  4. [neuer Adapter] smartgarden adapter for Gardena smart system
    6.3k
gardena smart systemsmartgarden
1.1k Beiträge 108 Kommentatoren 439.1k Aufrufe 101 Beobachtet
    SaschaS
    #968
    @jpgorganizer Ich musste ähnlich wie @mameier1234 feststellen, dass heute Nacht nur 1 von 3 Ventile angesteuert wurden. Aus den Logs werde ich nicht schlau. Hast du einen heißen Tipp für mich/uns?
    Ventil 1 hätte um 3 Uhr geöffnet werden soll:
    03:00:00.178	info:	javascript.0 (17790) script.js.SprinkleControl.SprinkleControl_Hilfsfunktion: SprinkleControl startet Bewässerung Rasen_Terasse
    03:00:00.179	warn:	javascript.0 (17790) You are assigning a number to the state "smartgarden.0.LOCATION_914e62a7-2D5346-2D4eff-2D97b9-2Db729129a328a.DEVICE_5fe75004-2D52d0-2D4d52-2D9d37-2Dfa485a0111bd.SERVICE_VALVE_5fe75004-2D52d0-2D4d52-2D9d37-2Dfa485a0111bd-3A6.duration_value" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
    03:00:00.190	warn:	javascript.0 (17790) at Object. (script.js.SprinkleControl.SprinkleControl_Hilfsfunktion:6:5)
    03:00:00.204	info:	javascript.0 (17790) State value to set for "smartgarden.0.LOCATION_914e62a7-2D5346-2D4eff-2D97b9-2Db729129a328a.DEVICE_5fe75004-2D52d0-2D4d52-2D9d37-2Dfa485a0111bd.SERVICE_VALVE_5fe75004-2D52d0-2D4d52-2D9d37-2Dfa485a0111bd-3A6.duration_value" has to be type "string" but received type "number"
    03:00:00.221	info:	sprinklecontrol.0 (20159) Set (calculation) ID: Rasen_Terasse, value: true, duration: 45:11
    03:00:01.115	info:	sprinklecontrol.0 (20159) Start zur festen Zeit (Fr) um 03:00
    03:00:20.254	info:	smartgarden.0 (20048) 2/ Valve command failure, options.url=https://api.smart.gardena.dev/v1/command/5fe75004-52d0-4d52-9d37-fa485a0111bd:6
    03:00:20.254	info:	smartgarden.0 (20048) 2/ Valve command failure: return with error
    03:00:20.254	info:	smartgarden.0 (20048) 2/ Valve command failure. No response
    03:00:20.255	error	: smartgarden.0 (20048) Error: Valve command failure. No response
    03:04:54.434	info:	smartgarden.0 (20048) 2/ ++ Closing connection. Reason: Too many missed heartbeats.
    03:05:24.438	info:	smartgarden.0 (20048) 2/ on_close: ### closed ### close.code=1006 close.reason=
    03:05:24.439	info:	smartgarden.0 (20048) 2/ on_close: trying to reconnect
    03:05:24.439	info:	smartgarden.0 (20048) 2/ reconnect!
    03:05:24.440	info:	smartgarden.0 (20048) 2/ reconnectWithRefreshToken!!!!
    Ventil 2 hätte um 03:45 Uhr geöffnet werden sollen
    03:40:24.696	info:	smartgarden.0 (20048) 2/ Connection failure.
    03:40:24.696	info:	smartgarden.0 (20048) 2/ Connection failure:..return with error
    03:40:24.697	error	: smartgarden.0 (20048) Error: no connect response
    03:40:24.697	info:	smartgarden.0 (20048) 2/ getConnection: returned connection error: no connect response
    03:40:24.697	info:	smartgarden.0 (20048) 2/ getConnection: trying to connect again in 300 seconds
    03:45:13.667	info:	javascript.0 (17790) script.js.SprinkleControl.SprinkleControl_Hilfsfunktion: SprinkleControl beendet Bewässerung Rasen_Terasse
    03:45:13.676	error	: smartgarden.0 (20048) Error: sendCommand: command not send, because not connected to Gardena Webservice
    03:45:13.741	info:	sprinklecontrol.0 (20159) Set (calculation) ID: Rasen_Terasse, value: false
    03:45:16.654	info:	javascript.0 (17790) script.js.SprinkleControl.SprinkleControl_Hilfsfunktion: SprinkleControl startet Bewässerung Rasen_Oben
    03:45:16.656	info:	sprinklecontrol.0 (20159) Set (calculation) ID: Rasen_Oben, value: true, duration: 34:58
    03:45:16.654	warn:	javascript.0 (17790) You are assigning a number to the state "smartgarden.0.LOCATION_914e62a7-2D5346-2D4eff-2D97b9-2Db729129a328a.DEVICE_5fe75004-2D52d0-2D4d52-2D9d37-2Dfa485a0111bd.SERVICE_VALVE_5fe75004-2D52d0-2D4d52-2D9d37-2Dfa485a0111bd-3A5.duration_value" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
    03:45:16.659	warn:	javascript.0 (17790) at Object. (script.js.SprinkleControl.SprinkleControl_Hilfsfunktion:18:5)
    03:45:16.669	info:	javascript.0 (17790) State value to set for "smartgarden.0.LOCATION_914e62a7-2D5346-2D4eff-2D97b9-2Db729129a328a.DEVICE_5fe75004-2D52d0-2D4d52-2D9d37-2Dfa485a0111bd.SERVICE_VALVE_5fe75004-2D52d0-2D4d52-2D9d37-2Dfa485a0111bd-3A5.duration_value" has to be type "string" but received type "number"
    03:45:16.677	error	: smartgarden.0 (20048) Error: sendCommand: command not send, because not connected to Gardena Webservice
    03:45:24.698	info:	smartgarden.0 (20048) 2/ getConnection...
    03:45:24.698	info:	smartgarden.0 (20048) 2/ connectToGardena...
    03:45:24.699	info:	smartgarden.0 (20048) 2/ connecting to Gardena Smart System Service ...
    03:45:24.699	info:	smartgarden.0 (20048) 2/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
    03:45:24.700	info:	smartgarden.0 (20048) 2/ connect ... empty application secret
    03:45:24.700	info:	smartgarden.0 (20048) 2/ connect ... using password grant
    03:45:24.727	info:	smartgarden.0 (20048) 2/ Connection failure: return with error
    03:45:24.727	info:	smartgarden.0 (20048) 2/ Connection failure.
    03:45:24.728	info:	smartgarden.0 (20048) 2/ Connection failure:..return with error
    03:45:24.728	error	: smartgarden.0 (20048) Error: no connect response
    03:45:24.729	info:	smartgarden.0 (20048) 2/ getConnection: returned connection error: no connect response
    03:45:24.729	info:	smartgarden.0 (20048) 2/ getConnection: trying to connect again in 300 seconds
    03:50:24.730	info:	smartgarden.0 (20048) 2/ getConnection...
    03:50:24.731	info:	smartgarden.0 (20048) 2/ connectToGardena...
    03:50:24.731	info:	smartgarden.0 (20048) 2/ connecting to Gardena Smart System Service ...
    03:50:24.731	info:	smartgarden.0 (20048) 2/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
    03:50:24.732	info:	smartgarden.0 (20048) 2/ connect ... empty application secret
    Ventil 3 um 4:20 Uhr <- da hat es dann geklappt
    04:17:55.931	info:	smartgarden.0 (20048) 2/ on_pong: ++ pong'ed ++
    04:20:13.782	info:	javascript.0 (17790) script.js.SprinkleControl.SprinkleControl_Hilfsfunktion: SprinkleControl beendet Bewässerung Rasen_Oben
    04:20:13.831	info:	sprinklecontrol.0 (20159) Set (calculation) ID: Rasen_Oben, value: false
    04:20:14.754	info:	smartgarden.0 (20048) 2/ Valve command successful. options.url=https://api.smart.gardena.dev/v1/command/5fe75004-52d0-4d52-9d37-fa485a0111bd:5 response.statusCode/Message=202/Accepted
    04:20:16.716	info:	javascript.0 (17790) script.js.SprinkleControl.SprinkleControl_Hilfsfunktion: SprinkleControl startet Bewässerung Rasen_Küche
    04:20:16.717	info:	sprinklecontrol.0 (20159) Set (calculation) ID: Rasen_Küche, value: true, duration: 45:11
    04:20:16.716	warn:	javascript.0 (17790) You are assigning a number to the state "smartgarden.0.LOCATION_914e62a7-2D5346-2D4eff-2D97b9-2Db729129a328a.DEVICE_5fe75004-2D52d0-2D4d52-2D9d37-2Dfa485a0111bd.SERVICE_VALVE_5fe75004-2D52d0-2D4d52-2D9d37-2Dfa485a0111bd-3A4.duration_value" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
    04:20:16.721	warn:	javascript.0 (17790) at Object. (script.js.SprinkleControl.SprinkleControl_Hilfsfunktion:30:5)
    04:20:16.734	info:	javascript.0 (17790) State value to set for "smartgarden.0.LOCATION_914e62a7-2D5346-2D4eff-2D97b9-2Db729129a328a.DEVICE_5fe75004-2D52d0-2D4d52-2D9d37-2Dfa485a0111bd.SERVICE_VALVE_5fe75004-2D52d0-2D4d52-2D9d37-2Dfa485a0111bd-3A4.duration_value" has to be type "string" but received type "number"
    04:20:17.599	info:	smartgarden.0 (20048) 2/ Valve command successful. options.url=https://api.smart.gardena.dev/v1/command/5fe75004-52d0-4d52-9d37-fa485a0111bd:4 response.statusCode/Message=202/Accepted
    04:20:18.123	info:	smartgarden.0 (20048) 2/ parseMessage: VALVE_SET found
    04:20:18.123	info:	smartgarden.0 (20048) 2/ setServiceStates: relationship searching
    04:20:18.128	info:	smartgarden.0 (20048) 2/ parseMessage: VALVE found
    jpgorganizerJ 1 Antwort Letzte Antwort
    • S SaschaS
      jpgorganizerJ Offline
      jpgorganizer
      #969
      @saschas sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
      ein Log mit Level 3 könnte mehr Aufschluss geben
      Du hast ein Verbindungsproblem. Les mal die Logausgaben.
      smartgarden Adapter für GARDENA smart system
      Plattform: Raspberry Pi OS Linux 12 (bookworm), Node.js: v18.18.2, NPM: 9.8.1
      • jpgorganizerJ jpgorganizer
        SaschaS
        #970
        @jpgorganizer Hab jetzt das Loglevel auf 3 geändert.
        Hoffentlich ist man dann beim nächsten Mal schlauer. Ich tue mir schwer auf den Logs jetzt irgendwas erkennen zu können. :(
        • S SaschaS
          jpgorganizer
          #971
          @saschas
          du hast die LoginProcedur noch nicht umgestellt auf Application Secret und API-Key. Es gibt von mir keinen Support mehr für Login mit USername + Passwort. .... Steht auch im Readme
            @saschas
            SaschaS
            #972
            @jpgorganizer Danke für den Tipp! Das war mir gar nicht so bewusst, dass bei mir der Adapter nicht auf Application Secret und API-Key läuft. Als ich den Adapter seinerseits installiert habe, habe ich offenbar nur Application Key, aber nicht den Application Secret eingetragen gehabt. 😲
            Warum weiß ich auch nicht. Die Informationen waren ja da...
            Also mal kurz die Daten eingetragen. Adapter neugestartet. Jetzt abwarten bis zum nächsten Triggerpunkt. Erstmal schauen die Logins fehlerfrei aus :-)
            smartgarden.0
            2022-08-04 12:54:57.833	info	3/ get_locations ...
            smartgarden.0
            2022-08-04 12:54:57.832	info	3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXX-XXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXX-XXXXXXXXXXXXXX
            smartgarden.0
            2022-08-04 12:54:57.830	info	3/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
            smartgarden.0
            2022-08-04 12:54:57.829	info	3/ Connection: successful: response.statusCode / statusMessage=200 / OK
            smartgarden.0
            2022-08-04 12:54:57.745	info	3/ ---> State change by device: state sg.0.info.adapterversion changed: 2.0.0 (ack = true)
            smartgarden.0
            2022-08-04 12:54:57.659	info	3/ ---> State change by device: state sg.0.info.revision changed: Main: 2831 / API: 2831 (ack = true)
            smartgarden.0
            2022-08-04 12:54:57.655	info	3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
            smartgarden.0
            2022-08-04 12:54:57.647	info	3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
            smartgarden.0
            2022-08-04 12:54:57.637	info	3/ sgSetState: info.revision value=Main: 2831 / API: 2831 ack=true
            smartgarden.0
            2022-08-04 12:54:57.562	info	3/ connect ... using client credentials grant
            smartgarden.0
            2022-08-04 12:54:57.561	info	3/ connect ... empty password
            smartgarden.0
            2022-08-04 12:54:57.560	info	3/ connect ... empty username
            smartgarden.0
            2022-08-04 12:54:57.560	info	3/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
            smartgarden.0
            2022-08-04 12:54:57.559	info	3/ connecting to Gardena Smart System Service ...
            smartgarden.0
            2022-08-04 12:54:57.557	info	3/ sgSetState: info.connection value=false ack=true
            smartgarden.0
            2022-08-04 12:54:57.553	info	3/ connectToGardena...
            smartgarden.0
            2022-08-04 12:54:57.551	info	3/ getConnection...
            smartgarden.0
            2022-08-04 12:54:57.488	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v14.19.3, js-controller: 4.0.23
            smartgarden.0
            2022-08-04 12:54:51.480	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            smartgarden.0
            2022-08-04 12:54:51.479	info	terminating
            DANKE!!!
              @mameier1234 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
              Ich steuere die Duration_value eines Bewässerungsventils an.
              immer mit dem gleichen Wert? Machst du das manuell?
              wenn dann aber ein paar Stunden ins Land gehen, dann kommt immer wieder mal der Fehler 400... der geht erst weg, wenn ich die Instanz neu starte...
              Was heißt "ein paar Stunden ins Land gehen"? Siehst du eine Zeitabhängigkeit?
              Woher weißt du, dass der dann nur weggeht, wenn du neu startest? Was hast du sonst so versucht?
              Mach mal ein Log - Level 3 einschalten!
              mameier1234
              #973
              @jpgorganizer Kaum beobachtet man die Sache, passiert es nicht mehr :-)
              Ich hatte jetzt keinerlei Probleme mehr.. (und das Logging wieder rungtergedreht..)
              Grüße,
              Martin
                mk712
                schrieb am zuletzt editiert von mk712
                #974
                ich habe meinen Sileno Mäher ein paar Wochen "ausgesetzt", demzufolge Adapter und Scripte pausiert. Jetzt, nach der Re-Aktivierung und Aktualisierung des Adapters habe ich war sofort wieder Verbindung bekommen (alles hübsch grün), jedoch aktualisieren sich die DP nicht mehr. Der Zeitstempel wird regelmäßig gesetzt, aber eben ohne Aktualisierung. Eine Befehlsübergabe per Script oder DP-Eintrag an den Mäher funktioniert, es kommt nur nichts zurück. Zudem fehlen nach der "Neuanlage" des DP-Baumes einige mir wichtige Datenpunkte wie z.B. "lastErrorCode_value". Dazu habe ich im Changelog der neuen Adapterversion 2 zwar etwas gelesen (function and configuration parameter pre-define states removed. All Gardena data points get deleted and created again) - da steh aber nix von gibt es nicht mehr?!
                Kann mir da jemand folgen und helfen?
                btw. - hab nur einen Mäher, keine weiteren Geräte.
                Danke und Grüße
                MK
                EDIT 1: es sieht wohl so aus, das der Mäher das Problem selbst verursacht, also keine Meldungen an das System inkl. sich selbst absetzt...
                EDIT 2: am Mähroboter hatte sich wohl das Funkmodul "aufgehängt", nach dem Ab- und Anstecken des Akku, was einen Neustart des Funkmoduls initiierte, läuft alles wie gehabt.
                Ein großes Dankeschön für diesen wertvollen Adapter!
                • S SaschaS
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  smartgarden.0
                  DANKE!!!
                  manuel35i
                  #975
                  Kurze Frage warum ist bei mir das Feld Application Secret ausgegraut.
                  Kann leider nichts eingeben.
                  • M manuel35i
                    mameier1234
                    #976
                    @manuel35i Weil entweder Secret oder Benutzername-Passwort...
                    Grüße,
                    Martin
                    • M mameier1234
                      manuel35i
                      #977
                      @mameier1234
                      Dankeschön für die Info
                      • R Offline
                        Roadrunner
                        #978
                        zwar etwas Off-Topic, aber hat eigentlich schon jemand versucht das Ganze ohne das Gardena Gateway aufzuziehen? (zB esp32 und 868Mhz-Modul oder Lemonbeat-Dongle)
                        Schöne Grüße!
                        • C Offline
                          ChrisChros
                          #979
                          Hat sonst noch wer Problem mit der Verbindung zum Server von Gardena?
                          Bekomme seit heute Mittag folgende Fehlermeldung:
                          2023-05-03 11:38:59.156 - error: smartgarden.0 (20631) Error: request returned 403 Forbidden
                          Das ganze wiederholt sich alle 5 Minuten.
                          Gruß Chris
                          B N M 3 Antworten Letzte Antwort
                          • C ChrisChros
                            Gruß Chris
                            BlueBook
                            schrieb am zuletzt editiert von BlueBook
                            #980
                            @chrischros is bei mir auch so :(
                            Ich hab das firmware update durchgeführt. Ich denke daran liegt es :/
                            Obwohl du hast recht. Es gab vorher auch schon Probleme.
                            Über die App von Gardena läuft es, hm
                            C 1 Antwort Letzte Antwort
                            • B BlueBook
                              ChrisChros
                              #981
                              @bluebook ich denke an dem Update liegt es nicht denn das habe ich schon seit dem Wochenende drauf als ich alles wieder reaktiviert habe.
                              Die Fehlermeldung habe ich aber erst seit heute, davor gab es keine Auffälligkeiten.
                              • C ChrisChros
                                Gruß Chris
                                N Offline
                                N Offline
                                netfriend
                                #982
                                @chrischros sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                Gruß Chris
                                Ja, ist bei mir auch so.
                                Ich habe aber keinerlei Änderungen am System vorgenommen.
                                • JohGreJ Offline
                                  JohGreJ Offline
                                  JohGre
                                  #983
                                  gibt schon eine Thread dazu.
                                  https://forum.iobroker.net/topic/65105/adapter-smartgarden-fehler-403?_=1683132394304
                                  nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
                                  • C ChrisChros
                                    Gruß Chris
                                    mirage
                                    #984
                                    @chrischros
                                    bei mir das Gleiche, seit 13:30 alle 5 min die selbe Fehlermeldung.
                                    Keine Änderung am System.
                                    P 1 Antwort Letzte Antwort
                                    • M mirage
                                      @chrischros
                                      Pino72
                                      #985
                                      Dito....
                                      • P Pino72
                                        Dito....
                                        jpgorganizer
                                        #986
                                        https://forum.iobroker.net/topic/65105/adapter-smartgarden-fehler-403/5?_=1683207342760
                                          Pistus
                                          #987
                                          @jpgorganizer Hallo, auf meinem Raspberry Py 3B V2.1 habe ich iobroker installiert und kann mittels ssh und auch über die URL auf iobroker zugreifen.
                                          Bei Husqvarna habe ich mich registriert und habe jetzt eine Authentication API, eine Automover Connect API und eine Gardena smart System API. Alle drei API's haben ein Applications Key un ein Applications sekret
                                          Gardena smart Garden habe ich installiert und muss in der Instanz jetzt key und secret eintragen. Aber von welcher API? Entschuldigt bitte die simple Frage, aber ich bin absoluter Neuling und unbedarft. Ich möchte iobroker nutzen um meinen smart Sileno Möhroboter bei Regen zu stoppen.
                                          Grüße, Franz
