  3. Off Topic
  4. Proxmox
  5. Proxmox VM friert ein
    2.7k
    4.8k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
186 Beiträge 20 Kommentatoren 45.4k Aufrufe 14 Beobachtet
  • T Trooper
    genau da ist das Problem
    es gibt davor keine datei
    das syslog gibt etwas aus
    einmal
    Apr 12 22:42:04 rockpi-4c chronyd[919]: System clock TAI offset set to 37 seconds
    Apr 12 22:42:08 rockpi-4c systemd[1]: Starting system activity accounting tool...
    Apr 12 22:42:08 rockpi-4c systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
    Apr 12 22:42:08 rockpi-4c systemd[1]: sysstat-collect.service: Deactivated successfully.
    Apr 12 22:42:08 rockpi-4c systemd[1]: Finished system activity accounting tool.
    Apr 12 22:42:23 rockpi-4c systemd[1]: systemd-hostnamed.service: Deactivated successfully.
    Apr 12 22:42:44 rockpi-4c bash[824]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
    Apr 12 22:42:44 rockpi-4c bash[824]: Send diag info: {"uuid":"c1b40163-c876-817d-fb52-0ed724c840f1","language":"de","country":"","hosts":[{"version":"4.0.24","platform":"Javascript/Node.js","type":"linux"}],"node":"v16.19.1","arch":"arm64","docker":false,"adapters":{"admin":{"version":"6.3.5","platform":"Javascript/Node.js"},"discovery":{"version":"3.1.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.6.16","platform":"Javascript/Node.js"},"web":{"version":"4.3.0","platform":"Javascript/Node.js"},"vis":{"version":"1.4.16","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":5,"compactMode":false,"noCompactInstances":0,"model":"Cortex-A53","cpus":6,"mem":4051189760,"ostype":"Linux","city":"Schwerin","vis":6}
    Apr 12 22:45:01 rockpi-4c CRON[1587]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
    Apr 12 22:45:01 rockpi-4c CRON[1586]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
    Apr 12 22:47:29 rockpi-4c chronyd[919]: Selected source 54.38.156.22 (1.ubuntu.pool.ntp.org)
    Apr 12 22:47:58 rockpi-4c bash[824]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
    Apr 12 22:47:58 rockpi-4c bash[824]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
    Apr 12 22:48:06 rockpi-4c bash[824]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
    Apr 12 22:48:27 rockpi-4c bash[824]: Send diag info: {"uuid":"c1b40163-c876-817d-fb52-0ed724c840f1","language":"de","country":"","hosts":[{"version":"4.0.24","platform":"Javascript/Node.js","type":"linux"}],"node":"v16.19.1","arch":"arm64","docker":false,"adapters":{"admin":{"version":"6.3.5","platform":"Javascript/Node.js"},"discovery":{"version":"3.1.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.6.16","platform":"Javascript/Node.js"},"web":{"version":"4.3.0","platform":"Javascript/Node.js"},"vis":{"version":"1.4.16","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":5,"compactMode":false,"noCompactInstances":0,"model":"Cortex-A53","cpus":6,"mem":4051189760,"ostype":"Linux","city":"Schwerin","vis":6}
    Apr 12 22:50:00 rockpi-4c systemd[1]: Starting system activity accounting tool...
    Apr 12 22:50:00 rockpi-4c systemd[1]: sysstat-collect.service: Deactivated successfully.
    Apr 12 22:50:00 rockpi-4c systemd[1]: Finished system activity accounting tool.
    Apr 12 22:55:01 rockpi-4c CRON[1710]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
    Apr 12 22:57:20 rockpi-4c systemd[1]: Starting Cleanup of Temporary Directories...
    Apr 12 22:57:20 rockpi-4c systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
    Apr 12 22:57:20 rockpi-4c systemd[1]: Finished Cleanup of Temporary Directories.
    Apr 12 23:00:00 rockpi-4c systemd[1]: Starting system activity accounting tool...
    Apr 12 23:00:00 rockpi-4c systemd[1]: sysstat-collect.service: Deactivated successfully.
    Apr 12 23:00:00 rockpi-4c systemd[1]: Finished system activity accounting tool.
    Apr 12 23:00:01 rockpi-4c CRON[1721]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
    Apr 12 23:05:01 rockpi-4c CRON[1735]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
    Apr 12 23:10:20 rockpi-4c systemd[1]: Starting system activity accounting tool...
    Apr 12 23:10:20 rockpi-4c systemd[1]: sysstat-collect.service: Deactivated successfully.
    Apr 12 23:10:20 rockpi-4c systemd[1]: Finished system activity accounting tool.
    Apr 12 23:15:01 rockpi-4c CRON[1751]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
    Apr 12 23:15:01 rockpi-4c CRON[1750]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
    Apr 12 23:17:01 rockpi-4c CRON[1763]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
    Apr 12 23:20:00 rockpi-4c systemd[1]: Starting system activity accounting tool...
    Apr 12 23:20:00 rockpi-4c systemd[1]: sysstat-collect.service: Deactivated successfully.
    Apr 12 23:20:00 rockpi-4c systemd[1]: Finished system activity accounting tool.
    Apr 12 23:25:01 rockpi-4c CRON[1783]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
    Apr 12 23:30:00 rockpi-4c systemd[1]: Starting system activity accounting tool...
    Apr 12 23:30:00 rockpi-4c systemd[1]: sysstat-collect.service: Deactivated successfully.
    Apr 12 23:30:00 rockpi-4c systemd[1]: Finished system activity accounting tool.
    Apr 12 23:30:01 rockpi-4c CRON[1790]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
    Apr 12 23:35:01 rockpi-4c CRON[1805]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
    Apr 12 23:40:20 rockpi-4c systemd[1]: Starting system activity accounting tool...
    Apr 12 23:40:20 rockpi-4c systemd[1]: sysstat-collect.service: Deactivated successfully.
    Apr 12 23:40:20 rockpi-4c systemd[1]: Finished system activity accounting tool.
    Apr 12 23:45:01 rockpi-4c CRON[1823]: (root) CMD (/usr/lib/armbian/armbian-truncate-logs)
    Apr 12 23:45:01 rockpi-4c CRON[1824]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
    Apr 12 23:50:00 rockpi-4c systemd[1]: Starting system activity accounting tool...
    Apr 12 23:50:00 rockpi-4c systemd[1]: sysstat-collect.service: Deactivated successfully.
    Apr 12 23:50:00 rockpi-4c systemd[1]: Finished system activity accounting tool.
    Apr 12 23:55:01 rockpi-4c CRON[1845]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
    Apr 12 23:59:01 rockpi-4c CRON[1852]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 60 2)
    Apr 13 00:00:00 rockpi-4c systemd[1]: Starting Daily dpkg database backup service...
    Apr 13 00:00:00 rockpi-4c systemd[1]: Starting system activity accounting tool...
    Apr 13 00:00:00 rockpi-4c systemd[1]: Starting Rotate log files...
    Apr 13 00:00:00 rockpi-4c systemd[1]: sysstat-collect.service: Deactivated successfully.
    Apr 13 00:00:00 rockpi-4c systemd[1]: Finished system activity accounting tool.
    Apr 13 00:00:00 rockpi-4c armbian-ramlog[1876]: Thu Apr 13 12:00:00 AM CEST 2023: Syncing logs to storage
    Apr 13 00:00:00 rockpi-4c armbian-ramlog[1881]: sending incremental file list
    Apr 13 00:00:00 rockpi-4c armbian-ramlog[1881]: ./
    Apr 13 00:00:00 rockpi-4c armbian-ramlog[1881]: armbian-hardware-monitor.log
    Apr 13 00:00:00 rockpi-4c armbian-ramlog[1881]: auth.log
    Apr 13 00:00:00 rockpi-4c armbian-ramlog[1881]: boot.log
    Apr 13 00:00:00 rockpi-4c armbian-ramlog[1881]: dmesg
    Apr 13 00:00:00 rockpi-4c armbian-ramlog[1881]: dmesg.0
    Apr 13 00:00:00 rockpi-4c armbian-ramlog[1881]: kern.log
    Apr 13 01:17:05 rockpi-4c systemd-random-seed[438]: Kernel entropy pool is not initialized yet, waiting until it is.
    Apr 13 01:17:05 rockpi-4c systemd-udevd[470]: Using default interface naming scheme 'v249'.
    Apr 13 01:17:05 rockpi-4c systemd-udevd[470]: eth0: Failed to query device driver: Device or resource busy
    Apr 13 01:17:05 rockpi-4c systemd-udevd[470]: eth0: Could not set offload features, ignoring: Device or resource busy
    Apr 13 01:17:05 rockpi-4c systemd-udevd[487]: Using default interface naming scheme 'v249'.
    Apr 13 01:17:05 rockpi-4c systemd-udevd[487]: wlan0: Process '/sbin/iw dev wlan0 set power_save off' failed with exit code 1.
    Apr 13 01:17:05 rockpi-4c fake-hwclock[413]: Wed Apr 12 11:17:01 PM UTC 2023
    Apr 13 01:17:05 rockpi-4c systemd[1]: Starting Flush Journal to Persistent Storage...
    Apr 13 01:17:05 rockpi-4c armbian-zram-config[500]: Setting up swapspace version 1, size = 1.9 GiB (2025590784 bytes)
    Apr 13 01:17:05 rockpi-4c armbian-zram-config[500]: no label, UUID=3f834bf3-a042-4a4e-adb1-2826356f3da2
    Apr 13 01:17:05 rockpi-4c armbian-zram-config[637]: mke2fs 1.46.5 (30-Dec-2021)
    Apr 13 01:17:05 rockpi-4c armbian-zram-config[637]: Discarding device blocks:     0/12800#010#010#010#010#010#010#010#010#010#010#010           #010#010#010#010#010#010#010#010#010#010#010done
    Apr 13 01:17:05 rockpi-4c armbian-zram-config[637]: Creating filesystem with 12800 4k blocks and 12800 inodes
    Apr 13 01:17:05 rockpi-4c armbian-zram-config[637]: Allocating group tables: 0/1#010#010#010   #010#010#010done
    Apr 13 01:17:05 rockpi-4c armbian-zram-config[637]: Writing inode tables: 0/1#010#010#010   #010#010#010done
    Apr 13 01:17:05 rockpi-4c armbian-zram-config[637]: Writing superblocks and filesystem accounting information: 0/1#010#010#010   #010#010#010done
    Apr 13 01:17:05 rockpi-4c ifup[555]: /etc/network/if-up.d/resolved: 12: mystatedir: not found
    Apr 13 01:17:05 rockpi-4c armbian-ramlog[644]: e2label: Bad magic number in super-block while trying to open /dev/zram0
    Apr 13 01:17:05 rockpi-4c armbian-ramlog[647]: Mounting /dev/zram1 as /var/log
    Apr 13 01:17:05 rockpi-4c armbian-ramlog[653]: Thu Apr 13 01:17:03 AM CEST 2023: Loading logs from storage
    Apr 13 01:17:05 rockpi-4c armbian-ramlog[656]: sending incremental file list
    Apr 13 01:17:05 rockpi-4c armbian-ramlog[656]: ./
    Apr 13 01:17:05 rockpi-4c armbian-ramlog[656]: alternatives.log
    Apr 13 01:17:05 rockpi-4c armbian-ramlog[656]: armbian-hardware-monitor.log
    Apr 13 01:17:05 rockpi-4c kernel: [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    Apr 13 01:17:05 rockpi-4c armbian-ramlog[656]: auth.log
    Apr 13 01:17:05 rockpi-4c kernel: [    0.000000] Linux version 5.15.80-rockchip64 (root@746a5325a2a9) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #22.11.1 SMP PREEMPT Wed Nov 30 11:12:47 UTC 2022
    Apr 13 01:17:05 rockpi-4c kernel: [    0.000000] Machine model: Radxa ROCK Pi 4C
    Apr 13 01:17:05 rockpi-4c kernel: [    0.000000] efi: UEFI not found.
    Apr 13 01:17:05 rockpi-4c kernel: [    0.000000] NUMA: No NUMA configuration found
    Apr 13 01:17:05 rockpi-4c armbian-ramlog[656]: boot.log
    Apr 13 01:17:05 rockpi-4c kernel: [    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff]
    Apr 13 01:17:05 rockpi-4c kernel: [    0.000000] NUMA: NODE_DATA [mem 0xf77d6100-0xf77d7fff]
    #158
    @trooper sagte in Proxmox VM friert ein:
    Das würde ich mir anschauen, das riecht nach Ärger mit/im Dateisystem.
    T 2 Antworten Letzte Antwort
      Trooper
      #159
      Gut wenn das die Ursache ist wars das für mich ich installiere nicht nochmal alles neu auf dem rockpi
      es ist die Standard Installation und die macht schon Fehler so ein ...
      Danke mit dem Rockpi mach ich nicht weiter mit iobroker den nur die Software hat Probleme nach der Installation alles andere läuft Fehler frei genau wie die VMs auf meiner anderen Kiste fehlerfrei.
      ich denke der Fehler ist der iobroker der mit bestimmten Systemen einfach nicht läuft.
      Danke trotzdem
      • T Trooper
        einmal
        #160
        Moin,
        ich bin kein Experte, was all die RasPIs und anderen Kleinstplatinen Rechner angeht und auch die dazugehörigen Betriebssysteme habe ich nicht am Laufen, nur so wie ich das interpretiere, macht Dein System alle fünf Minuten folgendes
        Damit sammelt das OS Metriken, die per SAR ausgewertet werden können, ich denke, die dazugehörigen Files findest Du unter /var/log/sysstat
        Dann werden die in der RAM-Disk = zram.0 oder wenn Fehler zram.1 abgelegten Logfiles komprimiert und auf der Platte abgelegt, glaube ich, musst Du mal schauen, was das Skript genau macht, Skript läuft auch alle fünf Minuten. Und wenn Files aus der RAM-Disk nicht auf Platte geschrieben werden, dann ist es logisch, dass die nach einem Reboot, Stromlos etc. weg sind ist halt RAM-Disk
        Ich habe nur gegoogelt und kurz überflogen, aber da gibt es wohl mehrere, die Probleme damit haben / hatten, einiges aus 2022 und auch 2023.
        Bernd
        • T Trooper
          Danke trotzdem
          HomoranH Offline
          HomoranH Offline
          #161
          das ist ein Fehlgedanke!
          Warum sollte ioBroker bei korrektem Unterbau von nodejs nicht laufen?
          Wenn du natürlich nodejs nicht sauber installieren kannst, liegt da möglicherweise das Problem.
          Welches OS läuft denn da?
          mal das versucht?
          https://redirect.armbian.com/rockpi-4c/Jammy_current
          • T Trooper
            Danke trotzdem
            #162
            Ich sehe den Ausfall da eher bei ZRAM und dem korrupten Superblock im Filesystem.
              mal das versucht?
              Trooper
              #163
              werde ich mal testen sonnst ist der rockpi für mich nicht die Lösung mit iobroker
              ich hatte das installiert https://github.com/radxa-build/rock-pi-4c/releases/tag/20221101-0124
              • T Trooper
                HomoranH Offline
                HomoranH Offline
                #164
                @trooper da steht allerdings auch was von armbian... 🤔
                  Trooper
                  #165
                  ja aber meine Version scheint etwas anders zu sein
                  bei der Installation und ich habe eine minimal Version
                  iobroker ist drauf und ich lass mal laufen mal sehen ob es besser wird.
                    Trooper
                    #166
                    hab jetzt mal das log durchgesehen und gesucht bei der neuinstallation.
                    ich habe armbian mit balenaEtcher auf den speicher geschrieben dann läuft er mit dem Fehler.
                    Danach beginnt erst die richtige Installation und der Fehler taucht nicht mehr auf.
                    Er macht dann erst die Partition.
                    • T Trooper
                      HomoranH Offline
                      HomoranH Offline
                      #167
                      @Thomas-Braun
                      Was war das denn nochmal?
                      Hab so was ganz dunkel im Hinterkopf (oder war das ein magic byte??)
                      Thomas BraunT ? 2 Antworten Letzte Antwort
                        @Thomas-Braun
                        #168
                        @homoran sagte in Proxmox VM friert ein:
                        Der super-block ist sowas wie ein Inhaltsverzeichnis zu den einzelnen Dateien im Dateisystem. Superwichtig für den stabilen Betrieb der ganzen Geschichte. Wenn der wurmstichig ist bekommst du die lustigsten Reaktionen vom System.
                          @Thomas-Braun
                          #169
                          Moin,
                          Auszug aus https://www.serveradminz.com/blog/bad-magic-number-in-superblock/
                          Bad Magic Number In Superblock
                          The Server will go down due to issues in disks attached. Sometimes fsck in disks ends up in an error
                           “Bad magic number in Superblock while trying to open /dev/sdb”.
                          What do you mean by superblock?
                          The superblock means a file system metadata (data of a data) that describes the size, type, and status
                          of the file system and information regarding other metadata structures. It is very significant to the file system.
                          Hence, for each file system, the superblock is retained in multiple redundant copies. If the superblock of a
                          partition is corrupt, we are not able to mount the file system of partition by operating system.
                          What is a magic number?
                          Magic numbers are the first few bytes of a file which are unique to a particular file type and they are also
                          called file signature. Magic numbers/File signatures are t not visible to the user.
                          Bernd
                            Moin,
                            Bernd
                            HomoranH Offline
                            HomoranH Offline
                            #170
                            @dp20eic sagte in Proxmox VM friert ein:
                            Danke!
                            das hatte ich als Magic Byte o.ä. im Hinterkopf
                              Danke!
                              Trooper
                              #171
                              So jetzt hab ich aufgegeben mit iobroker und rockpi
                              Hab jetzt das ganze auf einen Micro ATX laufen mit
                              Asrock Q1900M mit IntelQuad-Core Processor J1900
                              8 GB RAM und ner kleinen 32GB SSD
                              Läuft seit Tagen fehlerfrei
                              • T Trooper
                                HomoranH Offline
                                HomoranH Offline
                                #172
                                hattest du es zwischendurch auch mit einer SD Karte versucht?
                                und das eMMC definitiv deaktiviert?
                                Auf jeden Fall macht mich nach wie vor die MongodB stutzig. Ich weiß dass beinder Installation des Unifi Controllers auf ARM da mit alten Versionen Klimmzüge gemacht werden müssen, aber hast du es auch mal nur mit armbian und dann dem Einzeiler für ioBroker versucht?
                                sonst nichts!
                                Wobei ich gar nicht weiss ob das armbian UBUNTU nicht auch das falsche nodejs schon mitbringt.
                                  sonst nichts!
                                  Trooper
                                  #173
                                  Also die mongoDB spielt keine rolle mehr da es ja eine Saubere neu Installation gab mit dem richtigen Nutzer :-).
                                  die Installation mache ich grade hatte keine SD-Karten mehr :-) musste ich erst bestellen.
                                  Node ist nicht vorhanden bei der installation.
                                  Test mit SD Läuft :-)
                                  • T Trooper
                                    HomoranH Offline
                                    HomoranH Offline
                                    #174
                                    @trooper Dann bekommen wir ja mal ne Struktur in die Ursachensuche. Bin gespannt.
                                      Trooper
                                      #175
                                      Fehler bleibt leider auch mit SD-Karte
                                      • T Trooper
                                        HomoranH Offline
                                        HomoranH Offline
                                        #176
                                          Trooper
                                          #177
                                          die ist nicht mehr dran
