  4. Test Adapter onvif camera v1.x.x
341 Beiträge 48 Kommentatoren 132.2k Aufrufe 49 Beobachtet
  • T tombox
    @rookie50 Vielleicht kannst du ein paar screenshots posten wie du renderst oder den dialog öffnest
    R
    R
    Rookie50
    schrieb am zuletzt editiert von Rookie50
    #150
    @tombox Im VIS Editor unter Menupunkt Tools ist die Option Immer rendern:
    Das habe ich ausgeschaltet.
    Im VIS benutzte ich HTML-Dialog. Als Icon ist deine ONVIF Snapshot Funktion und im Dialog die HTML Tags für die Kamera. Hier mein Export des Widgets:
    [{"tpl":"tplJquiDialog","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"<img src=\"http://192.168.101.240:8095/192_168_102_20_80\" width=\"100%\" height=\"100%\">","html_dialog":"<input type=\"hidden\" name=\"webrtc-url\" id=\"webrtc-url\" value=\"http://192.168.101.4:8083/stream/d4548b06-a995-4f5c-a9d3-100a383843d3/channel/0/webrtc\" /> \n<video id=\"webrtc-video\" autoplay muted playsinline controls style=\"max-width: 100%; max-height: 100%;\"></video>","dialog_width":"1280","dialog_height":"800","autoclose":"10000","noHeader":true,"setId":"javascript.0.Cam-Motion.Eingang.Bewegung","setValue":"true","closeOnClick":false,"preload":true,"persistent":true,"title":"Eingang","modal":false,"overflowX":"","overflowY":"","dialog_top":"","dialog_left":"","views":["EG"]},"style":{"left":"1010px","top":"629px","width":"265px","height":"150px","border-width":"1px","border-style":"solid","border-color":"grey","border-radius":""},"widgetSet":"jqui"}]
    Wenn nun der PIR der Kamera eine Bewegung meldet schaltet dieses Script den Dialog des Widgets:
    on({id: [].concat(['onvif.0.192_168_102_20_80.events.Device/Trigger/DigitalInput']), val: true}, async function (obj) {
      let value = obj.state.val;
      let oldValue = obj.oldState.val;
      if ((obj.state ? obj.state.val : "") == true && getState("javascript.0.Schalter.Nachtruhe").val == false) {
      // Tablet aufwecken
        setState("mqtt.1.wallpanel.tab01.command"/*wallpanel/tab01/command*/, '{"wake": true}');
      // Dialog öffnen
        setState("vis.0.control.command"/*Command for vis*/, '{"instance": "FFFFFFFF", "data": "w00349_OG", "command": "dialogOpen"}');
        // CamView fuer 2 Minuten einschalten
            setStateDelayed("vis.0.control.command"/*Command for vis*/, '{"instance": "FFFFFFFF", "data": "w00349_OG", "command": "dialogClose"}', 120000, false);
        // command value löschen
        setStateDelayed("mqtt.1.wallpanel.tab01.command"/*wallpanel/tab01/command*/, '', 125000, false);
        setStateDelayed("javascript.0.Cam-Motion.Eingang.Bewegung"/*Cam-Motion.Eingang.Bewegung*/, false, 120000, false);
    Kurze Erklärung:
    "instance": "FFFFFFFF" -> alles verbundenen VIS Instanzen
    "data": "w00349_OG" -> Das Dialog Widget heißt bei mir "w00349_OG"
    "command": "dialogXXXXX" -> Open/Close Öffnet/Schließt das Dialog Fenster.
    • R Rookie50
      @wendy2702 Ich habe eine kurze Frage zum Player. Ich würde den gerne auf mehreren Views benutzen. Aber dazu muss der Player oder der Stream neu geladen werden. Wenn ich den View wechsel sieht es so aus:
      Gibt es dazu eine Möglichkeit? Oder muss ich für jeden View ein seperates Widget und Script erstellen?
      wendy2702W
      wendy2702W
      #151
      @rookie50 sagte in Test Adapter onvif camera v1.0.0:
      Sorry,
      wegen Server umbau war ich bisschen offline.
      Ich musste das leider zurück zu Motioneye bauen da ich meine alten Tablets mit Ubuntu und Chrome nicht dazu bewegen konnte die Streams sicher zu starten.
      Mal ging es, mal nicht. WAF im Keller.
      Habe gesehen das du Erfolg hattest wenn du den haken bei "Immer rendern" entfernst, der ist bei mir eh deaktiviert.
      Wenn ich mal Zeit und Lust habe gebe ich mich nochmal dran.
      R 1 Antwort Letzte Antwort
      • wendy2702W wendy2702
        Sorry,
        R
        R
        Rookie50
        #152
        @wendy2702 Ohjee, WAF im Keller geht gar nicht... Verstehe und kenne ich ;-)
        Zur Stabilität kann ich noch nichts sagen. Teste gerade und kann bestimmt in 1 - 2 Tagen etwas mehr dazu sagen.
        BTW. läuft bei mir auf einem Samsung A7...
        • R
          R
          Rookie50
          #153
          In iQontrol kann RTSPtoWEB auf genutzt werden. Man muss einfach ein neues Geräte als Widget erstellen und unter Background_HTML folgenden Code einfügen:
          <input type="hidden" name="webrtc-url" id="webrtc-url" value="http://192.168.2.2:8083/stream/a34525d7-6d13-421d-9127-2cd7bc4323dc/channel/0/webrtc" />
          <video id="webrtc-video" autoplay muted playsinline controls style="max-width: 100%; max-height: 100%;" />
          <script>
          setTimeout(function () {
            function startPlay(videoEl, url) {
              const webrtc = new RTCPeerConnection({
                iceServers: [
                    urls: ["stun:stun.l.google.com:19302"],
                sdpSemantics: "unified-plan",
              webrtc.ontrack = function (event) {
                console.log(event.streams.length + " track is delivered");
                videoEl.srcObject = event.streams[0];
                videoEl.play();
              webrtc.addTransceiver("video", { direction: "sendrecv" });
              webrtc.onnegotiationneeded = async function handleNegotiationNeeded() {
                const offer = await webrtc.createOffer();
                await webrtc.setLocalDescription(offer);
                fetch(url, {
                  method: "POST",
                  body: new URLSearchParams({ data: btoa(webrtc.localDescription.sdp) }),
                  .then((response) => response.text())
                  .then((data) => {
                    try {
                      webrtc.setRemoteDescription(new RTCSessionDescription({ type: "answer", sdp: atob(data) }));
                    } catch (e) {
                      console.warn(e);
              const webrtcSendChannel = webrtc.createDataChannel("rtsptowebSendChannel");
              webrtcSendChannel.onopen = (event) => {
                console.log(`${webrtcSendChannel.label} has opened`);
                webrtcSendChannel.send("ping");
              webrtcSendChannel.onclose = (_event) => {
                console.log(`${webrtcSendChannel.label} has closed`);
                startPlay(videoEl, url);
              webrtcSendChannel.onmessage = (event) => console.log(event.data);
            const videoEl = document.querySelector("#webrtc-video");
            const webrtcUrl = document.querySelector("#webrtc-url").value;
            startPlay(videoEl, webrtcUrl);
          }, 1000);
          </script>
          In der erste Zeile muss nur die IP addresse und die Kamera ID angepasst werden:
          Sobald die Ansicht geladen wird startet der Player mit Videobild.
          • Mr GlorillaM
            Mr GlorillaM
            Mr Glorilla
            #154
            es wurde schon oft geschrieben, aber ich finde, man kann gute Ideen und Support nicht oft genug lobend erwähnen. Ich finde es super, dass du den Adapter entwickelt hast und hier im Forum versuchst, allen zu helfen.
            Nun habe ich den Adapter ebenfalls installiert und leider ein Problem mit einer von zwei Kameras.
            Kurz: Der Snapshot-Datenpunkt wird nicht angelegt. Bei Betätigung des "Schalters" braucht der Server sehr lange um sich von dem Schock der Anfrage zu erholen und es kommt anschließend eine für mich unverständliche Fehlermeldung im Log:
            Error getting snapshot basic: {"data":{"type":"Buffer","data":[60,63,120,109,108,32,118,101,114,115,105,111,110,61,34,49,46,48,34,32,101,110,99,111,100,105,110,103,61,34,85,84,70,45,56,34,63,62,10,60,83,79,65,80,45,69,78,86,58,70,97,117,108,116,32,120,109,108,110,115,58,83,79,65,80,45,69,78,86,61,34,104,116,116,112,58,47,47,119,119,119,46,119,51,46,111,114,103,47,50,48,48,51,47,48,53,47,115,111,97,112,45,101,110,118,101,108,111,112,101,34,32,120,109,108,110,115,58,83,79,65,80,45,69,78,67,61,34,104,116,116,112,58,47,47,119,119,119,46,119,51,46,111,114,103,47,50,48,48,51,47,48,53,47,115,111,97,112,45,101,110,99,111,100,105,110,103,34,32,120,109,108,110,115,58,120,115,105,61,34,104,116,116,112,58,47,47,119,119,119,46,119,51,46,111,114,103,47,50,48,48,49,47,88,77,76,83,99,104,101,109,97,45,105,110,115,116,97,110,99,101,34,32,120,109,108,110,115,58,120,115,100,61,34,104,116,116,112,58,47,47,119,119,119,46,119,51,46,111,114,103,47,50,48,48,49,47,88,77,76,83,99,104,101,109,97,34,32,120,109,108,110,115,58,119,115,97,53,61,34,104,116,116,112,58,47,47,119,119,119,46,119,51,46,111,114,103,47,50,48,48,53,47,48,56,47,97,100,100,114,101,115,115,105,110,103,34,32,120,109,108,110,115,58,120,109,105,109,101,61,34,104,116,116,112,58,47,47,116,101,109,112,117,114,105,46,111,114,103,47,120,109,105,109,101,46,120,115,100,34,32,120,109,108,110,115,58,120,111,112,61,34,104,116,116,112,58,47,47,119,119,119,46,119,51,46,111,114,103,47,50,48,48,52,47,48,56,47,120,111,112,47,105,110,99,108,117,100,101,34,32,120,109,108,110,115,58,110,115,49,61,34,104,116,116,112,58,47,47,100,111,99,115,46,111,97,115,105,115,45,111,112,101,110,46,111,114,103,47,119,115,114,102,47,98,102,45,50,34,32,120,109,108,110,115,58,119,115,97,61,34,104,116,116,112,58,47,47,115,99,104,101,109,97,115,46,120,109,108,115,111,97,112,46,111,114,103,47,119,115,47,50,48,48,52,47,48,56,47,97,100,100,114,101,115,115,105,110,103,34,32,120,109,108,110,115,58,116,116,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,115,99,104,101,109,97,34,32,120,109,108,110,115,58,119,115,116,111,112,61,34,104,116,116,112,58,47,47,100,111,99,115,46,111,97,115,105,115,45,111,112,101,110,46,111,114,103,47,119,115,110,47,116,45,49,34,32,120,109,108,110,115,58,110,115,51,61,34,104,116,116,112,58,47,47,100,111,99,115,46,111,97,115,105,115,45,111,112,101,110,46,111,114,103,47,119,115,114,102,47,114,45,50,34,32,120,109,108,110,115,58,100,110,100,108,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,110,101,116,119,111,114,107,47,119,115,100,108,47,68,105,115,99,111,118,101,114,121,76,111,111,107,117,112,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,100,110,114,100,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,110,101,116,119,111,114,107,47,119,115,100,108,47,82,101,109,111,116,101,68,105,115,99,111,118,101,114,121,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,100,61,34,104,116,116,112,58,47,47,115,99,104,101,109,97,115,46,120,109,108,115,111,97,112,46,111,114,103,47,119,115,47,50,48,48,53,47,48,52,47,100,105,115,99,111,118,101,114,121,34,32,120,109,108,110,115,58,100,110,50,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,110,101,116,119,111,114,107,47,119,115,100,108,34,32,120,109,108,110,115,58,116,97,100,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,97,110,97,108,121,116,105,99,115,100,101,118,105,99,101,47,119,115,100,108,34,32,120,109,108,110,115,58,116,97,110,97,101,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,50,48,47,97,110,97,108,121,116,105,99,115,47,119,115,100,108,47,65,110,97,108,121,116,105,99,115,69,110,103,105,110,101,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,97,110,114,101,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,50,48,47,97,110,97,108,121,116,105,99,115,47,119,115,100,108,47,82,117,108,101,69,110,103,105,110,101,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,97,110,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,50,48,47,97,110,97,108,121,116,105,99,115,47,119,115,100,108,34,32,120,109,108,110,115,58,116,100,115,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,100,101,118,105,99,101,47,119,115,100,108,34,32,120,109,108,110,115,58,116,101,118,99,112,112,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,47,67,114,101,97,116,101,80,117,108,108,80,111,105,110,116,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,101,118,101,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,47,69,118,101,110,116,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,101,118,110,99,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,47,78,111,116,105,102,105,99,97,116,105,111,110,67,111,110,115,117,109,101,114,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,101,118,110,112,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,47,78,111,116,105,102,105,99,97,116,105,111,110,80,114,111,100,117,99,101,114,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,101,118,112,112,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,47,80,117,108,108,80,111,105,110,116,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,101,118,112,112,115,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,47,80,117,108,108,80,111,105,110,116,83,117,98,115,99,114,105,112,116,105,111,110,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,101,118,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,34,32,120,109,108,110,115,58,116,101,118,112,115,109,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,47,80,97,117,115,97,98,108,101,83,117,98,115,99,114,105,112,116,105,111,110,77,97,110,97,103,101,114,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,119,115,110,116,61,34,104,116,116,112,58,47,47,100,111,99,115,46,111,97,115,105,115,45,111,112,101,110,46,111,114,103,47,119,115,110,47,98,45,50,34,32,120,109,108,110,115,58,116,101,118,115,109,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,47,83,117,98,115,99,114,105,112,116,105,111,110,77,97,110,97,103,101,114,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,105,109,103,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,50,48,47,105,109,97,103,105,110,103,47,119,115,100,108,34,32,120,109,108,110,115,58,116,108,115,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,100,105,115,112,108,97,121,47,119,115,100,108,34,32,120,109,108,110,115,58,116,109,100,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,100,101,118,105,99,101,73,79,47,119,115,100,108,34,32,120,109,108,110,115,58,116,112,116,122,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,50,48,47,112,116,122,47,119,115,100,108,34,32,120,109,108,110,115,58,116,114,99,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,114,101,99,111,114,100,105,110,103,47,119,115,100,108,34,32,120,109,108,110,115,58,116,114,112,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,114,101,112,108,97,121,47,119,115,100,108,34,32,120,109,108,110,115,58,116,114,116,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,109,101,100,105,97,47,119,115,100,108,34,32,120,109,108,110,115,58,116,114,118,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,114,101,99,101,105,118,101,114,47,119,115,100,108,34,32,120,109,108,110,115,58,116,115,101,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,115,101,97,114,99,104,47,119,115,100,108,34,32,120,109,108,110,115,58,116,101,114,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,114,114,111,114,34,32,120,109,108,110,115,58,119,115,115,101,61,34,104,116,116,112,58,47,47,100,111,99,115,46,111,97,115,105,115,45,111,112,101,110,46,111,114,103,47,119,115,115,47,50,48,48,52,47,48,49,47,111,97,115,105,115,45,50,48,48,52,48,49,45,119,115,115,45,119,115,115,101,99,117,114,105,116,121,45,115,101,99,101,120,116,45,49,46,48,46,120,115,100,34,32,120,109,108,110,115,58,116,110,115,49,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,116,111,112,105,99,115,34,62,60,102,97,117,108,116,99,111,100,101,62,83,79,65,80,45,69,78,86,58,67,108,105,101,110,116,60,47,102,97,117,108,116,99,111,100,101,62,60,102,97,117,108,116,115,116,114,105,110,103,62,72,84,84,80,32,71,69,84,32,109,101,116,104,111,100,32,110,111,116,32,105,109,112,108,101,109,101,110,116,101,100,60,47,102,97,117,108,116,115,116,114,105,110,103,62,60,47,83,79,65,80,45,69,78,86,58,70,97,117,108,116,62]},"status":405,"headers":{"server":"gSOAP/2.8","content-type":"text/xml; charset=utf-8","content-length":"2744","connection":"close"},"res":{"status":405,"statusCode":405,"statusMessage":"Method Not Allowed","headers":{"server":"gSOAP/2.8","content-type":"text/xml; charset=utf-8","content-length":"2744","connection":"close"},"size":2744,"aborted":false,"rt":15,"keepAliveSocket":false,"data":{"type":"Buffer","data":[60,63,120,109,108,32,118,101,114,115,105,111,110,61,34,49,46,48,34,32,101,110,99,111,100,105,110,103,61,34,85,84,70,45,56,34,63,62,10,60,83,79,65,80,45,69,78,86,58,70,97,117,108,116,32,120,109,108,110,115,58,83,79,65,80,45,69,78,86,61,34,104,116,116,112,58,47,47,119,119,119,46,119,51,46,111,114,103,47,50,48,48,51,47,48,53,47,115,111,97,112,45,101,110,118,101,108,111,112,101,34,32,120,109,108,110,115,58,83,79,65,80,45,69,78,67,61,34,104,116,116,112,58,47,47,119,119,119,46,119,51,46,111,114,103,47,50,48,48,51,47,48,53,47,115,111,97,112,45,101,110,99,111,100,105,110,103,34,32,120,109,108,110,115,58,120,115,105,61,34,104,116,116,112,58,47,47,119,119,119,46,119,51,46,111,114,103,47,50,48,48,49,47,88,77,76,83,99,104,101,109,97,45,105,110,115,116,97,110,99,101,34,32,120,109,108,110,115,58,120,115,100,61,34,104,116,116,112,58,47,47,119,119,119,46,119,51,46,111,114,103,47,50,48,48,49,47,88,77,76,83,99,104,101,109,97,34,32,120,109,108,110,115,58,119,115,97,53,61,34,104,116,116,112,58,47,47,119,119,119,46,119,51,46,111,114,103,47,50,48,48,53,47,48,56,47,97,100,100,114,101,115,115,105,110,103,34,32,120,109,108,110,115,58,120,109,105,109,101,61,34,104,116,116,112,58,47,47,116,101,109,112,117,114,105,46,111,114,103,47,120,109,105,109,101,46,120,115,100,34,32,120,109,108,110,115,58,120,111,112,61,34,104,116,116,112,58,47,47,119,119,119,46,119,51,46,111,114,103,47,50,48,48,52,47,48,56,47,120,111,112,47,105,110,99,108,117,100,101,34,32,120,109,108,110,115,58,110,115,49,61,34,104,116,116,112,58,47,47,100,111,99,115,46,111,97,115,105,115,45,111,112,101,110,46,111,114,103,47,119,115,114,102,47,98,102,45,50,34,32,120,109,108,110,115,58,119,115,97,61,34,104,116,116,112,58,47,47,115,99,104,101,109,97,115,46,120,109,108,115,111,97,112,46,111,114,103,47,119,115,47,50,48,48,52,47,48,56,47,97,100,100,114,101,115,115,105,110,103,34,32,120,109,108,110,115,58,116,116,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,115,99,104,101,109,97,34,32,120,109,108,110,115,58,119,115,116,111,112,61,34,104,116,116,112,58,47,47,100,111,99,115,46,111,97,115,105,115,45,111,112,101,110,46,111,114,103,47,119,115,110,47,116,45,49,34,32,120,109,108,110,115,58,110,115,51,61,34,104,116,116,112,58,47,47,100,111,99,115,46,111,97,115,105,115,45,111,112,101,110,46,111,114,103,47,119,115,114,102,47,114,45,50,34,32,120,109,108,110,115,58,100,110,100,108,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,110,101,116,119,111,114,107,47,119,115,100,108,47,68,105,115,99,111,118,101,114,121,76,111,111,107,117,112,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,100,110,114,100,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,110,101,116,119,111,114,107,47,119,115,100,108,47,82,101,109,111,116,101,68,105,115,99,111,118,101,114,121,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,100,61,34,104,116,116,112,58,47,47,115,99,104,101,109,97,115,46,120,109,108,115,111,97,112,46,111,114,103,47,119,115,47,50,48,48,53,47,48,52,47,100,105,115,99,111,118,101,114,121,34,32,120,109,108,110,115,58,100,110,50,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,110,101,116,119,111,114,107,47,119,115,100,108,34,32,120,109,108,110,115,58,116,97,100,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,97,110,97,108,121,116,105,99,115,100,101,118,105,99,101,47,119,115,100,108,34,32,120,109,108,110,115,58,116,97,110,97,101,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,50,48,47,97,110,97,108,121,116,105,99,115,47,119,115,100,108,47,65,110,97,108,121,116,105,99,115,69,110,103,105,110,101,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,97,110,114,101,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,50,48,47,97,110,97,108,121,116,105,99,115,47,119,115,100,108,47,82,117,108,101,69,110,103,105,110,101,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,97,110,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,50,48,47,97,110,97,108,121,116,105,99,115,47,119,115,100,108,34,32,120,109,108,110,115,58,116,100,115,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,100,101,118,105,99,101,47,119,115,100,108,34,32,120,109,108,110,115,58,116,101,118,99,112,112,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,47,67,114,101,97,116,101,80,117,108,108,80,111,105,110,116,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,101,118,101,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,47,69,118,101,110,116,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,101,118,110,99,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,47,78,111,116,105,102,105,99,97,116,105,111,110,67,111,110,115,117,109,101,114,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,101,118,110,112,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,47,78,111,116,105,102,105,99,97,116,105,111,110,80,114,111,100,117,99,101,114,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,101,118,112,112,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,47,80,117,108,108,80,111,105,110,116,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,101,118,112,112,115,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,47,80,117,108,108,80,111,105,110,116,83,117,98,115,99,114,105,112,116,105,111,110,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,101,118,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,34,32,120,109,108,110,115,58,116,101,118,112,115,109,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,47,80,97,117,115,97,98,108,101,83,117,98,115,99,114,105,112,116,105,111,110,77,97,110,97,103,101,114,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,119,115,110,116,61,34,104,116,116,112,58,47,47,100,111,99,115,46,111,97,115,105,115,45,111,112,101,110,46,111,114,103,47,119,115,110,47,98,45,50,34,32,120,109,108,110,115,58,116,101,118,115,109,98,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,118,101,110,116,115,47,119,115,100,108,47,83,117,98,115,99,114,105,112,116,105,111,110,77,97,110,97,103,101,114,66,105,110,100,105,110,103,34,32,120,109,108,110,115,58,116,105,109,103,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,50,48,47,105,109,97,103,105,110,103,47,119,115,100,108,34,32,120,109,108,110,115,58,116,108,115,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,100,105,115,112,108,97,121,47,119,115,100,108,34,32,120,109,108,110,115,58,116,109,100,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,100,101,118,105,99,101,73,79,47,119,115,100,108,34,32,120,109,108,110,115,58,116,112,116,122,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,50,48,47,112,116,122,47,119,115,100,108,34,32,120,109,108,110,115,58,116,114,99,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,114,101,99,111,114,100,105,110,103,47,119,115,100,108,34,32,120,109,108,110,115,58,116,114,112,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,114,101,112,108,97,121,47,119,115,100,108,34,32,120,109,108,110,115,58,116,114,116,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,109,101,100,105,97,47,119,115,100,108,34,32,120,109,108,110,115,58,116,114,118,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,114,101,99,101,105,118,101,114,47,119,115,100,108,34,32,120,109,108,110,115,58,116,115,101,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,115,101,97,114,99,104,47,119,115,100,108,34,32,120,109,108,110,115,58,116,101,114,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,101,114,114,111,114,34,32,120,109,108,110,115,58,119,115,115,101,61,34,104,116,116,112,58,47,47,100,111,99,115,46,111,97,115,105,115,45,111,112,101,110,46,111,114,103,47,119,115,115,47,50,48,48,52,47,48,49,47,111,97,115,105,115,45,50,48,48,52,48,49,45,119,115,115,45,119,115,115,101,99,117,114,105,116,121,45,115,101,99,101,120,116,45,49,46,48,46,120,115,100,34,32,120,109,108,110,115,58,116,110,115,49,61,34,104,116,116,112,58,47,47,119,119,119,46,111,110,118,105,102,46,111,114,103,47,118,101,114,49,48,47,116,111,112,105,99,115,34,62,60,102,97,117,108,116,99,111,100,101,62,83,79,65,80,45,69,78,86,58,67,108,105,101,110,116,60,47,102,97,117,108,116,99,111,100,101,62,60,102,97,117,108,116,115,116,114,105,110,103,62,72,84,84,80,32,71,69,84,32,109,101,116,104,111,100,32,110,111,116,32,105,109,112,108,101,109,101,110,116,101,100,60,47,102,97,117,108,116,115,116,114,105,110,103,62,60,47,83,79,65,80,45,69,78,86,58,70,97,117,108,116,62]},"requestUrls":["http://192.168.192.231:1018/web/cgi-bin/hi3510/snap.cgi?&-getstream&"],"timing":null,"remoteAddress":"192.168.xxx.xxx","remotePort":1018,"socketHandledRequests":1,"socketHandledResponses":1}}
            Ich hatte weiter oben gelesen, dass jemand Probleme mit dem vorbelegten Port innerhalb der Kamera hatte. Bei meiner Kamera kann ich ebenfalls nur bestimmte Ports auswählen.
            Screenshot:
            Ich habe auch schon ungehorsam versucht, den Onvif-Port auf 80 zu setzen. Das lässt er aber nicht zu.
            Der Pfad in der Fehlermeldung "http://192.168.xxx.xxx:1018/web/cgi-bin/hi3510/snap.cgi?&-getstream&" lässt sich im Browser nicht aufrufen. Allerdings mit Port 80 funktioniert es. Dann bekomme ich einen Stream angezeigt. Daher tippe ich auf das Port-Problem.
            Gibt es dafür eine Abhilfe, die ich überlesen oder nicht verstanden habe?
            • Mr GlorillaM Mr Glorilla
              Screenshot:
              T
              T
              tombox
              #155
              @mr-glorilla probier mal die github version da kann man ein snapshot port spezifzieren "Überschreiben Snapshot url port mit kamera port" muss aktiv sein
              Mr GlorillaM 1 Antwort Letzte Antwort
              • T tombox
                Mr GlorillaM
                Mr GlorillaM
                Mr Glorilla
                schrieb am zuletzt editiert von Mr Glorilla
                #156
                @tombox
                die aktuelle Version habe ich von Github installiert.
                Port überschreiben ist bereits aktiviert. Kann/Muss ich den Port irgendwo manuell angeben?
                Die Fehlermeldung im Log bleibt wie schon geschrieben.
                  @tombox
                  T
                  T
                  tombox
                  #157
                  @mr-glorilla dann nochmal installieren
                  • R RandyAndy
                    Noch ein kleiner aber vielleicht für RaspberryPi Benutzer nicht ganz unwesentlicher Punkt.
                    Das Beschreiben des Datenpunkts wird die SD-Karte, die typisch verwendet wird, belasten. Bei einer SSD sollte das nicht die Rolle spielen aber im Datenpunkt wird das gesamte Bild abgelegt wenn ich das richtig interpretiere.
                    Schön wäre es eigentlich wenn man den Datenpunkt nur im DRAM halten könnte. Ich habe aber keine Möglichkeit gefunden das aus ioBroker heraus zu bewerkstelligen.
                    Alternative könnte man vielleicht Redis verwenden, aber am Ende werden die Datenpunkte dann doch wieder auf die SD geschrieben.
                    Ich habe lange ein Skript verwendet das mit das Bild in eine RAMDisk geschrieben hat. Das Bild aus der RAMdisk habe ich dann als html-Element in VIS eingebunden. Damit umgeht man das Schreiben großer Dantenmengen auf die SD-Karte.
                    Andreas
                    Jey CeeJ
                    Jey CeeJ
                    Jey Cee
                    #158
                    @randyandy sagte in Test Adapter onvif camera v1.0.0:
                    Andreas
                    Das ist nicht ganz richtig. ioBroker verwendet eine eigens Entwickelte File Datenbank Lösung namens JSONL. Die Speichert die Daten im RAM zwischen und schreibt sie erst nach x Minuten oder x Änderungen in die Datei.
                    Sinn war es weniger oft auf die Festplatte zu schreiben und die Performance zu verbessern.
                    Persönlicher Support
                    Spenden -> paypal.me/J3YC33
                    • T tombox
                      Mr GlorillaM
                      Mr GlorillaM
                      Mr Glorilla
                      #159
                      @tombox
                      habe es mit einem Downgrade probiert, aber leider gleicher Fehler.
                        @tombox
                        T
                        T
                        tombox
                        #160
                        @mr-glorilla Wie gesagt über das github symbol installieren
                        • FC1002F
                          FC1002F
                          FC1002
                          #161
                          Respekt an den Adaperentwickler. Ich habe jetzt meine Tapo-Cam mit der Bewässerung kombiniert und dadurch einen Katzenschreck im Garten. Meine Frau dankt mir auf Knien :-)
                          Eine Frage habe ich, es wird in dem Adapter nur ein Datenpunkt für Alam angezeigt, die Tapo hat aber unterschiedliche Trigger: "Person erkannt"; "Bewegung erkannt"; "Linienübschreitung" etc.. Kann man die Alarm differenzieren? Das würde den WAF noch maximieren.
                          Vg Frank
                          • FC1002F FC1002
                            Vg Frank
                            T
                            T
                            tombox
                            #162
                            @fc1002 Es gibt auch ein tapo adapter da ist das gleiche problem. Bisher nichts gefunden wenn du in anderen Smart Home Systeme dazu was findest könnte ich es übernehmen
                            FC1002F 2 Antworten Letzte Antwort
                            • T tombox
                              FC1002F
                              FC1002F
                              FC1002
                              #163
                              @tombox leider nicht :-( Schade, aber vielleicht wirst du ja noch nicht fündig
                              • T tombox
                                FC1002F
                                FC1002F
                                FC1002
                                #164
                                @tombox BTW im Tapo-Adapter habe ich gar keine Alarme gefunden? Da sind nur Konfigdaten der Cam. Oder ich bin blind.
                                Die Tapo-App auf dem Handy differenziert aber die unterschiedlichen Alarm-Typen. Also muss je irgendwo diese Information versteckt sein Oder?
                                • FC1002F FC1002
                                  T
                                  T
                                  tombox
                                  #165
                                  @fc1002 Nur bedingt die Implementierung nutzen die onvif Funktionalität der Kamera und das muss nicht identisch sein was die Kamera nativ an die app weitergibt
                                  FC1002F R 2 Antworten Letzte Antwort
                                  • T tombox
                                    FC1002F
                                    FC1002F
                                    FC1002
                                    #166
                                    @tombox Ich hab jetzt eine Möglichkeit gefunden. Leider ohne deinen Adapter.
                                    Über IFTTT können die verschiedenen Alarme abgefragt werden und über einen webhook an iobroker geschickt werden.
                                    Zwar unschön, funktioniert aber .
                                    Danke dir trotzdem für deinen Adapter.
                                    VG Frank
                                    • T tombox
                                      R
                                      R
                                      RandyAndy
                                      #167
                                      @tombox
                                      ich verwende den onvif adapter nun seit einigen Monaten (wir hatten schon mal Kontakt dazu). In der Summe läuft er auch sehr gut und füllt ein Lücke im ioBroker. Seit geraumer Zeit bekomme ich aber immer wieder Fehlermeldungen wie
                                      • xml undefinied
                                      • Wrong ONVIF SOAP response
                                        usw.
                                      Ich starte den Adapter alle 6 Stunden neu und dann geht es wieder von vorne los. Ich verwenden die Version 1.0., ist aber mit de Version 1.04 nicht anders.
                                      Andreas
                                      840
                                      Log-Größe: 955.7 KB
                                      Zeit
                                      Nachricht
                                      onvif.0
                                      	2023-05-08 19:24:06.988	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":37,"path":"/onvif-http/snapshot?Profile_1","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7001,"keepAliveSocket":false,"requestUrls":["http://192.168.178.11/onvif-http/snapshot?Profile_1"],"timing":null,"remoteAddress":"192.168.178.11","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:24:06.952	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":36,"path":"/onvif-http/snapshot?Profile_1","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7002,"keepAliveSocket":false,"requestUrls":["http://192.168.178.11/onvif-http/snapshot?Profile_1"],"timing":null,"remoteAddress":"192.168.178.11","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:24:06.949	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":35,"path":"/onvif-http/snapshot?Profile_1","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7003,"keepAliveSocket":false,"requestUrls":["http://192.168.178.11/onvif-http/snapshot?Profile_1"],"timing":null,"remoteAddress":"192.168.178.11","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:24:06.646	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":34,"path":"/onvif-http/snapshot?Profile_1","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7003,"keepAliveSocket":false,"requestUrls":["http://192.168.178.11/onvif-http/snapshot?Profile_1"],"timing":null,"remoteAddress":"192.168.178.11","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:24:06.544	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":33,"path":"/onvif-http/snapshot?Profile_1","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7003,"keepAliveSocket":false,"requestUrls":["http://192.168.178.11/onvif-http/snapshot?Profile_1"],"timing":null,"remoteAddress":"192.168.178.11","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:24:06.522	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":32,"path":"/onvif-http/snapshot?Profile_1","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7003,"keepAliveSocket":false,"requestUrls":["http://192.168.178.11/onvif-http/snapshot?Profile_1"],"timing":null,"remoteAddress":"192.168.178.11","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:23:59.133	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":27,"path":"/onvif-http/snapshot?Profile_1","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7002,"keepAliveSocket":false,"requestUrls":["http://192.168.178.11/onvif-http/snapshot?Profile_1"],"timing":null,"remoteAddress":"192.168.178.11","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:23:32.490	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":24,"path":"/cgi-bin/snapshot.cgi?stream=0","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7010,"keepAliveSocket":false,"requestUrls":["http://192.168.178.78/cgi-bin/snapshot.cgi?stream=0"],"timing":null,"remoteAddress":"192.168.178.78","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:23:32.489	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":25,"path":"/cgi-bin/snapshot.cgi?stream=0","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7005,"keepAliveSocket":false,"requestUrls":["http://192.168.178.78/cgi-bin/snapshot.cgi?stream=0"],"timing":null,"remoteAddress":"192.168.178.78","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:23:22.688	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":19,"path":"/cgi-bin/snapshot.cgi?stream=0","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7018,"keepAliveSocket":false,"requestUrls":["http://192.168.178.71/cgi-bin/snapshot.cgi?stream=0"],"timing":null,"remoteAddress":"192.168.178.71","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:23:22.608	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":18,"path":"/cgi-bin/snapshot.cgi?stream=0","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7007,"keepAliveSocket":false,"requestUrls":["http://192.168.178.71/cgi-bin/snapshot.cgi?stream=0"],"timing":null,"remoteAddress":"192.168.178.71","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:23:19.119	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":16,"path":"/onvif-http/snapshot?Profile_1","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7004,"keepAliveSocket":false,"requestUrls":["http://192.168.178.11/onvif-http/snapshot?Profile_1"],"timing":null,"remoteAddress":"192.168.178.11","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:23:18.041	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":15,"path":"/onvif-http/snapshot?Profile_1","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7005,"keepAliveSocket":false,"requestUrls":["http://192.168.178.11/onvif-http/snapshot?Profile_1"],"timing":null,"remoteAddress":"192.168.178.11","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:23:18.038	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":14,"path":"/onvif-http/snapshot?Profile_1","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7004,"keepAliveSocket":false,"requestUrls":["http://192.168.178.11/onvif-http/snapshot?Profile_1"],"timing":null,"remoteAddress":"192.168.178.11","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:23:14.714	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":13,"path":"/onvif-http/snapshot?Profile_1","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7005,"keepAliveSocket":false,"requestUrls":["http://192.168.178.11/onvif-http/snapshot?Profile_1"],"timing":null,"remoteAddress":"192.168.178.11","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:23:14.711	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":12,"path":"/onvif-http/snapshot?Profile_1","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7012,"keepAliveSocket":false,"requestUrls":["http://192.168.178.11/onvif-http/snapshot?Profile_1"],"timing":null,"remoteAddress":"192.168.178.11","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:23:14.691	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":11,"path":"/onvif-http/snapshot?Profile_1","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7005,"keepAliveSocket":false,"requestUrls":["http://192.168.178.11/onvif-http/snapshot?Profile_1"],"timing":null,"remoteAddress":"192.168.178.11","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:23:13.046	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":10,"path":"/onvif-http/snapshot?Profile_1","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7004,"keepAliveSocket":false,"requestUrls":["http://192.168.178.11/onvif-http/snapshot?Profile_1"],"timing":null,"remoteAddress":"192.168.178.11","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:23:07.117	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":9,"path":"/cgi-bin/snapshot.cgi?stream=0","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7006,"keepAliveSocket":false,"requestUrls":["http://192.168.178.70/cgi-bin/snapshot.cgi?stream=0"],"timing":null,"remoteAddress":"192.168.178.70","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:23:06.978	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":7,"path":"/cgi-bin/snapshot.cgi?stream=0","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7006,"keepAliveSocket":false,"requestUrls":["http://192.168.178.70/cgi-bin/snapshot.cgi?stream=0"],"timing":null,"remoteAddress":"192.168.178.70","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:22:58.705	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":6,"path":"/onvif-http/snapshot?Profile_1","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7003,"keepAliveSocket":false,"requestUrls":["http://192.168.178.11/onvif-http/snapshot?Profile_1"],"timing":null,"remoteAddress":"192.168.178.11","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:22:58.644	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":5,"path":"/onvif-http/snapshot?Profile_1","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7010,"keepAliveSocket":false,"requestUrls":["http://192.168.178.11/onvif-http/snapshot?Profile_1"],"timing":null,"remoteAddress":"192.168.178.11","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:22:58.640	error	Error getting snapshot: {"name":"ResponseTimeoutError","requestId":4,"path":"/onvif-http/snapshot?Profile_1","status":-1,"headers":{},"res":{"status":-1,"statusCode":-1,"statusMessage":null,"headers":{},"size":0,"aborted":false,"rt":7009,"keepAliveSocket":false,"requestUrls":["http://192.168.178.11/onvif-http/snapshot?Profile_1"],"timing":null,"remoteAddress":"192.168.178.11","remotePort":80,"socketHandledRequests":1,"socketHandledResponses":0}}
                                      onvif.0
                                      	2023-05-08 19:22:40.494	error	No status found for 192.168.178.20:80 Error: Wrong ONVIF SOAP response
                                      onvif.0
                                      	2023-05-08 19:22:40.493	error	Data: undefined xml: undefined
                                      onvif.0
                                      	2023-05-08 19:22:38.927	error	No status found for 192.168.178.71:80 Error: ONVIF SOAP Fault: {"value":"SOAP-ENV:Sender","subcode":{"value":"ter:ActionNotSupported","subcode":{"value":"ter:IPAddressFilterNotSupported"}}}
                                      onvif.0
                                      	2023-05-08 19:22:38.926	error	Data: undefined xml: undefined
                                      onvif.0
                                      	2023-05-08 19:22:37.225	error	No status found for 192.168.178.70:80 Error: ONVIF SOAP Fault: {"value":"SOAP-ENV:Sender","subcode":{"value":"ter:ActionNotSupported","subcode":{"value":"ter:IPAddressFilterNotSupported"}}}
                                      onvif.0
                                      	2023-05-08 19:22:37.224	error	Data: undefined xml: undefined
                                      onvif.0
                                      	2023-05-08 19:22:35.866	error	No status found for 192.168.178.11:80 Error: Wrong ONVIF SOAP response
                                      onvif.0
                                      	2023-05-08 19:22:35.865	error	Data: undefined xml: undefined
                                      onvif.0
                                      	2023-05-08 19:22:34.965	error	No status found for 192.168.178.78:80 Error: ONVIF SOAP Fault: {"value":"SOAP-ENV:Sender","subcode":{"value":"ter:ActionNotSupported","subcode":{"value":"ter:IPAddressFilterNotSupported"}}}
                                      onvif.0
                                      	2023-05-08 19:22:34.964	error	Data: undefined xml: undefined
                                      onvif.0
                                      	2023-05-08 19:22:33.977	error	No status found for 192.168.178.8:80 Error: Wrong ONVIF SOAP response
                                      onvif.0
                                      	2023-05-08 19:22:33.974	error	Data: undefined xml: undefined
                                      broadlink2.0
                                      	2023-05-08 19:00:00.561	error	Cannot read properties of null (reading 'removeAllListeners')
                                      broadlink2.0
                                      	2023-05-08 19:00:00.560	error	TypeError: Cannot read properties of null (reading 'removeAllListeners') at reject (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:403:18) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:469:11) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
                                      broadlink2.0
                                      	2023-05-08 19:00:00.556	error	uncaught exception: Cannot read properties of null (reading 'removeAllListeners')
                                      broadlink2.0
                                      	2023-05-08 18:00:00.448	error	Cannot read properties of null (reading 'removeAllListeners')
                                      broadlink2.0
                                      	2023-05-08 18:00:00.447	error	TypeError: Cannot read properties of null (reading 'removeAllListeners') at reject (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:403:18) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:469:11) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
                                      broadlink2.0
                                      	2023-05-08 18:00:00.442	error	uncaught exception: Cannot read properties of null (reading 'removeAllListeners')
                                      broadlink2.0
                                      	2023-05-08 16:00:00.192	error	Cannot read properties of null (reading 'removeAllListeners')
                                      broadlink2.0
                                      	2023-05-08 16:00:00.190	error	TypeError: Cannot read properties of null (reading 'removeAllListeners') at reject (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:403:18) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:469:11) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
                                      broadlink2.0
                                      	2023-05-08 16:00:00.186	error	uncaught exception: Cannot read properties of null (reading 'removeAllListeners')
                                      fahrplan.0
                                      	2023-05-08 09:26:53.207	error	Unknown Station defined in Route #3
                                      fahrplan.0
                                      	2023-05-08 09:26:53.202	error	Error occured: HAFAS error in Station in fStation/verifyStation [Error: CGI: Server died during request execution]
                                      fahrplan.0
                                      	2023-05-08 09:10:19.843	error	Unknown Station defined in Route #0
                                      broadlink2.0
                                      	2023-05-08 08:00:00.357	error	Cannot read properties of null (reading 'removeAllListeners')
                                      broadlink2.0
                                      	2023-05-08 08:00:00.356	error	TypeError: Cannot read properties of null (reading 'removeAllListeners') at reject (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:403:18) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink_fj.js:469:11) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
                                      broadlink2.0
                                      	2023-05-08 08:00:00.351	error	uncaught exception: Cannot read properties of null (reading 'removeAllListeners')
                                      fahrplan.0
                                      	2023-05-08 07:37:00.587	error	Unknown Station defined in Route #0
                                      fahrplan.0
                                      	2023-05-08 07:31:41.551	error	Unknown Station defined in Route #1
                                      fahrplan.0
                                      	2023-05-08 07:31:41.446	error	Unknown Station defined in Route #0
                                      fahrplan.0
                                      	2023-05-08 07:20:50.060	error	Unknown Station defined in Route #0
                                      onvif.0
                                      	2023-05-08 06:59:12.964	error	No status found for 192.168.178.8:80 Error: Wrong ONVIF SOAP response
                                      onvif.0
                                      	2023-05-08 06:59:12.960	error	Data: undefined xml: undefined
                                      onvif.0
                                      	2023-05-08 06:59:00.835	error	Error: DB closed
                                      onvif.0
                                      	2023-05-08 06:59:00.834	error	Error extract keys: 192_168_178_70_80.infos.presets {"1":1,"2":2,"3":3,"4":4,"5":5,"6":6,"7":7,"8":8,"9":9,"10":10,"11":11,"12":12,"13":13,"14":14,"15":15,"16":16,"17":17,"18":18,"19":19,"20":20,"21":21,"22":22,"23":23,"24":24,"25":25,"26":26,"27":27,"28":28,"29":29,"30":30,"31":31,"32":32,"33":33,"34":34,"35":35,"36":36,"37":37,"38":38,"39":39,"40":40,"41":41,"42":42,"43":43,"44":44,"45":45,"46":46,"47":47,"48":48,"49":49,"50":50,"51":51,"52":52,"53":53,"54":54,"55":55,"56":56,"57":57,"58":58,"59":59,"60":60,"61":61,"62":62,"63":63,"64":64,"65":65,"66":66,"67":67,"68":68,"69":69,"70":70,"71":71,"72":72,"73":73,"74":74,"75":75,"76":76,"77":77,"78":78,"79":79,"80":80,"81":81,"82":82,"83":83,"84":84,"85":85,"86":86,"87":87,"88":88,"89":89,"90":90,"91":91,"92":92,"93":93,"94":94,"95":95,"96":96,"97":97,"98":98,"99":99,"100":100,"101":101,"102":102,"103":103,"104":104,"105":105,"106":106,"107":107,"108":108,"109":109,"110":110,"111":111,"112":112,"113":113,"114":114,"115":115,"116":116,"117":117,"118":118,"119":119,"120":120,"121":121,"122":122,"123":123,"124":124,"125":125,"126":126,"127":127,"128":128,"129":129,"130":130,"131":131,"132":132,"133":133,"134":134,"135":135,"136":136,"137":137,"138":138,"139":139,"140":140,"141":141,"142":142,"143":143,"144":144,"145":145,"146":146,"147":147,"148":148,"149":149,"150":150,"151":151,"152":152,"153":153,"154":154,"155":155,"156":156,"157":157,"158":158,"159":159,"160":160,"161":161,"162":162,"163":163,"164":164,"165":165,"166":166,"167":167,"168":168,"169":169,"170":170,"171":171,"172":172,"173":173,"174":174,"175":175,"176":176,"177":177,"178":178,"179":179,"180":180,"181":181,"182":182,"183":183,"184":184,"185":185,"186":186,"187":187,"188":188,"189":189,"190":190,"191":191,"192":192,"193":193,"194":194,"195":195,"196":196,"197":197,"198":198,"199":199,"200":200,"201":201,"202":202,"203":203,"204":204,"205":205,"206":206,"207":207,"208":208,"209":209,"210":210,"211":211,"212":212,"213":213,"214":214,"215":215,"216":216,"217":217,"218":218,"219":219,"220":220,"221":221,"222":222,"223":223,"224":224,"225":225,"226":226,"227":227,"228":228,"229":229,"230":230,"231":231,"232":232,"233":233,"234":234,"235":235,"236":236,"237":237,"238":238,"239":239,"240":240,"241":241,"242":242,"243":243,"244":244,"245":245,"246":246,"247":247,"248":248,"249":249,"250":250,"251":251,"252":252,"253":253,"254":254,"255":255}
                                      onvif.0
                                      	2023-05-08 06:59:00.832	error	Error: DB closed
                                      onvif.0
                                      	2023-05-08 06:59:00.832	error	Error extract keys: 192_168_178_78_80.infos.deviceProfiles.02.PTZConfiguration.panTiltLimits.range.YRange {"min":-1,"max":1}
                                      onvif.0
                                      	2023-05-08 06:59:00.831	error	Error: DB closed
                                      onvif.0
                                      	2023-05-08 06:59:00.830	error	Error extract keys: 192_168_178_8_80.infos.deviceProfiles.02.videoSourceConfiguration.bounds.$ {"x":0,"y":0,"width":2688,"height":1520}
                                      onvif.0
                                      	2023-05-08 06:59:00.830	error	Error: DB closed
                                      onvif.0
                                      	2023-05-08 06:59:00.828	error	Error extract keys: 192_168_178_11_80.infos.deviceProfiles.02 {"$":{"token":"Profile_1","fixed":true},"name":"mainStream","videoSourceConfiguration":{"$":{"token":"VideoSourceToken"},"name":"VideoSourceConfig","useCount":2,"sourceToken":"VideoSource_1","bounds":{"$":{"x":0,"y":0,"width":2688,"height":1520}}},"videoEncoderConfiguration":{"$":{"token":"VideoEncoderToken_1","GovLength":20,"Profile":"Main"},"name":"VideoEncoder_1","useCount":1,"encoding":"H264","resolution":{"width":1920,"height":1080},"rateControl":{"$":{"ConstantBitRate":false},"frameRateLimit":20,"bitrateLimit":4096},"multicast":{"address":{"type":"IPv4","IPv4Address":"0.0.0.0"},"port":8860,"TTL":128,"autoStart":false},"quality":4},"analyticsConfiguration":{"$":{"token":"VideoAnalyticsToken"},"name":"VideoAnalyticsName","useCount":2,"analyticsEngineConfiguration":{"analyticsModule":[{"$":{"Name":"MyCellMotionModule","Type":"tt:CellMotionEngine"},"parameters":{"simpleItem":{"$":{"Name":"Sensitivity","Value":20}},"elementItem":{"$":{"Name":"Layout"},"cellLayout":{"$":{"Columns":22,"Rows":18},"transformation":{"translate":{"$":{"x":-1,"y":-1}},"scale":{"$":{"x":0.090909,"y":0.111111}}}}}}},{"$":{"Name":"MyLineDetectorModule","Type":"tt:LineDetectorEngine"},"parameters":{"simpleItem":{"$":{"Name":"Sensitivity","Value":20}},"elementItem":[{"$":{"Name":"Layout"},"transformation":{"translate":{"$":{"x":-1,"y":-1}},"scale":{"$":{"x":0.002,"y":0.002}}}},{"$":{"Name":"Field"},"polygonConfiguration":{"polygon":{"point":[{"$":{"x":0,"y":0}},{"$":{"x":0,"y":1000}},{"$":{"x":1000,"y":1000}},{"$":{"x":1000,"y":0}}]}}}]}},{"$":{"Name":"MyFieldDetectorModule","Type":"tt:FieldDetectorEngine"},"parameters":{"simpleItem":{"$":{"Name":"Sensitivity","Value":50}},"elementItem":[{"$":{"Name":"Layout"},"transformation":{"translate":{"$":{"x":-1,"y":-1}},"scale":{"$":{"x":0.002,"y":0.002}}}},{"$":{"Name":"Field"},"polygonConfiguration":{"polygon":{"point":[{"$":{"x":0,"y":0}},{"$":{"x":0,"y":1000}},{"$":{"x":1000,"y":1000}},{"$":{"x":1000,"y":0}}]}}}]}},{"$":{"Name":"MyTamperDetecModule","Type":"hikxsd:TamperEngine"},"parameters":{"simpleItem":{"$":{"Name":"Sensitivity","Value":0}},"elementItem":[{"$":{"Name":"Transformation"},"transformation":{"translate":{"$":{"x":-1,"y":-1}},"scale":{"$":{"x":0.002841,"y":0.003472}}}},{"$":{"Name":"Field"},"polygonConfiguration":{"polygon":{"point":[{"$":{"x":0,"y":0}},{"$":{"x":0,"y":576}},{"$":{"x":704,"y":576}},{"$":{"x":704,"y":0}}]}}}]}}]},"ruleEngineConfiguration":{"rule":[{"$":{"Name":"MyMotionDetectorRule","Type":"tt:CellMotionDetector"},"parameters":{"simpleItem":[{"$":{"Name":"MinCount","Value":5}},{"$":{"Name":"AlarmOnDelay","Value":1000}},{"$":{"Name":"AlarmOffDelay","Value":1000}},{"$":{"Name":"ActiveCells","Value":"JQAB/AAH8AAfwAB/AAH8AAfwAB/AB/8AH/wAf/AB/8AH/wAf//B/9v8A8A=="}}]}},{"$":{"Name":"MyLineDetector1","Type":"tt:LineDetector"},"parameters":{"simpleItem":{"$":{"Name":"Direction","Value":"Right"}},"elementItem":{"$":{"Name":"Segments"},"polyline":{"point":[{"$":{"x":17,"y":344}},{"$":{"x":457,"y":315}}]}}}},{"$":{"Name":"MyFieldDetector1","Type":"tt:FieldDetector"},"parameters":{"elementItem":{"$":{"Name":"Field"},"polygon":{"point":[{"$":{"x":0,"y":0}},{"$":{"x":0,"y":0}},{"$":{"x":0,"y":0}},{"$":{"x":0,"y":0}}]}}}},{"$":{"Name":"MyTamperDetectorRule","Type":"hikxsd:TamperDetector"},"parameters":{"elementItem":{"$":{"Name":"Field"},"polygonConfiguration":{"polygon":{"point":[{"$":{"x":0,"y":0}},{"$":{"x":0,"y":0}},{"$":{"x":0,"y":0}},{"$":{"x":0,"y":0}}]}}}}}]}}}
                                      onvif.0
                                      	2023-05-08 06:59:00.827	error	Error: DB closed
                                      onvif.0
                                      	2023-05-08 06:59:00.826	error	Error: DB closed
                                      onvif.0
                                      	2023-05-08 06:59:00.825	error	Error: DB closed
                                      onvif.0
                                      	2023-05-08 06:59:00.813	error	Error: DB closed
                                      onvif.0
                                      	2023-05-08 06:59:00.812	error	Error: DB closed
                                      onvif.0
                                      	2023-05-08 06:59:00.811	error	Error: DB closed
                                      onvif.0
                                      	2023-05-08 06:59:00.810	error	Error: DB closed
                                      • R RandyAndy
                                        @tombox
                                        • xml undefinied
                                          usw.
                                        Andreas
                                        840
                                        Log-Größe: 955.7 KB
                                        Zeit
                                        Nachricht
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        broadlink2.0
                                        broadlink2.0
                                        broadlink2.0
                                        broadlink2.0
                                        broadlink2.0
                                        broadlink2.0
                                        broadlink2.0
                                        broadlink2.0
                                        broadlink2.0
                                        fahrplan.0
                                        fahrplan.0
                                        fahrplan.0
                                        broadlink2.0
                                        broadlink2.0
                                        broadlink2.0
                                        fahrplan.0
                                        fahrplan.0
                                        fahrplan.0
                                        fahrplan.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        onvif.0
                                        T
                                        T
                                        tombox
                                        #168
                                        @randyandy Kannst du die genauen Zeitabstände sagen wenn die errors kommen.
                                        Nutz du den snapshot server? wie oft kommen die snapshot response timeouts
                                        • T tombox
                                          R
                                          R
                                          RandyAndy
                                          schrieb am zuletzt editiert von RandyAndy
                                          #169
                                          @tombox
                                          Ja ich verwende den snapshot server. ZEitabstände muss ich auswerten.
                                          Ich starte den Adapter im ürbigen alle 6 Stunden neu.
                                          Das Bild wird aktualisiert, sobald eine Bewegung (Datenpunkt erzeugt vom onvif-adapter).
                                          detektiert wird.
                                          83.8k
