  4. Adapter Installation und Update nicht möglich
    5.4k
installationupdate
61 Beiträge 4 Kommentatoren 8.4k Aufrufe 2 Beobachtet
  • S SvenH75
    @glasfaser mache ich sofort. Hatte jetzt erst dem Miele Adapter über den iobroker versucht zu aktualisieren
    Da kommt folgende Ausgabe:
    $ iobroker upgrade mielecloudservice@6.5.4 --debug
    Update mielecloudservice from @6.4.0 to @6.5.4
    Installing iobroker.mielecloudservice@6.5.4... (System call)
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
    npm WARN deprecated node-xmpp-tls-connect@1.0.1: this package is deprecated please use https://github.com/xmppjs/xmpp.js
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated node-xmpp-core@5.0.9: this package is deprecated please use https://github.com/xmppjs/xmpp.js
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated node-xmpp-stanza@1.1.1: use @xmpp/xml package <https://www.npmjs.com/package/@xmpp/xml>
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated node-xmpp-client@3.2.0: this package is deprecated please use https://www.npmjs.com/package/@xmpp/client
    Steht schon 5 Min. so da……
    GlasfaserG Offline
    GlasfaserG Offline
    @svenh75 sagte in Adapter Installation und Update nicht möglich:
    Sind nur Verkaufsangebote .
    Process exited with code 0
    alles gut
    • GlasfaserG Glasfaser
      Jetzt erst einmal den js..?
      Ja versuch mal ...
      Ausgabe hier Posten
      SvenH75
      @glasfaser Mist…..
      root@Iobroker: /opt / iobroker# pkill iob
      root@Iobroker: /opt/iobroker# iobroker update
      Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data /objects. jsonI"!
      • S SvenH75
        @glasfaser Mist…..
        GlasfaserG Offline
        GlasfaserG Offline
        @svenh75
        Was machst du da , habe ich alles nicht geschrieben !??
        pkill iob gibt es nicht
        so
        pkill -u iobroker
        lese doch bitte :
        https://docs.buanet.de/iobroker-docker-image/docs/#updates-upgrades
        den Link habe ich schon oben dir gegeben !!!!
          @svenh75
          so
          pkill -u iobroker
          lese doch bitte :
          SvenH75
          @glasfaser Sorry, hab die alten Aufzeichnungen schon gelöscht…..
          Nach dem Befehl „iobroker upgrade“ wenn die Installation durchgelaufen ist, hab ich noch folgendes:
          node node_modules/iobroker.js-/controllercontroller.js >/opt/scripts/docker_iobroker_log.txt 2>&1 &
          Ist das noch notwendig einzugeben bzw. aktuell?
          • S SvenH75
            GlasfaserG Offline
            GlasfaserG Offline
            Welche Aufzeichnung ... habe keine Ahnung was du jetzt meinst .
            Wo steht was .. !?
            Da braucht nichts per Befehl mehr gemacht werden
            Bitte nur ganze Logs zeigen .. das kann jetzt alles sein !
              Wo steht was .. !?
              SvenH75
              @glasfaser Nein, das war nur der Befehl….. lösche ich also auch in den meinen Aufzeichnungen .
              Js hat geklappt, ist jetzt aktuell…..
              Hab nur zwei Fehlermeldungen im Protokoll:
              javascript.0
              2023-05-09 21:23:04.166	error	WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
              javascript.0
              2023-05-09 21:23:04.164	error	npm
              wichtig?
              Muss dann leider erst mal Schluss machen für heute, erst mal tausend Dank und ich verspreche nur noch die korrekten Befehle zu nutzen.
              Werde morgen mal Versuchen einen Adapter zu installieren. Muss wegen den Fehlern beim Deinstallieren der Adapter noch etwas gemacht werden? Soll ich den fixer morgen noch mal laufen lassen?
              VG und Danke
              • S SvenH75
                javascript.0
                javascript.0
                wichtig?
                VG und Danke
                GlasfaserG Offline
                GlasfaserG Offline
                Dazu :
                https://forum.iobroker.net/topic/64513/warn-deprecated-npm-bitte-um-hilfe
                • S SvenH75
                  javascript.0
                  javascript.0
                  wichtig?
                  VG und Danke
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Deinstalliere über die Admin Konsole ,
                  wenn es nicht geht , dann mache ein upload bzw. installiere den Adapter neu , dann deinstallieren .
                    SvenH75
                    @glasfaser ok, Warnmeldungen sind also nix wildes……..
                    Wenn die gelöscht Adapter aus den Instanzen sind ist das also ausreichend, hatte sie ja bisher auch immer über die Admin Konsole gelöscht……..
                    Dann probiere ich morgen eine Neuinstallation eines Adapters und gebe noch mal Rückmeldung…….
                    Die USV besorge ich….. müsste der ioBroker Container von alleine starten oder ist das normal das man das manuell erledigen muss? Ich denke aber, dass das in der Vergangenheit funktioniert hat….weiß es aber nicht genau, da ich schon mal eine USV dran hatte………
                    • S SvenH75
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Ich kenne deine Einstellungen nicht , wie du den Container erstellt hast
                      so sollte es sein :
                      Schau hier Portainer :
                      oder hier Syn Docker :
                        so sollte es sein :
                        SvenH75
                        @glasfaser Hallo, hab den Hacken in Syn gesetzt, danke. Im Portainer hab ich die Einstellung nicht gefunden, denke wird ja aber übernommen.
                        Installation von neuen Adapter hat geklappt 👍, die Installation vom Node-Red Adapter hat aber über 5 min gedauert, hatte ich ja geschrieben, dass auch ein Adapter Update seine Zeit braucht. Ist das systembedingt? Bin der Meinung, dass es früher schneller ging.
                        Kann nur nochmal danke für deine Zeit und Geduld sagen……
