  4. Test Adapter OpenKNX 0.6.x
587 Beiträge 74 Kommentatoren 216.5k Aufrufe 73 Beobachtet
  • 123brokerei1 123brokerei
    ich habe leider ständige Verbindungsabbrüche. Hat mir im Zusammenhang mit dem Log jemand einen Tipp?
    023-03-08 10:22:21.846 - info: openknx.0 (3126) starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.openknx, node: v16.19.0, js-controller: 4.0.24
    2023-03-08 10:22:21.858 - info: openknx.0 (3126) Connecting to knx gateway: xxx.xxx.xxx.xx:3671 with phy. Adr: 1.1.1 minimum send delay: 50 ms debug level: debug
    2023-03-08 10:22:21.859 - info: openknx.0 (3126) /opt/iobroker/node_modules/iobroker.js-controller
    2023-03-08 10:22:21.925 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:23:21.927 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:23:24.927 - warn: openknx.0 (3126) [warn] 2023-03-08 09:23:24.927 connection timed out, retrying...
    2023-03-08 10:23:27.928 - warn: openknx.0 (3126) [warn] 2023-03-08 09:23:27.928 connection timed out, retrying...
    2023-03-08 10:23:33.931 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:23:33.939 - info: openknx.0 (3126) Connected!
    2023-03-08 10:23:33.990 - info: openknx.0 (3126) Found 0 valid KNX objects of 2 objects in adapter.
    2023-03-08 10:25:34.942 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:25:34.944 - warn: openknx.0 (3126) timed out waiting for CONNECTIONSTATE_RESPONSE
    2023-03-08 10:25:37.167 - warn: openknx.0 (2311) Connection lost
    2023-03-08 10:25:37.169 - warn: openknx.0 (2311) Could not perform strict object check of state openknx.0.info.connection: DB closed
    2023-03-08 10:25:37.169 - warn: openknx.0 (2311) get state error: Connection is closed.
    2023-03-08 10:25:37.944 - warn: openknx.0 (3126) [warn] 2023-03-08 09:25:37.944 connection timed out, retrying...
    2023-03-08 10:25:37.948 - info: openknx.0 (3126) Connected!
    2023-03-08 10:25:39.686 - info: openknx.0 (3126) [info] 2023-03-08 09:25:39.686 empty internal fsm queue due to inbound_DISCONNECT_REQUEST:
    2023-03-08 10:25:39.686 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:25:40.169 - warn: openknx.0 (2311) [warn] 2023-03-08 09:25:40.169 connection timed out, retrying...
    2023-03-08 10:25:42.688 - warn: openknx.0 (3126) [warn] 2023-03-08 09:25:42.687 connection timed out, retrying...
    2023-03-08 10:25:43.170 - warn: openknx.0 (2311) [warn] 2023-03-08 09:25:43.170 connection timed out, retrying...
    2023-03-08 10:25:45.687 - warn: openknx.0 (3126) [warn] 2023-03-08 09:25:45.687 connection timed out, retrying...
    2023-03-08 10:25:51.689 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:25:54.691 - warn: openknx.0 (3126) [warn] 2023-03-08 09:25:54.691 connection timed out, retrying...
    2023-03-08 10:25:57.692 - warn: openknx.0 (3126) [warn] 2023-03-08 09:25:57.692 connection timed out, retrying...
    2023-03-08 10:26:06.694 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:26:09.695 - warn: openknx.0 (3126) [warn] 2023-03-08 09:26:09.695 connection timed out, retrying...
    2023-03-08 10:26:12.696 - warn: openknx.0 (3126) [warn] 2023-03-08 09:26:12.696 connection timed out, retrying...
    2023-03-08 10:26:12.698 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:26:37.950 - warn: openknx.0 (3126) [warn] 2023-03-08 09:26:37.950 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2023-03-08 10:26:38.951 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:26:38.952 - warn: openknx.0 (3126) [warn] 2023-03-08 09:26:38.952 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2023-03-08 10:26:38.952 - warn: openknx.0 (3126) timed out waiting for CONNECTIONSTATE_RESPONSE
    2023-03-08 10:26:41.952 - warn: openknx.0 (3126) [warn] 2023-03-08 09:26:41.952 connection timed out, retrying...
    2023-03-08 10:26:41.953 - warn: openknx.0 (3126) [warn] 2023-03-08 09:26:41.953 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2023-03-08 10:26:44.953 - warn: openknx.0 (3126) [warn] 2023-03-08 09:26:44.953 connection timed out, retrying...
    2023-03-08 10:26:44.954 - warn: openknx.0 (3126) [warn] 2023-03-08 09:26:44.954 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2023-03-08 10:26:56.955 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:26:56.957 - warn: openknx.0 (3126) [warn] 2023-03-08 09:26:56.956 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2023-03-08 10:26:59.957 - warn: openknx.0 (3126) [warn] 2023-03-08 09:26:59.957 connection timed out, retrying...
    2023-03-08 10:26:59.958 - warn: openknx.0 (3126) [warn] 2023-03-08 09:26:59.958 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2023-03-08 10:27:02.958 - warn: openknx.0 (3126) [warn] 2023-03-08 09:27:02.958 connection timed out, retrying...
    2023-03-08 10:27:02.959 - warn: openknx.0 (3126) [warn] 2023-03-08 09:27:02.959 Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running
    2023-03-08 10:27:17.961 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:27:17.964 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:28:17.965 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:28:20.967 - warn: openknx.0 (3126) [warn] 2023-03-08 09:28:20.967 connection timed out, retrying...
    2023-03-08 10:28:22.293 - info: openknx.0 (3126) [info] 2023-03-08 09:28:22.293 empty internal fsm queue due to inbound_DISCONNECT_REQUEST:
    2023-03-08 10:28:23.967 - warn: openknx.0 (3126) [warn] 2023-03-08 09:28:23.967 connection timed out, retrying...
    2023-03-08 10:28:41.969 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:28:44.971 - warn: openknx.0 (3126) [warn] 2023-03-08 09:28:44.971 connection timed out, retrying...
    2023-03-08 10:28:44.974 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:28:44.976 - info: openknx.0 (3126) Connected!
    2023-03-08 10:28:44.979 - info: openknx.0 (3126) Connected!
    2023-03-08 10:30:46.170 - warn: openknx.0 (2311) Connection lost
    2023-03-08 10:30:46.172 - warn: openknx.0 (2311) Could not perform strict object check of state openknx.0.info.connection: DB closed
    2023-03-08 10:30:46.172 - warn: openknx.0 (2311) get state error: Connection is closed.
    2023-03-08 10:30:49.171 - warn: openknx.0 (2311) [warn] 2023-03-08 09:30:49.171 connection timed out, retrying...
    2023-03-08 10:30:52.172 - warn: openknx.0 (2311) [warn] 2023-03-08 09:30:52.172 connection timed out, retrying...
    2023-03-08 10:31:11.099 - info: openknx.0 (3126) [info] 2023-03-08 09:31:11.099 empty internal fsm queue due to inbound_DISCONNECT_REQUEST:
    2023-03-08 10:31:11.100 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:31:11.104 - info: openknx.0 (3126) Connected!
    2023-03-08 10:31:45.981 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:31:45.982 - warn: openknx.0 (3126) timed out waiting for CONNECTIONSTATE_RESPONSE
    2023-03-08 10:31:48.982 - warn: openknx.0 (3126) [warn] 2023-03-08 09:31:48.982 connection timed out, retrying...
    2023-03-08 10:31:48.987 - info: openknx.0 (3126) Connected!
    2023-03-08 10:34:49.994 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:34:49.995 - warn: openknx.0 (3126) timed out waiting for CONNECTIONSTATE_RESPONSE
    2023-03-08 10:34:52.995 - warn: openknx.0 (3126) [warn] 2023-03-08 09:34:52.995 connection timed out, retrying...
    2023-03-08 10:34:55.996 - warn: openknx.0 (3126) [warn] 2023-03-08 09:34:55.996 connection timed out, retrying...
    2023-03-08 10:35:01.997 - warn: openknx.0 (3126) Connection lost
    2023-03-08 10:35:02.003 - info: openknx.0 (3126) Connected!
    2023-03-08 10:35:55.174 - warn: openknx.0 (2311) Connection lost
    2023-03-08 10:35:55.175 - warn: openknx.0 (2311) Could not perform strict object check of state openknx.0.info.connection: DB closed
    2023-03-08 10:35:55.176 - warn: openknx.0 (2311) get state error: Connection is closed.
    2023-03-08 10:35:58.175 - warn: openknx.0 (2311) [warn] 2023-03-08 09:35:58.175 connection timed out, retrying...
    2023-03-08 10:36:01.176 - warn: openknx.0 (2311) [warn] 2023-03-08 09:36:01.176 connection timed out, retrying...
    killroy2
    #487
    @123brokerei said in Test Adapter OpenKNX 0.2.x:
    evtl hängt es mit dem js controller zusammen:
    https://github.com/iobroker-community-adapters/ioBroker.ical/issues/214
    T 123brokerei1 2 Antworten Letzte Antwort
    • K killroy2
      Tontechniker
      #488
      @killroy2 Hallo! Habe Dir gerade eine Spende über Paypal geschickt!
      Ich habe die 0.5.2 heute nochmal neu heruntergeladen. Ist es gewollt, dass alle Texte in der Instanz-Einstellung in Englisch sind, außer "IMPORT ETS XML UND SPEICHERN"? Nur eine "kleine Ungereimtheit"?!
      Hans
      • T Tontechniker
        Hans
        killroy2
        #489
        @tontechniker Herzlichen Dank für deine Spende!
        Ich mache gerade eine Überarbeitung vom Admin Menü, deswegen kann es sein dass die aktuellsten Quellen nicht mehr ganz ausgereift sind.
        Die 0.5.2 Version ist jetzt ins stable Repository gewandert und wird demnächst für alle sichtbar sein.
        • K killroy2
          123brokerei1 Offline
          123brokerei
          schrieb am zuletzt editiert von 123brokerei
          #490
          @killroy2 ich weiß nicht. Die Meldung ist von 2021 und kam seither nicht mehr auf. Mein JS-Controller ist eigentlich aktuell. Mit node red (knx ultimate) bekomme ich eine stabile Tunnelverbindung hin. Dort kann ich den Tunnel direkt angeben. Geht das im Adapter auch irgendwie? Im Log wird als physikalische Adresse 1.1.1 angezeigt, was bei mir nicht passen würde. Würde sehr gerne im ioBroker bleiben und nicht zusätzlich node red verwenden müssen.
            socke85
            #491
            Ich habe heute nodejs und auch openkx geupdatet alles aktuell leider bekomme ich den Adapter nicht mehr zum laufen, habe auch schon ältere Versionen probiert.
            Das log erzählt mir:
            ost.Jarvis
            2023-03-14 21:59:03.543	error	instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.Jarvis
            2023-03-14 21:59:03.543	error	Caught by controller[0]: }
            host.Jarvis
            2023-03-14 21:59:03.543	error	Caught by controller[0]: ]
            host.Jarvis
            2023-03-14 21:59:03.543	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/main.js'
            host.Jarvis
            2023-03-14 21:59:03.543	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
            host.Jarvis
            2023-03-14 21:59:03.543	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
            host.Jarvis
            2023-03-14 21:59:03.543	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/KnxProtocol.js',
            host.Jarvis
            2023-03-14 21:59:03.543	error	Caught by controller[0]: requireStack: [
            host.Jarvis
            2023-03-14 21:59:03.543	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
            host.Jarvis
            2023-03-14 21:59:03.543	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1057:19) {
            host.Jarvis
            2023-03-14 21:59:03.543	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:868:12)
            host.Jarvis
            2023-03-14 21:59:03.543	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1033:32)
            host.Jarvis
            2023-03-14 21:59:03.543	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
            host.Jarvis
            2023-03-14 21:59:03.542	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1155:14)
            host.Jarvis
            2023-03-14 21:59:03.542	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/KnxProtocol.js:8:16)
            host.Jarvis
            2023-03-14 21:59:03.542	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
            host.Jarvis
            2023-03-14 21:59:03.542	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1057:19)
            host.Jarvis
            2023-03-14 21:59:03.542	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:833:27)
            host.Jarvis
            2023-03-14 21:59:03.542	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
            host.Jarvis
            2023-03-14 21:59:03.542	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/main.js
            host.Jarvis
            2023-03-14 21:59:03.542	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js
            host.Jarvis
            2023-03-14 21:59:03.542	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js
            host.Jarvis
            2023-03-14 21:59:03.542	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/KnxProtocol.js
            host.Jarvis
            2023-03-14 21:59:03.542	error	Caught by controller[0]: Require stack:
            host.Jarvis
            2023-03-14 21:59:03.542	error	Caught by controller[0]: Error: Cannot find module 'binary-parser'
            host.Jarvis
            2023-03-14 21:59:03.542	error	Caught by controller[0]: ^
            host.Jarvis
            2023-03-14 21:59:03.542	error	Caught by controller[0]: throw err;
            host.Jarvis
            2023-03-14 21:59:03.542	error	Caught by controller[0]: node:internal/modules/cjs/loader:988
            host.Jarvis
            2023-03-14 21:58:57.808	error	instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.Jarvis
            2023-03-14 21:58:57.808	error	Caught by controller[0]: }
            host.Jarvis
            2023-03-14 21:58:57.808	error	Caught by controller[0]: ]
            host.Jarvis
            2023-03-14 21:58:57.807	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/main.js'
            host.Jarvis
            2023-03-14 21:58:57.807	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
            host.Jarvis
            2023-03-14 21:58:57.807	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
            host.Jarvis
            2023-03-14 21:58:57.807	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/KnxProtocol.js',
            host.Jarvis
            2023-03-14 21:58:57.807	error	Caught by controller[0]: requireStack: [
            Habt ihr eine Idee woran es liegen kann?
            F 1 Antwort Letzte Antwort
            • N Offline
              N Offline
              netfriend
              #492
              ich habe meinen openKNX-Adapter in den letzten Tagen von 0.1.22 (die seit langer Zeit stabil lief) auf die aktuelle 0.5.2 aktualisiert.
              Soweit hat alles gut funktioniert - herzlichen Dank an alle Beteiligten, vor allem @killroy2
              Mir ist lediglich aufgefallen, dass nun Werte als Dezimaltrennzeichen ein Komma verwenden, vorher war es ein Punkt.
              Ist das so gewollt? Kann man das irgendwo einstellen?
              K andreaskosA 2 Antworten Letzte Antwort
              • N netfriend
                killroy2
                #493
                @netfriend Sowas ist nicht bewusst eingebaut worden, kannst du ein Beispiel geben wo du sowas siehst?
                • N Offline
                  N Offline
                  netfriend
                  #494
                  Ja, kann ich.
                  z.B. DPT 9.001
                  0.5.2
                  01.22
                  Das selbe auch mit DPT9.005 oder DPT9.007 ...
                  oder DPT14.076 bzw. DPT14
                  Kann es sein, dass das eine allgemeine Systemeinstellung ist? Ich frage, weil ich das ganze Raspi OS neu aufgesetzt habe.
                  Ansonsten habe ich das selbe KNX-GA-Adressen.xml verwendet wie vorher auch.
                  • N netfriend
                    andreaskosA Offline
                    andreaskosA Offline
                    andreaskos
                    #495
                    @netfriend
                    Das ist eine systemweite Einstellung. Siehe Screenshot:
                    LG
                    Andreas
                    N 1 Antwort Letzte Antwort
                    • andreaskosA andreaskos
                      @netfriend
                      LG
                      Andreas
                      N Offline
                      N Offline
                      netfriend
                      #496
                      @andreaskos
                      Super, vielen Dank.
                      Das war's - geändert und iobroker neugestartet und jetzt passt's wieder. ..und ich habe gesucht und gesucht und den Wald vor lauter Bäumen nicht gesehen.
                      • S socke85
                        ost.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        host.Jarvis
                        Finkinho
                        #497
                        @socke85 ich habe den gleichen Fehler. Konntest du schon eine Lösung finden? Danke
                        • K killroy2
                          Tontechniker
                          schrieb am zuletzt editiert von Tontechniker
                          #498
                          @killroy2 Bei mir funktioniert die 0.5.3 seit ca. 3 Monaten (seit sie im GIT steht) ohne Beanstandung!
                          Hans
                          • IccubeI Offline
                            IccubeI Offline
                            Iccube
                            schrieb am zuletzt editiert von Iccube
                            #499
                            habe seit gestern das problem das ich den Adapter nicht zum laufen bekomme.
                            Habe gestern einige Adapter geupdatet seit dem startet der openknx nicht mehr.
                            Habe ein Backup von 3 Tagen eingespielt die geleich fehler meldung. Haben den Adapter auch schon gelöscht und neu installiert ohne erfolg .
                            Habe auch andere versionen vom Adapter versucht gleiche fehler.
                            Hat einer einen Tipp
                            Meine node version :
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            /usr/bin/npx
                            v18.16.0
                            v18.16.0
                            9.5.1
                            9.5.1
                            Fehler beim Starten :
                            2023-06-21 08:55:08.491 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1078
                            2023-06-21 08:55:08.492 - error: host.iobroker Caught by controller[0]: throw err;
                            2023-06-21 08:55:08.492 - error: host.iobroker Caught by controller[0]: ^
                            2023-06-21 08:55:08.492 - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'binary-parser'
                            2023-06-21 08:55:08.492 - error: host.iobroker Caught by controller[0]: Require stack:
                            2023-06-21 08:55:08.492 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/KnxProtocol.js
                            2023-06-21 08:55:08.492 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js
                            2023-06-21 08:55:08.492 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js
                            2023-06-21 08:55:08.492 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/main.js
                            2023-06-21 08:55:08.492 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
                            2023-06-21 08:55:08.492 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:920:27)
                            2023-06-21 08:55:08.492 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19)
                            2023-06-21 08:55:08.492 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
                            2023-06-21 08:55:08.493 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/KnxProtocol.js:8:16)
                            2023-06-21 08:55:08.493 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1254:14)
                            2023-06-21 08:55:08.493 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                            2023-06-21 08:55:08.493 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1117:32)
                            2023-06-21 08:55:08.493 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:958:12)
                            2023-06-21 08:55:08.493 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1141:19) {
                            2023-06-21 08:55:08.493 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                            2023-06-21 08:55:08.493 - error: host.iobroker Caught by controller[0]: requireStack: [
                            2023-06-21 08:55:08.493 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/KnxProtocol.js',
                            2023-06-21 08:55:08.493 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
                            2023-06-21 08:55:08.493 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
                            2023-06-21 08:55:08.493 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/main.js'
                            2023-06-21 08:55:08.493 - error: host.iobroker Caught by controller[0]: ]
                            2023-06-21 08:55:08.493 - error: host.iobroker Caught by controller[0]: }
                            2023-06-21 08:55:08.493 - error: host.iobroker Caught by controller[0]: Node.js v18.16.0
                            2023-06-21 08:55:08.493 - error: host.iobroker instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            im Log stehet das er den binary-Parser nicht finden kann ist aber installiert bzw.habe ich den noch mal installiert.
                            B K 2 Antworten Letzte Antwort
                            • 123brokerei1 Offline
                              123brokerei
                              #500
                              ich versuche gerade seit Stunden für eine GA ein GraupValueRead über iobroker auf den Bus zu bekommen um dann eine Response zu erhalten. Leider schaffe ich es aber immer nur ein GroupValueWrite zu generieren.
                              Wie gehe ich vor:
                              Der DP hat write = true und read = true. Das KO hat das KÜL-Flag
                              Jetzt schreibe ich einen beliebigen Wert in den DP, was im Gruppenmonitor dann ein GroupValueWrite mit diesem Wert auslöst. Das generiert dann eben nicht die gewünschte response.
                              Bei einem Neustart des Adapter wird die GA erfolgreich abgefragt. Es scheint also grundsätzlich zu gehen. Aber wie muss ich vorgehen, wenn ich eine GA manuell abrufen möchte?
                                Wie gehe ich vor:
                                Tontechniker
                                #501
                                @123brokerei Hallo, ich habe mir mit NodeRed und KNX Ultimate (in NodeRed einbunden) beholfen.
                                Wenn Du keine andere Möglichkeit findest, kann ich Dir die Einstellungen in der Abfrage-Node schicken.
                                Habe mir eine "festes" false genommen und mache alle 6 Minuten ein read auf die KNX-Adresse. Ich bekomme zwar von dem Gerät bei Änderungen der Messwerte die Daten, aber für die grafischen Darstellung benötige ich ein festes Abfrageinterwall. Geht vermutlich einfacher, aber es funktioniert.
                                123brokerei1 1 Antwort Letzte Antwort
                                • T Tontechniker
                                  123brokerei
                                  #502
                                  @tontechniker erst mal vielen Dank für den zweiten Ansatz. Wenn alles nichts hilft würde ich nochmal auf dein Angebot zurück kommen.
                                  @killroy2 Kannst du vielleicht kurz erklären, wie man ein groupvalueread auf den Bus aus dem Adapter/den Objekten initiiert? Vielleicht ergibt sich aus der Erläuterung mein Fehler.
                                  Ich verstehe glaube noch nicht ganz, was in der Doku des Adapters gemeint ist mit "Der Versand kann durch Schreiben eines Kommunikationsobjekts mit Kommentar ausgelöst werden."
                                    123brokerei
                                    #503
                                    Hm keiner eine Idee wie man über die Objekte einen GroupValueRead auf den Bus bringen kann?
                                    P andreaskosA 2 Antworten Letzte Antwort
                                      ple
                                      #504
                                      @123brokerei sagte in Test Adapter OpenKNX 0.2.x:
                                      kann
                                      Mh, glaube ich stehe gerade vor dem selben Problem und bin mir nicht sicher, ob das groupvalueread das richtige ist.
                                      Was würde passieren, wenn iob gestoppt ist und jemand öffnet das Fenster/Garagentor. werden beim Start alle Gruppenadresse die z.B. ein RM beinhalten neu angefragt?
                                      Mein KNX läuft soweit alles, aber die feinhalten fehlen halt noch.
                                      Gruß und Danke
                                      Intel Nuc + Proxmox
                                        Tontechniker
                                        #505
                                        Hallo!
                                        Vielleicht kann mir hier jemand helfen?
                                        Ich habe versucht unter Instanzen und openknx.0 die ALIAS GENERATION auszuführen. Nach einigen Sekunden kommt ein Fenster und die Meldung "generate 0 aliases". In den Objekten wird auch unter alias.0 kein alias angezeigt.
                                        Was mache ich falsch?
                                          andreaskosA Offline
                                          andreaskosA Offline
                                          andreaskos
                                          schrieb am zuletzt editiert von andreaskos
                                          #506
                                          Hi @123brokerei !
                                          Es ist glaub ich so: Wenn du einen Datenpunkt mit der Eigenschaft
                                          "write": false
                                          hast, dann wird durch das Schreiben auf diesen Datenpunkt, z.B. in einem Script durch
                                          setState("openknx.0.id_von_deinem_datenpunkt", true);
                                          ein GroupValueRead ausgelöst am KNX-Bus.
                                          LG Andreas
