  4. esphome - ERROR: Process exited with code 25
162 Beiträge 12 Kommentatoren 29.4k Aufrufe 5 Beobachtet
  • S Sushibomba
    Habs hinbekommen:
    di@iobroker:~$ iobroker add esphome auto --host iobroker --debug
    NPM version: 9.5.1
    Installing iobroker.esphome@0.2.4... (System call)
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/iobroker.esphome
    npm ERR! command failed
    npm ERR! command sh -c npip install
    npm ERR! No python_modules directory; installing pip locally if needed.
    npm ERR! pip 23.0.1 from /usr/lib/python3/dist-packages/pip (python 3.11)
    npm ERR! error: externally-managed-environment
    npm ERR!
    npm ERR! × This environment is externally managed
    npm ERR! ╰─> To install Python packages system-wide, try apt install
    npm ERR!     python3-xyz, where xyz is the package you are trying to
    npm ERR!     install.
    npm ERR!
    npm ERR!     If you wish to install a non-Debian-packaged Python package,
    npm ERR!     create a virtual environment using python3 -m venv path/to/venv.
    npm ERR!     Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
    npm ERR!     sure you have python3-full installed.
    npm ERR!
    npm ERR!     If you wish to install a non-Debian packaged Python application,
    npm ERR!     it may be easiest to use pipx install xyz, which will manage a
    npm ERR!     virtual environment for you. Make sure you have pipx installed.
    npm ERR!
    npm ERR!     See /usr/share/doc/python3.11/README.venv for more information.
    npm ERR!
    npm ERR! note: If you believe this is a mistake, please contact your Python inst        allation or OS distribution provider. You can override this, at the risk of brea        king your Python installation or OS, by passing --break-system-packages.
    npm ERR! hint: See PEP 668 for the detailed specification.
    npm ERR!     /home/iobroker/.npm/_logs/2023-05-10T19_45_39_054Z-debug-0.log
    host.iobroker Cannot install iobroker.esphome@0.2.4: 1
    di@iobroker:~$
    #149
    @sushibomba sagte in esphome - ERROR: Process exited with code 25:
    Es muss eine Sperrdatei geben.
    Bei Debian kann man die so temporär aus dem Weg räumen:
    mv /usr/lib/python3.11/EXTERNALLY-MANAGED ~
    Ob das bei Ubuntu auch so funktionier weiß ich aber mangels Verwendung nicht.
      Sushibomba
      schrieb am zuletzt editiert von Sushibomba
      #150
      Hat der hier das gleiche Problem wie ich?
      https://askubuntu.com/questions/1465218/pip-error-on-ubuntu-externally-managed-environment-×-this-environment-is-extern
      Auf einer anderen Site habe ich noch das gefunden:
      You can use python venv like described here.
      However if you really want to install packages that way, then there are couple solutions:
      remove file /usr/lib/python3.x/EXTERNALLY-MANAGED,
      use pip's argument --break-system-packages,
      add following lines to ~/.config/pip/pip.conf:
      [global]
      break-system-packages = true
      • S Sushibomba
        [global]
        #151
        @sushibomba
        Wobei das weder ein Fehler oder ein Problem ist, das ist eigentlich ganz bewusst so gemacht worden. Man will python-Pakete nicht mehr auf diese Art installieren, weil das zu zersemmelten Systemen führen kann.
        Also die Sperrdatei temporär aus dem Weg räumen, Pakete installieren und dann die Datei wieder in das Ursprungsverzeichnis zurückkopieren.
        Mach das nicht so wie in dem verlinkten Beitrag, das ist Quark.
          @sushibomba
          Sushibomba
          #152
          Ok also habe ich dann jetzt einfach Pech und kann den Adapter einfach nicht mehr installieren?
          Hat mich jetzt 6 Stunden gekostet alles wieder neu einzurichten. Jeden Adapter einzeln installiert und keine Datenpunkte übernommen sondern alles frisch installiert inkl. Grafana und Influx.
          Möchte nicht noch mal von vorne anfangen :(
          • S Sushibomba
            #153
            Haste die Sperrdatei jetzt weggeräumt?
              Sushibomba
              #154
              Nein ich habe gar nichts auf dein Anraten gemacht :-/
              • S Sushibomba
                #155
                @sushibomba
                Ich hab doch geschrieben, du sollst die Datei in den Home verschieben:
                Ggf. mit sudo, wenn die Rechte nicht ausreichen.
                sudo mv /usr/lib/python3.11/EXTERNALLY-MANAGED ~
                  @sushibomba
                  Sushibomba
                  #156
                  Hab ich gemacht.
                  • S Sushibomba
                    Hab ich gemacht.
                    #157
                    @sushibomba
                    Ja dann...
                      @sushibomba
                      Ja dann...
                      Sushibomba
                      #158
                      Jetzt hat es wieder geklappt den ESPhome Adapter zu installieren 🤠 👏 😍
                      Muss ich die Aktion von eben jetzt wieder rückgängig machen oder so?
                      • S Sushibomba
                        #159
                        @sushibomba
                        Ich würde die Datei wieder zurück schieben.
                          @sushibomba
                          Sushibomba
                          #160
                          Klar kein Problem. Wenn du mir jetzt noch sagen könntest wie :-P
                          • S Sushibomba
                            #161
                            @sushibomba
                            sudo mv ~/EXTERNALLY-MANAGED /usr/lib/python3.11/
                              @sushibomba
                              Sushibomba
                              #162
                              Danke dir wie immer. Auf dich ist immer verlass und du weißt einfach gefühlt alles. Herzlichen Dank 😽
