  4. backitup bricht bei sicherung zigbee2mqtt ab
    5.5k
35 Beiträge 6 Kommentatoren 3.8k Aufrufe 5 Beobachtet
  • simatecS simatec
    @arteck Jup sieht ganz danach aus... Das ist halt wie erwartet ein Problem mit unterschiedlichen Usern und dann halt ein Backup über iobroker.
    Backitup wird ja logischerweise vom User "iobroker" ausgeführt.
    @rotamint Stelle mal bitte Backitup auf Debuglog und poste mal die komplette Ausgabe vom Backupprozess (bitte gefiltert nach Backitup)
    rotamint
    @simatec Danke für Deine Mühe:
    backitup.0
    	2023-03-10 21:13:45.931	error	[iobroker] Error: EISDIR: illegal operation on a directory, read
    backitup.0
    	2023-03-10 21:13:45.930	error	[iobroker/zigbee2mqtt] Error: EISDIR: illegal operation on a directory, read
    backitup.0
    backitup.0
    	2023-03-10 21:13:45.905	debug	[iobroker/zigbee2mqtt] detected Zigbee2MQTT file: state.json
    backitup.0
    	2023-03-10 21:13:45.904	debug	[iobroker/zigbee2mqtt] detected Zigbee2MQTT file: log
    backitup.0
    	2023-03-10 21:13:45.903	debug	[iobroker/zigbee2mqtt] detected Zigbee2MQTT file: database.db
    backitup.0
    	2023-03-10 21:13:45.903	debug	[iobroker/zigbee2mqtt] detected Zigbee2MQTT file: coordinator_backup.json
    backitup.0
    	2023-03-10 21:13:45.901	debug	[iobroker/zigbee2mqtt] detected Zigbee2MQTT file: configuration.yaml
    backitup.0
    	2023-03-10 21:13:45.901	debug	[iobroker/zigbee2mqtt] compress from Zigbee2MQTT started ...
    backitup.0
    	2023-03-10 21:13:45.900	debug	[iobroker/zigbee2mqtt] Created new zigbee2mqtt_tmp directory
    backitup.0
    	2023-03-10 21:13:45.886	debug	[iobroker/zigbee2mqtt] old zigbee2mqtt_tmp directory "/opt/iobroker/backups/zigbee2mqtt_tmp" successfully deleted
    backitup.0
    	2023-03-10 21:13:45.258	debug	[iobroker/zigbee2mqtt] Try deleting the old zigbee2mqtt_tmp directory: "/opt/iobroker/backups/zigbee2mqtt_tmp"
    backitup.0
    	2023-03-10 21:13:44.588	debug	[iobroker/zigbee] done
    backitup.0
    	2023-03-10 21:13:44.587	debug	[iobroker/zigbee] found zigbee database: zigbee.0
    backitup.0
    	2023-03-10 21:13:44.432	debug	[iobroker/historyDB] done
    backitup.0
    	2023-03-10 21:13:44.430	debug	[iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2023_03_10-21_13_26_backupiobroker.tar.gz
    backitup.0
    	2023-03-10 21:13:36.003	debug	[iobroker/historyDB] Packed 6MB so far...
    backitup.0
    	2023-03-10 21:13:26.000	debug	[iobroker/historyDB] compress from historyDB started ...
    backitup.0
    	2023-03-10 21:13:25.096	debug	[iobroker/iobroker] done
    backitup.0
    	2023-03-10 21:13:23.365	debug	[iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2023_03_10-21_13_02_backupiobroker.tar.gz
    backitup.0
    	2023-03-10 21:13:11.478	debug	[iobroker/iobroker] host.ioBroker 13660 objects saved
    backitup.0
    	2023-03-10 21:13:06.234	debug	[iobroker/iobroker] host.ioBroker 10614 states saved
    backitup.0
    	2023-03-10 21:13:01.880	debug	[iobroker/mount] done
    backitup.0
    	2023-03-10 21:13:01.876	debug	[iobroker/mount] mount successfully completed
    backitup.0
    	2023-03-10 21:13:01.584	debug	[iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=IoBroker,password=****,domain=SynologyDS218j,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.16.9/IoBroker_Backup/ /opt/iobroker/backups"
    backitup.0
    	2023-03-10 21:13:01.582	debug	[iobroker/mount] noserverino option: false
    backitup.0
    	2023-03-10 21:12:51.579	debug	Backup has started ...
    backitup.0
    	2023-03-10 21:12:51.508	debug	The local storage check was completed successfully. On the host "ioBroker" are currently 47995 MB free space available!
    backitup.0
    	2023-03-10 21:12:47.670	debug	The local storage check was completed successfully. On the host "ioBroker" are currently 47995 MB free space available!
    • R rotamint
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      simatecS Offline
      simatecS Offline
      simatec
      @rotamint Kannst du mir den Inhalt von /data mal zeigen
      ls -l /opt/zigbee2mqtt/data
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      R 1 Antwort Letzte Antwort
      • arteckA arteck
        @simatec also was liegts es an den rechten ??
        JLegJ Offline
        JLegJ Offline
        JLeg
        @arteck sagte in backitup bricht bei sicherung zigbee2mqtt ab:
        imo: eher nicht. EISDIR bedeutet ‚Error, is a directory‘ => jemand oder etwas versucht ein Directory als ‚Datei‘ zu lesen
        • simatecS simatec
          rotamint
          @simatec sagte in backitup bricht bei sicherung zigbee2mqtt ab:
          pi@ioBroker:~ $ ls -l /opt/zigbee2mqtt/data
          insgesamt 60
          -rw-r--r--  1 pi pi  3559 10. Mär 10:13 configuration.yaml
          -rw-r--r--  1 pi pi  7546 10. Mär 10:24 coordinator_backup.json
          -rw-r--r--  1 pi pi 35566 10. Mär 20:35 database.db
          drwxr-xr-x 12 pi pi  4096 10. Mär 10:25 log
          -rw-r--r--  1 pi pi  7019 10. Mär 21:20 state.json
          pi@ioBroker:~ $
          • R rotamint
            insgesamt 60
            pi@ioBroker:~ $
            simatecS Offline
            simatecS Offline
            simatec
            @rotamint Gut das sollten bis auf den Log Ordner alle wichtigen Dateien sein
            @arteck Ist das korrekt?
            arteckA simatecS 2 Antworten Letzte Antwort
            • simatecS simatec
              arteckA Offline
              arteckA Offline
              arteck
              @simatec jo genau alles was im data liegt ausser log.. da sind aber noch mehr dateien.. kommt auf die konfiguration an ...
              also würde ich nur den log ausschliessen..
              • arteckA arteck
                simatecS Offline
                simatecS Offline
                simatec
                @arteck hab ich erstmal so angepasst und läuft auch. Müsste ich aber in der Doku aufnehmen, wie der Pfad aussehen müsste.
                Oder habt ihr den Pfad im zigbee2mqtt Adapter irgendwo definiert, wo Backitup sich den direkt aus der Config holen kann?
                Hintergrund ist, dass es im Docker ja etwas anders vom Pfad ausschaut. Da liegt das Volume ja direkt auf dem data Pfad.
                Restore ist gerade zwecks Dateirechten noch tricky. Muss ich heute mal schauen.
                • simatecS Offline
                  simatecS Offline
                  simatec
                  @Thomas-Braun Hast du als Linux Guru ne sinnvolle Idee, wie man den Config Ordner für den User iobroker sinnvoll Schreibberechtigungen geben kann?
                  Will es halt Userfreundlich machen und nicht die einzelnen Dateirechte anpassen
                  Meine Idee war ähnlich wie bei redis zu arbeiten.
                  sudo usermod -a -G <was-auch-immer-für-eine-User-Gruppe> iobroker
                  • simatecS simatec
                    @simatec
                    Gibt es keine Gruppe dafür? Hab mit mqtt2zigbee noch nie herumgespielt und kenne die default-Rechte da nicht.
                      @simatec
                      simatecS Offline
                      simatecS Offline
                      simatec
                      @thomas-braun So wie ich das sehe, gibt es die nicht.
                      Läuft wohl wie im Beispiel hier unter pi:pi
                      • simatecS simatec
                        @simatec
                        Ich würde dann glaube ich auf meinem System eine Gruppe 'mqtt2zigbee' anlegen und die Rechte entsprechend vergeben. Dann würde ein Backup über die Gruppenrechte ermöglicht.
                        • simatecS simatec
                          simatecS Offline
                          simatecS Offline
                          simatec
                          @simatec Ich habe in der v2.6.11 Anpassungen für das Zigbee2MQTT Backup gemacht.
                          Wichtig ist die richtige Pfadangabe zu den Config Files.
                          Des Weiteren muss der User "iobroker" Zugriff auf die Gruppe pi haben, damit er in deinem Fall an die Daten kommt ud sie auch lesen und schreiben darf.
                          sudo usermod -a -G pi iobroker
                          sudo reboot
                          Die v.2.6.11 wird gerade gepusht
                          • simatecS simatec
                            sudo reboot
                            rotamint
                            @simatec Herausragend! Vielen Dank!
                            backitup.0
                            	2023-03-11 17:33:14.292	debug	[iobroker] exec: done
                            backitup.0
                            	2023-03-11 17:33:14.141	debug	[iobroker/umount] done
                            backitup.0
                            	2023-03-11 17:33:14.139	debug	[iobroker/umount] umount successfully completed
                            backitup.0
                            	2023-03-11 17:33:09.076	debug	[iobroker/umount] mount activ, umount is started ...
                            backitup.0
                            	2023-03-11 17:33:08.876	debug	[iobroker/historyJSON] done
                            backitup.0
                            	2023-03-11 17:33:08.876	debug	[iobroker/historyJSON] new history json values created
                            backitup.0
                            	2023-03-11 17:33:08.709	debug	[iobroker/historyHTML] done
                            backitup.0
                            	2023-03-11 17:33:08.708	debug	[iobroker/historyHTML] new history html values created
                            backitup.0
                            	2023-03-11 17:33:07.605	debug	[iobroker/clean] done
                            backitup.0
                            	2023-03-11 17:33:07.603	debug	[iobroker/clean] No older backup files are deleted, because this backup was started manually
                            backitup.0
                            	2023-03-11 17:33:07.000	debug	[iobroker/cifs] done
                            backitup.0
                            	2023-03-11 17:33:06.999	debug	[iobroker/cifs] used copy path: /IoBroker_Backup/
                            backitup.0
                            	2023-03-11 17:33:05.644	debug	[iobroker/zigbee2mqtt] done
                            backitup.0
                            	2023-03-11 17:33:05.499	debug	[iobroker/zigbee2mqtt] Try deleting the old zigbee2mqtt tmp directory: "/opt/iobroker/backups/zigbee2mqtt_tmp"
                            backitup.0
                            	2023-03-11 17:33:05.498	debug	[iobroker/zigbee2mqtt] Backup created: /opt/iobroker/backups/zigbee2mqtt_2023_03_11-17_33_04_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:33:05.496	debug	[iobroker/zigbee2mqtt] Backup created: /opt/iobroker/backups/zigbee2mqtt_2023_03_11-17_33_04_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:33:05.391	debug	[iobroker/zigbee2mqtt] Zigbee2MQTT tmp copy finish
                            backitup.0
                            	2023-03-11 17:33:05.337	debug	[iobroker/zigbee2mqtt] compress from Zigbee2MQTT started ...
                            backitup.0
                            	2023-03-11 17:33:05.337	debug	[iobroker/zigbee2mqtt] Created noderedtmp directory
                            backitup.0
                            	2023-03-11 17:33:03.979	debug	[iobroker/zigbee] done
                            backitup.0
                            	2023-03-11 17:33:03.979	debug	[iobroker/zigbee] found zigbee database: zigbee.0
                            backitup.0
                            	2023-03-11 17:33:03.824	debug	[iobroker/historyDB] done
                            backitup.0
                            	2023-03-11 17:33:03.822	debug	[iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2023_03_11-17_32_48_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:32:59.012	debug	[iobroker/historyDB] Packed 8MB so far...
                            backitup.0
                            	2023-03-11 17:32:48.997	debug	[iobroker/historyDB] compress from historyDB started ...
                            backitup.0
                            	2023-03-11 17:32:48.092	debug	[iobroker/iobroker] done
                            backitup.0
                            	2023-03-11 17:32:46.575	debug	[iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2023_03_11-17_32_25_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:32:34.232	debug	[iobroker/iobroker] host.ioBroker 13667 objects saved
                            backitup.0
                            	2023-03-11 17:32:29.720	debug	[iobroker/iobroker] host.ioBroker 10660 states saved
                            backitup.0
                            	2023-03-11 17:32:25.450	debug	[iobroker/mount] done
                            backitup.0
                            	2023-03-11 17:32:25.449	debug	[iobroker/mount] mount successfully completed
                            backitup.0
                            	2023-03-11 17:32:24.758	debug	[iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=IoBroker,password=****,domain=SynologyDS218j,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.16.9/IoBroker_Backup/ /opt/iobroker/backups"
                            backitup.0
                            	2023-03-11 17:32:24.758	debug	[iobroker/mount] noserverino option: false
                            backitup.0
                            	2023-03-11 17:32:14.757	debug	Backup has started ...
                            backitup.0
                            	2023-03-11 17:32:14.702	debug	The local storage check was completed successfully. On the host "ioBroker" are currently 46262 MB free space available!
                            backitup.0
                            	2023-03-11 17:32:10.843	debug	The local storage check was completed successfully. On the host "ioBroker" are currently 46262 MB free space available!
                            backitup.0
                            	2023-03-11 17:31:49.827	debug	umount successfully completed
                            backitup.0
                            	2023-03-11 17:31:47.785	debug	mount activ... umount in 2 Seconds!!
                            backitup.0
                            	2023-03-11 17:31:40.658	debug	detect last backup file: iobroker_2023_03_11-17_30_07_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.657	debug	detect backup file 51 from NAS: iobroker_2023_03_11-17_30_07_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.656	debug	detect backup file 50 from NAS: iobroker_2023_03_11-02_40_20_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.656	debug	detect backup file 49 from NAS: iobroker_2023_03_10-21_13_02_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.656	debug	detect backup file 48 from NAS: iobroker_2023_03_10-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.656	debug	detect backup file 47 from NAS: iobroker_2023_03_10-00_15_34_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.655	debug	detect backup file 46 from NAS: iobroker_2023_03_10-00_10_34_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.655	debug	detect backup file 45 from NAS: iobroker_2023_03_09-21_26_17_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.655	debug	detect backup file 44 from NAS: iobroker_2023_03_09-21_13_59_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.655	debug	detect backup file 43 from NAS: iobroker_2023_03_09-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.655	debug	detect backup file 42 from NAS: iobroker_2023_03_08-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.654	debug	detect backup file 41 from NAS: iobroker_2023_03_07-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.654	debug	detect backup file 40 from NAS: iobroker_2023_03_06-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.654	debug	detect backup file 39 from NAS: iobroker_2023_03_05-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.654	debug	detect backup file 38 from NAS: iobroker_2023_03_04-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.653	debug	detect backup file 37 from NAS: iobroker_2023_03_03-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.653	debug	detect backup file 36 from NAS: iobroker_2023_03_02-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.653	debug	detect backup file 35 from NAS: iobroker_2023_03_01-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.653	debug	detect backup file 34 from NAS: iobroker_2023_02_28-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.652	debug	detect backup file 33 from NAS: iobroker_2023_02_27-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.652	debug	detect backup file 32 from NAS: iobroker_2023_02_26-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.652	debug	detect backup file 31 from NAS: iobroker_2023_02_25-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.652	debug	detect backup file 30 from NAS: iobroker_2023_02_24-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.651	debug	detect backup file 29 from NAS: iobroker_2023_02_23-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.651	debug	detect backup file 28 from NAS: iobroker_2023_02_22-02_40_20_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.651	debug	detect backup file 27 from NAS: iobroker_2023_02_21-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.651	debug	detect backup file 26 from NAS: iobroker_2023_02_20-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.650	debug	detect backup file 25 from NAS: iobroker_2023_02_19-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.649	debug	detect backup file 24 from NAS: iobroker_2023_02_18-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.649	debug	detect backup file 23 from NAS: iobroker_2023_02_17-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.649	debug	detect backup file 22 from NAS: iobroker_2023_02_16-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.649	debug	detect backup file 21 from NAS: iobroker_2023_02_15-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.648	debug	detect backup file 20 from NAS: iobroker_2023_02_14-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.648	debug	detect backup file 19 from NAS: iobroker_2023_02_13-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.648	debug	detect backup file 18 from NAS: iobroker_2023_02_12-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.648	debug	detect backup file 17 from NAS: iobroker_2023_02_11-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.647	debug	detect backup file 16 from NAS: iobroker_2023_02_10-02_40_20_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.647	debug	detect backup file 15 from NAS: iobroker_2023_02_09-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.647	debug	detect backup file 14 from NAS: iobroker_2023_02_08-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.646	debug	detect backup file 13 from NAS: iobroker_2023_02_07-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.646	debug	detect backup file 12 from NAS: iobroker_2023_02_06-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.646	debug	detect backup file 11 from NAS: iobroker_2023_02_05-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.645	debug	detect backup file 10 from NAS: iobroker_2023_02_04-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.645	debug	detect backup file 9 from NAS: iobroker_2023_02_03-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.644	debug	detect backup file 8 from NAS: iobroker_2023_02_02-02_40_20_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.644	debug	detect backup file 7 from NAS: iobroker_2023_02_01-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.644	debug	detect backup file 6 from NAS: iobroker_2023_01_31-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.643	debug	detect backup file 5 from NAS: iobroker_2023_01_30-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.643	debug	detect backup file 4 from NAS: iobroker_2023_01_29-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.642	debug	detect backup file 3 from NAS: iobroker_2023_01_28-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.642	debug	detect backup file 2 from NAS: iobroker_2023_01_27-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:40.641	debug	detect backup file 1 from NAS: iobroker_2023_01_26-02_40_21_backupiobroker.tar.gz
                            backitup.0
                            	2023-03-11 17:31:38.607	debug	mount successfully completed
                            backitup.0
                            	2023-03-11 17:31:37.878	debug	cifs-mount command: "sudo mount -t cifs -o username=IoBroker,password=****,domain=SynologyDS218j,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.16.9IoBroker_Backup/ /opt/iobroker/backups"
                            backitup.0
                            	2023-03-11 17:31:37.878	debug	noserverino option: false
                            backitup.0
                            	2023-03-11 17:31:37.862	info	[ccu] backup was activated at 03:00 every 1 day(s)
                            backitup.0
                            	2023-03-11 17:31:37.787	info	[iobroker] backup was activated at 02:40 every 1 day(s)
                            backitup.0
                            	2023-03-11 17:31:37.713	debug	Backitup has recognized a linux system
                            backitup.0
                            	2023-03-11 17:31:37.660	info	starting. Version 2.6.11 (non-npm: simatec/ioBroker.backitup#2831644ef6a5b9b3489d8b436e1df6a0c344e1cd) in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
                            backitup.0
                            	2023-03-11 17:31:37.322	debug	Plugin sentry destroyed because not initialized correctly
                            backitup.0
                            	2023-03-11 17:31:37.271	debug	Plugin sentry Do not initialize Plugin (enabled=false)
                            backitup.0
                            	2023-03-11 17:31:37.099	debug	States connected to redis: 127.0.0.1:9000
                            backitup.0
                            	2023-03-11 17:31:36.993	debug	States create User PubSub Client
                            backitup.0
                            	2023-03-11 17:31:36.991	debug	States create System PubSub Client
                            backitup.0
                            	2023-03-11 17:31:36.958	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                            backitup.0
                            	2023-03-11 17:31:36.892	debug	Objects connected to redis: 127.0.0.1:9001
                            backitup.0
                            	2023-03-11 17:31:36.884	debug	Objects client initialize lua scripts
                            backitup.0
                            	2023-03-11 17:31:36.757	debug	Objects create User PubSub Client
                            backitup.0
                            	2023-03-11 17:31:36.755	debug	Objects create System PubSub Client
                            backitup.0
                            	2023-03-11 17:31:36.752	debug	Objects client ready ... initialize now
                            backitup.0
                            	2023-03-11 17:31:36.657	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                            backitup.0
                            	2023-03-11 17:31:32.200	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            backitup.0
                            	2023-03-11 17:31:32.199	info	terminating
                            backitup.0
                            	2023-03-11 17:31:32.198	info	cleaned everything up...
                            backitup.0
                            	2023-03-11 17:31:32.194	info	Got terminate signal TERMINATE_YOURSELF
                            • R rotamint
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              backitup.0
                              simatecS Offline
                              simatecS Offline
                              simatec
                              @rotamint Kontrolliere mal bitte den Inhalt des Backups. Sind die 2x erstellt wurden oder hab ich nur einen Log doppelt drin.
                              Zeige mal bitte den Inhalt des zigbee2mqtt Backups
                              • simatecS simatec
                                rotamint
                                @simatec Soll ich die zigbee2mqtt_xx.tar.gz hier hochladen?
                                • R rotamint
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  @rotamint der Inhalt als Screenshot würde mir reichen
                                  • simatecS simatec
                                    rotamint
                                    • R rotamint
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      @rotamint sieht seht gut aus 😊
                                      • simatecS simatec
                                        rotamint
                                        schrieb am zuletzt editiert von rotamint
                                        @simatec Danke für Deine schnelle Hilfe. Und die rege Unterstützung aller Beteiligten, @arteck ! 👍
