2.9k Beiträge 248 Kommentatoren 2.4m Aufrufe 123 Beobachtet
  • J johanneslisa
    @andre
    ----- Step 5 of 5: ioBroker startup -----
    Starting ioBroker...
    #### ### ## # iobroker.js-controller log output # ## ### ####
    host.iobroker check instance "system.adapter.admin.0" for host "iobroker"
    host.iobroker check instance "system.adapter.discovery.0" for host "iobroker"
    host.iobroker check instance "system.adapter.backitup.0" for host "iobroker"
    Recived termination signal (SIGTERM).
    Shutting down ioBroker...
    .================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
    ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
    Done. Have a nice day!
    ------------------------- 2023-04-02 11:56:50 -------------------------
    ----- Welcome to your ioBroker Docker container! -----
    ----- Startupscript is now running! -----
    ----- Please be patient! -----
    ----- System Information -----
    ----- arch: x86_64 -----
    ----- hostname: iobroker -----
    ----- Version Information -----
    ----- image: v8.0.0 -----
    ----- build: 2023-03-20T21:14:35+00:00 -----
    ----- node: v18.15.0 -----
    ----- npm: 9.5.0 -----
    ----- Environment Variables -----
    ----- AVAHI: false -----
    ----- PACKAGES: nano -----
    ----- SETGID: 1000 -----
    ----- SETUID: 1000 -----
    ----- Step 1 of 5: Preparing container -----
    This is not the first run of this container. Skipping first run preparation.
    ----- Step 2 of 5: Detecting ioBroker installation -----
    There is no data detected in /opt/iobroker.
    Restoring initial ioBroker installation... Done.
    ----- Step 3 of 5: Checking ioBroker installation -----
    (Re)setting permissions (This might take a while! Please be patient!)... Done.
    Fixing "sudo-bug" by replacing sudo with gosu... Done.
    Initializing a fresh installation of ioBroker... Done.
    Hostname in ioBroker does not match the hostname of this container.
    Updating hostname to "iobroker"... The host for instance "system.adapter.admin.0" was changed from "buildkitsandbox" to "iobroker".
    The host for instance "system.adapter.discovery.0" was changed from "buildkitsandbox" to "iobroker".
    The host for instance "system.adapter.backitup.0" was changed from "buildkitsandbox" to "iobroker".
    Done.
    ----- Step 4 of 5: Applying special settings -----
    Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
    J
    J
    johanneslisa
    #2783
    @andre
    Dieser Schritt funktioniert bei mir nicht:
    dann hat wahrscheinlich alles geklappt und ihr könnt den ioBroker-Admin über den bekannten Weg „http://[name_des_hosts]:8081“ oder „http://[IP-Adresse]:8081“ aufrufen.
    • J johanneslisa
      @andre
      Done.
      andreA
      andreA
      andre
      #2784
      @johanneslisa Ja, so sieht ein erfolgreicher Start aus. Bitte Logs immer in Code-Tags!
      Was ist mit den anderen Fragen? Netzwerkoption?
      MfG,
      André
      • andreA andre
        MfG,
        André
        J
        J
        johanneslisa
        schrieb am zuletzt editiert von johanneslisa
        #2785
        @andre
        Was möchtest du wissen? Ich kenne mich noch nicht so gut aus. Ich komme nicht in den iobroker, bzw. ich kann ihn nicht öffnen.
        andreA 1 Antwort Letzte Antwort
        • J johanneslisa
          @andre
          andreA
          andreA
          andre
          schrieb am zuletzt editiert von andre
          #2786
          @johanneslisa Ist das dein erster Docker Container? Falls ja, wirst du nicht umhin kommen dich ein wenig mit Docker zu beschäftigen. Du hast dieses Tutorial gemacht? https://smarthome.buanet.de/2019/05/iobroker-unter-docker-auf-der-synology-diskstation-v3/
          Dann hast du einen Bereich mit der Überschrift "Netzwerk" gelesen. Wofür hast du dich entschieden? Host? MACVLAN? Bridge?
          Alles Andere hast du 1:1 genauso gemacht? Was (exakt) rufst du auf um auf die Weboberfläche zuzugreifen? Ich behaupte jetzt mal, dass der ioBroker nicht das Problem ist, sondern das Netzwerk oder der Weg wie du darauf zugreifst.
          Was bekommst du für eine Fehlermeldung im Browser? Screenshot?
          MfG,
          André
          PS: An deinem Logfile sehe ich, dass du schon mal NICHT das Host Netzwerk (einfachste Option) verwendest. Korrekt? Nutzt du Bridge musst du mindestens den Port 8081 durch reichen. MACVLAN? Besser nicht, wenn du nicht sicher weißt was du tust...
          • andreA andre
            MfG,
            André
            J
            J
            johanneslisa
            #2787
            @andre
            Diese Anleitung habe ich verwendet. Ich habe jetzt die Bridge verwendet, so wie ich es verstehe ist das am einfachsten und für mich ausreichend. Zumindest jetzt am Anfang. Ja ist mein erster Container. Ich gebe ein: http://iobroker:8081 und da kommt nichts.
            Was ist durchreichen? Ich finde dazu nichts per google.
            Wenn Host leichter ist und keine großen Nachteile hat dann steige ich gerne um.
            GlasfaserG andreA 2 Antworten Letzte Antwort
            • J johanneslisa
              @andre
              GlasfaserG
              GlasfaserG
              #2788
              @johanneslisa sagte in [HowTo] ioBroker unter Docker auf Synology DiskStation:
              siehe hier z.B :
              https://forum.iobroker.net/post/887191
              Nix google ,
              sondern hier im Forum oder auf Andre´s Homepage suchen
              • J johanneslisa
                @andre
                andreA
                andreA
                andre
                #2789
                @johanneslisa Jo, da haben wir das Problem. Das wird nicht gehen:
                es heißt ja auch:
                Name oder IP des HOSTS! Der Host ist deine DiskStation.
                Port durchreichen hier:
                Ist glaub ich besser wenn du es mit Host versuchst... es sei denn du hast Portainer auf port 9000... ein Hinweis dazu steht aber auch im entsprechenden Tutorial.
                MfG,
                André
                • andreA andre
                  es heißt ja auch:
                  MfG,
                  André
                  J
                  J
                  johanneslisa
                  #2790
                  @andre
                  Ah ok.
                  Was muss ich da beim durchreichen eingeben? Ich kann den container so nicht deployen. Ich habe im ersten feld die ip der syonology und im zweiten 8081
                  • J johanneslisa
                    @andre
                    Ah ok.
                    GlasfaserG
                    GlasfaserG
                    #2791
                    Hast du nicht mein Link gesehn , es geht auch mit Bordmittel !
                    8081 : 8081
                    Hinweis , Lokal 8081 funktioniert nur , wenn er nicht schon von deiner Synology belegt ist !
                    • GlasfaserG Glasfaser
                      8081 : 8081
                      J
                      J
                      johanneslisa
                      #2792
                      @glasfaser
                      Iobroker lässt sich immer noch nicht öffnen.
                      Wo sehe ich ob dieser port schon vergeben ist?
                      • J johanneslisa
                        @glasfaser
                        GlasfaserG
                        GlasfaserG
                        #2793
                        Dann würdest du , in der gezeigten Oberfläche einen Hinweis bekommen !
                        • J johanneslisa
                          @glasfaser
                          GlasfaserG
                          GlasfaserG
                          #2794
                          Nutze bitte einen anderen Browser !
                          http://IPvondeinerSynology:8081
                            J
                            J
                            johanneslisa
                            #2795
                            @glasfaser
                            Geht weder in Safari noch in Firefox
                            • J johanneslisa
                              @glasfaser
                              GlasfaserG
                              GlasfaserG
                              #2796
                              @johanneslisa
                              Lösche den Container und starte von neuen und gebe die Ports dann auch bei der Konfig ein .
                              Aber alles ohne Portainer !
                              Ist mit Bordmitteln selbsterklärend.
                              usw,
                              • B
                                B
                                Boardy
                                #2797
                                ich versuche gerade einen Container unter IPv6 erreicbar zu machen.
                                Hat das schon jemand hinbekommen?
                                muss man dazu den Deamon.json noch modifizieren, habe irgendwo gelesen mit MCVLAN benötigt man das nicht mehr, finde es aber gerade nicht...
                                im MCVLAN Script habe ich die ip -6 Zeile ergänzt - läuft auch ohne Fehler...
                                # MACVLAN für VLAN 1 - IP Adresse 192.168.10.30/32
                                ip link del mac1
                                ip link add mac1 link bond0.1 type macvlan mode bridge
                                ip addr add 192.168.10.30/32 dev mac1
                                ip -6 addr add fd00:100::211:32ff:feca:a7e1/64 dev mac1
                                ip link set mac1 up
                                ich habe es auch mit eienm 64er Segment versucht: ip -6 addr add fd00💯:/64 dev mac1
                                Größer machtr wohl keinen Sinn...
                                Hat das schon jemand am laufen?
                                Wo ist mein Denkfehler, was mache ich falsch?
                                Hat jemand ein Beispiel dasa geht?
                                • Marc BergM
                                  Marc BergM
                                  Marc Berg
                                  #2798
                                  @boardy
                                  Ich nutze Docker nativ + Docker Compose, insofern ist es nicht vergleichbar, aber vielleicht kannst du daraus was ableiten:
                                  Inhalt der daemon.json:
                                  "experimental": true,
                                  "ip6tables": true
                                  Docker compose:
                                  networks:
                                    mvl1:
                                      driver: macvlan
                                      enable_ipv6: true
                                      driver_opts:
                                        parent: eno1
                                      ipam:
                                        config:
                                          - subnet: "fd00:1000:ffff::/64"
                                            gateway: "fd00:1000:ffff::3ea6:2fef:fe85:4dcf"
                                          - subnet: 192.168.1.0/24
                                            gateway: 192.168.1.1
                                            ip_range: 192.168.1.32/27
                                  Pi-hole, Traefik, Checkmk, Conbee II+Zigbee2MQTT, LoRaWAN
                                  • B
                                    B
                                    Boardy
                                    #2799
                                    Hi, Danke, ist für IPv6 vielleicht auch geschickter es so zu machen... ich probiere das mal auf diesem weg...
                                    was auffällt, du hast macvlan + Anpassung der json, dann mach ich das doch erst mal...
                                    Neues Problem: Durch mein Rumspieln hab ich mir irgendwas an der Netzwerkconfig ? zerschossen, seit heute geht mein FTP Server nicht mehr über IPv6, auch nicht lokal... IPV4 geht noch... hat jemand ne Idee was da nun schief ist? leider sieht man ja niocht was die Firewall so macht.... es gibt keien Rückmeldung, nur Timeout...
                                    • Marc BergM Marc Berg
                                      @boardy
                                      "ip6tables": true
                                      Docker compose:
                                      networks:
                                        mvl1:
                                          driver: macvlan
                                          enable_ipv6: true
                                          driver_opts:
                                            parent: eno1
                                          ipam:
                                            config:
                                      OliverIOO
                                      OliverIOO
                                      OliverIO
                                      #2800
                                      @marc-berg
                                      Wer ipv6 für einen Container aktiviert sollte sich bewusst sein, das dieser Container dann öffentlich im Internet steht.
                                      Der Schutz durch das nat für ipv4 wirkt hier ja nicht mehr. So sind die ipv4 Container einigermaßen geschützt.
                                      Dadurch wird der Einsatz einer Firewall unumgänglich, so das nur bestimmte ports über das Internet zugänglich sind.
                                      Meine Adapter und Widgets
                                      Links im Profil
                                      B Marc BergM 2 Antworten Letzte Antwort
                                      • OliverIOO OliverIO
                                        @marc-berg
                                        B
                                        B
                                        Boardy
                                        #2801
                                        @oliverio
                                        ja das ist klar - ich kämpfe auch gerade an der Mikrotik front... gestern ging alles - heute geschrottet... ):
                                          @marc-berg
                                          Marc BergM
                                          Marc BergM
                                          Marc Berg
                                          #2802
                                          @oliverio sagte in [HowTo] ioBroker unter Docker auf Synology DiskStation:
                                          ... was aber in dieser Absolutheit nicht stimmt. Jeder halbwegs aktuelle Router bringt eine Firewall mit, die den Zugriff aus dem Internet per IPv6 unterbindet, sofern man nicht explizit freischaltet. Aber ja, man sollte sich der erhöhten Risiken bewusst sein, gerade, wenn man Hosting Angebote nutzt.
                                          84.1k
