  4. [neuer Adapter] smartgarden adapter for Gardena smart system
    6.3k
gardena smart systemsmartgarden
1.1k Beiträge 108 Kommentatoren 439.1k Aufrufe 101 Beobachtet
  • jpgorganizerJ jpgorganizer
    @saschas
    du hast die LoginProcedur noch nicht umgestellt auf Application Secret und API-Key. Es gibt von mir keinen Support mehr für Login mit USername + Passwort. .... Steht auch im Readme
    SaschaS
    #972
    @jpgorganizer Danke für den Tipp! Das war mir gar nicht so bewusst, dass bei mir der Adapter nicht auf Application Secret und API-Key läuft. Als ich den Adapter seinerseits installiert habe, habe ich offenbar nur Application Key, aber nicht den Application Secret eingetragen gehabt. 😲
    Warum weiß ich auch nicht. Die Informationen waren ja da...
    Also mal kurz die Daten eingetragen. Adapter neugestartet. Jetzt abwarten bis zum nächsten Triggerpunkt. Erstmal schauen die Logins fehlerfrei aus :-)
    smartgarden.0
    2022-08-04 12:54:57.833	info	3/ get_locations ...
    smartgarden.0
    2022-08-04 12:54:57.832	info	3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXX-XXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXX-XXXXXXXXXXXXXX
    smartgarden.0
    2022-08-04 12:54:57.830	info	3/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
    smartgarden.0
    2022-08-04 12:54:57.829	info	3/ Connection: successful: response.statusCode / statusMessage=200 / OK
    smartgarden.0
    2022-08-04 12:54:57.745	info	3/ ---> State change by device: state sg.0.info.adapterversion changed: 2.0.0 (ack = true)
    smartgarden.0
    2022-08-04 12:54:57.659	info	3/ ---> State change by device: state sg.0.info.revision changed: Main: 2831 / API: 2831 (ack = true)
    smartgarden.0
    2022-08-04 12:54:57.655	info	3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
    smartgarden.0
    2022-08-04 12:54:57.647	info	3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
    smartgarden.0
    2022-08-04 12:54:57.637	info	3/ sgSetState: info.revision value=Main: 2831 / API: 2831 ack=true
    smartgarden.0
    2022-08-04 12:54:57.562	info	3/ connect ... using client credentials grant
    smartgarden.0
    2022-08-04 12:54:57.561	info	3/ connect ... empty password
    smartgarden.0
    2022-08-04 12:54:57.560	info	3/ connect ... empty username
    smartgarden.0
    2022-08-04 12:54:57.560	info	3/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
    smartgarden.0
    2022-08-04 12:54:57.559	info	3/ connecting to Gardena Smart System Service ...
    smartgarden.0
    2022-08-04 12:54:57.557	info	3/ sgSetState: info.connection value=false ack=true
    smartgarden.0
    2022-08-04 12:54:57.553	info	3/ connectToGardena...
    smartgarden.0
    2022-08-04 12:54:57.551	info	3/ getConnection...
    smartgarden.0
    2022-08-04 12:54:57.488	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v14.19.3, js-controller: 4.0.23
    smartgarden.0
    2022-08-04 12:54:51.480	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    smartgarden.0
    2022-08-04 12:54:51.479	info	terminating
    DANKE!!!
      @mameier1234 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
      Ich steuere die Duration_value eines Bewässerungsventils an.
      immer mit dem gleichen Wert? Machst du das manuell?
      wenn dann aber ein paar Stunden ins Land gehen, dann kommt immer wieder mal der Fehler 400... der geht erst weg, wenn ich die Instanz neu starte...
      Was heißt "ein paar Stunden ins Land gehen"? Siehst du eine Zeitabhängigkeit?
      Woher weißt du, dass der dann nur weggeht, wenn du neu startest? Was hast du sonst so versucht?
      Mach mal ein Log - Level 3 einschalten!
      mameier1234
      #973
      @jpgorganizer Kaum beobachtet man die Sache, passiert es nicht mehr :-)
      Ich hatte jetzt keinerlei Probleme mehr.. (und das Logging wieder rungtergedreht..)
      Grüße,
      Martin
        mk712
        schrieb am zuletzt editiert von mk712
        #974
        ich habe meinen Sileno Mäher ein paar Wochen "ausgesetzt", demzufolge Adapter und Scripte pausiert. Jetzt, nach der Re-Aktivierung und Aktualisierung des Adapters habe ich war sofort wieder Verbindung bekommen (alles hübsch grün), jedoch aktualisieren sich die DP nicht mehr. Der Zeitstempel wird regelmäßig gesetzt, aber eben ohne Aktualisierung. Eine Befehlsübergabe per Script oder DP-Eintrag an den Mäher funktioniert, es kommt nur nichts zurück. Zudem fehlen nach der "Neuanlage" des DP-Baumes einige mir wichtige Datenpunkte wie z.B. "lastErrorCode_value". Dazu habe ich im Changelog der neuen Adapterversion 2 zwar etwas gelesen (function and configuration parameter pre-define states removed. All Gardena data points get deleted and created again) - da steh aber nix von gibt es nicht mehr?!
        Kann mir da jemand folgen und helfen?
        btw. - hab nur einen Mäher, keine weiteren Geräte.
        Danke und Grüße
        MK
        EDIT 1: es sieht wohl so aus, das der Mäher das Problem selbst verursacht, also keine Meldungen an das System inkl. sich selbst absetzt...
        EDIT 2: am Mähroboter hatte sich wohl das Funkmodul "aufgehängt", nach dem Ab- und Anstecken des Akku, was einen Neustart des Funkmoduls initiierte, läuft alles wie gehabt.
        Ein großes Dankeschön für diesen wertvollen Adapter!
        • S SaschaS
          smartgarden.0
          smartgarden.0
          smartgarden.0
          smartgarden.0
          smartgarden.0
          smartgarden.0
          smartgarden.0
          smartgarden.0
          smartgarden.0
          smartgarden.0
          smartgarden.0
          smartgarden.0
          smartgarden.0
          smartgarden.0
          smartgarden.0
          smartgarden.0
          smartgarden.0
          smartgarden.0
          smartgarden.0
          smartgarden.0
          DANKE!!!
          manuel35i
          #975
          Kurze Frage warum ist bei mir das Feld Application Secret ausgegraut.
          Kann leider nichts eingeben.
          • M manuel35i
            mameier1234
            #976
            @manuel35i Weil entweder Secret oder Benutzername-Passwort...
            Grüße,
            Martin
            • M mameier1234
              manuel35i
              #977
              @mameier1234
              Dankeschön für die Info
              • R Offline
                Roadrunner
                #978
                zwar etwas Off-Topic, aber hat eigentlich schon jemand versucht das Ganze ohne das Gardena Gateway aufzuziehen? (zB esp32 und 868Mhz-Modul oder Lemonbeat-Dongle)
                Schöne Grüße!
                • C Offline
                  ChrisChros
                  #979
                  Hat sonst noch wer Problem mit der Verbindung zum Server von Gardena?
                  Bekomme seit heute Mittag folgende Fehlermeldung:
                  2023-05-03 11:38:59.156 - error: smartgarden.0 (20631) Error: request returned 403 Forbidden
                  Das ganze wiederholt sich alle 5 Minuten.
                  Gruß Chris
                  B N M 3 Antworten Letzte Antwort
                  • C ChrisChros
                    Gruß Chris
                    BlueBook
                    schrieb am zuletzt editiert von BlueBook
                    #980
                    @chrischros is bei mir auch so :(
                    Ich hab das firmware update durchgeführt. Ich denke daran liegt es :/
                    Obwohl du hast recht. Es gab vorher auch schon Probleme.
                    Über die App von Gardena läuft es, hm
                    C 1 Antwort Letzte Antwort
                    • B BlueBook
                      ChrisChros
                      #981
                      @bluebook ich denke an dem Update liegt es nicht denn das habe ich schon seit dem Wochenende drauf als ich alles wieder reaktiviert habe.
                      Die Fehlermeldung habe ich aber erst seit heute, davor gab es keine Auffälligkeiten.
                      • C ChrisChros
                        Gruß Chris
                        N Offline
                        N Offline
                        netfriend
                        #982
                        @chrischros sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                        Gruß Chris
                        Ja, ist bei mir auch so.
                        Ich habe aber keinerlei Änderungen am System vorgenommen.
                        • JohGreJ Offline
                          JohGreJ Offline
                          JohGre
                          #983
                          gibt schon eine Thread dazu.
                          https://forum.iobroker.net/topic/65105/adapter-smartgarden-fehler-403?_=1683132394304
                          nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
                          • C ChrisChros
                            Gruß Chris
                            mirage
                            #984
                            @chrischros
                            bei mir das Gleiche, seit 13:30 alle 5 min die selbe Fehlermeldung.
                            Keine Änderung am System.
                            P 1 Antwort Letzte Antwort
                            • M mirage
                              @chrischros
                              Pino72
                              #985
                              Dito....
                              jpgorganizerJ 1 Antwort Letzte Antwort
                              • P Pino72
                                Dito....
                                jpgorganizerJ Offline
                                jpgorganizer
                                #986
                                https://forum.iobroker.net/topic/65105/adapter-smartgarden-fehler-403/5?_=1683207342760
                                smartgarden Adapter für GARDENA smart system
                                Plattform: Raspberry Pi OS Linux 12 (bookworm), Node.js: v18.18.2, NPM: 9.8.1
                                  Pistus
                                  #987
                                  @jpgorganizer Hallo, auf meinem Raspberry Py 3B V2.1 habe ich iobroker installiert und kann mittels ssh und auch über die URL auf iobroker zugreifen.
                                  Bei Husqvarna habe ich mich registriert und habe jetzt eine Authentication API, eine Automover Connect API und eine Gardena smart System API. Alle drei API's haben ein Applications Key un ein Applications sekret
                                  Gardena smart Garden habe ich installiert und muss in der Instanz jetzt key und secret eintragen. Aber von welcher API? Entschuldigt bitte die simple Frage, aber ich bin absoluter Neuling und unbedarft. Ich möchte iobroker nutzen um meinen smart Sileno Möhroboter bei Regen zu stoppen.
                                  Grüße, Franz
                                  • P Pistus
                                    Grüße, Franz
                                    jpgorganizer
                                    #988
                                    @pistus sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                    .... ich habe jetzt eine Authentication API, eine Automover Connect API und eine Gardena smart System API. Alle drei API's haben ein Applications Key un ein Applications sekret ...
                                    falsch, du hast eine Applikation mit zugeordneten APIs und die Applikation hat einen key und ein secret - ich glaube nicht, dass das bei dir anders sein wird
                                    und die Automower Connect API brauchst du für den smartgarden Adapter nicht.
                                    siehe https://github.com/jpgorganizer/ioBroker.smartgarden#requirements
                                      Pistus
                                      #989
                                      @jpgorganizer Danke für die Info und den Link, den ich noch nicht kannte.
                                      • P Pistus
                                        Pistus
                                        schrieb am zuletzt editiert von Pistus
                                        #990
                                        @pistus Verbunden mit Gerät oder Dienst bleibt rot. Das Testskript habe ich im Editor kopiert. Ich bekomme das seit 2 Tagen nicht hin.
                                        smartgarden.0
                                        2023-05-16 13:27:53.284 error Error: request returned 404 Not Found
                                        • P Offline
                                          Pistus
                                          #991
                                          könnte sich bitte jemand die Logdatei ansehen und mir mitteilen, was falsch ist?
                                          M jpgorganizerJ 2 Antworten Letzte Antwort
