  4. JavaScript
  5. Roborock Adapter tester gesucht
    6.8k
766 Beiträge 51 Kommentatoren 323.6k Aufrufe 52 Beobachtet
  • S simplyclever
    @david-g Könntest Du Blockly und VIS (Widgets?) teilen?
    David G.D Online
    David G.D Online
    David G.
    #351
    @simplyclever
    Anbei das Skript:
     <variables>
       <variable id="m*1}PM*vX/e5QPUWCX/~">raume_og</variable>
       <variable id="HGnKiadUT}LlnVPI#)V5">raume_ug</variable>
       <variable id="WF[nL{a)J(;8bBQ3kw,Q">j</variable>
     </variables>
     <block type="variables_set" id="LJG9IQ:;c(+_sG54Nbpv" x="563" y="-1213">
       <field name="VAR" id="m*1}PM*vX/e5QPUWCX/~">raume_og</field>
       <value name="VALUE">
         <block type="selector" id="YMrJZw87j]=8);ry1@f]">
           <field name="TEXT">roborock.0.Devices.7UreppMhwYr4WlSbCtcsno.floors.1.*</field>
         </block>
       </value>
       <next>
         <block type="variables_set" id="H8H5NrBhth.kWD,lWmWC">
           <field name="VAR" id="HGnKiadUT}LlnVPI#)V5">raume_ug</field>
             <block type="selector" id="+9@TR[f{`qLJ+Gt$L4f9">
               <field name="TEXT">roborock.0.Devices.7UreppMhwYr4WlSbCtcsno.floors.0.*</field>
             </block>
           </value>
           <next>
             <block type="on_ext" id="/[tZ4DhA:zBka)VD;oq:">
               <field name="CONDITION">true</field>
               <value name="OID0">
                 <shadow type="field_oid" id=")9tNYU]I]2zJRDL$yJ!L">
                 </shadow>
                 <block type="variables_get" id="f{{]lfXFJ7}HcU;T%14x">
                 </block>
               </value>
               <statement name="STATEMENT">
                 <block type="controls_forEach" id="Y,;q@xe$2!LnUQcP)|Yy">
                   <field name="VAR" id="WF[nL{a)J(;8bBQ3kw,Q">j</field>
                   <value name="LIST">
                     <block type="variables_get" id="DU8hj`D=P}-_8~k~*fTS">
                     </block>
                   </value>
                   <statement name="DO">
                     <block type="control_ex" id="zD?!9SShbd,Ky#a%!AJ%">
                       <field name="TYPE">false</field>
                       <value name="OID">
                         <shadow type="field_oid" id="Vqmc=1_*}x+nX$AOsaRb">
                           <field name="oid">Object ID</field>
                         </shadow>
                         <block type="variables_get" id="G9:X=`u[])`|5aU8+=Dw">
                         </block>
                       </value>
                         <shadow type="logic_boolean" id="[L!m2~:ZWQxe8@yU[7NP">
                         </shadow>
                       </value>
                       <value name="DELAY_MS">
                         <shadow type="math_number" id="N.HMqS+m/3H14%B3F[1|">
                           <field name="NUM">0</field>
                         </shadow>
                       </value>
                     </block>
                   </statement>
                   <next>
                     <block type="update" id="T5Nr6)3:_o*4OwlC,kkB">
                       <field name="OID">roborock.0.Devices.7UreppMhwYr4WlSbCtcsno.commands.load_multi_map</field>
                         <block type="math_number" id="lbmY(vKPJw?rI3Ly9ZVT">
                           <field name="NUM">1</field>
                         </block>
                       </value>
                     </block>
                   </next>
                 </block>
               </statement>
               <next>
                 <block type="on_ext" id="`yx429a:d#})9*}K:x5?">
                   <value name="OID0">
                     <shadow type="field_oid">
                     </shadow>
                     <block type="variables_get" id="[M6zXe5%J(zRl=5D6@AI">
                     </block>
                   </value>
                     <block type="controls_forEach" id="9b[KI}p/Vcqmi;AIOvoP">
                       <value name="LIST">
                         <block type="variables_get" id="^iD/8)NBfbWNoi)a1xWA">
                         </block>
                       </value>
                         <block type="control_ex" id="W5yI0~~A}BRZ;w]H-M5y">
                           <value name="OID">
                             </shadow>
                             <block type="variables_get" id="[Tr|(mpClG/-*BP,,SfZ">
                             </block>
                           </value>
                             <shadow type="logic_boolean" id="j}b57r;.pBj=*o$_ZC^Y">
                             </shadow>
                           </value>
                             <shadow type="math_number" id="ArP;CZy8xNW6dzENFQ[A">
                             </shadow>
                           </value>
                         </block>
                       </statement>
                       <next>
                         <block type="update" id="Wwrb?1viM#Hn+RTHv:J4">
                             <block type="math_number" id="7/b3!/qa$]8DV[^/_HXa">
                             </block>
                           </value>
                         </block>
                       </next>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </next>
     </block>
    </xml>
    Als Visu nutze ich Lovelace.
    Hast du das auch?
    • David G.D David G.
      @simplyclever
      Anbei das Skript:
       <variables>
       </variables>
           </block>
         </value>
         <next>
               </block>
             </value>
             <next>
                 <value name="OID0">
                   </shadow>
                   </block>
                 </value>
                     <value name="LIST">
                       </block>
                     </value>
                         <value name="OID">
                           </shadow>
                           </block>
                         </value>
                           </shadow>
                         </value>
                           </shadow>
                         </value>
                       </block>
                     </statement>
                     <next>
                           </block>
                         </value>
                       </block>
                     </next>
                   </block>
                 </statement>
                 <next>
                     <value name="OID0">
                       </shadow>
                       </block>
                     </value>
                         <value name="LIST">
                           </block>
                         </value>
                             <value name="OID">
                               </shadow>
                               </block>
                             </value>
                               </shadow>
                             </value>
                               </shadow>
                             </value>
                           </block>
                         </statement>
                         <next>
                               </block>
                             </value>
                           </block>
                         </next>
                       </block>
                     </statement>
                   </block>
                 </next>
               </block>
             </next>
           </block>
         </next>
       </block>
      </xml>
      Hast du das auch?
      simplyclever
      #352
      @david-g Danke! Ich benutze VIS. Aber evtl. hilft es anderen.
      • S simplyclever
        David G.D Online
        David G.D Online
        David G.
        #353
        @simplyclever
        Gerne,
        das was du auf dem Bild siehst ist easy und "nicht wert zu posten" in Lovelace.
        Das hier ist eher interessant.
        Wenn man auf "Los" drückt öffnen sich das vorherige Bild. Oben links der Status der Basis als Popup. Oben rechts der Adapterstatus.
        Bei den unteren Icons klappen die entsprechenden Dinge aus.
        Das Poste ich, wenn ich mit allem fertig bin, im Lovelace Thread.
        Da wird sich immer schön ausgetauscht.
        • David G.D Online
          David G.D Online
          David G.
          #354
          Ich habe den Adapter heute mal auf der Arbeit in einer Ubuntu VM (über vmware esxi) installiert (den-version von vor 10min) um mir die Funktionen anzuschauen die am RPI nicht klappen.
          Hier möchte sich der Adapter nicht verbinden:
          roborock.0
          2023-02-27 14:04:35.458	info	Terminated (NO_ERROR): Without reason
          roborock.0
          2023-02-27 14:04:35.457	info	terminating
          roborock.0
          2023-02-27 14:04:35.453	warn	Restart initiated
          roborock.0
          2023-02-27 14:04:35.436	error	Connection timed out! Deleting UserData and trying again
          roborock.0
          2023-02-27 14:04:30.435	info	MQTT initialized
          roborock.0
          2023-02-27 14:04:29.442	info	starting. Version 0.0.10-alpha.0 (non-npm: copystring/ioBroker.roborock#dev) in /opt/iobroker/node_modules/iobroker.roborock, node: v14.19.3, js-controller: 4.0.21
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            wendy2702W Online
            wendy2702W Online
            #355
            @david-g sagte in Roborock Adapter tester gesucht:
            Zu wenig infos.
            Welche Ubuntu Version?
            NodeJS?
            NPM?
            Log im Debug mode
            • David G.D Online
              David G.D Online
              David G.
              #356
              @wendy2702
              Bleibt nun grün.
              Die Firewall hat den Adapter irgendwie geblockt. Mal sehen warum (hab Sie grad zum Test kurz deaktiviert).
                @copystring
                So,
                habe getestet. Es klappt.
                Allerdings war es wohl ein Fehler meinerseits.
                Ich muss (wie ich jetzt gemerkt habe) erst die Multimap der Etage laden, und dann die Reinigung starten.
                Das bekomme ich aber leicht in einem Skript eingebaut.
                EDIT:
                Hab mir ein Blockly geschrieben, um sicherzugehen, dass ich nur Räume in einer Etage aktiv habe und wähle dementsprechend die entsprechende Map aus.
                So kann man in der Visu nichts falsch machen:
                Aber eine andere Frage:
                Bei jedem Start sende ich vorab noch die Saugleistung und Wassermenge über set_water_box_custom_mode und set_custom_mode.
                Die Beiden Datenpunkte stehen in meiner Visualisierung zum dropdown bereit.
                Das mache ich, da meine Frau das ggf zwischenzeitlich per App geändert haben könnte.
                Ist es möglich die beiden Datenpunkte unter commands vom Adapter aus mit dem Roboter synchron zu halten?
                So müsste man/ich es nicht immer mit senden und man sieht die aktuelle Einstellung in seiner Auswahl.
                copystringC Offline
                copystringC Offline
                copystring
                #357
                @david-g said in Roborock Adapter tester gesucht:
                @copystring
                So,
                Genau. Die Karte muss ausgewählt sein damit dort entsprechenden gesaugt wird.
                EDIT:
                Es reicht tatsächlich aus nur die Karte auszuwählen. Den Rest macht der Adapter automatisch. Das bedeutet es werden nur die Räume zum Reinigen abgeschickt, welche auf auf der aktuellen Karte verfügbar sind. Dadurch muss man nicht jedes mal die zu reinigenden Räume ändern.
                Ähm nein. Das baue ich bewusst nicht ein da die commands, wie der Name schon verrät, einfach nur Befehle sind. Dort wird absichtlich nichts gelesen weil der echte wert von z.B. water_box_custom_mode unter deviceStatus zu finden ist. Synchron ist also alles unter deviceStatus. Diese nehmen auch die Daten aus der App entsprechend an. Wenn du dann über den Adapter set_water_box_custom_mode ausführst taucht genau so unter deviceStatus auf wie aus der App.
                Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
                https://paypal.me/copystring
                David G.D 2 Antworten Letzte Antwort
                • copystringC Offline
                  copystringC Offline
                  copystring
                  schrieb am zuletzt editiert von copystring
                  #358
                  Ich brauche mal eure Hilfe.
                  Es geht darum, die echten Werte der Verbrauchsmaterialien des Saugroboters zu bekommen.
                  Bei mir sind das diese: Filter, Main Brush, Side Brush.
                  In der aktuellen dev branch von gerade eben wird nicht mehr wie zuvor HomeData nur ein mal beim Einrichten des Adapters aktualisiert, sondern bei jedem Reconnect. Dadurch werden selbstverständlich einige weitere Daten zur Verfügung gestellt.
                  In diesem Fall geht es um drei Werte im JSON String unter deviceStatus von HomeData.: 125, 126,127
                  Diese haben bei mir folgende Bedeutung:
                  • 125 = Main Brush
                  • 126 = Side Brush
                  • 127 = Filter
                  Von jedem Wert dann jeweils 1 abziehen. Das sollte dann dem Wert in der App entsprechen.
                  Klappt das bei euch auch würde ich das tatsächlich einbauen. Dadurch erhalten wir alle drei Stunden (oder bei Reconnect) die echten Werte in Prozent der Verbrauchsmaterialien, ohne für jeden Roboter eine eigene Berechnung durchführen zu müssen.
                  • copystringC copystring
                    @copystring
                    So,
                    EDIT:
                    David G.D Online
                    David G.D Online
                    David G.
                    #359
                    @copystring sagte in Roborock Adapter tester gesucht:
                    Ähm nein. Das baue ich bewusst nicht ein da die commands......
                    Okay, danke für die Info. Dann schaue ich mal, wie man das in der Visu schlau umsetzt um sich nicht von den "falschen" Werten irritieren zu lassen.
                    Gibt es die Werte schon irgendwo?
                    In der Json hab ich was stehen, hier exemplarisch ein Wert.
                              "id": "125",
                              "name": "主刷寿命",
                              "code": "main_brush_life",
                              "mode": "rw",
                              "type": "VALUE",
                              "property": "{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}",
                              "desc": null
                      copystringC Offline
                      copystring
                      #360
                                "id": "125",
                                "name": "主刷寿命",
                                "mode": "rw",
                                "type": "VALUE",
                                "desc": null
                      Ja weiter unten im deviceStatus
                                  "id": "125",
                                  "name": "主刷寿命",
                                  "mode": "rw",
                                  "type": "VALUE",
                                  "desc": null
                        David G.D Online
                        David G.D Online
                        David G.
                        #361
                        @copystring
                        Gefunden
                              "deviceStatus": {
                                "120": 0,
                                "121": 8,
                                "122": 79,
                                "123": 102,
                                "124": 203,
                                "125": 99,
                                "126": 99,
                                "127": 98,
                                "128": 0,
                                "133": 1
                        Stimmt bei mir aber nicht mit den Daten in der App überein (auch nicht mit -1).
                        copystringC 1 Antwort Letzte Antwort
                          @copystring
                          Gefunden
                                "deviceStatus": {
                                  "120": 0,
                                  "121": 8,
                                  "122": 79,
                                  "123": 102,
                                  "124": 203,
                                  "125": 99,
                                  "126": 99,
                                  "127": 98,
                                  "128": 0,
                                  "133": 1
                          copystringC Offline
                          copystringC Offline
                          copystring
                          #362
                          @david-g OK. Mal bitte in ioBroker checken, wann HomeData zuletzt geschrieben wurden. Sind das vielleicht alte Daten?
                            David G.D Online
                            David G.D Online
                            David G.
                            #363
                            In der Tat.
                            Ist vom 19.2
                              In der Tat.
                              Ist vom 19.2
                              copystringC Offline
                              copystringC Offline
                              copystring
                              #364
                              @david-g aber die aktuelle dev branch ist installiert? Die schreibt bei jedem Start die Daten neu.
                                David G.D Online
                                David G.D Online
                                David G.
                                #365
                                @copystring
                                Ja, gestern Abend nach deinem Post mit der Bitte zu testen installiert.
                                Installiere gleich nochmal drüber.
                                EDIT
                                Jetzt stimmen die Werte.
                                Braucht das auf git ggf kurz bis die aktuellste Version ausgeliefert wird?
                                   "deviceStatus": {
                                        "120": 0,
                                        "121": 8,
                                        "122": 22,
                                        "123": 104,
                                        "124": 201,
                                        "125": 96,
                                        "126": 94,
                                        "127": 92,
                                        "128": 0,
                                        "133": 1
                                Die Werte sind zum Screenshot oben wirklich was gesunken.
                                  @copystring
                                  So,
                                  EDIT:
                                  David G.D Online
                                  David G.D Online
                                  David G.
                                  #366
                                  Da habe ich doch nochmal eine Frage zu.
                                  Wie würdest du einen parallelen Betrieb der App und Iobroker dann in einer Visualisierung umsetzen?
                                  Ich sehe mehrere Varianten, die aber alle Nachteile haben.
                                  Man zeigt in der Visu den Wert unter commands und steuert auch darüber. Diese Werte sind aber veraltet, falls zuvor die App genutzt wurde
                                  Ich zeige den Wert von deviceStatus und mache zusätzlich ein dropdown mit den Werten aus commands. Sieht aber a nicht gut aus und kann b zu Problemen führen wenn ich die Saugleistung zb in der App aktuell auf stark stehen habe, diese über den Adapter auf leise stellen möchte und diese unter commands bereits auf leise steht. Dann müsste man immer erst was anderes auswählen und dann wieder auf leise gehen.
                                  Wie ich es jetzt mache. In der VIS wie unter 1 und ein Blockly was commands mit deviceStatus syncon hält. Der Nachteil ist, dass man jede akustische Meldung doppelt bekommt mit einigen Sekunden Versatz. Ist von der Bedienung her die beste Variante,abgesehen von dem doppelten Geräusch.
                                    copystringC Offline
                                    copystringC Offline
                                    copystring
                                    #367
                                    @david-g Schau dir mal aliase an. Dort kann man getter und setter einstellen.
                                    Set wäre dann command und get entsprechend der Status aus deviceStatus.
                                    Den alias dann in vis verwenden.
                                    Das hat den auch den Vorteil, dass wenn man den Roboter Mal tauschen muss reicht es aus die aliase anzupassen und in vis muss nichts geändert werden.
                                      David G.D Online
                                      David G.D Online
                                      David G.
                                      #368
                                      @copystring
                                      Das stimmt, mit dem Alias arbeite ich auch schon recht viel. Aber daran habe ich nicht gedacht....
                                      So hat man dann vermutlich nach der Eingabe nur eine Verzögerung bis der echte neue Wert angezeigt wird (der Adapter wieder Daten geholt hat)
                                      Umgeht das Alias auch das Problem von 2b?
                                        @copystring
                                        copystringC Offline
                                        copystringC Offline
                                        copystring
                                        #369
                                        @copystring
                                        Ich glaube schon. Am besten einfach Mal ausprobieren.
                                          @copystring
                                          David G.D Online
                                          David G.D Online
                                          David G.
                                          #370
                                          @copystring
                                          Beobachte es mal.
                                          Hab mir jetzt alle Aliase erstellt.
                                          Da ist mir bei Mop_Mode was aufgefallen.
                                          Auf Deep+ steht er bei commands auf 302 und bei deviceStatus auf 303. Vermutlich ein Fehler oder?
                                          EDIT
                                          Das mit dem Alias klappt gut.
                                          Das befürchtete Problem scheint es nicht zu geben. Bekomme es zumindest nicht provoziert.
