  4. Influxdb2 Backitup
    5.4k
Influxdb2 Backitup
214 Beiträge 7 Kommentatoren 30.8k Aufrufe 5 Beobachtet
  • Damrak2022D Damrak2022
    @mickym sagte in Influxdb2 Backitup:
    sudo apt autoremove
    Ist weg, jetzt raspi Neustarten?
    mickymM Offline
    mickymM Offline
    mickym
    #187
    @damrak2022 Ja
    • mickymM mickym
      @damrak2022 Ja
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      #188
      @mickym So, neugestartet. Was nun zuerst?
      Mit besten Grüßen
      Andy
        mickymM Offline
        mickymM Offline
        mickym
        #189
        @damrak2022 sagte in Influxdb2 Backitup:
        Schauen ob der Service nun weg ist. 😁
        systemctl status influxdb
        • mickymM mickym
          Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          #190
          Andy@homebridge:~ $ systemctl status influxdb
          ● influxdb.service - InfluxDB is an open-source, distributed, time series datab>
               Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor pre>
               Active: failed (Result: exit-code) since Thu 2023-04-20 02:53:49 CEST; 2mi>
                 Docs: https://docs.influxdata.com/influxdb/
              Process: 727 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (>
                  CPU: 2ms
          Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Scheduled restart job,>
          Apr 20 02:53:49 homebridge systemd[1]: Stopped InfluxDB is an open-source, dist>
          Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Start request repeated>
          Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Failed with result 'ex>
          Apr 20 02:53:49 homebridge systemd[1]: Failed to start InfluxDB is an open-sour>
          lines 1-12/12 (END)
          ● influxdb.service - InfluxDB is an open-source, distributed, time series databa>
               Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor pres>
               Active: failed (Result: exit-code) since Thu 2023-04-20 02:53:49 CEST; 2min>
              Process: 727 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (c>
                  CPU: 2ms
          Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Scheduled restart job, >
          Apr 20 02:53:49 homebridge systemd[1]: Stopped InfluxDB is an open-source, distr>
          Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Start request repeated >
          Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Failed with result 'exi>
          Apr 20 02:53:49 homebridge systemd[1]: Failed to start InfluxDB is an open-sourc>
          lines 1-12/12 (END)
          ● influxdb.service - InfluxDB is an open-source, distributed, time series database
               Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor preset: enabled)
               Active: failed (Result: exit-code) since Thu 2023-04-20 02:53:49 CEST; 2min 49s ago
              Process: 727 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=203/EXEC)
                  CPU: 2ms
          Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
          Apr 20 02:53:49 homebridge systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
          Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Start request repeated too quickly.
          Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Failed with result 'exit-code'.
          Apr 20 02:53:49 homebridge systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
          lines 1-12/12 (END)
                  CPU: 2ms
          lines 1-12/12 (END)
                  CPU: 2ms
          lines 1-12/12 (END)
                  CPU: 2ms
          lines 1-12/12 (END)
          Nochmal weil Start zu schnell?
          Mit besten Grüßen
          Andy
                    CPU: 2ms
            lines 1-12/12 (END)
                    CPU: 2ms
            lines 1-12/12 (END)
                    CPU: 2ms
            lines 1-12/12 (END)
                    CPU: 2ms
            lines 1-12/12 (END)
                    CPU: 2ms
            lines 1-12/12 (END)
                    CPU: 2ms
            lines 1-12/12 (END)
            mickymM Offline
            mickymM Offline
            mickym
            #191
            @damrak2022 man könnte die Datei einfach löschen.
            Gut wir löschen den Service das geht:
            sudo rm /etc/systemd/system/influxdb.service
            sudo rm /lib/systemd/system/influxdb.service
            • mickymM mickym
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              #192
              Anscheinend gibt es die erste Datei nicht:
              Andy@homebridge:~ $ sudo rm /etc/systemd/system/influxdb.service
              rm: das Entfernen von '/etc/systemd/system/influxdb.service' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
              Andy@homebridge:~ $ sudo rm /lib/systemd/system/influxdb.service
              Andy@homebridge:~ $
              Mit besten Grüßen
              Andy
                Andy@homebridge:~ $
                mickymM Offline
                mickymM Offline
                mickym
                #193
                @damrak2022 Ok dann Maschine nochmal starten
                • mickymM mickym
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  #194
                  @mickym ok
                  Mit besten Grüßen
                  Andy
                  • mickymM mickym
                    Damrak2022D Offline
                    Damrak2022D Offline
                    Damrak2022
                    #195
                    @mickym Und jetzt
                    Mit besten Grüßen
                    Andy
                      @mickym Und jetzt
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #196
                      @damrak2022 Schauen obs weg ist.
                      • mickymM mickym
                        Damrak2022D Offline
                        Damrak2022D Offline
                        Damrak2022
                        #197
                        Unit influxdb.service could not be found.
                        Andy@homebridge:~ $
                        Mit besten Grüßen
                        Andy
                          Andy@homebridge:~ $
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #198
                          @damrak2022 Hurra. :)
                          Nun installieren:
                          sudo apt install influxdb2
                          Nach der Installation wieder schauen, ob Service läuft
                          • mickymM mickym
                            Nun installieren:
                            Damrak2022D Offline
                            Damrak2022D Offline
                            Damrak2022
                            #199
                            Andy@homebridge:~ $ sudo apt install influxdb2
                            Die folgenden zusätzlichen Pakete werden installiert:
                              influxdb2-cli
                            Die folgenden NEUEN Pakete werden installiert:
                              influxdb2 influxdb2-cli
                            0 aktualisiert, 2 neu installiert, 0 zu entfernen und 1 nicht aktualisiert.
                            Es müssen noch 0 B von 54,3 MB an Archiven heruntergeladen werden.
                            Nach dieser Operation werden 123 MB Plattenplatz zusätzlich benutzt.
                            Möchten Sie fortfahren? [J/n] j
                            Vormals nicht ausgewähltes Paket influxdb2 wird gewählt.
                            (Lese Datenbank ... 55623 Dateien und Verzeichnisse sind derzeit installiert.)
                            Vorbereitung zum Entpacken von .../influxdb2_2.7.0-1_arm64.deb ...
                            Entpacken von influxdb2 (2.7.0-1) ...
                            Vormals nicht ausgewähltes Paket influxdb2-cli wird gewählt.
                            Vorbereitung zum Entpacken von .../influxdb2-cli_2.7.1-2_arm64.deb ...
                            Entpacken von influxdb2-cli (2.7.1-2) ...
                            influxdb2 (2.7.0-1) wird eingerichtet ...
                            Created symlink /etc/systemd/system/influxd.service → /lib/systemd/system/influxdb.service.
                            Created symlink /etc/systemd/system/multi-user.target.wants/influxdb.service → /lib/systemd/system/influxdb.service.
                            influxdb2-cli (2.7.1-2) wird eingerichtet ...
                            Andy@homebridge:~ $
                            Mit besten Grüßen
                            Andy
                                influxdb2-cli
                              Andy@homebridge:~ $
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #200
                              @mickym Und nun
                              • mickymM mickym
                                @mickym Und nun
                                Damrak2022D Offline
                                Damrak2022D Offline
                                Damrak2022
                                #201
                                     Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
                                     Active: inactive (dead)
                                Andy@homebridge:~ $
                                Mit besten Grüßen
                                Andy
                                  Andy@homebridge:~ $
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #202
                                  @damrak2022 Gut - schau mal ob GUI funktioniert - wenn nicht werden wir den service starten.
                                  • mickymM mickym
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    #203
                                    @mickym nein, wir müssen den service starten
                                    Mit besten Grüßen
                                    Andy
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #204
                                      @damrak2022 Dann schau, ob es so geht oder wenn nicht nochmal Maschine starten.
                                      Also schau erstmal
                                      sudo systemctl start influxdb
                                      und dann
                                      • mickymM mickym
                                        Also schau erstmal
                                        und dann
                                        Damrak2022D Offline
                                        Damrak2022D Offline
                                        Damrak2022
                                        #205
                                        Sieht anscheinend gut aus:
                                        Andy@homebridge:~ $ sudo systemctl  start influxdb
                                             Active: active (running) since Thu 2023-04-20 03:20:35 CEST; 15s ago
                                            Process: 2847 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
                                           Main PID: 2848 (influxd)
                                              Tasks: 9 (limit: 3932)
                                                CPU: 1.491s
                                             CGroup: /system.slice/influxdb.service
                                                     └─2848 /usr/bin/influxd
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856708Z lvl=info msg="Open store (start)">
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856962Z lvl=info msg="Open store (end)" l>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857060Z lvl=info msg="Starting retention >
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857101Z lvl=info msg="Starting precreatio>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.859797Z lvl=info msg="Starting query cont>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.868861Z lvl=info msg="Configuring InfluxQ>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.896976Z lvl=info msg=Starting log_id=0hJ3>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.898980Z lvl=info msg=Listening log_id=0hJ>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2847]: InfluxDB started
                                        Apr 20 03:20:35 homebridge systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
                                        lines 1-21/21 (END)
                                                CPU: 1.491s
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856708Z lvl=info msg="Open store (start)" >
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856962Z lvl=info msg="Open store (end)" lo>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857060Z lvl=info msg="Starting retention p>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857101Z lvl=info msg="Starting precreation>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.859797Z lvl=info msg="Starting query contr>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.868861Z lvl=info msg="Configuring InfluxQL>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.896976Z lvl=info msg=Starting log_id=0hJ3p>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.898980Z lvl=info msg=Listening log_id=0hJ3>
                                        lines 1-21/21 (END)
                                                CPU: 1.491s
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856708Z lvl=info msg="Open store (start)" log_id=0hJ3pWnl000 service=storage-engine serv>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856962Z lvl=info msg="Open store (end)" log_id=0hJ3pWnl000 service=storage-engine servic>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857060Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ3pWnl000 >
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857101Z lvl=info msg="Starting precreation service" log_id=0hJ3pWnl000 service=shard-pre>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.859797Z lvl=info msg="Starting query controller" log_id=0hJ3pWnl000 service=storage-read>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.868861Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.896976Z lvl=info msg=Starting log_id=0hJ3pWnl000 service=telemetry interval=8h
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.898980Z lvl=info msg=Listening log_id=0hJ3pWnl000 service=tcp-listener transport=http ad>
                                        lines 1-21/21 (END)
                                                CPU: 1.491s
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856708Z lvl=info msg="Open store (start)" log_id=0hJ3pWnl000 service=storage-engine service=store op>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856962Z lvl=info msg="Open store (end)" log_id=0hJ3pWnl000 service=storage-engine service=store op_n>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857060Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ3pWnl000 service=rete>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857101Z lvl=info msg="Starting precreation service" log_id=0hJ3pWnl000 service=shard-precreation che>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.859797Z lvl=info msg="Starting query controller" log_id=0hJ3pWnl000 service=storage-reads concurrenc>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.868861Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0h>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.898980Z lvl=info msg=Listening log_id=0hJ3pWnl000 service=tcp-listener transport=http addr=:8086 por>
                                        lines 1-21/21 (END)
                                                CPU: 1.491s
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856708Z lvl=info msg="Open store (start)" log_id=0hJ3pWnl000 service=storage-engine service=store op_n>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856962Z lvl=info msg="Open store (end)" log_id=0hJ3pWnl000 service=storage-engine service=store op_nam>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857060Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ3pWnl000 service=retent>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857101Z lvl=info msg="Starting precreation service" log_id=0hJ3pWnl000 service=shard-precreation check>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.859797Z lvl=info msg="Starting query controller" log_id=0hJ3pWnl000 service=storage-reads concurrency_>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.868861Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ3>
                                        Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.898980Z lvl=info msg=Listening log_id=0hJ3pWnl000 service=tcp-listener transport=http addr=:8086 port=>
                                        lines 1-21/21 (END)
                                        Mit besten Grüßen
                                        Andy
                                                  CPU: 1.491s
                                          lines 1-21/21 (END)
                                                  CPU: 1.491s
                                          lines 1-21/21 (END)
                                                  CPU: 1.491s
                                          lines 1-21/21 (END)
                                                  CPU: 1.491s
                                          lines 1-21/21 (END)
                                                  CPU: 1.491s
                                          lines 1-21/21 (END)
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #206
                                          @damrak2022 Gut und nun GUI`?
