  4. Test Adapter Garmin
Test Adapter Garmin
196 Beiträge 21 Kommentatoren 53.8k Aufrufe 21 Beobachtet
  • T tombox
    @dirk1962 Bitte neue github version testen ob der Fehler weg ist
    dirk1962D Offline
    dirk1962D Offline
    dirk1962
    @tombox Auch mit neuer Github Version habe ich die Errors.
    2023-01-12 18:56:52.435 - error: garmin.1 (2080293) https://connect.garmin.com/modern/proxy/userstats-service/wellness/daily/Nicki_1966?fromDate=2023-01-06
    2023-01-12 18:56:52.435 - error: garmin.1 (2080293) Error: read ECONNRESET
    2023-01-12 18:56:52.798 - info: linux-control.0 (1970948) getting data from iobroker-Test (192.168.1.173:22)
    2023-01-12 18:56:53.712 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray01
    2023-01-12 18:56:53.713 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
    at Function.keys ()
    at Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:148:40)
    at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:82:9)
    at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:256:9)
    at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:92:11)
    2023-01-12 18:56:53.715 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray02
    2023-01-12 18:56:53.715 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
    at Function.keys ()
    2023-01-12 18:57:01.048 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray360
    2023-01-12 18:57:01.048 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
    at Function.keys ()
    2023-01-12 18:57:01.092 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray361
    2023-01-12 18:57:01.092 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
    at Function.keys ()
    2023-01-12 18:57:01.096 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray362
    2023-01-12 18:57:01.096 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
    at Function.keys ()
    2023-01-12 18:57:01.144 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray363
    2023-01-12 18:57:01.144 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
    2023-01-12 18:57:01.145 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
    at Function.keys ()
    2023-01-12 18:57:01.148 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray364
    2023-01-12 18:57:01.148 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
    Ich habe zwischendurch Fehlermeldungen rausgenommen, weil es sonst mehr als die zulässigen 100.000 Zeichen sind.
    NUC8i5 mit Proxmox; Raspberrymatic in VM, iobroker, Motioneye, infuxDB und Grafana in CT.
    • dirk1962D dirk1962
      at Function.keys ()
      at Function.keys ()
      at Function.keys ()
      at Function.keys ()
      at Function.keys ()
      at Function.keys ()
      tombox
      @dirk1962 Dann wurde nicht richtig neu installiert oder die Instanz nicht neugestartet
      dirk1962D 1 Antwort Letzte Antwort
      • T tombox
        dirk1962D Offline
        dirk1962D Offline
        dirk1962
        @tombox Habe den Adapter nochmals von Github geladen und beide Instanzen neu gestartet. Seitdem gibt es keine Fehlermeldungen mehr 👍 . Vielen Dank für Deine Hilfe.
        • StuebiS Offline
          StuebiS Offline
          Stuebi
          der Adapter läuft super. Danke dafür. Nur im Objekt garmin.X.activities.YY.averageSpeed werden bei mir merkwürdige Werte angezeigt.
          Lauf:
          ioBroker Garmin Adapter : 2,74399996
          Garmin Connect App: 6.04 min/km
          Beim Radfahren kann ich die Speed Werte bei averageSpeed und maxSpeed auch nicht nachvollziehen.
          Gibt es eigentlich noch ein Feld für durchschnittliche Geschwindigkeit in Bewegung analog der Garmin Connect App.?
          Viele Grüße
          Stuebi
          ioBroker auf Synology DS216+II im Docker Container
          • Curtis777C Offline
            Curtis777C Offline
            Curtis777
            Genial der Adapter sowas hab ich ewig gesucht... gibts irgendwas zu beachten bevor ich denn ausprobiere ?
            • Stefan SchoberS Offline
              Stefan Schober
              Welche Funktionen hat der Adapter? Kann man darüber auch einen Alarm einstellen oder die Uhr suchen lassen?
              Curtis777C 1 Antwort Letzte Antwort
              • Stefan SchoberS Stefan Schober
                Curtis777C Offline
                Curtis777C Offline
                Curtis777
                @stefan-schober der Adapter gibt rein die Werte aus der Garmin Page / Garmin Backend aus.
                Ich habe soeine Funktion nicht gesehen. bzw Datenpunkt.
                  kirbsi
                  Hallo Leute. Habt ihr auch das Probleme, dass bei eurem Garminkonto versucht wird das Passwort zu ändern? 😠 Habe das jetzt schon 3x gehabt. Garmin sperrt dann immer wieder das Konto.
                  Ich habe dann meine Email geändert aber dennoch heute wieder ein Angriff. Woher haben sie meine Emailadresse? Von diesem Adapter? Ich werde jetzt den Adapter mal deaktivieren und schauen ob es daran liegt. Habe sonst nirgendwo meinen Garmin Account angegeben.
                  Curtis777C B 2 Antworten Letzte Antwort
                  • K kirbsi
                    Curtis777C Offline
                    Curtis777C Offline
                    Curtis777
                    @kirbsi
                    Nein, habe nichts dergleichen gemerkt.
                    Betreibe ihn jetzt schon länger wüsste auch nicht wie der Adapter das gemacht haben soll.
                    Überprüfe Mal dein System auf offene Ports / Sicherheitsprobleme.
                    • K kirbsi
                      bommel_030
                      @kirbsi
                      Ich habe den Adapter eine gewisse Zeit lang laufen gehabt. Nachdem Garmin das 5. Mal mein Passwort resettet hat habe ich den Adapter deaktiviert. Seitdem ist Ruhe. Ich tippe daher auf den Adapter. Konnte mich mangels Zeit noch nicht genauer damit beschäftigen.
                      Vermute aber keinen "angriff" dahinter. Schätze Garmin ist ob der Anfragen verwirrt.
                      Was für ein Garmin Gerät benutzt du, bzw. produzierst du 24/7 Daten wie Schritte / Puls / Aktivitäten etc. ?
                        kirbsi
                        @bommel_030 Genau wie bei mir . Habe jetzt mal die Logs vom Adapter überprüft im Vergleich zum Emailzeitpunkt.
                        Kurz bevor die Email von Garmin kommt, läuft folgendes im Adapter ab.
                        2023-03-28 10:08:10.188 - info: garmin.0 (52299) usersummary receive 401 error. Refresh Token in 60 seconds
                        2023-03-28 10:08:10.536 - info: garmin.0 (52299) maxmet receive 401 error. Refresh Token in 60 seconds
                        2023-03-28 10:08:10.767 - info: garmin.0 (52299) hydration receive 401 error. Refresh Token in 60 seconds
                        2023-03-28 10:08:11.025 - info: garmin.0 (52299) dailysleep receive 401 error. Refresh Token in 60 seconds
                        2023-03-28 10:08:11.281 - info: garmin.0 (52299) dailystress receive 401 error. Refresh Token in 60 seconds
                        2023-03-28 10:08:11.928 - info: garmin.0 (52299) heartrate receive 401 error. Refresh Token in 60 seconds
                        2023-03-28 10:08:12.280 - info: garmin.0 (52299) trainingstatus receive 401 error. Refresh Token in 60 seconds
                        2023-03-28 10:08:12.512 - info: garmin.0 (52299) activities receive 401 error. Refresh Token in 60 seconds
                        2023-03-28 10:08:12.899 - info: garmin.0 (52299) weight receive 401 error. Refresh Token in 60 seconds
                        2023-03-28 10:08:13.192 - info: garmin.0 (52299) adhocchallenge receive 401 error. Refresh Token in 60 seconds
                        2023-03-28 10:08:13.441 - info: garmin.0 (52299) personalrecords receive 401 error. Refresh Token in 60 seconds
                        2023-03-28 10:09:15.848 - error: garmin.0 (52299) Failed ticket please check username and password
                        2023-03-28 10:09:15.848 - error: garmin.0 (52299) TypeError: Cannot read properties of undefined
                        Ich habe den Adapter 24/7 am laufen. Aktualisierungsintervat 15 min! Wie habt ihr ihn eingestellt? Wird der vielleicht zu oft abgefragt?
                        • K kirbsi
                          Curtis777C Offline
                          Curtis777C Offline
                          Curtis777
                          @kirbsi probiere mal weniger Abfragen,
                          Welches Gerät synced denn so oft das alle 15 Minuten notwendig ist ?
                          • Curtis777C Curtis777
                            kirbsi
                            @curtis777 Ist richtig. Wollte halt immer aktuelle Daten in der Visu. Was hast du eingestellt?
                            • K kirbsi
                              Curtis777C Offline
                              Curtis777C Offline
                              Curtis777
                              @kirbsi
                              Das dachte ich mir auch anfangs. hab sogar alle 5 Minuten eingestellt gehabt.
                              Allerdings kommen meine Daten "Nur" von meiner Fenix 6 am Handgelenk.
                              Die syncronisiert nicht so oft um einen Intervall von öfter als 70-90 Minuten zu benötigen.
                              Ich hab derzeit mal 70 Minuten Intervall aktiviert und das läuft seit ca 10.februar durchgehend.
                                @kirbsi
                                bommel_030
                                @curtis777
                                Hast du bei dir MFA in Garmin aktiviert? Ich hatte den Adapter zum Schluß mit Abrufintervallen >3h laufen und hatte weiterhin die Probleme mit dem Passwort reset. MFA hab ich (noch) nicht aktiviert.
                                Hab den Adapter jetzt mal wieder mit 90 min Intervallen aktiviert und schau mal ob er jetzt durchläuft.
                                • B bommel_030
                                  @curtis777
                                  Curtis777C Offline
                                  Curtis777C Offline
                                  Curtis777
                                  @bommel_030
                                  Nein habe kein MFA aktiv.
                                  Bin gespannt. wie es bei dir läuft.
                                  Und wie ich hübsch die Pace und Distanz der Aktivitäten umrechnen kann.
                                  Average Speed ist bei mir zum Beispiel 3.3010001182556152
                                  wie das allerdings in min/km umzurechnen ist und wie man das in der VIS löst weiss ich nicht.
                                  ausserdem klappt die umrechnung m in km nicht.
                                  so sieht meine VIS (also der GarminTeil) derzeit aus.
                                    @bommel_030
                                    bommel_030
                                    @curtis777
                                    Da der Adapter bei mir nicht stabil lief habe ich mich mit der VIS noch nicht beschäftigt. Welche Datenpunkt nutzt du?
                                    Hab mir damals angefangen mittels alias ein paar Gesundheitsdaten übersichtlicher zu strukturieren. Bei den Aktivitäten hab ich noch keine sinnvolle Aufteilung nach Aktivität gefunden. Wenn der Adapter jetzt durchläuft werde ich mich damit mla wieder beschäftigen.
                                    • B bommel_030
                                      @curtis777
                                      Curtis777C Offline
                                      Curtis777C Offline
                                      Curtis777
                                      @bommel_030
                                      Ich verwende die Daten aus folgenden Ordnern:
                                      garmin.0.activities.01
                                      Für Daten aus dem letzten Lauf ....
                                      garmin.0.trainingstatus
                                      für Daten wie persönliche Rekorde etc.
                                        kirbsi
                                        Ich habe es jetzt auf 120 min gestellt und hoffe das es jetzt durch läuft. Meine Visu habe ich versucht so darzustellen wie es auf der App ist. Hat n Wochenende gedauert.😀 98479e83-3ddf-4848-91d0-2858b4d76102-image.png
                                          kirbsi
                                          Wo bekommt man denn M
                                          FA her?
