Solarman PV, Bosswerk MI & Deye
@rene55 Ich bin nicht ganz sicher, ob ich die Frage richtig verstehe. Du brauchst ein Gerät, auf dem ein Venus OS läuft (bei mir ist es ein Cerbo GX, kann aber auch ein Raspi sein). Dort kann man dann Modbus aktivieren:
Und dann über die Netzwerkadresse des GX Gerätes ansprechen:
@Rene55 Ich bekomme jetzt ziemlich viele Fehlermeldungen:
solarmanpv.0 2023-02-13 12:52:13.064 error DB closed solarmanpv.0 2023-02-13 12:52:13.063 error Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (events.js:520:26) at Socket.emit (events.js:400:28) at TCP.<anonymous> (net.js:686:12) solarmanpv.0 2023-02-13 12:52:13.062 error unhandled promise rejection: DB closed solarmanpv.0 2023-02-13 12:52:13.046 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). solarmanpv.0 2023-02-13 12:52:13.018 error DB closed solarmanpv.0 2023-02-13 12:52:13.017 error Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (events.js:520:26) at Socket.emit (events.js:400:28) at TCP.<anonymous> (net.js:686:12) solarmanpv.0 2023-02-13 12:52:12.991 error unhandled promise rejection: DB closed solarmanpv.0 2023-02-13 12:52:12.989 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). solarmanpv.0 2023-02-13 12:52:12.986 error DB closed solarmanpv.0 2023-02-13 12:52:12.966 error Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (events.js:520:26) at Socket.emit (events.js:400:28) at TCP.<anonymous> (net.js:686:12) solarmanpv.0 2023-02-13 12:52:12.965 error unhandled promise rejection: DB closed solarmanpv.0 2023-02-13 12:52:12.963 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). solarmanpv.0 2023-02-13 12:52:12.944 error DB closed solarmanpv.0 2023-02-13 12:52:12.926 error Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (events.js:520:26) at Socket.emit (events.js:400:28) at TCP.<anonymous> (net.js:686:12) solarmanpv.0 2023-02-13 12:52:12.925 error unhandled promise rejection: DB closed -
@bambulko Das sieht nicht so gut aus. Kamen die Fehler beim Start oder beim Beenden des Adapters - oder einfach so?
@ralf-roessler Ok, stabiles Internet ist schon mal gut. Ich geh mal davon aus, dass die Bandbreite eventuell durch HomeOffice / Videostreaming nicht voll ausgereizt ist. Aber dann fällt mir auch schon nichts mehr ein.
@rene55 Seit heute kann ich das auch durchgängig beobachten. Beim Neustart des Adapters wird einmal sauber eingelesen - alle folgenden Starts (per cron) laufen auf das Timeout. Internet ist stabil. Probleme mit der China-Cloud? In der (Handy-)App bekomme ich alle Daten aktuell angezeigt.
@typhos laeuft hier einwandfrei, keine Probleme mit Timeouts..
@typhos Da bin ich dann auch ein bisschen überfragt. Ich hatte gerade einen Ausfall des Accesspoints, an dem mein Inverter hängt. Da bekam ich dann auch aus der ChinaCloud mehrere unbeantwortete Abfragen:
2023-02-15 11:18:05.208 warn [getDeviceData] error: undefined. Ob es damit zusammenhängt ? ? ? -
@ilovegym Komisch... Wenn ich den Request per curl von der Maschine aus mache, funktioniert es immer wunderbar... aus dem Adapter irgendwie nicht mehr. Jemand eine Idee, was das sein könnte oder was man noch prüfen könnte?
@typhos ich hab 2 Stueck, laufen. Hast du irgendn Blocker Pihole oder sowas drin?
2023-02-15 11:18:05.208 warn [getDeviceData] error: undefined. Ob es damit zusammenhängt ? ? ?@rene55 Ich denke nicht... was ich beobachten konnte, ist, dass ein schnell wiederholter Request deutlich schneller geht - vermutlich cachen die Jungs in der Cloud die Responses ein paar Sekunden. Ich habe dann testweise mal den Adapter auf Start alle 30 Sekunden gestellt, dann bekomme ich so ziemlich jedes 2. Mal ne vernünftige Antwort (vermutlich dann immer die gecachte vom vorherigen Request, der auf einen Timeout gelaufen ist)...
Wäre es möglich, dass man den Timeout mal selbst setzen kann im Adapter? Vielleicht ist es - aus welchen Gründen auch immer - mit 4s doch ein bisschen eng? Auch wenn ich das Gefühl habe, dass die Requests per curl schneller sind als 4s. -
Der Adapter sieht ja echt super aus, zumindest was ich so gesehen habe. Vielleicht kann mir ja jemand weiter helfen, ich installiere Ihn, dann kommt der automatische Wechsel zur Instanzen und es passiert nix mehr ???
@beauceron Browsercache ?
@typhos Ich hab schon von Version 0.2.0 (2 Sekunden) in Version 0.2.2 auf 4 Sekunden hochgesetzt. Ich selber glaube nicht, dass ich deswegen weniger TimeOuts hatte. Parametrierbar ist das nur im Quellcode.
@rene55 Ich habe den Cronjob jetzt so eingestellt, dass der Adapter alle 6 Minuten 2 mal hintereinander (im Abstand von 30 Sekunden) startet. Damit funktioniert es "zuverlässig". Ich werde das mal weiter beobachten - da ich das Problem erst heute habe, denk ich trotzdem irgendwie, dass es an der Cloud liegt... keine Ahnung...
@rene55 extra gerade noch Firefox installiert. Leider keine Veränderung. Aber es kommt ein Fenster "[JsonConfig] Cannot parse json5 config!"
@beauceron Wie hast du das installiert?
@beauceron Ok, schon mal gut. Welche Version von node.js und welche vom Admin?
