  4. Backitup und Synology Problem
    5.4k
26 Beiträge 6 Kommentatoren 3.9k Aufrufe 4 Beobachtet
    @thexbrain
    Ist das auf dem Server richtig?
    username=Fischer,password=****
    thexbrainT Offline
    thexbrainT Offline
    thexbrain
    @thomas-braun Ja das passt
    • thexbrainT thexbrain
      @thexbrain
      Und was steht in
      dmesg -T
      zu den Zeiten des Backups drin?
      • haselchenH haselchen
        @thexbrain
        Mach es per FTP
        Leg einen gemeinsamen Ordner an auf der Syno.
        Ich hab dir mal nen Screenshot gemacht
        Das Backup wird in den Ordner gemacht und auch in den Backup Ordner von Iobroker
        Und hier die Dateien, die in den originalen Ordner abgelegt werden
        thexbrainT Offline
        thexbrainT Offline
        thexbrain
        @haselchen sagte in Backitup und Synology Problem:
        @thexbrain
        Mach es per FTP
        Klappt auch nicht.
        Bekomme auch ein Fehler.
        Backup Ordner bleibt leer.
        	[iobroker] Error: Maximum number of tries exceeded. Please contact the site manager.
        backitup.0
        2023-04-15 14:07:09.032	error	[iobroker/ftp] Error: Maximum number of tries exceeded. Please contact the site manager.
        Started iobroker ...
        [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:00","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"ftp","host":"192.168.1.27","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/Backup_iobroker","dirMinimal":"/backupDir/minimal","user":"Fischer","pass":"****","port":"21","secure":false,"ignoreErrors":false},"ignoreErrors":false,"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"shortTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
        [DEBUG] [iobroker] - host.Iobroker 152411 states saved
        [DEBUG] [iobroker] - host.Iobroker 17906 objects saved
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_04_15-14_12_21_backupiobroker.tar.gz
        [DEBUG] [iobroker] - done
        [ERROR] [ftp] - Error: Maximum number of tries exceeded. Please contact the site manager.
        [DEBUG] [ftp] start with {"type":"storage","source":"ftp","host":"192.168.1.27","debugging":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"/Backup_iobroker","dirMinimal":"/backupDir/minimal","user":"Fischer","pass":"****","port":"21","secure":false,"ignoreErrors":false,"deleteBackupAfter":0}
        haselchenH Thomas BraunT GlasfaserG 3 Antworten Letzte Antwort
          @thexbrain
          Mach es per FTP
          Klappt auch nicht.
          backitup.0
          haselchenH Offline
          haselchenH Offline
          haselchen
          @thexbrain
          Hast du das auf der Syno aktiviert?
          thexbrainT 1 Antwort Letzte Antwort
            @thexbrain
            Mach es per FTP
            Klappt auch nicht.
            backitup.0
            @thexbrain
            MinimalBackup?
            Das gibt es seit Urzeiten nicht mehr, wenn ich das richtig sehe. Mit welchen Versionen biste denn da unterwegs?
            iob diag
            anschauen.
              @thexbrain
              thexbrainT Offline
              thexbrainT Offline
              thexbrain
              @haselchen ja das passt soweit.
                haselchenH Offline
                haselchenH Offline
                haselchen
                @thexbrain
                Hast du denn den Ordner , dessen Pfad du im Adapter angegeben hast, in der Syno angelegt unter gemeinsame Ordner?
                Mach das mal wie bei mir.
                Backups Ordner anlegen in Gemeinsame Ordner und dann so den Pfad angeben wie bei mir
                  @thexbrain
                  MinimalBackup?
                  iob diag
                  anschauen.
                  thexbrainT Offline
                  thexbrainT Offline
                  thexbrain
                  Sorry bin Anfänger.
                  (dmesg -T) wo finde ich das`?
                  iob diag kommt das raus.
                  Skript v.2023-04-02
                  *** BASE SYSTEM ***
                  Architecture    : x86_64
                  Docker          : false
                  Virtualization  : lxc
                  Distributor ID: Ubuntu
                  Description:    Ubuntu 22.04.2 LTS
                  Release:        22.04
                  Codename:       jammy
                  PRETTY_NAME="Ubuntu 22.04.2 LTS"
                  NAME="Ubuntu"
                  VERSION_ID="22.04"
                  VERSION="22.04.2 LTS (Jammy Jellyfish)"
                  VERSION_CODENAME=jammy
                  ID=ubuntu
                  ID_LIKE=debian
                  HOME_URL="https://www.ubuntu.com/"
                  SUPPORT_URL="https://help.ubuntu.com/"
                  BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
                  PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
                  UBUNTU_CODENAME=jammy
                  Systemuptime and Load:
                   14:41:04 up  2:51,  2 users,  load average: 0.90, 1.06, 1.00
                  CPU threads: 2
                  *** Time and Time Zones ***
                                 Local time: Sat 2023-04-15 14:41:05 CEST
                             Universal time: Sat 2023-04-15 12:41:05 UTC
                                   RTC time: n/a
                                NTP service: inactive
                            RTC in local TZ: no
                  *** User and Groups ***
                  vitali
                  /home/vitali
                  vitali sudo iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            4.1G        2.2G        1.4G        0.0K        504M        1.9G
                  Swap:           512M        0.0K        511M
                  Total:          4.6G        2.2G        1.9G
                           4096 M total memory
                           2167 M used memory
                            345 M active memory
                           2151 M inactive memory
                           1423 M free memory
                              0 M buffer memory
                            504 M swap cache
                            512 M total swap
                              0 M used swap
                            511 M free swap
                  *** FILESYSTEM ***
                  Filesystem                       Type   Size  Used Avail Use% Mounted on
                  /dev/mapper/pve-vm--100--disk--0 ext4    20G  4.2G   15G  23% /
                  none                             tmpfs  492K  4.0K  488K   1% /dev
                  tmpfs                            tmpfs  2.9G     0  2.9G   0% /dev/shm
                  tmpfs                            tmpfs  1.2G  128K  1.2G   1% /run
                  tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
                  tmpfs                            tmpfs  576M     0  576M   0% /run/user/1001
                  dmesg: read kernel buffer failed: Operation not permitted
                  TARGET SOURCE                           FSTYPE OPTIONS
                  /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
                  /var:
                  523M    /var/
                  240M    /var/lib
                  225M    /var/cache
                  219M    /var/cache/apt
                  145M    /var/lib/apt/lists
                  /opt/iobroker/backups:
                  446M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  602M    /opt/iobroker/iobroker-data/
                  371M    /opt/iobroker/iobroker-data/files
                  165M    /opt/iobroker/iobroker-data/backup-objects
                  65M     /opt/iobroker/iobroker-data/files/vis.0
                  51M     /opt/iobroker/iobroker-data/files/javascript.admin
                  41M     /opt/iobroker/iobroker-data/states.jsonl
                  33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
                  26M     /opt/iobroker/iobroker-data/objects.jsonl
                  19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.a5972028.js.map
                  19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v18.16.0
                  /usr/bin/node           v18.16.0
                  /usr/bin/npm            9.5.1
                  /usr/bin/npx            9.5.1
                  nodejs:
                    Installed: 18.16.0-deb-1nodesource1
                    Candidate: 18.16.0-deb-1nodesource1
                    Version table:
                   *** 18.16.0-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
                       12.22.9~dfsg-1ubuntu3 500
                          500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                  No problems detected
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller:  4.0.24
                  admin:          6.3.6
                  javascript:     7.0.1
                  Adapters from github:   0
                  Adapter State
                  + system.adapter.accuweather.0            : accuweather           : Iobroker                                 -  enabled
                  + system.adapter.admin.0                  : admin                 : Iobroker                                 -  enabled, port: 8081, bind: 192.168.1.18, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : Iobroker                                 -  enabled
                  + system.adapter.backitup.0               : backitup              : Iobroker                                 -  enabled
                    system.adapter.daswetter.0              : daswetter             : Iobroker                                 -  enabled
                    system.adapter.devices.0                : devices               : Iobroker                                 - disabled
                  + system.adapter.discovery.0              : discovery             : Iobroker                                 -  enabled
                    system.adapter.dwd.0                    : dwd                   : Iobroker                                 -  enabled
                  + system.adapter.harmony.0                : harmony               : Iobroker                                 -  enabled
                  + system.adapter.hmip.0                   : hmip                  : Iobroker                                 -  enabled
                  + system.adapter.hs100.0                  : hs100                 : Iobroker                                 -  enabled
                    system.adapter.ical.0                   : ical                  : Iobroker                                 -  enabled
                    system.adapter.ical.1                   : ical                  : Iobroker                                 -  enabled
                    system.adapter.ical.2                   : ical                  : Iobroker                                 -  enabled
                    system.adapter.ical.3                   : ical                  : Iobroker                                 -  enabled
                    system.adapter.icons-icons8.0           : icons-icons8          : Iobroker                                 - disabled
                    system.adapter.icons-material-png.0     : icons-material-png    : Iobroker                                 - disabled
                    system.adapter.icons-material-svg.0     : icons-material-svg    : Iobroker                                 - disabled
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : Iobroker                                 - disabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Iobroker                                 - disabled
                    system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Iobroker                                 - disabled
                  + system.adapter.info.0                   : info                  : Iobroker                                 -  enabled
                  + system.adapter.iot.0                    : iot                   : Iobroker                                 -  enabled
                  + system.adapter.javascript.0             : javascript            : Iobroker                                 -  enabled
                    system.adapter.javascript.1             : javascript            : Iobroker                                 - disabled
                  + system.adapter.km200.0                  : km200                 : Iobroker                                 -  enabled
                    system.adapter.mihome-vacuum.0          : mihome-vacuum         : Iobroker                                 - disabled, port: 54321
                  + system.adapter.mihome-vacuum.1          : mihome-vacuum         : Iobroker                                 -  enabled, port: 54321
                  + system.adapter.mqtt.0                   : mqtt                  : Iobroker                                 -  enabled, port: 1884, bind: 192.168.1.18
                    system.adapter.netatmo.0                : netatmo               : Iobroker                                 - disabled
                    system.adapter.openweathermap.0         : openweathermap        : Iobroker                                 -  enabled
                  + system.adapter.ping.0                   : ping                  : Iobroker                                 -  enabled
                    system.adapter.robonect.0               : robonect              : Iobroker                                 - disabled
                  + system.adapter.scenes.0                 : scenes                : Iobroker                                 -  enabled
                    system.adapter.shelly.0                 : shelly                : Iobroker                                 - disabled, port: 1884, bind: 192.168.1.18
                  + system.adapter.simple-api.0             : simple-api            : Iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  + system.adapter.sonoff.0                 : sonoff                : Iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                    system.adapter.synology.0               : synology              : Iobroker                                 - disabled, port: 5000
                  + system.adapter.tankerkoenig.0           : tankerkoenig          : Iobroker                                 -  enabled
                    system.adapter.telegram.0               : telegram              : Iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.terminal.0               : terminal              : Iobroker                                 -  enabled, port: 8088, bind: 192.168.1.18, run as: admin
                    system.adapter.vis-bars.0               : vis-bars              : Iobroker                                 - disabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : Iobroker                                 - disabled
                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : Iobroker                                 - disabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Iobroker                                 - disabled
                    system.adapter.vis-justgage.0           : vis-justgage          : Iobroker                                 - disabled
                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : Iobroker                                 - disabled
                    system.adapter.vis-metro.0              : vis-metro             : Iobroker                                 - disabled
                    system.adapter.vis-players.0            : vis-players           : Iobroker                                 - disabled
                    system.adapter.vis-plumb.0              : vis-plumb             : Iobroker                                 - disabled
                    system.adapter.vis-rgraph.0             : vis-rgraph            : Iobroker                                 - disabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : Iobroker                                 - disabled
                    system.adapter.vis-weather.0            : vis-weather           : Iobroker                                 - disabled
                    system.adapter.vis.0                    : vis                   : Iobroker                                 -  enabled
                  + system.adapter.web.0                    : web                   : Iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    system.adapter.yr.0                     : yr                    : Iobroker                                 -  enabled
                    system.adapter.zigbee.0                 : zigbee                : Iobroker                                 - disabled, port: /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
                  Adapter    "admin"        : 6.3.5    , installed 6.3.6
                  Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                  Adapter    "backitup"     : 2.6.16   , installed 2.6.16
                  Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
                  Adapter    "devices"      : 1.1.2    , installed 1.1.2
                  Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                  Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                  Adapter    "hmip"         : 1.20.0   , installed 1.20.0
                  Adapter    "hs100"        : 2.1.2    , installed 2.1.2
                  Adapter    "info"         : 1.9.19   , installed 1.9.26
                  Adapter    "iot"          : 1.14.2   , installed 1.14.5
                  Adapter    "javascript"   : 6.1.4    , installed 7.0.1
                  Adapter    "km200"        : 2.0.3    , installed 2.0.3
                  Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
                  Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                  Adapter    "netatmo"      : 2.0.5    , installed 3.1.0
                  Adapter    "openweathermap": 0.3.3   , installed 0.3.8
                  Adapter    "robonect"     : 0.1.4    , installed 0.1.4
                  Adapter    "shelly"       : 6.3.1    , installed 6.4.0
                  Adapter    "socketio"     : 4.2.0    , installed 6.3.4
                  Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                  Adapter    "synology"     : 2.1.13   , installed 2.1.13
                  Adapter    "telegram"     : 1.15.2   , installed 1.15.6
                  Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                  Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.1
                  Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                  Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                  Adapter    "web"          : 4.3.0    , installed 5.5.2
                  Adapter    "ws"           : 1.3.0    , installed 2.3.6
                  Adapter    "yr"           : 5.3.0    , installed 5.3.0
                  Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                  Objects and States
                  Objects:        17902
                  States:         152407
                  Hit:1 https://deb.nodesource.com/node_18.x jammy InRelease
                  Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                  Get:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [119 kB]
                  Get:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
                  Fetched 229 kB in 2s (128 kB/s)
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       8681579    106878/io.sonoff.0
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          8164525    289/master
                  tcp        0      0 192.168.1.18:8081       0.0.0.0:*               LISTEN      1000       8678239    106682/io.admin.0
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       8678819    106661/iobroker.js-
                  tcp        1      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       8678115    106661/iobroker.js-
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          8161739    1/systemd
                  tcp        0      0 192.168.1.18:1884       0.0.0.0:*               LISTEN      1000       8681480    106852/io.mqtt.0
                  tcp        0      0 0.0.0.0:51841           0.0.0.0:*               LISTEN      111        8271412    26963/rpc.statd
                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        8645138    97515/systemd-resol
                  tcp6       0      0 :::61991                :::*                    LISTEN      1000       8681661    106935/io.harmony.0
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          8164526    289/master
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          8161741    1/systemd
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          8160970    1/systemd
                  tcp6       0      0 :::8088                 :::*                    LISTEN      1000       8680237    107054/io.terminal.
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1000       8680294    107088/io.web.0
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1000       8680140    107028/io.simple-ap
                  tcp6       0      0 :::47687                :::*                    LISTEN      111        8271418    26963/rpc.statd
                  udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        8645137    97515/systemd-resol
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          8161740    1/systemd
                  udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1000       8679330    106811/io.mihome-va
                  udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       8681662    106935/io.harmony.0
                  udp        0      0 0.0.0.0:33546           0.0.0.0:*                           111        8271409    26963/rpc.statd
                  udp        0      0 127.0.0.1:851           0.0.0.0:*                           0          8271404    26963/rpc.statd
                  udp6       0      0 :::60588                :::*                                111        8271415    26963/rpc.statd
                  udp6       0      0 :::111                  :::*                                0          8161742    1/systemd
                  2023-04-15 14:40:13.257  - info: ical.1 (168527) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v18.16.0, js-controller: 4.0.24
                  2023-04-15 14:40:17.257  - info: ical.2 (168396) Terminated (NO_ERROR): Without reason
                  2023-04-15 14:40:17.324  - info: host.Iobroker instance system.adapter.dwd.0 started with pid 168691
                  2023-04-15 14:40:17.819  - info: host.Iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
                  2023-04-15 14:40:17.906  - info: ical.0 (168571) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v18.16.0, js-controller: 4.0.24
                  2023-04-15 14:40:21.409  - info: ical.1 (168527) Terminated (NO_ERROR): Without reason
                  2023-04-15 14:40:21.410  - info: mihome-vacuum.1 (106811) State value to set for "mihome-vacuum.1.info.water_box" has to be type "string" but received type "boolean"
                  2023-04-15 14:40:21.710  - info: dwd.0 (168691) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24
                  2023-04-15 14:40:21.970  - info: host.Iobroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                  2023-04-15 14:40:22.227  - info: dwd.0 (168691) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-04-15 14:40:22.749  - info: host.Iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-04-15 14:40:24.809  - info: ical.0 (168571) Terminated (NO_ERROR): Without reason
                  2023-04-15 14:40:25.345  - info: host.Iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  2023-04-15 14:40:42.502  - info: mihome-vacuum.1 (106811) State value to set for "mihome-vacuum.1.info.water_box" has to be type "string" but received type "boolean"
                  2023-04-15 14:41:03.709  - info: mihome-vacuum.1 (106811) State value to set for "mihome-vacuum.1.info.water_box" has to be type "string" but received type "boolean"
                  2023-04-15 14:41:24.802  - info: mihome-vacuum.1 (106811) State value to set for "mihome-vacuum.1.info.water_box" has to be type "string" but received type "boolean"
                  2023-04-15 14:41:54.726  - info: mihome-vacuum.1 (106811) State value to set for "mihome-vacuum.1.info.water_box" has to be type "string" but received type "boolean"
                  2023-04-15 14:42:00.117  - info: host.Iobroker instance system.adapter.ical.0 started with pid 170664
                  2023-04-15 14:42:04.909  - info: host.Iobroker instance system.adapter.ical.1 started with pid 170799
                  2023-04-15 14:42:05.567  - info: ical.0 (170664) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v18.16.0, js-controller: 4.0.24
                  2023-04-15 14:42:09.173  - info: host.Iobroker instance system.adapter.ical.2 started with pid 171163
                  2023-04-15 14:42:13.927  - info: host.Iobroker instance system.adapter.ical.3 started with pid 171588
                    @thexbrain
                    thexbrainT Offline
                    thexbrainT Offline
                    thexbrain
                    @haselchen Ja hatte schon einen Ordner.
                    Ich habe jetzt noch einen Ordner erstellt und versucht. Aber gleiches Problem.
                    haselchenH Thomas BraunT 2 Antworten Letzte Antwort
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      @thexbrain
                      Du sollst den Pfad so schreiben wie ich es habe
                        @thexbrain
                        Muss das nicht mal wieder anders aufgesetzt werden?
                          @thexbrain
                          thexbrainT Offline
                          thexbrainT Offline
                          thexbrain
                          @thomas-braun was meinst du damit genau?
                          Das System hatte ich erst vor kurzem neu aufgesetzt.
                            @thexbrain
                            LXC muss man bei Netzwerkgeschichten ggf. als 'privileged' oder so aufsetzen. Hab ich aber nix mit am Hut, war nur über das LXC-Setup gestolpert.
                              Sorry bin Anfänger.
                              Skript v.2023-04-02
                              *** BASE SYSTEM ***
                              Docker          : false
                              Release:        22.04
                              Codename:       jammy
                              NAME="Ubuntu"
                              VERSION_ID="22.04"
                              ID=ubuntu
                              ID_LIKE=debian
                              CPU threads: 2
                                               RTC time: n/a
                                        RTC in local TZ: no
                              vitali
                              /home/vitali
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                                       4096 M total memory
                                       2167 M used memory
                                        345 M active memory
                                       1423 M free memory
                                          0 M buffer memory
                                        504 M swap cache
                                        512 M total swap
                                          0 M used swap
                                        511 M free swap
                              *** FILESYSTEM ***
                              /var:
                              523M    /var/
                              240M    /var/lib
                              225M    /var/cache
                              219M    /var/cache/apt
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.3.6
                              javascript:     7.0.1
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        17902
                              States:         152407
                              Pending Updates: 0
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @thexbrain sagte in Backitup und Synology Problem:
                              Nur mal so nebenbei , wie passt das zusammen , bzw. wie bekommt man das hin !?
                              Sorry bin Anfänger.
                              github:	6.4.3 for 13 days
                              latest:	6.4.3 for 15 days
                              stable:	6.3.5 for 3 months
                              ist :
                              github:	7.0.3
                              latest:	7.0.3 for 29 days
                              stable:	6.1.4 for 5 months
                                @thexbrain
                                Mach es per FTP
                                Klappt auch nicht.
                                backitup.0
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Das sieht mir so aus ... als würde dein Syn den Zugriff von deinem neuen lxc blocken .
                                schaue mal in den Sicherheitseistellungen von der Syn mal nach , bzw. auch in der Firewall
                                Eventuell auch :
                                https://www.synology-forum.de/threads/max-number-of-tries-exeeded.85250/
                                und
                                ... ich hoffe du hast den admin nicht mehr aktiv , denn dies ist eine Sicheheitslücker auf der Syn !?
                                • GlasfaserG Glasfaser
                                  Eventuell auch :
                                  und
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  @thexbrain Ein LXC muss für CIFS oder NFS privilegiert ausgeführt werden.
                                  Sollte dann in den Optionen so ausschauen
                                  c912b959-0723-497c-b21c-30b0227e5cb3-Bildschirmfoto 2023-04-17 um 19.29.02.png
                                  • Besuche meine Github Seite
                                  • HowTo Restore ioBroker
                                  • simatecS simatec
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @thexbrain
                                    ist für dich ...
                                    siehe Antwort von @simatec
