  4. Alpha Test js-controller 5.0
    6.6k
140 Beiträge 25 Kommentatoren 31.9k Aufrufe 31 Beobachtet
  • apollon77A apollon77
    @e-i-k-e mach mal loglevel Debug. Vllt sieht man da mehr.
    e-i-k-e
    @apollon77
    Gerne.
    host.ioBroker-Rock
    2023-04-03 23:27:06.136	info	Restart adapter system.adapter.yeelight-2.0 because enabled
    host.ioBroker-Rock
    2023-04-03 23:27:06.135	error	instance system.adapter.yeelight-2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.ioBroker-Rock
    2023-04-03 23:27:06.135	error	Caught by controller[1]: at TCP.<anonymous> (node:net:322:12)
    host.ioBroker-Rock
    2023-04-03 23:27:06.135	error	Caught by controller[1]: at Socket.emit (node:domain:489:12)
    host.ioBroker-Rock
    2023-04-03 23:27:06.134	error	Caught by controller[1]: at Socket.emit (node:events:525:35)
    host.ioBroker-Rock
    2023-04-03 23:27:06.134	error	Caught by controller[1]: at Object.onceWrapper (node:events:628:26)
    host.ioBroker-Rock
    2023-04-03 23:27:06.134	error	Caught by controller[1]: at Socket.onClose (node:net:911:10)
    host.ioBroker-Rock
    2023-04-03 23:27:06.134	error	Caught by controller[1]: at new NodeError (node:internal/errors:399:5)
    host.ioBroker-Rock
    2023-04-03 23:27:06.133	error	Caught by controller[1]: Error: Socket closed before the connection was established
    host.ioBroker-Rock
    2023-04-03 23:27:06.133	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    yeelight-2.0
    2023-04-03 23:27:05.485	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    yeelight-2.0
    2023-04-03 23:27:05.484	debug	Plugin sentry destroyed
    yeelight-2.0
    2023-04-03 23:27:05.483	info	terminating
    yeelight-2.0
    2023-04-03 23:27:05.482	info	cleaned everything up...
    yeelight-2.0
    2023-04-03 23:27:05.446	error	Exception-Code: ERR_SOCKET_CLOSED_BEFORE_CONNECTION: Socket closed before the connection was established
    yeelight-2.0
    2023-04-03 23:27:05.445	error	Error: Socket closed before the connection was established at new NodeError (node:internal/errors:399:5) at Socket.onClose (node:net:911:10) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:525:35) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:322:12)
    yeelight-2.0
    2023-04-03 23:27:05.445	error	unhandled promise rejection: Socket closed before the connection was established
    yeelight-2.0
    2023-04-03 23:27:05.444	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    yeelight-2.0
    2023-04-03 23:27:05.436	debug	ERROR YEELIGHT CONNECTION: 0x000000000000000: Connection 192.168.3.140:55443: Error: connect EHOSTUNREACH 192.168.3.140:55443
    yeelight-2.0
    2023-04-03 23:27:02.673	debug	DEVICE FOUND IN AND CONFIG: {"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}
    yeelight-2.0
    2023-04-03 23:27:02.670	debug	INITINAL ID FOUND FOR: color-0x0000000005ed0835
    yeelight-2.0
    2023-04-03 23:27:02.669	debug	RESPONSE MESSAGE: from: 0x0000000005ed0835, id: 1, result:[off,23,16711680,2,3000,,,0,100,0,,,,,,,,]}
    yeelight-2.0
    2023-04-03 23:27:02.642	debug	YEELIGHT FOUND: 192.168.3.141:55443 id: 0x0000000005ed0835 model: color
    yeelight-2.0
    2023-04-03 23:27:02.349	debug	YEELIGHT FOUND: 192.168.3.140:55443 id: 0x000000000000000 model: color
    yeelight-2.0
    2023-04-03 23:27:02.333	debug	SMARTNAME:
    yeelight-2.0
    2023-04-03 23:27:02.331	debug	OLD CONF. FROM OBJ: {"name":"Stehlampe_Schlafzimmer_groß","ip":"192.168.3.140","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
    yeelight-2.0
    2023-04-03 23:27:02.323	debug	OBJ_ELEMENT: yeelight-2.0.Stehlampe_Schlafzimmer_groß
    yeelight-2.0
    2023-04-03 23:27:02.322	debug	SMARTNAME:
    yeelight-2.0
    2023-04-03 23:27:02.320	debug	OLD CONF. FROM OBJ: {"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}
    yeelight-2.0
    2023-04-03 23:27:02.308	debug	OBJ_ELEMENT: yeelight-2.0.Stehlampe_Schlafzimmer_klein
    yeelight-2.0
    2023-04-03 23:27:02.307	debug	DEVICES IN OBJECTS FOUND: 2
    yeelight-2.0
    2023-04-03 23:27:02.306	debug	DEVICES IN OBJECTS: {"yeelight-2.0.Stehlampe_Schlafzimmer_klein":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"Stehlampe_Schlafzimmer_klein","type":"color"},"from":"system.adapter.yeelight-2.0","user":"system.user.admin","ts":1680464629168,"_id":"yeelight-2.0.Stehlampe_Schlafzimmer_klein","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}},"yeelight-2.0.Stehlampe_Schlafzimmer_groß":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"Stehlampe_Schlafzimmer_groß","type":"color"},"from":"system.adapter.yeelight-2.0","user":"system.user.admin","ts":1680464629164,"_id":"yeelight-2.0.Stehlampe_Schlafzimmer_groß","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}}
    yeelight-2.0
    2023-04-03 23:27:02.272	debug	DEVICES IN CONFIG: [{"name":"Stehlampe_Schlafzimmer_groß","ip":"192.168.3.140","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]},{"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}]
    yeelight-2.0
    2023-04-03 23:27:02.218	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230403-fd495c2e
    yeelight-2.0
    2023-04-03 23:27:01.853	debug	Plugin sentry Initialize Plugin (enabled=true)
    mqtt.0
    2023-04-03 23:27:01.267	info	Client [] connected with secret 1680557221267_3140
    mqtt.0
    2023-04-03 23:27:01.022	info	Client [] connection closed: disconnected
    host.ioBroker-Rock
    2023-04-03 23:26:59.134	info	instance system.adapter.yeelight-2.0 started with pid 34722
    influxdb.0
    2023-04-03 23:26:36.571	info	Store 501 buffered influxDB history points
    host.ioBroker-Rock
    2023-04-03 23:26:29.001	info	Restart adapter system.adapter.yeelight-2.0 because enabled
    host.ioBroker-Rock
    2023-04-03 23:26:29.000	error	instance system.adapter.yeelight-2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.ioBroker-Rock
    2023-04-03 23:26:29.000	error	Caught by controller[0]: at TCP.<anonymous> (node:net:322:12)
    host.ioBroker-Rock
    2023-04-03 23:26:29.000	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
    host.ioBroker-Rock
    2023-04-03 23:26:28.999	error	Caught by controller[0]: at Socket.emit (node:events:525:35)
    host.ioBroker-Rock
    2023-04-03 23:26:28.999	error	Caught by controller[0]: at Object.onceWrapper (node:events:628:26)
    host.ioBroker-Rock
    2023-04-03 23:26:28.999	error	Caught by controller[0]: at Socket.onClose (node:net:911:10)
    host.ioBroker-Rock
    2023-04-03 23:26:28.999	error	Caught by controller[0]: at new NodeError (node:internal/errors:399:5)
    host.ioBroker-Rock
    2023-04-03 23:26:28.998	error	Caught by controller[0]: Error: Socket closed before the connection was established
    host.ioBroker-Rock
    2023-04-03 23:26:28.997	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    yeelight-2.0
    2023-04-03 23:26:28.347	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    yeelight-2.0
    2023-04-03 23:26:28.346	debug	Plugin sentry destroyed
    yeelight-2.0
    2023-04-03 23:26:28.345	info	terminating
    yeelight-2.0
    2023-04-03 23:26:28.344	info	cleaned everything up...
    yeelight-2.0
    2023-04-03 23:26:28.323	error	Exception-Code: ERR_SOCKET_CLOSED_BEFORE_CONNECTION: Socket closed before the connection was established
    yeelight-2.0
    2023-04-03 23:26:28.323	error	Error: Socket closed before the connection was established at new NodeError (node:internal/errors:399:5) at Socket.onClose (node:net:911:10) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:525:35) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:322:12)
    yeelight-2.0
    2023-04-03 23:26:28.322	error	unhandled promise rejection: Socket closed before the connection was established
    yeelight-2.0
    2023-04-03 23:26:28.322	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    yeelight-2.0
    2023-04-03 23:26:28.315	debug	ERROR YEELIGHT CONNECTION: 0x000000000000000: Connection 192.168.3.140:55443: Error: connect EHOSTUNREACH 192.168.3.140:55443
    yeelight-2.0
    2023-04-03 23:26:26.545	debug	DEVICE FOUND IN AND CONFIG: {"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}
    yeelight-2.0
    2023-04-03 23:26:26.542	debug	INITINAL ID FOUND FOR: color-0x0000000005ed0835
    yeelight-2.0
    2023-04-03 23:26:26.542	debug	RESPONSE MESSAGE: from: 0x0000000005ed0835, id: 1, result:[off,23,16711680,2,3000,,,0,100,0,,,,,,,,]}
    yeelight-2.0
    2023-04-03 23:26:25.547	debug	YEELIGHT FOUND: 192.168.3.141:55443 id: 0x0000000005ed0835 model: color
    yeelight-2.0
    2023-04-03 23:26:25.254	debug	YEELIGHT FOUND: 192.168.3.140:55443 id: 0x000000000000000 model: color
    yeelight-2.0
    2023-04-03 23:26:25.238	debug	SMARTNAME:
    yeelight-2.0
    2023-04-03 23:26:25.236	debug	OLD CONF. FROM OBJ: {"name":"Stehlampe_Schlafzimmer_groß","ip":"192.168.3.140","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
    yeelight-2.0
    2023-04-03 23:26:25.229	debug	OBJ_ELEMENT: yeelight-2.0.Stehlampe_Schlafzimmer_groß
    yeelight-2.0
    2023-04-03 23:26:25.228	debug	SMARTNAME:
    yeelight-2.0
    2023-04-03 23:26:25.226	debug	OLD CONF. FROM OBJ: {"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}
    yeelight-2.0
    2023-04-03 23:26:25.213	debug	OBJ_ELEMENT: yeelight-2.0.Stehlampe_Schlafzimmer_klein
    yeelight-2.0
    2023-04-03 23:26:25.212	debug	DEVICES IN OBJECTS FOUND: 2
    yeelight-2.0
    2023-04-03 23:26:25.211	debug	DEVICES IN OBJECTS: {"yeelight-2.0.Stehlampe_Schlafzimmer_klein":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"Stehlampe_Schlafzimmer_klein","type":"color"},"from":"system.adapter.yeelight-2.0","user":"system.user.admin","ts":1680464629168,"_id":"yeelight-2.0.Stehlampe_Schlafzimmer_klein","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}},"yeelight-2.0.Stehlampe_Schlafzimmer_groß":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"Stehlampe_Schlafzimmer_groß","type":"color"},"from":"system.adapter.yeelight-2.0","user":"system.user.admin","ts":1680464629164,"_id":"yeelight-2.0.Stehlampe_Schlafzimmer_groß","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}}
    yeelight-2.0
    2023-04-03 23:26:25.181	debug	DEVICES IN CONFIG: [{"name":"Stehlampe_Schlafzimmer_groß","ip":"192.168.3.140","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]},{"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}]
    yeelight-2.0
    2023-04-03 23:26:25.142	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230403-fd495c2e
    yeelight-2.0
    2023-04-03 23:26:24.734	debug	Plugin sentry Initialize Plugin (enabled=true)
    yeelight-2.0
    2023-04-03 23:26:24.629	debug	States connected to redis: 192.168.3.104:6379
    yeelight-2.0
    2023-04-03 23:26:24.617	debug	States create User PubSub Client
    yeelight-2.0
    2023-04-03 23:26:24.615	debug	States create System PubSub Client
    yeelight-2.0
    2023-04-03 23:26:24.608	debug	Redis States: Use Redis connection: 192.168.3.104:6379
    yeelight-2.0
    2023-04-03 23:26:24.587	debug	Objects connected to redis: 192.168.3.104:6379
    yeelight-2.0
    2023-04-03 23:26:24.579	debug	Objects client initialize lua scripts
    yeelight-2.0
    2023-04-03 23:26:23.863	debug	Objects create User PubSub Client
    yeelight-2.0
    2023-04-03 23:26:23.861	debug	Objects create System PubSub Client
    yeelight-2.0
    2023-04-03 23:26:23.856	debug	Objects client ready ... initialize now
    yeelight-2.0
    2023-04-03 23:26:23.793	debug	Redis Objects: Use Redis connection: 192.168.3.104:6379
    host.ioBroker-Rock
    2023-04-03 23:26:21.996	info	instance system.adapter.yeelight-2.0 started with pid 34705
    host.ioBroker-Rock
    2023-04-03 23:26:21.680	info	"system.adapter.yeelight-2.0" enabled
    host.ioBroker-Rock
    2023-04-03 23:26:10.184	info	"system.adapter.yeelight-2.0" disabled
    • E e-i-k-e
      @apollon77
      Gerne.
      host.ioBroker-Rock
      host.ioBroker-Rock
      host.ioBroker-Rock
      host.ioBroker-Rock
      host.ioBroker-Rock
      host.ioBroker-Rock
      host.ioBroker-Rock
      host.ioBroker-Rock
      host.ioBroker-Rock
      host.ioBroker-Rock
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      mqtt.0
      mqtt.0
      host.ioBroker-Rock
      influxdb.0
      host.ioBroker-Rock
      host.ioBroker-Rock
      host.ioBroker-Rock
      host.ioBroker-Rock
      host.ioBroker-Rock
      host.ioBroker-Rock
      host.ioBroker-Rock
      host.ioBroker-Rock
      host.ioBroker-Rock
      host.ioBroker-Rock
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      yeelight-2.0
      host.ioBroker-Rock
      host.ioBroker-Rock
      host.ioBroker-Rock
      @e-i-k-e sagte in Alpha Test js-controller 5.0:
      Also mal abgesehen vom crash tippe ich das eher das dein issue ist ... EHOSTUNREACH heisst das das gerät im Netzwerk nicht da ist ... Ich denke er adapter code schliesst darauf hin das socket was aber nie offen war wegen dem Fehler. Bitte adapter issue anlegen das man das dort fixt ... und schau warum das Geröt nicht online ist
      • apollon77A Offline
        Alpha Update
        5.0.1-alpha.0-20230406-4552d569
        • Fixes compact mode
        • Hide warning about "www folder not found" for widgets adapters
        Wenn alles so stabil bleibt würde wir überlegen Mitte nächste Woche in den Beta Test im Latest Repo zu gehen ...
        GaspodeG Thomas BraunT FeuersturmF 3 Antworten Letzte Antwort
          Alpha Update
          GaspodeG Offline
          GaspodeG Offline
          Gaspode
          @apollon77
          Keine Auffälligkeiten. Den Compact Mode nutze ich normalerweise nicht. Hab ihn jetzt mal testweise nach langer Suche :) eingeschaltet (Windows) und merke keinen Unterschied zu vorher. Ist wahrscheinlich gut so, aber kann ich irgendwie kontrollieren, dass er auch wirklich aktiv ist? Hinter jeder Instanz wird jedenfalls noch unterschiedliche RAM Nutzung angezeigt.
          @apollon77 said in Alpha Test js-controller 5.0:
          Dazu kann ich nix sagen, kenne die Warning nicht.
            Alpha Update
            @apollon77
            So auf den ersten Blick läuft das rund hier. Das Log ist ruhig, ich verwende allerdings auch den CompactMode nicht.
            • GaspodeG Gaspode
              @apollon77
              @gaspode Compat einschalten macht erstmal nichts. Du musst jetzt Instanzen sagen das sie in compact laufen sollen und eine gruppe angeben (0 ist "Mit controller", 1....n ist eigene Gruppen, je gruppe gibts einen prozess). das geht via admin bei den instanzen. ggf expertenmodus. Dann sollte ram nutzung weg sein bei den instanzen.
              GaspodeG ? 2 Antworten Letzte Antwort
                GaspodeG Offline
                GaspodeG Offline
                Gaspode
                Ah, OK. Danke. Wieder was gelernt. Hab jetzt alle Instanzen in die Controller Gruppe gepackt. Sehe keine Auffälligkeiten.
                  @apollon77
                  Habe hier 71 Adapter laufen, nur der fitbit-fitness zickt rum:
                  2023-04-06 10:52:54.815  - info: host.iobrokerS2 instance system.adapter.fitbit-fitness.0 started with pid 13160
                  2023-04-06 10:52:55.535  - debug: fitbit-fitness.0 (13160) Redis Objects: Use Redis connection: 10.1.1.1:6379
                  2023-04-06 10:52:55.555  - debug: fitbit-fitness.0 (13160) Objects client ready ... initialize now
                  2023-04-06 10:52:55.556  - debug: fitbit-fitness.0 (13160) Objects create System PubSub Client
                  2023-04-06 10:52:55.557  - debug: fitbit-fitness.0 (13160) Objects create User PubSub Client
                  2023-04-06 10:52:56.062  - debug: fitbit-fitness.0 (13160) Objects client initialize lua scripts
                  2023-04-06 10:52:56.066  - debug: fitbit-fitness.0 (13160) Objects connected to redis: 10.1.1.1:6379
                  2023-04-06 10:52:56.089  - debug: fitbit-fitness.0 (13160) Redis States: Use Redis connection: 10.1.1.1:6379
                  2023-04-06 10:52:56.096  - debug: fitbit-fitness.0 (13160) States create System PubSub Client
                  2023-04-06 10:52:56.097  - debug: fitbit-fitness.0 (13160) States create User PubSub Client
                  2023-04-06 10:52:56.103  - debug: fitbit-fitness.0 (13160) States connected to redis: 10.1.1.1:6379
                  2023-04-06 10:52:58.489  - info: fitbit-fitness.0 (13160) starting. Version 0.4.10 (non-npm: Chris-656/ioBroker.fitbit-fitness) in /opt/iobroker/node_modules/iobroker.fitbit-fitness, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230406-4552d569
                  2023-04-06 10:52:58.550  - debug: fitbit-fitness.0 (13160) Getting refresh Token: c817bd62dd39ec8ed529fc0d16396a1xxxxxxxx
                  2023-04-06 10:52:58.803  - info: fitbit-fitness.0 (13160) User logged in B...l id:xxxx8
                  2023-04-06 10:52:58.808  - debug: fitbit-fitness.0 (13160) Tokens checked
                  2023-04-06 10:52:59.041  - info: fitbit-fitness.0 (13160) Activity Records: Steps:0 Floors:undefined Calories:1884
                  2023-04-06 10:52:59.047  - error: fitbit-fitness.0 (13160) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  2023-04-06 10:52:59.047  - error: fitbit-fitness.0 (13160) unhandled promise rejection: undefined is not a valid state value
                  2023-04-06 10:52:59.049  - error: fitbit-fitness.0 (13160) Error: undefined is not a valid state value
                     at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17)
                     at FitBit._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5332:49)
                     at FitBit.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5293:21)
                     at FitBit.setActivityStates (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:321:9)
                     at FitBit.getActivityRecords (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:305:15)
                     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                     at async FitBit.getFitbitRecords (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:87:5)
                  2023-04-06 10:52:59.049  - error: fitbit-fitness.0 (13160) undefined is not a valid state value
                  2023-04-06 10:52:59.057  - info: fitbit-fitness.0 (13160) terminating
                  2023-04-06 10:52:59.058  - warn: fitbit-fitness.0 (13160) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2023-04-06 10:52:59.277  - info: fitbit-fitness.0 (13160) Body records: Weight:10.5 Fat:11.342750549316406 BMI:20.1
                  2023-04-06 10:52:59.559  - info: fitbit-fitness.0 (13160) terminating
                  2023-04-06 10:52:59.612  - error: host.iobrokerS2 instance system.adapter.fitbit-fitness.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  hab n Issue beim Adapter angelegt:
                  Issue
                  Daten zum System(iob diag):
                  Skript v.2023-04-02
                  *** BASE SYSTEM ***
                  Architecture : x86_64
                  Docker : false
                  Virtualization : kvm
                  Distributor ID: Debian
                  Description: Debian GNU/Linux 11 (bullseye)
                  Release: 11
                  Codename: bullseye
                  PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                  NAME="Debian GNU/Linux"
                  VERSION_ID="11"
                  VERSION="11 (bullseye)"
                  VERSION_CODENAME=bullseye
                  ID=debian
                  HOME_URL="https://www.debian.org/"
                  SUPPORT_URL="https://www.debian.org/support"
                  BUG_REPORT_URL="https://bugs.debian.org/"
                  Systemuptime and Load:
                  11:09:32 up 38 min, 1 user, load average: 1.21, 1.27, 1.24
                  CPU threads: 8
                  *** Time and Time Zones ***
                  Local time: Thu 2023-04-06 11:09:33 CEST
                  Universal time: Thu 2023-04-06 09:09:33 UTC
                  RTC time: Thu 2023-04-06 09:09:33
                  NTP service: n/a
                  RTC in local TZ: no
                  *** User and Groups ***
                  ilovegym
                  /home/ilovegym
                  ilovegym tty cdrom floppy audio dip video plugdev netdev iobroker
                  *** X-Server-Setup ***
                  X-Server: false
                  Desktop:
                  Terminal: tty
                  Boot Target: graphical.target
                  *** MEMORY ***
                  total used free shared buff/cache available
                  Mem: 16G 5.5G 9.6G 0.0K 886M 10G
                  Swap: 974M 0B 974M
                  Total: 16G 5.5G 10G
                      16007 M total memory
                       5518 M used memory
                        384 M active memory
                       5558 M inactive memory
                       9602 M free memory
                         98 M buffer memory
                        788 M swap cache
                        974 M total swap
                          0 M used swap
                        974 M free swap
                  *** FILESYSTEM ***
                  Filesystem Type Size Used Avail Use% Mounted on
                  udev devtmpfs 7.8G 0 7.8G 0% /dev
                  tmpfs tmpfs 1.6G 492K 1.6G 1% /run
                  /dev/sda1 ext4 8.9G 5.6G 2.8G 67% /
                  tmpfs tmpfs 7.9G 0 7.9G 0% /dev/shm
                  tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock
                  //10.10.2.10/photo cifs 11T 7.4T 3.1T 71% /mnt/photo
                  //10.10.2.10/daten cifs 11T 7.4T 3.1T 71% /mnt/daten
                  tmpfs tmpfs 1.6G 0 1.6G 0% /run/user/1000
                  [Thu Apr 6 10:30:48 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                  [Thu Apr 6 10:30:53 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                  TARGET SOURCE FSTYPE OPTIONS
                  / /dev/sda1 ext4 rw,relatime,errors=remount-ro
                  |-/mnt/photo //10.10.2.10/photo cifs rw,relatime,vers=3.1.1,cache=strict,username=ilovegym,uid=0,noforceuid,gid=0,noforcegid,addr=10.10.2.10,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
                  `-/mnt/daten //10.10.2.10/daten cifs rw,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=10.10.2.10,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
                  /var:
                  760M /var/
                  349M /var/log
                  273M /var/log/journal/fa9fb9e36d4942faa246786f755447be
                  259M /var/cache
                  /opt/iobroker/backups:
                  4.0K /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  151M /opt/iobroker/iobroker-data/
                  28M /opt/iobroker/iobroker-data/files
                  13M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                  93M /opt/iobroker/iobroker-data/objects.jsonl
                  29M /opt/iobroker/iobroker-data/states.jsonl
                  6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                  2.8M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                  1.6M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs v18.15.0
                  /usr/bin/node v18.15.0
                  /usr/bin/npm 9.5.0
                  /usr/bin/npx 9.5.0
                  nodejs:
                  Installed: 18.15.0-deb-1nodesource1
                  Candidate: 18.15.0-deb-1nodesource1
                  Version table:
                  *** 18.15.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                  12.22.12~dfsg-1~deb11u3 500
                  500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                  12.22.5~dfsg-2~11u1 500
                  500 http://deb.debian.org/debian bullseye/main amd64 Packages
                  No problems detected
                  *** ioBroker-Installation ***
                  ioBroker Status
                  At least one iobroker host is running.
                  Objects type: redis
                  States type: redis
                  Core adapters versions
                  admin: 6.4.3
                  javascript: 7.0.3
                  Adapters from github: 21
                  Adapter State
                  • system.adapter.admin.0 : admin : iobrokerS2 - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  • system.adapter.alarm.0 : alarm : iobrokerS2 - enabled
                  • system.adapter.alexa-shoppinglist.0 : alexa-shoppinglist : iobrokerS2 - enabled
                  • system.adapter.alexa-timer-vis.0 : alexa-timer-vis : iobrokerS2 - enabled
                  • system.adapter.alexa2.0 : alexa2 : iobrokerS2 - enabled
                  • system.adapter.backitup.0 : backitup : iobrokerS2 - enabled
                  • system.adapter.bluelink.0 : bluelink : iobrokerS2 - enabled
                  • system.adapter.cloud.0 : cloud : iobrokerS2 - enabled
                  • system.adapter.countdown.0 : countdown : iobrokerS2 - enabled
                  • system.adapter.device-watcher.0 : device-watcher : iobrokerS2 - enabled
                    system.adapter.devices.0 : devices : iobrokerS2 - disabled
                  • system.adapter.deyeidc.0 : deyeidc : iobrokerS2 - enabled, port: 8899
                  • system.adapter.deyeidc.1 : deyeidc : iobrokerS2 - enabled, port: 8899
                  • system.adapter.discovery.0 : discovery : iobrokerS2 - enabled
                  • system.adapter.drops-weather.0 : drops-weather : iobrokerS2 - enabled
                    system.adapter.dwd.0 : dwd : iobrokerS2 - enabled
                  • system.adapter.email.0 : email : iobrokerS2 - enabled
                  • system.adapter.energiefluss.0 : energiefluss : iobrokerS2 - enabled
                  • system.adapter.energiefluss.1 : energiefluss : iobrokerS2 - enabled
                    system.adapter.feiertage.0 : feiertage : iobrokerS2 - enabled
                    system.adapter.fitbit-fitness.0 : fitbit-fitness : iobrokerS2 - disabled
                    system.adapter.flot.0 : flot : iobrokerS2 - disabled
                  • system.adapter.fritzdect.0 : fritzdect : iobrokerS2 - enabled
                  • system.adapter.fully-mqtt.0 : fully-mqtt : iobrokerS2 - enabled
                  • system.adapter.go-e.0 : go-e : iobrokerS2 - enabled
                  • system.adapter.govee-app.0 : govee-app : iobrokerS2 - enabled
                  • system.adapter.heizoel.0 : heizoel : iobrokerS2 - enabled
                    system.adapter.ical.0 : ical : iobrokerS2 - enabled
                    system.adapter.iceroad.0 : iceroad : iobrokerS2 - enabled
                  • system.adapter.influxdb.0 : influxdb : iobrokerS2 - enabled, port: 8086
                  • system.adapter.influxdb.1 : influxdb : iobrokerS2 - enabled, port: 8086
                  • system.adapter.influxdb.2 : influxdb : iobrokerS2 - enabled, port: 8086
                  • system.adapter.iot.0 : iot : iobrokerS2 - enabled
                  • system.adapter.javascript.0 : javascript : iobrokerS2 - enabled
                  • system.adapter.lgtv.0 : lgtv : iobrokerS2 - enabled
                  • system.adapter.lgtv.1 : lgtv : iobrokerS2 - enabled
                  • system.adapter.lightcontrol.0 : lightcontrol : iobrokerS2 - enabled
                  • system.adapter.lightcontrol.1 : lightcontrol : iobrokerS2 - enabled
                  • system.adapter.linux-control.0 : linux-control : iobrokerS2 - enabled
                  • system.adapter.lovelace.0 : lovelace : iobrokerS2 - enabled, port: 8091, bind: 0.0.0.0, run as: admin
                    system.adapter.meteoalarm.0 : meteoalarm : iobrokerS2 - enabled
                  • system.adapter.mihome-vacuum.0 : mihome-vacuum : iobrokerS2 - enabled, port: 54321
                  • system.adapter.mihome-vacuum.1 : mihome-vacuum : iobrokerS2 - enabled, port: 54321
                  • system.adapter.mihome-vacuum.2 : mihome-vacuum : iobrokerS2 - enabled, port: 54321
                  • system.adapter.mihome-vacuum.3 : mihome-vacuum : iobrokerS2 - enabled, port: 54321
                  • system.adapter.minuaru.0 : minuaru : iobrokerS2 - enabled
                    system.adapter.minuvis.0 : minuvis : iobrokerS2 - disabled
                  • system.adapter.mqtt.0 : mqtt : iobrokerS2 - enabled, port: 1886, bind: 0.0.0.0
                  • system.adapter.mqtt.1 : mqtt : iobrokerS2 - enabled, port: 1884, bind: 0.0.0.0
                  • system.adapter.nut.0 : nut : iobrokerS2 - enabled
                  • system.adapter.octoprint.0 : octoprint : iobrokerS2 - enabled
                    system.adapter.odl.0 : odl : iobrokerS2 - enabled
                    system.adapter.oilfox.0 : oilfox : iobrokerS2 - enabled
                  • system.adapter.openligadb.0 : openligadb : iobrokerS2 - enabled
                    system.adapter.openweathermap.0 : openweathermap : iobrokerS2 - enabled
                  • system.adapter.operating-hours.0 : operating-hours : iobrokerS2 - enabled
                  • system.adapter.ping.0 : ping : iobrokerS2 - enabled
                  • system.adapter.pioneer_sc_vsx.0 : pioneer_sc_vsx : iobrokerS2 - enabled, port: 8102
                  • system.adapter.pollenflug.0 : pollenflug : iobrokerS2 - enabled
                  • system.adapter.puppeteer.0 : puppeteer : iobrokerS2 - enabled
                  • system.adapter.rest-api.0 : rest-api : iobrokerS2 - enabled, port: 8880, bind: 0.0.0.0, run as: restapi
                  • system.adapter.simple-api.0 : simple-api : iobrokerS2 - enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  • system.adapter.snmp.0 : snmp : iobrokerS2 - enabled
                    system.adapter.solarmanpv.0 : solarmanpv : iobrokerS2 - enabled
                  • system.adapter.sonoff.0 : sonoff : iobrokerS2 - enabled, port: 1883, bind: 0.0.0.0
                  • system.adapter.synochat.0 : synochat : iobrokerS2 - enabled
                  • system.adapter.synology.0 : synology : iobrokerS2 - enabled, port: 5001
                  • system.adapter.synology.1 : synology : iobrokerS2 - enabled, port: 5000
                  • system.adapter.text2command.0 : text2command : iobrokerS2 - enabled
                  • system.adapter.tr-064.0 : tr-064 : iobrokerS2 - enabled
                  • system.adapter.tr-064.1 : tr-064 : iobrokerS2 - enabled
                  • system.adapter.trashschedule.0 : trashschedule : iobrokerS2 - enabled
                  • system.adapter.tuya.0 : tuya : iobrokerS2 - enabled
                  • system.adapter.unifi.0 : unifi : iobrokerS2 - enabled
                  • system.adapter.viessmannapi.0 : viessmannapi : iobrokerS2 - enabled
                    system.adapter.vis.0 : vis : iobrokerS2 - enabled
                    system.adapter.weatherunderground.0 : weatherunderground : iobrokerS2 - enabled
                  • system.adapter.web.0 : web : iobrokerS2 - enabled, port: 81, bind: 0.0.0.0, run as: admin
                  • system.adapter.wifilight.0 : wifilight : iobrokerS2 - enabled
                  • system.adapter.windows-control.0 : windows-control : iobrokerS2 - enabled
                  • system.adapter.wireguard.0 : wireguard : iobrokerS2 - enabled
                  • system.adapter.wled.0 : wled : iobrokerS2 - enabled
                  • system.adapter.worx.0 : worx : iobrokerS2 - enabled
                  • system.adapter.yahka.0 : yahka : iobrokerS2 - enabled
                  • system.adapter.yeelight-2.0 : yeelight-2 : iobrokerS2 - enabled
                  • system.adapter.zigbee.0 : zigbee : iobrokerS2 - enabled, port: tcp://10.1.1.98:20108
                  • instance is alive
                  ioBroker-Repositories
                  stable : http://download.iobroker.net/sources-dist.json
                  beta : http://download.iobroker.net/sources-dist-latest.json
                  Active repo(s): beta
                  Installed ioBroker-Instances
                  Used repository: beta
                  Adapter "admin" : 6.4.3 , installed 6.4.3
                  Adapter "alarm" : 3.3.10 , installed 3.3.10
                  Adapter "alexa-shoppinglist": 0.1.5, installed 0.1.5
                  Adapter "alexa-timer-vis": 0.1.14 , installed 0.1.14
                  Adapter "alexa2" : 3.23.2 , installed 3.23.2
                  Adapter "backitup" : 2.6.16 , installed 2.6.16
                  Adapter "bluelink" : 2.2.6 , installed 2.2.8
                  Adapter "cloud" : 4.4.0 , installed 4.4.0
                  Adapter "countdown" : 1.3.0 , installed 1.3.0
                  Adapter "device-watcher": 2.8.0 , installed 2.8.0
                  Adapter "devices" : 1.1.2 , installed 1.1.2
                  Adapter "discovery" : 3.1.0 , installed 3.1.0
                  Adapter "dwd" : 2.8.3 , installed 2.8.3
                  Adapter "email" : 1.1.4 , installed 1.1.4
                  Adapter "feiertage" : 1.1.0 , installed 1.1.0
                  Adapter "fitbit-fitness": 0.4.10 , installed 0.4.10
                  Adapter "flot" : 1.12.0 , installed 1.12.0
                  Adapter "fritzdect" : 2.3.1 , installed 2.3.1
                  Adapter "go-e" : 1.0.27 , installed 1.0.26 [Updatable]
                  Adapter "heizoel" : 1.0.3 , installed 1.0.3
                  Adapter "ical" : 1.13.2 , installed 1.13.2
                  Adapter "iceroad" : 1.2.0 , installed 1.2.0
                  Adapter "influxdb" : 3.2.0 , installed 3.2.0
                  Adapter "iot" : 1.14.5 , installed 1.14.5
                  Adapter "javascript" : 7.0.3 , installed 7.0.3
                  Controller "js-controller": 4.0.24 , installed 5.0.1
                  Adapter "lgtv" : 1.1.10 , installed 1.1.10
                  Adapter "lightcontrol" : 0.2.1 , installed 0.2.1
                  Adapter "linux-control": 1.1.5 , installed 1.1.5
                  Adapter "lovelace" : 3.0.1 , installed 3.0.1
                  Adapter "meteoalarm" : 2.3.5 , installed 2.3.5
                  Adapter "mihome-vacuum": 3.9.5 , installed 3.9.5
                  Adapter "minuvis" : 2.3.3 , installed 2.3.3
                  Adapter "mqtt" : 4.1.1 , installed 4.1.1
                  Adapter "nut" : 1.6.0 , installed 1.6.0
                  Adapter "octoprint" : 4.1.0 , installed 4.1.0
                  Adapter "odl" : 2.0.5 , installed 2.0.5
                  Adapter "oilfox" : 4.1.2 , installed 4.1.2
                  Adapter "openligadb" : 1.2.4 , installed 1.2.4
                  Adapter "openweathermap": 0.3.8 , installed 0.3.8
                  Adapter "operating-hours": 1.0.0 , installed 1.0.0
                  Adapter "ping" : 1.5.3 , installed 1.5.3
                  Adapter "pollenflug" : 1.0.6 , installed 1.0.6
                  Adapter "puppeteer" : 0.2.7 , installed 0.2.7
                  Adapter "rest-api" : 1.0.5 , installed 1.0.5
                  Adapter "simple-api" : 2.7.2 , installed 2.7.2
                  Adapter "snmp" : 2.4.6 , installed 2.4.6
                  Adapter "socketio" : 6.3.5 , installed 6.3.5
                  Adapter "solarmanpv" : 0.3.2 , installed 0.3.2
                  Adapter "sonoff" : 2.5.3 , installed 2.5.3
                  Adapter "synochat" : 1.2.1 , installed 1.2.1
                  Adapter "synology" : 2.1.13 , installed 2.1.13
                  Adapter "text2command" : 3.0.2 , installed 3.0.2
                  Adapter "tr-064" : 4.2.18 , installed 4.2.18
                  Adapter "trashschedule": 2.2.0 , installed 2.2.0
                  Adapter "tuya" : 3.14.2 , installed 3.14.2
                  Adapter "unifi" : 0.6.4 , installed 0.6.4
                  Adapter "viessmannapi" : 2.0.9 , installed 2.0.9
                  Adapter "vis" : 1.4.16 , installed 1.4.16
                  Adapter "weatherunderground": 3.4.2, installed 3.4.2
                  Adapter "web" : 5.5.3 , installed 5.5.3
                  Adapter "wifilight" : 1.1.4 , installed 1.1.4
                  Adapter "windows-control": 0.1.5 , installed 0.1.5
                  Adapter "wireguard" : 1.4.1 , installed 1.4.1
                  Adapter "wled" : 0.6.7 , installed 0.6.7
                  Adapter "worx" : 2.0.3 , installed 2.0.3
                  Adapter "ws" : 2.3.6 , installed 2.3.6
                  Adapter "yahka" : 1.0.3 , installed 1.0.3
                  Adapter "yeelight-2" : 1.2.1 , installed 1.2.1
                  Adapter "zigbee" : 1.8.10 , installed 1.8.11
                  Objects and States
                  Objects: 101001
                  States: 83854
                  Hit:1 http://deb.debian.org/debian bullseye InRelease
                  Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                  Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
                  tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 15385 1/init
                  tcp 0 0 127.0.0.1:44467 0.0.0.0:* LISTEN 1001 43357 9753/chrome
                  tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 14536 523/sshd: /usr/sbin
                  tcp 0 0 127.0.0.1:6010 0.0.0.0:* LISTEN 1000 10636 597/sshd: ilovegym@
                  tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 32668 7176/io.sonoff.0
                  tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 31568 7623/io.mqtt.1
                  tcp 0 0 0.0.0.0:1886 0.0.0.0:* LISTEN 1001 33588 7529/io.mqtt.0
                  tcp6 0 0 :::44783 :::* LISTEN 1001 42537 8491/io.yahka.0
                  tcp6 0 0 :::111 :::* LISTEN 0 17436 1/init
                  tcp6 0 0 :::8880 :::* LISTEN 1001 40249 8662/io.rest-api.0
                  tcp6 0 0 :::81 :::* LISTEN 1001 37769 9131/io.web.0
                  tcp6 0 0 :::8081 :::* LISTEN 1001 36296 6749/io.admin.0
                  tcp6 0 0 :::22 :::* LISTEN 0 14538 523/sshd: /usr/sbin
                  tcp6 0 0 :::8087 :::* LISTEN 1001 46575 10220/io.simple-api
                  tcp6 0 0 ::1:6010 :::* LISTEN 1000 10635 597/sshd: ilovegym@
                  tcp6 0 0 :::8091 :::* LISTEN 1001 37748 8954/io.lovelace.0
                  tcp6 0 0 :::1888 :::* LISTEN 1001 51609 12074/io.fully-mqtt
                  udp 0 0 0.0.0.0:68 0.0.0.0:* 0 15469 387/dhclient
                  udp 0 0 0.0.0.0:111 0.0.0.0:* 0 17433 1/init
                  udp 0 0 10.1.1.2:123 0.0.0.0:* 0 9840 509/ntpd
                  udp 0 0 127.0.0.1:123 0.0.0.0:* 0 9838 509/ntpd
                  udp 0 0 0.0.0.0:123 0.0.0.0:* 0 9834 509/ntpd
                  udp 0 0 0.0.0.0:41823 0.0.0.0:* 110 10608 489/avahi-daemon: r
                  udp 0 0 0.0.0.0:34368 0.0.0.0:* 1001 42324 8208/io.snmp.0
                  udp 0 0 0.0.0.0:53421 0.0.0.0:* 1001 34730 7059/io.mihome-vacu
                  udp 0 0 0.0.0.0:54322 0.0.0.0:* 1001 46892 10637/io.mihome-vac
                  udp 0 0 0.0.0.0:54323 0.0.0.0:* 1001 32598 7020/io.mihome-vacu
                  udp 0 0 0.0.0.0:54324 0.0.0.0:* 1001 51230 10678/io.mihome-vac
                  udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 46434 10133/io.wled.0
                  udp 0 0 10.1.1.2:5353 0.0.0.0:* 1001 38275 7909/io.tr-064.0
                  udp 0 0 0.0.0.0:5353 0.0.0.0:* 110 10606 489/avahi-daemon: r
                  udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 37294 7833/io.tuya.0
                  udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 37295 7833/io.tuya.0
                  udp6 0 0 :::111 :::* 0 17439 1/init
                  udp6 0 0 fe80::11:32ff:fe28::123 :::* 106 9986 509/ntpd
                  udp6 0 0 ::1:123 :::* 0 9842 509/ntpd
                  udp6 0 0 :::123 :::* 0 9831 509/ntpd
                  udp6 0 0 :::5353 :::* 110 10607 489/avahi-daemon: r
                  udp6 0 0 :::38898 :::* 110 10609 489/avahi-daemon: r
                  2023-04-06 11:10:08.921 - info: web.0 (9131) ==> Connected system.user.admin from ::ffff:10.1.1.60
                  2023-04-06 11:10:10.219 - warn: sonoff.0 (7176) Client "Stecker7" not connected
                  2023-04-06 11:10:11.100 - info: meteoalarm.0 (20420) starting. Version 2.3.5 (non-npm: jack-blackson/ioBroker.meteoalarm) in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230406-4552d569
                  2023-04-06 11:10:12.555 - info: meteoalarm.0 (20420) 15.1: Updated Weather Alarms for Kreis Darmstadt-Dieburg und Stadt Darmstadt -> 0 alarm(s) found
                  2023-04-06 11:10:12.556 - warn: meteoalarm.0 (20420) Terminated (ADAPTER_REQUESTED_TERMINATION): All data processed. Adapter stopped until next scheduled process.
                  2023-04-06 11:10:13.080 - info: host.iobrokerS2 instance system.adapter.meteoalarm.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-04-06 11:10:15.813 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KI: MQTT connected
                  2023-04-06 11:10:16.138 - info: solarmanpv.0 (20379) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                  2023-04-06 11:10:16.653 - info: host.iobrokerS2 instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-04-06 11:10:17.236 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KA: MQTT connected
                  2023-04-06 11:10:20.096 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KI: Nuki start pairing
                  2023-04-06 11:10:20.098 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KI: Nuki paired
                  2023-04-06 11:10:20.810 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KA: Nuki start pairing
                  2023-04-06 11:10:20.811 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KA: Nuki paired
                  2023-04-06 11:10:23.579 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KI: Querying lock state: locked
                  2023-04-06 11:10:23.679 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KI: Querying lock battery state: success
                  2023-04-06 11:10:23.897 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KI: Reading config. Result: success
                  2023-04-06 11:10:23.897 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KI: Reading advanced config. Result: success
                  2023-04-06 11:10:24.088 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KA: Querying lock state: locked
                  2023-04-06 11:10:24.200 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KA: Querying lock battery state: success
                  2023-04-06 11:10:24.494 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KA: Reading config. Result: success
                  2023-04-06 11:10:24.597 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KA: Reading advanced config. Result: success
                  2023-04-06 11:10:25.923 - info: web.0 (9131) <== Disconnect system.user.admin from ::ffff:10.1.1.60
                  2023-04-06 11:10:29.145 - info: web.0 (9131) ==> Connected system.user.admin from ::ffff:10.1.1.60
                  2023-04-06 11:10:29.146 - info: web.0 (9131) ==> Connected system.user.admin from ::ffff:10.1.1.60
                    @apollon77
                    Issue
                    Skript v.2023-04-02
                    *** BASE SYSTEM ***
                    Docker : false
                    Release: 11
                    Codename: bullseye
                    VERSION_ID="11"
                    ID=debian
                    CPU threads: 8
                    NTP service: n/a
                    RTC in local TZ: no
                    ilovegym
                    /home/ilovegym
                    X-Server: false
                    Desktop:
                    Terminal: tty
                    *** MEMORY ***
                    Swap: 974M 0B 974M
                    Total: 16G 5.5G 10G
                         5518 M used memory
                          384 M active memory
                         9602 M free memory
                           98 M buffer memory
                          788 M swap cache
                          974 M total swap
                            0 M used swap
                          974 M free swap
                    *** FILESYSTEM ***
                    /var:
                    760M /var/
                    349M /var/log
                    259M /var/cache
                    /usr/bin/npm 9.5.0
                    /usr/bin/npx 9.5.0
                    nodejs:
                    Version table:
                    ioBroker Status
                    Objects type: redis
                    States type: redis
                    admin: 6.4.3
                    javascript: 7.0.3
                    Adapter State
                    • instance is alive
                    Objects and States
                    Objects: 101001
                    States: 83854
                    Pending Updates: 0
                    @ilovegym sagte in Alpha Test js-controller 5.0:
                    Jupp das ist genau richtig ... das sollte aber schon mit controller 4 gemeckert haben :-)
                      @apollon77
                      hmm mit Controller 4 hat er evtl gemeckert aber nicht den Adapter gestoppt.. hier stoppt er ihn und im Host-Tab wird eine 1 angezeigt und die Meldung, dass der fitbit-Adapter mehrmals mit Fehler gestartet wurde..
                      vorher lief er ohne mir aufzufallen.. und sonst ist am System nichts anders.. hab die VM geklont und nur den js-controller geupdatet...
                        @apollon77
                        @ilovegym Ok, dann haben wir vllt doch eine "lange zeit deprecation" jetzt härter ... Danke!
                          @apollon77 @simatec
                          Backitup-Adapter V2.6.16 zickt hier seltsam und steigt aus, weil er die Objects nicht sichern kann..?? hmm? das geht so mit anscheinend allem, was in vis, userdata etc gelagert ist.. ?
                          Datenbank ist redis/redis auf einer externen VM..
                          Ansonsten laeft alles unauffaellig...
                          [DEBUG] [iobroker] - Can not copy File vis/lib/js/moment-with-locales.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/moment-with-locales.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                          Can not copy File vis/lib/js/quo.standalone.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/quo.standalone.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                            @apollon77 @simatec
                            simatecS Online
                            simatecS Online
                            simatec
                            @ilovegym Führe mal bitte das Backup über die CLI aus und poste mal die Ausgabe
                            iob backup
                            • Besuche meine Github Seite
                            • HowTo Restore ioBroker
                            • simatecS simatec
                              iob backup
                              @simatec
                              das wird lang.. Moment.. er macht... musste kuerzen, waren mehr als 100000 Zeichen..
                              ilovegym@iobrokerS2:/opt/iobroker$ iob backup
                              host.iobrokerS2 84652 states saved
                              Can not copy File 0_userdata.0/Icons/blaue_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/blaue_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/Icons/braune_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/braune_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/Icons/braune_tonne1.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/braune_tonne1.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/Icons/gelbe_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/gelbe_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/Icons/graue_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/graue_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/Icons/gruene_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/gruene_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/Icons/hellblaue_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/hellblaue_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_blau.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_blau.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_gelb.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_gelb.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_grau.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_grau.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_gruen.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_gruen.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/Icons/schwarze_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/schwarze_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/Icons/state_leerung blaue tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung blaue tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/Icons/state_leerung braune tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung braune tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/Icons/state_leerung gelbe tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung gelbe tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/Icons/state_leerung gruene tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung gruene tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/Icons/state_leerung schwarze tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung schwarze tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/Icons/undefined.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/undefined.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/htmlakku.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlakku.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/htmlbackitup.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlbackitup.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/htmldect2.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmldect2.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/htmlfussball1.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlfussball1.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/htmlfussball2.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlfussball2.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/htmltrash1.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmltrash1.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Alarmpanel.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Alarmpanel.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD10.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD10.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD8.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD8.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Frontdoor.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Frontdoor.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Guest.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Guest.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Home.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Home.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_HomeTV.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_HomeTV.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Mobile.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Mobile.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/AlarmpanelHD8.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/AlarmpanelHD8.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/Energy.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Energy.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/Home.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Home.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/HomeTV.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/HomeTV.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/Log.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Log.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/Mobile.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Mobile.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/OldMobile.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/OldMobile.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/TVOGB.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/TVOGB.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/Test.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Test.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/minukodu/Video.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Video.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/screenshots/bundesliga2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/screenshots/bundesliga2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File 0_userdata.0/synology/Doorbell.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/synology/Doorbell.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File lovelace.0/cards/background.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/lovelace.0/cards/background.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File mihome-vacuum.0.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.0.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File mihome-vacuum.1.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.1.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File mihome-vacuum.2.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.2.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File mihome-vacuum.3.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.3.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File synology.0/cover.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/cover.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File synology.0/snapshotCam_13.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_13.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File synology.0/snapshotCam_19.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_19.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File synology.0/snapshotCam_21.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_21.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File synology.0/snapshotCam_24.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_24.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File synology.0/snapshotCam_26.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_26.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File synology.0/snapshotCam_7.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_7.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File synology.1/cover.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.1/cover.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/cache.manifest to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/cache.manifest: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/cordova.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/cordova.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/css/add_kian.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/add_kian.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/css/app.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/app.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/css/backgrounds.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/backgrounds.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/css/doc.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/doc.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/css/montserrat-regular-webfont.woff to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/montserrat-regular-webfont.woff: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/css/styles.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/styles.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/css/vis-common-user.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/vis-common-user.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/css/vis-editor.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/vis-editor.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/css/vis.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/vis.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/edit.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/edit.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/edit.src.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/edit.src.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/add.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/add.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/align-height.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-height.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/align-horizontal-center-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-horizontal-center-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/align-horizontal-left.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-horizontal-left.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/align-horizontal-right-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-horizontal-right-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/align-vertical-bottom-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-vertical-bottom-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/align-vertical-center-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-vertical-center-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/align-vertical-top-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-vertical-top-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/align-width.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-width.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/bar.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/bar.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/cancel.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/cancel.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/checkbox.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/checkbox.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/container.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/container.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/control.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/control.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/copy.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/copy.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/delete.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/delete.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/dialog.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/dialog.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/distribute-horizontal-equal.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/distribute-horizontal-equal.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/distribute-vertical-equal.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/distribute-vertical-equal.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/door.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/door.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/filter.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/filter.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/groupFixed.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/groupFixed.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/groupVisibility.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/groupVisibility.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/info.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/info.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/lamp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/lamp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/lock.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/lock.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/lockIcon.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/lockIcon.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/navigation.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/navigation.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/ok.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/ok.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/refresh-4.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/refresh-4.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/rename.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/rename.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/rgb.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/rgb.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/shutter.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/shutter.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/state.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/state.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/stateful.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/stateful.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/static.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/static.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/table.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/table.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/temperature.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/temperature.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/timestamp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/timestamp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/tools.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/tools.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/value.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/value.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/icon/window.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/window.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/Heating.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/Heating.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/Lamp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/Lamp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/OutsideTemp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/OutsideTemp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/Window.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/Window.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/back/box-radial.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/back/box-radial.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/back/flowers.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/back/flowers.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/back/oblique-line-bk.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/back/oblique-line-bk.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/bg-dots-10.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-10.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/bg-dots-15.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-15.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/bg-dots-20.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-20.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/bg-dots-25.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-25.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/bg-dots-30.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-30.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/bg-dots-40.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-40.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/bg-dots-5.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-5.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/bg-dots-50.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-50.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/bulbOff.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulbOff.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/bulbOn.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulbOn.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/bulb_off.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulb_off.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/bulb_on.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulb_on.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/camera.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/camera.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/cc-nc-by.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/cc-nc-by.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/disconnect.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/disconnect.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/door-bell.mp3 to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/door-bell.mp3: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/editmode-pattern.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/editmode-pattern.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/eg_trans.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/eg_trans.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/favicon.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/favicon.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/faviconEdit.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/faviconEdit.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/garage-door-closed.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/garage-door-closed.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/garage-door-opened.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/garage-door-opened.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/gear-icon-md.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/gear-icon-md.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/hexabump.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/hexabump.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/kde_folder.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/kde_folder.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/no_filter.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/no_filter.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/sound.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/sound.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/tank.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/tank.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/vis.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/vis.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/img/zip.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/zip.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/index.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/index.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/index.src.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/index.src.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/app.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/app.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/config.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/config.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/conn.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/conn.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/connSignalR.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/connSignalR.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/fileManager.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/fileManager.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/fileManager.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/fileManager.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/actions/add.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/add.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/actions/back.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/back.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/actions/delete.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/delete.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/actions/down.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/down.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/actions/edit-rename.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/edit-rename.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/actions/folder-new-7.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/folder-new-7.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/actions/folder-new.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/folder-new.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/actions/icons.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/icons.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/actions/list.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/list.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/actions/play.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/play.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/actions/refresh.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/refresh.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/actions/stop.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/stop.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/actions/up.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/up.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/circleLeftIcon.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/circleLeftIcon.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/128/JS.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/JS.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/128/bmp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/bmp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/128/css.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/css.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/128/folder-blue.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/folder-blue.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/128/folder-brown.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/folder-brown.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/128/folder-green.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/folder-green.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/128/gif.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/gif.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/128/img2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/img2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/128/jpg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/jpg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/128/misc.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/misc.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/128/mp3.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/mp3.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/128/png.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/png.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/128/prg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/prg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/128/svg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/svg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/128/undef.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/undef.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/128/wav.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/wav.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/128/zip.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/zip.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/24/bmp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/bmp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/24/css.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/css.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/24/folder-blue.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/folder-blue.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/24/folder-brown.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/folder-brown.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/24/folder-green.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/folder-green.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/24/gif.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/gif.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/24/img2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/img2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/24/jpg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/jpg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/24/js.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/js.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/24/misc.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/misc.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/24/mp3.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/mp3.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/24/png.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/png.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/24/prg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/prg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/24/svg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/svg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/24/undef.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/undef.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/24/wav.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/wav.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/fm/icon/mine/24/zip.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/zip.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/vis.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/vis.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/visAbout.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visAbout.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/visEdit.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEdit.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/visEditExt.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditExt.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/visEditInspect.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditInspect.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/visEditTemplates.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditTemplates.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/visEditWelcome.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditWelcome.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/visUtils.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visUtils.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/visWizard.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visWizard.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/js/words.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/words.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/ace/ace.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/ace.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/ace/ext-language_tools.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/ext-language_tools.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/ace/ext-searchbox.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/ext-searchbox.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/ace/mode-css.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/mode-css.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/ace/mode-html.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/mode-html.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/ace/mode-javascript.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/mode-javascript.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/ace/worker-css.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/worker-css.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/ace/worker-html.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/worker-html.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/ace/worker-javascript.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/worker-javascript.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/css/add2home-2.0.8.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/add2home-2.0.8.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/css/fancytree/channel.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/channel.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/css/fancytree/device.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/device.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/css/fancytree/icons.gif to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/icons.gif: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/css/fancytree/loading.gif to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/loading.gif: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/css/fancytree/state.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/state.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/css/fancytree/ui.fancytree.jquery.min.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/ui.fancytree.jquery.min.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/css/fancytree/ui.fancytree.min.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/ui.fancytree.min.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/css/farbtastic.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/farbtastic.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/css/jquery-ui-timepicker-addon-1.6.3.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery-ui-timepicker-addon-1.6.3.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/css/jquery.jgrowl.min.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery.jgrowl.min.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/css/jquery.multiselect-1.13.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery.multiselect-1.13.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/css/jquery.multiselect.filter.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery.multiselect.filter.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/css/superfish/megafish.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/megafish.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/css/superfish/superfish-navbar.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/superfish-navbar.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/css/superfish/superfish-vertical.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/superfish-vertical.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/css/superfish/superfish.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/superfish.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/img/delete.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/delete.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/img/edit-undo-8.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/edit-undo-8.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/img/logout.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/logout.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/img/marker.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/marker.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/img/mask.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/mask.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/img/shape_align_bottom.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_bottom.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/img/shape_align_left.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_left.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/img/shape_align_right.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_right.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/img/shape_align_top.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_top.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/img/wheel.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/wheel.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/js/add2home-2.0.8.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/add2home-2.0.8.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/js/can.custom.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/can.custom.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/js/colResizable-1.5.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/colResizable-1.5.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/js/dropzone.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/dropzone.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/js/farbtastic.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/farbtastic.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/js/html2canvas.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/html2canvas.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/js/jquery-ui-1.10.3.dragdropsort.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery-ui-1.10.3.dragdropsort.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/js/jquery-ui-timepicker-addon-1.6.3.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery-ui-timepicker-addon-1.6.3.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/js/jquery.ba-resize.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.ba-resize.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/js/jquery.base64.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.base64.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/js/jquery.fancytree-all.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.fancytree-all.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              Can not copy File vis/lib/js/jquery.inputmask.bundle.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.inputmask.bundle.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                              host.iobrokerS2 102072 objects saved
                              Backup created: /opt/iobroker/backups/2023_04_07-11_18_10_backupiobroker.tar.gz
                              This backup can only be restored with js-controller version up from 4.1
                              ilovegym@iobrokerS2:/opt/iobroker$
                                @simatec
                                das wird lang.. Moment.. er macht... musste kuerzen, waren mehr als 100000 Zeichen..
                                ilovegym@iobrokerS2:/opt/iobroker$ iob backup
                                host.iobrokerS2 84652 states saved
                                Can not copy File 0_userdata.0/Icons/blaue_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/blaue_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/Icons/braune_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/braune_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/Icons/braune_tonne1.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/braune_tonne1.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/Icons/gelbe_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/gelbe_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/Icons/graue_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/graue_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/Icons/gruene_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/gruene_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/Icons/hellblaue_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/hellblaue_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_blau.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_blau.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_gelb.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_gelb.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_grau.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_grau.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_gruen.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_gruen.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/Icons/schwarze_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/schwarze_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/Icons/state_leerung blaue tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung blaue tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/Icons/state_leerung braune tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung braune tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/Icons/state_leerung gelbe tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung gelbe tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/Icons/state_leerung gruene tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung gruene tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/Icons/state_leerung schwarze tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung schwarze tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/Icons/undefined.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/undefined.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/htmlakku.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlakku.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/htmlbackitup.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlbackitup.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/htmldect2.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmldect2.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/htmlfussball1.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlfussball1.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/htmlfussball2.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlfussball2.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/htmltrash1.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmltrash1.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Alarmpanel.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Alarmpanel.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD10.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD10.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD8.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD8.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Frontdoor.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Frontdoor.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Guest.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Guest.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Home.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Home.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_HomeTV.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_HomeTV.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Mobile.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Mobile.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/AlarmpanelHD8.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/AlarmpanelHD8.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/Energy.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Energy.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/Home.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Home.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/HomeTV.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/HomeTV.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/Log.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Log.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/Mobile.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Mobile.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/OldMobile.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/OldMobile.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/TVOGB.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/TVOGB.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/Test.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Test.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/minukodu/Video.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Video.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/screenshots/bundesliga2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/screenshots/bundesliga2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File 0_userdata.0/synology/Doorbell.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/synology/Doorbell.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File lovelace.0/cards/background.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/lovelace.0/cards/background.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File mihome-vacuum.0.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.0.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File mihome-vacuum.1.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.1.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File mihome-vacuum.2.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.2.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File mihome-vacuum.3.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.3.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File synology.0/cover.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/cover.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File synology.0/snapshotCam_13.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_13.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File synology.0/snapshotCam_19.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_19.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File synology.0/snapshotCam_21.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_21.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File synology.0/snapshotCam_24.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_24.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File synology.0/snapshotCam_26.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_26.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File synology.0/snapshotCam_7.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_7.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File synology.1/cover.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.1/cover.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/cache.manifest to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/cache.manifest: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/cordova.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/cordova.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/css/add_kian.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/add_kian.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/css/app.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/app.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/css/backgrounds.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/backgrounds.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/css/doc.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/doc.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/css/montserrat-regular-webfont.woff to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/montserrat-regular-webfont.woff: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/css/styles.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/styles.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/css/vis-common-user.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/vis-common-user.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/css/vis-editor.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/vis-editor.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/css/vis.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/vis.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/edit.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/edit.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/edit.src.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/edit.src.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/add.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/add.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/align-height.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-height.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/align-horizontal-center-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-horizontal-center-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/align-horizontal-left.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-horizontal-left.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/align-horizontal-right-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-horizontal-right-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/align-vertical-bottom-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-vertical-bottom-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/align-vertical-center-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-vertical-center-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/align-vertical-top-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-vertical-top-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/align-width.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-width.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/bar.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/bar.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/cancel.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/cancel.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/checkbox.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/checkbox.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/container.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/container.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/control.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/control.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/copy.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/copy.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/delete.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/delete.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/dialog.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/dialog.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/distribute-horizontal-equal.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/distribute-horizontal-equal.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/distribute-vertical-equal.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/distribute-vertical-equal.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/door.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/door.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/filter.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/filter.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/groupFixed.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/groupFixed.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/groupVisibility.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/groupVisibility.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/info.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/info.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/lamp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/lamp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/lock.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/lock.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/lockIcon.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/lockIcon.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/navigation.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/navigation.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/ok.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/ok.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/refresh-4.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/refresh-4.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/rename.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/rename.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/rgb.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/rgb.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/shutter.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/shutter.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/state.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/state.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/stateful.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/stateful.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/static.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/static.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/table.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/table.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/temperature.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/temperature.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/timestamp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/timestamp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/tools.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/tools.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/value.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/value.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/icon/window.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/window.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/Heating.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/Heating.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/Lamp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/Lamp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/OutsideTemp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/OutsideTemp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/Window.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/Window.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/back/box-radial.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/back/box-radial.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/back/flowers.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/back/flowers.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/back/oblique-line-bk.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/back/oblique-line-bk.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/bg-dots-10.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-10.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/bg-dots-15.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-15.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/bg-dots-20.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-20.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/bg-dots-25.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-25.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/bg-dots-30.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-30.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/bg-dots-40.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-40.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/bg-dots-5.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-5.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/bg-dots-50.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-50.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/bulbOff.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulbOff.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/bulbOn.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulbOn.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/bulb_off.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulb_off.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/bulb_on.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulb_on.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/camera.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/camera.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/cc-nc-by.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/cc-nc-by.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/disconnect.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/disconnect.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/door-bell.mp3 to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/door-bell.mp3: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/editmode-pattern.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/editmode-pattern.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/eg_trans.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/eg_trans.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/favicon.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/favicon.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/faviconEdit.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/faviconEdit.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/garage-door-closed.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/garage-door-closed.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/garage-door-opened.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/garage-door-opened.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/gear-icon-md.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/gear-icon-md.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/hexabump.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/hexabump.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/kde_folder.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/kde_folder.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/no_filter.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/no_filter.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/sound.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/sound.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/tank.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/tank.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/vis.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/vis.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/img/zip.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/zip.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/index.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/index.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/index.src.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/index.src.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/app.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/app.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/config.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/config.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/conn.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/conn.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/connSignalR.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/connSignalR.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/fileManager.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/fileManager.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/fileManager.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/fileManager.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/actions/add.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/add.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/actions/back.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/back.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/actions/delete.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/delete.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/actions/down.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/down.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/actions/edit-rename.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/edit-rename.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/actions/folder-new-7.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/folder-new-7.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/actions/folder-new.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/folder-new.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/actions/icons.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/icons.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/actions/list.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/list.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/actions/play.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/play.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/actions/refresh.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/refresh.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/actions/stop.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/stop.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/actions/up.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/up.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/circleLeftIcon.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/circleLeftIcon.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/128/JS.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/JS.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/128/bmp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/bmp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/128/css.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/css.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/128/folder-blue.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/folder-blue.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/128/folder-brown.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/folder-brown.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/128/folder-green.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/folder-green.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/128/gif.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/gif.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/128/img2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/img2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/128/jpg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/jpg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/128/misc.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/misc.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/128/mp3.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/mp3.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/128/png.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/png.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/128/prg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/prg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/128/svg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/svg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/128/undef.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/undef.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/128/wav.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/wav.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/128/zip.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/zip.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/24/bmp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/bmp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/24/css.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/css.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/24/folder-blue.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/folder-blue.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/24/folder-brown.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/folder-brown.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/24/folder-green.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/folder-green.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/24/gif.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/gif.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/24/img2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/img2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/24/jpg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/jpg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/24/js.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/js.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/24/misc.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/misc.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/24/mp3.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/mp3.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/24/png.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/png.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/24/prg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/prg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/24/svg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/svg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/24/undef.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/undef.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/24/wav.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/wav.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/fm/icon/mine/24/zip.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/zip.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/vis.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/vis.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/visAbout.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visAbout.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/visEdit.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEdit.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/visEditExt.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditExt.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/visEditInspect.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditInspect.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/visEditTemplates.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditTemplates.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/visEditWelcome.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditWelcome.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/visUtils.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visUtils.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/visWizard.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visWizard.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/js/words.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/words.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/ace/ace.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/ace.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/ace/ext-language_tools.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/ext-language_tools.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/ace/ext-searchbox.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/ext-searchbox.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/ace/mode-css.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/mode-css.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/ace/mode-html.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/mode-html.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/ace/mode-javascript.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/mode-javascript.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/ace/worker-css.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/worker-css.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/ace/worker-html.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/worker-html.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/ace/worker-javascript.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/worker-javascript.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/css/add2home-2.0.8.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/add2home-2.0.8.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/css/fancytree/channel.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/channel.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/css/fancytree/device.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/device.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/css/fancytree/icons.gif to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/icons.gif: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/css/fancytree/loading.gif to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/loading.gif: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/css/fancytree/state.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/state.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/css/fancytree/ui.fancytree.jquery.min.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/ui.fancytree.jquery.min.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/css/fancytree/ui.fancytree.min.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/ui.fancytree.min.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/css/farbtastic.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/farbtastic.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/css/jquery-ui-timepicker-addon-1.6.3.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery-ui-timepicker-addon-1.6.3.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/css/jquery.jgrowl.min.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery.jgrowl.min.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/css/jquery.multiselect-1.13.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery.multiselect-1.13.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/css/jquery.multiselect.filter.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery.multiselect.filter.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/css/superfish/megafish.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/megafish.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/css/superfish/superfish-navbar.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/superfish-navbar.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/css/superfish/superfish-vertical.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/superfish-vertical.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/css/superfish/superfish.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/superfish.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/img/delete.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/delete.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/img/edit-undo-8.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/edit-undo-8.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/img/logout.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/logout.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/img/marker.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/marker.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/img/mask.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/mask.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/img/shape_align_bottom.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_bottom.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/img/shape_align_left.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_left.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/img/shape_align_right.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_right.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/img/shape_align_top.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_top.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/img/wheel.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/wheel.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/js/add2home-2.0.8.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/add2home-2.0.8.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/js/can.custom.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/can.custom.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/js/colResizable-1.5.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/colResizable-1.5.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/js/dropzone.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/dropzone.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/js/farbtastic.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/farbtastic.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/js/html2canvas.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/html2canvas.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/js/jquery-ui-1.10.3.dragdropsort.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery-ui-1.10.3.dragdropsort.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/js/jquery-ui-timepicker-addon-1.6.3.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery-ui-timepicker-addon-1.6.3.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/js/jquery.ba-resize.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.ba-resize.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/js/jquery.base64.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.base64.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/js/jquery.fancytree-all.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.fancytree-all.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/js/jquery.inputmask.bundle.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.inputmask.bundle.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                host.iobrokerS2 102072 objects saved
                                Backup created: /opt/iobroker/backups/2023_04_07-11_18_10_backupiobroker.tar.gz
                                This backup can only be restored with js-controller version up from 4.1
                                ilovegym@iobrokerS2:/opt/iobroker$
                                simatecS Online
                                simatecS Online
                                simatec
                                @ilovegym Mach da mal bitte ein Issue beim js-controller auf. Der Befehl "iob backup" wird direkt vom js-controller bearbeitet. Backitup bedient sich nur der Backup Funktionen des js-controllers
                                • Besuche meine Github Seite
                                • HowTo Restore ioBroker
                                • simatecS simatec
                                  @simatec
                                  Issue done
                                    @simatec
                                    Issue done
                                    @ilovegym Und Danke, ist in der nächsten Alpha gefixt
                                    E 1 Antwort Letzte Antwort
                                    • apollon77A apollon77
                                      e-i-k-e
                                      #66
                                      @apollon77 sagte in Alpha Test js-controller 5.0:
                                      Ist die bereits verfügbar?
                                      • E e-i-k-e
                                        foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        #67
                                        @e-i-k-e Nein
                                        Videotutorials & mehr
                                        • BBTownB Offline
                                          BBTownB Offline
                                          BBTown
                                          #68
                                          Bei mir ging der Umstieg auf die v5 auch recht reibungslo über die Bühne.
                                          Ich habe das bekannte Problem mit dem iQontrol-Adapter und ich musste einen Upload im VIS-Adapter manuell anwerfen, danach waren meine Visualisierungen auch wieder erreichbar
