  4. Alpha Test js-controller 5.0
    6.6k
140 Beiträge 25 Kommentatoren 31.9k Aufrufe 31 Beobachtet
  • E Offline
    e-i-k-e
    Danke für das Update.
    Das Problem mit Yeelight besteht weiterhin.
    host.ioBroker-Rock
    2023-04-03 21:29:21.231	info	Restart adapter system.adapter.yeelight-2.0 because enabled
    host.ioBroker-Rock
    2023-04-03 21:29:21.230	error	instance system.adapter.yeelight-2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.ioBroker-Rock
    2023-04-03 21:29:21.229	error	Caught by controller[1]: at TCP.<anonymous> (node:net:322:12)
    host.ioBroker-Rock
    2023-04-03 21:29:21.228	error	Caught by controller[1]: at Socket.emit (node:domain:489:12)
    host.ioBroker-Rock
    2023-04-03 21:29:21.227	error	Caught by controller[1]: at Socket.emit (node:events:525:35)
    host.ioBroker-Rock
    2023-04-03 21:29:21.227	error	Caught by controller[1]: at Object.onceWrapper (node:events:628:26)
    host.ioBroker-Rock
    2023-04-03 21:29:21.226	error	Caught by controller[1]: at Socket.onClose (node:net:911:10)
    host.ioBroker-Rock
    2023-04-03 21:29:21.225	error	Caught by controller[1]: at new NodeError (node:internal/errors:399:5)
    host.ioBroker-Rock
    2023-04-03 21:29:21.225	error	Caught by controller[1]: Error: Socket closed before the connection was established
    host.ioBroker-Rock
    2023-04-03 21:29:21.224	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    yeelight-2.0
    2023-04-03 21:29:20.592	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    yeelight-2.0
    2023-04-03 21:29:20.590	info	terminating
    yeelight-2.0
    2023-04-03 21:29:20.589	info	cleaned everything up...
    yeelight-2.0
    2023-04-03 21:29:20.562	error	Exception-Code: ERR_SOCKET_CLOSED_BEFORE_CONNECTION: Socket closed before the connection was established
    yeelight-2.0
    2023-04-03 21:29:20.561	error	Error: Socket closed before the connection was established at new NodeError (node:internal/errors:399:5) at Socket.onClose (node:net:911:10) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:525:35) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:322:12)
    yeelight-2.0
    2023-04-03 21:29:20.560	error	unhandled promise rejection: Socket closed before the connection was established
    yeelight-2.0
    2023-04-03 21:29:20.558	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.ioBroker-Rock
    2023-04-03 21:29:20.372	info	instance system.adapter.alexa2.0 started with pid 33531
    host.ioBroker-Rock
    2023-04-03 21:29:18.170	info	instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.ioBroker-Rock
    2023-04-03 21:29:17.910	info	instance system.adapter.device-watcher.0 started with pid 33520
    yeelight-2.0
    2023-04-03 21:29:17.308	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230403-fd495c2e
    • apollon77A apollon77
      Alpha (@next) updated to 5.0.1-alpha.0-20230403-fd495c2e
      • Fixes missing logging object when logTransporter is used (e.g. Admin)
      • Fixes other issue with logTransporter (e.g. Admin) - events should now stream again in Admin
      • Fixed Compact group initialization
      • Fixes Binary/Text detection in writeFile
      • Fixes sendToHost (all) command
      Laut aktuellem stand sind damit alle gemeldete und auf den controller zurückzuführeden Themen behoben. Das Windows Kodi/git-npm-Fehler Thema muss man noch genauer untersuchen denke ich.
      FeuersturmF Offline
      FeuersturmF Offline
      Feuersturm
      @apollon77 sagte in Alpha Test js-controller 5.0:
      Master Slave System wurde erfolgreich aktualisiert.
      Admin Log aktualisiert sich jetzt auch wieder automatisch
      Bisher keine weiteren Auffälligkeiten bei mir :-)
      Dankeschön 🌻
      • E e-i-k-e
        host.ioBroker-Rock
        host.ioBroker-Rock
        host.ioBroker-Rock
        host.ioBroker-Rock
        host.ioBroker-Rock
        host.ioBroker-Rock
        host.ioBroker-Rock
        host.ioBroker-Rock
        host.ioBroker-Rock
        host.ioBroker-Rock
        yeelight-2.0
        yeelight-2.0
        yeelight-2.0
        yeelight-2.0
        yeelight-2.0
        yeelight-2.0
        yeelight-2.0
        host.ioBroker-Rock
        host.ioBroker-Rock
        host.ioBroker-Rock
        yeelight-2.0
        @e-i-k-e mach mal loglevel Debug. Vllt sieht man da mehr.
        E 1 Antwort Letzte Antwort
          e-i-k-e
          @apollon77
          Gerne.
          host.ioBroker-Rock
          2023-04-03 23:27:06.136	info	Restart adapter system.adapter.yeelight-2.0 because enabled
          host.ioBroker-Rock
          2023-04-03 23:27:06.135	error	instance system.adapter.yeelight-2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          host.ioBroker-Rock
          2023-04-03 23:27:06.135	error	Caught by controller[1]: at TCP.<anonymous> (node:net:322:12)
          host.ioBroker-Rock
          2023-04-03 23:27:06.135	error	Caught by controller[1]: at Socket.emit (node:domain:489:12)
          host.ioBroker-Rock
          2023-04-03 23:27:06.134	error	Caught by controller[1]: at Socket.emit (node:events:525:35)
          host.ioBroker-Rock
          2023-04-03 23:27:06.134	error	Caught by controller[1]: at Object.onceWrapper (node:events:628:26)
          host.ioBroker-Rock
          2023-04-03 23:27:06.134	error	Caught by controller[1]: at Socket.onClose (node:net:911:10)
          host.ioBroker-Rock
          2023-04-03 23:27:06.134	error	Caught by controller[1]: at new NodeError (node:internal/errors:399:5)
          host.ioBroker-Rock
          2023-04-03 23:27:06.133	error	Caught by controller[1]: Error: Socket closed before the connection was established
          host.ioBroker-Rock
          2023-04-03 23:27:06.133	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          yeelight-2.0
          2023-04-03 23:27:05.485	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          yeelight-2.0
          2023-04-03 23:27:05.484	debug	Plugin sentry destroyed
          yeelight-2.0
          2023-04-03 23:27:05.483	info	terminating
          yeelight-2.0
          2023-04-03 23:27:05.482	info	cleaned everything up...
          yeelight-2.0
          2023-04-03 23:27:05.446	error	Exception-Code: ERR_SOCKET_CLOSED_BEFORE_CONNECTION: Socket closed before the connection was established
          yeelight-2.0
          2023-04-03 23:27:05.445	error	Error: Socket closed before the connection was established at new NodeError (node:internal/errors:399:5) at Socket.onClose (node:net:911:10) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:525:35) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:322:12)
          yeelight-2.0
          2023-04-03 23:27:05.445	error	unhandled promise rejection: Socket closed before the connection was established
          yeelight-2.0
          2023-04-03 23:27:05.444	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          yeelight-2.0
          2023-04-03 23:27:05.436	debug	ERROR YEELIGHT CONNECTION: 0x000000000000000: Connection 192.168.3.140:55443: Error: connect EHOSTUNREACH 192.168.3.140:55443
          yeelight-2.0
          2023-04-03 23:27:02.673	debug	DEVICE FOUND IN AND CONFIG: {"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}
          yeelight-2.0
          2023-04-03 23:27:02.670	debug	INITINAL ID FOUND FOR: color-0x0000000005ed0835
          yeelight-2.0
          2023-04-03 23:27:02.669	debug	RESPONSE MESSAGE: from: 0x0000000005ed0835, id: 1, result:[off,23,16711680,2,3000,,,0,100,0,,,,,,,,]}
          yeelight-2.0
          2023-04-03 23:27:02.642	debug	YEELIGHT FOUND: 192.168.3.141:55443 id: 0x0000000005ed0835 model: color
          yeelight-2.0
          2023-04-03 23:27:02.349	debug	YEELIGHT FOUND: 192.168.3.140:55443 id: 0x000000000000000 model: color
          yeelight-2.0
          2023-04-03 23:27:02.333	debug	SMARTNAME:
          yeelight-2.0
          2023-04-03 23:27:02.331	debug	OLD CONF. FROM OBJ: {"name":"Stehlampe_Schlafzimmer_groß","ip":"192.168.3.140","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
          yeelight-2.0
          2023-04-03 23:27:02.323	debug	OBJ_ELEMENT: yeelight-2.0.Stehlampe_Schlafzimmer_groß
          yeelight-2.0
          2023-04-03 23:27:02.322	debug	SMARTNAME:
          yeelight-2.0
          2023-04-03 23:27:02.320	debug	OLD CONF. FROM OBJ: {"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}
          yeelight-2.0
          2023-04-03 23:27:02.308	debug	OBJ_ELEMENT: yeelight-2.0.Stehlampe_Schlafzimmer_klein
          yeelight-2.0
          2023-04-03 23:27:02.307	debug	DEVICES IN OBJECTS FOUND: 2
          yeelight-2.0
          2023-04-03 23:27:02.306	debug	DEVICES IN OBJECTS: {"yeelight-2.0.Stehlampe_Schlafzimmer_klein":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"Stehlampe_Schlafzimmer_klein","type":"color"},"from":"system.adapter.yeelight-2.0","user":"system.user.admin","ts":1680464629168,"_id":"yeelight-2.0.Stehlampe_Schlafzimmer_klein","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}},"yeelight-2.0.Stehlampe_Schlafzimmer_groß":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"Stehlampe_Schlafzimmer_groß","type":"color"},"from":"system.adapter.yeelight-2.0","user":"system.user.admin","ts":1680464629164,"_id":"yeelight-2.0.Stehlampe_Schlafzimmer_groß","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}}
          yeelight-2.0
          2023-04-03 23:27:02.272	debug	DEVICES IN CONFIG: [{"name":"Stehlampe_Schlafzimmer_groß","ip":"192.168.3.140","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]},{"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}]
          yeelight-2.0
          2023-04-03 23:27:02.218	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230403-fd495c2e
          yeelight-2.0
          2023-04-03 23:27:01.853	debug	Plugin sentry Initialize Plugin (enabled=true)
          mqtt.0
          2023-04-03 23:27:01.267	info	Client [] connected with secret 1680557221267_3140
          mqtt.0
          2023-04-03 23:27:01.022	info	Client [] connection closed: disconnected
          host.ioBroker-Rock
          2023-04-03 23:26:59.134	info	instance system.adapter.yeelight-2.0 started with pid 34722
          influxdb.0
          2023-04-03 23:26:36.571	info	Store 501 buffered influxDB history points
          host.ioBroker-Rock
          2023-04-03 23:26:29.001	info	Restart adapter system.adapter.yeelight-2.0 because enabled
          host.ioBroker-Rock
          2023-04-03 23:26:29.000	error	instance system.adapter.yeelight-2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          host.ioBroker-Rock
          2023-04-03 23:26:29.000	error	Caught by controller[0]: at TCP.<anonymous> (node:net:322:12)
          host.ioBroker-Rock
          2023-04-03 23:26:29.000	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
          host.ioBroker-Rock
          2023-04-03 23:26:28.999	error	Caught by controller[0]: at Socket.emit (node:events:525:35)
          host.ioBroker-Rock
          2023-04-03 23:26:28.999	error	Caught by controller[0]: at Object.onceWrapper (node:events:628:26)
          host.ioBroker-Rock
          2023-04-03 23:26:28.999	error	Caught by controller[0]: at Socket.onClose (node:net:911:10)
          host.ioBroker-Rock
          2023-04-03 23:26:28.999	error	Caught by controller[0]: at new NodeError (node:internal/errors:399:5)
          host.ioBroker-Rock
          2023-04-03 23:26:28.998	error	Caught by controller[0]: Error: Socket closed before the connection was established
          host.ioBroker-Rock
          2023-04-03 23:26:28.997	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          yeelight-2.0
          2023-04-03 23:26:28.347	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          yeelight-2.0
          2023-04-03 23:26:28.346	debug	Plugin sentry destroyed
          yeelight-2.0
          2023-04-03 23:26:28.345	info	terminating
          yeelight-2.0
          2023-04-03 23:26:28.344	info	cleaned everything up...
          yeelight-2.0
          2023-04-03 23:26:28.323	error	Exception-Code: ERR_SOCKET_CLOSED_BEFORE_CONNECTION: Socket closed before the connection was established
          yeelight-2.0
          2023-04-03 23:26:28.323	error	Error: Socket closed before the connection was established at new NodeError (node:internal/errors:399:5) at Socket.onClose (node:net:911:10) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:525:35) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:322:12)
          yeelight-2.0
          2023-04-03 23:26:28.322	error	unhandled promise rejection: Socket closed before the connection was established
          yeelight-2.0
          2023-04-03 23:26:28.322	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          yeelight-2.0
          2023-04-03 23:26:28.315	debug	ERROR YEELIGHT CONNECTION: 0x000000000000000: Connection 192.168.3.140:55443: Error: connect EHOSTUNREACH 192.168.3.140:55443
          yeelight-2.0
          2023-04-03 23:26:26.545	debug	DEVICE FOUND IN AND CONFIG: {"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}
          yeelight-2.0
          2023-04-03 23:26:26.542	debug	INITINAL ID FOUND FOR: color-0x0000000005ed0835
          yeelight-2.0
          2023-04-03 23:26:26.542	debug	RESPONSE MESSAGE: from: 0x0000000005ed0835, id: 1, result:[off,23,16711680,2,3000,,,0,100,0,,,,,,,,]}
          yeelight-2.0
          2023-04-03 23:26:25.547	debug	YEELIGHT FOUND: 192.168.3.141:55443 id: 0x0000000005ed0835 model: color
          yeelight-2.0
          2023-04-03 23:26:25.254	debug	YEELIGHT FOUND: 192.168.3.140:55443 id: 0x000000000000000 model: color
          yeelight-2.0
          2023-04-03 23:26:25.238	debug	SMARTNAME:
          yeelight-2.0
          2023-04-03 23:26:25.236	debug	OLD CONF. FROM OBJ: {"name":"Stehlampe_Schlafzimmer_groß","ip":"192.168.3.140","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
          yeelight-2.0
          2023-04-03 23:26:25.229	debug	OBJ_ELEMENT: yeelight-2.0.Stehlampe_Schlafzimmer_groß
          yeelight-2.0
          2023-04-03 23:26:25.228	debug	SMARTNAME:
          yeelight-2.0
          2023-04-03 23:26:25.226	debug	OLD CONF. FROM OBJ: {"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}
          yeelight-2.0
          2023-04-03 23:26:25.213	debug	OBJ_ELEMENT: yeelight-2.0.Stehlampe_Schlafzimmer_klein
          yeelight-2.0
          2023-04-03 23:26:25.212	debug	DEVICES IN OBJECTS FOUND: 2
          yeelight-2.0
          2023-04-03 23:26:25.211	debug	DEVICES IN OBJECTS: {"yeelight-2.0.Stehlampe_Schlafzimmer_klein":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"Stehlampe_Schlafzimmer_klein","type":"color"},"from":"system.adapter.yeelight-2.0","user":"system.user.admin","ts":1680464629168,"_id":"yeelight-2.0.Stehlampe_Schlafzimmer_klein","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}},"yeelight-2.0.Stehlampe_Schlafzimmer_groß":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"Stehlampe_Schlafzimmer_groß","type":"color"},"from":"system.adapter.yeelight-2.0","user":"system.user.admin","ts":1680464629164,"_id":"yeelight-2.0.Stehlampe_Schlafzimmer_groß","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}}
          yeelight-2.0
          2023-04-03 23:26:25.181	debug	DEVICES IN CONFIG: [{"name":"Stehlampe_Schlafzimmer_groß","ip":"192.168.3.140","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]},{"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}]
          yeelight-2.0
          2023-04-03 23:26:25.142	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230403-fd495c2e
          yeelight-2.0
          2023-04-03 23:26:24.734	debug	Plugin sentry Initialize Plugin (enabled=true)
          yeelight-2.0
          2023-04-03 23:26:24.629	debug	States connected to redis: 192.168.3.104:6379
          yeelight-2.0
          2023-04-03 23:26:24.617	debug	States create User PubSub Client
          yeelight-2.0
          2023-04-03 23:26:24.615	debug	States create System PubSub Client
          yeelight-2.0
          2023-04-03 23:26:24.608	debug	Redis States: Use Redis connection: 192.168.3.104:6379
          yeelight-2.0
          2023-04-03 23:26:24.587	debug	Objects connected to redis: 192.168.3.104:6379
          yeelight-2.0
          2023-04-03 23:26:24.579	debug	Objects client initialize lua scripts
          yeelight-2.0
          2023-04-03 23:26:23.863	debug	Objects create User PubSub Client
          yeelight-2.0
          2023-04-03 23:26:23.861	debug	Objects create System PubSub Client
          yeelight-2.0
          2023-04-03 23:26:23.856	debug	Objects client ready ... initialize now
          yeelight-2.0
          2023-04-03 23:26:23.793	debug	Redis Objects: Use Redis connection: 192.168.3.104:6379
          host.ioBroker-Rock
          2023-04-03 23:26:21.996	info	instance system.adapter.yeelight-2.0 started with pid 34705
          host.ioBroker-Rock
          2023-04-03 23:26:21.680	info	"system.adapter.yeelight-2.0" enabled
          host.ioBroker-Rock
          2023-04-03 23:26:10.184	info	"system.adapter.yeelight-2.0" disabled
          • E e-i-k-e
            @apollon77
            Gerne.
            host.ioBroker-Rock
            host.ioBroker-Rock
            host.ioBroker-Rock
            host.ioBroker-Rock
            host.ioBroker-Rock
            host.ioBroker-Rock
            host.ioBroker-Rock
            host.ioBroker-Rock
            host.ioBroker-Rock
            host.ioBroker-Rock
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            mqtt.0
            mqtt.0
            host.ioBroker-Rock
            influxdb.0
            host.ioBroker-Rock
            host.ioBroker-Rock
            host.ioBroker-Rock
            host.ioBroker-Rock
            host.ioBroker-Rock
            host.ioBroker-Rock
            host.ioBroker-Rock
            host.ioBroker-Rock
            host.ioBroker-Rock
            host.ioBroker-Rock
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            yeelight-2.0
            host.ioBroker-Rock
            host.ioBroker-Rock
            host.ioBroker-Rock
            @e-i-k-e sagte in Alpha Test js-controller 5.0:
            Also mal abgesehen vom crash tippe ich das eher das dein issue ist ... EHOSTUNREACH heisst das das gerät im Netzwerk nicht da ist ... Ich denke er adapter code schliesst darauf hin das socket was aber nie offen war wegen dem Fehler. Bitte adapter issue anlegen das man das dort fixt ... und schau warum das Geröt nicht online ist
            • apollon77A Offline
              Alpha Update
              5.0.1-alpha.0-20230406-4552d569
              • Fixes compact mode
              • Hide warning about "www folder not found" for widgets adapters
              Wenn alles so stabil bleibt würde wir überlegen Mitte nächste Woche in den Beta Test im Latest Repo zu gehen ...
              GaspodeG Thomas BraunT FeuersturmF 3 Antworten Letzte Antwort
                Alpha Update
                GaspodeG Offline
                GaspodeG Offline
                Gaspode
                @apollon77
                Keine Auffälligkeiten. Den Compact Mode nutze ich normalerweise nicht. Hab ihn jetzt mal testweise nach langer Suche :) eingeschaltet (Windows) und merke keinen Unterschied zu vorher. Ist wahrscheinlich gut so, aber kann ich irgendwie kontrollieren, dass er auch wirklich aktiv ist? Hinter jeder Instanz wird jedenfalls noch unterschiedliche RAM Nutzung angezeigt.
                @apollon77 said in Alpha Test js-controller 5.0:
                Dazu kann ich nix sagen, kenne die Warning nicht.
                  Alpha Update
                  @apollon77
                  So auf den ersten Blick läuft das rund hier. Das Log ist ruhig, ich verwende allerdings auch den CompactMode nicht.
                  • GaspodeG Gaspode
                    @apollon77
                    @gaspode Compat einschalten macht erstmal nichts. Du musst jetzt Instanzen sagen das sie in compact laufen sollen und eine gruppe angeben (0 ist "Mit controller", 1....n ist eigene Gruppen, je gruppe gibts einen prozess). das geht via admin bei den instanzen. ggf expertenmodus. Dann sollte ram nutzung weg sein bei den instanzen.
                    GaspodeG ? 2 Antworten Letzte Antwort
                      GaspodeG Offline
                      GaspodeG Offline
                      Gaspode
                      Ah, OK. Danke. Wieder was gelernt. Hab jetzt alle Instanzen in die Controller Gruppe gepackt. Sehe keine Auffälligkeiten.
                        @apollon77
                        Habe hier 71 Adapter laufen, nur der fitbit-fitness zickt rum:
                        2023-04-06 10:52:54.815  - info: host.iobrokerS2 instance system.adapter.fitbit-fitness.0 started with pid 13160
                        2023-04-06 10:52:55.535  - debug: fitbit-fitness.0 (13160) Redis Objects: Use Redis connection: 10.1.1.1:6379
                        2023-04-06 10:52:55.555  - debug: fitbit-fitness.0 (13160) Objects client ready ... initialize now
                        2023-04-06 10:52:55.556  - debug: fitbit-fitness.0 (13160) Objects create System PubSub Client
                        2023-04-06 10:52:55.557  - debug: fitbit-fitness.0 (13160) Objects create User PubSub Client
                        2023-04-06 10:52:56.062  - debug: fitbit-fitness.0 (13160) Objects client initialize lua scripts
                        2023-04-06 10:52:56.066  - debug: fitbit-fitness.0 (13160) Objects connected to redis: 10.1.1.1:6379
                        2023-04-06 10:52:56.089  - debug: fitbit-fitness.0 (13160) Redis States: Use Redis connection: 10.1.1.1:6379
                        2023-04-06 10:52:56.096  - debug: fitbit-fitness.0 (13160) States create System PubSub Client
                        2023-04-06 10:52:56.097  - debug: fitbit-fitness.0 (13160) States create User PubSub Client
                        2023-04-06 10:52:56.103  - debug: fitbit-fitness.0 (13160) States connected to redis: 10.1.1.1:6379
                        2023-04-06 10:52:58.489  - info: fitbit-fitness.0 (13160) starting. Version 0.4.10 (non-npm: Chris-656/ioBroker.fitbit-fitness) in /opt/iobroker/node_modules/iobroker.fitbit-fitness, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230406-4552d569
                        2023-04-06 10:52:58.550  - debug: fitbit-fitness.0 (13160) Getting refresh Token: c817bd62dd39ec8ed529fc0d16396a1xxxxxxxx
                        2023-04-06 10:52:58.803  - info: fitbit-fitness.0 (13160) User logged in B...l id:xxxx8
                        2023-04-06 10:52:58.808  - debug: fitbit-fitness.0 (13160) Tokens checked
                        2023-04-06 10:52:59.041  - info: fitbit-fitness.0 (13160) Activity Records: Steps:0 Floors:undefined Calories:1884
                        2023-04-06 10:52:59.047  - error: fitbit-fitness.0 (13160) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2023-04-06 10:52:59.047  - error: fitbit-fitness.0 (13160) unhandled promise rejection: undefined is not a valid state value
                        2023-04-06 10:52:59.049  - error: fitbit-fitness.0 (13160) Error: undefined is not a valid state value
                           at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17)
                           at FitBit._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5332:49)
                           at FitBit.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5293:21)
                           at FitBit.setActivityStates (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:321:9)
                           at FitBit.getActivityRecords (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:305:15)
                           at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                           at async FitBit.getFitbitRecords (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:87:5)
                        2023-04-06 10:52:59.049  - error: fitbit-fitness.0 (13160) undefined is not a valid state value
                        2023-04-06 10:52:59.057  - info: fitbit-fitness.0 (13160) terminating
                        2023-04-06 10:52:59.058  - warn: fitbit-fitness.0 (13160) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2023-04-06 10:52:59.277  - info: fitbit-fitness.0 (13160) Body records: Weight:10.5 Fat:11.342750549316406 BMI:20.1
                        2023-04-06 10:52:59.559  - info: fitbit-fitness.0 (13160) terminating
                        2023-04-06 10:52:59.612  - error: host.iobrokerS2 instance system.adapter.fitbit-fitness.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        hab n Issue beim Adapter angelegt:
                        Issue
                        Daten zum System(iob diag):
                        Skript v.2023-04-02
                        *** BASE SYSTEM ***
                        Architecture : x86_64
                        Docker : false
                        Virtualization : kvm
                        Distributor ID: Debian
                        Description: Debian GNU/Linux 11 (bullseye)
                        Release: 11
                        Codename: bullseye
                        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                        NAME="Debian GNU/Linux"
                        VERSION_ID="11"
                        VERSION="11 (bullseye)"
                        VERSION_CODENAME=bullseye
                        ID=debian
                        HOME_URL="https://www.debian.org/"
                        SUPPORT_URL="https://www.debian.org/support"
                        BUG_REPORT_URL="https://bugs.debian.org/"
                        Systemuptime and Load:
                        11:09:32 up 38 min, 1 user, load average: 1.21, 1.27, 1.24
                        CPU threads: 8
                        *** Time and Time Zones ***
                        Local time: Thu 2023-04-06 11:09:33 CEST
                        Universal time: Thu 2023-04-06 09:09:33 UTC
                        RTC time: Thu 2023-04-06 09:09:33
                        NTP service: n/a
                        RTC in local TZ: no
                        *** User and Groups ***
                        ilovegym
                        /home/ilovegym
                        ilovegym tty cdrom floppy audio dip video plugdev netdev iobroker
                        *** X-Server-Setup ***
                        X-Server: false
                        Desktop:
                        Terminal: tty
                        Boot Target: graphical.target
                        *** MEMORY ***
                        total used free shared buff/cache available
                        Mem: 16G 5.5G 9.6G 0.0K 886M 10G
                        Swap: 974M 0B 974M
                        Total: 16G 5.5G 10G
                            16007 M total memory
                             5518 M used memory
                              384 M active memory
                             5558 M inactive memory
                             9602 M free memory
                               98 M buffer memory
                              788 M swap cache
                              974 M total swap
                                0 M used swap
                              974 M free swap
                        *** FILESYSTEM ***
                        Filesystem Type Size Used Avail Use% Mounted on
                        udev devtmpfs 7.8G 0 7.8G 0% /dev
                        tmpfs tmpfs 1.6G 492K 1.6G 1% /run
                        /dev/sda1 ext4 8.9G 5.6G 2.8G 67% /
                        tmpfs tmpfs 7.9G 0 7.9G 0% /dev/shm
                        tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock
                        //10.10.2.10/photo cifs 11T 7.4T 3.1T 71% /mnt/photo
                        //10.10.2.10/daten cifs 11T 7.4T 3.1T 71% /mnt/daten
                        tmpfs tmpfs 1.6G 0 1.6G 0% /run/user/1000
                        [Thu Apr 6 10:30:48 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                        [Thu Apr 6 10:30:53 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                        TARGET SOURCE FSTYPE OPTIONS
                        / /dev/sda1 ext4 rw,relatime,errors=remount-ro
                        |-/mnt/photo //10.10.2.10/photo cifs rw,relatime,vers=3.1.1,cache=strict,username=ilovegym,uid=0,noforceuid,gid=0,noforcegid,addr=10.10.2.10,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
                        `-/mnt/daten //10.10.2.10/daten cifs rw,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=10.10.2.10,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
                        /var:
                        760M /var/
                        349M /var/log
                        273M /var/log/journal/fa9fb9e36d4942faa246786f755447be
                        259M /var/cache
                        /opt/iobroker/backups:
                        4.0K /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        151M /opt/iobroker/iobroker-data/
                        28M /opt/iobroker/iobroker-data/files
                        13M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                        93M /opt/iobroker/iobroker-data/objects.jsonl
                        29M /opt/iobroker/iobroker-data/states.jsonl
                        6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                        2.8M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                        1.6M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs v18.15.0
                        /usr/bin/node v18.15.0
                        /usr/bin/npm 9.5.0
                        /usr/bin/npx 9.5.0
                        nodejs:
                        Installed: 18.15.0-deb-1nodesource1
                        Candidate: 18.15.0-deb-1nodesource1
                        Version table:
                        *** 18.15.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                        12.22.12~dfsg-1~deb11u3 500
                        500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                        12.22.5~dfsg-2~11u1 500
                        500 http://deb.debian.org/debian bullseye/main amd64 Packages
                        No problems detected
                        *** ioBroker-Installation ***
                        ioBroker Status
                        At least one iobroker host is running.
                        Objects type: redis
                        States type: redis
                        Core adapters versions
                        admin: 6.4.3
                        javascript: 7.0.3
                        Adapters from github: 21
                        Adapter State
                        • system.adapter.admin.0 : admin : iobrokerS2 - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        • system.adapter.alarm.0 : alarm : iobrokerS2 - enabled
                        • system.adapter.alexa-shoppinglist.0 : alexa-shoppinglist : iobrokerS2 - enabled
                        • system.adapter.alexa-timer-vis.0 : alexa-timer-vis : iobrokerS2 - enabled
                        • system.adapter.alexa2.0 : alexa2 : iobrokerS2 - enabled
                        • system.adapter.backitup.0 : backitup : iobrokerS2 - enabled
                        • system.adapter.bluelink.0 : bluelink : iobrokerS2 - enabled
                        • system.adapter.cloud.0 : cloud : iobrokerS2 - enabled
                        • system.adapter.countdown.0 : countdown : iobrokerS2 - enabled
                        • system.adapter.device-watcher.0 : device-watcher : iobrokerS2 - enabled
                          system.adapter.devices.0 : devices : iobrokerS2 - disabled
                        • system.adapter.deyeidc.0 : deyeidc : iobrokerS2 - enabled, port: 8899
                        • system.adapter.deyeidc.1 : deyeidc : iobrokerS2 - enabled, port: 8899
                        • system.adapter.discovery.0 : discovery : iobrokerS2 - enabled
                        • system.adapter.drops-weather.0 : drops-weather : iobrokerS2 - enabled
                          system.adapter.dwd.0 : dwd : iobrokerS2 - enabled
                        • system.adapter.email.0 : email : iobrokerS2 - enabled
                        • system.adapter.energiefluss.0 : energiefluss : iobrokerS2 - enabled
                        • system.adapter.energiefluss.1 : energiefluss : iobrokerS2 - enabled
                          system.adapter.feiertage.0 : feiertage : iobrokerS2 - enabled
                          system.adapter.fitbit-fitness.0 : fitbit-fitness : iobrokerS2 - disabled
                          system.adapter.flot.0 : flot : iobrokerS2 - disabled
                        • system.adapter.fritzdect.0 : fritzdect : iobrokerS2 - enabled
                        • system.adapter.fully-mqtt.0 : fully-mqtt : iobrokerS2 - enabled
                        • system.adapter.go-e.0 : go-e : iobrokerS2 - enabled
                        • system.adapter.govee-app.0 : govee-app : iobrokerS2 - enabled
                        • system.adapter.heizoel.0 : heizoel : iobrokerS2 - enabled
                          system.adapter.ical.0 : ical : iobrokerS2 - enabled
                          system.adapter.iceroad.0 : iceroad : iobrokerS2 - enabled
                        • system.adapter.influxdb.0 : influxdb : iobrokerS2 - enabled, port: 8086
                        • system.adapter.influxdb.1 : influxdb : iobrokerS2 - enabled, port: 8086
                        • system.adapter.influxdb.2 : influxdb : iobrokerS2 - enabled, port: 8086
                        • system.adapter.iot.0 : iot : iobrokerS2 - enabled
                        • system.adapter.javascript.0 : javascript : iobrokerS2 - enabled
                        • system.adapter.lgtv.0 : lgtv : iobrokerS2 - enabled
                        • system.adapter.lgtv.1 : lgtv : iobrokerS2 - enabled
                        • system.adapter.lightcontrol.0 : lightcontrol : iobrokerS2 - enabled
                        • system.adapter.lightcontrol.1 : lightcontrol : iobrokerS2 - enabled
                        • system.adapter.linux-control.0 : linux-control : iobrokerS2 - enabled
                        • system.adapter.lovelace.0 : lovelace : iobrokerS2 - enabled, port: 8091, bind: 0.0.0.0, run as: admin
                          system.adapter.meteoalarm.0 : meteoalarm : iobrokerS2 - enabled
                        • system.adapter.mihome-vacuum.0 : mihome-vacuum : iobrokerS2 - enabled, port: 54321
                        • system.adapter.mihome-vacuum.1 : mihome-vacuum : iobrokerS2 - enabled, port: 54321
                        • system.adapter.mihome-vacuum.2 : mihome-vacuum : iobrokerS2 - enabled, port: 54321
                        • system.adapter.mihome-vacuum.3 : mihome-vacuum : iobrokerS2 - enabled, port: 54321
                        • system.adapter.minuaru.0 : minuaru : iobrokerS2 - enabled
                          system.adapter.minuvis.0 : minuvis : iobrokerS2 - disabled
                        • system.adapter.mqtt.0 : mqtt : iobrokerS2 - enabled, port: 1886, bind: 0.0.0.0
                        • system.adapter.mqtt.1 : mqtt : iobrokerS2 - enabled, port: 1884, bind: 0.0.0.0
                        • system.adapter.nut.0 : nut : iobrokerS2 - enabled
                        • system.adapter.octoprint.0 : octoprint : iobrokerS2 - enabled
                          system.adapter.odl.0 : odl : iobrokerS2 - enabled
                          system.adapter.oilfox.0 : oilfox : iobrokerS2 - enabled
                        • system.adapter.openligadb.0 : openligadb : iobrokerS2 - enabled
                          system.adapter.openweathermap.0 : openweathermap : iobrokerS2 - enabled
                        • system.adapter.operating-hours.0 : operating-hours : iobrokerS2 - enabled
                        • system.adapter.ping.0 : ping : iobrokerS2 - enabled
                        • system.adapter.pioneer_sc_vsx.0 : pioneer_sc_vsx : iobrokerS2 - enabled, port: 8102
                        • system.adapter.pollenflug.0 : pollenflug : iobrokerS2 - enabled
                        • system.adapter.puppeteer.0 : puppeteer : iobrokerS2 - enabled
                        • system.adapter.rest-api.0 : rest-api : iobrokerS2 - enabled, port: 8880, bind: 0.0.0.0, run as: restapi
                        • system.adapter.simple-api.0 : simple-api : iobrokerS2 - enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        • system.adapter.snmp.0 : snmp : iobrokerS2 - enabled
                          system.adapter.solarmanpv.0 : solarmanpv : iobrokerS2 - enabled
                        • system.adapter.sonoff.0 : sonoff : iobrokerS2 - enabled, port: 1883, bind: 0.0.0.0
                        • system.adapter.synochat.0 : synochat : iobrokerS2 - enabled
                        • system.adapter.synology.0 : synology : iobrokerS2 - enabled, port: 5001
                        • system.adapter.synology.1 : synology : iobrokerS2 - enabled, port: 5000
                        • system.adapter.text2command.0 : text2command : iobrokerS2 - enabled
                        • system.adapter.tr-064.0 : tr-064 : iobrokerS2 - enabled
                        • system.adapter.tr-064.1 : tr-064 : iobrokerS2 - enabled
                        • system.adapter.trashschedule.0 : trashschedule : iobrokerS2 - enabled
                        • system.adapter.tuya.0 : tuya : iobrokerS2 - enabled
                        • system.adapter.unifi.0 : unifi : iobrokerS2 - enabled
                        • system.adapter.viessmannapi.0 : viessmannapi : iobrokerS2 - enabled
                          system.adapter.vis.0 : vis : iobrokerS2 - enabled
                          system.adapter.weatherunderground.0 : weatherunderground : iobrokerS2 - enabled
                        • system.adapter.web.0 : web : iobrokerS2 - enabled, port: 81, bind: 0.0.0.0, run as: admin
                        • system.adapter.wifilight.0 : wifilight : iobrokerS2 - enabled
                        • system.adapter.windows-control.0 : windows-control : iobrokerS2 - enabled
                        • system.adapter.wireguard.0 : wireguard : iobrokerS2 - enabled
                        • system.adapter.wled.0 : wled : iobrokerS2 - enabled
                        • system.adapter.worx.0 : worx : iobrokerS2 - enabled
                        • system.adapter.yahka.0 : yahka : iobrokerS2 - enabled
                        • system.adapter.yeelight-2.0 : yeelight-2 : iobrokerS2 - enabled
                        • system.adapter.zigbee.0 : zigbee : iobrokerS2 - enabled, port: tcp://10.1.1.98:20108
                        • instance is alive
                        ioBroker-Repositories
                        stable : http://download.iobroker.net/sources-dist.json
                        beta : http://download.iobroker.net/sources-dist-latest.json
                        Active repo(s): beta
                        Installed ioBroker-Instances
                        Used repository: beta
                        Adapter "admin" : 6.4.3 , installed 6.4.3
                        Adapter "alarm" : 3.3.10 , installed 3.3.10
                        Adapter "alexa-shoppinglist": 0.1.5, installed 0.1.5
                        Adapter "alexa-timer-vis": 0.1.14 , installed 0.1.14
                        Adapter "alexa2" : 3.23.2 , installed 3.23.2
                        Adapter "backitup" : 2.6.16 , installed 2.6.16
                        Adapter "bluelink" : 2.2.6 , installed 2.2.8
                        Adapter "cloud" : 4.4.0 , installed 4.4.0
                        Adapter "countdown" : 1.3.0 , installed 1.3.0
                        Adapter "device-watcher": 2.8.0 , installed 2.8.0
                        Adapter "devices" : 1.1.2 , installed 1.1.2
                        Adapter "discovery" : 3.1.0 , installed 3.1.0
                        Adapter "dwd" : 2.8.3 , installed 2.8.3
                        Adapter "email" : 1.1.4 , installed 1.1.4
                        Adapter "feiertage" : 1.1.0 , installed 1.1.0
                        Adapter "fitbit-fitness": 0.4.10 , installed 0.4.10
                        Adapter "flot" : 1.12.0 , installed 1.12.0
                        Adapter "fritzdect" : 2.3.1 , installed 2.3.1
                        Adapter "go-e" : 1.0.27 , installed 1.0.26 [Updatable]
                        Adapter "heizoel" : 1.0.3 , installed 1.0.3
                        Adapter "ical" : 1.13.2 , installed 1.13.2
                        Adapter "iceroad" : 1.2.0 , installed 1.2.0
                        Adapter "influxdb" : 3.2.0 , installed 3.2.0
                        Adapter "iot" : 1.14.5 , installed 1.14.5
                        Adapter "javascript" : 7.0.3 , installed 7.0.3
                        Controller "js-controller": 4.0.24 , installed 5.0.1
                        Adapter "lgtv" : 1.1.10 , installed 1.1.10
                        Adapter "lightcontrol" : 0.2.1 , installed 0.2.1
                        Adapter "linux-control": 1.1.5 , installed 1.1.5
                        Adapter "lovelace" : 3.0.1 , installed 3.0.1
                        Adapter "meteoalarm" : 2.3.5 , installed 2.3.5
                        Adapter "mihome-vacuum": 3.9.5 , installed 3.9.5
                        Adapter "minuvis" : 2.3.3 , installed 2.3.3
                        Adapter "mqtt" : 4.1.1 , installed 4.1.1
                        Adapter "nut" : 1.6.0 , installed 1.6.0
                        Adapter "octoprint" : 4.1.0 , installed 4.1.0
                        Adapter "odl" : 2.0.5 , installed 2.0.5
                        Adapter "oilfox" : 4.1.2 , installed 4.1.2
                        Adapter "openligadb" : 1.2.4 , installed 1.2.4
                        Adapter "openweathermap": 0.3.8 , installed 0.3.8
                        Adapter "operating-hours": 1.0.0 , installed 1.0.0
                        Adapter "ping" : 1.5.3 , installed 1.5.3
                        Adapter "pollenflug" : 1.0.6 , installed 1.0.6
                        Adapter "puppeteer" : 0.2.7 , installed 0.2.7
                        Adapter "rest-api" : 1.0.5 , installed 1.0.5
                        Adapter "simple-api" : 2.7.2 , installed 2.7.2
                        Adapter "snmp" : 2.4.6 , installed 2.4.6
                        Adapter "socketio" : 6.3.5 , installed 6.3.5
                        Adapter "solarmanpv" : 0.3.2 , installed 0.3.2
                        Adapter "sonoff" : 2.5.3 , installed 2.5.3
                        Adapter "synochat" : 1.2.1 , installed 1.2.1
                        Adapter "synology" : 2.1.13 , installed 2.1.13
                        Adapter "text2command" : 3.0.2 , installed 3.0.2
                        Adapter "tr-064" : 4.2.18 , installed 4.2.18
                        Adapter "trashschedule": 2.2.0 , installed 2.2.0
                        Adapter "tuya" : 3.14.2 , installed 3.14.2
                        Adapter "unifi" : 0.6.4 , installed 0.6.4
                        Adapter "viessmannapi" : 2.0.9 , installed 2.0.9
                        Adapter "vis" : 1.4.16 , installed 1.4.16
                        Adapter "weatherunderground": 3.4.2, installed 3.4.2
                        Adapter "web" : 5.5.3 , installed 5.5.3
                        Adapter "wifilight" : 1.1.4 , installed 1.1.4
                        Adapter "windows-control": 0.1.5 , installed 0.1.5
                        Adapter "wireguard" : 1.4.1 , installed 1.4.1
                        Adapter "wled" : 0.6.7 , installed 0.6.7
                        Adapter "worx" : 2.0.3 , installed 2.0.3
                        Adapter "ws" : 2.3.6 , installed 2.3.6
                        Adapter "yahka" : 1.0.3 , installed 1.0.3
                        Adapter "yeelight-2" : 1.2.1 , installed 1.2.1
                        Adapter "zigbee" : 1.8.10 , installed 1.8.11
                        Objects and States
                        Objects: 101001
                        States: 83854
                        Hit:1 http://deb.debian.org/debian bullseye InRelease
                        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                        Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
                        tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 15385 1/init
                        tcp 0 0 127.0.0.1:44467 0.0.0.0:* LISTEN 1001 43357 9753/chrome
                        tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 14536 523/sshd: /usr/sbin
                        tcp 0 0 127.0.0.1:6010 0.0.0.0:* LISTEN 1000 10636 597/sshd: ilovegym@
                        tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 32668 7176/io.sonoff.0
                        tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 31568 7623/io.mqtt.1
                        tcp 0 0 0.0.0.0:1886 0.0.0.0:* LISTEN 1001 33588 7529/io.mqtt.0
                        tcp6 0 0 :::44783 :::* LISTEN 1001 42537 8491/io.yahka.0
                        tcp6 0 0 :::111 :::* LISTEN 0 17436 1/init
                        tcp6 0 0 :::8880 :::* LISTEN 1001 40249 8662/io.rest-api.0
                        tcp6 0 0 :::81 :::* LISTEN 1001 37769 9131/io.web.0
                        tcp6 0 0 :::8081 :::* LISTEN 1001 36296 6749/io.admin.0
                        tcp6 0 0 :::22 :::* LISTEN 0 14538 523/sshd: /usr/sbin
                        tcp6 0 0 :::8087 :::* LISTEN 1001 46575 10220/io.simple-api
                        tcp6 0 0 ::1:6010 :::* LISTEN 1000 10635 597/sshd: ilovegym@
                        tcp6 0 0 :::8091 :::* LISTEN 1001 37748 8954/io.lovelace.0
                        tcp6 0 0 :::1888 :::* LISTEN 1001 51609 12074/io.fully-mqtt
                        udp 0 0 0.0.0.0:68 0.0.0.0:* 0 15469 387/dhclient
                        udp 0 0 0.0.0.0:111 0.0.0.0:* 0 17433 1/init
                        udp 0 0 10.1.1.2:123 0.0.0.0:* 0 9840 509/ntpd
                        udp 0 0 127.0.0.1:123 0.0.0.0:* 0 9838 509/ntpd
                        udp 0 0 0.0.0.0:123 0.0.0.0:* 0 9834 509/ntpd
                        udp 0 0 0.0.0.0:41823 0.0.0.0:* 110 10608 489/avahi-daemon: r
                        udp 0 0 0.0.0.0:34368 0.0.0.0:* 1001 42324 8208/io.snmp.0
                        udp 0 0 0.0.0.0:53421 0.0.0.0:* 1001 34730 7059/io.mihome-vacu
                        udp 0 0 0.0.0.0:54322 0.0.0.0:* 1001 46892 10637/io.mihome-vac
                        udp 0 0 0.0.0.0:54323 0.0.0.0:* 1001 32598 7020/io.mihome-vacu
                        udp 0 0 0.0.0.0:54324 0.0.0.0:* 1001 51230 10678/io.mihome-vac
                        udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 46434 10133/io.wled.0
                        udp 0 0 10.1.1.2:5353 0.0.0.0:* 1001 38275 7909/io.tr-064.0
                        udp 0 0 0.0.0.0:5353 0.0.0.0:* 110 10606 489/avahi-daemon: r
                        udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 37294 7833/io.tuya.0
                        udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 37295 7833/io.tuya.0
                        udp6 0 0 :::111 :::* 0 17439 1/init
                        udp6 0 0 fe80::11:32ff:fe28::123 :::* 106 9986 509/ntpd
                        udp6 0 0 ::1:123 :::* 0 9842 509/ntpd
                        udp6 0 0 :::123 :::* 0 9831 509/ntpd
                        udp6 0 0 :::5353 :::* 110 10607 489/avahi-daemon: r
                        udp6 0 0 :::38898 :::* 110 10609 489/avahi-daemon: r
                        2023-04-06 11:10:08.921 - info: web.0 (9131) ==> Connected system.user.admin from ::ffff:10.1.1.60
                        2023-04-06 11:10:10.219 - warn: sonoff.0 (7176) Client "Stecker7" not connected
                        2023-04-06 11:10:11.100 - info: meteoalarm.0 (20420) starting. Version 2.3.5 (non-npm: jack-blackson/ioBroker.meteoalarm) in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230406-4552d569
                        2023-04-06 11:10:12.555 - info: meteoalarm.0 (20420) 15.1: Updated Weather Alarms for Kreis Darmstadt-Dieburg und Stadt Darmstadt -> 0 alarm(s) found
                        2023-04-06 11:10:12.556 - warn: meteoalarm.0 (20420) Terminated (ADAPTER_REQUESTED_TERMINATION): All data processed. Adapter stopped until next scheduled process.
                        2023-04-06 11:10:13.080 - info: host.iobrokerS2 instance system.adapter.meteoalarm.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2023-04-06 11:10:15.813 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KI: MQTT connected
                        2023-04-06 11:10:16.138 - info: solarmanpv.0 (20379) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                        2023-04-06 11:10:16.653 - info: host.iobrokerS2 instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2023-04-06 11:10:17.236 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KA: MQTT connected
                        2023-04-06 11:10:20.096 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KI: Nuki start pairing
                        2023-04-06 11:10:20.098 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KI: Nuki paired
                        2023-04-06 11:10:20.810 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KA: Nuki start pairing
                        2023-04-06 11:10:20.811 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KA: Nuki paired
                        2023-04-06 11:10:23.579 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KI: Querying lock state: locked
                        2023-04-06 11:10:23.679 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KI: Querying lock battery state: success
                        2023-04-06 11:10:23.897 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KI: Reading config. Result: success
                        2023-04-06 11:10:23.897 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KI: Reading advanced config. Result: success
                        2023-04-06 11:10:24.088 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KA: Querying lock state: locked
                        2023-04-06 11:10:24.200 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KA: Querying lock battery state: success
                        2023-04-06 11:10:24.494 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KA: Reading config. Result: success
                        2023-04-06 11:10:24.597 - info: javascript.0 (6930) script.js.common.Nuki.mqtt2log: NUKI Hub KA: Reading advanced config. Result: success
                        2023-04-06 11:10:25.923 - info: web.0 (9131) <== Disconnect system.user.admin from ::ffff:10.1.1.60
                        2023-04-06 11:10:29.145 - info: web.0 (9131) ==> Connected system.user.admin from ::ffff:10.1.1.60
                        2023-04-06 11:10:29.146 - info: web.0 (9131) ==> Connected system.user.admin from ::ffff:10.1.1.60
                          @apollon77
                          Issue
                          Skript v.2023-04-02
                          *** BASE SYSTEM ***
                          Docker : false
                          Release: 11
                          Codename: bullseye
                          VERSION_ID="11"
                          ID=debian
                          CPU threads: 8
                          NTP service: n/a
                          RTC in local TZ: no
                          ilovegym
                          /home/ilovegym
                          X-Server: false
                          Desktop:
                          Terminal: tty
                          *** MEMORY ***
                          Swap: 974M 0B 974M
                          Total: 16G 5.5G 10G
                               5518 M used memory
                                384 M active memory
                               9602 M free memory
                                 98 M buffer memory
                                788 M swap cache
                                974 M total swap
                                  0 M used swap
                                974 M free swap
                          *** FILESYSTEM ***
                          /var:
                          760M /var/
                          349M /var/log
                          259M /var/cache
                          /usr/bin/npm 9.5.0
                          /usr/bin/npx 9.5.0
                          nodejs:
                          Version table:
                          ioBroker Status
                          Objects type: redis
                          States type: redis
                          admin: 6.4.3
                          javascript: 7.0.3
                          Adapter State
                          • instance is alive
                          Objects and States
                          Objects: 101001
                          States: 83854
                          Pending Updates: 0
                          @ilovegym sagte in Alpha Test js-controller 5.0:
                          Jupp das ist genau richtig ... das sollte aber schon mit controller 4 gemeckert haben :-)
                            @apollon77
                            hmm mit Controller 4 hat er evtl gemeckert aber nicht den Adapter gestoppt.. hier stoppt er ihn und im Host-Tab wird eine 1 angezeigt und die Meldung, dass der fitbit-Adapter mehrmals mit Fehler gestartet wurde..
                            vorher lief er ohne mir aufzufallen.. und sonst ist am System nichts anders.. hab die VM geklont und nur den js-controller geupdatet...
                              @apollon77
                              @ilovegym Ok, dann haben wir vllt doch eine "lange zeit deprecation" jetzt härter ... Danke!
                                @apollon77 @simatec
                                Backitup-Adapter V2.6.16 zickt hier seltsam und steigt aus, weil er die Objects nicht sichern kann..?? hmm? das geht so mit anscheinend allem, was in vis, userdata etc gelagert ist.. ?
                                Datenbank ist redis/redis auf einer externen VM..
                                Ansonsten laeft alles unauffaellig...
                                [DEBUG] [iobroker] - Can not copy File vis/lib/js/moment-with-locales.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/moment-with-locales.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                Can not copy File vis/lib/js/quo.standalone.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/quo.standalone.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                  @apollon77 @simatec
                                  simatecS Online
                                  simatecS Online
                                  simatec
                                  @ilovegym Führe mal bitte das Backup über die CLI aus und poste mal die Ausgabe
                                  iob backup
                                  • Besuche meine Github Seite
                                  • HowTo Restore ioBroker
                                  • simatecS simatec
                                    iob backup
                                    @simatec
                                    das wird lang.. Moment.. er macht... musste kuerzen, waren mehr als 100000 Zeichen..
                                    ilovegym@iobrokerS2:/opt/iobroker$ iob backup
                                    host.iobrokerS2 84652 states saved
                                    Can not copy File 0_userdata.0/Icons/blaue_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/blaue_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/Icons/braune_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/braune_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/Icons/braune_tonne1.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/braune_tonne1.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/Icons/gelbe_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/gelbe_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/Icons/graue_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/graue_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/Icons/gruene_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/gruene_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/Icons/hellblaue_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/hellblaue_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_blau.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_blau.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_gelb.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_gelb.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_grau.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_grau.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_gruen.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_gruen.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/Icons/schwarze_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/schwarze_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/Icons/state_leerung blaue tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung blaue tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/Icons/state_leerung braune tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung braune tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/Icons/state_leerung gelbe tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung gelbe tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/Icons/state_leerung gruene tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung gruene tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/Icons/state_leerung schwarze tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung schwarze tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/Icons/undefined.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/undefined.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/htmlakku.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlakku.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/htmlbackitup.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlbackitup.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/htmldect2.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmldect2.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/htmlfussball1.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlfussball1.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/htmlfussball2.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlfussball2.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/htmltrash1.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmltrash1.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Alarmpanel.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Alarmpanel.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD10.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD10.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD8.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD8.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Frontdoor.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Frontdoor.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Guest.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Guest.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Home.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Home.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_HomeTV.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_HomeTV.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Mobile.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Mobile.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/AlarmpanelHD8.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/AlarmpanelHD8.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/Energy.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Energy.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/Home.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Home.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/HomeTV.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/HomeTV.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/Log.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Log.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/Mobile.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Mobile.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/OldMobile.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/OldMobile.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/TVOGB.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/TVOGB.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/Test.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Test.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/minukodu/Video.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Video.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/screenshots/bundesliga2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/screenshots/bundesliga2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File 0_userdata.0/synology/Doorbell.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/synology/Doorbell.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File lovelace.0/cards/background.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/lovelace.0/cards/background.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File mihome-vacuum.0.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.0.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File mihome-vacuum.1.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.1.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File mihome-vacuum.2.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.2.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File mihome-vacuum.3.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.3.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File synology.0/cover.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/cover.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File synology.0/snapshotCam_13.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_13.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File synology.0/snapshotCam_19.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_19.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File synology.0/snapshotCam_21.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_21.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File synology.0/snapshotCam_24.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_24.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File synology.0/snapshotCam_26.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_26.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File synology.0/snapshotCam_7.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_7.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File synology.1/cover.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.1/cover.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/cache.manifest to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/cache.manifest: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/cordova.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/cordova.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/css/add_kian.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/add_kian.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/css/app.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/app.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/css/backgrounds.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/backgrounds.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/css/doc.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/doc.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/css/montserrat-regular-webfont.woff to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/montserrat-regular-webfont.woff: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/css/styles.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/styles.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/css/vis-common-user.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/vis-common-user.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/css/vis-editor.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/vis-editor.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/css/vis.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/vis.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/edit.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/edit.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/edit.src.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/edit.src.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/add.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/add.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/align-height.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-height.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/align-horizontal-center-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-horizontal-center-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/align-horizontal-left.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-horizontal-left.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/align-horizontal-right-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-horizontal-right-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/align-vertical-bottom-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-vertical-bottom-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/align-vertical-center-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-vertical-center-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/align-vertical-top-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-vertical-top-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/align-width.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-width.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/bar.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/bar.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/cancel.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/cancel.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/checkbox.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/checkbox.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/container.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/container.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/control.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/control.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/copy.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/copy.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/delete.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/delete.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/dialog.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/dialog.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/distribute-horizontal-equal.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/distribute-horizontal-equal.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/distribute-vertical-equal.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/distribute-vertical-equal.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/door.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/door.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/filter.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/filter.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/groupFixed.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/groupFixed.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/groupVisibility.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/groupVisibility.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/info.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/info.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/lamp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/lamp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/lock.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/lock.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/lockIcon.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/lockIcon.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/navigation.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/navigation.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/ok.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/ok.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/refresh-4.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/refresh-4.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/rename.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/rename.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/rgb.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/rgb.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/shutter.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/shutter.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/state.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/state.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/stateful.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/stateful.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/static.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/static.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/table.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/table.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/temperature.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/temperature.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/timestamp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/timestamp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/tools.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/tools.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/value.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/value.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/icon/window.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/window.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/Heating.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/Heating.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/Lamp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/Lamp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/OutsideTemp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/OutsideTemp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/Window.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/Window.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/back/box-radial.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/back/box-radial.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/back/flowers.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/back/flowers.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/back/oblique-line-bk.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/back/oblique-line-bk.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/bg-dots-10.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-10.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/bg-dots-15.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-15.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/bg-dots-20.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-20.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/bg-dots-25.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-25.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/bg-dots-30.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-30.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/bg-dots-40.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-40.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/bg-dots-5.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-5.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/bg-dots-50.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-50.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/bulbOff.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulbOff.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/bulbOn.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulbOn.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/bulb_off.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulb_off.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/bulb_on.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulb_on.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/camera.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/camera.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/cc-nc-by.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/cc-nc-by.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/disconnect.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/disconnect.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/door-bell.mp3 to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/door-bell.mp3: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/editmode-pattern.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/editmode-pattern.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/eg_trans.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/eg_trans.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/favicon.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/favicon.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/faviconEdit.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/faviconEdit.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/garage-door-closed.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/garage-door-closed.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/garage-door-opened.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/garage-door-opened.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/gear-icon-md.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/gear-icon-md.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/hexabump.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/hexabump.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/kde_folder.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/kde_folder.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/no_filter.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/no_filter.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/sound.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/sound.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/tank.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/tank.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/vis.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/vis.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/img/zip.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/zip.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/index.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/index.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/index.src.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/index.src.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/app.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/app.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/config.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/config.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/conn.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/conn.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/connSignalR.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/connSignalR.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/fileManager.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/fileManager.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/fileManager.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/fileManager.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/actions/add.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/add.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/actions/back.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/back.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/actions/delete.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/delete.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/actions/down.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/down.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/actions/edit-rename.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/edit-rename.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/actions/folder-new-7.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/folder-new-7.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/actions/folder-new.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/folder-new.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/actions/icons.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/icons.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/actions/list.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/list.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/actions/play.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/play.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/actions/refresh.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/refresh.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/actions/stop.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/stop.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/actions/up.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/up.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/circleLeftIcon.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/circleLeftIcon.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/128/JS.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/JS.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/128/bmp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/bmp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/128/css.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/css.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/128/folder-blue.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/folder-blue.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/128/folder-brown.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/folder-brown.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/128/folder-green.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/folder-green.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/128/gif.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/gif.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/128/img2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/img2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/128/jpg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/jpg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/128/misc.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/misc.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/128/mp3.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/mp3.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/128/png.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/png.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/128/prg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/prg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/128/svg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/svg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/128/undef.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/undef.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/128/wav.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/wav.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/128/zip.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/zip.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/24/bmp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/bmp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/24/css.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/css.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/24/folder-blue.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/folder-blue.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/24/folder-brown.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/folder-brown.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/24/folder-green.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/folder-green.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/24/gif.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/gif.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/24/img2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/img2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/24/jpg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/jpg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/24/js.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/js.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/24/misc.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/misc.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/24/mp3.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/mp3.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/24/png.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/png.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/24/prg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/prg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/24/svg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/svg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/24/undef.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/undef.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/24/wav.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/wav.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/fm/icon/mine/24/zip.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/zip.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/vis.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/vis.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/visAbout.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visAbout.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/visEdit.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEdit.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/visEditExt.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditExt.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/visEditInspect.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditInspect.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/visEditTemplates.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditTemplates.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/visEditWelcome.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditWelcome.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/visUtils.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visUtils.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/visWizard.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visWizard.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/js/words.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/words.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/ace/ace.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/ace.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/ace/ext-language_tools.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/ext-language_tools.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/ace/ext-searchbox.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/ext-searchbox.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/ace/mode-css.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/mode-css.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/ace/mode-html.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/mode-html.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/ace/mode-javascript.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/mode-javascript.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/ace/worker-css.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/worker-css.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/ace/worker-html.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/worker-html.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/ace/worker-javascript.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/worker-javascript.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/css/add2home-2.0.8.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/add2home-2.0.8.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/css/fancytree/channel.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/channel.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/css/fancytree/device.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/device.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/css/fancytree/icons.gif to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/icons.gif: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/css/fancytree/loading.gif to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/loading.gif: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/css/fancytree/state.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/state.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/css/fancytree/ui.fancytree.jquery.min.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/ui.fancytree.jquery.min.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/css/fancytree/ui.fancytree.min.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/ui.fancytree.min.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/css/farbtastic.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/farbtastic.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/css/jquery-ui-timepicker-addon-1.6.3.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery-ui-timepicker-addon-1.6.3.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/css/jquery.jgrowl.min.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery.jgrowl.min.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/css/jquery.multiselect-1.13.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery.multiselect-1.13.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/css/jquery.multiselect.filter.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery.multiselect.filter.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/css/superfish/megafish.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/megafish.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/css/superfish/superfish-navbar.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/superfish-navbar.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/css/superfish/superfish-vertical.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/superfish-vertical.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/css/superfish/superfish.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/superfish.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/img/delete.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/delete.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/img/edit-undo-8.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/edit-undo-8.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/img/logout.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/logout.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/img/marker.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/marker.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/img/mask.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/mask.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/img/shape_align_bottom.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_bottom.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/img/shape_align_left.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_left.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/img/shape_align_right.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_right.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/img/shape_align_top.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_top.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/img/wheel.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/wheel.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/js/add2home-2.0.8.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/add2home-2.0.8.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/js/can.custom.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/can.custom.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/js/colResizable-1.5.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/colResizable-1.5.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/js/dropzone.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/dropzone.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/js/farbtastic.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/farbtastic.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/js/html2canvas.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/html2canvas.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/js/jquery-ui-1.10.3.dragdropsort.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery-ui-1.10.3.dragdropsort.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/js/jquery-ui-timepicker-addon-1.6.3.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery-ui-timepicker-addon-1.6.3.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/js/jquery.ba-resize.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.ba-resize.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/js/jquery.base64.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.base64.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/js/jquery.fancytree-all.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.fancytree-all.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    Can not copy File vis/lib/js/jquery.inputmask.bundle.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.inputmask.bundle.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                    host.iobrokerS2 102072 objects saved
                                    Backup created: /opt/iobroker/backups/2023_04_07-11_18_10_backupiobroker.tar.gz
                                    This backup can only be restored with js-controller version up from 4.1
                                    ilovegym@iobrokerS2:/opt/iobroker$
                                      @simatec
                                      das wird lang.. Moment.. er macht... musste kuerzen, waren mehr als 100000 Zeichen..
                                      ilovegym@iobrokerS2:/opt/iobroker$ iob backup
                                      host.iobrokerS2 84652 states saved
                                      Can not copy File 0_userdata.0/Icons/blaue_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/blaue_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/Icons/braune_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/braune_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/Icons/braune_tonne1.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/braune_tonne1.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/Icons/gelbe_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/gelbe_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/Icons/graue_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/graue_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/Icons/gruene_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/gruene_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/Icons/hellblaue_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/hellblaue_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_blau.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_blau.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_gelb.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_gelb.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_grau.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_grau.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_gruen.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_gruen.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/Icons/schwarze_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/schwarze_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/Icons/state_leerung blaue tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung blaue tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/Icons/state_leerung braune tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung braune tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/Icons/state_leerung gelbe tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung gelbe tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/Icons/state_leerung gruene tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung gruene tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/Icons/state_leerung schwarze tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung schwarze tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/Icons/undefined.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/undefined.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/htmlakku.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlakku.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/htmlbackitup.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlbackitup.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/htmldect2.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmldect2.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/htmlfussball1.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlfussball1.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/htmlfussball2.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlfussball2.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/htmltrash1.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmltrash1.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Alarmpanel.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Alarmpanel.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD10.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD10.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD8.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD8.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Frontdoor.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Frontdoor.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Guest.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Guest.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Home.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Home.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_HomeTV.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_HomeTV.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Mobile.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Mobile.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/AlarmpanelHD8.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/AlarmpanelHD8.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/Energy.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Energy.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/Home.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Home.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/HomeTV.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/HomeTV.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/Log.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Log.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/Mobile.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Mobile.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/OldMobile.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/OldMobile.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/TVOGB.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/TVOGB.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/Test.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Test.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/minukodu/Video.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Video.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/screenshots/bundesliga2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/screenshots/bundesliga2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File 0_userdata.0/synology/Doorbell.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/synology/Doorbell.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File lovelace.0/cards/background.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/lovelace.0/cards/background.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File mihome-vacuum.0.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.0.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File mihome-vacuum.1.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.1.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File mihome-vacuum.2.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.2.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File mihome-vacuum.3.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.3.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File synology.0/cover.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/cover.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File synology.0/snapshotCam_13.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_13.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File synology.0/snapshotCam_19.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_19.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File synology.0/snapshotCam_21.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_21.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File synology.0/snapshotCam_24.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_24.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File synology.0/snapshotCam_26.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_26.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File synology.0/snapshotCam_7.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_7.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File synology.1/cover.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.1/cover.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/cache.manifest to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/cache.manifest: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/cordova.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/cordova.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/css/add_kian.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/add_kian.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/css/app.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/app.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/css/backgrounds.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/backgrounds.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/css/doc.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/doc.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/css/montserrat-regular-webfont.woff to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/montserrat-regular-webfont.woff: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/css/styles.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/styles.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/css/vis-common-user.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/vis-common-user.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/css/vis-editor.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/vis-editor.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/css/vis.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/vis.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/edit.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/edit.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/edit.src.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/edit.src.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/add.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/add.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/align-height.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-height.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/align-horizontal-center-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-horizontal-center-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/align-horizontal-left.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-horizontal-left.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/align-horizontal-right-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-horizontal-right-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/align-vertical-bottom-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-vertical-bottom-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/align-vertical-center-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-vertical-center-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/align-vertical-top-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-vertical-top-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/align-width.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-width.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/bar.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/bar.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/cancel.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/cancel.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/checkbox.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/checkbox.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/container.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/container.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/control.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/control.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/copy.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/copy.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/delete.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/delete.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/dialog.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/dialog.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/distribute-horizontal-equal.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/distribute-horizontal-equal.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/distribute-vertical-equal.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/distribute-vertical-equal.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/door.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/door.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/filter.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/filter.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/groupFixed.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/groupFixed.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/groupVisibility.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/groupVisibility.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/info.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/info.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/lamp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/lamp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/lock.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/lock.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/lockIcon.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/lockIcon.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/navigation.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/navigation.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/ok.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/ok.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/refresh-4.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/refresh-4.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/rename.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/rename.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/rgb.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/rgb.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/shutter.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/shutter.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/state.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/state.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/stateful.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/stateful.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/static.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/static.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/table.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/table.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/temperature.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/temperature.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/timestamp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/timestamp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/tools.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/tools.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/value.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/value.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/icon/window.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/window.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/Heating.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/Heating.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/Lamp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/Lamp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/OutsideTemp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/OutsideTemp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/Window.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/Window.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/back/box-radial.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/back/box-radial.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/back/flowers.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/back/flowers.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/back/oblique-line-bk.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/back/oblique-line-bk.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/bg-dots-10.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-10.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/bg-dots-15.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-15.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/bg-dots-20.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-20.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/bg-dots-25.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-25.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/bg-dots-30.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-30.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/bg-dots-40.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-40.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/bg-dots-5.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-5.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/bg-dots-50.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-50.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/bulbOff.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulbOff.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/bulbOn.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulbOn.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/bulb_off.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulb_off.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/bulb_on.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulb_on.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/camera.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/camera.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/cc-nc-by.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/cc-nc-by.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/disconnect.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/disconnect.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/door-bell.mp3 to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/door-bell.mp3: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/editmode-pattern.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/editmode-pattern.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/eg_trans.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/eg_trans.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/favicon.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/favicon.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/faviconEdit.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/faviconEdit.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/garage-door-closed.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/garage-door-closed.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/garage-door-opened.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/garage-door-opened.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/gear-icon-md.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/gear-icon-md.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/hexabump.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/hexabump.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/kde_folder.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/kde_folder.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/no_filter.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/no_filter.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/sound.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/sound.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/tank.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/tank.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/vis.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/vis.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/img/zip.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/zip.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/index.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/index.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/index.src.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/index.src.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/app.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/app.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/config.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/config.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/conn.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/conn.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/connSignalR.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/connSignalR.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/fileManager.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/fileManager.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/fileManager.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/fileManager.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/actions/add.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/add.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/actions/back.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/back.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/actions/delete.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/delete.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/actions/down.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/down.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/actions/edit-rename.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/edit-rename.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/actions/folder-new-7.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/folder-new-7.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/actions/folder-new.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/folder-new.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/actions/icons.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/icons.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/actions/list.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/list.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/actions/play.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/play.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/actions/refresh.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/refresh.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/actions/stop.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/stop.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/actions/up.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/up.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/circleLeftIcon.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/circleLeftIcon.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/128/JS.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/JS.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/128/bmp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/bmp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/128/css.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/css.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/128/folder-blue.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/folder-blue.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/128/folder-brown.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/folder-brown.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/128/folder-green.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/folder-green.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/128/gif.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/gif.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/128/img2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/img2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/128/jpg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/jpg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/128/misc.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/misc.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/128/mp3.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/mp3.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/128/png.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/png.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/128/prg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/prg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/128/svg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/svg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/128/undef.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/undef.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/128/wav.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/wav.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/128/zip.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/zip.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/24/bmp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/bmp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/24/css.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/css.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/24/folder-blue.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/folder-blue.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/24/folder-brown.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/folder-brown.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/24/folder-green.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/folder-green.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/24/gif.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/gif.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/24/img2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/img2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/24/jpg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/jpg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/24/js.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/js.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/24/misc.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/misc.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/24/mp3.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/mp3.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/24/png.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/png.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/24/prg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/prg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/24/svg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/svg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/24/undef.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/undef.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/24/wav.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/wav.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/fm/icon/mine/24/zip.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/zip.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/vis.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/vis.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/visAbout.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visAbout.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/visEdit.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEdit.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/visEditExt.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditExt.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/visEditInspect.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditInspect.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/visEditTemplates.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditTemplates.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/visEditWelcome.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditWelcome.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/visUtils.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visUtils.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/visWizard.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visWizard.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/js/words.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/words.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/ace/ace.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/ace.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/ace/ext-language_tools.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/ext-language_tools.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/ace/ext-searchbox.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/ext-searchbox.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/ace/mode-css.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/mode-css.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/ace/mode-html.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/mode-html.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/ace/mode-javascript.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/mode-javascript.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/ace/worker-css.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/worker-css.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/ace/worker-html.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/worker-html.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/ace/worker-javascript.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/worker-javascript.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/css/add2home-2.0.8.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/add2home-2.0.8.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/css/fancytree/channel.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/channel.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/css/fancytree/device.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/device.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/css/fancytree/icons.gif to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/icons.gif: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/css/fancytree/loading.gif to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/loading.gif: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/css/fancytree/state.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/state.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/css/fancytree/ui.fancytree.jquery.min.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/ui.fancytree.jquery.min.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/css/fancytree/ui.fancytree.min.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/ui.fancytree.min.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/css/farbtastic.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/farbtastic.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/css/jquery-ui-timepicker-addon-1.6.3.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery-ui-timepicker-addon-1.6.3.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/css/jquery.jgrowl.min.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery.jgrowl.min.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/css/jquery.multiselect-1.13.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery.multiselect-1.13.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/css/jquery.multiselect.filter.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery.multiselect.filter.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/css/superfish/megafish.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/megafish.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/css/superfish/superfish-navbar.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/superfish-navbar.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/css/superfish/superfish-vertical.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/superfish-vertical.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/css/superfish/superfish.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/superfish.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/img/delete.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/delete.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/img/edit-undo-8.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/edit-undo-8.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/img/logout.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/logout.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/img/marker.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/marker.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/img/mask.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/mask.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/img/shape_align_bottom.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_bottom.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/img/shape_align_left.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_left.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/img/shape_align_right.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_right.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/img/shape_align_top.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_top.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/img/wheel.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/wheel.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/js/add2home-2.0.8.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/add2home-2.0.8.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/js/can.custom.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/can.custom.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/js/colResizable-1.5.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/colResizable-1.5.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/js/dropzone.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/dropzone.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/js/farbtastic.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/farbtastic.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/js/html2canvas.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/html2canvas.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/js/jquery-ui-1.10.3.dragdropsort.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery-ui-1.10.3.dragdropsort.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/js/jquery-ui-timepicker-addon-1.6.3.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery-ui-timepicker-addon-1.6.3.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/js/jquery.ba-resize.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.ba-resize.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/js/jquery.base64.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.base64.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/js/jquery.fancytree-all.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.fancytree-all.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      Can not copy File vis/lib/js/jquery.inputmask.bundle.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.inputmask.bundle.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
                                      host.iobrokerS2 102072 objects saved
                                      Backup created: /opt/iobroker/backups/2023_04_07-11_18_10_backupiobroker.tar.gz
                                      This backup can only be restored with js-controller version up from 4.1
                                      ilovegym@iobrokerS2:/opt/iobroker$
                                      simatecS Online
                                      simatecS Online
                                      simatec
                                      @ilovegym Mach da mal bitte ein Issue beim js-controller auf. Der Befehl "iob backup" wird direkt vom js-controller bearbeitet. Backitup bedient sich nur der Backup Funktionen des js-controllers
                                      • Besuche meine Github Seite
                                      • HowTo Restore ioBroker
                                      • simatecS simatec
                                        @simatec
                                        Issue done
                                          @simatec
                                          Issue done
                                          @ilovegym Und Danke, ist in der nächsten Alpha gefixt
                                          E 1 Antwort Letzte Antwort
