  3. Einsteigerfragen
  4. Performance im Multihostbetrieb
    5.5k
32 Beiträge 4 Kommentatoren 3.3k Aufrufe 3 Beobachtet
    @markussr1984
    Und was steht da so drin?
    MarkusSR1984M Offline
    MarkusSR1984
    Skript v.2023-04-02
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : lxc
    Distributor ID: Ubuntu
    Description:    Ubuntu 22.10
    Release:        22.10
    Codename:       kinetic
    PRETTY_NAME="Ubuntu 22.10"
    NAME="Ubuntu"
    VERSION_ID="22.10"
    VERSION="22.10 (Kinetic Kudu)"
    VERSION_CODENAME=kinetic
    ID=ubuntu
    ID_LIKE=debian
    HOME_URL="https://www.ubuntu.com/"
    SUPPORT_URL="https://help.ubuntu.com/"
    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
    UBUNTU_CODENAME=kinetic
    LOGO=ubuntu-logo
    Systemuptime and Load:
     20:06:19 up 1 day, 21:59,  1 user,  load average: 0.95, 0.91, 0.77
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Sat 2023-04-08 20:06:20 UTC
               Universal time: Sat 2023-04-08 20:06:20 UTC
                     RTC time: n/a
                    Time zone: Etc/UTC (UTC, +0000)
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:             10G        962M        8.8G        0.0K        490M        9.3G
    Swap:            16G          0B         16G
    Total:           26G        962M         25G
            10240 M total memory
              962 M used memory
              200 M active memory
             1171 M inactive memory
             8786 M free memory
                0 M buffer memory
              490 M swap cache
            16383 M total swap
                0 M used swap
            16383 M free swap
    *** FILESYSTEM ***
    Filesystem                       Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4   7.8G  1.6G  5.9G  21% /
    /dev/mapper/pve-vm--100--disk--1 ext4   7.8G  350M  7.1G   5% /opt/iobroker
    none                             tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                            tmpfs  5.8G     0  5.8G   0% /dev/shm
    tmpfs                            tmpfs  2.4G  112K  2.4G   1% /run
    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET          SOURCE                           FSTYPE OPTIONS
    /               /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
    `-/opt/iobroker /dev/mapper/pve-vm--100--disk--1 ext4   rw,relatime,stripe=16
    /var:
    451M    /var/
    219M    /var/cache
    214M    /var/lib
    213M    /var/cache/apt
    132M    /var/cache/apt/archives
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    384K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
    *** NodeJS-Installation ***
    /bin/nodejs     v18.7.0
    /bin/node               v18.7.0
    /bin/npm                8.18.0
    /bin/npx                8.18.0
    nodejs:
      Installed: 18.7.0+dfsg-5ubuntu1
      Candidate: 18.7.0+dfsg-5ubuntu1
      Version table:
     *** 18.7.0+dfsg-5ubuntu1 500
            500 http://archive.ubuntu.com/ubuntu kinetic/universe amd64 Packages
         16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x kinetic/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     "javascript" not found
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-shuttle                         -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.admin.1                  : admin                 : iobroker-rpi-n                           -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.admin.2                  : admin                 : iobroker-pve                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.alexa2.0                 : alexa2                : iobroker-shuttle                         -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker-shuttle                         -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker-shuttle                         -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker-shuttle                         -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : iobroker-pve                             -  enabled
      system.adapter.devices.0                : devices               : iobroker-shuttle                         -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker-shuttle                         -  enabled
    + system.adapter.ds18b20.0                : ds18b20               : Heizungsregler                           -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker-shuttle                         -  enabled
      system.adapter.flot.0                   : flot                  : iobroker-shuttle                         -  enabled
    + system.adapter.fullcalendar.0           : fullcalendar          : iobroker-shuttle                         -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker-shuttle                         -  enabled
    + system.adapter.history.0                : history               : Heizungsregler                           -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker-pve                             -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pve                             -  enabled, port: 12001
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pve                             -  enabled, port: 12010
    + system.adapter.hue-extended.0           : hue-extended          : iobroker-pve                             -  enabled
    + system.adapter.i2c.0                    : i2c                   : Heizungsregler                           -  enabled
      system.adapter.ical.1                   : ical                  : iobroker-shuttle                         -  enabled
      system.adapter.ical.2                   : ical                  : iobroker-shuttle                         -  enabled
      system.adapter.ical.3                   : ical                  : iobroker-shuttle                         - disabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-shuttle                         -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker-shuttle                         -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker-shuttle                         -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker-shuttle                         -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker-shuttle                         -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-shuttle                         -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-shuttle                         -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-shuttle                         -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-shuttle                         -  enabled
    + system.adapter.info.0                   : info                  : iobroker-shuttle                         -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker-shuttle                         -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker-shuttle                         -  enabled
    + system.adapter.javascript.1             : javascript            : iobroker-shuttle                         -  enabled
      system.adapter.javascript.10            : javascript            : iobroker-shuttle                         - disabled
      system.adapter.javascript.100           : javascript            : iobroker-rpi-n                           - disabled
      system.adapter.javascript.20            : javascript            : iobroker-rpi-n                           - disabled
      system.adapter.javascript.30            : javascript            : Heizungsregler                           -  enabled
    + system.adapter.logparser.0              : logparser             : Heizungsregler                           -  enabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker-shuttle                         - disabled, port: 54321
    + system.adapter.moma.0                   : moma                  : iobroker-pve                             -  enabled
      system.adapter.mqtt.1                   : mqtt                  : iobroker-shuttle                         - disabled, port: 1883, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : iobroker-pve                             -  enabled
      system.adapter.proxy.0                  : proxy                 : iobroker-shuttle                         - disabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker-rpi-n                           -  enabled
      system.adapter.roborock.0               : roborock              : iobroker-rpi-n                           - disabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker-rpi-n                           -  enabled
    + system.adapter.rpi2.1                   : rpi2                  : Heizungsregler                           -  enabled
    + system.adapter.rpi2.3                   : rpi2                  : iob-rpi-kueche                           -  enabled
    + system.adapter.sayit.0                  : sayit                 : iobroker-rpi-n                           -  enabled, port: 0
    + system.adapter.simple-api.0             : simple-api            : iobroker-shuttle                         -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : iobroker-shuttle                         -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : iobroker-shuttle                         -  enabled
    + system.adapter.smartmeter.2             : smartmeter            : iobroker-shuttle                         -  enabled
    + system.adapter.socketio.0               : socketio              : iobroker-shuttle                         -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker-rpi-n                           -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-pve                             -  enabled
    + system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker-pve                             -  enabled
    + system.adapter.sql.0                    : sql                   : iobroker-pve                             -  enabled, port: 3306
    + system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : iobroker-rpi-n                           -  enabled, port: 9000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-shuttle                         -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker-shuttle                         -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobroker-shuttle                         -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker-pve                             -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker-pve                             -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-pve                             -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-pve                             -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-pve                             -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker-pve                             -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-pve                             -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-pve                             -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker-pve                             -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker-shuttle                         -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker-shuttle                         -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker-shuttle                         -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-shuttle                         -  enabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker-shuttle                         -  enabled
      system.adapter.vis.0                    : vis                   : iobroker-pve                             -  enabled
    + system.adapter.web.0                    : web                   : iobroker-shuttle                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.web.1                    : web                   : iobroker-pve                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.worx.0                   : worx                  : iobroker-shuttle                         -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.6.16   , installed 2.6.16
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Objects and States
    Objects:        16974
    States:         14941
    Hit:1 http://archive.ubuntu.com/ubuntu kinetic InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu kinetic-updates InRelease
    Hit:3 https://deb.nodesource.com/node_16.x kinetic InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu kinetic-security InRelease
    Reading package lists...
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          2041957    284/master
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2038482    1/init
    tcp        0      0 0.0.0.0:12010           0.0.0.0:*               LISTEN      1000       5587724    99273/io.hm-rpc.1
    tcp        0      0 0.0.0.0:12001           0.0.0.0:*               LISTEN      1000       5586552    99272/io.hm-rpc.0
    tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      103        2039796    98/systemd-resolved
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      103        2039794    98/systemd-resolved
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       2043199    301/io.admin.2
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       5442190    96245/io.web.1
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          2041958    284/master
    tcp6       0      0 :::111                  :::*                    LISTEN      0          2038484    1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          2041276    1/init
    udp        0      0 127.0.0.54:53           0.0.0.0:*                           103        2039795    98/systemd-resolved
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           103        2039793    98/systemd-resolved
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2038483    1/init
    udp6       0      0 :::111                  :::*                                0          2038485    1/init
    2023-04-08 19:19:06.561  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
    2023-04-08 19:24:06.561  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
    2023-04-08 19:24:06.562  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
    2023-04-08 19:29:06.555  - info: sql.0 (113036) Do not store value "NULL" for sonoff.0.RegenSensor.BH1750_Illuminance because no number
    2023-04-08 19:29:06.563  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
    2023-04-08 19:29:06.564  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
    2023-04-08 19:34:06.564  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
    2023-04-08 19:34:06.565  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
    2023-04-08 19:39:06.556  - info: sql.0 (113036) Do not store value "NULL" for sonoff.0.RegenSensor.BH1750_Illuminance because no number
    2023-04-08 19:39:06.564  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
    2023-04-08 19:39:06.567  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
    2023-04-08 19:44:06.565  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
    2023-04-08 19:44:06.567  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
    2023-04-08 19:49:06.558  - info: sql.0 (113036) Do not store value "NULL" for sonoff.0.RegenSensor.BH1750_Illuminance because no number
    2023-04-08 19:49:06.566  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
    2023-04-08 19:49:06.568  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
    2023-04-08 19:54:06.567  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
    2023-04-08 19:54:06.570  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
    2023-04-08 19:59:06.558  - info: sql.0 (113036) Do not store value "NULL" for sonoff.0.RegenSensor.BH1750_Illuminance because no number
    2023-04-08 19:59:06.568  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
    2023-04-08 19:59:06.570  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
    2023-04-08 20:03:54.516  - info: admin.2 (301) ==> Connected system.user.admin from ::ffff:192.168.1.50
    2023-04-08 20:04:02.418  - info: admin.2 (301) <== Disconnect system.user.admin from ::ffff:192.168.1.50 devices
    2023-04-08 20:04:06.570  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
    2023-04-08 20:04:06.572  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
    Wer Rechtschreibfehler findet, darf sie gerne behalten :P
    • Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      Wie sieht den die Netzwerk Topologie aus?
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
      • MarkusSR1984M MarkusSR1984
        Skript v.2023-04-02
        *** BASE SYSTEM ***
        Docker          : false
        Release:        22.10
        Codename:       kinetic
        NAME="Ubuntu"
        VERSION_ID="22.10"
        ID=ubuntu
        ID_LIKE=debian
        LOGO=ubuntu-logo
        CPU threads: 4
                         RTC time: n/a
                  RTC in local TZ: no
        root
        /root
        root
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            16G          0B         16G
        Total:           26G        962M         25G
                  962 M used memory
                  200 M active memory
                 8786 M free memory
                    0 M buffer memory
                  490 M swap cache
                16383 M total swap
                    0 M used swap
                16383 M free swap
        *** FILESYSTEM ***
        /var:
        451M    /var/
        219M    /var/cache
        214M    /var/lib
        213M    /var/cache/apt
        /bin/nodejs     v18.7.0
        /bin/node               v18.7.0
        /bin/npm                8.18.0
        /bin/npx                8.18.0
        nodejs:
          Version table:
        ioBroker Status
        Objects type: redis
        States  type: redis
        admin:          6.3.5
        Adapter State
        + instance is alive
        Objects and States
        Objects:        16974
        States:         14941
        Pending Updates: 1
        Thomas BraunT Offline
        @markussr1984
        Zeitzone setzen und nicht als root herumhampeln.
        Und nodejs möchtest du von nodesource beziehen.
        MarkusSR1984M 1 Antwort Letzte Antwort
          @markussr1984
          MarkusSR1984
          schrieb am zuletzt editiert von MarkusSR1984
          @thomas-braun said in Performance im Multihostbetrieb:
          @markussr1984
          Wenn ich ehrlich bin, der host ist noch recht frisch und wurde mit dem Empfohlenen install script aufgesetzt. Ich ziehe im moment einige Adapter etc. auf diesen Host um weil er von CPU und RAM den Raspis haushoch überlegen ist und ich so hoffe das Gesammtsystem wieder etwas flotter zu bekommen. Aus diesem Grund wollte/will ich die diag ausgabe eben machen wenn diese Schritte abgeschlossen sind weil sie dann auch aussagekräftig sind.
          Das die instanz als root läuft ist nicht weiter schlimm da es in einem unpreviligierten container unter proxmox läuft. wer in der lage ist da auszubrechen den stört das auch nicht weiter wenn er im container keine root rechte hat aber grundsätzlich stimme ich dir da zu.
          Thomas BraunT HomoranH 3 Antworten Letzte Antwort
            @markussr1984
            @markussr1984 sagte in Performance im Multihostbetrieb:
            Da ist eine Interimsversion von Ubuntu eh das falsche Pferd. Die ist in wenigen Wochen wieder anabgekündigt. Wenn es unbedingt Ubuntu sein muss, nimm die aktuelle LTS Variante.
              @markussr1984
              Das ist nicht der (Haupt)-Grund, warum man nicht als root herumeimert. Du verbiegst dir Ratzfatz die Rechte am iobroker und das Ding läuft nicht so wie es soll.
              Ist nicht zufällig 'best practice ' nur mit den notwendigsten Rechten durch das System zu stolpern.
                MarkusSR1984
                Da ist eine Interimsversion von Ubuntu eh das falsche Pferd. Die ist in wenigen Wochen wieder angekündigt. Wenn es unbedingt Ubuntu sein muss, nimm die aktuelle LTS Variante.
                Ne, das werd ich bei gelegenheit wieder auf debian umstellen, wollte mir die version nur mal anschauen. Ich hab aber aus weiser Vorraussicht eine eigene storage für den IOB verwendet damit sowas leicht zu bewerkstelligen ist, aber das hast du sicher schon bemerkt in der ausgabe ;)
                  Natürlich.
                    Natürlich.
                    MarkusSR1984
                    Natürlich.
                    Also hab ich dich richtig eingeschätzt ;) 😀
                    Aktuell kämpfe ich aber mit nem Every Update Fehler, Nach jedem JS Adapter update meint der IOB ständig das ich was an den Globalen TS Scripts geändert hätte und startet mir somit im Minutentakt alle JS Instanzen neu 😬
                    Das hat erstmal höhere Priorität da bei mir auch die Zentralheizung über den IOB läuft und es noch zu kalt ist die paar stunden abzuschalten
                      Natürlich.
                      nodejs jetzt in der Version von nodesource installiert oder noch die 'kaputte' dfsg-Version?
                        MarkusSR1984
                        aktuell noch die aus dem installer script, aber ich änder das mal eben auf dem host wo meine globelen scripte laufen ob er sich dann beruhigt, danke für den Denkansatz
                          @markussr1984
                          Warum fragst du eigentlich nach Hilfe, wenn du die erkannten Fehler im Setup dann nicht änderst?
                            @markussr1984
                            MarkusSR1984
                            @markussr1984
                            Ich hab ehrlich gesagt nicht mit so einer schnellen Reaktion gerechnet und war da schon im Updateprozess. Wie du sicher weist macht man bei sowas ungern mehrere Fässer auf weil man sonst bei Fehlern schlecht zurückverfolgen kann was passiert ist.
                              @markussr1984
                              @markussr1984
                              nodejs als Laufzeitumgebung ist nur so wesentlich für den iobroker, das muss sitzen. Genauso wie die Zeitzone (und die root shell).
                              Das sind die drei Dinge, die du als erstes angehen musst. Und wenn das richtig ist kannst du auf dieser Basis weiter machen.
                              Alles andere ist wenig bis gar nicht sinnvoll.
                                @markussr1984
                                MarkusSR1984
                                @markussr1984
                                Hab mir grad meine anderen hosts angeschaut, die 3 von 4 laufen auf dem iobroker docker image von buanet:
                                iob läuft auf user iobroker
                                nodejs kommt von der source: https://deb.nodesource.com/node_16.x bullseye main
                                und auch die zeitzone ist da überall richtig gesetzt.
                                leider kann er da mit dem iob diag command nichts anfangen, das muss ich mir noch anschauen woran das liegt da es ja eigentlich die gleiche version sein sollte.
                                  @markussr1984
                                  @markussr1984
                                  Ein
                                  iob fix
                                  zieht iob diag auf das System. Jedenfalls auf Nicht-Dockern.
                                    @markussr1984
                                    Ein
                                    iob fix
                                    MarkusSR1984
                                    @markussr1984
                                    Ein
                                    iob fix
                                    Hat geholfen, danke. Die anderen Hosts folgen noch, aber dafür währ ich hald gern in einem Stable Zustand. Wenn ich da angekommen bin pack ich die diad logs von allen host nochmal hier rein, dann ist das ganze wie schon gesagt auch aussagekräftig.
                                    Hier das log meines "IOB Masters"
                                    Skript v.2023-04-02
                                    *** BASE SYSTEM ***
                                    Docker          : v8.0.0
                                    Virtualization  : Unknown (buanet/Synology?)
                                    Distributor ID: Debian
                                    Description:    Debian GNU/Linux 11 (bullseye)
                                    Release:        11
                                    Codename:       bullseye
                                    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                                    NAME="Debian GNU/Linux"
                                    VERSION_ID="11"
                                    VERSION="11 (bullseye)"
                                    VERSION_CODENAME=bullseye
                                    ID=debian
                                    HOME_URL="https://www.debian.org/"
                                    SUPPORT_URL="https://www.debian.org/support"
                                    BUG_REPORT_URL="https://bugs.debian.org/"
                                     00:56:56 up 46 days, 25 min,  0 users,  load average: 13.38, 6.90, 5.71
                                    CPU threads: 4
                                    /home/iobroker/.diag.sh: line 76: timedatectl: command not found
                                    root
                                    /root
                                    root
                                    X-Server:       false
                                    Desktop:
                                    Terminal:
                                    /home/iobroker/.diag.sh: line 93: systemctl: command not found
                                    Boot Target:
                                    *** MEMORY ***
                                    Mem:            3.9G        3.2G        104M        5.0M        588M        412M
                                    Swap:           3.9G        2.0G        2.0G
                                    Total:          7.8G        5.2G        2.1G
                                             3911 M total memory
                                             3219 M used memory
                                              780 M active memory
                                             2622 M inactive memory
                                              103 M free memory
                                               56 M buffer memory
                                              533 M swap cache
                                             3912 M total swap
                                             1960 M used swap
                                             1952 M free swap
                                    *** FILESYSTEM ***
                                    overlay                           overlay  915G  227G  650G  26% /
                                    tmpfs                             tmpfs     64M     0   64M   0% /dev
                                    shm                               tmpfs     64M     0   64M   0% /dev/shm
                                    /dev/mapper/ubuntu--vg-ubuntu--lv ext4     915G  227G  650G  26% /opt/vc
                                    tmpfs                             tmpfs    2.0G     0  2.0G   0% /proc/asound
                                    tmpfs                             tmpfs    2.0G     0  2.0G   0% /proc/acpi
                                    tmpfs                             tmpfs    2.0G     0  2.0G   0% /proc/scsi
                                    tmpfs                             tmpfs    2.0G     0  2.0G   0% /sys/firmware
                                    /opt/iobroker               /dev/mapper/ubuntu--vg-ubuntu--lv[/opt/docker-share/iobroker/data]        ext4   rw,relatime
                                    /opt/vc                     /dev/mapper/ubuntu--vg-ubuntu--lv[/opt/docker-share/iobroker/vc]        ext4   rw,relatime
                                    /usr/share/zoneinfo/Etc/UTC /dev/mapper/ubuntu--vg-ubuntu--lv[/usr/share/zoneinfo/Europe/Berlin]        ext4   rw,relatime
                                    /etc/resolv.conf            /dev/mapper/ubuntu--vg-ubuntu--lv[/var/lib/docker/containers/19e2d4c8dd001d95f8e77200bef0659fc5d334c1adaf173934df1ecea1abb911/resolv.conf] ext4   rw,relatime
                                    /etc/hostname               /dev/mapper/ubuntu--vg-ubuntu--lv[/var/lib/docker/containers/19e2d4c8dd001d95f8e77200bef0659fc5d334c1adaf173934df1ecea1abb911/hostname]    ext4   rw,relatime
                                    /etc/hosts                  /dev/mapper/ubuntu--vg-ubuntu--lv[/var/lib/docker/containers/19e2d4c8dd001d95f8e77200bef0659fc5d334c1adaf173934df1ecea1abb911/hosts]       ext4   rw,relatime
                                    /var:
                                    33M     /var/
                                    31M     /var/lib
                                    18M     /var/lib/apt/lists
                                    18M     /var/lib/apt
                                    13M     /var/lib/dpkg
                                    1.7G    /opt/iobroker/backups/
                                    14M     /opt/iobroker/iobroker-data/files
                                    /usr/bin/nodejs         v18.15.0
                                    /usr/bin/node           v18.15.0
                                    /usr/bin/npm            9.5.0
                                    /usr/bin/npx            9.5.0
                                    nodejs:
                                      Installed: 18.15.0-deb-1nodesource1
                                      Candidate: 18.15.0-deb-1nodesource1
                                      Version table:
                                     *** 18.15.0-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                                         12.22.12~dfsg-1~deb11u3 500
                                            500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                                         12.22.5~dfsg-2~11u1 500
                                            500 http://deb.debian.org/debian bullseye/main amd64 Packages
                                    ioBroker Status
                                    Objects type: redis
                                    States  type: redis
                                    admin:          6.3.5
                                    javascript:     6.1.4
                                    Adapter State
                                    + system.adapter.alexa2.0                 : alexa2                : iobroker-shuttle                         -  enabled
                                      system.adapter.sql.0                    : sql                   : iobroker-pve                             - disabled, port: 3306
                                    + instance is alive
                                    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                                    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
                                    Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
                                    Adapter    "devices"      : 1.1.2    , installed 1.1.2
                                    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                                    Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                    Adapter    "fullcalendar" : 1.2.0    , installed 1.2.0
                                    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                                    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                                    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                                    Adapter    "info"         : 1.9.19   , installed 1.9.19
                                    Adapter    "iot"          : 1.14.2   , installed 1.14.2
                                    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                                    Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
                                    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                                    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
                                    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                                    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                                    Adapter    "text2command" : 2.3.0    , installed 2.3.0
                                    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                    Adapter    "worx"         : 2.0.3    , installed 2.0.3
                                    Objects and States
                                    Objects:        16947
                                    States:         14918
                                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                                    Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
                                    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                                    Pending Updates: 0
                                    tcp        0      0 127.0.0.11:40499        0.0.0.0:*               LISTEN      0          108627423  -
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       108634491  -
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       108627636  -
                                    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       108631223  -
                                    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       108632658  -
                                    udp        0      0 127.0.0.11:49741        0.0.0.0:*                           0          108627422  -
                                    2023-04-09 00:59:01.287  - info: javascript.1 (1199) received all objects
                                    2023-04-09 00:59:02.552  - info: javascript.1 (1199) script.js.global.Global_Variables: compiling TypeScript source...
                                    2023-04-09 00:59:02.871  - info: javascript.1 (1199) script.js.global.Global_Variables: source code did not change, using cached compilation result...
                                    2023-04-09 00:59:02.874  - info: javascript.1 (1199) script.js.global.Global_Functions: compiling TypeScript source...
                                    2023-04-09 00:59:03.156  - info: javascript.1 (1199) script.js.global.Global_Functions: source code did not change, using cached compilation result...
                                    2023-04-09 00:59:03.459  - info: javascript.1 (1199) Start javascript script.js.Smart_Home.Steuerung_Beleuchtung
                                    2023-04-09 00:59:03.690  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Beleuchtung: Register Event for hm-rpc.1.0008DBE98F4607.1.PRESS_SHORT
                                    2023-04-09 00:59:03.695  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Beleuchtung: Register Event for hm-rpc.1.0008DD89A2BC10.1.PRESS_SHORT
                                    2023-04-09 00:59:03.699  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Beleuchtung: registered 12 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2023-04-09 00:59:03.699  - info: javascript.1 (1199) Start javascript script.js.Smart_Home.Steuerung_Beleuchtung_Bad
                                    2023-04-09 00:59:03.726  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Beleuchtung_Bad: Aktueller Lichtstatus im Bad ist: false
                                    2023-04-09 00:59:03.729  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Beleuchtung_Bad: registered 6 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2023-04-09 00:59:03.732  - info: javascript.1 (1199) Start javascript script.js.Smart_Home.Steuerung_Jalousie_OG
                                    2023-04-09 00:59:03.763  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Jalousie_OG: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2023-04-09 00:59:03.767  - info: javascript.1 (1199) Start javascript script.js.Smart_Home.SommerWinter_Automatik
                                    2023-04-09 00:59:03.963  - info: javascript.1 (1199) script.js.Smart_Home.SommerWinter_Automatik: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                    2023-04-09 00:59:05.273  - info: smartmeter.0 (290) Received 10 values, 3 updated
                                    2023-04-09 00:59:11.066  - info: smartmeter.1 (264) Received 9 values, 0 updated
                                    2023-04-09 00:59:13.766  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Jalousie_OG: Current Brightness ==> 46.25
                                    2023-04-09 00:59:13.768  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Jalousie_OG: Current Brightness ==> 46.25
                                    2023-04-09 00:59:13.789  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Jalousie_OG: Current Brightness ==> 46.25
                                    2023-04-09 00:59:13.792  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Jalousie_OG: Current Brightness ==> 46.25
                                    2023-04-09 00:59:14.032  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Jalousie_OG: Jalousie Gästezimmer ==> Current Pos: -1 Target Level: 100 Send Allowed: true
                                    2023-04-09 00:59:14.110  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Jalousie_OG: Jalousie Wohnzimmer ==> Current Pos: 100 Target Level: 100 Send Allowed: false
                                    2023-04-09 00:59:14.215  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Jalousie_OG: Jalousie Schlafzimmer ==> Current Pos: 59 Target Level: 60 Send Allowed: false
                                      @markussr1984
                                      nicht ganz!
                                      nodejs wird von den Skript korrekt installiert, wenn vorher keine andere Version von nodejs vorhanden ist.
                                      Dein Ubuntu bringt aber eine eigene Version aus einer anderen Quelle mit.
                                      Die wird bei der Installation nicht angefasst und bleibt auch später so drin.
                                      Dass es nicht gut ist siehst du ja daran, dass nach Anwendung des Fixers, der die Rechte geradebiegt, doch einiges funktioniert, was vorher nicht klappte.
                                        nicht ganz!
                                        MarkusSR1984
                                        @homoran said in Performance im Multihostbetrieb:
                                        nicht ganz!
                                        Gut zu wissen. Ich hab aber inzwischen wieder ein Debian installiert und mir das Installerscript genauer angeschaut. Laut diesem sollte es ihn nicht sonderlich interressieren ob nun debian oder ubuntu und es müsste den user iobroker eigentlich bei der installation erstellen. Warum das unter Ubuntu nicht geht ? KP.
                                        unter Debian macht es das alles sauber. Also richtiger User, richtige nodesource etc. Das einzige was mir aufgefallen ist, das er noch nodejs v16.19.1 verwendet obwohl die v18 Empfohlen wird.
                                        Da wo ich das eingesetzt habe waren diese Sachen alles Korrect, da ging nur der "iob diag" command nicht.
                                        Aber ich glaube, das heist ich bin mir nicht zu 100% sicher, das ich durch die Updateprobleme die ich gestern hatte evtl, die Ursache für das träge Verhalten gefunden habe. Im JS Adapter auf meinem Heizungsregler hatte ich einige NPM Packages eingetragen und er wollte sich auf biegen und brechen nicht auf die aktuelle Version updaten lassen, Dies hat dann komischerweise auch dazu geführt das IOB andauernd meinte das sich etwas an den Globalen Scripts geändert hätte. Die ligen zwar auf einem anderen Host aber naja...
                                        Als ich dann die Schnauze voll hatte das mir die Kiste ständig abgeschmiert/eingefrohren ist beim versuch den Adapter zu updaten habe ich den aus den node_modules gelöscht und hab mir das paket von einem anderen Raspi geschnappt und rüberkopiert. Er hat zwar dann trotzdem angefangen ein paar sachen zu kompliieren aber nun läuft die mühle wieder, und das gefühlt auch wieder flotter. Ich beobachte das aber nun mal einige Zeit.
                                        Bei Interesse oder falls wiedererwarten immernoch Performanceprobleme auftreten pack ich die DIAG ausgaben aller hosts in dieses Thema.
                                        Herzlichen Dank nochmal für die Denkanstöße und Diagnose :*
                                          nicht ganz!
                                          Globalen Scripts
                                          sind auch mit außerster Vorsicht zu genießen. Du weißt, dass die Dinger vor jedem anderen Skript auch herangezogen werden?
