  4. Test Adapter Vaillant multiMatic/senso und myVaillant
    6.8k
multimaticsensovaillanvr900vr920
966 Beiträge 94 Kommentatoren 419.5k Aufrufe 88 Beobachtet
  • G GeKi
    @tombox danke, version 0.1.1 von github funktioniert mit dem fix refreshtoken
    Geg0r
    schrieb am zuletzt editiert von Geg0r
    #532
    @tombox ich bekomme mit der 0.1.2 keine Verbindung mehr hin.
    User und Passwort funktionieren in der App aber ohne Probleme.
    2023-03-22 22:00:04.585 - error: vaillant.0 (290451) AxiosError: Request failed with status code 400
    2023-03-22 22:00:04.585 - error: vaillant.0 (290451) {"error":"invalid_grant","error_description":"The refresh token is invalid or expired."}
    2023-03-22 22:00:53.897 - info: host.iobroker "system.adapter.vaillant.0" disabled
    2023-03-22 22:00:53.898 - info: host.iobroker stopInstance system.adapter.vaillant.0 (force=false, process=true)
    2023-03-22 22:00:53.902 - info: vaillant.0 (290451) Got terminate signal TERMINATE_YOURSELF
    2023-03-22 22:00:53.903 - info: vaillant.0 (290451) cleaned everything up...
    2023-03-22 22:00:53.903 - info: vaillant.0 (290451) terminating
    2023-03-22 22:00:53.904 - info: vaillant.0 (290451) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-03-22 22:02:45.103 - info: host.iobroker "system.adapter.vaillant.0" enabled
    2023-03-22 22:02:45.232 - info: host.iobroker instance system.adapter.vaillant.0 started with pid 293041
    2023-03-22 22:02:46.486 - info: vaillant.0 (293041) starting. Version 0.1.2 (non-npm: TA2k/ioBroker.vaillant) in /opt/iobroker/node_modules/iobroker.vaillant, node: v16.19.0, js-controller: 4.0.24
    2023-03-22 22:02:46.558 - info: vaillant.0 (293041) Generate new Id
    2023-03-22 22:02:46.968 - error: vaillant.0 (293041) Login failed no code for myvLoginv2
    2023-03-22 22:02:46.968 - error: vaillant.0 (293041) Ungültiger Benutzername oder Passwort.
    2023-03-22 22:03:10.321 - info: host.iobroker "system.adapter.vaillant.0" disabled
    2023-03-22 22:03:10.321 - info: host.iobroker stopInstance system.adapter.vaillant.0 (force=false, process=true)
    2023-03-22 22:03:10.324 - info: vaillant.0 (293041) Got terminate signal TERMINATE_YOURSELF
    2023-03-22 22:03:10.324 - info: vaillant.0 (293041) cleaned everything up...
    2023-03-22 22:03:10.324 - info: vaillant.0 (293041) terminating
    2023-03-22 22:03:10.325 - info: vaillant.0 (293041) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-03-22 22:03:10.366 - info: host.iobroker stopInstance system.adapter.vaillant.0 send kill signal
    2023-03-22 22:03:10.880 - info: host.iobroker instance system.adapter.vaillant.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-03-22 22:03:39.972 - info: host.iobroker "system.adapter.vaillant.0" enabled
    2023-03-22 22:03:40.106 - info: host.iobroker instance system.adapter.vaillant.0 started with pid 293056
    2023-03-22 22:03:41.270 - info: vaillant.0 (293056) starting. Version 0.1.2 (non-npm: TA2k/ioBroker.vaillant) in /opt/iobroker/node_modules/iobroker.vaillant, node: v16.19.0, js-controller: 4.0.24
    2023-03-22 22:03:41.338 - info: vaillant.0 (293056) Generate new Id
    2023-03-22 22:03:41.687 - error: vaillant.0 (293056) Login failed no code for myvLoginv2
    2023-03-22 22:03:41.687 - error: vaillant.0 (293056) Ungültiger Benutzername oder Passwort.
    Hast du ne Idee?
    • G Geg0r
      Hast du ne Idee?
      tombox
      #533
      @geg0r und 0.1.1 geht ?
      G 1 Antwort Letzte Antwort
      • T tombox
        Geg0r
        #534
        @tombox nein, da kam der Fehler der in Zeile 1 steht "code 400"
        • Poldies PottP Offline
          Poldies Pott
          #535
          Ich bekommen den Adapter auch nicht dazu sich anzumelden.
          PW habe ich auch schon geändert aber es hat leider nicht geholfen.
          vaillant.0
          	2023-03-27 17:17:22.875	error	Login failed
          vaillant.0
          	2023-03-27 17:17:22.873	error	401
          vaillant.0
          	2023-03-27 17:17:22.873	error	{"errorCode":"NOT_AUTHORIZED"}
          vaillant.0
          	2023-03-27 17:17:22.872	error	null
          vaillant.0
          	2023-03-27 17:17:22.870	error	Failed to login
          vaillant.0
          	2023-03-27 17:17:22.449	info	Generate new Id
          vaillant.0
          	2023-03-27 17:17:22.381	info	starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.vaillant, node: v16.19.1, js-controller: 4.0.24
          • T tombox
            Hi ich habe ein Vaillant multiMATIC/senso und myVaillant Adapter erstellt.
            In den Instanzoptionen mail und password der multimatic /senso app eingeben.
            Configuration können geändert werde in dem sie unter dem Unterpunkt configuration angepasst werden. Manche configuration werden erst angewendet wenn der Modus auf ON oder MANUAL ist und nicht AUTO oder TIME_CONTROLLED
            Beispiel für Multimatic:
            Warmwasser: vaillant.0.serialnummer.systemcontrol/tli.dhw.hotwater.configuration.hotwater_temperature_setpoint
            Heizung:
            Erst auf MANUAL
            vaillant.0.serialnummber.systemcontrol/tli.zones03.heating.configuration.operation_mode
            MANUAL
            Dann die Temperatur
            vaillant.0.serial.systemcontrol/tli.zones03.heating.configuration.manual_mode_temperature_setpoint
            Und am Ende operation_mode auf TIME_CONTROLLED
            Parameter können über den Punkt parameterValue angepasst werden dabei beachten welche Werte im Objekt definition erlaubt sind.
            Beispiel myVaillant:
            vaillant.0.id.systemControlState.controlState.domesticHotWater01.boost auf true/false setzen um den Boost zu aktivieren oder deaktivieren
            vaillant.0.id.systemControlState.controlState.zones01.desiredRoomTemperatureSetpoint um die RaumTemperatur zu setzen
            vaillant.0.id.systemControlState.controlState.zones01.setBackTemperature
            vaillant.0.id.systemControlState.controlState.zones01.heatingOperationMode OFF MANUAL TIME_CONTROLLED
            vaillant.0.id.systemControlState.controlState.domesticHotWater01.operationMode OFF MANUAL TIME_CONTROLLED
            Remote Commands
            For Refresh and predefined
            vaillant.0.id.remote
            Custom Command
            You can use custom Commmand remote for not predefined remotes
            vaillant.0.id.remotes.customCommand
            Examples:
            Die zone kann von 0 bis X gehen. Bitte zone/0/ oder zone/2/ testen
            zone/0/xxxx
            zone/1/xxxx
            zone/2/xxxx
              "url": "zone/0/heating/comfort-room-temperature",
              "data": { "comfortRoomTemperature": 10.5 }
              "url": "zone/1/heating/comfort-room-temperature",
              "url": "domestic-hot-water/255/operation-mode",
              "data": { "operationMode": "OFF" }
              "url": "domestic-hot-water/255/temperature",
              "data": { "setpoint": 55 }
              "url": "zone/1/heating/operation-mode",
              "data": { "operationMode": "DAY" }
              "url": "zone/1/heating/set-back-temperature",
              "data": { "setBackTemperature": 20 }
              "url": "zone/1/cooling/operation-mode",
              "url": "zone/1/cooling/setpoint",
              "data": { "setpoint": 20 }
              "url": "ventilation/0/operation-mode",
              "data": { "operationMode": "SET_BACK" }
              "url": "zone/1/heating/quick-veto",
              "data": { "desiredRoomTemperatureSetpoint": 11, "duration": 3 },
              "method": "POST"
              "url": "domestic-hot-water/255/boost",
              "data": {},
              "method": "POST"
              "data": {},
              "method": "DELETE"
              "url": "domestic-hot-water/255/circulation-pump/time-windows",
              "data": {
                "friday": [
                    "endTime": 540,
                    "startTime": 360
                "monday": [],
                "saturday": [],
                "sunday": [],
                "thursday": [],
                "tuesday": [],
                "wednesday": []
              "url": "domestic-hot-water/255/time-windows",
              "data": {
                "friday": [],
                "monday": [
                    "endTime": 1320,
                    "startTime": 330
                "saturday": [
                    "endTime": 1320,
                    "startTime": 330
                "sunday": [
                    "endTime": 1320,
                    "startTime": 330
                "thursday": [
                    "endTime": 1320,
                    "startTime": 330
                "tuesday": [
                    "endTime": 1320,
                    "startTime": 330
                "wednesday": [
                    "endTime": 1320,
                    "startTime": 330
            setState('vaillant.0.xxx.remote.customCommand','{"url": "zone/0/heating/operation-mode", "data":{"operationMode": "MANUAL"}}')
            setState('vaillant.0.xxx.remote.customCommand','{"url": "zone/0/heating/comfort-room-temperature", "data":{"comfortRoomTemperature":20}}')
            tombox
            #536
            Dann brauch ich nochmal Zugangsdaten um zuschauen was da anders ist
            • T tombox
              Geg0r
              #537
              @tombox also bei mir gehts jetzt wieder mit deiner letzten Version 0.1.2
              Ich musste beim user nun meinem e-Mail adresse angeben und nicht mehr den Usernamen und dann ging es...
              F 1 Antwort Letzte Antwort
              • G Geg0r
                FASchmidt
                #538
                ich nutzte den Vaillant-Adapter schon einige Monate ohne größere Probleme. Vielen lieben Dank dafür. Nun habe ich zu meinem Gas-Brennwertgerät ecoTEC noch eine Wärmepumpe aroTHERM plus VWL 75/6 mit dem Steuerungsmodul VWZ AI ergänzt. Damit kommen jedoch auch die Probleme. Bisher wurden die Energiedaten korrekt in IOBroker verarbeitet, nun aber schmeißt der Vaillant-Adapter die Werte aus den beiden unterschiedlichen Wärmequellen immer zusammen, d.h. der Wert der zuletzt kommt gewinnt. Hier mal ein Auszug aus dem Debugger:
                {"body":[
                {"id":"NoneGateway-LL_HMU03_0351_HP_Platform_Outdoor_Monobloc_PR_EBUS","type":"HEAT_PUMP","marketingName":"VWL 75/6 A 230V S2","reports":[
                {"function":"DHW","energyType":"ENVIRONMENTAL_YIELD","currentMeterReading":5000,"from":"2023-03-09","to":"2023-03-28"},
                {"function":"COOLING","energyType":"CONSUMED_ELECTRICAL_POWER","currentMeterReading":0,"from":"2023-03-09","to":"2023-03-28"},
                {"function":"CENTRAL_HEATING","energyType":"ENVIRONMENTAL_YIELD","currentMeterReading":847000,"from":"2023-03-09","to":"2023-03-28"},
                {"function":"CENTRAL_HEATING","energyType":"CONSUMED_ELECTRICAL_POWER","currentMeterReading":503000,"from":"2023-03-09","to":"2023-03-28"},
                {"function":"COOLING","energyType":"ENVIRONMENTAL_YIELD","currentMeterReading":0,"from":"2023-03-09","to":"2023-03-28"},
                {"function":"DHW","energyType":"CONSUMED_ELECTRICAL_POWER","currentMeterReading":1000,"from":"2023-03-09","to":"2023-03-28"}]
                {"id":"LL_V32___0460_VR32_SUB_2_PR_EBUS-LL_BAI00_0376_Peec_PR_EBUS","type":"BOILER","marketingName":"VC 20CS/1-5 (N-DE) ecoTEC plus","reports":[
                {"function":"CENTRAL_HEATING","energyType":"CONSUMED_ELECTRICAL_POWER","currentMeterReading":417743.5,"from":"2023-03-09","to":"2023-03-28"},
                {"function":"DHW","energyType":"CONSUMED_ELECTRICAL_POWER","currentMeterReading":147526.8125,"from":"2023-03-09","to":"2023-03-28"},
                {"function":"CENTRAL_HEATING","energyType":"CONSUMED_PRIMARY_ENERGY","currentMeterReading":26193212,"from":"2023-03-09","to":"2023-03-28"},
                {"function":"DHW","energyType":"CONSUMED_PRIMARY_ENERGY","currentMeterReading":10087876,"from":"2023-03-09","to":"2023-03-28"}]}],"meta":{}}
                Die Umwelterträge und die Gasverbräuche sind korrekt, aber die elektrischen Verbräuche werden zusammen in einen Wert gepackt.
                Kann hier vielleicht jemand helfen?
                Gruß Andreas
                • F FASchmidt
                  {"body":[
                  Gruß Andreas
                  tombox
                  #539
                  @faschmidt kannst du den debug log anschauen und schauen wo das verhalten herkommt bzw mal ein screenshot vom Objekt baum und markieren wo die werte falsch sind
                  • T tombox
                    FASchmidt
                    #540
                    @tombox
                    Ich hab mal versucht die aussagekräftigsten Screenshots zusammenzustellen:
                    Hier sehen wir die problematischen Werte (Seriennummer ersetzt durch xxx):
                    vaillant.0.xxx.emf.CENTRAL_HEATING_CONSUMED_ELECTRICAL_POWER.currentMeterReading
                    vaillant.0.xxx.emf.DHW_CONSUMED_ELECTRICAL_POWER.currentMeterReading
                    vaillant.0.xxx.emf.id
                    vaillant.0.xxx.emf.marketingName
                    vaillant.0.xxx.emf.type
                    In den folgenden Bildern zeigen sich die abwechselnd registrierten Werte:
                    und hier, wie der Adapter die Geräte zusammenschmeißt:
                    Ich hoffe, dass ich damit das Problem verständlich darstellen konnte.
                    Gruß Andreas
                    • F FASchmidt
                      @tombox
                      Gruß Andreas
                      tombox
                      #541
                      @faschmidt welche App nutzt du? Kannst du schon auf myVAILLANT?
                      • T tombox
                        FASchmidt
                        #542
                        @tombox
                        Ich nutze auf Android die Vaillant SensoAPP Version 3.15. Für MyVaillant wurde meine Anlage noch nicht freigeschaltet.
                        Gruß Andreas
                          DRUROB
                          schrieb am zuletzt editiert von DRUROB
                          #543
                          Hi!
                          Werden hier die ID´s der Geräte im ebus adapter/reader nicht sauber getrennt?
                          Wenn beide Geräte die selbe ID haben und sich dort den gleichen Speicherplatz z.B. value"245"=x teilen dann bekommt der eben 2 Werte auf diesem Platz zugewiesen mit der selben ID. dann hat value"245"=x,y.
                          Hab nur ein Gerät und kann das leider nicht nachstellen.
                          Wenn das über den Adapter nicht möglich sein sollte dann muss vielleicht ein zweiter Adapter her, der die Datenpunkte dann komplett getrennt anlegt. Mich wundert nur warum zwei unterschiedliche Geräte mit der selben Seriennummer im Datenpunkt angelegt werden. Vielleicht hat "John30", von Ihm hab ich zum Beispiel mein Adapter, eine direkte Antwort. Oder natürlich der Produzent deines Ebus Adapters
                          • D DRUROB
                            Hi!
                            FASchmidt
                            #544
                            @drurob die Serienummer ist die des Vaillant Internetgateways. Über dieses sind beide, also die Arotherm und die ecoTEC mit den ebus verbunden. In der sensoApp werden deren Werte auch sauber getrennt, nur eben in IOBroker leider bisher nicht.
                            Gruß Andreas.
                            • F FASchmidt
                              Gruß Andreas.
                              FASchmidt
                              #545
                              Kaum habe ich hier geantwortet kommt von Vaillant eine eMail, dass ich voraussichtlich in den nächsten Tagen von der SensoAPP auf myVAILLANT umgestellt werde. Das Update des Gateways soll dabei automatisch erfolgen.
                              Gruß Andreas.
                              • G Offline
                                Glowzz
                                #546
                                Guten Tag zusammen,
                                Vielen Dank erstmal für das erstellen des Adapters!
                                Habe die Tage schonmal alles eingestellt und es hat auch schon super funktioniert allerdings kommt seit 2 Tagen der Fehler “clean configuration failed” des Weiteren kommen Fehler das einige Werte nicht gesetzt werden können sprich Heizung auf DAY/NIGHT und warmwasserbereitung auf AUTO/OFF
                                Gelegentlich kommt der/die Fehler auch wenn ich unter Objekte die werte mit der Hand setze allerdings nicht immer.
                                Bin auf der Version 0.1.2 und verwende die multiMATIC App
                                • F FASchmidt
                                  Gruß Andreas.
                                  FASchmidt
                                  schrieb am zuletzt editiert von FASchmidt
                                  #547
                                  Nun habe ich seit etwa einem Monat die Umstellung auf myVaillant bekommen. Ich bin etwas zwiegespalten. Einiges ist besser. Das ist z.B. alles was mit der Reglung der Kreise zusammenhängt. Nachteilig empfinde ich andererseits, dass es nun scheinbar (oder ich finde sie einfach nicht) keine Summenwerte für die Energieverbräuche oder den -ertrag gibt. Dafür gibt es jeden Tag für die Energieerzeuger neue Unterordner, d.h. der Datenbaum wird immer größer. Ich sehr da irgendwie keinen Sinn drin.
                                  Ich werde mich mal in den eeBus-Adapter einarbeiten. Da muss zwar noch Hardware angeschlossen werden, aber vielleicht ist das dann weniger chaotisch als mit diesem Adapter der obendrein noch sosehr abhängig von einer funktionierenden Vaillant-Cloud ist.
                                  Gruß Andreas
                                  • F FASchmidt
                                    Gruß Andreas
                                    tombox
                                    #548
                                    @faschmidt welcher Datenpunkt wird genau größer?
                                    • T tombox
                                      FASchmidt
                                      #549
                                      @tombox Alle diejenigen welche Ernergiewerte beinhalten z.B. beigefügte Bilder. Dabei hat Vaillant offensichtlich die Tageswerte auch noch rückwärts für einige Zeit vor myVaillant breitgestellt.
                                      Gruß Andreas.
                                        merbes
                                        #550
                                        moin zusammen, wenn ich jetzt daheim eine VR900 an meiner Heizung mit einer Multimatic 700 habe und die auch über die Multimatic-App ausgelesen bekomme, wie erhalte ich überhaupt werde in dieser Instanz?
                                        Die Version ist 0.1.2.
                                        Die Login Daten sind ok. Der Adapter wird mir auch grün angezeigt.
                                        wie kann ich danach eine Konfiguration anhängen?
                                        Danke,
                                        michael
                                        • M merbes
                                          Danke,
                                          michael
                                          JoergH
                                          #551
                                          @merbes
                                          Wenn die Instanz grün ist, dann zieht er die Werte schon. Da aber nur alle 15 Minuten ein Update gezogen wird, dauert es etwas.
