5.8k Beiträge 156 Kommentatoren 5.0m Aufrufe 138 Beobachtet
  • Chris76eC Chris76e
    Wenn man AWEKAS nutzt kann man sich auch von dort die Daten per API holen, da wird auch die WindböeMAX geloggt.
      "fetchdate": 1678981151,
      "error": null,
      "current":
      "datatimestamp": 1678981114,
      "timeoffset": 3600,
      "conditiontimestamp": null,
      "condition": 0,
      "temperature": 14.8,
      "dewpoint": 3.8,
      "windchill": 14.8,
      "wetbulbtemperature": 9.32,
      "humidity": 47,
      "airpress_rel": null,
      "tendency": 0,
      "precipitation": 0,
      "rainrate": 0,
      "itsraining": false,
      "windspeed": 1.5,
      "gustspeed": 1.8,
      "winddirection": 252,
      "uv": 0,
      "solar": 82,
      "brightness": null,
      "suntime": null,
      "snowheighttimestamp": null,
      "snowheight": null,
      "temp1": null,
      "temp2": null,
      "temp3": null,
      "temp4": null,
      "humidity1": null,
      "humidity2": null,
      "humidity3": null,
      "humidity4": null,
      "soilmoisture1": null,
      "soilmoisture2": null,
      "soilmoisture3": null,
      "soilmoisture4": null,
      "leafwetness1": null,
      "leafwetness2": null,
      "indoortemperature": 16.5,
      "indoorhumidity": 44,
      "airquality_pm1": null,
      "airquality_pm2": null,
      "airquality_pm10": null
      "1h":
      "precipitation_1h": null
      "day":
      "temp_min": 3.7,
      "temp_min_ts": 1678933951,
      "temp_max": 15.6,
      "temp_max_ts": 1678977423,
      "dewpoint_min": -0.8,
      "dewpoint_min_ts": 1678921438,
      "dewpoint_max": 4.6,
      "dewpoint_max_ts": 1678979790,
      "hum_min": 44,
      "hum_min_ts": 1678974335,
      "hum_max": 78,
      "hum_max_ts": 1678955582,
      "airp_rel_min": null,
      "airp_rel_min_ts": null,
      "airp_rel_max": null,
      "airp_rel_max_ts": null,
      "windspeed_min": 0,
      "windspeed_min_ts": 1678921566,
      "windspeed_max": 10.8,
      "windspeed_max_ts": 1678972714,
      "winddir_max": 216,
      "gustspeed_min": 0,
      "gustspeed_min_ts": 1678921566,
      "gustspeed_max": 16.6,
      "gustspeed_max_ts": 1678972714,
      "gustdir_max": 216,
      "rainrate_max": 0,
      "rainrate_max_ts": 1678921566,
      "precipitation_24h": 0,
      "brightness_max": null,
      "brightness_max_ts": null,
      "solar_max": 493,
      "solar_max_ts": 1678961647,
      "uv_max": 4,
      "uv_max_ts": 1678961647,
      "intemp_min": 16.3,
      "intemp_min_ts": 1678942832,
      "intemp_max": 17,
      "intemp_max_ts": 1678921263,
      "inhum_min": 44,
      "inhum_min_ts": 1678963262,
      "inhum_max": 46,
      "inhum_max_ts": 1678921263,
    NegaleinN
    NegaleinN
    Negalein
    #4634
    @chris76e sagte in [Linux Shell-Skript] WLAN-Wetterstation:
    Ja, geht auch.
    Aber warum ein extra Weg (Script), wenns auch mit SBorgs Weg geht?
    ° Fixer ---> iob fix
    • NashraN Nashra
      @negalein sagte in [Linux Shell-Skript] WLAN-Wetterstation:
      @sborg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
      Euer Part = es muss "Wind_max" in InfluxDB geloggt werden (Aufbewahrung zumindest die letzten 24h)
      Ah, ok.
      Den logge ich sowieso.
      Mein Part... 😟
      Dann ist wieder mal ein Kaffee fällig. ;)
      Dem schließe ich mich an ☕
      SBorgS
      SBorgS
      SBorg
      #4635
      @nashra sagte in [Linux Shell-Skript] WLAN-Wetterstation:
      Danke, dass war aber schon ein ordentlicher Pott 👍 😎
      Ich habe jetzt 0:00 Uhr bis aktuelle Uhrzeit umgesetzt. Folgt heute nach dem Release der V3.0.0 zum testen wenn nichts dazwischen kommt.
      Die Idee mit Awekas finde ich aber auch nicht schlecht, gerade wenn man den Wert möchte aber kein InfluxDB einsetzt.
      Für mich persönlich allerdings offen gestanden nichts, da ich so wenig wie nur irgend möglich von extern oder Cloud-Diensten abhängig sein möchte ;)
      LG SBorg ( SBorg auf GitHub)
      • SBorgS SBorg
        NashraN
        NashraN
        Nashra
        Most Active Forum Testing
        #4636
        Dachte wenn es länger dauert brauchst Du viel Kaffee 😁
        Aber auch für die vielen Hilfen von dir 👍
        ok, werden dann berichten
        Warum zwei Sachen wenn es auch mit einem geht 😉
        Gruß Ralf
        • SBorgS
          SBorgS
          SBorg
          #4637
          Da keine offensichtlichen Fehler aufgetreten sind:
          Neues Breaking (!) Release des Wetterstation WLAN-Skriptes auf GitHub V3.0.0
          • ~ Breaking Release / Support für (und nur noch!) InfluxDB V2.x / Issue #41
          • ~ Mindestintervall von 65 Sekunden beim Datenversand an AWEKAS.at
          • + Support Zusatzsensor Curconsa FT0300 / Pull Request #55 (LukasTr1980)
          • ~ Anzahl maximaler interner Sensoren von 30 auf 35 angehoben
          Wie immer zu finden im GitHub
          Update-Routine von Vorgängerversion:
          • aktuellen WS-Updater nutzen (Download falls älter als V2.12.1: wget -O ws_updater.sh https://raw.githubusercontent.com/SBorg2014/WLAN-Wetterstation/master/ws_updater.sh)
          • ./ws_updater.sh im Installationsverzeichnis ausführen
          • Menüpunkt "4" wählen und die Fragen beantworten
          • wetterstation.js muss ebenfalls im JavaScript-Adapter ersetzt und einmalig ausgeführt werden (falls man den Curconsa-Sensor nutzt)
          Update nur durchführen falls man auch InfluxDB V2.x nutzt!
          Die Release-Version ist mit dem letzten Beta-Release identisch!
          • SBorgS
            SBorgS
            SBorg
            #4638
            ...und OT + in eigener Sache,
            auch einen Dank @ilovegym für die Unterstützung. Danke 👍 ☕ 🍩
            ...und nicht zu vergessen die Tage von @Negalein , hier nochmals ein dickes Danke 🤘
            Warum? Da bin ich noch immer zweigeteilt. Hier sich zu bedanken sieht dann schon fast nach Nötigung aus mir etwas spenden zu müssen. Allerdings weit gefehlt, das ändert bei mir nichts. Es macht nichts besser oder schlechter, oder hat einen Einfluss darauf was es demnächst gibt oder auch nicht. Jeder kann seinen Wunsch äußern und jeder bekommt auch geholfen. Ich wäge nur ab ob das Sinn gibt, oder ob das nur mit großem Aufwand möglich ist, oder, oder...
            Ich bin aber Baujahr in den sechzigern und bei mir gehört ein "Bitte" und "Danke" einfach dazu ;)
            ...und wenn es sich jetzt auch "großkotzig" anhört, ich hatte auch schon mal 1-2 € Spenden. Nicht dass ich das nicht zu schätzen wüsste, aber laßt das lieber sein und trinkt dann lieber einen Schluck Bier oder sonst was auf mein Wohl.
            PayPal hat auch Gebühren für Spenden eingeführt. Bei kleinen Beträgen freut das nur PayPal, denn ich muss immer mindestens 60 Cent an Gebühren bezahlen. Von einem Euro kommen also gerade mal 40 Cent bei mir an und ihr schmeißt PayPal 60 Cent in den Rachen...
            NashraN ? 2 Antworten Letzte Antwort
            • SBorgS SBorg
              NashraN
              NashraN
              Nashra
              #4639
              Richtig, so sind wir erzogen worden in den 50/60iger Jahren 👍
              Und man glaubt nicht wie weit man damit kommen kann 😉
              Das ist ja wohl ein Witz, wußte ich echt nicht und finde das nicht gut.
              Gruß Ralf
              • NashraN Nashra
                SBorgS
                SBorgS
                SBorg
                #4640
                Ist jetzt zwar nicht mehr so richtig, aber warum kann sich Hr. E. Musk wohl SpaceX und Tesla leisten ;)
                Ich habe jetzt auch die neue Beta hochgeladen. Test macht nur für diejenigen Sinn bei denen es keine "Windböe max." seitens der Station gibt.
                Einfach wetterstation.sh + *.sub tauschen (conf bleibt aktuell) und Service mittels sudo systemctl restart wetterstation neu starten. Wenn ich nichts falsch gemacht habe (nochmal erwähnt, ich konnte die Funktion nicht testen) sollte dann jede volle 15 Minuten der Wert aktualisiert werden (bzw. ts / lc sich ändern). Ohne Wind sollte zumindest eine "0" im DP landen, sonst halt der aktuelle Maximalwert seit 0:00 Uhr.
                NashraN NegaleinN 2 Antworten Letzte Antwort
                • Chris76eC
                  Chris76eC
                  Chris76e
                  #4641
                  Kann vieleicht jemand jetzt ne Art Zusammungfassung/Anleitung machen was man alles umstellen usw. muss um beim Wetterscript aktuell zubleiben? Habe zwar von Anfang an das Thema verfolgt, blicke jetzt aber nicht mehr richtig durch was wo und wie alles angepasst werden muss. 🤔
                  • SBorgS SBorg
                    NashraN
                    NashraN
                    Nashra
                    #4642
                    Habe die Daten getauscht und um 17:10 Uhr einen restart durchgeführt.
                    Ok, Wind ist nicht viel los aber bis jetzt keine aktualisierung des DP.
                    Gruß Ralf
                    • SBorgS SBorg
                      #4643
                      @sborg
                      gern doch!
                      hab gerade mal die V3.0 neu installieren muessen, auf m alten Pi 3, da kommt immer ein syntax error, aber es funktioniert soweit..., ist das normal?
                      ilovegym@zweiberry /opt/wetterstation $ sudo systemctl status wetterstation.service
                      ● wetterstation.service - Service für ioBroker Wetterstation
                         Loaded: loaded (/etc/systemd/system/wetterstation.service; enabled; vendor preset: enabled)
                         Active: active (running) since Fri 2023-03-17 19:07:12 CET; 28min ago
                       Main PID: 20105 (wetterstation.s)
                          Tasks: 3 (limit: 2059)
                         CGroup: /system.slice/wetterstation.service
                                 ├─ 7649 /bin/bash /opt/wetterstation/wetterstation.sh
                                 ├─ 7650 curl -s HTTP://10.1.1.2:8087/set/0_userdata.0.Wetterstation.Aussentemperatur_Trend?value=-1.11&ack=true&user=&pass=
                                 └─20105 /bin/bash /opt/wetterstation/wetterstation.sh
                      Mar 17 19:09:26 zweiberry wetterstation.sh[20105]: (standard_in) 1: syntax error
                      Mar 17 19:10:32 zweiberry wetterstation.sh[20105]: (standard_in) 1: syntax error
                      Mar 17 19:10:32 zweiberry wetterstation.sh[20105]: (standard_in) 12: syntax error
                      Mar 17 19:10:33 zweiberry wetterstation.sh[20105]: (standard_in) 1: syntax error
                      Mar 17 19:11:39 zweiberry wetterstation.sh[20105]: (standard_in) 1: syntax error
                      Mar 17 19:12:45 zweiberry wetterstation.sh[20105]: (standard_in) 1: syntax error
                      Mar 17 19:13:51 zweiberry wetterstation.sh[20105]: (standard_in) 1: syntax error
                      Mar 17 19:14:57 zweiberry wetterstation.sh[20105]: (standard_in) 1: syntax error
                      Mar 17 19:16:03 zweiberry wetterstation.sh[20105]: (standard_in) 1: syntax error
                      Mar 17 19:17:09 zweiberry wetterstation.sh[20105]: (standard_in) 1: syntax error
                      ilovegym@zweiberry /opt/wetterstation $ sudo nano wetterstation.sh
                      • SBorgS SBorg
                        NegaleinN
                        NegaleinN
                        Negalein
                        #4644
                        Danke!!
                        Denke es funktioniert (wenn er erst ab tausch von .sub & .sh rechnet).
                        wenn er aber heute schon ab 00:00 Uhr rechnet, dann stimmt noch was nicht.
                        lt. Awekas
                        Edit: ts / lc steht auf 19.2.2023
                        • NegaleinN Negalein
                          Danke!!
                          lt. Awekas
                          SBorgS
                          SBorgS
                          SBorg
                          schrieb am zuletzt editiert von SBorg
                          #4645
                          @negalein / @Nashra Mein Fehler, Klammer vergessen.
                          Entweder sh neu von GitHub laden und Service neu starten,
                          oder in Zeile 387 der wetterstation.sh die Klammer hinzufügen und Service neu starten:
                          von $MESSWERTE[21] in ${MESSWERTE[21]} ändern
                            @sborg
                            gern doch!
                            SBorgS
                            SBorgS
                            SBorg
                            #4646
                            @ilovegym sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                            ist das normal?
                            Nein, da stimmt etwas bei dir nicht. Er kann da einen Wert nicht lesen (leider ist da bash nicht sehr gesprächig). Es aktualisiert sich wirklich alles ?
                            Bist du von "javascript" nach "0_userdata" umgezogen? Ev. fehlt da noch ein DP, oder du hast nicht alle Windboe "erwischt"...
                              SBorgS
                              SBorgS
                              SBorg
                              #4647
                              Kommt darauf an was du genau machen willst, InfluxDB nutzen (V1 oder V2; Skript V3 nur noch InfluxDB V2.x), falls nötig von "javascript --> 0_userdata" umziehen (ist nicht nötig, man kann auch bei "javascript" bleiben).
                              Aktuell wäre V3 des Skriptes und nach "0_userdata" umziehen, aber gerade letztes hat natürlich Auswirkungen auf eigene Skripte, VIS, usw.
                              Chris76eC 1 Antwort Letzte Antwort
                              • SBorgS SBorg
                                Chris76eC
                                Chris76eC
                                Chris76e
                                #4648
                                @sborg
                                Möchte halt gerne immer das aktuelle Wetterscript nutzen, somit muss ich ja auf influxDB V2.x gehen. Hier habe ich den anschluss verpasst wie man genau die alten Daten aus der V1 in die neue DB bekommt. Ob die DP´s in javascript oder 0_userdata liegen ist mir egal, die paar scripte die ich habe und die Anzeigen in VIS kann ich ja anpassen.
                                • SBorgS SBorg
                                  NashraN
                                  NashraN
                                  Nashra
                                  schrieb am zuletzt editiert von Nashra
                                  #4649
                                  erledigt und wird angezeigt 👍
                                  geht das auch alle 5 Minuten 😀
                                  Gruß Ralf
                                  SBorgS 2 Antworten Letzte Antwort
                                  • SBorgS SBorg
                                    ist das normal?
                                    #4650
                                    @sborg
                                    Danke, hast recht, mit mir stimmt was nicht 😄😂🙈🙈🙈
                                    Hab’s gefunden, war ne boe !
                                    • SBorgS SBorg
                                      NegaleinN
                                      NegaleinN
                                      Negalein
                                      #4651
                                      Zeitstempel ändert sich zur vollen 15. Minute
                                      zuletzt geändert bleibt beim 19.2.2023
                                      lt. Awekas müsste zumindest um 15:35 was im DP stehen.
                                        @sborg
                                        SBorgS
                                        SBorgS
                                        SBorg
                                        #4652
                                        😊 ...aber nicht mit sondern bei [m/d]ir...
                                        • SBorgS SBorg
                                          #4653
                                          OT - sowohl als auch haha 😂
                                          83.9k
