  4. Flot Diagramm - history nicht wählbar
    5.5k
73 Beiträge 5 Kommentatoren 2.9k Aufrufe 4 Beobachtet
  • M Muttileinchen 0
    So ihr Profis. Alles umgesetzt. Nix gewonnen.
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Architecture:   x86_64
    Docker:         false
    Virtualization: lxc
    Distributor ID: Ubuntu
    Description:    Ubuntu 22.04.2 LTS
    Release:        22.04
    Codename:       jammy
    PRETTY_NAME="Ubuntu 22.04.2 LTS"
    NAME="Ubuntu"
    VERSION_ID="22.04"
    VERSION="22.04.2 LTS (Jammy Jellyfish)"
    VERSION_CODENAME=jammy
    ID=ubuntu
    ID_LIKE=debian
    HOME_URL="https://www.ubuntu.com/"
    SUPPORT_URL="https://help.ubuntu.com/"
    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
    UBUNTU_CODENAME=jammy
    Systemuptime and Load:
     13:50:34 up 5 min,  2 users,  load average: 0.47, 0.43, 0.22
    CPU threads: 2
    *** Time and Time Zones ***
    Fri Mar  3 13:50:34 UTC 2023
    UTC +0000
    Etc/UTC
    *** User and Groups ***
    uli
    /home/uli
    uli sudo iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            2.0G        925M        870M        0.0K        251M        1.1G
    Swap:           2.0G          0B        2.0G
    Total:          4.1G        925M        2.9G
             2048 M total memory
              926 M used memory
               95 M active memory
             1016 M inactive memory
              869 M free memory
                0 M buffer memory
              251 M swap cache
             2048 M total swap
                0 M used swap
             2048 M free swap
    *** FILESYSTEM ***
    Filesystem                       Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--101--disk--0 ext4   7.8G  2.9G  4.6G  39% /
    none                             tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                            tmpfs  1.9G     0  1.9G   0% /dev/shm
    tmpfs                            tmpfs  739M  100K  739M   1% /run
    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
    Messages in dmesg:
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
    /var:
    514M    /var/
    236M    /var/lib
    233M    /var/cache
    228M    /var/cache/apt
    142M    /var/lib/apt/lists
    /opt/iobroker/backups:
    267M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    264M    /opt/iobroker/iobroker-data/
    171M    /opt/iobroker/iobroker-data/files
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    38M     /opt/iobroker/iobroker-data/backup-objects
    32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    22M     /opt/iobroker/iobroker-data/states.jsonl
    8.5M    /opt/iobroker/iobroker-data/files/vis.0/vis/vis-views.json
    7.7M    /opt/iobroker/iobroker-data/files/vis.0/neu/vis-views.json
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.1
    /usr/bin/node           v16.19.1
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Candidate: 16.19.1-deb-1nodesource1
      Version table:
     *** 16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   1
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : IOBroker-Uli                             -  enabled
    + system.adapter.admin.0                  : admin                 : IOBroker-Uli                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : IOBroker-Uli                             -  enabled
      system.adapter.daswetter.0              : daswetter             : IOBroker-Uli                             -  enabled
    + system.adapter.discovery.0              : discovery             : IOBroker-Uli                             -  enabled
      system.adapter.dwd.0                    : dwd                   : IOBroker-Uli                             -  enabled
      system.adapter.flot.0                   : flot                  : IOBroker-Uli                             -  enabled
    + system.adapter.followthesun.0           : followthesun          : IOBroker-Uli                             -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : IOBroker-Uli                             - disabled
      system.adapter.garmin.0                 : garmin                : IOBroker-Uli                             - disabled
    + system.adapter.history.0                : history               : IOBroker-Uli                             -  enabled
      system.adapter.ical.0                   : ical                  : IOBroker-Uli                             -  enabled
      system.adapter.ical.1                   : ical                  : IOBroker-Uli                             -  enabled
      system.adapter.ical.2                   : ical                  : IOBroker-Uli                             -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : IOBroker-Uli                             -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IOBroker-Uli                             -  enabled
      system.adapter.imow.0                   : imow                  : IOBroker-Uli                             - disabled
    + system.adapter.javascript.0             : javascript            : IOBroker-Uli                             -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : IOBroker-Uli                             -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : IOBroker-Uli                             -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : IOBroker-Uli                             -  enabled
    + system.adapter.shelly.0                 : shelly                : IOBroker-Uli                             -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : IOBroker-Uli                             -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : IOBroker-Uli                             -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : IOBroker-Uli                             -  enabled
    + system.adapter.trashschedule.1          : trashschedule         : IOBroker-Uli                             -  enabled
      system.adapter.vis-bars.0               : vis-bars              : IOBroker-Uli                             -  enabled
      system.adapter.vis-history.0            : vis-history           : IOBroker-Uli                             -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IOBroker-Uli                             -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : IOBroker-Uli                             -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : IOBroker-Uli                             -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IOBroker-Uli                             -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : IOBroker-Uli                             -  enabled
      system.adapter.vis-metro.0              : vis-metro             : IOBroker-Uli                             -  enabled
      system.adapter.vis-players.0            : vis-players           : IOBroker-Uli                             -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : IOBroker-Uli                             -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : IOBroker-Uli                             -  enabled
      system.adapter.vis.0                    : vis                   : IOBroker-Uli                             -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : IOBroker-Uli                             -  enabled
    + system.adapter.web.0                    : web                   : IOBroker-Uli                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.ws.0                     : ws                    : IOBroker-Uli                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
    Adapter    "backitup"     : 2.5.12   , installed 2.5.12
    Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "followthesun" : 0.4.1    , installed 0.4.1
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "garmin"       : 0.0.3    , installed 0.0.3
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "imow"         : 0.0.2    , installed 0.0.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vw-connect"   : 0.0.62   , installed 0.0.62
    Objects and States
    Objects:        14659
    States:         13327
    Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
    Reading package lists...
    Pending Updates: 2
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          28677      1/init
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        26605      110/systemd-resolve
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          36966      713/master
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       29723      118/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       29716      118/iobroker.js-con
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       29249      195/io.mqtt.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          26456      1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          28679      1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          36967      713/master
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       29625      361/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       29820      147/io.admin.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       31899      406/io.ws.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       29355      225/io.shelly.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        26604      110/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          28678      1/init
    udp6       0      0 :::111                  :::*                                0          28680      1/init
    2023-03-03 13:48:59.607  - info: host.IOBroker-Uli iobroker upload [8] flot /opt/iobroker/node_modules/iobroker.flot/www/img/favicon.png img/favicon.png image/png
    2023-03-03 13:48:59.612  - info: host.IOBroker-Uli iobroker upload [7] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html index.html text/html
    2023-03-03 13:48:59.617  - info: host.IOBroker-Uli iobroker upload [6] flot /opt/iobroker/node_modules/iobroker.flot/www/index.html.map index.html.map application/json
    2023-03-03 13:48:59.622  - info: host.IOBroker-Uli iobroker upload [5] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js js/edit.js application/javascript
    2023-03-03 13:48:59.629  - info: host.IOBroker-Uli iobroker upload [4] flot /opt/iobroker/node_modules/iobroker.flot/www/js/edit.js.map js/edit.js.map application/json
    2023-03-03 13:48:59.642  - info: host.IOBroker-Uli iobroker upload [3] flot /opt/iobroker/node_modules/iobroker.flot/www/js/flot.js js/flot.js application/javascript
    2023-03-03 13:48:59.649  - info: host.IOBroker-Uli iobroker upload [2] flot /opt/iobroker/node_modules/iobroker.flot/www/js/flot.js.map js/flot.js.map application/json
    2023-03-03 13:48:59.663  - info: host.IOBroker-Uli iobroker upload [1] flot /opt/iobroker/node_modules/iobroker.flot/www/preset.html preset.html text/html
    2023-03-03 13:48:59.668  - info: host.IOBroker-Uli iobroker upload [0] flot /opt/iobroker/node_modules/iobroker.flot/www/preset.html.map preset.html.map application/json
    2023-03-03 13:48:59.824  - info: host.IOBroker-Uli iobroker host.IOBroker-Uli object _design/chart created/updated
    2023-03-03 13:48:59.835  - info: host.IOBroker-Uli iobroker host.IOBroker-Uli object system.adapter.flot created/updated
    2023-03-03 13:48:59.901  - info: host.IOBroker-Uli iobroker host.IOBroker-Uli create instance flot
    2023-03-03 13:48:59.916  - info: host.IOBroker-Uli iobroker host.IOBroker-Uli object system.adapter.flot.upload created
    2023-03-03 13:48:59.935  - info: host.IOBroker-Uli iobroker host.IOBroker-Uli object system.adapter.flot.0 created
    2023-03-03 13:49:00.983  - info: host.IOBroker-Uli iobroker exit 0
    2023-03-03 13:49:05.637  - info: ws.0 (406) ==> Connected system.user.admin from ::ffff:192.168.188.20
    2023-03-03 13:49:05.659  - warn: ws.0 (406) socket 1677851344901 changed socket name from selectID to flotEditDialog
    2023-03-03 13:49:38.582  - info: ws.0 (406) <== Disconnect system.user.admin from ::ffff:192.168.188.20 flotEditDialog
    2023-03-03 13:50:00.025  - info: host.IOBroker-Uli instance system.adapter.dwd.0 started with pid 777
    2023-03-03 13:50:01.194  - info: dwd.0 (777) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2023-03-03 13:50:01.374  - info: dwd.0 (777) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.1, js-controller: 4.0.24
    2023-03-03 13:50:02.691  - info: dwd.0 (777) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-03-03 13:50:03.208  - info: host.IOBroker-Uli instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-03-03 13:50:41.418  - info: ws.0 (406) ==> Connected system.user.admin from ::ffff:192.168.188.20
    2023-03-03 13:50:41.438  - warn: ws.0 (406) socket 1677851440682 changed socket name from selectID to flotEditDialog
                         v.2023-01-02
    Operatingsystem:        Ubuntu 22.04.2 LTS
    Installation:           lxc
    Timezone:               Etc/UTC
    User-ID:                1001
    X-Server:               false
    Pending OS-Updates:     2
    Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                            /usr/bin/npm            8.19.3
                            /usr/bin/npx            8.19.3
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Status admin:
    Pending iob updates:    0
    Objects:                14659
    States:                 13327
    Size of iob-Database:
    Nach Nodejs&NPM "Downgrade", User aufsetzen, Bios Update & Zeit Korrektur im Bios, Entfernung der Adapter, Neuaufsetzen der Adapter, neuaufsetzen der Datenpunkte bin ich ratlos.
    Mein Zweitsystem, gleiches Setup (mit falscher Uhrzeit ;-) ) lässt FLOT zu und läuft. 😞
    @muttileinchen-0 sagte in Flot Diagramm - history nicht wählbar:
    Etc/UTC
    Zeitzone ist nicht gesetzt.
    Das nodesource-Repository ist falsch, es gibt für ubuntu/jammy ein eigenes.
    2 OS-Updates in der Pipeline.
    Insofern richtig: Nix gewonnen, immer noch schief.
      Etc/UTC
      Muttileinchen 0
      Ich steige aus. Sytem mit Debian (wie von euch empfohlen) komplett neu aufgesetzt. Bin jetzt auf bullyeye. Backup eingespielt. IoBroker fix ausgeführt. Timezone korrigiert. Auch die Adapter History und Flot gelöscht (es sollte keinen Unterschied machen die Adapter in der Weboerfläche zu löschen oder in der Console, oder???). Adapter neu eingespielt.
      Keine Änderung. Ich bin zu doof.
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Docker:         false
      Virtualization: lxc
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
       16:22:48 up 12 min,  1 user,  load average: 1.22, 0.93, 0.96
      CPU threads: 4
      Fri Mar  3 15:22:48 UTC 2023
      Fri Mar  3 16:22:48 CET 2023
      CET +0100
      Europe/Berlin
      uli
      /home/uli
      uli sudo iobroker
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            3.7G        383M        2.6G        0.0K        661M        3.3G
      Swap:           4.1G        0.0K        4.1G
      Total:          7.8G        383M        6.7G
               3693 M total memory
                384 M used memory
                329 M active memory
                610 M inactive memory
               2647 M free memory
                  0 M buffer memory
                661 M swap cache
               4095 M total swap
                  0 M used swap
               4095 M free swap
      *** FILESYSTEM ***
      /dev/loop0     ext4      7.8G  2.5G  4.9G  34% /
      udev           devtmpfs  1.8G     0  1.8G   0% /dev/tty
      tmpfs          tmpfs     739M   96K  739M   1% /run
      Messages in dmesg:
      /      /dev/loop0 ext4   rw,relatime
      /var:
      383M    /var/
      223M    /var/cache
      219M    /var/cache/apt
      152M    /var/cache/apt/archives
      135M    /var/lib
      14M     /opt/iobroker/backups/
      178M    /opt/iobroker/iobroker-data/
      165M    /opt/iobroker/iobroker-data/files
      9.7M    /opt/iobroker/iobroker-data/objects.jsonl
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      /usr/bin/npm            8.19.3
      /usr/bin/npx            8.19.3
      nodejs:
        Version table:
           12.22.12~dfsg-1~deb11u3 500
              500 http://security.debian.org bullseye-security/main amd64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + system.adapter.ical.0                   : ical                  : IOBroker-Uli                             -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : IOBroker-Uli                             - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IOBroker-Uli                             - disabled
        system.adapter.vis-bars.0               : vis-bars              : IOBroker-Uli                             - disabled
        system.adapter.vis-history.0            : vis-history           : IOBroker-Uli                             - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IOBroker-Uli                             - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : IOBroker-Uli                             - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IOBroker-Uli                             - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : IOBroker-Uli                             - disabled
        system.adapter.vis-metro.0              : vis-metro             : IOBroker-Uli                             - disabled
        system.adapter.vis-players.0            : vis-players           : IOBroker-Uli                             - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : IOBroker-Uli                             - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : IOBroker-Uli                             - disabled
      + instance is alive
      Objects and States
      Objects:        14659
      States:         13330
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://security.debian.org bullseye-security InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
      Pending Updates: 0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          280446     1/init
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        282506     115/systemd-resolve
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       336345     3765/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       333730     3765/iobroker.js-co
      tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        282500     115/systemd-resolve
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       339305     4146/io.mqtt.0
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          283703     291/master
      tcp6       0      0 :::111                  :::*                    LISTEN      0          280448     1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          280522     1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          283704     291/master
      tcp6       0      0 :::5355                 :::*                    LISTEN      104        282503     115/systemd-resolve
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       336668     3791/io.admin.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       341913     4235/io.shelly.0
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        282505     115/systemd-resolve
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          280447     1/init
      udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        282499     115/systemd-resolve
      udp6       0      0 :::111                  :::*                                0          280449     1/init
      udp6       0      0 :::5355                 :::*                                104        282502     115/systemd-resolve
      2023-03-03 16:23:10.556  - info: host.IOBroker-Uli iobroker npm-install: Installing iobroker.garmin@0.0.3... (System call)
      2023-03-03 16:23:11.249  - info: mqtt.0 (4146) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2023-03-03 16:23:11.345  - info: mqtt.0 (4146) starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.mqtt, node: v16.19.1, js-controller: 4.0.24
      2023-03-03 16:23:11.740  - info: mqtt.0 (4146) Starting MQTT authenticated server on 0.0.0.0:1883
      2023-03-03 16:23:13.150  - info: ical.2 (4103) Terminated (NO_ERROR): Without reason
      2023-03-03 16:23:14.139  - info: host.IOBroker-Uli instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
      2023-03-03 16:23:14.168  - info: host.IOBroker-Uli instance system.adapter.ping.0 started with pid 4200
      2023-03-03 16:23:14.737  - error: host.IOBroker-Uli iobroker npm-install: host.IOBroker-Uli Cannot install iobroker.garmin@0.0.3: 1
      2023-03-03 16:23:15.544  - info: ping.0 (4200) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2023-03-03 16:23:15.616  - info: ping.0 (4200) starting. Version 1.5.3 in /opt/iobroker/node_modules/iobroker.ping, node: v16.19.1, js-controller: 4.0.24
      2023-03-03 16:23:15.760  - info: host.IOBroker-Uli iobroker npm-install: exit 25
      2023-03-03 16:23:16.760  - warn: host.IOBroker-Uli startInstance cannot find adapter "garmin@0.0.3". Try to install it... 4 attempt
      2023-03-03 16:23:16.761  - info: host.IOBroker-Uli iobroker install garmin@0.0.3 using installedVersion
      2023-03-03 16:23:17.852  - info: host.IOBroker-Uli instance system.adapter.shelly.0 started with pid 4235
      2023-03-03 16:23:18.669  - info: host.IOBroker-Uli iobroker npm-install: NPM version: 8.19.3
      2023-03-03 16:23:18.670  - info: host.IOBroker-Uli iobroker npm-install: Installing iobroker.garmin@0.0.3... (System call)
      2023-03-03 16:23:19.623  - info: shelly.0 (4235) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2023-03-03 16:23:19.756  - info: shelly.0 (4235) starting. Version 6.3.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v16.19.1, js-controller: 4.0.24
      2023-03-03 16:23:19.959  - info: shelly.0 (4235) Starting in CoAP mode. Listening on 0.0.0.0:5683
      2023-03-03 16:23:20.131  - info: shelly.0 (4235) [CoAP Server] Listening for packets in the network
      2023-03-03 16:23:21.785  - info: host.IOBroker-Uli instance system.adapter.discovery.0 started with pid 4743
      2023-03-03 16:23:23.081  - error: host.IOBroker-Uli iobroker npm-install: host.IOBroker-Uli Cannot install iobroker.garmin@0.0.3: 1
      2023-03-03 16:23:23.338  - info: discovery.0 (4743) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2023-03-03 16:23:23.453  - info: discovery.0 (4743) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.1, js-controller: 4.0.24
      2023-03-03 16:23:24.100  - info: host.IOBroker-Uli iobroker npm-install: exit 25
                           v.2023-01-02
      Operatingsystem:        Debian GNU/Linux 11 (bullseye)
      Installation:           lxc
      Timezone:               Europe/Berlin
      User-ID:                1001
      X-Server:               false
      Pending OS-Updates:     0
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Status admin:
      Objects:                14659
      States:                 13330
      11M     /opt/iobroker/iobroker-data/objects.jsonl
      3.7M    /opt/iobroker/iobroker-data/states.jsonl
      M HomoranH 2 Antworten Letzte Antwort
      • M Muttileinchen 0
        Skript v.2023-01-02
        *** BASE SYSTEM ***
        Docker:         false
        Virtualization: lxc
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 4
        CET +0100
        Europe/Berlin
        uli
        /home/uli
        uli sudo iobroker
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
                 3693 M total memory
                  384 M used memory
                  329 M active memory
                 2647 M free memory
                    0 M buffer memory
                  661 M swap cache
                 4095 M total swap
                    0 M used swap
                 4095 M free swap
        *** FILESYSTEM ***
        Messages in dmesg:
        /var:
        383M    /var/
        223M    /var/cache
        219M    /var/cache/apt
        135M    /var/lib
        /usr/bin/npm            8.19.3
        /usr/bin/npx            8.19.3
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.5
        javascript:     6.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        14659
        States:         13330
        Pending Updates: 0
                             v.2023-01-02
        Installation:           lxc
        User-ID:                1001
        X-Server:               false
                                /usr/bin/npm            8.19.3
                                /usr/bin/npx            8.19.3
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Status admin:
        Objects:                14659
        States:                 13330
        Muttileinchen 0
        @muttileinchen-0 und wie erwähnt - Zweitsystem läuft. Trotz altem Ubuntu und sonst gleichem Setup.
        • JLegJ Offline
          JLegJ Offline
          JLeg
          @muttileinchen-0
          ein guter Teil der Doku zum History-Adapter befasst sich mit der Frage, wie man ihn wieder los wird (bzw. wie man z.B. auf Influxdb umsteigen kann) ;-) Vielleicht wäre es einen Versuch - oder Test - wert, mal ein paar DPs nach Influx loggen zu lassen? Das geht ja auch parallel zum History-Adapter.
          Ansonsten - ruf' doch mal den Flot-Editor auf, nachdem du mit F12 die Browser-Konsole geöffnet hast, evtl. gibt es ein Problem mit dem JS im Frontend.
          HomoranH M 2 Antworten Letzte Antwort
          • JLegJ JLeg
            @muttileinchen-0
            @jleg sagte in Flot Diagramm - history nicht wählbar:
            das kenne ich gar nicht 😱
            hast du mal einen Link dahin?
            JLegJ 1 Antwort Letzte Antwort
            • M Muttileinchen 0
              Skript v.2023-01-02
              *** BASE SYSTEM ***
              Docker:         false
              Virtualization: lxc
              Release:        11
              Codename:       bullseye
              VERSION_ID="11"
              ID=debian
              CPU threads: 4
              CET +0100
              Europe/Berlin
              uli
              /home/uli
              uli sudo iobroker
              X-Server:       false
              Desktop:
              Terminal:
              *** MEMORY ***
                       3693 M total memory
                        384 M used memory
                        329 M active memory
                       2647 M free memory
                          0 M buffer memory
                        661 M swap cache
                       4095 M total swap
                          0 M used swap
                       4095 M free swap
              *** FILESYSTEM ***
              Messages in dmesg:
              /var:
              383M    /var/
              223M    /var/cache
              219M    /var/cache/apt
              135M    /var/lib
              /usr/bin/npm            8.19.3
              /usr/bin/npx            8.19.3
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.3.5
              javascript:     6.1.4
              Adapter State
              + instance is alive
              Objects and States
              Objects:        14659
              States:         13330
              Pending Updates: 0
                                   v.2023-01-02
              Installation:           lxc
              User-ID:                1001
              X-Server:               false
                                      /usr/bin/npm            8.19.3
                                      /usr/bin/npx            8.19.3
                                      admin                   6.3.5
              Objects type: jsonl
              States  type: jsonl
              Status admin:
              Objects:                14659
              States:                 13330
              Backup eingespielt
              dann liegt der Hund tiefer begraben, und die Ursache ist auch im Backup vorhanden.
              • JLegJ JLeg
                @muttileinchen-0
                Muttileinchen 0
                #66
                @jleg jetzt wo du es sagst, mist. Das Zweit System hat eine Influxdb, kein history, und flot läuft sauber.
                Werde nun folgendes tun:
                System mit Debian neu aufsetzen, Backup weglassen, stattdessen influx und dann beten das flot läuft. Ansonsten eben doch grafana.
                Ich verstehe einfach nicht, warum im Backup (da sind doch nur Java scripte und die Adapter drin?)probleme mit übernommen werden. .
                • M Muttileinchen 0
                  #67
                  naja, auch die vis usw.
                  Aber auch deine Systemeinstellungen.
                  Da hatte ich ja zuerst den Verdacht.
                  warum direkt an 2 Schrauben drehen?
                  history läuft bei 25.000 Usern und flot bei 15.000
                  So ein Problem müsste dann ja wesentlich öfter hier aufschlagen.
                  Mach doch erstmal ne Neunstallation ohne Backup mit flot und history
                  Wenn das läuft ist der Wurm im Backup
                    JLegJ Offline
                    JLegJ Offline
                    JLeg
                    #68
                    @homoran sagte in Flot Diagramm - history nicht wählbar:
                    …in der Adapterliste rechts auf das ? klicken - das untere Viertel dreht sich um die Migration auf eine ‚echte DB‘:
                    Wenn im Laufe der Zeit viele Daten anfallen, ist der History-Adapter möglicherweise nicht die beste Wahl und es wäre besser eine echte Datenbank zu nutzen…
                    • JLegJ JLeg
                      #69
                      das ist nicht die Doku 😁
                      aber Danke für den Hinweis!
                      Edit:
                      Die Hinweise für eine Migration der Historydaten nach influxdb oder SQL, ist aber ganz etwas anderes als deine Aussage
                      zu implizieren scheint.
                        Edit:
                        JLegJ Offline
                        JLegJ Offline
                        JLeg
                        #70
                        immerhin aber die, die man unmittelbar aus iob und ohne Google erreicht - oder?
                        Edit:
                        nämlich?
                        Was habe ich denn deiner Meinung nach impliziert (was demnach nicht dort beschrieben wird)?
                        • JLegJ JLeg
                          Edit:
                          nämlich?
                          #71
                          was ich rot markiert habe.
                          hab dazu nichts größeres gefunden
                          • JLegJ JLeg
                            Edit:
                            nämlich?
                            #72
                            die Doku ist hier in der Titelzeile verlinkt
                            ...und siehe da, dort wurde der Text auch ausgetauscht
                              JLegJ Offline
                              JLegJ Offline
                              JLeg
                              #73
                              kaum - das Implizierte wäre das, was da eben nicht steht (sondern d.M.n. beinhaltet ist).
                              Aber egal, jedenfalls wollte ich nichts ‚implizieren‘ jenseits des Expliziten, sondern nur dem TO eine weitere und recht einfache Testmöglichkeit nennen, die ohne die 7. Totalneuinstallation auskommt…
