  4. Influxdb2 Backitup
    5.4k
Influxdb2 Backitup
214 Beiträge 7 Kommentatoren 30.8k Aufrufe 5 Beobachtet
  • mickymM mickym
    @damrak2022 sagte in Influxdb2 Backitup:
    @mickym So, neugestartet. Was nun zuerst?
    Schauen ob der Service nun weg ist. 😁
    systemctl status influxdb
    Damrak2022D Offline
    Damrak2022D Offline
    Damrak2022
    #190
    @mickym sagte in Influxdb2 Backitup:
    Andy@homebridge:~ $ systemctl status influxdb
    ● influxdb.service - InfluxDB is an open-source, distributed, time series datab>
         Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor pre>
         Active: failed (Result: exit-code) since Thu 2023-04-20 02:53:49 CEST; 2mi>
           Docs: https://docs.influxdata.com/influxdb/
        Process: 727 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (>
            CPU: 2ms
    Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Scheduled restart job,>
    Apr 20 02:53:49 homebridge systemd[1]: Stopped InfluxDB is an open-source, dist>
    Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Start request repeated>
    Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Failed with result 'ex>
    Apr 20 02:53:49 homebridge systemd[1]: Failed to start InfluxDB is an open-sour>
    lines 1-12/12 (END)
    ● influxdb.service - InfluxDB is an open-source, distributed, time series databa>
         Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor pres>
         Active: failed (Result: exit-code) since Thu 2023-04-20 02:53:49 CEST; 2min>
        Process: 727 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (c>
            CPU: 2ms
    Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Scheduled restart job, >
    Apr 20 02:53:49 homebridge systemd[1]: Stopped InfluxDB is an open-source, distr>
    Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Start request repeated >
    Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Failed with result 'exi>
    Apr 20 02:53:49 homebridge systemd[1]: Failed to start InfluxDB is an open-sourc>
    lines 1-12/12 (END)
    ● influxdb.service - InfluxDB is an open-source, distributed, time series database
         Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor preset: enabled)
         Active: failed (Result: exit-code) since Thu 2023-04-20 02:53:49 CEST; 2min 49s ago
        Process: 727 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=203/EXEC)
            CPU: 2ms
    Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
    Apr 20 02:53:49 homebridge systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
    Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Start request repeated too quickly.
    Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Failed with result 'exit-code'.
    Apr 20 02:53:49 homebridge systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
    lines 1-12/12 (END)
            CPU: 2ms
    lines 1-12/12 (END)
            CPU: 2ms
    lines 1-12/12 (END)
            CPU: 2ms
    lines 1-12/12 (END)
    Nochmal weil Start zu schnell?
    Mit besten Grüßen
    Andy
    • Damrak2022D Damrak2022
              CPU: 2ms
      lines 1-12/12 (END)
              CPU: 2ms
      lines 1-12/12 (END)
              CPU: 2ms
      lines 1-12/12 (END)
              CPU: 2ms
      lines 1-12/12 (END)
              CPU: 2ms
      lines 1-12/12 (END)
              CPU: 2ms
      lines 1-12/12 (END)
      mickymM Offline
      mickymM Offline
      mickym
      #191
      @damrak2022 man könnte die Datei einfach löschen.
      Gut wir löschen den Service das geht:
      sudo rm /etc/systemd/system/influxdb.service
      sudo rm /lib/systemd/system/influxdb.service
      • mickymM mickym
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        #192
        Anscheinend gibt es die erste Datei nicht:
        Andy@homebridge:~ $ sudo rm /etc/systemd/system/influxdb.service
        rm: das Entfernen von '/etc/systemd/system/influxdb.service' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
        Andy@homebridge:~ $ sudo rm /lib/systemd/system/influxdb.service
        Andy@homebridge:~ $
        Mit besten Grüßen
        Andy
          Andy@homebridge:~ $
          mickymM Offline
          mickymM Offline
          mickym
          #193
          @damrak2022 Ok dann Maschine nochmal starten
          • mickymM mickym
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            #194
            @mickym ok
            Mit besten Grüßen
            Andy
            • mickymM mickym
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              #195
              @mickym Und jetzt
              Mit besten Grüßen
              Andy
                @mickym Und jetzt
                mickymM Offline
                mickymM Offline
                mickym
                #196
                @damrak2022 Schauen obs weg ist.
                • mickymM mickym
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  #197
                  Unit influxdb.service could not be found.
                  Andy@homebridge:~ $
                  Mit besten Grüßen
                  Andy
                    Andy@homebridge:~ $
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #198
                    @damrak2022 Hurra. :)
                    Nun installieren:
                    sudo apt install influxdb2
                    Nach der Installation wieder schauen, ob Service läuft
                    • mickymM mickym
                      Nun installieren:
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      #199
                      Andy@homebridge:~ $ sudo apt install influxdb2
                      Die folgenden zusätzlichen Pakete werden installiert:
                        influxdb2-cli
                      Die folgenden NEUEN Pakete werden installiert:
                        influxdb2 influxdb2-cli
                      0 aktualisiert, 2 neu installiert, 0 zu entfernen und 1 nicht aktualisiert.
                      Es müssen noch 0 B von 54,3 MB an Archiven heruntergeladen werden.
                      Nach dieser Operation werden 123 MB Plattenplatz zusätzlich benutzt.
                      Möchten Sie fortfahren? [J/n] j
                      Vormals nicht ausgewähltes Paket influxdb2 wird gewählt.
                      (Lese Datenbank ... 55623 Dateien und Verzeichnisse sind derzeit installiert.)
                      Vorbereitung zum Entpacken von .../influxdb2_2.7.0-1_arm64.deb ...
                      Entpacken von influxdb2 (2.7.0-1) ...
                      Vormals nicht ausgewähltes Paket influxdb2-cli wird gewählt.
                      Vorbereitung zum Entpacken von .../influxdb2-cli_2.7.1-2_arm64.deb ...
                      Entpacken von influxdb2-cli (2.7.1-2) ...
                      influxdb2 (2.7.0-1) wird eingerichtet ...
                      Created symlink /etc/systemd/system/influxd.service → /lib/systemd/system/influxdb.service.
                      Created symlink /etc/systemd/system/multi-user.target.wants/influxdb.service → /lib/systemd/system/influxdb.service.
                      influxdb2-cli (2.7.1-2) wird eingerichtet ...
                      Andy@homebridge:~ $
                      Mit besten Grüßen
                      Andy
                          influxdb2-cli
                        Andy@homebridge:~ $
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #200
                        @mickym Und nun
                        • mickymM mickym
                          @mickym Und nun
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          #201
                               Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
                               Active: inactive (dead)
                          Andy@homebridge:~ $
                          Mit besten Grüßen
                          Andy
                            Andy@homebridge:~ $
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #202
                            @damrak2022 Gut - schau mal ob GUI funktioniert - wenn nicht werden wir den service starten.
                            • mickymM mickym
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              #203
                              @mickym nein, wir müssen den service starten
                              Mit besten Grüßen
                              Andy
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #204
                                @damrak2022 Dann schau, ob es so geht oder wenn nicht nochmal Maschine starten.
                                Also schau erstmal
                                sudo systemctl start influxdb
                                und dann
                                • mickymM mickym
                                  Also schau erstmal
                                  und dann
                                  Damrak2022D Offline
                                  Damrak2022D Offline
                                  Damrak2022
                                  #205
                                  Sieht anscheinend gut aus:
                                  Andy@homebridge:~ $ sudo systemctl  start influxdb
                                       Active: active (running) since Thu 2023-04-20 03:20:35 CEST; 15s ago
                                      Process: 2847 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
                                     Main PID: 2848 (influxd)
                                        Tasks: 9 (limit: 3932)
                                          CPU: 1.491s
                                       CGroup: /system.slice/influxdb.service
                                               └─2848 /usr/bin/influxd
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856708Z lvl=info msg="Open store (start)">
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856962Z lvl=info msg="Open store (end)" l>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857060Z lvl=info msg="Starting retention >
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857101Z lvl=info msg="Starting precreatio>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.859797Z lvl=info msg="Starting query cont>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.868861Z lvl=info msg="Configuring InfluxQ>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.896976Z lvl=info msg=Starting log_id=0hJ3>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.898980Z lvl=info msg=Listening log_id=0hJ>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2847]: InfluxDB started
                                  Apr 20 03:20:35 homebridge systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
                                  lines 1-21/21 (END)
                                          CPU: 1.491s
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856708Z lvl=info msg="Open store (start)" >
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856962Z lvl=info msg="Open store (end)" lo>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857060Z lvl=info msg="Starting retention p>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857101Z lvl=info msg="Starting precreation>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.859797Z lvl=info msg="Starting query contr>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.868861Z lvl=info msg="Configuring InfluxQL>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.896976Z lvl=info msg=Starting log_id=0hJ3p>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.898980Z lvl=info msg=Listening log_id=0hJ3>
                                  lines 1-21/21 (END)
                                          CPU: 1.491s
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856708Z lvl=info msg="Open store (start)" log_id=0hJ3pWnl000 service=storage-engine serv>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856962Z lvl=info msg="Open store (end)" log_id=0hJ3pWnl000 service=storage-engine servic>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857060Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ3pWnl000 >
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857101Z lvl=info msg="Starting precreation service" log_id=0hJ3pWnl000 service=shard-pre>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.859797Z lvl=info msg="Starting query controller" log_id=0hJ3pWnl000 service=storage-read>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.868861Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.896976Z lvl=info msg=Starting log_id=0hJ3pWnl000 service=telemetry interval=8h
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.898980Z lvl=info msg=Listening log_id=0hJ3pWnl000 service=tcp-listener transport=http ad>
                                  lines 1-21/21 (END)
                                          CPU: 1.491s
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856708Z lvl=info msg="Open store (start)" log_id=0hJ3pWnl000 service=storage-engine service=store op>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856962Z lvl=info msg="Open store (end)" log_id=0hJ3pWnl000 service=storage-engine service=store op_n>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857060Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ3pWnl000 service=rete>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857101Z lvl=info msg="Starting precreation service" log_id=0hJ3pWnl000 service=shard-precreation che>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.859797Z lvl=info msg="Starting query controller" log_id=0hJ3pWnl000 service=storage-reads concurrenc>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.868861Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0h>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.898980Z lvl=info msg=Listening log_id=0hJ3pWnl000 service=tcp-listener transport=http addr=:8086 por>
                                  lines 1-21/21 (END)
                                          CPU: 1.491s
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856708Z lvl=info msg="Open store (start)" log_id=0hJ3pWnl000 service=storage-engine service=store op_n>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856962Z lvl=info msg="Open store (end)" log_id=0hJ3pWnl000 service=storage-engine service=store op_nam>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857060Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ3pWnl000 service=retent>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857101Z lvl=info msg="Starting precreation service" log_id=0hJ3pWnl000 service=shard-precreation check>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.859797Z lvl=info msg="Starting query controller" log_id=0hJ3pWnl000 service=storage-reads concurrency_>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.868861Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ3>
                                  Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.898980Z lvl=info msg=Listening log_id=0hJ3pWnl000 service=tcp-listener transport=http addr=:8086 port=>
                                  lines 1-21/21 (END)
                                  Mit besten Grüßen
                                  Andy
                                            CPU: 1.491s
                                    lines 1-21/21 (END)
                                            CPU: 1.491s
                                    lines 1-21/21 (END)
                                            CPU: 1.491s
                                    lines 1-21/21 (END)
                                            CPU: 1.491s
                                    lines 1-21/21 (END)
                                            CPU: 1.491s
                                    lines 1-21/21 (END)
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    #206
                                    @damrak2022 Gut und nun GUI`?
                                    • mickymM mickym
                                      Damrak2022D Offline
                                      Damrak2022D Offline
                                      Damrak2022
                                      #207
                                      @mickym Geht
                                      Mit besten Grüßen
                                      Andy
                                        @mickym Geht
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #208
                                        @damrak2022 Und kannst Du nun neues bucket einrichten, org eingeben usw. und bekommst ein neues Master-Token?
                                        • mickymM mickym
                                          Damrak2022D Offline
                                          Damrak2022D Offline
                                          Damrak2022
                                          #209
                                          @mickym Okay und das speichere ich mir 5 fach weg
                                          Mit besten Grüßen
                                          Andy
