41689_Bat_Discharge_Today","type":"state","common":{"name":"","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"kWh"},"native":{"regType":"holdingRegs","address":1688,"deviceId":2,"type":"uint32be","len":2,"offset":0,"factor":0.01,"poll":true}}
    modbus.0
    	2023-01-23 17:28:44.931	debug	Add holdingRegisters.2.41685_Bat_Charge_Today: {"_id":"holdingRegisters.2.41685_Bat_Charge_Today","type":"state","common":{"name":"","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"kWh"},"native":{"regType":"holdingRegs","address":1684,"deviceId":2,"type":"uint32be","len":2,"offset":0,"factor":0.01,"poll":true}}
    modbus.0
    	2023-01-23 17:28:44.931	debug	Add holdingRegisters.2.41681_Energy_Selling_Today: {"_id":"holdingRegisters.2.41681_Energy_Selling_Today","type":"state","common":{"name":"","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"kWh"},"native":{"regType":"holdingRegs","address":1680,"deviceId":2,"type":"uint32be","len":2,"offset":0,"factor":0.01,"poll":true}}
    modbus.0
    	2023-01-23 17:28:44.930	debug	Add holdingRegisters.2.41677_Energy_Purchase_Today: {"_id":"holdingRegisters.2.41677_Energy_Purchase_Today","type":"state","common":{"name":"","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"kWh"},"native":{"regType":"holdingRegs","address":1676,"deviceId":2,"type":"uint32be","len":2,"offset":0,"factor":0.01,"poll":true}}
    modbus.0
    	2023-01-23 17:28:44.929	debug	Add holdingRegisters.2.41673_Load_Consumption_Today: {"_id":"holdingRegisters.2.41673_Load_Consumption_Today","type":"state","common":{"name":"","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"kWh"},"native":{"regType":"holdingRegs","address":1672,"deviceId":2,"type":"uint32be","len":2,"offset":0,"factor":0.01,"poll":true}}
    modbus.0
    	2023-01-23 17:28:44.929	debug	Add holdingRegisters.2.41669_PV_Generation_Today: {"_id":"holdingRegisters.2.41669_PV_Generation_Today","type":"state","common":{"name":"","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"kWh"},"native":{"regType":"holdingRegs","address":1668,"deviceId":2,"type":"uint32be","len":2,"offset":0,"factor":0.01,"poll":true}}
    modbus.0
    	2023-01-23 17:28:44.928	debug	Add holdingRegisters.2.41477_Power_PV_Total: {"_id":"holdingRegisters.2.41477_Power_PV_Total","type":"state","common":{"name":"","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"kW"},"native":{"regType":"holdingRegs","address":1476,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":0.1,"poll":true}}
    modbus.0
    	2023-01-23 17:28:44.928	debug	Add holdingRegisters.2.41158_Active_Power_Output_Total: {"_id":"holdingRegisters.2.41158_Active_Power_Output_Total","type":"state","common":{"name":"","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"kW"},"native":{"regType":"holdingRegs","address":1157,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":0.01,"poll":true}}
    modbus.0
    	2023-01-23 17:28:44.927	debug	Initialize Objects for holdingRegs: [{"_address":41158,"deviceId":2,"name":"Active_Power_Output_Total","description":"","unit":"kW","type":"int16be","len":1,"factor":0.01,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"address":1157,"id":"holdingRegisters.2.41158_Active_Power_Output_Total"},{"_address":41477,"deviceId":2,"name":"Power_PV_Total","description":"","unit":"kW","type":"uint16be","len":1,"factor":0.1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"address":1476,"id":"holdingRegisters.2.41477_Power_PV_Total"},{"_address":41669,"name":"PV_Generation_Today","description":"","unit":"kWh","type":"uint32be","len":2,"factor":0.01,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":1668,"id":"holdingRegisters.2.41669_PV_Generation_Today"},{"_address":41673,"name":"Load_Consumption_Today","description":"","unit":"kWh","type":"uint32be","len":2,"factor":0.01,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":1672,"id":"holdingRegisters.2.41673_Load_Consumption_Today"},{"_address":41677,"name":"Energy_Purchase_Today","description":"","unit":"kWh","type":"uint32be","len":2,"factor":0.01,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":1676,"id":"holdingRegisters.2.41677_Energy_Purchase_Today"},{"_address":41681,"name":"Energy_Selling_Today","description":"","unit":"kWh","type":"uint32be","len":2,"factor":0.01,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":1680,"id":"holdingRegisters.2.41681_Energy_Selling_Today"},{"_address":41685,"name":"Bat_Charge_Today","description":"","unit":"kWh","type":"uint32be","len":2,"factor":0.01,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":1684,"id":"holdingRegisters.2.41685_Bat_Charge_Today"},{"_address":41689,"name":"Bat_Discharge_Today","description":"","unit":"kWh","type":"uint32be","len":2,"factor":0.01,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":1688,"id":"holdingRegisters.2.41689_Bat_Discharge_Today"}]
    modbus.0
    	2023-01-23 17:28:44.926	debug	Initialize Objects for inputRegs: []
    modbus.0
    	2023-01-23 17:28:44.925	debug	Initialize Objects for coils: []
    modbus.0
    	2023-01-23 17:28:44.925	debug	Initialize Objects for disInputs: []
    modbus.0
    	2023-01-23 17:28:44.775	info	starting. Version 5.0.11 (non-npm: ioBroker/ioBroker.modbus) in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.0, js-controller: 4.0.24
    modbus.0
    	2023-01-23 17:28:44.419	debug	Plugin sentry Initialize Plugin (enabled=true)
    modbus.0
    	2023-01-23 17:28:44.348	debug	States connected to redis: 127.0.0.1:9000
    modbus.0
    	2023-01-23 17:28:44.284	debug	States create User PubSub Client
    modbus.0
    	2023-01-23 17:28:44.282	debug	States create System PubSub Client
    modbus.0
    	2023-01-23 17:28:44.271	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    modbus.0
    	2023-01-23 17:28:44.248	debug	Objects connected to redis: 127.0.0.1:9001
    modbus.0
    	2023-01-23 17:28:44.241	debug	Objects client initialize lua scripts
    modbus.0
    	2023-01-23 17:28:44.214	debug	Objects create User PubSub Client
    modbus.0
    	2023-01-23 17:28:44.213	debug	Objects create System PubSub Client
    modbus.0
    	2023-01-23 17:28:44.210	debug	Objects client ready ... initialize now
    modbus.0
    	2023-01-23 17:28:44.174	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    admin.0
    	2023-01-23 17:28:43.533	info	<== Disconnect system.user.admin from ::ffff:192.168.178.203 modbus
    host.raspberrypi
    	2023-01-23 17:28:42.914	info	instance system.adapter.modbus.0 started with pid 7562
    host.raspberrypi
    	2023-01-23 17:28:40.250	info	instance system.adapter.modbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.raspberrypi
    	2023-01-23 17:28:39.757	info	stopInstance system.adapter.modbus.0 send kill signal
    modbus.0
    	2023-01-23 17:28:39.684	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    modbus.0
    	2023-01-23 17:28:39.683	debug	Plugin sentry destroyed
    modbus.0
    	2023-01-23 17:28:39.681	info	terminating
    modbus.0
    	2023-01-23 17:28:39.678	info	Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi
    	2023-01-23 17:28:39.670	info	stopInstance system.adapter.modbus.0 (force=false, process=true)
    modbus.0
    	2023-01-23 17:28:22.542	debug	Cleaning up request fifo.
    modbus.0
    	2023-01-23 17:28:22.541	debug	Clearing timeout of the current request.
    modbus.0
    	2023-01-23 17:28:22.537	info	Disconnected from slave
    modbus.0
    	2023-01-23 17:28:21.534	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
    modbus.0
    	2023-01-23 17:28:21.533	error	Request timed out.
    modbus.0
    	2023-01-23 17:28:21.532	warn	Error: undefined
    modbus.0
    	2023-01-23 17:28:16.530	debug	[DevID_2/holdingRegs] Poll address 1668 - 22 registers
    modbus.0
    	2023-01-23 17:28:16.527	debug	[DevID_2/holdingRegs] Poll address 1476 DONE
    modbus.0
    	2023-01-23 17:28:16.493	debug	[DevID_2/holdingRegs] Poll address 1476 - 1 registers
    modbus.0
    	2023-01-23 17:28:16.492	debug	[DevID_2] Poll start ---------------------
    admin.0
    	2023-01-23 17:27:57.689	info	==> Connected system.user.admin from ::ffff:192.168.178.203
    modbus.0
    	2023-01-23 17:27:46.437	debug	[DevID_2/holdingRegs] Poll address 1668 DONE
    modbus.0
    	2023-01-23 17:27:46.360	debug	[DevID_2/holdingRegs] Poll address 1668 - 22 registers
    modbus.0
    	2023-01-23 17:27:46.358	debug	[DevID_2/holdingRegs] Poll address 1476 DONE
    modbus.0
    	2023-01-23 17:27:46.323	debug	[DevID_2/holdingRegs] Poll address 1476 - 1 registers
    modbus.0
    	2023-01-23 17:27:46.321	debug	[DevID_2] Poll start ---------------------
    modbus.0
    	2023-01-23 17:27:16.266	debug	[DevID_2/holdingRegs] Poll address 1668 DONE
    modbus.0
    	2023-01-23 17:27:16.189	debug	[DevID_2/holdingRegs] Poll address 1668 - 22 registers
    modbus.0
    	2023-01-23 17:27:16.187	debug	[DevID_2/holdingRegs] Poll address 1476 DONE
    modbus.0
    	2023-01-23 17:27:16.154	debug	[DevID_2/holdingRegs] Poll address 1476 - 1 registers
    klassisch
    #66
    @v8turbo Das heißt, auch mit USB gehen nicht mehr als 3 Register, aber wenigstens geht ein Register mit USB?
    V 1 Antwort Letzte Antwort
    • K klassisch
      V Offline
      V Offline
      V8Turbo
      #67
      @klassisch ja das ist schon immer so. Hatte ich auch schon geschrieben.
      L 1 Antwort Letzte Antwort
      • V V8Turbo
        LotharF
        #68
        Ich habe eigentlich die gleiche Kombination aus SofarSolar HYD Wechselrichter und Pylontech Akku.
        Das was du machst scheint ja nicht so einfach zu sein. Es gibt ja auch anscheinend die Möglichkeit, das per MQTT einzubinden.
        https://www.instructables.com/Sofar2mqtt-Remote-Control-for-Sofar-Solar-Inverter/
        oder
        https://github.com/pawelka/sofarsolar_esp_rs485_logger
        Das zweite habe ich versucht nachzubauen, aber irgendwie bekomme ich da auch keine Daten angezeigt.
        Hat vielleicht hier schon jemand eins der beiden Sachen evtl. schon mit Erfolg eingebunden an nem HYD Wechselrichter?
        • wendy2702W Offline
          wendy2702W Offline
          #69
          Ich persönlich glaube das es mit Modbus nicht schwerer ist als mit anderen wegen wenn die HW passt und man gezielt an die Konfig geht.
          Aus eigener Erfahrung kann ich sagen das ein Abbruch nach hinzufügen mehrerer Register meistens ein Fehler in der Konfig genau dieser war. Entweder falscher Typ und /oder falsche länge.
          • L LotharF
            oder
            shooter
            #70
            @lotharf
            Ja, sofar2mqtt läuft bei mir aktuell am HYD3000es. Aktuell habe ich ehr das Problem das ich ein JSON-Response bekomme und keine einzelnen Datenobjekte. Entweder parse ich den Kram (am liebsten ohne Aufwand) oder ich bau mir den Code entsprechend um...mal sehen.
            Original kommt hier hier: link sofar2mqtt
            Gruß,
            Flo
            • V V8Turbo
              Hallo, habe einen Sofar Solar HYD10 KTL Wechselrichter + Pylontech Force H2 Akkus und möchte gern den Wechselrichter an ioBroker mit dem Modbus Adapter einbinden. Habe mir schon den USB -> RS485 Adapter bei Amazon bestellt und angeschlossen. Wird auch vom Raspberry erkannt. Nur leider funktioniert es nicht... Habe mir schon die HEX in DEC Adressen umgerechnet... +/- stimmt auch.
              Meldung im LOG
              modbus.0
              2023-01-12 08:45:33.506	info	Connected to slave
              modbus.0
              2023-01-12 08:45:33.293	info	Can not execute task "add" for ID undefined: The id is empty! Please provide a valid id. ({"name":"add","obj":{"type":"state","common":{"name":"L1","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":-35377,"deviceId":1,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}}
              modbus.0
              2023-01-12 08:45:33.223	error	Invalid object: {"type":"state","common":{"name":"L1","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":-35377,"deviceId":1,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
              modbus.0
              2023-01-12 08:45:33.221	error	Invalid data holdingRegisters/0: {"_address":"4624","name":"Voltage_Line_L1","description":"L1","unit":"V","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":-35377,"deviceId":1,"fullId":"modbus.0.0"}
              modbus.0
              2023-01-12 08:45:33.217	error	Invalid holdingRegisters address: -35377
              _address name description unit type len factor offset formula role room poll wp cw isScale
              4624 Voltage_Line_L1 L1 V int16be 1 1 0 level true
              Kann jemand helfen ?
              W Offline
              W Offline
              WilliK
              #71
              @v8turbo mein HYD 15 KTL 3P läuft mit folgender Konfiguration:
              Pin 1 und 3 des COM-Steckers am Wechselrichter verbunden mit einem Waveshare RS485 TO ETH (B), dieser hängt am LAN. Die Modbusleitung ist ca. 4 m lang und habe keine Abschlusswiderstände dran.
              https://www.waveshare.com/catalogsearch/result/?q=RS485+TO+ETH+(B)
              Er ist wie folgt konfiguriert: (Neben dem Wechselrichter hängt auch noch ein SDM72D-M-2 Modbus Drei-Phasen-Elektro-Energiezähler auf dem gleichen Gerät am Modbus, jedoch mit eigener Modbus Instanz im ioBroker)
              Im ioBroker habe ich eine eigene Modbus-Instanz für den Wechselrichter mit folgender Konfiguration (Für meinen Wechselrichter habe ich die ID 7 im Wechselrichter eingestellt, Standard ist 1):
              Um den Faktor einstellen zu können, muss man auf den rot eingekreisten Kopf klicken um den erweiterten Modus einzuschalten.
              In den Objekten im ioBroker sieht man dementsprechend folgende Werte (Da es dunkel ist, ist die PV-Leistung 0, negative Batterieladung bedeutet Entladung)
              W 1 Antwort Letzte Antwort
              • W WilliK
                W Offline
                W Offline
                WilliK
                #72
                ich habe jetzt noch ein paar Register mehr hinzugefügt, da irgendwo geschrieben stand dass nur 3 Register gleichzeitig gehen. In meiner Konfig scheint das kein Problem zu sein.
                M S 2 Antworten Letzte Antwort
                • W WilliK
                  Malti18
                  #73
                  @willik
                  Hallo, sage mal wie bist du auf die Zahlen für die Register gekommen ?
                  MH
                  • W WilliK
                    SAD1983
                    #74
                    @willik
                    Hallo, ich habe mir den Waveshare RS485 to ETH (B) besorgt und probiere diesen nun seit 2Tagen an meinem SofarSolar ins laufen zu bekommen.
                    1. Zum einem bekomme ich keine stetige Verbindung mit dem IO-Broker hin. Er baut die Verbindung auf und bricht diese Verbindung nach der eingestellten Zeit wieder ab.
                      Log:
                    2. Des Weiteren blinkt die ACT LED, und die Link LED blinkt zwischen Grün und Blau
                    3. Da du die Pins 1 -3 beschrieben hast, es nach der Beschreibung allerdings Pin 1 - 4 laut Beschreibung sein sollte, habe ich einen LogicAnalyzer dazwischen gehangen. Ich habe zwischen PIN 1 -4 alle varianten ausprobiert, jedoch sehe ich immer nur die Anfrage vom Waveshare in Richtung SoforSolar Umrichter. Er reagiert nicht. (ID habe ich ebenfalls bereits probiert zu ändern, Baud 9600 sollte passen):
                    Da ich aus meiner Sicht zwei unterschiedliche Probleme habe, wollte ich um Rat fragen. Ich habe soweit ich es nachvollziehen konnte alle Einstellungen im IO-Broker sowie auf der Web-Oberfläche des Waveshares eingetragen.
                    Vielen Dank für eine Rückmeldung im Vorfeld!
                    wendy2702W W 2 Antworten Letzte Antwort
                    • S SAD1983
                      @willik
                        Log:
                      wendy2702W Offline
                      wendy2702W Offline
                      #75
                      @sad1983 sagte in Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter:
                      Bitte zeigen!
                      Logs bitte als Text in Code Tags </> posten.
                      Hinweis: die Verbindung zu IOB bzw. der Adapter wird erst "grün" wenn mindestens ein Register erfolgreich ausgelesen werden kann.
                      • M Malti18
                        @willik
                        W Offline
                        W Offline
                        WilliK
                        #76
                        @malti18 ich habe eine Excel-Datei im Netz gefunden mit allen Registern, allerdings mit HEX-Adressen. Ich habe dann mit einem Online-Konverter die Adressen in die Dezimal-Werte konvertiert
                        • S SAD1983
                          @willik
                            Log:
                          W Offline
                          W Offline
                          WilliK
                          #77
                          @sad1983 said in Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter:
                          laut dem mitgeliefertem Handbuch ist es Pin1, Definition: RS485-A1-1 und Pin3, Definition: RS485-B1-1, so funktioniert es bei mir auch
                            schorty
                            #78
                            Hallo Zusammen,
                            Pin1 und Pin3 funktioniert bei mir. PIN 1 und 2 sowie 3 und 4 sind wohl parallel geschaltet für mehrere Wechselrichter.
                            Hat jemand die Implementierung mit allen auslesbaren Registern am laufen und kann die Einstellungen mal posten?
                            • S schorty
                              Hallo Zusammen,
                              W Offline
                              W Offline
                              WilliK
                              #79
                              @schorty hier eine Übersicht über die verfügbaren Register (Achtung die Registeradressen sind in HEX, müssen also nach Dezimal gewandelt werden) 211116_SOFAR HYD-3PH and SOFAR -G3 Modbus Protocol 2021-10-14_Client.xlsx
                              • W WilliK
                                W Offline
                                W Offline
                                WilliK
                                #80
                                e7604f94-1934-423d-9a14-12c60b1d44be-image.png Meine derzeitige Konfiguration
                                • W WilliK
                                  schorty
                                  #81
                                  @willik Dank Dir! Habs auf laufen
                                  • S schorty
                                    schorty
                                    #82
                                    Jetzt läuft es wieder nicht mehr. Der WR zeigt auch kein RS485 mehr an...
                                    modbus.0
                                    2023-10-22 15:33:19.222 warn Poll error count: 3 code: {"err":"timeout","timeout":5000}
                                    modbus.0
                                    2023-10-22 15:33:19.220 error Client in error state.
                                    modbus.0
                                    2023-10-22 15:33:19.219 error Request timed out.
                                    modbus.0
                                    2023-10-22 15:33:19.218 warn Error: undefined
                                    modbus.0
                                    2023-10-22 15:33:14.215 info Connected to slave 192.168.2.36
                                    modbus.0
                                    2023-10-22 15:33:12.210 info Disconnected from slave 192.168.2.36
                                    modbus.0
                                    2023-10-22 15:33:11.214 warn Poll error count: 2 code: {"err":"timeout","timeout":5000}
                                    modbus.0
                                    2023-10-22 15:33:11.211 error Client in error state.
                                    modbus.0
                                    2023-10-22 15:33:11.210 error Request timed out.
                                    modbus.0
                                    2023-10-22 15:33:11.208 warn Error: undefined
                                    modbus.0
                                    2023-10-22 15:33:06.204 info Connected to slave 192.168.2.36
                                    modbus.0
                                    2023-10-22 15:33:04.199 info Disconnected from slave 192.168.2.36
                                    modbus.0
                                    2023-10-22 15:33:03.202 warn Poll error count: 1 code: {"err":"timeout","timeout":5000}
                                    modbus.0
                                    2023-10-22 15:33:03.199 error Client in error state.
                                    modbus.0
                                    2023-10-22 15:33:03.196 error Request timed out.
                                    modbus.0
                                    2023-10-22 15:33:03.195 warn Error: undefined
                                    modbus.0
                                    2023-10-22 15:32:58.169 info Connected to slave 192.168.2.36
                                    • S schorty
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      schorty
                                      #83
                                      @schorty
                                      Antworte mir mal selbst: Die Einstellungen von LAN<->RS485 Gateway hatten sich gelöscht...
                                      Läuft wieder.
                                      Wie habt ihr die Visualisierung schick gelöst?
                                      Schaut in der Solarmann App oder Homeasistant https://www.home-assistant.io/home-energy-management/ sehr fein aus.
                                      R 1 Antwort Letzte Antwort
                                        schorty
                                        #84
                                        Hallo, wie stabil läuft das Auslesen über RS485 / Modbus bei Euch?
                                        Lese über ein PE11 LAN<>RS485 Gateway zwei Handvoll Werte alle 2min aus. Nach 20...30h bricht der WR die Verbindung ab.
                                        Interessant: Wenn man bei HYD20 auf Systemeinstellungen - Modbus-Geschwindigkeit geht und die Einstellung unverändert bestätigt geht die Verbindung wieder und der Adapter bekommt neue Daten.
                                        Habe im Netz schon Lösungen über den LSE-3 Solarman Dongle gesehen. Soll wohl stabil laufen, doch würde ich gerne die Ausgabe und den Umbau vermeiden.
                                        Alex
                                        modbus.0
                                        2023-11-16 10:06:06.219 warn Poll error count: 5 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-11-16 10:06:06.216 error Client in error state.
                                        modbus.0
                                        2023-11-16 10:06:06.215 error Request timed out.
                                        modbus.0
                                        2023-11-16 10:06:06.213 warn Error: undefined
                                        modbus.0
                                        2023-11-16 10:05:50.207 warn Poll error count: 4 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-11-16 10:05:50.206 error Client in error state.
                                        modbus.0
                                        2023-11-16 10:05:50.205 error Request timed out.
                                        modbus.0
                                        2023-11-16 10:05:50.204 warn Error: undefined
                                        modbus.0
                                        2023-11-16 10:05:34.198 warn Poll error count: 3 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-11-16 10:05:34.195 error Client in error state.
                                        modbus.0
                                        2023-11-16 10:05:34.194 error Request timed out.
                                        modbus.0
                                        2023-11-16 10:05:34.191 warn Error: undefined
                                        modbus.0
                                        2023-11-16 10:05:18.190 warn Poll error count: 2 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-11-16 10:05:18.184 error Client in error state.
                                        modbus.0
                                        2023-11-16 10:05:18.181 error Request timed out.
                                        • S schorty
                                          Alex
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          W Offline
                                          W Offline
                                          WilliK
                                          #85
                                          @schorty ich habe den Waveshare RS485 TO ETH (B) und bisher keine Abbrüche oder Aussetzer
