  3. Einsteigerfragen
  4. Absturzursache Raspi und iO Broker finden
    5.5k
148 Beiträge 11 Kommentatoren 18.3k Aufrufe 9 Beobachtet
  • L Laser
    Ein Versuch:
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     10:06:57 up 1 day,  1:32,  1 user,  load average: 0.41, 0.57, 0.50
    CPU threads: 4
    *** Time and Time Zones ***
    Wed Mar  1 09:06:57 UTC 2023
    Wed Mar  1 10:06:57 CET 2023
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            1.9G        1.1G        192M        1.0M        596M        861M
    Swap:            99M        1.0M         98M
    Total:          2.0G        1.1G        291M
             1871 M total memory
             1082 M used memory
              278 M active memory
             1280 M inactive memory
              192 M free memory
               59 M buffer memory
              536 M swap cache
               99 M total swap
                1 M used swap
               98 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4      110G  3.5G  102G   4% /
    devtmpfs       devtmpfs  775M     0  775M   0% /dev
    tmpfs          tmpfs     936M     0  936M   0% /dev/shm
    tmpfs          tmpfs     375M  1.1M  374M   1% /run
    /dev/sda1      vfat      255M   50M  206M  20% /boot
    tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
    Messages in dmesg:
    [Tue Feb 28 08:34:47 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:1E:BF:CD vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=a8b32cdb-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Feb 28 08:34:49 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Tue Feb 28 08:34:49 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Tue Feb 28 08:34:52 2023] EXT4-fs (sda2): re-mounted. Opts: commit=600. Quota mode: none.
    [Tue Feb 28 08:34:56 2023] systemd[1]: Started Periodic ext4 Online Metadata Check for All Filesystems.
    [Tue Feb 28 08:34:56 2023] systemd[1]: Starting Remove Stale Online ext4 Metadata Check Snapshots...
    [Tue Feb 28 08:34:56 2023] systemd[1]: Finished Remove Stale Online ext4 Metadata Check Snapshots.
    TARGET      SOURCE    FSTYPE  OPTIONS
    /           /dev/sda2 ext4    rw,noatime,commit=600
    |-/run/owfs OWFS      fuse.OW rw,nosuid,nodev,relatime,user_id=0,group_id=0,allo
    `-/boot     /dev/sda1 vfat    rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc
    /var:
    498M    /var/
    279M    /var/cache
    274M    /var/cache/apt
    210M    /var/cache/apt/archives
    94M     /var/lib
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    530M    /opt/iobroker/iobroker-data/
    343M    /opt/iobroker/iobroker-data/history
    137M    /opt/iobroker/iobroker-data/files
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    34M     /opt/iobroker/iobroker-data/backup-objects
    9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.3d2d025f.chunk.js.map
    8.4M    /opt/iobroker/iobroker-data/objects.jsonl
    8.3M    /opt/iobroker/iobroker-data/states.jsonl
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.1
    /usr/bin/node           v16.19.1
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Candidate: 16.19.1-deb-1nodesource1
      Version table:
     *** 16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u3 500
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.1                  : admin                 : Heizung                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : Heizung                                  -  enabled
    + system.adapter.discovery.0              : discovery             : Heizung                                  -  enabled
    + system.adapter.echarts.0                : echarts               : Heizung                                  -  enabled
      system.adapter.flot.0                   : flot                  : Heizung                                  - disabled
    + system.adapter.history.0                : history               : Heizung                                  -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : Heizung                                  -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : Heizung                                  -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : Heizung                                  -  enabled, port: 0
    + system.adapter.info.0                   : info                  : Heizung                                  -  enabled
    + system.adapter.javascript.0             : javascript            : Heizung                                  -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : Heizung                                  -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : Heizung                                  -  enabled
    + system.adapter.opendtu.0                : opendtu               : Heizung                                  -  enabled
    + system.adapter.owfs.0                   : owfs                  : Heizung                                  -  enabled, port: 4304
    + system.adapter.rpi2.0                   : rpi2                  : Heizung                                  -  enabled
    + system.adapter.shelly.1                 : shelly                : Heizung                                  -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : Heizung                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.vis-bars.0               : vis-bars              : Heizung                                  - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Heizung                                  - disabled
      system.adapter.vis.0                    : vis                   : Heizung                                  -  enabled
    + system.adapter.web.0                    : web                   : Heizung                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : Heizung                                  -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.5.12   , installed 2.5.12
    Adapter    "ds18b20"      : 1.6.1    , installed 1.6.1
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hm-rega"      : 3.0.43   , installed 3.0.43
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "i2c"          : 1.2.1    , installed 1.2.1
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "owfs"         : 0.7.0    , installed 0.7.0
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        3207
    States:         2406
    ^C
    @laser
    Das ist ja nur ein Bruchteil. Scroll an den Anfang...
    Oder hol das log aus /home/iobroker/iob_diag.log ab.
    L 1 Antwort Letzte Antwort
      @laser
      Laser
      Habe Code Tags angepasst. Ein Log in iobroker finde ich nicht.
      • L Laser
        @laser
        Liegt hier:
          @laser
          Liegt hier:
          Laser
          /home/iobroker ist leer...
          • L Laser
            @laser
            ls -lah /home/iobroker
              @laser
              Laser
              pi@Heizung:/home/iobroker $ ls -lah /home/iobroker
              total 32K
              drwxr-xr-x 4 iobroker iobroker 4.0K Dec 22 15:26 .
              drwxr-xr-x 4 root     root     4.0K Dec 22 15:16 ..
              -rw-r--r-- 1 iobroker iobroker  220 Mar 27  2022 .bash_logout
              -rw-r--r-- 1 iobroker iobroker 3.5K Sep 22 02:05 .bashrc
              drwxr-xr-x 3 iobroker iobroker 4.0K Dec 22 15:26 .cache
              -rw-r--r-- 1 iobroker iobroker 1.7K Jul 10  2021 .mkshrc
              drwxr-xr-x 5 iobroker iobroker 4.0K Dec 22 16:05 .npm
              -rw-r--r-- 1 iobroker iobroker  807 Mar 27  2022 .profile
              • L Laser
                total 32K
                @laser
                Keine Ahnung was da auf deinem System krumm ist.
                Eigentlich wirft das skript ein log file da rein.
                  @laser
                  Laser
                  Ich habe vor geraumer Zeit versucht, das Logging abzuschalten, da endlose Suchen in den Logs nichts gebracht haben. Diese Orgie haben wir ja schon mal durchgemacht. Offenbar steht der Prozessor, bevor etwas in irgendein Log geschrieben wird. Das Einzige, was die Logs mit Sicherheit machen, ist, die SSD im 5 Sekunden- Abstand kaputtzuschreiben.
                  • L Laser
                    @laser sagte in Absturzursache Raspi und iO Broker finden:
                    Das log vom iob diag schreibt aber nur wenn es aufgerufen wird.
                      Laser
                      OK, was soll ich jetzt tun?
                      • L Laser
                        @laser
                        Den Mittelteil posten.
                          @laser
                          Laser
                          OK. Versuche ich. Wie kann ich den "Mittelteil" einfangen?
                          • L Laser
                            @laser
                            In meinem Terminal scrolle ich bis zur Anfangsmarkierung nach oben, wenn der Tastendruck angefragt wird und kopiere das dann bis zur Endemarkierung.
                              @laser
                              Laser
                              Habe das Fenster schon vergrößert. Ab "Copy text starting here" verschwindet der bisher aufgelistete Text. Habe schon versucht, die Ausgabe in eine Textdatei umzuleiten. Hat bisher nicht funktioniert (Permission denied). "sudo iob diag >> Fehler.txt" ist offenbar falsch
                              • L Laser
                                @laser
                                Wer sagt denn was von sudo?
                                Mir scheint, du hast dein System hinten und vorne verfummelt.
                                iob diag > iob_diag.log
                                  @laser
                                  Laser
                                  #66
                                  "Verfummelt" Das System habe ich schon x mal nach Beschreibung neu aufgesetzt. Was soll ich denn "verfummelt" haben?
                                  L Thomas BraunT 2 Antworten Letzte Antwort
                                  • L Laser
                                    Laser
                                    #67
                                    pi@Heizung:/home/iobroker $ sudo iob diag >> Fehler.log
                                    -bash: Fehler.log: Permission denied
                                    pi@Heizung:/home/iobroker $ iob diag > iob_diag.log
                                    -bash: iob_diag.log: Permission denied
                                    pi@Heizung:/home/iobroker $ sudo iob diag > iob_diag.log
                                    • L Laser
                                      #68
                                      @laser
                                      Das logging, die Rechte, was weiß ich...
                                      Jedenfalls landet in 'unverfummelten' Systemen z. B. ein log in /home/iobroker/iob_diag.log
                                      Bei dir offenbar nicht.
                                        @laser
                                        Laser
                                        schrieb am zuletzt editiert von Laser
                                        #69
                                        Ich habe nichts vorsätzlich an Rechten geändert. Warum auch?
                                        Wenn das System funktioniert, fasse ich nichts an!
                                        • L Laser
                                          #70
                                          @laser
                                          Logisch, der 'pi' darf dem iobroker nicht in dessen home schreiben.
                                          Da fehlt dem pi wohl die Gruppe 'iobroker'.
                                          Stell dich in dein /home und dann nochmal.
                                          cd ~
                                          L 2 Antworten Letzte Antwort
