  4. JavaScript
  5. Roborock Adapter tester gesucht
766 Beiträge 51 Kommentatoren 324.3k Aufrufe 52 Beobachtet
  • C cburger
    @copystring, leider zu früh gefreut :-/. Habe über den Adapter den Robo gestartet und dann passiert folgendes und der Adapter geht wieder auf rot und ich kann den Robi nicht mehr über den Adapter bedienen:
    roborock.0
    2023-05-01 14:20:46.037	error	Error executing fileError: Command failed: /opt/iobroker/node_modules/iobroker.roborock/lib/go2rtc/go2rtc_linux_arm -config {"streams":{"2W7IyvOlcOhxokJjog5Zef":"roborock://mqtt-eu-3.roborock.com:8883?u=WedLEYQ1SRPAXKJVQf1Kx&s=YIKfVT&k=lscHyVO1&did=2W7IyvOlcOhxokJjog5Zef&key=2kXf5GJktah1eYuv&pin=1234"}}
    roborock.0
    2023-05-01 14:20:39.182	info	MQTT initialized
    roborock.0
    2023-05-01 14:20:38.634	info	starting. Version 0.1.6 (non-npm: copystring/ioBroker.roborock#dev) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.1, js-controller: 4.0.24
    roborock.0
    2023-05-01 14:20:03.297	error	Error executing fileError: Command failed: /opt/iobroker/node_modules/iobroker.roborock/lib/go2rtc/go2rtc_linux_arm -config {"streams":{"2W7IyvOlcOhxokJjog5Zef":"roborock://mqtt-eu-3.roborock.com:8883?u=WedLEYQ1SRPAXKJVQf1Kx&s=YIKfVT&k=lscHyVO1&did=2W7IyvOlcOhxokJjog5Zef&key=2kXf5GJktah1eYuv&pin=1234"}}
    roborock.0
    2023-05-01 14:19:55.758	info	MQTT initialized
    roborock.0
    2023-05-01 14:19:55.130	info	starting. Version 0.1.6 (non-npm: copystring/ioBroker.roborock#dev) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.1, js-controller: 4.0.24
    roborock.0
    2023-05-01 14:19:11.182	error	Failed to create map. The error was: locating
    roborock.0
    2023-05-01 14:19:09.179	error	Failed to create map. The error was: locating
    roborock.0
    2023-05-01 14:19:07.178	error	Failed to create map. The error was: locating
    roborock.0
    2023-05-01 14:19:05.182	error	Failed to create map. The error was: locating
    roborock.0
    2023-05-01 14:19:03.210	error	Failed to create map. The error was: locating
    roborock.0
    2023-05-01 14:19:01.181	error	Failed to create map. The error was: locating
    roborock.0
    2023-05-01 14:18:59.184	error	Failed to create map. The error was: locating
    roborock.0
    2023-05-01 14:18:57.180	error	Failed to create map. The error was: locating
    roborock.0
    2023-05-01 14:18:55.207	error	Failed to create map. The error was: locating
    roborock.0
    2023-05-01 14:18:53.177	error	Failed to create map. The error was: locating
    roborock.0
    2023-05-01 14:18:51.177	error	Failed to create map. The error was: locating
    roborock.0
    2023-05-01 14:18:49.186	error	Failed to create map. The error was: locating
    roborock.0
    2023-05-01 14:18:43.211	error	Failed to create canvas: {}
    roborock.0
    2023-05-01 14:18:41.221	error	Failed to create canvas: {}
    roborock.0
    2023-05-01 14:18:39.223	error	Failed to create canvas: {}
    roborock.0
    2023-05-01 14:18:36.056	error	Unknown parameter: ["ok"]
    roborock.0
    2023-05-01 14:17:19.953	error	Error executing fileError: Command failed: /opt/iobroker/node_modules/iobroker.roborock/lib/go2rtc/go2rtc_linux_arm -config {"streams":{"2W7IyvOlcOhxokJjog5Zef":"roborock://mqtt-eu-3.roborock.com:8883?u=WedLEYQ1SRPAXKJVQf1Kx&s=YIKfVT&k=lscHyVO1&did=2W7IyvOlcOhxokJjog5Zef&key=2kXf5GJktah1eYuv&pin=1234"}}
    roborock.0
    2023-05-01 14:17:13.572	info	MQTT initialized
    roborock.0
    2023-05-01 14:17:12.924	info	starting. Version 0.1.6 (non-npm: copystring/ioBroker.roborock#dev) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.1, js-controller: 4.0.24
    Neustart des Adapters bringt folgendes:
    roborock.0
    2023-05-01 14:24:25.658	error	Cannot read properties of undefined (reading 'timeout102')
    roborock.0
    2023-05-01 14:24:25.657	error	TypeError: Cannot read properties of undefined (reading 'timeout102') at EventEmitter.listener102 (/opt/iobroker/node_modules/iobroker.roborock/lib/roborock_mqtt_connector.js:248:72) at EventEmitter.emit (/opt/iobroker/node_modules/eventemitter2/lib/eventemitter2.js:1019:19) at MqttClient.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/roborock_mqtt_connector.js:167:9) at MqttClient.emit (node:events:513:28) at MqttClient.emit (node:domain:489:12) at MqttClient._handlePublish (/opt/iobroker/node_modules/mqtt/lib/client.js:1547:12) at MqttClient._handlePacket (/opt/iobroker/node_modules/mqtt/lib/client.js:535:12) at work (/opt/iobroker/node_modules/mqtt/lib/client.js:438:12) at Writable.writable._write (/opt/iobroker/node_modules/mqtt/lib/client.js:452:5) at doWrite (/opt/iobroker/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:390:139)
    roborock.0
    2023-05-01 14:24:25.656	error	uncaught exception: Cannot read properties of undefined (reading 'timeout102')
    roborock.0
    2023-05-01 14:24:25.627	error	Error executing fileError: Command failed: /opt/iobroker/node_modules/iobroker.roborock/lib/go2rtc/go2rtc_linux_arm -config {"streams":{"2W7IyvOlcOhxokJjog5Zef":"roborock://mqtt-eu-3.roborock.com:8883?u=WedLEYQ1SRPAXKJVQf1Kx&s=YIKfVT&k=lscHyVO1&did=2W7IyvOlcOhxokJjog5Zef&key=2kXf5GJktah1eYuv&pin=1234"}}
    roborock.0
    2023-05-01 14:24:25.582	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    roborock.0
    2023-05-01 14:24:25.579	info	terminating
    roborock.0
    2023-05-01 14:24:25.547	error	Exception-Code: EADDRINUSE: listen EADDRINUSE: address already in use :::7906
    roborock.0
    2023-05-01 14:24:25.545	error	Error: listen EADDRINUSE: address already in use :::7906 at Server.setupListenHandle [as _listen2] (node:net:1463:16) at listenInCluster (node:net:1511:12) at Server.listen (node:net:1599:7) at new WebSocketServer (/opt/iobroker/node_modules/ws/lib/websocket-server.js:97:20) at Roborock.startWebsocketServer (/opt/iobroker/node_modules/iobroker.roborock/main.js:272:18) at /opt/iobroker/node_modules/iobroker.roborock/main.js:231:12 at runMicrotasks (<anonymous>) at processTicksAndRejections (node:internal/process/task_queues:96:5)
    roborock.0
    2023-05-01 14:24:25.545	error	uncaught exception: listen EADDRINUSE: address already in use :::7906
    roborock.0
    2023-05-01 14:24:25.504	error	Exception-Code: EADDRINUSE: listen EADDRINUSE: address already in use :::6824
    roborock.0
    2023-05-01 14:24:25.502	error	Error: listen EADDRINUSE: address already in use :::6824 at Server.setupListenHandle [as _listen2] (node:net:1463:16) at listenInCluster (node:net:1511:12) at Server.listen (node:net:1599:7) at Function.listen (/opt/iobroker/node_modules/express/lib/application.js:635:24) at Roborock.startWebserver (/opt/iobroker/node_modules/iobroker.roborock/main.js:265:19) at /opt/iobroker/node_modules/iobroker.roborock/main.js:230:12 at runMicrotasks (<anonymous>) at processTicksAndRejections (node:internal/process/task_queues:96:5)
    roborock.0
    2023-05-01 14:24:25.500	error	uncaught exception: listen EADDRINUSE: address already in use :::6824
    roborock.0
    2023-05-01 14:24:18.990	info	MQTT initialized
    roborock.0
    2023-05-01 14:24:18.431	info	starting. Version 0.1.6 (non-npm: copystring/ioBroker.roborock#dev) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.1, js-controller: 4.0.24
    copystringC Offline
    copystringC Offline
    copystring
    #614
    @cburger OK.
    Dann bitte auf GitHub ein Issue eröffnen. Dort dann das vollständige debug log einfügen.
    Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
    https://paypal.me/copystring
    C 1 Antwort Letzte Antwort
    • copystringC copystring
      @cburger OK.
      cburger
      #615
      @copystring, habe ich erstellt. Dank dir - so far!
      CCU3 mit 2 Extender mit >515 Kanäle an 84 Homematic und HomematicIP Geräten / Iobroker @ Raspberry 3 / SQL Server @ Synology NAS / WebMatic im Einsatz
      • VumerV Offline
        VumerV Offline
        Vumer
        #616
        Ich bekomme sporadisch verschiedene Fehlermeldungen:
        roborock.0    2023-05-01 11:49:55.685	error	Unknown parameter: ["ok"]
        host.iobroker 2023-05-01 11:48:27.276	error	Invalid request getRepository. "callback" or "from" is null
        oder
        roborock.0 2023-05-01 17:17:34.190	error	Failed to create map. The error was: retry
        k.A. ob die für GitHub interessant sind.
        copystringC 1 Antwort Letzte Antwort
        • VumerV Vumer
          oder
          copystringC Offline
          copystringC Offline
          copystring
          #617
          @vumer said in Roborock Adapter tester gesucht:
          Das ist rein kosmetisch. Tut erstmal nichts zur sache.
          oder
          Der Roboter ist gerade mit etwas anderen beschäftigt. Daher kann gerade nicht eine neue Karte bezogen werden.
          VumerV 1 Antwort Letzte Antwort
            oder
            VumerV Offline
            VumerV Offline
            Vumer
            #618
            @copystring sagte in Roborock Adapter tester gesucht:
            hab irgendwie Allergie auf rot ;)
            • VumerV Vumer
              Kusi
              #619
              Hallo zusammen
              Ich habe seit einer Woche den Roborock S7 MaxV, nutze aber seither die XiaomiHome App und den passenden Adapter im ioBroker.
              Erst im Nachhinein habe ich gesehen, dass es einen passenden "Roborock"-Adapter auf Github gibt.
              Nun zu meinen Fragen (betrifft diesen Adapter):
              -Ist es möglich, mehrere Räume hintereinander reinigen zu lassen, ohne dass der Roboter zwischen den Räumer auf die Ladestation fährt?
              -Kann der Wischen und/oder Saugen Modus geändert werden? Für jeden einzelnen Raum oder nur die komplette Reinigung?
              Ich habe vor, mehrere Favoriten zu erstellen.
              -Reinigung von 4 der 7 Räume
              -Reinigung von 2 der 7 Räume
              -Einstellung für mit/ohne Wischen
              • K Kusi
                Hallo zusammen
                David G.D Online
                David G.D Online
                David G.
                #620
                @kusi sagte in Roborock Adapter tester gesucht:
                Ja, das geht
                Komplette Reinigung.
                Per Skript (Zb Blockly) möglich.
                • copystringC Offline
                  copystringC Offline
                  copystring
                  #621
                  Hallo Leute,
                  ich benötige mal eure Hilfe.
                  Dies trifft nur diejenigen zu, bei denen die Kartenerstellung auf einem Raspberry Pi nicht läuft.
                  Ich hatte einen Fall, in dem es gereicht hat, folgendes ins Terminal auf dem Pi einzugeben und danach lief die Karte.
                  cd /opt/iobroker/node_modules/iobroker.roborock/
                  npm install canvas
                  Danach den Adapter neu starten. Kartenerstellung aktivieren und am besten direkt über das Webinterface (z. B. http://iobroker:6824/map.html) ausprobieren.
                  Über kurze Rückmeldungen würde ich mich freuen. Danke im Voraus für eure Mithilfe! 👍
                  David G.D D 2 Antworten Letzte Antwort
                    Hallo Leute,
                    npm install canvas
                    David G.D Online
                    David G.D Online
                    David G.
                    #622
                    @copystring
                    Kann jetzt leider nicht testen, wie es sich beim putzen verhält, da es zu spät ist.
                    Jedoch kann ich über load_multimap eine Etage laden und das Bild ändert sich erfolgreich.
                    EDIT
                    Jetzt konnte ich richtig testen. Das erste Bild nach Adapterstart klappt. Dann stürzt der Adapter ab.
                    Das heißt, wenn der Roboter fährt bekomme ich nach jedem Adapterstart genau ein neues Bild bis er abstürzt.
                      Hallo Leute,
                      npm install canvas
                      Dimi
                      #623
                      @copystring
                      also ich hatte ja zuerst die 32 Bit Version auf dem Raspi4. Dort lief der Adapter kurz, jedoch lief das Log der Raspi voll so daß am Ende die SD Karte kein Speicher mehr hatte und sich die Raspi komplett aufgehängt hat. Nach dem Wechsel auf die die 64 Bit Version, ist das Speicherproblem gelöst, jedoch stützt der Adapter nach einiger Zeit ab. Ich muss ihn dann manuell wieder starten. Die Kartendarstellung funktioniert aber. Ich sehe den Sauger auf der Karte, bis halt irgendwann der Adpter wieder abstürzt.
                        copystringC Offline
                        copystring
                        #624
                        Mal bitte die neue dev testen.
                        Außerdem suche ich aktuell Hilfe von jemanden, der sich mit reverse Engineering und rsa gut auskennt. Ich bin kurz davor, die Fotos abrufbar zu machen, die von den MaxV Robotern erstellt werden, wenn Hindernisse erkannt werden.
                        Ich kann die entsprechende Anfrage an den Server stellen und bekomme die passende Antwort. Die Daten werden mit einem vom Adapter erstellen public key verschlüsselt und müssen dann mit dem ebenfalls vom Adapter erstellten private key wieder entschlüsselt werden und da komme ich nicht weiter. Sehr wahrscheinlich gibt es irgendeinen Offset oder ähnliches. Möglicherweise müssen die Daten vorher in irgendeiner Form umgewandelt werden, bevor diese wieder entschlüsselt werden können. Kennt einer von euch da jemanden? @rovo89 bist du vielleicht hier noch aktiv und kannst aushelfen?
                        Eigentlich ist das der Grund, warum es bisher keinen neuen Release gab.
                          mikiline
                          #625
                          hi @copystring
                          danke für den adapter, sehr gut.
                          gibt es eine möglichkeit zonen zu speichern? (evtl aus der webseite raus)
                          und irgendwie in einem datenpunkt zu speichern
                          • M mikiline
                            hi @copystring
                            copystringC Offline
                            copystringC Offline
                            copystring
                            #626
                            @mikiline Wenn du über die Webseite (z. B. bei mir http://iobroker:6824/map.html) die Konsole des Browsers aufrufst, kannst du dir die Zonen in Koordinaten anzeigen lassen und diese dann über Blockly oder ähnlich an roborock.0.Devices.XXX.commands.app_zoned_clean senden, um den entsprechenden Bereich reinigen zu lassen.
                            Mal den Thread durchsuchen. Da wurde das bereits genauer besprochen.
                              mikiline
                              schrieb am zuletzt editiert von mikiline
                              #627
                              @copystring
                              vielen dank, ich bin auch schon ein stück weiter gekommen
                              zumindest habe ich jetzt mal koordinaten und weiss wie ich daran komme
                              zone: [27375,26300,28975,27600,1]
                              wie gebe ich das nun über blockly an den adapter?
                              "commands.app_zoned_clean" ist doch true, false
                              mir fehlt auch ein datenpunkt "GoTo", wie schickt man den roboter an eine bestimmte stelle?
                              wurde aus den ganzen beiträgen nicht ganz schlau daraus
                              vielleicht kann @Spampunk auch ein beispiel geben, scheint dort zum einsatz zu kommen
                                DonToben
                                #628
                                @copystring
                                Mit der neusten DEV heute folgende Meldungen:
                                Eine Idee? WLAN Verbindung ist eigentlich stabil.
                                	2023-05-07 18:01:54.408	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                roborock.0
                                	2023-05-07 18:01:53.720	error	Request with id 2526 timed out after 10 seconds for response.102
                                roborock.0
                                	2023-05-07 18:01:53.719	error	Error: Request with id 2526 timed out after 10 seconds for response.102 at /opt/iobroker/node_modules/iobroker.roborock/lib/roborock_mqtt_connector.js:272:12 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1119:13) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
                                roborock.0
                                	2023-05-07 18:01:53.716	error	unhandled promise rejection: Request with id 2526 timed out after 10 seconds for response.102
                                roborock.0
                                	2023-05-07 18:01:53.715	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                host.raspberrypi
                                	2023-05-07 17:59:33.447	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                roborock.0
                                	2023-05-07 17:59:32.813	error	Request with id 3075 timed out after 10 seconds for response.102
                                roborock.0
                                	2023-05-07 17:59:32.812	error	Error: Request with id 3075 timed out after 10 seconds for response.102 at /opt/iobroker/node_modules/iobroker.roborock/lib/roborock_mqtt_connector.js:272:12 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1119:13) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
                                roborock.0
                                	2023-05-07 17:59:32.808	error	unhandled promise rejection: Request with id 3075 timed out after 10 seconds for response.102
                                roborock.0
                                	2023-05-07 17:59:32.807	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                host.raspberrypi
                                	2023-05-07 17:48:12.772	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                roborock.0
                                	2023-05-07 17:48:12.105	error	Request with id 3632 timed out after 10 seconds for response.102
                                roborock.0
                                	2023-05-07 17:48:12.105	error	Error: Request with id 3632 timed out after 10 seconds for response.102 at /opt/iobroker/node_modules/iobroker.roborock/lib/roborock_mqtt_connector.js:272:12 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1119:13) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
                                roborock.0
                                	2023-05-07 17:48:12.102	error	unhandled promise rejection: Request with id 3632 timed out after 10 seconds for response.102
                                roborock.0
                                	2023-05-07 17:48:12.101	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                • M mikiline
                                  @copystring
                                  copystringC Offline
                                  copystringC Offline
                                  copystring
                                  #629
                                  @mikiline du müsstest dir mal die aktuelle dev installieren. Da geht das.
                                  • D DonToben
                                    @copystring
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    host.raspberrypi
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    host.raspberrypi
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    copystringC Offline
                                    copystringC Offline
                                    copystring
                                    #630
                                    @dontoben Das sieht nicht aus wie aktuelle dev. In der aktuellen dev werden alle Timeouts als Warnung ausgegeben und nicht als Error.
                                      DonToben
                                      #631
                                      @copystring said in Roborock Adapter tester gesucht:
                                      Unter benutzerdefinierte Adapterinstallation doch nur den Link https://github.com/copystring/ioBroker.roborock/tree/dev eintragen und installieren, oder?
                                      Hatte das gestern mehrfach gemacht. Auch Adapter zuvor deinstalliert. Immer das gleiche Problem. Ging jetzt auf den Main zurück. Der funktioniert.
                                        DonToben
                                        #632
                                        Befehl ausführen
                                        Process exited with code 0
                                        weniger
                                        mehr
                                        $ iobroker url https://github.com/copystring/ioBroker.roborock/tree/dev --host raspberrypi --debug
                                        install copystring/ioBroker.roborock#dev
                                        NPM version: 9.5.1
                                        Installing copystring/ioBroker.roborock#dev... (System call)
                                        66 packages are looking for funding run `npm fund` for details
                                        upload [13] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                        upload [12] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                        upload [10] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                        upload [9] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                        upload [7] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                        upload [6] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                        upload [3] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                        upload [2] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/jsonConfig.json jsonConfig.json application/json
                                        upload [1] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/roborock.png roborock.png image/png
                                        upload [0] roborock.admin /opt/iobroker/node_modules/iobroker.roborock/admin/words.js words.js application/javascript
                                        Update "system.adapter.roborock.0"
                                        Hier der Log der Installation. Die aktuelle Dev funktioniert bei mir nicht.
                                          mikiline
                                          #633
                                          @copystring vielen Dank, die hab ich nun installiert und goto ist vorhanden ;)
                                          was ich aber jetzt festgestellt habe ist, wenn ich über webseite (Map) eine zone in die karte mache und auf start klicke, fährt der roboter los, jedoch ist die zone nicht dort wo ich sie eingezeichnet habe (wird ja grün umrandet)
