  4. Influxdb2 Backitup
    5.4k
Influxdb2 Backitup
214 Beiträge 7 Kommentatoren 30.8k Aufrufe 5 Beobachtet
  • Damrak2022D Damrak2022
    @mickym So, neugestartet. Was nun zuerst?
    mickymM Offline
    mickymM Offline
    mickym
    #189
    @damrak2022 sagte in Influxdb2 Backitup:
    Schauen ob der Service nun weg ist. 😁
    systemctl status influxdb
    • mickymM mickym
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      #190
      @mickym sagte in Influxdb2 Backitup:
      Andy@homebridge:~ $ systemctl status influxdb
      ● influxdb.service - InfluxDB is an open-source, distributed, time series datab>
           Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor pre>
           Active: failed (Result: exit-code) since Thu 2023-04-20 02:53:49 CEST; 2mi>
             Docs: https://docs.influxdata.com/influxdb/
          Process: 727 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (>
              CPU: 2ms
      Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Scheduled restart job,>
      Apr 20 02:53:49 homebridge systemd[1]: Stopped InfluxDB is an open-source, dist>
      Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Start request repeated>
      Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Failed with result 'ex>
      Apr 20 02:53:49 homebridge systemd[1]: Failed to start InfluxDB is an open-sour>
      lines 1-12/12 (END)
      ● influxdb.service - InfluxDB is an open-source, distributed, time series databa>
           Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor pres>
           Active: failed (Result: exit-code) since Thu 2023-04-20 02:53:49 CEST; 2min>
          Process: 727 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (c>
              CPU: 2ms
      Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Scheduled restart job, >
      Apr 20 02:53:49 homebridge systemd[1]: Stopped InfluxDB is an open-source, distr>
      Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Start request repeated >
      Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Failed with result 'exi>
      Apr 20 02:53:49 homebridge systemd[1]: Failed to start InfluxDB is an open-sourc>
      lines 1-12/12 (END)
      ● influxdb.service - InfluxDB is an open-source, distributed, time series database
           Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor preset: enabled)
           Active: failed (Result: exit-code) since Thu 2023-04-20 02:53:49 CEST; 2min 49s ago
          Process: 727 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=203/EXEC)
              CPU: 2ms
      Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
      Apr 20 02:53:49 homebridge systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
      Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Start request repeated too quickly.
      Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Failed with result 'exit-code'.
      Apr 20 02:53:49 homebridge systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
      lines 1-12/12 (END)
              CPU: 2ms
      lines 1-12/12 (END)
              CPU: 2ms
      lines 1-12/12 (END)
              CPU: 2ms
      lines 1-12/12 (END)
      Nochmal weil Start zu schnell?
      Mit besten Grüßen
      Andy
                CPU: 2ms
        lines 1-12/12 (END)
                CPU: 2ms
        lines 1-12/12 (END)
                CPU: 2ms
        lines 1-12/12 (END)
                CPU: 2ms
        lines 1-12/12 (END)
                CPU: 2ms
        lines 1-12/12 (END)
                CPU: 2ms
        lines 1-12/12 (END)
        mickymM Offline
        mickymM Offline
        mickym
        #191
        @damrak2022 man könnte die Datei einfach löschen.
        Gut wir löschen den Service das geht:
        sudo rm /etc/systemd/system/influxdb.service
        sudo rm /lib/systemd/system/influxdb.service
        • mickymM mickym
          Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          #192
          Anscheinend gibt es die erste Datei nicht:
          Andy@homebridge:~ $ sudo rm /etc/systemd/system/influxdb.service
          rm: das Entfernen von '/etc/systemd/system/influxdb.service' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
          Andy@homebridge:~ $ sudo rm /lib/systemd/system/influxdb.service
          Andy@homebridge:~ $
          Mit besten Grüßen
          Andy
            Andy@homebridge:~ $
            mickymM Offline
            mickymM Offline
            mickym
            #193
            @damrak2022 Ok dann Maschine nochmal starten
            • mickymM mickym
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              #194
              @mickym ok
              Mit besten Grüßen
              Andy
              • mickymM mickym
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                #195
                @mickym Und jetzt
                Mit besten Grüßen
                Andy
                  @mickym Und jetzt
                  mickymM Offline
                  mickymM Offline
                  mickym
                  #196
                  @damrak2022 Schauen obs weg ist.
                  • mickymM mickym
                    Damrak2022D Offline
                    Damrak2022D Offline
                    Damrak2022
                    #197
                    Unit influxdb.service could not be found.
                    Andy@homebridge:~ $
                    Mit besten Grüßen
                    Andy
                      Andy@homebridge:~ $
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #198
                      @damrak2022 Hurra. :)
                      Nun installieren:
                      sudo apt install influxdb2
                      Nach der Installation wieder schauen, ob Service läuft
                      • mickymM mickym
                        Nun installieren:
                        Damrak2022D Offline
                        Damrak2022D Offline
                        Damrak2022
                        #199
                        Andy@homebridge:~ $ sudo apt install influxdb2
                        Die folgenden zusätzlichen Pakete werden installiert:
                          influxdb2-cli
                        Die folgenden NEUEN Pakete werden installiert:
                          influxdb2 influxdb2-cli
                        0 aktualisiert, 2 neu installiert, 0 zu entfernen und 1 nicht aktualisiert.
                        Es müssen noch 0 B von 54,3 MB an Archiven heruntergeladen werden.
                        Nach dieser Operation werden 123 MB Plattenplatz zusätzlich benutzt.
                        Möchten Sie fortfahren? [J/n] j
                        Vormals nicht ausgewähltes Paket influxdb2 wird gewählt.
                        (Lese Datenbank ... 55623 Dateien und Verzeichnisse sind derzeit installiert.)
                        Vorbereitung zum Entpacken von .../influxdb2_2.7.0-1_arm64.deb ...
                        Entpacken von influxdb2 (2.7.0-1) ...
                        Vormals nicht ausgewähltes Paket influxdb2-cli wird gewählt.
                        Vorbereitung zum Entpacken von .../influxdb2-cli_2.7.1-2_arm64.deb ...
                        Entpacken von influxdb2-cli (2.7.1-2) ...
                        influxdb2 (2.7.0-1) wird eingerichtet ...
                        Created symlink /etc/systemd/system/influxd.service → /lib/systemd/system/influxdb.service.
                        Created symlink /etc/systemd/system/multi-user.target.wants/influxdb.service → /lib/systemd/system/influxdb.service.
                        influxdb2-cli (2.7.1-2) wird eingerichtet ...
                        Andy@homebridge:~ $
                        Mit besten Grüßen
                        Andy
                            influxdb2-cli
                          Andy@homebridge:~ $
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #200
                          @mickym Und nun
                          • mickymM mickym
                            @mickym Und nun
                            Damrak2022D Offline
                            Damrak2022D Offline
                            Damrak2022
                            #201
                                 Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
                                 Active: inactive (dead)
                            Andy@homebridge:~ $
                            Mit besten Grüßen
                            Andy
                              Andy@homebridge:~ $
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #202
                              @damrak2022 Gut - schau mal ob GUI funktioniert - wenn nicht werden wir den service starten.
                              • mickymM mickym
                                Damrak2022D Offline
                                Damrak2022D Offline
                                Damrak2022
                                #203
                                @mickym nein, wir müssen den service starten
                                Mit besten Grüßen
                                Andy
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #204
                                  @damrak2022 Dann schau, ob es so geht oder wenn nicht nochmal Maschine starten.
                                  Also schau erstmal
                                  sudo systemctl start influxdb
                                  und dann
                                  • mickymM mickym
                                    Also schau erstmal
                                    und dann
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    #205
                                    Sieht anscheinend gut aus:
                                    Andy@homebridge:~ $ sudo systemctl  start influxdb
                                         Active: active (running) since Thu 2023-04-20 03:20:35 CEST; 15s ago
                                        Process: 2847 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
                                       Main PID: 2848 (influxd)
                                          Tasks: 9 (limit: 3932)
                                            CPU: 1.491s
                                         CGroup: /system.slice/influxdb.service
                                                 └─2848 /usr/bin/influxd
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856708Z lvl=info msg="Open store (start)">
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856962Z lvl=info msg="Open store (end)" l>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857060Z lvl=info msg="Starting retention >
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857101Z lvl=info msg="Starting precreatio>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.859797Z lvl=info msg="Starting query cont>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.868861Z lvl=info msg="Configuring InfluxQ>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.896976Z lvl=info msg=Starting log_id=0hJ3>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.898980Z lvl=info msg=Listening log_id=0hJ>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2847]: InfluxDB started
                                    Apr 20 03:20:35 homebridge systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
                                    lines 1-21/21 (END)
                                            CPU: 1.491s
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856708Z lvl=info msg="Open store (start)" >
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856962Z lvl=info msg="Open store (end)" lo>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857060Z lvl=info msg="Starting retention p>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857101Z lvl=info msg="Starting precreation>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.859797Z lvl=info msg="Starting query contr>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.868861Z lvl=info msg="Configuring InfluxQL>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.896976Z lvl=info msg=Starting log_id=0hJ3p>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.898980Z lvl=info msg=Listening log_id=0hJ3>
                                    lines 1-21/21 (END)
                                            CPU: 1.491s
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856708Z lvl=info msg="Open store (start)" log_id=0hJ3pWnl000 service=storage-engine serv>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856962Z lvl=info msg="Open store (end)" log_id=0hJ3pWnl000 service=storage-engine servic>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857060Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ3pWnl000 >
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857101Z lvl=info msg="Starting precreation service" log_id=0hJ3pWnl000 service=shard-pre>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.859797Z lvl=info msg="Starting query controller" log_id=0hJ3pWnl000 service=storage-read>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.868861Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.896976Z lvl=info msg=Starting log_id=0hJ3pWnl000 service=telemetry interval=8h
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.898980Z lvl=info msg=Listening log_id=0hJ3pWnl000 service=tcp-listener transport=http ad>
                                    lines 1-21/21 (END)
                                            CPU: 1.491s
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856708Z lvl=info msg="Open store (start)" log_id=0hJ3pWnl000 service=storage-engine service=store op>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856962Z lvl=info msg="Open store (end)" log_id=0hJ3pWnl000 service=storage-engine service=store op_n>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857060Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ3pWnl000 service=rete>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857101Z lvl=info msg="Starting precreation service" log_id=0hJ3pWnl000 service=shard-precreation che>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.859797Z lvl=info msg="Starting query controller" log_id=0hJ3pWnl000 service=storage-reads concurrenc>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.868861Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0h>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.898980Z lvl=info msg=Listening log_id=0hJ3pWnl000 service=tcp-listener transport=http addr=:8086 por>
                                    lines 1-21/21 (END)
                                            CPU: 1.491s
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856708Z lvl=info msg="Open store (start)" log_id=0hJ3pWnl000 service=storage-engine service=store op_n>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.856962Z lvl=info msg="Open store (end)" log_id=0hJ3pWnl000 service=storage-engine service=store op_nam>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857060Z lvl=info msg="Starting retention policy enforcement service" log_id=0hJ3pWnl000 service=retent>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.857101Z lvl=info msg="Starting precreation service" log_id=0hJ3pWnl000 service=shard-precreation check>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.859797Z lvl=info msg="Starting query controller" log_id=0hJ3pWnl000 service=storage-reads concurrency_>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.868861Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ3>
                                    Apr 20 03:20:35 homebridge influxd-systemd-start.sh[2848]: ts=2023-04-20T01:20:35.898980Z lvl=info msg=Listening log_id=0hJ3pWnl000 service=tcp-listener transport=http addr=:8086 port=>
                                    lines 1-21/21 (END)
                                    Mit besten Grüßen
                                    Andy
                                              CPU: 1.491s
                                      lines 1-21/21 (END)
                                              CPU: 1.491s
                                      lines 1-21/21 (END)
                                              CPU: 1.491s
                                      lines 1-21/21 (END)
                                              CPU: 1.491s
                                      lines 1-21/21 (END)
                                              CPU: 1.491s
                                      lines 1-21/21 (END)
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #206
                                      @damrak2022 Gut und nun GUI`?
                                      • mickymM mickym
                                        Damrak2022D Offline
                                        Damrak2022D Offline
                                        Damrak2022
                                        #207
                                        @mickym Geht
                                        Mit besten Grüßen
                                        Andy
                                          @mickym Geht
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #208
                                          @damrak2022 Und kannst Du nun neues bucket einrichten, org eingeben usw. und bekommst ein neues Master-Token?
