  4. Deconz-Gui
    5.5k
Deconz-Gui
53 Beiträge 5 Kommentatoren 7.5k Aufrufe 3 Beobachtet
  • G Gabe
    leider habe ich das gleiche Problem mit Deconz-gui, auch bei mir startet die nicht.
    Folgende Befehle habe ich bereits ausgeführt:
    sudo systemctl stop deconz
    sudo systemctl disable deconz
    sudo systemctl enable deconz-gui
    sudo systemctl start deconz-gui
    bei systemctl status deconz deconz-gui
    ● deconz.service - deCONZ: ZigBee gateway -- REST API
         Loaded: loaded (/lib/systemd/system/deconz.service; disabled; vendor preset: enabled)
         Active: failed (Result: exit-code) since Fri 2023-03-03 10:22:04 CET; 6min ago
       Main PID: 16590 (code=exited, status=143)
            CPU: 3.083s
    Mar 03 10:21:33 raspberrypi deCONZ[16590]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
    Mar 03 10:21:33 raspberrypi deCONZ[16590]: libpng warning: iCCP: known incorrect sRGB profile
    Mar 03 10:21:34 raspberrypi deCONZ[16590]: This plugin does not support propagateSizeHints()
    Mar 03 10:21:36 raspberrypi deCONZ[16590]: This plugin does not support propagateSizeHints()
    Mar 03 10:22:02 raspberrypi systemd[1]: Stopping deCONZ: ZigBee gateway -- REST API...
    Mar 03 10:22:04 raspberrypi systemd[1]: deconz.service: Main process exited, code=exited, status=143/n/a
    Mar 03 10:22:04 raspberrypi systemd[1]: deconz.service: Failed with result 'exit-code'.
    Mar 03 10:22:04 raspberrypi systemd[1]: Stopped deCONZ: ZigBee gateway -- REST API.
    Mar 03 10:22:04 raspberrypi systemd[1]: deconz.service: Consumed 3.083s CPU time.
    ● deconz-gui.service - deCONZ: ZigBee gateway -- GUI/REST API
         Loaded: loaded (/lib/systemd/system/deconz-gui.service; enabled; vendor preset: enabled)
         Active: activating (auto-restart) (Result: signal) since Fri 2023-03-03 10:28:19 CET; 5s ago
        Process: 2500 ExecStart=/usr/bin/deCONZ --http-port=80 (code=killed, signal=ABRT)
       Main PID: 2500 (code=killed, signal=ABRT)
            CPU: 82ms
    FabioF Offline
    FabioF Offline
    Fabio
    @gabe wende dich doch mal an den Support von Dresden Elektronik https://phoscon.de/de/support hast du überhaupt deconz installiert und wenn ja wie und für welche Version sprich für welches Gerät. Hast du hier mal geschaut https://phoscon.de/de/conbee2/install
    Iobroker:
    • Matter over Thread Hilfe
    G 1 Antwort Letzte Antwort
    • FabioF Fabio
      Gabe
      @fa-bio ja alles installiert und funktioniert ja auch soweit. Nur die blöde GUI bekomme ich nicht zum laufen...
      FabioF 1 Antwort Letzte Antwort
        @gabe sagte in Deconz-Gui:
        wie ich die gui gestartet bekomme?
        Am besten gar nicht.
        Gabe
        @thomas-braun ich weiß, ich brauch die auch nur einmal um etwas auszulesen... das geht leider nur über die blöde GUI...
        • G Gabe
          FabioF Offline
          FabioF Offline
          Fabio
          @gabe prima, ich weiß aber immer noch nicht was du wie wo installiert hast.
          So kann ich nicht helfen, was willst du über die GUI auslesen. Hast du einen Stick oder das Phoscon Gateway oder Rasperry mit dem Modul von Phoscon.
          Iobroker:
          • FabioF Fabio
            Gabe
            @fa-bio hi ich habe ein Conbee II und Deconz auf einen raspberry installiert. Ich lass normalerweise nur deconz laufen und dort funktioniert alles super.
            Deconz-Gui kann ich zwar im OS anklicken, es passiert dann leider weiter nichts.
            Gruss
            Thomas BraunT FabioF 2 Antworten Letzte Antwort
            • G Gabe
              Gruss
              @gabe
              sagt?
                @gabe
                sagt?
                Gabe
                @thomas-braun sagt aktuelles das
                     Active: failed (Result: exit-code) since Fri 2023-03-10 17:21:22 CET; 1min 46s ago
                   Main PID: 17682 (code=exited, status=143)
                        CPU: 4.472s
                Mar 10 17:19:30 raspberrypi deCONZ[17682]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
                Mar 10 17:19:30 raspberrypi deCONZ[17682]: libpng warning: iCCP: known incorrect sRGB profile
                Mar 10 17:19:31 raspberrypi deCONZ[17682]: This plugin does not support propagateSizeHints()
                Mar 10 17:19:34 raspberrypi deCONZ[17682]: This plugin does not support propagateSizeHints()
                Mar 10 17:21:21 raspberrypi systemd[1]: Stopping deCONZ: ZigBee gateway -- REST API...
                Mar 10 17:21:22 raspberrypi systemd[1]: deconz.service: Main process exited, code=exited, status=143/n/a
                Mar 10 17:21:22 raspberrypi systemd[1]: deconz.service: Failed with result 'exit-code'.
                Mar 10 17:21:22 raspberrypi systemd[1]: Stopped deCONZ: ZigBee gateway -- REST API.
                Mar 10 17:21:22 raspberrypi systemd[1]: deconz.service: Consumed 4.472s CPU time.
                     Active: activating (auto-restart) (Result: signal) since Fri 2023-03-10 17:23:05 CET; 4s ago
                    Process: 23759 ExecStart=/usr/bin/deCONZ --http-port=8090 (code=killed, signal=ABRT)
                   Main PID: 23759 (code=killed, signal=ABRT)
                        CPU: 71ms
                • FabioF Offline
                  FabioF Offline
                  Fabio
                  @gabe bei mir sieht die Ausgabe so aus
                    Active: inactive (dead)
                    Active: active (running) since Thu 2023-03-09 10:47:58 CET; 1 day 7h ago
                  Main PID: 1099 (deCONZ)
                     Tasks: 16 (limit: 2059)
                    CGroup: /system.slice/deconz-gui.service
                            ├─1099 /usr/bin/deCONZ --http-port=80
                            ├─1128 dbus-launch --autolaunch ac0bc689a75d428fa91b8bc7f3aeace8 --binary-syntax --close-stderr
                            └─1129 /usr/bin/dbus-daemon --syslog-only --fork --print-pid 5 --print-address 7 --session
                  Mär 09 17:09:25 phoscon deCONZ[1099]: DJS_GetResourceEndpoints
                  Mär 09 17:09:25 phoscon deCONZ[1099]: PROTO: CRC error
                  Mär 10 02:38:08 phoscon deCONZ[1099]: DJS_GetResourceEndpoints
                  Mär 10 12:22:12 phoscon deCONZ[1099]: DJS_GetResourceEndpoints
                  Iobroker:
                  • G Gabe
                    Gruss
                    FabioF Offline
                    FabioF Offline
                    Fabio
                    @gabe läuft denn die Phoscon App? Ist auf dem Rasperry ein Desktop installiert?
                    Iobroker:
                    • FabioF Fabio
                      Gabe
                      @fa-bio beides jupp
                      • G Gabe
                        @fa-bio beides jupp
                        FabioF Offline
                        FabioF Offline
                        Fabio
                        @gabe ja das gibt es doch nicht. Sag mal hast mal probiert den Raspi runter zu fahren dann stromlos machen. Und dann noch mal versuchen. Läuft da nur ioBroker und Deconz drauf?
                        Iobroker:
                        • G Gabe
                          @fa-bio beides jupp
                          FabioF Offline
                          FabioF Offline
                          Fabio
                          schrieb am zuletzt editiert von Fabio
                          @gabe du kannst doch Deconz auch über die Desktop vom Rasperry starten müsste im Menü sein bei der Erdbeere. Schau mal nach.
                          Schau dir auch mal den link an https://github.com/dresden-elektronik/deconz-rest-plugin/issues/3415
                          Iobroker:
                          • FabioF Fabio
                            Gabe
                            @fa-bio ja öfters schon versucht
                            • FabioF Fabio
                              Gabe
                              @fa-bio ja das ist genau mein Problem. Alles ist da, nur er startet einfach nicht
                              • FabioF Fabio
                                Gabe
                                schrieb am zuletzt editiert von Gabe
                                @fa-bio ok das sieht für mich dann aber so aus, als würde er meinen service nicht richtig starten…
                                Kannst du mir mal deine deconz-gui.service zeigen
                                FabioF Thomas BraunT 2 Antworten Letzte Antwort
                                • G Gabe
                                  FabioF Offline
                                  FabioF Offline
                                  Fabio
                                  Was meinst du damit?
                                  Iobroker:
                                  • G Gabe
                                    @gabe
                                    sudo apt update
                                    apt policy deconz
                                    sagt?
                                    • G Gabe
                                      FabioF Offline
                                      FabioF Offline
                                      Fabio
                                      @gabe also fassen wir mal zusammen:
                                      1. Phoscon App läuft.
                                      Geräte werden angezeigt und können angelernt werden wie auch steuerbar.
                                      2. Das setzt zwingend vorraus das Deconz läuft.
                                      Entweder die Headless oder die GUI Version. Beides zusammen geht nicht.
                                      3. Desktop auf Rasperry ist installiert
                                      Im Menü von Rasperry wird Deconz auch angezeigt startet aber nicht.
                                      Muss/sollte aber laufen falls die GUI installiert ist, da die Phoscon App ja läuft.
                                      Dann bleibt dir nur eins übrig:
                                      Deconz stoppen,
                                      dann komplett deinstallieren,
                                      dann Rasperry neu starten,
                                      dann Deconz als GUI Version neu installieren.
                                      Dann Rasperry neu starten und sehen was passiert.
                                      Ich weiß leider nicht mehr weiter, vielleicht weiss @Thomas-Braun noch was. Ich würde dir dann dringend raten den Phoscon Support zur Rate zu ziehen oder das Forum fragen
                                      Iobroker:
                                        @gabe
                                        sudo apt update
                                        apt policy deconz
                                        sagt?
                                        Gabe
                                        @thomas-braun hier beide Ausgaben
                                        sudo apt update
                                        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                        Get:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
                                        Hit:3 http://phoscon.de/apt/deconz bullseye InRelease
                                        Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                        Fetched 15.0 kB in 1s (11.1 kB/s)
                                        Reading package lists... Done
                                        All packages are up to date.
                                        apt policy deconz
                                        deconz:
                                          Installed: 2.20.01-raspbian-buster-stable
                                          Candidate: 2.20.01-raspbian-buster-stable
                                          Version table:
                                         *** 2.20.01-raspbian-buster-stable 500
                                                500 http://phoscon.de/apt/deconz bullseye/main armhf Packages
                                        • FabioF Fabio
                                          Deconz stoppen,
                                          Gabe
                                          @fa-bio danke dir für deine Hilfe!
