  3. Off Topic
  4. apt full-upgrade Error
    6.1k
71 Beiträge 6 Kommentatoren 6.1k Aufrufe 5 Beobachtet
  • NegaleinN Negalein
    @crunchip sagte in apt full-upgrade Error:
    sudo apt autoremove
    nega@ubuntu:~$ sudo apt autoremove
    Reading package lists... Done
    Building dependency tree
    The following packages will be REMOVED:
      linux-headers-5.4.0-139 linux-headers-5.4.0-139-generic linux-image-5.4.0-139-generic
      linux-modules-5.4.0-139-generic linux-modules-extra-5.4.0-139-generic
    0 upgraded, 0 newly installed, 5 to remove and 96 not upgraded.
    After this operation, 380 MB disk space will be freed.
    Do you want to continue? [Y/n] Y
    (Reading database ... 188197 files and directories currently installed.)
    Removing linux-headers-5.4.0-139-generic (5.4.0-139.156) ...
    Removing linux-headers-5.4.0-139 (5.4.0-139.156) ...
    Removing linux-modules-extra-5.4.0-139-generic (5.4.0-139.156) ...
    Removing linux-image-5.4.0-139-generic (5.4.0-139.156) ...
    /etc/kernel/postrm.d/initramfs-tools:
    update-initramfs: Deleting /boot/initrd.img-5.4.0-139-generic
    /etc/kernel/postrm.d/zz-update-grub:
    Sourcing file `/etc/default/grub'
    Sourcing file `/etc/default/grub.d/init-select.cfg'
    Generating grub configuration file ...
    Found linux image: /boot/vmlinuz-5.4.0-146-generic
    Found initrd image: /boot/initrd.img-5.4.0-146-generic
    Found linux image: /boot/vmlinuz-5.4.0-144-generic
    Found initrd image: /boot/initrd.img-5.4.0-144-generic
    Found linux image: /boot/vmlinuz-5.4.0-137-generic
    Found initrd image: /boot/initrd.img-5.4.0-137-generic
    done
    Removing linux-modules-5.4.0-139-generic (5.4.0-139.156) ...
    nega@ubuntu:~$
    @thomas-braun sagte in apt full-upgrade Error:
    df -h
    nega@ubuntu:~$ df -h
    Filesystem                         Size  Used Avail Use% Mounted on
    udev                               947M     0  947M   0% /dev
    tmpfs                              199M 1016K  198M   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv  8.8G  8.0G  362M  96% /
    tmpfs                              992M     0  992M   0% /dev/shm
    tmpfs                              5.0M     0  5.0M   0% /run/lock
    tmpfs                              992M     0  992M   0% /sys/fs/cgroup
    /dev/loop1                          56M   56M     0 100% /snap/core18/2714
    /dev/sda2                          974M  306M  601M  34% /boot
    /dev/loop0                          56M   56M     0 100% /snap/core18/2721
    /dev/loop2                          64M   64M     0 100% /snap/core20/1828
    /dev/loop3                          64M   64M     0 100% /snap/core20/1852
    /dev/loop4                          92M   92M     0 100% /snap/lxd/23991
    /dev/loop5                          92M   92M     0 100% /snap/lxd/24061
    /dev/loop7                          50M   50M     0 100% /snap/snapd/18596
    /dev/loop6                          50M   50M     0 100% /snap/snapd/18357
    tmpfs                              199M     0  199M   0% /run/user/1000
    nega@ubuntu:~$
    crunchipC Abwesend
    crunchipC Abwesend
    @negalein sagte in apt full-upgrade Error:
    362M
    nun bisserl Platz😁
      sudo apt autoremove
      done
      nega@ubuntu:~$
      df -h
      nega@ubuntu:~$
      @negalein
      Im npm cache liegt auch gerne viel herum.
      sudo -H -u iobroker npm cache clear --force
        @negalein
        crunchipC Abwesend
        crunchipC Abwesend
        @thomas-braun wenns ne iobroker VM ist/wäre
          @crunchip
          Stimmt. Hatte ich jetzt angenommen.
          Und ohne den ganzen Desktopkrempel wäre da auch mehr Platz...
          crunchipC NegaleinN 2 Antworten Letzte Antwort
            362M
            nun bisserl Platz😁
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            nun bisserl Platz
            ja, ein bisserl 😁
            dafür spinnen jetzt ein paar Switche und lassen sich nicht einbinden. :(
            nega@ubuntu:~$ sudo -H -u nega npm cache clear --force
            sudo: npm: command not found
            ° Fixer ---> iob fix
              @crunchip
              crunchipC Abwesend
              crunchipC Abwesend
              @thomas-braun sieht mit eher nach nem unifi controller aus
                @crunchip
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                ok, das ist schon ewig her. Damals hab ich nicht darauf geachtet.
                Wie bringt man den Desktop wieder weg?
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  Jep, ist er
                    Jep, ist er
                    Und der Unifi-Controller ist 8GB schwer?
                    Keine Ahnung was der alles benötigt und anschleppt.
                    crunchipC NegaleinN Dr. BakteriusD 3 Antworten Letzte Antwort
                      Jep, ist er
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @negalein wenn du nicht zurecht kommst, könntest ja auch ein backup vom Controller machen, VM neu aufsetzen und backup wieder einspielen
                        crunchipC Abwesend
                        crunchipC Abwesend
                        hatte den mal im LXC laufen, aber 8GB reichen eigentlich locker
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          ja, das ist der letzte Ausweg.
                          Sobald die Switche wieder laufen, versuch ich https://indibit.de/ubuntu-partition-vergroessern/
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            ist das richtig mit init 3, oder wird hier nur umgeschaltet und der Desktop nicht deinstalliert?
                              @negalein
                              Da wird nur der Zustand geändert, die Software bleibt dennoch auf dem System.
                                @negalein
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                ok, dachte ich mir. :(
                                Kann der Desktop überhaupt nachträglich deinstalliert werden?
                                In deinem Baukasten steht nur was zum Pi.
                                  Natürlich. Ist aber nicht so ganz trivial. Welcher ist denn da überhaupt am Start?
                                    NegaleinN Offline
                                    NegaleinN Offline
                                    Negalein
                                    das seh ich wie?
                                      das seh ich wie?
                                      @negalein
                                      echo $DESKTOP_SESSION
                                      echo $XDG_SESSION_TYPE
                                        @negalein
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        echo $DESKTOP_SESSION echo $XDG_SESSION_TYPE
                                        nega@ubuntu:~$ echo $DESKTOP_SESSION
                                        nega@ubuntu:~$ echo $XDG_SESSION_TYPE
                                        tty
                                        nega@ubuntu:~$
                                          tty
                                          nega@ubuntu:~$
                                          @negalein
                                          Momentan läuft da kein Desktop.
                                          Funktioniert das?
                                          sudo apt remove gnome desktop environment -y
