  4. Puppeteer: Screenshots PhantomJS Alternative
screenshotsheadlessbrowserpuppeteerphantomjsscreenshotwebsite
247 Beiträge 24 Kommentatoren 67.9k Aufrufe 18 Beobachtet
  • foxriver76F foxriver76
    @ilovegym keine Ahnung welche Version du meinst, gerne Log zeigen
    #183
    @foxriver76
    Bin am Tablett mit meinen dicken Fingern.. verwende den buanet Docker mit Node 16
    hier beim installieren:
    host.iobroker
    2023-03-18 21:09:38.495	info	iobroker npm WARN deprecated puppeteer@13.7.0: < 19.2.0 is no longer supported
    Dann beim starten des Adapter:
    puppeteer.0
    2023-03-18 21:10:24.951	error	Error: Failed to launch the browser process![0318/211024.570664:FATAL:zygote_host_impl_linux.cc(117)] No usable sandbox! Update your kernel or see https://chromium.googlesource.com/chromium/src/+/main/docs/linux/suid_sandbox_development.md for more information on developing with the SUID sandbox. If you want to live dangerously and need an immediate workaround, you can try using --no-sandbox.#0 0x55aca5667b89 base::debug::CollectStackTrace()#1 0x55aca55cc433 base::debug::StackTrace::StackTrace()#2 0x55aca55df330 logging::LogMessage::~LogMessage()#3 0x55aca35c499b content::ZygoteHostImpl::Init()#4 0x55aca5175372 content::ContentMainRunnerImpl::Initialize()#5 0x55aca5173439 content::RunContentProcess()#6 0x55aca517358e content::ContentMain()#7 0x55aca51ced7a headless::(anonymous namespace)::RunContentMain()#8 0x55aca51cea85 headless::HeadlessShellMain()#9 0x55aca1c323e8 ChromeMain#10 0x7effdda9dd0a __libc_start_main#11 0x55aca1c3222a _startTROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md at onClose (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:241:20) at Interface.<anonymous> (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:231:68) at Interface.emit (node:events:525:35) at Interface.close (node:readline:590:8) at Socket.onend (node:readline:280:10) at Socket.emit (node:events:525:35) at endReadableNT (node:internal/streams/readable:1358:12) at processTicksAndRejections (node:internal/process/task_queues:83:21)
    puppeteer.0
    2023-03-18 21:10:24.950	error	unhandled promise rejection: Failed to launch the browser process![0318/211024.570664:FATAL:zygote_host_impl_linux.cc(117)] No usable sandbox! Update your kernel or see https://chromium.googlesource.com/chromium/src/+/main/docs/linux/suid_sandbox_development.md for more information on developing with the SUID sandbox. If you want to live dangerously and need an immediate workaround, you can try using --no-sandbox.#0 0x55aca5667b89 base::debug::CollectStackTrace()#1 0x55aca55cc433 base::debug::StackTrace::StackTrace()#2 0x55aca55df330 logging::LogMessage::~LogMessage()#3 0x55aca35c499b content::ZygoteHostImpl::Init()#4 0x55aca5175372 content::ContentMainRunnerImpl::Initialize()#5 0x55aca5173439 content::RunContentProcess()#6 0x55aca517358e content::ContentMain()#7 0x55aca51ced7a headless::(anonymous namespace)::RunContentMain()#8 0x55aca51cea85 headless::HeadlessShellMain()#9 0x55aca1c323e8 ChromeMain#10 0x7effdda9dd0a __libc_start_main#11 0x55aca1c3222a _startTROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
    foxriver76F F 2 Antworten Letzte Antwort
      @foxriver76
      host.iobroker
      puppeteer.0
      puppeteer.0
      foxriver76F Offline
      foxriver76F Offline
      foxriver76
      #184
      @ilovegym Krass, die sind tatsächlich innerhalb von einem Jahr von 13 auf 19.
      Ich habe eben eine 0.2.7 auf den Weg geschickt, gerne ausprobieren.
      Videotutorials & mehr
      • ? Offline
        #185
        @foxriver76 ja, fand ich auch, hab noch ein Problem, denke das kann auch am Docker liegen.. ? der kann irgendwie Chrome nicht starten oder hat n Problem mit der sandbox.. ??
        2023-03-19 11:05:50.634  - info: puppeteer.0 (8448) starting. Version 0.2.7 in /opt/iobroker/node_modules/iobroker.puppeteer, node: v16.19.1, js-controller: 4.0.24
        2023-03-19 11:05:52.762  - error: puppeteer.0 (8448) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-03-19 11:05:52.762  - error: puppeteer.0 (8448) unhandled promise rejection: Failed to launch the browser process!
        [0319/110552.557613:FATAL:zygote_host_impl_linux.cc(127)] No usable sandbox! Update your kernel or see https://chromium.googlesource.com/chromium/src/+/main/docs/linux/suid_sandbox_development.md for more information on developing with the SUID sandbox. If you want to live dangerously and need an immediate workaround, you can try using --no-sandbox.
        #0 0x55ab22b4c7d2 base::debug::CollectStackTrace()
        #1 0x55ab22aac373 base::debug::StackTrace::StackTrace()
        #2 0x55ab22aa92d8 logging::LogMessage::~LogMessage()
        #3 0x55ab2130cd56 content::ZygoteHostImpl::Init()
        #4 0x55ab2202113c content::ContentMainRunnerImpl::Initialize()
        #5 0x55ab2201e780 content::RunContentProcess()
        #6 0x55ab2201eb86 content::ContentMain()
        #7 0x55ab225f5259 headless::HeadlessShellMain()
        #8 0x55ab1e7d9255 ChromeMain
        #9 0x7f64f225bd0a __libc_start_main
        #10 0x55ab1e7d902a _start
        TROUBLESHOOTING: https://pptr.dev/troubleshooting
        2023-03-19 11:05:52.763  - error: puppeteer.0 (8448) Error: Failed to launch the browser process!
           at onClose (/opt/iobroker/node_modules/puppeteer-core/lib/cjs/puppeteer/node/BrowserRunner.js:302:20)
           at Interface.<anonymous> (/opt/iobroker/node_modules/puppeteer-core/lib/cjs/puppeteer/node/BrowserRunner.js:290:24)
        2023-03-19 11:05:52.764  - error: puppeteer.0 (8448) Failed to launch the browser process!
        2023-03-19 11:05:52.767  - info: puppeteer.0 (8448) terminating
        2023-03-19 11:05:52.768  - warn: puppeteer.0 (8448) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-03-19 11:05:53.311  - error: host.iobroker instance system.adapter.puppeteer.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2023-03-19 11:05:53.312  - info: host.iobroker Restart adapter system.adapter.puppeteer.0 because enabled
          foxriver76F Offline
          foxriver76F Offline
          foxriver76
          #186
          @ilovegym Probier mal bitte das im Container https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md#recommended-enable-user-namespace-cloning
          • ? Offline
            #187
            @foxriver76
            Hat leider nicht funktioniert, Variante a sagt den Datenpunkt in proc/sys gibts nicht, und bei Variante b find ich die chrome_sandbox nicht.. hmm
            Hat noch einer den Adapter im Docker laufen?
              Marty56
              #188
              Puppender stürzt bei mir auch ab, weil der Adapter wohl auch den Browser nicht starten kann.
              OS: Debian
              Node:v14.21.3
              npm: 6.14.18
              iobroker: aktuelle Versionen vom stable Repro.
              apt update und apt upgrade habe ich gemacht und gebootet.
              2023-04-21 06:39:42.178 - info: puppeteer.0 (2686) starting. Version 0.2.7 in /opt/iobroker/node_modules/iobroker.puppeteer, node: v14.21.3, js-controller: 4.0.24
              2023-04-21 06:39:42.288 - error: puppeteer.0 (2686) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2023-04-21 06:39:42.290 - error: puppeteer.0 (2686) unhandled promise rejection: Failed to launch the browser process! undefined
              2023-04-21 06:39:42.294 - error: puppeteer.0 (2686) Error: Failed to launch the browser process! undefined
              at ChildProcess.onClose (/opt/iobroker/node_modules/@puppeteer/browsers/lib/cjs/launch.js:262:24)
              at ChildProcess.emit (events.js:412:35)
              at Process.ChildProcess._handle.onexit (internal/child_process.js:285:12)
              2023-04-21 06:39:42.295 - error: puppeteer.0 (2686) Failed to launch the browser process! undefined
              2023-04-21 06:39:42.310 - info: puppeteer.0 (2686) terminating
              2023-04-21 06:39:42.313 - warn: puppeteer.0 (2686) Terminated (UNCAUGHT_EXCEPTION): Without reason
              2023-04-21 06:39:42.942 - error: host.Thom
              HW:NUC (16 GB Ram)
              OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
              Thomas BraunT ? 2 Antworten Letzte Antwort
              • M Marty56
                OS: Debian
                Node:v14.21.3
                npm: 6.14.18
                #189
                @marty56 sagte in Puppeteer: Screenshots PhantomJS Alternative:
                Node:v14.21.3
                Versuchs mal mit aktueller nodejs-Version.
                • M Marty56
                  OS: Debian
                  Node:v14.21.3
                  npm: 6.14.18
                  #190
                  @marty56 ist das ein Docker oder sowas? Ist Chrome und der Adapter mit allen Depencies installiert, also nur den Adapter alleine geht ja nicht, wie du in der Anleitung gelesen hast.. :)
                    Marty56
                    #191
                    @ilovegym Ich finde keine Anleitung zum Installieren. Im Github readme steht nur, wie man puppeteer benutzt, wenn er installiert ist.
                    Wo finde ich das Vorgehen zum Installieren von chrome?
                    HW:NUC (16 GB Ram)
                    • M Marty56
                      #192
                      @marty56 hast recht, habs mit Phantomjs verwechselt.. hier sollten alle depencies mit installiert werden..
                      und das linux ist aufm Raspi installiert, kein Docker?
                        Marty56
                        #193
                        @ilovegym Aber Dein Hinweis hat mich auf eine Spur gebraucht. Ich habe bemerkt, dass ich unter
                        /opt/iobroker/node_modules/puppeteer kein verstecktes Verzeichnis
                        .local-chromium habe.
                        Keine Ahnung warum. ich habe ganz normal über den Tab Adapter installiert.
                        HW:NUC (16 GB Ram)
                          @crunchip
                          Ich weiß ja nicht ob die Intention von @foxriver76 ist die libs selber mitzubringen, aber die sind systemweit in den genannten Paketen drin.
                          apt policy libnss3 libnspr4 libgbm1
                          bimmi
                          #194
                          Danke für den Adapter!
                          Gibt es eine Möglichkeit die Qualität des generierten jpg einzustellen?
                          Gruß Bimmi
                          iobroker in einer Proxmox Umgebung auf einem ausrangierten DELL OptiPlex 3080 24GB i5 in der VM auf SSD. Nutze den slaeh zigbee Router mit Tür- und Temperatursensoren von Aqara, viele Tasmota Devices, Unifi AP, Sprinklecontrol, günstige E-INK Displays, Adguard und noch vieles mehr 😬
                          • B bimmi
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #195
                            @bimmi RTFM https://github.com/foxriver76/ioBroker.puppeteer/blob/main/README.md
                            • arteckA arteck
                              bimmi
                              #196
                              @arteck vielen Dank für das manual! Das kenne ich bereits. Mir ging es hier in dem Beitrag rund um den Adapter für iobroker darum, ob man es ermöglichen kann, den Parameter mit quality zusätzlich zur Clip höhe/breite usw mit übertragen kann.
                              Das ist ja nicht möglich, da ja nur die wichtigsten Parameter eingetragen werden können.
                              Gruß Bimmi
                              • B bimmi
                                foxriver76F Offline
                                foxriver76F Offline
                                foxriver76
                                #197
                                @bimmi Wenn du sendTo nutzt kannst du wie in der ReadMe steht, alle Optionen die in der Puppeteer API verfügbar sind mitgeben.
                                  bimmi
                                  #198
                                  @foxriver76 ok. Danke. Jetzt verstehe ich.
                                  Geht das auch mit blockly? Sento gibt es ja keine Option für puppeteer... 😬
                                  Gruß Bimmi
                                  • B bimmi
                                    foxriver76F Offline
                                    foxriver76F Offline
                                    foxriver76
                                    schrieb am zuletzt editiert von foxriver76
                                    #199
                                    @bimmi Ich habe keine Ahnung von Blockly, im Zweifel nimmst du einen JavaScript Block und adjustierst das Beispiel aus der ReadMe. Wobei da die ganzen ? raus müssen, die zeigen nur auf, dass eine Property optional ist.
                                      bimmi
                                      #200
                                      @foxriver76 danke! Ich glaube ich hab es gefunden 😂 man lernt nie aus!
                                      Gruß Bimmi
                                      • B bimmi
                                        bimmi
                                        schrieb am zuletzt editiert von bimmi
                                        #201
                                        vielleicht nochmal an die, die bereits ein blockly erstellt hatten...
                                        Sorry, ich blick da bei dem SendTo nicht durch :(
                                        So sieht mein Blockly aus:
                                        diesen Fehler bekomme ich:
                                        javascript.0
                                        2023-07-12 16:21:54.618	error	script.js.EPS.Grundwasser: {'error':{}}
                                        puppeteer.0
                                        2023-07-12 16:21:54.615	error	Could not take screenshot of "http://192.168.1.10:8082/vis/index.html?EPS#Grundwasser": Expected options.clip.x to be a number but found undefined
                                        Der Fehler sagt eigentlich, dass es mit dem clip width und height ein Problem gibt. Der Datenpunkt ist eine "number".
                                        Jemand, der das schon in Blockly getan hat vielleicht einen Tipp für mich? 🦆
                                        Auf Debug kommt folgende Message:
                                        puppeteer.0
                                        2023-07-12 17:06:02.091	debug	Message: {"command":"screenshot","message":{"url":"http://192.168.1.10:8082/vis/index.html?EPS#Grundwasser","waitOption":{"waitForTimeout":5000},"clip":"{width:296height:128}","path":"/var/www/html/eps-display/Grundwasser.jpg","quality":100},"from":"system.adapter.javascript.0","callback":{"message":{"url":"http://192.168.1.10:8082/vis/index.html?EPS#Grundwasser","waitOption":{"waitForTimeout":5000},"clip":"{width:296height:128}","path":"/var/www/html/eps-display/Grundwasser.jpg","quality":100},"id":14,"ack":false,"time":1689174362088},"_id":40259716}
                                        Da fehlt auch m.M. noch ein Trennzeichen wenn er das aus den Textfeldern zusammenstellt...
                                        Gruß Bimmi
                                        • B bimmi
                                          javascript.0
                                          puppeteer.0
                                          puppeteer.0
                                          bimmi
                                          #202
                                          ich bin inzwischen etwas weiter gekommen:
                                          Jetzt bekomme ich zwar keine Fehlermeldung, jedoch schneider mir puppeteer den Screenshot nicht zu.
                                          puppeteer.0
                                          2023-07-12 17:57:40.099	debug	Message: {"command":"screenshot","message":{"url":"http://192.168.1.10:8082/vis/index.html?EPS#Grundwasser","path":"/var/www/html/eps-display/Grundwasser.jpg","quality":100,"waitOptions":{"waitForTimeout":2000},"clip.width":296,"clip.height":128,"clip.x":0,"clip.y":0},"from":"system.adapter.javascript.0","callback":{"message":{"url":"http://192.168.1.10:8082/vis/index.html?EPS#Grundwasser","path":"/var/www/html/eps-display/Grundwasser.jpg","quality":100,"waitOptions":{"waitForTimeout":2000},"clip.width":296,"clip.height":128,"clip.x":0,"clip.y":0},"id":37,"ack":false,"time":1689177460098},"_id":40259743}
                                          Gruß Bimmi
