  4. Test Adapter Garmin
Test Adapter Garmin
196 Beiträge 21 Kommentatoren 53.8k Aufrufe 21 Beobachtet
  • B bommel_030
    @tombox
    Ich hab gerade nochmal auf meine Testinstallation geschaut. Ich kann mich auch nicht mehr anmelden.
    Kann leider nicht genau eingrenzen seit wann. Login über Webseite klappt ohne Probleme.
    Und auch wenn er Node 18 anmeckert, es ist installiert....
    host.iobtester 2022-12-01 09:25:13.467	warn	Do not restart adapter system.adapter.garmin.0 because restart loop detected
    host.iobtester 2022-12-01 09:25:13.467	info	Restart adapter system.adapter.garmin.0 because enabled
    host.iobtester 2022-12-01 09:25:13.466	error	instance system.adapter.garmin.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    garmin.0 2022-12-01 09:25:12.942	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    garmin.0 2022-12-01 09:25:12.942	info	terminating
    garmin.0 2022-12-01 09:25:12.941	error	Cannot read properties of undefined (reading 'displayName')
    garmin.0 2022-12-01 09:25:12.941	error	TypeError: Cannot read properties of undefined (reading 'displayName') at Garmin.updateDevices (/opt/iobroker/node_modules/iobroker.garmin/main.js:297:32) at Garmin.onReady (/opt/iobroker/node_modules/iobroker.garmin/main.js:74:18) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    garmin.0 2022-12-01 09:25:12.941	error	unhandled promise rejection: Cannot read properties of undefined (reading 'displayName')
    garmin.0 2022-12-01 09:25:12.941	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    garmin.0 2022-12-01 09:25:12.940	error	{"clientMessage":"Reference Error ID in error logs for further information","errorId":"1566ba08-00c8-4c8f-93e2-a92e1495ac3e","error":"WebApplicationException"}
    garmin.0 2022-12-01 09:25:12.940	error	AxiosError: Request failed with status code 403
    garmin.0 2022-12-01 09:25:12.727	error	""
    garmin.0 2022-12-01 09:25:12.727	error	AxiosError: Request failed with status code 401
    garmin.0 2022-12-01 09:25:11.301	error	Please update node to version 18 or higher
    garmin.0 2022-12-01 09:25:10.792	info	Login to Garmin
    garmin.0 2022-12-01 09:25:10.777	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.garmin#016f743f623cdbba0a844db9623ab38046e7d24f) in /opt/iobroker/node_modules/iobroker.garmin, node: v18.12.1, js-controller: 4.0.23
    host.iobtester 2022-12-01 09:25:10.233	info	instance system.adapter.garmin.0 started with pid 1143
    host.iobtester 2022-12-01 09:24:40.204	info	Restart adapter system.adapter.garmin.0 because enabled
    und
    bommel@iobtester:/$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    /usr/bin/nodejs
    v18.12.1
    /usr/bin/node
    v18.12.1
    /usr/bin/npm
    8.19.2
    nodejs:
      Installed: 18.12.1-deb-1nodesource1
      Candidate: 18.12.1-deb-1nodesource1
      Version table:
     *** 18.12.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u1 500
            500 http://security.debian.org bullseye-security/main amd64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://ftp.debian.org/debian bullseye/main amd64 Packages
    bommel@iobtester:/$
    tombox
    @bommel_030 Garmin hatte nochmal was geändert login sollte jetzt wieder gehen. Einfach neu installieren
    • T tombox
      bommel_030
      @tombox
      Danke, das wars, läuft wieder. Alle 12.583 states aktualisiert...
      • dirk1962D Offline
        dirk1962D Offline
        dirk1962
        Hallo @tombox ,
        vielen Dank für den Adapter. Ich nutze ihn mit zwei Instanzen. In der ersten Instanz ist eine Scale Index S2, ein Forerunner 235 und eine Vivoactive 3. In dieser Instanz ist alles okay. In der zweiten Instanz ist noch zusätzlich eine Vivoactive 4s und da habe ich folgende Fehlermeldungen:
        2023-01-11 16:53:10.888 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray01
        2023-01-11 16:53:10.888 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:10.934 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray02
        2023-01-11 16:53:10.934 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:10.941 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray03
        2023-01-11 16:53:10.941 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:10.944 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray04
        2023-01-11 16:53:10.944 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:10.948 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray05
        2023-01-11 16:53:10.948 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:10.953 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray06
        2023-01-11 16:53:10.953 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:10.956 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray07
        2023-01-11 16:53:10.956 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:10.960 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray08
        2023-01-11 16:53:10.960 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:10.964 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray09
        2023-01-11 16:53:10.964 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:10.967 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray10
        2023-01-11 16:53:10.967 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:10.970 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray11
        2023-01-11 16:53:10.970 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:10.974 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray12
        2023-01-11 16:53:10.974 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.017 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray13
        2023-01-11 16:53:11.017 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.021 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray14
        2023-01-11 16:53:11.021 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.065 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray15
        2023-01-11 16:53:11.065 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.069 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray16
        2023-01-11 16:53:11.069 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.114 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray17
        2023-01-11 16:53:11.115 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.117 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray18
        2023-01-11 16:53:11.117 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.122 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray19
        2023-01-11 16:53:11.122 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.126 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray20
        2023-01-11 16:53:11.126 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.130 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray21
        2023-01-11 16:53:11.130 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.134 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray22
        2023-01-11 16:53:11.134 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.138 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray23
        2023-01-11 16:53:11.138 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.142 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray24
        2023-01-11 16:53:11.142 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.146 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray25
        2023-01-11 16:53:11.146 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.151 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray26
        2023-01-11 16:53:11.151 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.155 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray27
        2023-01-11 16:53:11.155 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.182 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray28
        2023-01-11 16:53:11.182 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.187 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray29
        2023-01-11 16:53:11.187 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.192 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray30
        2023-01-11 16:53:11.192 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.199 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray31
        2023-01-11 16:53:11.199 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.204 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray32
        2023-01-11 16:53:11.204 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.208 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray33
        2023-01-11 16:53:11.208 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.213 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray34
        2023-01-11 16:53:11.213 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.218 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray35
        2023-01-11 16:53:11.218 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.223 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray36
        2023-01-11 16:53:11.224 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.228 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray37
        2023-01-11 16:53:11.229 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.234 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray38
        2023-01-11 16:53:11.234 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.239 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray39
        2023-01-11 16:53:11.239 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.246 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray40
        2023-01-11 16:53:11.246 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.251 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray41
        2023-01-11 16:53:11.251 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.255 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray42
        2023-01-11 16:53:11.255 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.260 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray43
        2023-01-11 16:53:11.260 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.264 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray44
        2023-01-11 16:53:11.264 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.269 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray45
        2023-01-11 16:53:11.269 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.274 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray46
        2023-01-11 16:53:11.274 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.279 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray47
        2023-01-11 16:53:11.279 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.284 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray48
        2023-01-11 16:53:11.284 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.289 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray49
        2023-01-11 16:53:11.289 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.294 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray50
        2023-01-11 16:53:11.294 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.298 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray51
        2023-01-11 16:53:11.298 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.303 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray52
        2023-01-11 16:53:11.303 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.308 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray53
        2023-01-11 16:53:11.308 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.313 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray54
        2023-01-11 16:53:11.313 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.317 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray55
        2023-01-11 16:53:11.317 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.322 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray56
        2023-01-11 16:53:11.322 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.326 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray57
        2023-01-11 16:53:11.327 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.332 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray58
        2023-01-11 16:53:11.332 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.336 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray59
        2023-01-11 16:53:11.336 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.342 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray60
        2023-01-11 16:53:11.342 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.346 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray61
        2023-01-11 16:53:11.346 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.352 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray62
        2023-01-11 16:53:11.352 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.356 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray63
        2023-01-11 16:53:11.356 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.361 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray64
        2023-01-11 16:53:11.362 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.366 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray65
        2023-01-11 16:53:11.366 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.371 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray66
        2023-01-11 16:53:11.371 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.375 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray67
        2023-01-11 16:53:11.375 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.381 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray68
        2023-01-11 16:53:11.381 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.385 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray69
        2023-01-11 16:53:11.385 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.391 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray70
        2023-01-11 16:53:11.391 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.395 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray71
        2023-01-11 16:53:11.395 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.407 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray72
        2023-01-11 16:53:11.407 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.411 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray73
        2023-01-11 16:53:11.412 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.418 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray74
        2023-01-11 16:53:11.418 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.422 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray75
        2023-01-11 16:53:11.422 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.428 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray76
        2023-01-11 16:53:11.428 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.433 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray77
        2023-01-11 16:53:11.433 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.440 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray78
        2023-01-11 16:53:11.440 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.445 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray79
        2023-01-11 16:53:11.445 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.452 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray80
        2023-01-11 16:53:11.452 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.458 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray81
        2023-01-11 16:53:11.458 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.464 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray82
        2023-01-11 16:53:11.465 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.469 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray83
        2023-01-11 16:53:11.469 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.476 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray84
        2023-01-11 16:53:11.476 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.480 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray85
        2023-01-11 16:53:11.480 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.487 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray86
        2023-01-11 16:53:11.487 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.493 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray87
        2023-01-11 16:53:11.493 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.497 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray88
        2023-01-11 16:53:11.497 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.504 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray89
        2023-01-11 16:53:11.504 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.509 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray90
        2023-01-11 16:53:11.509 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.516 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray91
        2023-01-11 16:53:11.516 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.521 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray92
        2023-01-11 16:53:11.521 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.528 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray93
        2023-01-11 16:53:11.528 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.532 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray94
        2023-01-11 16:53:11.532 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.539 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray95
        2023-01-11 16:53:11.539 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.543 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray96
        2023-01-11 16:53:11.543 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.549 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray97
        2023-01-11 16:53:11.549 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.554 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray98
        2023-01-11 16:53:11.554 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.560 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray99
        2023-01-11 16:53:11.561 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.565 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray100
        2023-01-11 16:53:11.565 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.571 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray101
        2023-01-11 16:53:11.571 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.575 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray102
        2023-01-11 16:53:11.575 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.581 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray103
        2023-01-11 16:53:11.581 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.585 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray104
        2023-01-11 16:53:11.585 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.589 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray105
        2023-01-11 16:53:11.589 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.595 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray106
        2023-01-11 16:53:11.595 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.599 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray107
        2023-01-11 16:53:11.599 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.604 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray108
        2023-01-11 16:53:11.604 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.609 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray109
        2023-01-11 16:53:11.609 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.613 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray110
        2023-01-11 16:53:11.613 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.617 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray111
        2023-01-11 16:53:11.617 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.622 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray112
        2023-01-11 16:53:11.622 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.625 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray113
        2023-01-11 16:53:11.625 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.629 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray114
        2023-01-11 16:53:11.629 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.634 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray115
        2023-01-11 16:53:11.634 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.637 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray116
        2023-01-11 16:53:11.637 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.682 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray117
        2023-01-11 16:53:11.682 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.686 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray118
        2023-01-11 16:53:11.686 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.732 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray119
        2023-01-11 16:53:11.732 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.735 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray120
        2023-01-11 16:53:11.735 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.739 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray121
        2023-01-11 16:53:11.739 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.785 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray122
        2023-01-11 16:53:11.785 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.829 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray123
        2023-01-11 16:53:11.829 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.833 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray124
        2023-01-11 16:53:11.833 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.877 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray125
        2023-01-11 16:53:11.877 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.922 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray126
        2023-01-11 16:53:11.922 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.926 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray127
        2023-01-11 16:53:11.926 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.980 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray128
        2023-01-11 16:53:11.980 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.984 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray129
        2023-01-11 16:53:11.984 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.988 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray130
        2023-01-11 16:53:11.988 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.993 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray131
        2023-01-11 16:53:11.993 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:11.997 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray132
        2023-01-11 16:53:11.997 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.001 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray133
        2023-01-11 16:53:12.001 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.045 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray134
        2023-01-11 16:53:12.045 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.049 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray135
        2023-01-11 16:53:12.049 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.052 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray136
        2023-01-11 16:53:12.052 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.055 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray137
        2023-01-11 16:53:12.055 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.059 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray138
        2023-01-11 16:53:12.059 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.062 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray139
        2023-01-11 16:53:12.062 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.065 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray140
        2023-01-11 16:53:12.065 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.068 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray141
        2023-01-11 16:53:12.069 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.072 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray142
        2023-01-11 16:53:12.072 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.075 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray143
        2023-01-11 16:53:12.075 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.078 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray144
        2023-01-11 16:53:12.078 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.081 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray145
        2023-01-11 16:53:12.081 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.085 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray146
        2023-01-11 16:53:12.085 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.105 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray147
        2023-01-11 16:53:12.105 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.108 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray148
        2023-01-11 16:53:12.108 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.110 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray149
        2023-01-11 16:53:12.111 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.158 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray150
        2023-01-11 16:53:12.158 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.161 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray151
        2023-01-11 16:53:12.161 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.164 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray152
        2023-01-11 16:53:12.164 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.211 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray153
        2023-01-11 16:53:12.211 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.214 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray154
        2023-01-11 16:53:12.214 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        2023-01-11 16:53:12.217 - error: garmin.1 (1909169) Cannot extract array dailystress.bodyBatteryValuesArray155
        2023-01-11 16:53:12.217 - error: garmin.1 (1909169) TypeError: Cannot convert undefined or null to object
        Hast Du eine Idee, was falsch läuft? Die Errors kommen nicht permanent, aber immer mal wieder.
        NUC8i5 mit Proxmox; Raspberrymatic in VM, iobroker, Motioneye, infuxDB und Grafana in CT.
        • dirk1962D dirk1962
          Hallo @tombox ,
          tombox
          @dirk1962 kannst du bitte die GitHub version installieren da sollte der Fehler mehr details enthalten
          dirk1962D 1 Antwort Letzte Antwort
          • T tombox
            dirk1962D Offline
            dirk1962D Offline
            dirk1962
            @tombox ,
            Ich habe die aktuelle Version von Github installiert und das sind die Errors:
            2023-01-11 20:55:56.250 - error: garmin.1 (1986553) Cannot extract array dailystress.bodyBatteryValuesArray154
            2023-01-11 20:55:56.251 - error: garmin.1 (1986553) TypeError: Cannot convert undefined or null to object
            at Function.keys (<anonymous>)
            at Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:148:40)
            at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:82:9)
            at async Json2iob.extractArray (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:256:9)
            at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.garmin/lib/json2iob.js:92:11)
            2023-01-11 20:55:56.254 - error: garmin.1 (1986553) Cannot extract array dailystress.bodyBatteryValuesArray155
            2023-01-11 20:55:56.254 - error: garmin.1 (1986553) TypeError: Cannot convert undefined or null to object
            Ich hoffe, dass es Dir hilft.
              @tombox ,
              tombox
              @dirk1962 Bitte neue github version testen ob der Fehler weg ist
              • T tombox
                dirk1962D Offline
                dirk1962D Offline
                dirk1962
                @tombox Auch mit neuer Github Version habe ich die Errors.
                2023-01-12 18:56:52.435 - error: garmin.1 (2080293) https://connect.garmin.com/modern/proxy/userstats-service/wellness/daily/Nicki_1966?fromDate=2023-01-06
                2023-01-12 18:56:52.435 - error: garmin.1 (2080293) Error: read ECONNRESET
                2023-01-12 18:56:52.798 - info: linux-control.0 (1970948) getting data from iobroker-Test (192.168.1.173:22)
                2023-01-12 18:56:53.712 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray01
                2023-01-12 18:56:53.713 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
                at Function.keys ()
                2023-01-12 18:56:53.715 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray02
                2023-01-12 18:56:53.715 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
                at Function.keys ()
                2023-01-12 18:57:01.048 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray360
                2023-01-12 18:57:01.048 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
                at Function.keys ()
                2023-01-12 18:57:01.092 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray361
                2023-01-12 18:57:01.092 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
                at Function.keys ()
                2023-01-12 18:57:01.096 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray362
                2023-01-12 18:57:01.096 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
                at Function.keys ()
                2023-01-12 18:57:01.144 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray363
                2023-01-12 18:57:01.144 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
                2023-01-12 18:57:01.145 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
                at Function.keys ()
                2023-01-12 18:57:01.148 - error: garmin.1 (2080293) Cannot extract array dailystress.bodyBatteryValuesArray364
                2023-01-12 18:57:01.148 - error: garmin.1 (2080293) TypeError: Cannot convert undefined or null to object
                Ich habe zwischendurch Fehlermeldungen rausgenommen, weil es sonst mehr als die zulässigen 100.000 Zeichen sind.
                  at Function.keys ()
                  at Function.keys ()
                  at Function.keys ()
                  at Function.keys ()
                  at Function.keys ()
                  at Function.keys ()
                  tombox
                  @dirk1962 Dann wurde nicht richtig neu installiert oder die Instanz nicht neugestartet
                  • T tombox
                    dirk1962D Offline
                    dirk1962D Offline
                    dirk1962
                    @tombox Habe den Adapter nochmals von Github geladen und beide Instanzen neu gestartet. Seitdem gibt es keine Fehlermeldungen mehr 👍 . Vielen Dank für Deine Hilfe.
                    • StuebiS Offline
                      StuebiS Offline
                      Stuebi
                      der Adapter läuft super. Danke dafür. Nur im Objekt garmin.X.activities.YY.averageSpeed werden bei mir merkwürdige Werte angezeigt.
                      Lauf:
                      ioBroker Garmin Adapter : 2,74399996
                      Garmin Connect App: 6.04 min/km
                      Beim Radfahren kann ich die Speed Werte bei averageSpeed und maxSpeed auch nicht nachvollziehen.
                      Gibt es eigentlich noch ein Feld für durchschnittliche Geschwindigkeit in Bewegung analog der Garmin Connect App.?
                      Viele Grüße
                      Stuebi
                      ioBroker auf Synology DS216+II im Docker Container
                      • Curtis777C Offline
                        Curtis777C Offline
                        Curtis777
                        Genial der Adapter sowas hab ich ewig gesucht... gibts irgendwas zu beachten bevor ich denn ausprobiere ?
                        • Stefan SchoberS Offline
                          Stefan Schober
                          Welche Funktionen hat der Adapter? Kann man darüber auch einen Alarm einstellen oder die Uhr suchen lassen?
                          Curtis777C 1 Antwort Letzte Antwort
                          • Stefan SchoberS Stefan Schober
                            Curtis777C Offline
                            Curtis777C Offline
                            Curtis777
                            @stefan-schober der Adapter gibt rein die Werte aus der Garmin Page / Garmin Backend aus.
                            Ich habe soeine Funktion nicht gesehen. bzw Datenpunkt.
                              kirbsi
                              Hallo Leute. Habt ihr auch das Probleme, dass bei eurem Garminkonto versucht wird das Passwort zu ändern? 😠 Habe das jetzt schon 3x gehabt. Garmin sperrt dann immer wieder das Konto.
                              Ich habe dann meine Email geändert aber dennoch heute wieder ein Angriff. Woher haben sie meine Emailadresse? Von diesem Adapter? Ich werde jetzt den Adapter mal deaktivieren und schauen ob es daran liegt. Habe sonst nirgendwo meinen Garmin Account angegeben.
                              Curtis777C B 2 Antworten Letzte Antwort
                              • K kirbsi
                                Curtis777C Offline
                                Curtis777C Offline
                                Curtis777
                                @kirbsi
                                Nein, habe nichts dergleichen gemerkt.
                                Betreibe ihn jetzt schon länger wüsste auch nicht wie der Adapter das gemacht haben soll.
                                Überprüfe Mal dein System auf offene Ports / Sicherheitsprobleme.
                                • K kirbsi
                                  bommel_030
                                  @kirbsi
                                  Ich habe den Adapter eine gewisse Zeit lang laufen gehabt. Nachdem Garmin das 5. Mal mein Passwort resettet hat habe ich den Adapter deaktiviert. Seitdem ist Ruhe. Ich tippe daher auf den Adapter. Konnte mich mangels Zeit noch nicht genauer damit beschäftigen.
                                  Vermute aber keinen "angriff" dahinter. Schätze Garmin ist ob der Anfragen verwirrt.
                                  Was für ein Garmin Gerät benutzt du, bzw. produzierst du 24/7 Daten wie Schritte / Puls / Aktivitäten etc. ?
                                    kirbsi
                                    @bommel_030 Genau wie bei mir . Habe jetzt mal die Logs vom Adapter überprüft im Vergleich zum Emailzeitpunkt.
                                    Kurz bevor die Email von Garmin kommt, läuft folgendes im Adapter ab.
                                    2023-03-28 10:08:10.188 - info: garmin.0 (52299) usersummary receive 401 error. Refresh Token in 60 seconds
                                    2023-03-28 10:08:10.536 - info: garmin.0 (52299) maxmet receive 401 error. Refresh Token in 60 seconds
                                    2023-03-28 10:08:10.767 - info: garmin.0 (52299) hydration receive 401 error. Refresh Token in 60 seconds
                                    2023-03-28 10:08:11.025 - info: garmin.0 (52299) dailysleep receive 401 error. Refresh Token in 60 seconds
                                    2023-03-28 10:08:11.281 - info: garmin.0 (52299) dailystress receive 401 error. Refresh Token in 60 seconds
                                    2023-03-28 10:08:11.928 - info: garmin.0 (52299) heartrate receive 401 error. Refresh Token in 60 seconds
                                    2023-03-28 10:08:12.280 - info: garmin.0 (52299) trainingstatus receive 401 error. Refresh Token in 60 seconds
                                    2023-03-28 10:08:12.512 - info: garmin.0 (52299) activities receive 401 error. Refresh Token in 60 seconds
                                    2023-03-28 10:08:12.899 - info: garmin.0 (52299) weight receive 401 error. Refresh Token in 60 seconds
                                    2023-03-28 10:08:13.192 - info: garmin.0 (52299) adhocchallenge receive 401 error. Refresh Token in 60 seconds
                                    2023-03-28 10:08:13.441 - info: garmin.0 (52299) personalrecords receive 401 error. Refresh Token in 60 seconds
                                    2023-03-28 10:09:15.848 - error: garmin.0 (52299) Failed ticket please check username and password
                                    2023-03-28 10:09:15.848 - error: garmin.0 (52299) TypeError: Cannot read properties of undefined
                                    Ich habe den Adapter 24/7 am laufen. Aktualisierungsintervat 15 min! Wie habt ihr ihn eingestellt? Wird der vielleicht zu oft abgefragt?
                                    • K kirbsi
                                      Curtis777C Offline
                                      Curtis777C Offline
                                      Curtis777
                                      @kirbsi probiere mal weniger Abfragen,
                                      Welches Gerät synced denn so oft das alle 15 Minuten notwendig ist ?
                                      • Curtis777C Curtis777
                                        kirbsi
                                        @curtis777 Ist richtig. Wollte halt immer aktuelle Daten in der Visu. Was hast du eingestellt?
                                        • K kirbsi
                                          Curtis777C Offline
                                          Curtis777C Offline
                                          Curtis777
                                          @kirbsi
                                          Das dachte ich mir auch anfangs. hab sogar alle 5 Minuten eingestellt gehabt.
                                          Allerdings kommen meine Daten "Nur" von meiner Fenix 6 am Handgelenk.
                                          Die syncronisiert nicht so oft um einen Intervall von öfter als 70-90 Minuten zu benötigen.
                                          Ich hab derzeit mal 70 Minuten Intervall aktiviert und das läuft seit ca 10.februar durchgehend.
