  4. Test Adapter Garmin
Test Adapter Garmin
196 Beiträge 21 Kommentatoren 53.8k Aufrufe 21 Beobachtet
  • dirk1962D dirk1962
    @tombox ,
    Ich habe die aktuelle Version von Github installiert und das sind die Errors:
    2023-01-11 20:55:56.250 - error: garmin.1 (1986553) Cannot extract array dailystress.bodyBatteryValuesArray154
    2023-01-11 20:55:56.251 - error: garmin.1 (1986553) TypeError: Cannot convert undefined or null to object
    at Function.keys (<anonymous>)
    at Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:148:40)
    at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:82:9)
    at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:256:9)
    at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:92:11)
    2023-01-11 20:55:56.254 - error: garmin.1 (1986553) Cannot extract array dailystress.bodyBatteryValuesArray155
    2023-01-11 20:55:56.254 - error: garmin.1 (1986553) TypeError: Cannot convert undefined or null to object
    Ich hoffe, dass es Dir hilft.
    tombox
    @dirk1962 Bitte neue github version testen ob der Fehler weg ist
    dirk1962D 1 Antwort Letzte Antwort
    • T tombox
      dirk1962D Offline
      dirk1962D Offline
      dirk1962
      @tombox Auch mit neuer Github Version habe ich die Errors.
      2023-01-12 18:56:52.435 - error: garmin.1 (2080293) https://connect.garmin.com/modern/proxy/userstats-service/wellness/daily/Nicki_1966?fromDate=2023-01-06
      2023-01-12 18:56:52.435 - error: garmin.1 (2080293) Error: read ECONNRESET
      2023-01-12 18:56:52.798 - info: linux-control.0 (1970948) getting data from iobroker-Test (192.168.1.173:22)
      2023-01-12 18:56:53.712 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray01
      2023-01-12 18:56:53.713 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
      at Function.keys ()
      2023-01-12 18:56:53.715 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray02
      2023-01-12 18:56:53.715 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
      at Function.keys ()
      2023-01-12 18:57:01.048 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray360
      2023-01-12 18:57:01.048 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
      at Function.keys ()
      2023-01-12 18:57:01.092 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray361
      2023-01-12 18:57:01.092 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
      at Function.keys ()
      2023-01-12 18:57:01.096 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray362
      2023-01-12 18:57:01.096 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
      at Function.keys ()
      2023-01-12 18:57:01.144 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray363
      2023-01-12 18:57:01.144 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
      2023-01-12 18:57:01.145 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
      at Function.keys ()
      2023-01-12 18:57:01.148 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray364
      2023-01-12 18:57:01.148 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
      Ich habe zwischendurch Fehlermeldungen rausgenommen, weil es sonst mehr als die zulässigen 100.000 Zeichen sind.
      NUC8i5 mit Proxmox; Raspberrymatic in VM, iobroker, Motioneye, infuxDB und Grafana in CT.
        at Function.keys ()
        at Function.keys ()
        at Function.keys ()
        at Function.keys ()
        at Function.keys ()
        at Function.keys ()
        tombox
        @dirk1962 Dann wurde nicht richtig neu installiert oder die Instanz nicht neugestartet
        • T tombox
          dirk1962D Offline
          dirk1962D Offline
          dirk1962
          @tombox Habe den Adapter nochmals von Github geladen und beide Instanzen neu gestartet. Seitdem gibt es keine Fehlermeldungen mehr 👍 . Vielen Dank für Deine Hilfe.
          • StuebiS Offline
            StuebiS Offline
            Stuebi
            der Adapter läuft super. Danke dafür. Nur im Objekt garmin.X.activities.YY.averageSpeed werden bei mir merkwürdige Werte angezeigt.
            Lauf:
            ioBroker Garmin Adapter : 2,74399996
            Garmin Connect App: 6.04 min/km
            Beim Radfahren kann ich die Speed Werte bei averageSpeed und maxSpeed auch nicht nachvollziehen.
            Gibt es eigentlich noch ein Feld für durchschnittliche Geschwindigkeit in Bewegung analog der Garmin Connect App.?
            Viele Grüße
            Stuebi
            ioBroker auf Synology DS216+II im Docker Container
            • Curtis777C Offline
              Curtis777C Offline
              Curtis777
              Genial der Adapter sowas hab ich ewig gesucht... gibts irgendwas zu beachten bevor ich denn ausprobiere ?
              • Stefan SchoberS Offline
                Stefan Schober
                Welche Funktionen hat der Adapter? Kann man darüber auch einen Alarm einstellen oder die Uhr suchen lassen?
                Curtis777C 1 Antwort Letzte Antwort
                • Stefan SchoberS Stefan Schober
                  Curtis777C Offline
                  Curtis777C Offline
                  Curtis777
                  @stefan-schober der Adapter gibt rein die Werte aus der Garmin Page / Garmin Backend aus.
                  Ich habe soeine Funktion nicht gesehen. bzw Datenpunkt.
                    kirbsi
                    Hallo Leute. Habt ihr auch das Probleme, dass bei eurem Garminkonto versucht wird das Passwort zu ändern? 😠 Habe das jetzt schon 3x gehabt. Garmin sperrt dann immer wieder das Konto.
                    Ich habe dann meine Email geändert aber dennoch heute wieder ein Angriff. Woher haben sie meine Emailadresse? Von diesem Adapter? Ich werde jetzt den Adapter mal deaktivieren und schauen ob es daran liegt. Habe sonst nirgendwo meinen Garmin Account angegeben.
                    Curtis777C B 2 Antworten Letzte Antwort
                    • K kirbsi
                      Curtis777C Offline
                      Curtis777C Offline
                      Curtis777
                      @kirbsi
                      Nein, habe nichts dergleichen gemerkt.
                      Betreibe ihn jetzt schon länger wüsste auch nicht wie der Adapter das gemacht haben soll.
                      Überprüfe Mal dein System auf offene Ports / Sicherheitsprobleme.
                      • K kirbsi
                        bommel_030
                        @kirbsi
                        Ich habe den Adapter eine gewisse Zeit lang laufen gehabt. Nachdem Garmin das 5. Mal mein Passwort resettet hat habe ich den Adapter deaktiviert. Seitdem ist Ruhe. Ich tippe daher auf den Adapter. Konnte mich mangels Zeit noch nicht genauer damit beschäftigen.
                        Vermute aber keinen "angriff" dahinter. Schätze Garmin ist ob der Anfragen verwirrt.
                        Was für ein Garmin Gerät benutzt du, bzw. produzierst du 24/7 Daten wie Schritte / Puls / Aktivitäten etc. ?
                          kirbsi
                          @bommel_030 Genau wie bei mir . Habe jetzt mal die Logs vom Adapter überprüft im Vergleich zum Emailzeitpunkt.
                          Kurz bevor die Email von Garmin kommt, läuft folgendes im Adapter ab.
                          2023-03-28 10:08:10.188 - info: garmin.0 (52299) usersummary receive 401 error. Refresh Token in 60 seconds
                          2023-03-28 10:08:10.536 - info: garmin.0 (52299) maxmet receive 401 error. Refresh Token in 60 seconds
                          2023-03-28 10:08:10.767 - info: garmin.0 (52299) hydration receive 401 error. Refresh Token in 60 seconds
                          2023-03-28 10:08:11.025 - info: garmin.0 (52299) dailysleep receive 401 error. Refresh Token in 60 seconds
                          2023-03-28 10:08:11.281 - info: garmin.0 (52299) dailystress receive 401 error. Refresh Token in 60 seconds
                          2023-03-28 10:08:11.928 - info: garmin.0 (52299) heartrate receive 401 error. Refresh Token in 60 seconds
                          2023-03-28 10:08:12.280 - info: garmin.0 (52299) trainingstatus receive 401 error. Refresh Token in 60 seconds
                          2023-03-28 10:08:12.512 - info: garmin.0 (52299) activities receive 401 error. Refresh Token in 60 seconds
                          2023-03-28 10:08:12.899 - info: garmin.0 (52299) weight receive 401 error. Refresh Token in 60 seconds
                          2023-03-28 10:08:13.192 - info: garmin.0 (52299) adhocchallenge receive 401 error. Refresh Token in 60 seconds
                          2023-03-28 10:08:13.441 - info: garmin.0 (52299) personalrecords receive 401 error. Refresh Token in 60 seconds
                          2023-03-28 10:09:15.848 - error: garmin.0 (52299) Failed ticket please check username and password
                          2023-03-28 10:09:15.848 - error: garmin.0 (52299) TypeError: Cannot read properties of undefined
                          Ich habe den Adapter 24/7 am laufen. Aktualisierungsintervat 15 min! Wie habt ihr ihn eingestellt? Wird der vielleicht zu oft abgefragt?
                          • K kirbsi
                            Curtis777C Offline
                            Curtis777C Offline
                            Curtis777
                            @kirbsi probiere mal weniger Abfragen,
                            Welches Gerät synced denn so oft das alle 15 Minuten notwendig ist ?
                            • Curtis777C Curtis777
                              kirbsi
                              @curtis777 Ist richtig. Wollte halt immer aktuelle Daten in der Visu. Was hast du eingestellt?
                              • K kirbsi
                                Curtis777C Offline
                                Curtis777C Offline
                                Curtis777
                                @kirbsi
                                Das dachte ich mir auch anfangs. hab sogar alle 5 Minuten eingestellt gehabt.
                                Allerdings kommen meine Daten "Nur" von meiner Fenix 6 am Handgelenk.
                                Die syncronisiert nicht so oft um einen Intervall von öfter als 70-90 Minuten zu benötigen.
                                Ich hab derzeit mal 70 Minuten Intervall aktiviert und das läuft seit ca 10.februar durchgehend.
                                  @kirbsi
                                  bommel_030
                                  @curtis777
                                  Hast du bei dir MFA in Garmin aktiviert? Ich hatte den Adapter zum Schluß mit Abrufintervallen >3h laufen und hatte weiterhin die Probleme mit dem Passwort reset. MFA hab ich (noch) nicht aktiviert.
                                  Hab den Adapter jetzt mal wieder mit 90 min Intervallen aktiviert und schau mal ob er jetzt durchläuft.
                                  • B bommel_030
                                    @curtis777
                                    Curtis777C Offline
                                    Curtis777C Offline
                                    Curtis777
                                    @bommel_030
                                    Nein habe kein MFA aktiv.
                                    Bin gespannt. wie es bei dir läuft.
                                    Und wie ich hübsch die Pace und Distanz der Aktivitäten umrechnen kann.
                                    Average Speed ist bei mir zum Beispiel 3.3010001182556152
                                    wie das allerdings in min/km umzurechnen ist und wie man das in der VIS löst weiss ich nicht.
                                    ausserdem klappt die umrechnung m in km nicht.
                                    so sieht meine VIS (also der GarminTeil) derzeit aus.
                                      @bommel_030
                                      bommel_030
                                      @curtis777
                                      Da der Adapter bei mir nicht stabil lief habe ich mich mit der VIS noch nicht beschäftigt. Welche Datenpunkt nutzt du?
                                      Hab mir damals angefangen mittels alias ein paar Gesundheitsdaten übersichtlicher zu strukturieren. Bei den Aktivitäten hab ich noch keine sinnvolle Aufteilung nach Aktivität gefunden. Wenn der Adapter jetzt durchläuft werde ich mich damit mla wieder beschäftigen.
                                      • B bommel_030
                                        @curtis777
                                        Curtis777C Offline
                                        Curtis777C Offline
                                        Curtis777
                                        @bommel_030
                                        Ich verwende die Daten aus folgenden Ordnern:
                                        garmin.0.activities.01
                                        Für Daten aus dem letzten Lauf ....
                                        garmin.0.trainingstatus
                                        für Daten wie persönliche Rekorde etc.
                                          kirbsi
                                          Ich habe es jetzt auf 120 min gestellt und hoffe das es jetzt durch läuft. Meine Visu habe ich versucht so darzustellen wie es auf der App ist. Hat n Wochenende gedauert.😀 98479e83-3ddf-4848-91d0-2858b4d76102-image.png
