  4. JavaScript
  5. Roborock Adapter tester gesucht
766 Beiträge 51 Kommentatoren 324.3k Aufrufe 52 Beobachtet
    DonToben
    #628
    @copystring
    Mit der neusten DEV heute folgende Meldungen:
    Eine Idee? WLAN Verbindung ist eigentlich stabil.
    	2023-05-07 18:01:54.408	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    roborock.0
    	2023-05-07 18:01:53.720	error	Request with id 2526 timed out after 10 seconds for response.102
    roborock.0
    	2023-05-07 18:01:53.719	error	Error: Request with id 2526 timed out after 10 seconds for response.102 at /opt/iobroker/node_modules/iobroker.roborock/lib/roborock_mqtt_connector.js:272:12 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1119:13) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
    roborock.0
    	2023-05-07 18:01:53.716	error	unhandled promise rejection: Request with id 2526 timed out after 10 seconds for response.102
    roborock.0
    	2023-05-07 18:01:53.715	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.raspberrypi
    	2023-05-07 17:59:33.447	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    roborock.0
    	2023-05-07 17:59:32.813	error	Request with id 3075 timed out after 10 seconds for response.102
    roborock.0
    	2023-05-07 17:59:32.812	error	Error: Request with id 3075 timed out after 10 seconds for response.102 at /opt/iobroker/node_modules/iobroker.roborock/lib/roborock_mqtt_connector.js:272:12 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1119:13) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
    roborock.0
    	2023-05-07 17:59:32.808	error	unhandled promise rejection: Request with id 3075 timed out after 10 seconds for response.102
    roborock.0
    	2023-05-07 17:59:32.807	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.raspberrypi
    	2023-05-07 17:48:12.772	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    roborock.0
    	2023-05-07 17:48:12.105	error	Request with id 3632 timed out after 10 seconds for response.102
    roborock.0
    	2023-05-07 17:48:12.105	error	Error: Request with id 3632 timed out after 10 seconds for response.102 at /opt/iobroker/node_modules/iobroker.roborock/lib/roborock_mqtt_connector.js:272:12 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1119:13) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
    roborock.0
    	2023-05-07 17:48:12.102	error	unhandled promise rejection: Request with id 3632 timed out after 10 seconds for response.102
    roborock.0
    	2023-05-07 17:48:12.101	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    copystringC 1 Antwort Letzte Antwort
    • M mikiline
      @copystring
      vielen dank, ich bin auch schon ein stück weiter gekommen
      zumindest habe ich jetzt mal koordinaten und weiss wie ich daran komme
      zone: [27375,26300,28975,27600,1]
      wie gebe ich das nun über blockly an den adapter?
      "commands.app_zoned_clean" ist doch true, false
      mir fehlt auch ein datenpunkt "GoTo", wie schickt man den roboter an eine bestimmte stelle?
      wurde aus den ganzen beiträgen nicht ganz schlau daraus
      vielleicht kann @Spampunk auch ein beispiel geben, scheint dort zum einsatz zu kommen
      copystringC Offline
      copystringC Offline
      copystring
      #629
      @mikiline du müsstest dir mal die aktuelle dev installieren. Da geht das.
      Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
      https://paypal.me/copystring
      • D DonToben
        @copystring
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        host.raspberrypi
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        host.raspberrypi
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        copystringC Offline
        copystringC Offline
        copystring
        #630
        @dontoben Das sieht nicht aus wie aktuelle dev. In der aktuellen dev werden alle Timeouts als Warnung ausgegeben und nicht als Error.
        • copystringC copystring
          DonToben
          #631
          @copystring said in Roborock Adapter tester gesucht:
          Unter benutzerdefinierte Adapterinstallation doch nur den Link https://github.com/copystring/ioBroker.roborock/tree/dev eintragen und installieren, oder?
          Hatte das gestern mehrfach gemacht. Auch Adapter zuvor deinstalliert. Immer das gleiche Problem. Ging jetzt auf den Main zurück. Der funktioniert.
            DonToben
            #632
            Befehl ausführen
            Process exited with code 0
            weniger
            mehr
            $ iobroker url https://github.com/copystring/ioBroker.roborock/tree/dev --host raspberrypi --debug
            install copystring/ioBroker.roborock#dev
            NPM version: 9.5.1
            Installing copystring/ioBroker.roborock#dev... (System call)
            66 packages are looking for funding run `npm fund` for details
            upload [13] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [12] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [10] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [9] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [7] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [6] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [3] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [2] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/jsonConfig.json jsonConfig.json application/json
            upload [1] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/roborock.png roborock.png image/png
            upload [0] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/words.js words.js application/javascript
            Update "system.adapter.roborock.0"
            Hier der Log der Installation. Die aktuelle Dev funktioniert bei mir nicht.
              mikiline
              #633
              @copystring vielen Dank, die hab ich nun installiert und goto ist vorhanden ;)
              was ich aber jetzt festgestellt habe ist, wenn ich über webseite (Map) eine zone in die karte mache und auf start klicke, fährt der roboter los, jedoch ist die zone nicht dort wo ich sie eingezeichnet habe (wird ja grün umrandet)
              • D DonToben
                DonToben
                #634
                @dontoben said in Roborock Adapter tester gesucht:
                Jemand eine Idee? Auf einen älteren Dev Stand komme ich nicht zurück, oder?
                • D DonToben
                  DonToben
                  #635
                  Scheint wirklich ein Bug zu sein. GitHub Ticket habe ich erstellt. Fehler tritt auf, wenn der Adapter gestartet wird, aber der Roborock in der Ladestation steht und im Standby ist.
                  Workaround:
                  Adapter starten wenn der Saugroboter gerade reinigt, dann ist alles ok.
                  • copystringC Offline
                    copystringC Offline
                    copystring
                    #636
                    Es gibt eine neue branch, in der versucht wird, die aufgenommenen Fotos von den Modellen mit Kamera abzurufen.
                    Das Abrufen läuft über das Webinterface, indem man auf einen der roten Punkte von dem entsprechenden Hindernis klickt.
                    Dann wird eine Anfrage zum Server von Roborock mit der ID vom Foto zusammen mit vom Adapter generierten PublicKey (RSA128) übersendet.
                    Die Antwort muss dann entsprechend mit dem PrivateKey entschlüsselt werden. Es scheint da irgendeinen Offset zu geben, den ich nicht herausfinden kann. Da hört es mit meinen Skills zum Reverse Engineering auf.
                    Wer mag und vielleicht mithelfen kann, kann sich das ja mal angucken. Aber nur dann, wenn man ernsthaft Interesse hat, daran mitzuentwickeln. https://github.com/copystring/ioBroker.roborock/tree/get_photo_public_test
                    Das Interessante ist, dass es möglich war, direkt den Code von Roborock zu verwenden, da Roborock eine Zip-Datei herunterlädt, in welcher einiges von der Logik zum Verschlüsseln und Entschlüsseln hinterlegt ist. Dies ist einfach nur nodejs code. Was für ein Zufall, dass ioBroker nodejs ist. :D
                    Wie auch immer, da ich da nicht weiter komme, wird sich da wohl erstmal nicht viel dran ändern, es sei denn, jemand finden heraus, was ich falsch mache.
                    • M mikiline
                      copystringC Offline
                      copystringC Offline
                      copystring
                      #637
                      @mikiline said in Roborock Adapter tester gesucht:
                      Hast du Bilder dazu? Kann mir das so nicht richtig vorstellen, was gemeint ist.
                        mikiline
                        #638
                        @copystring ja klar, bitte schön
                        zonenauswahl
                        zonenreinigung
                        • M mikiline
                          zonenauswahl
                          zonenreinigung
                          copystringC Offline
                          copystringC Offline
                          copystring
                          #639
                          @mikiline also das gleiche Problem wie hier? https://github.com/copystring/ioBroker.roborock/issues/88
                            mikiline
                            #640
                            @copystring
                            dann mach ich jetzt alles stromlos? :-) (spass)
                            ja, genau gleicher fehler.
                            zuvor mit dem "normalen" adapter hatte alles funktioniert, hab dann den DEV drüber installiert.....
                            ich lösche mal den adapter starte den server neu und schau ob es evtl dann gelöst ist.
                              mikiline
                              schrieb am zuletzt editiert von mikiline
                              #641
                              leider keine Abhilfe mit neu Installation, auch eine Browser Cache leeren brachte keinen Erfolg....
                              Sehr seltsam.
                              Wieso hat es davor funktioniert, ist ja die gleiche Berechnung. Oder unterscheiden sich die zones.js?
                              copystringC 2 Antworten Letzte Antwort
                              • M mikiline
                                Sehr seltsam.
                                copystringC Offline
                                copystringC Offline
                                copystring
                                schrieb am zuletzt editiert von copystring
                                #642
                                @mikiline kann eigentlich nicht sein, da die Berechnung der Zonen seit 13. März nicht mehr angefasst wurde.
                                Ganz sicher, dass 0.1.6 in Ordnung ist und die dev nicht?
                                EDIT: Stimmt. Geht tatsächlich nicht. Hatte vergessen, dass ich Zoom eingebaut habe. Die Berechnung der Zonen ist aber noch nicht angepasst.
                                • M mikiline
                                  Sehr seltsam.
                                  copystringC Offline
                                  copystringC Offline
                                  copystring
                                  #643
                                  @mikiline teste bitte mal die neue dev. Konnte den Fehler reproduzieren und beheben.
                                  M 2 Antworten Letzte Antwort
                                    mikiline
                                    #644
                                    @copystring
                                    wir kommen der Sache näher, jedoch stimmt es noch nicht ganz
                                    Falls dies noch hilft (Spawn der Zone)
                                    Nach "Start"
                                    Bekomme übrigens auch immer diesen Fehler angezeigt (Bei Zonenreinigung und auch bei GoTo)
                                    • M mikiline
                                      @copystring
                                      Nach "Start"
                                      copystringC Offline
                                      copystringC Offline
                                      copystring
                                      #645
                                      @mikiline Habe ich mir beides angeguckt. Bitte nochmal testen.
                                        mikiline
                                        #646
                                        @copystring
                                        Perfekt, funktioniert jetzt! Danke für Deine Arbeit
                                        Die Error Meldung kommt aber immer noch, nicht weiter schlimm aber unschön
                                        • M mikiline
                                          @copystring
                                          copystringC Offline
                                          copystringC Offline
                                          copystring
                                          #647
                                          @mikiline bist du dir sicher, dass die Fehlermeldung noch auftaucht? Bei mir taucht sie bei der Zonenreinigung und bei goto nicht auf.
                                          M wendy2702W 2 Antworten Letzte Antwort
                                          -1
