  4. Backitup und Synology Problem
    5.4k
26 Beiträge 6 Kommentatoren 3.9k Aufrufe 4 Beobachtet
    @thexbrain
    MinimalBackup?
    Das gibt es seit Urzeiten nicht mehr, wenn ich das richtig sehe. Mit welchen Versionen biste denn da unterwegs?
    iob diag
    anschauen.
    thexbrainT Offline
    thexbrainT Offline
    thexbrain
    Sorry bin Anfänger.
    (dmesg -T) wo finde ich das`?
    iob diag kommt das raus.
    Skript v.2023-04-02
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : lxc
    Distributor ID: Ubuntu
    Description:    Ubuntu 22.04.2 LTS
    Release:        22.04
    Codename:       jammy
    PRETTY_NAME="Ubuntu 22.04.2 LTS"
    NAME="Ubuntu"
    VERSION_ID="22.04"
    VERSION="22.04.2 LTS (Jammy Jellyfish)"
    VERSION_CODENAME=jammy
    ID=ubuntu
    ID_LIKE=debian
    HOME_URL="https://www.ubuntu.com/"
    SUPPORT_URL="https://help.ubuntu.com/"
    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
    UBUNTU_CODENAME=jammy
    Systemuptime and Load:
     14:41:04 up  2:51,  2 users,  load average: 0.90, 1.06, 1.00
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Sat 2023-04-15 14:41:05 CEST
               Universal time: Sat 2023-04-15 12:41:05 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    vitali
    /home/vitali
    vitali sudo iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.1G        2.2G        1.4G        0.0K        504M        1.9G
    Swap:           512M        0.0K        511M
    Total:          4.6G        2.2G        1.9G
             4096 M total memory
             2167 M used memory
              345 M active memory
             2151 M inactive memory
             1423 M free memory
                0 M buffer memory
              504 M swap cache
              512 M total swap
                0 M used swap
              511 M free swap
    *** FILESYSTEM ***
    Filesystem                       Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4    20G  4.2G   15G  23% /
    none                             tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                            tmpfs  2.9G     0  2.9G   0% /dev/shm
    tmpfs                            tmpfs  1.2G  128K  1.2G   1% /run
    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs  576M     0  576M   0% /run/user/1001
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
    /var:
    523M    /var/
    240M    /var/lib
    225M    /var/cache
    219M    /var/cache/apt
    145M    /var/lib/apt/lists
    /opt/iobroker/backups:
    446M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    602M    /opt/iobroker/iobroker-data/
    371M    /opt/iobroker/iobroker-data/files
    165M    /opt/iobroker/iobroker-data/backup-objects
    65M     /opt/iobroker/iobroker-data/files/vis.0
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    41M     /opt/iobroker/iobroker-data/states.jsonl
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    26M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.a5972028.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.6
    javascript:     7.0.1
    Adapters from github:   0
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : Iobroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : Iobroker                                 -  enabled, port: 8081, bind: 192.168.1.18, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : Iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : Iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : Iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : Iobroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : Iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : Iobroker                                 -  enabled
    + system.adapter.harmony.0                : harmony               : Iobroker                                 -  enabled
    + system.adapter.hmip.0                   : hmip                  : Iobroker                                 -  enabled
    + system.adapter.hs100.0                  : hs100                 : Iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : Iobroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : Iobroker                                 -  enabled
      system.adapter.ical.2                   : ical                  : Iobroker                                 -  enabled
      system.adapter.ical.3                   : ical                  : Iobroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : Iobroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : Iobroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : Iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : Iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Iobroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Iobroker                                 - disabled
    + system.adapter.info.0                   : info                  : Iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : Iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : Iobroker                                 -  enabled
      system.adapter.javascript.1             : javascript            : Iobroker                                 - disabled
    + system.adapter.km200.0                  : km200                 : Iobroker                                 -  enabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : Iobroker                                 - disabled, port: 54321
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : Iobroker                                 -  enabled, port: 54321
    + system.adapter.mqtt.0                   : mqtt                  : Iobroker                                 -  enabled, port: 1884, bind: 192.168.1.18
      system.adapter.netatmo.0                : netatmo               : Iobroker                                 - disabled
      system.adapter.openweathermap.0         : openweathermap        : Iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : Iobroker                                 -  enabled
      system.adapter.robonect.0               : robonect              : Iobroker                                 - disabled
    + system.adapter.scenes.0                 : scenes                : Iobroker                                 -  enabled
      system.adapter.shelly.0                 : shelly                : Iobroker                                 - disabled, port: 1884, bind: 192.168.1.18
    + system.adapter.simple-api.0             : simple-api            : Iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : Iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.synology.0               : synology              : Iobroker                                 - disabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : Iobroker                                 -  enabled
      system.adapter.telegram.0               : telegram              : Iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : Iobroker                                 -  enabled, port: 8088, bind: 192.168.1.18, run as: admin
      system.adapter.vis-bars.0               : vis-bars              : Iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : Iobroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : Iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : Iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : Iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : Iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : Iobroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : Iobroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : Iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : Iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : Iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : Iobroker                                 -  enabled
    + system.adapter.web.0                    : web                   : Iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yr.0                     : yr                    : Iobroker                                 -  enabled
      system.adapter.zigbee.0                 : zigbee                : Iobroker                                 - disabled, port: /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
    Adapter    "admin"        : 6.3.5    , installed 6.3.6
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.16   , installed 2.6.16
    Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
    Adapter    "devices"      : 1.1.2    , installed 1.1.2
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
    Adapter    "hs100"        : 2.1.2    , installed 2.1.2
    Adapter    "info"         : 1.9.19   , installed 1.9.26
    Adapter    "iot"          : 1.14.2   , installed 1.14.5
    Adapter    "javascript"   : 6.1.4    , installed 7.0.1
    Adapter    "km200"        : 2.0.3    , installed 2.0.3
    Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "netatmo"      : 2.0.5    , installed 3.1.0
    Adapter    "openweathermap": 0.3.3   , installed 0.3.8
    Adapter    "robonect"     : 0.1.4    , installed 0.1.4
    Adapter    "shelly"       : 6.3.1    , installed 6.4.0
    Adapter    "socketio"     : 4.2.0    , installed 6.3.4
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "telegram"     : 1.15.2   , installed 1.15.6
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.1
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 4.3.0    , installed 5.5.2
    Adapter    "ws"           : 1.3.0    , installed 2.3.6
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        17902
    States:         152407
    Hit:1 https://deb.nodesource.com/node_18.x jammy InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
    Get:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [119 kB]
    Get:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
    Fetched 229 kB in 2s (128 kB/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       8681579    106878/io.sonoff.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          8164525    289/master
    tcp        0      0 192.168.1.18:8081       0.0.0.0:*               LISTEN      1000       8678239    106682/io.admin.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       8678819    106661/iobroker.js-
    tcp        1      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       8678115    106661/iobroker.js-
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          8161739    1/systemd
    tcp        0      0 192.168.1.18:1884       0.0.0.0:*               LISTEN      1000       8681480    106852/io.mqtt.0
    tcp        0      0 0.0.0.0:51841           0.0.0.0:*               LISTEN      111        8271412    26963/rpc.statd
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        8645138    97515/systemd-resol
    tcp6       0      0 :::61991                :::*                    LISTEN      1000       8681661    106935/io.harmony.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          8164526    289/master
    tcp6       0      0 :::111                  :::*                    LISTEN      0          8161741    1/systemd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          8160970    1/systemd
    tcp6       0      0 :::8088                 :::*                    LISTEN      1000       8680237    107054/io.terminal.
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       8680294    107088/io.web.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       8680140    107028/io.simple-ap
    tcp6       0      0 :::47687                :::*                    LISTEN      111        8271418    26963/rpc.statd
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        8645137    97515/systemd-resol
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          8161740    1/systemd
    udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1000       8679330    106811/io.mihome-va
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       8681662    106935/io.harmony.0
    udp        0      0 0.0.0.0:33546           0.0.0.0:*                           111        8271409    26963/rpc.statd
    udp        0      0 127.0.0.1:851           0.0.0.0:*                           0          8271404    26963/rpc.statd
    udp6       0      0 :::60588                :::*                                111        8271415    26963/rpc.statd
    udp6       0      0 :::111                  :::*                                0          8161742    1/systemd
    2023-04-15 14:40:13.257  - info: ical.1 (168527) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v18.16.0, js-controller: 4.0.24
    2023-04-15 14:40:17.257  - info: ical.2 (168396) Terminated (NO_ERROR): Without reason
    2023-04-15 14:40:17.324  - info: host.Iobroker instance system.adapter.dwd.0 started with pid 168691
    2023-04-15 14:40:17.819  - info: host.Iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
    2023-04-15 14:40:17.906  - info: ical.0 (168571) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v18.16.0, js-controller: 4.0.24
    2023-04-15 14:40:21.409  - info: ical.1 (168527) Terminated (NO_ERROR): Without reason
    2023-04-15 14:40:21.410  - info: mihome-vacuum.1 (106811) State value to set for "mihome-vacuum.1.info.water_box" has to be type "string" but received type "boolean"
    2023-04-15 14:40:21.710  - info: dwd.0 (168691) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24
    2023-04-15 14:40:21.970  - info: host.Iobroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
    2023-04-15 14:40:22.227  - info: dwd.0 (168691) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-04-15 14:40:22.749  - info: host.Iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-04-15 14:40:24.809  - info: ical.0 (168571) Terminated (NO_ERROR): Without reason
    2023-04-15 14:40:25.345  - info: host.Iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-04-15 14:40:42.502  - info: mihome-vacuum.1 (106811) State value to set for "mihome-vacuum.1.info.water_box" has to be type "string" but received type "boolean"
    2023-04-15 14:41:03.709  - info: mihome-vacuum.1 (106811) State value to set for "mihome-vacuum.1.info.water_box" has to be type "string" but received type "boolean"
    2023-04-15 14:41:24.802  - info: mihome-vacuum.1 (106811) State value to set for "mihome-vacuum.1.info.water_box" has to be type "string" but received type "boolean"
    2023-04-15 14:41:54.726  - info: mihome-vacuum.1 (106811) State value to set for "mihome-vacuum.1.info.water_box" has to be type "string" but received type "boolean"
    2023-04-15 14:42:00.117  - info: host.Iobroker instance system.adapter.ical.0 started with pid 170664
    2023-04-15 14:42:04.909  - info: host.Iobroker instance system.adapter.ical.1 started with pid 170799
    2023-04-15 14:42:05.567  - info: ical.0 (170664) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v18.16.0, js-controller: 4.0.24
    2023-04-15 14:42:09.173  - info: host.Iobroker instance system.adapter.ical.2 started with pid 171163
    2023-04-15 14:42:13.927  - info: host.Iobroker instance system.adapter.ical.3 started with pid 171588
    • haselchenH haselchen
      @thexbrain
      Hast du denn den Ordner , dessen Pfad du im Adapter angegeben hast, in der Syno angelegt unter gemeinsame Ordner?
      Mach das mal wie bei mir.
      Backups Ordner anlegen in Gemeinsame Ordner und dann so den Pfad angeben wie bei mir
      thexbrainT Offline
      thexbrainT Offline
      thexbrain
      @haselchen Ja hatte schon einen Ordner.
      Ich habe jetzt noch einen Ordner erstellt und versucht. Aber gleiches Problem.
      haselchenH Thomas BraunT 2 Antworten Letzte Antwort
      • thexbrainT thexbrain
        haselchenH Offline
        haselchenH Offline
        haselchen
        @thexbrain
        Du sollst den Pfad so schreiben wie ich es habe
          @thexbrain
          Muss das nicht mal wieder anders aufgesetzt werden?
          thexbrainT 1 Antwort Letzte Antwort
            @thexbrain
            thexbrainT Offline
            thexbrainT Offline
            thexbrain
            @thomas-braun was meinst du damit genau?
            Das System hatte ich erst vor kurzem neu aufgesetzt.
              @thexbrain
              LXC muss man bei Netzwerkgeschichten ggf. als 'privileged' oder so aufsetzen. Hab ich aber nix mit am Hut, war nur über das LXC-Setup gestolpert.
                Sorry bin Anfänger.
                Skript v.2023-04-02
                *** BASE SYSTEM ***
                Docker          : false
                Release:        22.04
                Codename:       jammy
                NAME="Ubuntu"
                VERSION_ID="22.04"
                ID=ubuntu
                ID_LIKE=debian
                CPU threads: 2
                                 RTC time: n/a
                          RTC in local TZ: no
                vitali
                /home/vitali
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                         4096 M total memory
                         2167 M used memory
                          345 M active memory
                         1423 M free memory
                            0 M buffer memory
                          504 M swap cache
                          512 M total swap
                            0 M used swap
                          511 M free swap
                *** FILESYSTEM ***
                /var:
                523M    /var/
                240M    /var/lib
                225M    /var/cache
                219M    /var/cache/apt
                /usr/bin/npm            9.5.1
                /usr/bin/npx            9.5.1
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.3.6
                javascript:     7.0.1
                Adapter State
                + instance is alive
                Objects and States
                Objects:        17902
                States:         152407
                Pending Updates: 0
                GlasfaserG Offline
                GlasfaserG Offline
                @thexbrain sagte in Backitup und Synology Problem:
                Nur mal so nebenbei , wie passt das zusammen , bzw. wie bekommt man das hin !?
                Sorry bin Anfänger.
                github:	6.4.3 for 13 days
                latest:	6.4.3 for 15 days
                stable:	6.3.5 for 3 months
                ist :
                github:	7.0.3
                latest:	7.0.3 for 29 days
                stable:	6.1.4 for 5 months
                  @haselchen sagte in Backitup und Synology Problem:
                  @thexbrain
                  Mach es per FTP
                  Leg einen gemeinsamen Ordner an auf der Syno.
                  Ich hab dir mal nen Screenshot gemacht
                  Das Backup wird in den Ordner gemacht und auch in den Backup Ordner von Iobroker
                  Und hier die Dateien, die in den originalen Ordner abgelegt werden
                  Klappt auch nicht.
                  Bekomme auch ein Fehler.
                  Backup Ordner bleibt leer.
                  	[iobroker] Error: Maximum number of tries exceeded. Please contact the site manager.
                  backitup.0
                  2023-04-15 14:07:09.032	error	[iobroker/ftp] Error: Maximum number of tries exceeded. Please contact the site manager.
                  Started iobroker ...
                  [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:00","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.27","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/Backup_iobroker","dirMinimal":"/backupDir/minimal","user":"Fischer","pass":"****","port":"21","secure":false,"ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"shortTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                  [DEBUG] [iobroker] - host.Iobroker 152411 states saved
                  [DEBUG] [iobroker] - host.Iobroker 17906 objects saved
                  [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_04_15-14_12_21_backupiobroker.tar.gz
                  [DEBUG] [iobroker] - done
                  [ERROR] [ftp] - Error: Maximum number of tries exceeded. Please contact the site manager.
                  [DEBUG] [ftp] start with {"type":"storage","source":"ftp","host":"192.168.1.27","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/Backup_iobroker","dirMinimal":"/backupDir/minimal","user":"Fischer","pass":"****","port":"21","secure":false,"ignoreErrors":false,"deleteBackupAfter":0}
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Das sieht mir so aus ... als würde dein Syn den Zugriff von deinem neuen lxc blocken .
                  schaue mal in den Sicherheitseistellungen von der Syn mal nach , bzw. auch in der Firewall
                  Eventuell auch :
                  https://www.synology-forum.de/threads/max-number-of-tries-exeeded.85250/
                  und
                  ... ich hoffe du hast den admin nicht mehr aktiv , denn dies ist eine Sicheheitslücker auf der Syn !?
                  • GlasfaserG Glasfaser
                    Eventuell auch :
                    und
                    simatecS Offline
                    simatecS Offline
                    simatec
                    @thexbrain Ein LXC muss für CIFS oder NFS privilegiert ausgeführt werden.
                    Sollte dann in den Optionen so ausschauen
                    c912b959-0723-497c-b21c-30b0227e5cb3-Bildschirmfoto 2023-04-17 um 19.29.02.png
                    • Besuche meine Github Seite
                    • HowTo Restore ioBroker
                    • simatecS simatec
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @thexbrain
                      ist für dich ...
                      siehe Antwort von @simatec
